C1005X7R1H472K/50
C1005X7R1H472K/50
    TDK(东电化)
    贴片电容(MLCC) 0402 4700pF ±10% 50V X7R
C1005X7R1H472K/50 数据手册
C Series General Application Type: C0402 [EIA CC01005] C0603 [EIA CC0201] C1005 [EIA CC0402] C1608 [EIA CC0603] C2012 [EIA CC0805] C3216 [EIA CC1206] C3225 [EIA CC1210] C4532 [EIA CC1812] C5750 [EIA CC2220] Issue date: April 2011 TDK MLCC US Catalog Version B11 REMINDERS Please read before using this product SAFETY REMINDERS REMINDERS 1. 2. 3. 4. 5. 6. 7. If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other damage, you must contact our company’s sales window. We may modify products or discontinue production of a product listed in this catalog without prior notification. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export permission in harmony with this law. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. TDK MLCC US Catalog Page 4 Version B11 C Series General Application Type: C0402, C0603, C1005, C1608, C2012, C3216, C3225, C4532, C5750 Features • High capacitance has been achieved through precision technologies that enable the use of multiple thinner ceramic dielectric layers. • A monolithic structure ensures superior mechanical strength and reliability. • High-accuracy automatic mounting is facilitated through the maintenance of very precise dimensional tolerances. • Composed of only ceramics and metals, these capacitors provide extremely dependable performance, exhibiting virtually no degradation even when subjected to temperature extremes. • Low stray capacitance ensures high conformity with nominal values, thereby simplifying the circuit design process. • Low residual inductance assures superior frequency characteristics. • Because electrostatic capacity has been obtained up to the electrolytic capacitor range, these capacitors offer long service life and are optimally suited for power supply designs that require high levels of reliability. • Owing to their low ESR and excellent frequency characteristics, these products are optimally suited for high frequency and high-density type power supplies. Applications • • • • • • • • • Electronics equipment Mobile communications equipment Office automation equipment Automotive electronics Test and measurement equipment Hybrid ICs, etc. Decoupling Smoothing Charge pump Shape & Dimensions L W T B Body Length Body Width Body Height Terminal Width Dimensions in mm Part Number Construction C Series Name Dimensions L x W (mm) Case Code C0402 C0603 C1005 C1608 C2012 C3216 C3225 C4532 C5750 Length 0.40 ± 0.02 0.60 ± 0.03 1.00 ± 0.05 1.60 ± 0.10 2.00 ± 0.20 3.20 ± 0.20 3.20 ± 0.40 4.50 ± 0.40 5.70 ± 0.40 2012 X7R 1E 105 K T XXXX Width 0.20 ± 0.02 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 1.25 ± 0.20 1.60 ± 0.20 2.50 ± 0.30 3.20 ± 0.40 5.00 ± 0.40 Capacitance Change 0±30 ppm/ºC +350/-1000 ppm/ºC ±15% +22% ±15% ±22% +22/-82% Temperature Range -55 to +125ºC -25 to +85ºC -55 to +85ºC -55 to +105ºC -55 to +125ºC -55 to +125ºC -33 to +85ºC Voltage (DC) 4V 6.3V 10V TDK MLCC US Catalog Voltage Code 1C 1E 1V Voltage (DC) 16V 25V 35V Voltage Code 1H Style Tape & Reel Tolerance Code W B C D E G J K M Z Tolerance ± 0.05 pF ± 0.10 pF ± 0.25 pF ± 0.50 pF ± 0.20 pF ± 2% ± 5% ± 10% ± 20% +80-20% Capacitance Code 0R5 010 102 105 Capacitance 0.5pF 1pF 1,000pF (1nF) 1,000,000pF (1µF) Nominal Capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. Rated Voltage (DC) Voltage Code 0G 0J 1A Packaging Code T Capacitance Tolerance Temperature Characteristic Temperature Characteristics C0G SL X5R X6S X7R X7S Y5V Internal Codes Packaging Style Voltage (DC) 50V Page 5 Version B11 Capacitance Range Chart C0402 [EIA CC01005] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC) Rated Voltage: 16V (1C) Capacitance (pF) 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 1.2 1.3 1.5 1.6 1.8 2 2.2 2.4 2.7 3 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 C0G Cap Code 0R1 0R2 0R3 0R4 0R5 0R6 0R7 0R8 0R9 010 1R1 1R2 1R3 1R5 1R6 1R8 020 2R2 2R4 2R7 030 3R3 3R6 3R9 4R3 4R7 5R1 5R6 6R2 Tolerance Capacitance (pF) 1C (16V) Cap Code 6.8 7.5 8.2 9.1 10 11 12 13 15 16 18 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 100 W: ± 0.05pF B: ± 0.10pF C: ± 0.25pF D: ± 0.50pF 6R8 7R5 8R2 9R1 100 110 120 130 150 160 180 200 220 240 270 300 330 360 390 430 470 510 560 620 680 750 820 910 101 C0G Tolerance 1C (16V) B: ± 0.10pF E: ± 0.20pF C: ± 0.25pF D: ± 0.50pF G: ± 2% J: ± 5% • Standard capacitance is shown. Please refer to Capacitance Range Table for additional capacitance values. Capacitance Range Chart Temperature Characteristics: X7R (± 15%), X5R (± 15%) Rated Voltage: 16V (1C), 10V (1A), 6.3V (0J) Capacitance (pF) 100 150 220 330 470 680 1,000 1,500 2,200 3,300 4,700 6,800 10,000 X7R Cap Code 101 151 221 331 471 681 102 152 222 332 472 682 103 Tolerance 1A (10V) X5R 1C (16V) 1A (10V) 0J (6.3V) K: ± 10% Standard Thickness 0.20 mm TDK MLCC US Catalog Page 6 Version B11 Capacitance Range Table C0402 [EIA CC01005] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C0402C0G1C0R2W C0G 16V 0.2 ± 0.05pF 0.20 ± 0.02 C0402C0G1C0R2B C0G 16V 0.2 ± 0.10pF 0.20 ± 0.02 C0402C0G1C0R3W C0G 16V 0.3 ± 0.05pF 0.20 ± 0.02 C0402C0G1C0R3B C0G 16V 0.3 ± 0.10pF 0.20 ± 0.02 C0402C0G1C0R4W C0G 16V 0.4 ± 0.05pF 0.20 ± 0.02 C0402C0G1C0R4B C0G 16V 0.4 ± 0.10pF 0.20 ± 0.02 C0402C0G1C0R5W C0G 16V 0.5 ± 0.05pF 0.20 ± 0.02 C0402C0G1C0R5C C0G 16V 0.5 ± 0.25pF 0.20 ± 0.02 C0402C0G1C0R5B C0G 16V 0.5 ± 0.10pF 0.20 ± 0.02 C0402C0G1C0R6W C0G 16V 0.6 ± 0.05pF 0.20 ± 0.02 C0402C0G1C0R6B C0G 16V 0.6 ± 0.10pF 0.20 ± 0.02 C0402C0G1C0R7W C0G 16V 0.7 ± 0.05pF 0.20 ± 0.02 C0402C0G1C0R7B C0G 16V 0.7 ± 0.10pF 0.20 ± 0.02 C0402C0G1C0R8W C0G 16V 0.8 ± 0.05pF 0.20 ± 0.02 C0402C0G1C0R8B C0G 16V 0.8 ± 0.10pF 0.20 ± 0.02 C0402C0G1C0R9W C0G 16V 0.9 ± 0.05pF 0.20 ± 0.02 C0402C0G1C0R9B C0G 16V 0.9 ± 0.10pF 0.20 ± 0.02 C0402C0G1C010B C0G 16V 1.0 ± 0.10pF 0.20 ± 0.02 C0402C0G1C010C C0G 16V 1.0 ± 0.25pF 0.20 ± 0.02 C0402C0G1C1R1B C0G 16V 1.1 ± 0.10pF 0.20 ± 0.02 C0402C0G1C1R1C C0G 16V 1.1 ± 0.25pF 0.20 ± 0.02 C0402C0G1C1R2B C0G 16V 1.2 ± 0.10pF 0.20 ± 0.02 C0402C0G1C1R2C C0G 16V 1.2 ± 0.25pF 0.20 ± 0.02 C0402C0G1C1R3B C0G 16V 1.3 ± 0.10pF 0.20 ± 0.02 C0402C0G1C1R3C C0G 16V 1.3 ± 0.25pF 0.20 ± 0.02 C0402C0G1C1R5B C0G 16V 1.5 ± 0.10pF 0.20 ± 0.02 C0402C0G1C1R5C C0G 16V 1.5 ± 0.25pF 0.20 ± 0.02 C0402C0G1C1R6B C0G 16V 1.6 ± 0.10pF 0.20 ± 0.02 C0402C0G1C1R6C C0G 16V 1.6 ± 0.25pF 0.20 ± 0.02 C0402C0G1C1R8B C0G 16V 1.8 ± 0.10pF 0.20 ± 0.02 C0402C0G1C1R8C C0G 16V 1.8 ± 0.25pF 0.20 ± 0.02 C0402C0G1C020B C0G 16V 2.0 ± 0.10pF 0.20 ± 0.02 C0402C0G1C020C C0G 16V 2.0 ± 0.25pF 0.20 ± 0.02 