C-HVAC01-E3-KIT
C-HVAC01-E3-KIT
    TDK(东电化)
    SMD
    KIT MLCC HI-VOLT 10PF-.047UF SMD
C-HVAC01-E3-KIT 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS May 2022 MULTILAYER CERAMIC CHIP CAPACITORS Commercial grade, high voltage (1,000V and over) C series C3216 C3225 C4520 C4532 C5750 [EIA 1206] [EIA 1210] [EIA 1808] [EIA 1812] [EIA 2220] * Dimensions code: JIS[EIA] (2/10) MULTILAYER CERAMIC CHIP CAPACITORS REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS 1. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (excepting Pharmaceutical Affairs Law classification Class1,2) (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 2. We may modify products or discontinue production of a product listed in this catalog without prior notification. 3. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. 4. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export permission in harmony with this law. 5. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. 6. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. 7. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging specification detail. This new catalog number should be referenced on all catalog orders going forward, and is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will differ from the item description (internal control number) on the product label. Contact your local TDK Sales representative for more information. (Example) Catalog issued date Prior to January 2013 January 2013 and later Catalog number C1608C0G1E103J(080AA) C1608C0G1E103J080AA Item description (on delivery label) C1608C0G1E103JT000N C1608C0G1E103JT000N 20220510 / mlcc_commercial_highvoltage_en.fm (3/10) MULTILAYER CERAMIC CHIP CAPACITORS C series Cl Br High voltage (1,000V and over) RoHS REACH Halogen Free SVHC-Free Pb Lead Free Type: C3216 [EIA 1206], C3225 [EIA 1210], C4520 [EIA 1808], C4532 [EIA 1812], C5750 [EIA 2220] ■ SERIES OVERVIEW High voltage C series, commercial grade of TDK's multilayer ceramic chip capacitor, is a product having a high withstanding voltage characteristic. The lineup is voltage rating of 1,000V to 3,000V with capacitance range up to 47nF. ■ FEATURES ■ APPLICATIONS • Voltage rating of 1,000V, 2,000V and 3,000V • Operating temperature range: –55 to +125°C • C0G type having excellent stable temperature and DC-bias characteristics is also available • Decoupling, snubber and resonant circuits of high voltage circuits • Wireless charging units, DC-DC converter, Inverter ■ SHAPE & DIMENSIONS ■ RECOMMENDED CONDITIONS Slit to improve washing flux W L PC T B L W T B SD PB Body length Body width Body height Terminal width Type L W C3216 3.20±0.20 1.60±0.20 C3225 3.20±0.40 2.50±0.30 C4520 4.50±0.40 2.00±0.20 C4532 4.50±0.40 3.20±0.40 C5750 5.70±0.40 5.00±0.40 Dimensional tolerances are typical values. PA • It is recommended to provide a slit (about 1mm width) in the board under the components to improve washing flux. • Please make sure to dry detergent up completely before. • It is recommended to use low activated flux (Chlorine content: less than 0.1wt%) such rosin due to high voltage usage. • When mounting on an aluminum substrate, it is more likely to be affected by heat stress from the substrate. Please inquire separate specification when mounted on the substrate. T 1.30±0.20 2.50±0.30 2.00±0.20 2.50±0.30 2.80±0.30 Dimensions in mm B 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20220510 / mlcc_commercial_highvoltage_en.fm (4/10) MULTILAYER CERAMIC CHIP CAPACITORS ■ CATALOG NUMBER CONSTRUCTION C 5750 X7S (1) (2) (3) 3A 473 K 250 K A (4) (5) (6) (7) (8) (9) (1) Series (8) Packaging style (2) Dimensions L x W (mm) Code A K Code C3216 C3225 C4520 C4532 C5750 EIA 1206 1210 1808 1812 2220 Length 3.20 3.20 4.50 4.50 5.70 Width 1.60 2.50 2.00 3.20 5.00 Terminal width 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. Style 178mm reel, 4mm pitch 178mm reel, 8mm pitch (9) Special reserved code Code A,C Description TDK internal code (3) Temperature characteristics Temperature characteristics C0G CH JB X7R X7S Temperature coefficient or capacitance change 0±30 ppm/°C 0±60 ppm/°C ±10% ±15% ±22% Temperature range –55 to +125°C –25 to +85°C –25 to +85°C –55 to +125°C –55 to +125°C (4) Rated voltage (DC) Code 3A 3D 3F Voltage (DC) 1,000V 2,000V 3,000V (5) Nominal capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. (Example)0R5 = 0.5pF 101 = 100pF 225 = 2,200,000pF = 2.2µF (6) Capacitance tolerance Code F J K M Tolerance ±1pF ±5% ±10% ±20% (7) Thickness Code 085 110 130 160 200 230 250 280 Thickness 0.85 mm 1.10 mm 1.30 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm 2.80 mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20220510 / mlcc_commercial_highvoltage_en.fm (5/10) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) 100 220 470 1,000 2,200 C3216 [EIA 1206] X7S Code 3D (2kV) 3A (1kV) 101 221 471 102 222 Standard thickness   0.85 mm  1.30 mm ■For details such as the catalog numbers, please refer to the capacitance range table on page 8 and after. Capacitance range chart Capacitance (pF) 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 12,000 15,000 18,000 22,000 Code C0G 3A (1kV) C3225 [EIA 1210] X7S 3D (2kV) 3A (1kV) 102 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 Standard thickness   1.60 mm  2.00 mm  2.30 mm  2.50 mm ■For details such as the catalog numbers, please refer to the capacitance range table on page 8 and after. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20220510 / mlcc_commercial_highvoltage_en.fm (6/10) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) Code 10 12 15 18 22 27 33 39 47 56 68 82 100 470 1,000 C0G CH 3F (3kV) 3F (3kV) C4520 [EIA 1808] JB 3D (2kV) X7R 3A (1kV) 3D (2kV) 3A (1kV) 100 120 150 180 220 270 330 390 470 560 680 820 101 471 102 Standard thickness   0.85 mm  1.10 mm  1.30 mm  1.60 mm  2.00 mm Background gray: These products are not recommended for new designs. ■For details such as the catalog numbers, please refer to the capacitance range table on page 8 and after. Capacitance range chart Capacitance (pF) 100 120 150 180 220 270 330 2,200 4,700 10,000 Code C0G CH 3F (3kV) 3F (3kV) C4532 [EIA 1812] JB 3D (2kV) X7R 3A (1kV) 3D (2kV) 3A (1kV) 101 121 151 181 221 271 331 222 472 103 Standard thickness   1.30 mm  1.60 mm  2.00 mm  2.30 mm  2.50 mm Background gray: These products are not recommended for new designs. ■For details such as the catalog numbers, please refer to the capacitance range table on page 8 and after. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20220510 / mlcc_commercial_highvoltage_en.fm (7/10) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) 4,700 10,000 12,000 15,000 18,000 22,000 27,000 33,000 47,000 C0G Code 3A (1kV) C5750 [EIA 2220] X7S 3D (2kV) 3A (1kV) 472 103 123 153 183 223 273 333 473 Standard thickness   1.60 mm  2.00 mm  2.50 mm  2.80 mm Background gray: These products are not recommended for new designs. ■For details such as the catalog numbers, please refer to the capacitance range table on page 8 and after. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20220510 / mlcc_commercial_highvoltage_en.fm (8/10) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions 10pF 12pF 15pF 18pF 22pF 27pF 33pF 39pF 47pF 56pF 68pF 82pF 100pF 120pF 150pF 180pF 220pF 270pF 330pF 1nF 1.2nF 1.5nF 1.8nF 2.2nF 2.7nF 3.3nF 3.9nF 4.7nF 5.6nF 6.8nF 8.2nF 10nF 12nF 15nF 18nF 22nF 27nF 33nF 4520 4520 4520 4520 4520 4520 4520 4520 4520 4520 4520 4520 4520 4532 4532 4532 4532 4532 4532 4532 3225 3225 3225 3225 3225 3225 3225 3225 3225 3225 3225 3225 3225 5750 3225 5750 3225 5750 3225 5750 3225 5750 5750 5750 Temperature characteristic: C0G (–55 to +125°C, 0±30ppm/°C) Thickness (mm) Capacitance tolerance Catalog number Rated voltage Edc: 3kV 0.85±0.15 ±1pF ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% C4520C0G3F100F085KA 0.85±0.15 1.10±0.20 1.10±0.20 1.10±0.20 1.60±0.20 1.60±0.20 1.60±0.20 1.60±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 1.60±0.20 1.60±0.20 1.60±0.20 1.60±0.20 2.00±0.20 2.30±0.20 2.50±0.30 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.30±0.20 2.50±0.30 2.80±0.30 2.50±0.30 2.80±0.30 2.50±0.30 2.80±0.30 2.50±0.30 2.80±0.30 2.50±0.30 2.80±0.30 2.80±0.30 2.80±0.30 Rated voltage Edc: 1kV C4520C0G3F120K085KA C4520C0G3F150K110KA C4520C0G3F180K110KA C4520C0G3F220K110KA C4520C0G3F270K160KA C4520C0G3F330K160KA C4520C0G3F390K160KA C4520C0G3F470K160KA C4520C0G3F560K200KA C4520C0G3F680K200KA C4520C0G3F820K200KA C4520C0G3F101K200KA C4532C0G3F101K160KA C4532C0G3F121K160KA C4532C0G3F151K160KA C4532C0G3F181K160KA C4532C0G3F221K200KA C4532C0G3F271K230KA C4532C0G3F331K250KA C3225C0G3A102J200AC C3225C0G3A122J200AC C3225C0G3A152J200AC C3225C0G3A182J200AC C3225C0G3A222J200AC C3225C0G3A272J200AC C3225C0G3A332J200AC C3225C0G3A392J200AC C3225C0G3A472J200AC C3225C0G3A562J200AC C3225C0G3A682J200AC C3225C0G3A822J230AC C3225C0G3A103J250AC C5750C0G3A103J280KC C3225C0G3A123J250AC C5750C0G3A123J280KC C3225C0G3A153J250AC C5750C0G3A153J280KC C3225C0G3A183J250AC C5750C0G3A183J280KC C3225C0G3A223J250AC C5750C0G3A223J280KC C5750C0G3A273J280KC C5750C0G3A333J280KC ■ Gray items: These products are not recommended for new designs. Click the part numbers for details. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20220510 / mlcc_commercial_highvoltage_en.fm (9/10) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions 10pF 12pF 15pF 18pF 22pF 27pF 33pF 39pF 47pF 56pF 68pF 82pF 100pF 120pF 150pF 180pF 220pF 270pF 330pF 4520 4520 4520 4520 4520 4520 4520 4520 4520 4520 4520 4520 4520 4532 4532 4532 4532 4532 4532 4532 Thickness (mm) Capacitance tolerance 0.85±0.15 ±1pF ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% 0.85±0.15 1.10±0.20 1.10±0.20 1.10±0.20 1.60±0.20 1.60±0.20 1.60±0.20 1.60±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 1.60±0.20 1.60±0.20 1.60±0.20 1.60±0.20 2.00±0.20 2.30±0.20 2.50±0.30 Temperature characteristic: CH (–25 to +85°C, 0±60ppm/°C) Catalog number Rated voltage Edc: 3kV C4520CH3F100F085KA C4520CH3F120K085KA C4520CH3F150K110KA C4520CH3F180K110KA C4520CH3F220K110KA C4520CH3F270K160KA C4520CH3F330K160KA C4520CH3F390K160KA C4520CH3F470K160KA C4520CH3F560K200KA C4520CH3F680K200KA C4520CH3F820K200KA C4520CH3F101K200KA C4532CH3F101K160KA C4532CH3F121K160KA C4532CH3F151K160KA C4532CH3F181K160KA C4532CH3F221K200KA C4532CH3F271K230KA C4532CH3F331K250KA ■ Gray items: These products are not recommended for new designs. Click the part numbers for details. Capacitance range table Capacitance Dimensions Thickness (mm) 470pF 4520 1.30±0.20 1nF 4520 1.30±0.20 2.2nF 4532 1.30±0.20 4.7nF 4532 1.60±0.20 10nF 4532 2.00±0.20 Temperature characteristic: JB (–25 to +85°C, ±10%) Capacitance tolerance Catalog number Rated voltage Edc: 2kV ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% C4520JB3D471K130KA C4520JB3A471K130KA C4520JB3D471M130KA C4520JB3A471M130KA Rated voltage Edc: 1kV C4520JB3D102K130KA C4520JB3A102K130KA C4520JB3D102M130KA C4520JB3A102M130KA C4532JB3D222K130KA C4532JB3D222M130KA C4532JB3A472K160KA C4532JB3A472M160KA C4532JB3A103K200KA C4532JB3A103M200KA ■ Gray items: These products are not recommended for new designs. Click the part numbers for details. Capacitance range table Capacitance Dimensions Thickness (mm) 470pF 4520 1.30±0.20 1nF 4520 1.30±0.20 2.2nF 4532 1.30±0.20 4.7nF 4532 1.60±0.20 10nF 4532 2.00±0.20 Temperature characteristic: X7R (–55 to +125°C, ±15%) Capacitance tolerance Catalog number Rated voltage Edc: 2kV Rated voltage Edc: 1kV ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% C4520X7R3D471K130KA C4520X7R3A471K130KA C4520X7R3D471M130KA C4520X7R3A471M130KA C4520X7R3D102K130KA C4520X7R3A102K130KA C4520X7R3D102M130KA C4520X7R3A102M130KA C4532X7R3D222K130KA C4532X7R3D222M130KA C4532X7R3A472K160KA C4532X7R3A472M160KA C4532X7R3A103K200KA C4532X7R3A103M200KA ■ Gray items: These products are not recommended for new designs. Click the part numbers for details. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20220510 / mlcc_commercial_highvoltage_en.fm (10/10) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions 100pF 220pF 470pF 1nF 2.2nF 4.7nF 10nF 22nF 47nF 3216 3216 3216 3216 3225 3216 3225 3225 5750 5750 5750 5750 Thickness (mm) 0.85±0.15 0.85±0.15 1.30±0.20 0.85±0.15 2.00±0.20 1.30±0.20 2.50±0.30 1.60±0.20 2.00±0.20 2.50±0.30 1.60±0.20 2.50±0.30 Temperature characteristic: X7S (-55 to +125℃, ±22%) Capacitance tolerance Catalog number Rated voltage Edc: 2kV ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% C3216X7S3D101K085AA Rated voltage Edc: 1kV C3216X7S3D221K085AA C3216X7S3D471K130AA C3216X7S3A102K085AA C3225X7S3D102K200AA C3216X7S3A222K130AA C3225X7S3D222K250AA C3225X7S3A472K160AA C5750X7S3D472K200KA C5750X7S3D103K250KA C5750X7S3A223K160KA C5750X7S3A473K250KA Click the part numbers for details. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20220510 / mlcc_commercial_highvoltage_en.fm
C-HVAC01-E3-KIT 价格&库存
很抱歉,暂时无法提供与“C-HVAC01-E3-KIT”相匹配的价格&库存,您可以联系我们找货