C0402C0G1C2R2B C0G 16V 2.2 ± 0.10pF 0.20 ± 0.02 C0402C0G1C2R2C C0G 16V 2.2 ± 0.25pF 0.20 ± 0.02 C0402C0G1C2R4B C0G 16V 2.4 ± 0.10pF 0.20 ± 0.02 C0402C0G1C2R4C C0G 16V 2.4 ± 0.25pF 0.20 ± 0.02 C0402C0G1C2R7B C0G 16V 2.7 ± 0.10pF 0.20 ± 0.02 C0402C0G1C2R7C C0G 16V 2.7 ± 0.25pF 0.20 ± 0.02 C0402C0G1C030B C0G 16V 3.0 ± 0.10pF 0.20 ± 0.02 C0402C0G1C030C C0G 16V 3.0 ± 0.25pF 0.20 ± 0.02 C0402C0G1C3R3B C0G 16V 3.3 ± 0.10pF 0.20 ± 0.02 C0402C0G1C3R3C C0G 16V 3.3 ± 0.25pF 0.20 ± 0.02 C0402C0G1C3R6B C0G 16V 3.6 ± 0.10pF 0.20 ± 0.02 TDK MLCC US Catalog Page 7 Version B11 Capacitance Range Table C0402 [EIA CC01005] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C0402C0G1C3R6C C0G 16V 3.6 ± 0.25pF 0.20 ± 0.02 C0402C0G1C3R9B C0G 16V 3.9 ± 0.10pF 0.20 ± 0.02 C0402C0G1C3R9C C0G 16V 3.9 ± 0.25pF 0.20 ± 0.02 C0402C0G1C040B C0G 16V 4.0 ± 0.10pF 0.20 ± 0.02 C0402C0G1C040C C0G 16V 4.0 ± 0.25pF 0.20 ± 0.02 C0402C0G1C4R3B C0G 16V 4.3 ± 0.10pF 0.20 ± 0.02 C0402C0G1C4R3C C0G 16V 4.3 ± 0.25pF 0.20 ± 0.02 C0402C0G1C4R7B C0G 16V 4.7 ± 0.10pF 0.20 ± 0.02 C0402C0G1C4R7C C0G 16V 4.7 ± 0.25pF 0.20 ± 0.02 C0402C0G1C050B C0G 16V 5.0 ± 0.10pF 0.20 ± 0.02 C0402C0G1C050C C0G 16V 5.0 ± 0.25pF 0.20 ± 0.02 C0402C0G1C5R1B C0G 16V 5.1 ± 0.10pF 0.20 ± 0.02 C0402C0G1C5R1C C0G 16V 5.1 ± 0.25pF 0.20 ± 0.02 C0402C0G1C5R1D C0G 16V 5.1 ± 0.50pF 0.20 ± 0.02 C0402C0G1C5R6B C0G 16V 5.6 ± 0.10pF 0.20 ± 0.02 C0402C0G1C5R6C C0G 16V 5.6 ± 0.25pF 0.20 ± 0.02 C0402C0G1C5R6D C0G 16V 5.6 ± 0.50pF 0.20 ± 0.02 C0402C0G1C060B C0G 16V 6.0 ± 0.10pF 0.20 ± 0.02 C0402C0G1C060C C0G 16V 6.0 ± 0.25pF 0.20 ± 0.02 C0402C0G1C060D C0G 16V 6.0 ± 0.50pF 0.20 ± 0.02 C0402C0G1C6R2B C0G 16V 6.2 ± 0.10pF 0.20 ± 0.02 C0402C0G1C6R2C C0G 16V 6.2 ± 0.25pF 0.20 ± 0.02 C0402C0G1C6R2D C0G 16V 6.2 ± 0.50pF 0.20 ± 0.02 C0402C0G1C6R8B C0G 16V 6.8 ± 0.10pF 0.20 ± 0.02 C0402C0G1C6R8C C0G 16V 6.8 ± 0.25pF 0.20 ± 0.02 C0402C0G1C6R8D C0G 16V 6.8 ± 0.50pF 0.20 ± 0.02 C0402C0G1C070B C0G 16V 7.0 ± 0.10pF 0.20 ± 0.02 C0402C0G1C070C C0G 16V 7.0 ± 0.25pF 0.20 ± 0.02 C0402C0G1C070D C0G 16V 7.0 ± 0.50pF 0.20 ± 0.02 C0402C0G1C7R5B C0G 16V 7.5 ± 0.10pF 0.20 ± 0.02 C0402C0G1C7R5C C0G 16V 7.5 ± 0.25pF 0.20 ± 0.02 C0402C0G1C7R5D C0G 16V 7.5 ± 0.50pF 0.20 ± 0.02 C0402C0G1C080B C0G 16V 8.0 ± 0.10pF 0.20 ± 0.02 C0402C0G1C080C C0G 16V 8.0 ± 0.25pF 0.20 ± 0.02 C0402C0G1C080D C0G 16V 8.0 ± 0.50pF 0.20 ± 0.02 C0402C0G1C8R2B C0G 16V 8.2 ± 0.10pF 0.20 ± 0.02 C0402C0G1C8R2C C0G 16V 8.2 ± 0.25pF 0.20 ± 0.02 C0402C0G1C8R2D C0G 16V 8.2 ± 0.50pF 0.20 ± 0.02 C0402C0G1C090B C0G 16V 9.0 ± 0.10pF 0.20 ± 0.02 C0402C0G1C090C C0G 16V 9.0 ± 0.25pF 0.20 ± 0.02 C0402C0G1C090D C0G 16V 9.0 ± 0.50pF 0.20 ± 0.02 C0402C0G1C9R1B C0G 16V 9.1 ± 0.10pF 0.20 ± 0.02 C0402C0G1C9R1C C0G 16V 9.1 ± 0.25pF 0.20 ± 0.02 C0402C0G1C9R1D C0G 16V 9.1 ± 0.50pF 0.20 ± 0.02 TDK MLCC US Catalog Page 8 Version B11 Capacitance Range Table C0402 [EIA CC01005] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) 0.20 ± 0.02 C0402C0G1C100E C0G 16V 10 ± 0.20pF C0402C0G1C100D C0G 16V 10 ± 0.50pF 0.20 ± 0.02 C0402C0G1C110G C0G 16V 11 ± 2% 0.20 ± 0.02 C0402C0G1C110J C0G 16V 11 ± 5% 0.20 ± 0.02 C0402C0G1C120G C0G 16V 12 ± 2% 0.20 ± 0.02 C0402C0G1C120J C0G 16V 12 ± 5% 0.20 ± 0.02 C0402C0G1C130G C0G 16V 13 ± 2% 0.20 ± 0.02 C0402C0G1C130J C0G 16V 13 ± 5% 0.20 ± 0.02 C0402C0G1C150G C0G 16V 15 ± 2% 0.20 ± 0.02 C0402C0G1C150J C0G 16V 15 ± 5% 0.20 ± 0.02 C0402C0G1C160G C0G 16V 16 ± 2% 0.20 ± 0.02 C0402C0G1C160J C0G 16V 16 ± 5% 0.20 ± 0.02 C0402C0G1C180G C0G 16V 18 ± 2% 0.20 ± 0.02 C0402C0G1C180J C0G 16V 18 ± 5% 0.20 ± 0.02 C0402C0G1C200G C0G 16V 20 ± 2% 0.20 ± 0.02 C0402C0G1C200J C0G 16V 20 ± 5% 0.20 ± 0.02 C0402C0G1C220G C0G 16V 22 ± 2% 0.20 ± 0.02 C0402C0G1C220J C0G 16V 22 ± 5% 0.20 ± 0.02 C0402C0G1C240G C0G 16V 24 ± 2% 0.20 ± 0.02 C0402C0G1C240J C0G 16V 24 ± 5% 0.20 ± 0.02 C0402C0G1C270G C0G 16V 27 ± 2% 0.20 ± 0.02 C0402C0G1C270J C0G 16V 27 ± 5% 0.20 ± 0.02 C0402C0G1C300G C0G 16V 30 ± 2% 0.20 ± 0.02 C0402C0G1C300J C0G 16V 30 ± 5% 0.20 ± 0.02 C0402C0G1C330G C0G 16V 33 ± 2% 0.20 ± 0.02 C0402C0G1C330J C0G 16V 33 ± 5% 0.20 ± 0.02 C0402C0G1C360G C0G 16V 36 ± 2% 0.20 ± 0.02 C0402C0G1C360J C0G 16V 36 ± 5% 0.20 ± 0.02 C0402C0G1C390G C0G 16V 39 ± 2% 0.20 ± 0.02 C0402C0G1C390J C0G 16V 39 ± 5% 0.20 ± 0.02 C0402C0G1C430G C0G 16V 43 ± 2% 0.20 ± 0.02 C0402C0G1C430J C0G 16V 43 ± 5% 0.20 ± 0.02 C0402C0G1C470G C0G 16V 47 ± 2% 0.20 ± 0.02 C0402C0G1C470J C0G 16V 47 ± 5% 0.20 ± 0.02 C0402C0G1C510G C0G 16V 51 ± 2% 0.20 ± 0.02 C0402C0G1C510J C0G 16V 51 ± 5% 0.20 ± 0.02 C0402C0G1C560G C0G 16V 56 ± 2% 0.20 ± 0.02 C0402C0G1C560J C0G 16V 56 ± 5% 0.20 ± 0.02 C0402C0G1C620G C0G 16V 62 ± 2% 0.20 ± 0.02 C0402C0G1C620J C0G 16V 62 ± 5% 0.20 ± 0.02 C0402C0G1C680G C0G 16V 68 ± 2% 0.20 ± 0.02 C0402C0G1C680J C0G 16V 68 ± 5% 0.20 ± 0.02 C0402C0G1C750G C0G 16V 75 ± 2% 0.20 ± 0.02 C0402C0G1C750J C0G 16V 75 ± 5% 0.20 ± 0.02 TDK MLCC US Catalog Page 9 Version B11 Capacitance Range Table C0402 [EIA CC01005] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C0402C0G1C820G C0G 16V 82 ± 2% 0.20 ± 0.02 C0402C0G1C820J C0G 16V 82 ± 5% 0.20 ± 0.02 C0402C0G1C910G C0G 16V 91 ± 2% 0.20 ± 0.02 C0402C0G1C910J C0G 16V 91 ± 5% 0.20 ± 0.02 C0402C0G1C101G C0G 16V 100 ± 2% 0.20 ± 0.02 C0402C0G1C101J C0G 16V 100 ± 5% 0.20 ± 0.02 Capacitance Tolerance Thickness (mm) Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%), X5R (-55 to +85ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) C0402X7R1A101K X7R 10V 100 ± 10% 0.20 ± 0.02 C0402X7R1A151K X7R 10V 150 ± 10% 0.20 ± 0.02 C0402X7R1A221K X7R 10V 220 ± 10% 0.20 ± 0.02 C0402X7R1A331K X7R 10V 330 ± 10% 0.20 ± 0.02 C0402X7R1A471K X7R 10V 470 ± 10% 0.20 ± 0.02 C0402X7R1A681K X7R 10V 680 ± 10% 0.20 ± 0.02 C0402X5R1C101K X5R 16V 100 ± 10% 0.20 ± 0.02 C0402X5R1C151K X5R 16V 150 ± 10% 0.20 ± 0.02 C0402X5R1C221K X5R 16V 220 ± 10% 0.20 ± 0.02 C0402X5R1C331K X5R 16V 330 ± 10% 0.20 ± 0.02 C0402X5R1C471K X5R 16V 470 ± 10% 0.20 ± 0.02 C0402X5R1C681K X5R 16V 680 ± 10% 0.20 ± 0.02 C0402X5R1A101K X5R 10V 100 ± 10% 0.20 ± 0.02 C0402X5R1A221K X5R 10V 220 ± 10% 0.20 ± 0.02 C0402X5R1A471K X5R 10V 470 ± 10% 0.20 ± 0.02 C0402X5R1A102K X5R 10V 1,000 ± 10% 0.20 ± 0.02 C0402X5R1A152K X5R 10V 1,500 ± 10% 0.20 ± 0.02 C0402X5R1A222K X5R 10V 2,200 ± 10% 0.20 ± 0.02 C0402X5R0J681K X5R 6.3V 680 ± 10% 0.20 ± 0.02 C0402X5R0J102K X5R 6.3V 1,000 ± 10% 0.20 ± 0.02 C0402X5R0J152K X5R 6.3V 1,500 ± 10% 0.20 ± 0.02 C0402X5R0J222K X5R 6.3V 2,200 ± 10% 0.20 ± 0.02 C0402X5R0J332K X5R 6.3V 3,300 ± 10% 0.20 ± 0.02 C0402X5R0J472K X5R 6.3V 4,700 ± 10% 0.20 ± 0.02 C0402X5R0J682K X5R 6.3V 6,800 ± 10% 0.20 ± 0.02 C0402X5R0J103K X5R 6.3V 10,000 ± 10% 0.20 ± 0.02 TDK MLCC US Catalog Page 10 Version B11 Capacitance Range Chart C0603 [EIA CC0201] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC) Rated Voltage: 50V (1H), 25V (1E) Capacitance (pF) 0.2 0.3 0.4 0.5 0.6 0.7 0.75 0.8 0.9 1 1.1 1.2 1.3 1.5 1.6 1.8 2 2.2 2.4 2.7 3 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 C0G Cap Code 0R2 0R3 0R4 0R5 0R6 0R7 R75 0R8 0R9 010 1R1 1R2 1R3 1R5 1R6 1R8 020 2R2 2R4 2R7 030 3R3 3R6 3R9 4R3 4R7 5R1 5R6 6R2 Tolerance W: ± 0.05pF B: ± 0.10pF C: ± 0.25pF D: ± 0.50pF 1H (50V) 1E (25V) Capacitance (pF) 6.8 7.5 8.2 9.1 10 11 12 13 15 16 18 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 100 Cap Code 6R8 7R5 8R2 9R1 100 110 120 130 150 160 180 200 220 240 270 300 330 360 390 430 470 510 560 620 680 750 820 910 101 C0G Tolerance 1H (50V) 1E (25V) B: ± 0.10pF E: ± 0.20pF C: ± 0.25pF D: ± 0.50pF G: ± 2% J: ± 5% Standard Thickness 0.30 mm • Standard capacitance is shown. Please refer to Capacitance Range Table for additional capacitance values. TDK MLCC US Catalog Page 11 Version B11 Capacitance Range Chart C0603 [EIA CC0201] Capacitance Range Chart Temperature Characteristics: X7R (± 15%), X5R (± 15%) Rated Voltage: 50V (1H), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J) Capacitance (pF) 100 150 220 330 470 680 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 X7R Cap Code 101 151 221 331 471 681 102 152 222 332 472 682 103 153 223 333 473 683 104 154 224 Tolerance 1H (50V) 1E (25V) 1C (16V) X5R 1A (10V) 0J (6.3V) 1H (50V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) K: ± 10% M: ± 20% • Standard capacitance is shown. Please refer to Capacitance Range Table for additional capacitance values. TDK MLCC US Catalog Standard Thickness 0.30 mm Page 12 Version B11 Capacitance Range Table C0603 [EIA CC0201] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C0603C0G1H0R5B C0G 50V 0.5 ± 0.10pF 0.30 ± 0.03 C0603C0G1H0R5C C0G 50V 0.5 ± 0.25pF 0.30 ± 0.03 C0603C0G1H010B C0G 50V 1.0 ± 0.10pF 0.30 ± 0.03 C0603C0G1H010C C0G 50V 1.0 ± 0.25pF 0.30 ± 0.03 C0603C0G1H1R2C C0G 50V 1.2 ± 0.25pF 0.30 ± 0.03 C0603C0G1H1R5B C0G 50V 1.5 ± 0.10pF 0.30 ± 0.03 C0603C0G1H1R5C C0G 50V 1.5 ± 0.25pF 0.30 ± 0.03 C0603C0G1H1R8C C0G 50V 1.8 ± 0.25pF 0.30 ± 0.03 C0603C0G1H020B C0G 50V 2.0 ± 0.10pF 0.30 ± 0.03 C0603C0G1H020C C0G 50V 2.0 ± 0.25pF 0.30 ± 0.03 C0603C0G1H2R2B C0G 50V 2.2 ± 0.10pF 0.30 ± 0.03 C0603C0G1H2R2C C0G 50V 2.2 ± 0.25pF 0.30 ± 0.03 C0603C0G1H2R7C C0G 50V 2.7 ± 0.25pF 0.30 ± 0.03 C0603C0G1H030B C0G 50V 3.0 ± 0.10pF 0.30 ± 0.03 C0603C0G1H030C C0G 50V 3.0 ± 0.25pF 0.30 ± 0.03 C0603C0G1H3R3B C0G 50V 3.3 ± 0.10pF 0.30 ± 0.03 C0603C0G1H3R3C C0G 50V 3.3 ± 0.25pF 0.30 ± 0.03 C0603C0G1H3R9C C0G 50V 3.9 ± 0.25pF 0.30 ± 0.03 C0603C0G1H040B C0G 50V 4.0 ± 0.10pF 0.30 ± 0.03 C0603C0G1H040C C0G 50V 4.0 ± 0.25pF 0.30 ± 0.03 C0603C0G1H4R7B C0G 50V 4.7 ± 0.10pF 0.30 ± 0.03 C0603C0G1H4R7C C0G 50V 4.7 ± 0.25pF 0.30 ± 0.03 C0603C0G1H050B C0G 50V 5.0 ± 0.10pF 0.30 ± 0.03 C0603C0G1H050C C0G 50V 5.0 ± 0.25pF 0.30 ± 0.03 C0603C0G1H5R6C C0G 50V 5.6 ± 0.25pF 0.30 ± 0.03 C0603C0G1H060C C0G 50V 6.0 ± 0.25pF 0.30 ± 0.03 C0603C0G1H060D C0G 50V 6.0 ± 0.50pF 0.30 ± 0.03 C0603C0G1H6R8C C0G 50V 6.8 ± 0.25pF 0.30 ± 0.03 C0603C0G1H6R8D C0G 50V 6.8 ± 0.50pF 0.30 ± 0.03 C0603C0G1H070C C0G 50V 7.0 ± 0.25pF 0.30 ± 0.03 C0603C0G1H070D C0G 50V 7.0 ± 0.50pF 0.30 ± 0.03 C0603C0G1H080C C0G 50V 8.0 ± 0.25pF 0.30 ± 0.03 C0603C0G1H080D C0G 50V 8.0 ± 0.50pF 0.30 ± 0.03 C0603C0G1H8R2C C0G 50V 8.2 ± 0.25pF 0.30 ± 0.03 C0603C0G1H090C C0G 50V 9.0 ± 0.25pF 0.30 ± 0.03 C0603C0G1H090D C0G 50V 9.0 ± 0.50pF 0.30 ± 0.03 C0603C0G1H100C C0G 50V 10 ± 0.25pF 0.30 ± 0.03 C0603C0G1H100D C0G 50V 10 ± 0.50pF 0.30 ± 0.03 C0603C0G1H110J C0G 50V 11 ± 5% 0.30 ± 0.03 C0603C0G1H120J C0G 50V 12 ± 5% 0.30 ± 0.03 C0603C0G1H130J C0G 50V 13 ± 5% 0.30 ± 0.03 C0603C0G1H150J C0G 50V 15 ± 5% 0.30 ± 0.03 C0603C0G1H160J C0G 50V 16 ± 5% 0.30 ± 0.03 C0603C0G1H180J C0G 50V 18 ± 5% 0.30 ± 0.03 TDK MLCC US Catalog Page 13 Version B11 Capacitance Range Table C0603 [EIA CC0201] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C0603C0G1H200J C0G 50V 20 ± 5% 0.30 ± 0.03 C0603C0G1H220J C0G 50V 22 ± 5% 0.30 ± 0.03 C0603C0G1H240J C0G 50V 24 ± 5% 0.30 ± 0.03 C0603C0G1H270J C0G 50V 27 ± 5% 0.30 ± 0.03 C0603C0G1H300J C0G 50V 30 ± 5% 0.30 ± 0.03 C0603C0G1H330J C0G 50V 33 ± 5% 0.30 ± 0.03 C0603C0G1H360J C0G 50V 36 ± 5% 0.30 ± 0.03 C0603C0G1H390J C0G 50V 39 ± 5% 0.30 ± 0.03 C0603C0G1H430J C0G 50V 43 ± 5% 0.30 ± 0.03 C0603C0G1H470J C0G 50V 47 ± 5% 0.30 ± 0.03 C0603C0G1H510J C0G 50V 51 ± 5% 0.30 ± 0.03 C0603C0G1H560J C0G 50V 56 ± 5% 0.30 ± 0.03 C0603C0G1H620J C0G 50V 62 ± 5% 0.30 ± 0.03 C0603C0G1H680J C0G 50V 68 ± 5% 0.30 ± 0.03 C0603C0G1H750J C0G 50V 75 ± 5% 0.30 ± 0.03 C0603C0G1H820J C0G 50V 82 ± 5% 0.30 ± 0.03 C0603C0G1H910J C0G 50V 91 ± 5% 0.30 ± 0.03 C0603C0G1H101J C0G 50V 100 ± 5% 0.30 ± 0.03 C0603C0G1E0R2W C0G 25V 0.2 ± 0.05pF 0.30 ± 0.03 C0603C0G1E0R2B C0G 25V 0.2 ± 0.10pF 0.30 ± 0.03 C0603C0G1E0R3W C0G 25V 0.3 ± 0.05pF 0.30 ± 0.03 C0603C0G1E0R3B C0G 25V 0.3 ± 0.10pF 0.30 ± 0.03 C0603C0G1E0R4W C0G 25V 0.4 ± 0.05pF 0.30 ± 0.03 C0603C0G1E0R4B C0G 25V 0.4 ± 0.10pF 0.30 ± 0.03 C0603C0G1E0R5W C0G 25V 0.5 ± 0.05pF 0.30 ± 0.03 C0603C0G1E0R5C C0G 25V 0.5 ± 0.25pF 0.30 ± 0.03 C0603C0G1E0R5B C0G 25V 0.5 ± 0.10pF 0.30 ± 0.03 C0603C0G1E0R6W C0G 25V 0.6 ± 0.05pF 0.30 ± 0.03 C0603C0G1E0R6B C0G 25V 0.6 ± 0.10pF 0.30 ± 0.03 C0603C0G1E0R7W C0G 25V 0.7 ± 0.05pF 0.30 ± 0.03 C0603C0G1E0R7B C0G 25V 0.7 ± 0.10pF 0.30 ± 0.03 C0603C0G1ER75B C0G 25V 0.75 ± 0.10pF 0.30 ± 0.03 C0603C0G1ER75C C0G 25V 0.75 ± 0.25pF 0.30 ± 0.03 C0603C0G1E0R8W C0G 25V 0.8 ± 0.05pF 0.30 ± 0.03 C0603C0G1E0R8B C0G 25V 0.8 ± 0.10pF 0.30 ± 0.03 C0603C0G1E0R9W C0G 25V 0.9 ± 0.05pF 0.30 ± 0.03 C0603C0G1E0R9B C0G 25V 0.9 ± 0.10pF 0.30 ± 0.03 C0603C0G1E010B C0G 25V 1.0 ± 0.10pF 0.30 ± 0.03 C0603C0G1E010C C0G 25V 1.0 ± 0.25pF 0.30 ± 0.03 C0603C0G1E1R1B C0G 25V 1.1 ± 0.10pF 0.30 ± 0.03 C0603C0G1E1R1C C0G 25V 1.1 ± 0.25pF 0.30 ± 0.03 C0603C0G1E1R2B C0G 25V 1.2 ± 0.10pF 0.30 ± 0.03 C0603C0G1E1R2C C0G 25V 1.2 ± 0.25pF 0.30 ± 0.03 C0603C0G1E1R3B C0G 25V 1.3 ± 0.10pF 0.30 ± 0.03 TDK MLCC US Catalog Page 14 Version B11 Capacitance Range Table C0603 [EIA CC0201] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C0603C0G1E1R3C C0G 25V 1.3 ± 0.25pF 0.30 ± 0.03 C0603C0G1E1R5B C0G 25V 1.5 ± 0.10pF 0.30 ± 0.03 C0603C0G1E1R5C C0G 25V 1.5 ± 0.25pF 0.30 ± 0.03 C0603C0G1E1R6B C0G 25V 1.6 ± 0.10pF 0.30 ± 0.03 C0603C0G1E1R6C C0G 25V 1.6 ± 0.25pF 0.30 ± 0.03 C0603C0G1E1R8B C0G 25V 1.8 ± 0.10pF 0.30 ± 0.03 C0603C0G1E1R8C C0G 25V 1.8 ± 0.25pF 0.30 ± 0.03 C0603C0G1E020B C0G 25V 2.0 ± 0.10pF 0.30 ± 0.03 C0603C0G1E020C C0G 25V 2.0 ± 0.25pF 0.30 ± 0.03 C0603C0G1E2R2B C0G 25V 2.2 ± 0.10pF 0.30 ± 0.03 C0603C0G1E2R2C C0G 25V 2.2 ± 0.25pF 0.30 ± 0.03 C0603C0G1E2R4B C0G 25V 2.4 ± 0.10pF 0.30 ± 0.03 C0603C0G1E2R4C C0G 25V 2.4 ± 0.25pF 0.30 ± 0.03 C0603C0G1E2R7B C0G 25V 2.7 ± 0.10pF 0.30 ± 0.03 C0603C0G1E2R7C C0G 25V 2.7 ± 0.25pF 0.30 ± 0.03 C0603C0G1E030B C0G 25V 3.0 ± 0.10pF 0.30 ± 0.03 C0603C0G1E030C C0G 25V 3.0 ± 0.25pF 0.30 ± 0.03 C0603C0G1E3R3B C0G 25V 3.3 ± 0.10pF 0.30 ± 0.03 C0603C0G1E3R3C C0G 25V 3.3 ± 0.25pF 0.30 ± 0.03 C0603C0G1E3R6B C0G 25V 3.6 ± 0.10pF 0.30 ± 0.03 C0603C0G1E3R6C C0G 25V 3.6 ± 0.25pF 0.30 ± 0.03 C0603C0G1E3R9B C0G 25V 3.9 ± 0.10pF 0.30 ± 0.03 C0603C0G1E3R9C C0G 25V 3.9 ± 0.25pF 0.30 ± 0.03 C0603C0G1E040B C0G 25V 4.0 ± 0.10pF 0.30 ± 0.03 C0603C0G1E040C C0G 25V 4.0 ± 0.25pF 0.30 ± 0.03 C0603C0G1E4R3B C0G 25V 4.3 ± 0.10pF 0.30 ± 0.03 C0603C0G1E4R3C C0G 25V 4.3 ± 0.25pF 0.30 ± 0.03 C0603C0G1E4R7B C0G 25V 4.7 ± 0.10pF 0.30 ± 0.03 C0603C0G1E4R7C C0G 25V 4.7 ± 0.25pF 0.30 ± 0.03 C0603C0G1E050B C0G 25V 5.0 ± 0.10pF 0.30 ± 0.03 C0603C0G1E050C C0G 25V 5.0 ± 0.25pF 0.30 ± 0.03 C0603C0G1E5R1B C0G 25V 5.1 ± 0.10pF 0.30 ± 0.03 C0603C0G1E5R1C C0G 25V 5.1 ± 0.25pF 0.30 ± 0.03 C0603C0G1E5R1D C0G 25V 5.1 ± 0.50pF 0.30 ± 0.03 C0603C0G1E5R6B C0G 25V 5.6 ± 0.10pF 0.30 ± 0.03 C0603C0G1E5R6C C0G 25V 5.6 ± 0.25pF 0.30 ± 0.03 C0603C0G1E5R6D C0G 25V 5.6 ± 0.50pF 0.30 ± 0.03 C0603C0G1E060B C0G 25V 6.0 ± 0.10pF 0.30 ± 0.03 C0603C0G1E060C C0G 25V 6.0 ± 0.25pF 0.30 ± 0.03 C0603C0G1E060D C0G 25V 6.0 ± 0.50pF 0.30 ± 0.03 C0603C0G1E6R2B C0G 25V 6.2 ± 0.10pF 0.30 ± 0.03 C0603C0G1E6R2C C0G 25V 6.2 ± 0.25pF 0.30 ± 0.03 C0603C0G1E6R2D C0G 25V 6.2 ± 0.50pF 0.30 ± 0.03 C0603C0G1E6R8B C0G 25V 6.8 ± 0.10pF 0.30 ± 0.03 TDK MLCC US Catalog Page 15 Version B11 Capacitance Range Table C0603 [EIA CC0201] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C0603C0G1E6R8C C0G 25V 6.8 ± 0.25pF 0.30 ± 0.03 C0603C0G1E6R8D C0G 25V 6.8 ± 0.50pF 0.30 ± 0.03 C0603C0G1E070B C0G 25V 7.0 ± 0.10pF 0.30 ± 0.03 C0603C0G1E070C C0G 25V 7.0 ± 0.25pF 0.30 ± 0.03 C0603C0G1E070D C0G 25V 7.0 ± 0.50pF 0.30 ± 0.03 C0603C0G1E7R5B C0G 25V 7.5 ± 0.10pF 0.30 ± 0.03 C0603C0G1E7R5C C0G 25V 7.5 ± 0.25pF 0.30 ± 0.03 C0603C0G1E7R5D C0G 25V 7.5 ± 0.50pF 0.30 ± 0.03 C0603C0G1E080B C0G 25V 8.0 ± 0.10pF 0.30 ± 0.03 C0603C0G1E080C C0G 25V 8.0 ± 0.25pF 0.30 ± 0.03 C0603C0G1E080D C0G 25V 8.0 ± 0.50pF 0.30 ± 0.03 C0603C0G1E8R2B C0G 25V 8.2 ± 0.10pF 0.30 ± 0.03 C0603C0G1E8R2C C0G 25V 8.2 ± 0.25pF 0.30 ± 0.03 C0603C0G1E8R2D C0G 25V 8.2 ± 0.50pF 0.30 ± 0.03 C0603C0G1E090B C0G 25V 9.0 ± 0.10pF 0.30 ± 0.03 C0603C0G1E090C C0G 25V 9.0 ± 0.25pF 0.30 ± 0.03 C0603C0G1E090D C0G 25V 9.0 ± 0.50pF 0.30 ± 0.03 C0603C0G1E9R1B C0G 25V 9.1 ± 0.10pF 0.30 ± 0.03 C0603C0G1E9R1C C0G 25V 9.1 ± 0.25pF 0.30 ± 0.03 C0603C0G1E9R1D C0G 25V 9.1 ± 0.50pF 0.30 ± 0.03 C0603C0G1E100E C0G 25V 10 ± 0.20pF 0.30 ± 0.03 C0603C0G1E100C C0G 25V 10 ± 0.25pF 0.30 ± 0.03 C0603C0G1E100D C0G 25V 10 ± 0.50pF 0.30 ± 0.03 C0603C0G1E110G C0G 25V 11 ± 2% 0.30 ± 0.03 C0603C0G1E110J C0G 25V 11 ± 5% 0.30 ± 0.03 C0603C0G1E120G C0G 25V 12 ± 2% 0.30 ± 0.03 C0603C0G1E120J C0G 25V 12 ± 5% 0.30 ± 0.03 C0603C0G1E130G C0G 25V 13 ± 2% 0.30 ± 0.03 C0603C0G1E130J C0G 25V 13 ± 5% 0.30 ± 0.03 C0603C0G1E150G C0G 25V 15 ± 2% 0.30 ± 0.03 C0603C0G1E150J C0G 25V 15 ± 5% 0.30 ± 0.03 C0603C0G1E160G C0G 25V 16 ± 2% 0.30 ± 0.03 C0603C0G1E160J C0G 25V 16 ± 5% 0.30 ± 0.03 C0603C0G1E180G C0G 25V 18 ± 2% 0.30 ± 0.03 C0603C0G1E180J C0G 25V 18 ± 5% 0.30 ± 0.03 C0603C0G1E200G C0G 25V 20 ± 2% 0.30 ± 0.03 C0603C0G1E200J C0G 25V 20 ± 5% 0.30 ± 0.03 C0603C0G1E220G C0G 25V 22 ± 2% 0.30 ± 0.03 C0603C0G1E220J C0G 25V 22 ± 5% 0.30 ± 0.03 C0603C0G1E240G C0G 25V 24 ± 2% 0.30 ± 0.03 C0603C0G1E240J C0G 25V 24 ± 5% 0.30 ± 0.03 C0603C0G1E270G C0G 25V 27 ± 2% 0.30 ± 0.03 C0603C0G1E270J C0G 25V 27 ± 5% 0.30 ± 0.03 C0603C0G1E300G C0G 25V 30 ± 2% 0.30 ± 0.03 TDK MLCC US Catalog Page 16 Version B11 Capacitance Range Table C0603 [EIA CC0201] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C0603C0G1E300J C0G 25V 30 ± 5% 0.30 ± 0.03 C0603C0G1E330G C0G 25V 33 ± 2% 0.30 ± 0.03 C0603C0G1E330J C0G 25V 33 ± 5% 0.30 ± 0.03 C0603C0G1E360G C0G 25V 36 ± 2% 0.30 ± 0.03 C0603C0G1E360J C0G 25V 36 ± 5% 0.30 ± 0.03 C0603C0G1E390G C0G 25V 39 ± 2% 0.30 ± 0.03 C0603C0G1E390J C0G 25V 39 ± 5% 0.30 ± 0.03 C0603C0G1E430G C0G 25V 43 ± 2% 0.30 ± 0.03 C0603C0G1E430J C0G 25V 43 ± 5% 0.30 ± 0.03 C0603C0G1E470G C0G 25V 47 ± 2% 0.30 ± 0.03 C0603C0G1E470J C0G 25V 47 ± 5% 0.30 ± 0.03 C0603C0G1E510G C0G 25V 51 ± 2% 0.30 ± 0.03 C0603C0G1E510J C0G 25V 51 ± 5% 0.30 ± 0.03 C0603C0G1E560G C0G 25V 56 ± 2% 0.30 ± 0.03 C0603C0G1E560J C0G 25V 56 ± 5% 0.30 ± 0.03 C0603C0G1E620G C0G 25V 62 ± 2% 0.30 ± 0.03 C0603C0G1E620J C0G 25V 62 ± 5% 0.30 ± 0.03 C0603C0G1E680G C0G 25V 68 ± 2% 0.30 ± 0.03 C0603C0G1E680J C0G 25V 68 ± 5% 0.30 ± 0.03 C0603C0G1E750G C0G 25V 75 ± 2% 0.30 ± 0.03 C0603C0G1E750J C0G 25V 75 ± 5% 0.30 ± 0.03 C0603C0G1E820G C0G 25V 82 ± 2% 0.30 ± 0.03 C0603C0G1E820J C0G 25V 82 ± 5% 0.30 ± 0.03 C0603C0G1E910G C0G 25V 91 ± 2% 0.30 ± 0.03 C0603C0G1E910J C0G 25V 91 ± 5% 0.30 ± 0.03 C0603C0G1E101G C0G 25V 100 ± 2% 0.30 ± 0.03 C0603C0G1E101J C0G 25V 100 ± 5% 0.30 ± 0.03 Capacitance Tolerance Thickness (mm) Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) C0603X7R1H101K X7R 50V 100 ± 10% 0.30 ± 0.03 C0603X7R1H101M X7R 50V 100 ± 20% 0.30 ± 0.03 C0603X7R1H151K X7R 50V 150 ± 10% 0.30 ± 0.03 C0603X7R1H151M X7R 50V 150 ± 20% 0.30 ± 0.03 C0603X7R1H221K X7R 50V 220 ± 10% 0.30 ± 0.03 C0603X7R1H221M X7R 50V 220 ± 20% 0.30 ± 0.03 C0603X7R1H331K X7R 50V 330 ± 10% 0.30 ± 0.03 C0603X7R1H331M X7R 50V 330 ± 20% 0.30 ± 0.03 C0603X7R1H471K X7R 50V 470 ± 10% 0.30 ± 0.03 C0603X7R1H471M X7R 50V 470 ± 20% 0.30 ± 0.03 C0603X7R1E101K X7R 25V 100 ± 10% 0.30 ± 0.03 C0603X7R1E101M X7R 25V 100 ± 20% 0.30 ± 0.03 TDK MLCC US Catalog Page 17 Version B11 Capacitance Range Table C0603 [EIA CC0201] Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C0603X7R1E151K X7R 25V 150 ± 10% 0.30 ± 0.03 C0603X7R1E151M X7R 25V 150 ± 20% 0.30 ± 0.03 C0603X7R1E221K X7R 25V 220 ± 10% 0.30 ± 0.03 C0603X7R1E221M X7R 25V 220 ± 20% 0.30 ± 0.03 C0603X7R1E331K X7R 25V 330 ± 10% 0.30 ± 0.03 C0603X7R1E331M X7R 25V 330 ± 20% 0.30 ± 0.03 C0603X7R1E471K X7R 25V 470 ± 10% 0.30 ± 0.03 C0603X7R1E471M X7R 25V 470 ± 20% 0.30 ± 0.03 C0603X7R1E681K X7R 25V 680 ± 10% 0.30 ± 0.03 C0603X7R1E681M X7R 25V 680 ± 20% 0.30 ± 0.03 C0603X7R1E102K X7R 25V 1,000 ± 10% 0.30 ± 0.03 C0603X7R1E102M X7R 25V 1,000 ± 20% 0.30 ± 0.03 C0603X7R1E152K X7R 25V 1,500 ± 10% 0.30 ± 0.03 C0603X7R1E152M X7R 25V 1,500 ± 20% 0.30 ± 0.03 C0603X7R1E222K X7R 25V 2,200 ± 10% 0.30 ± 0.03 C0603X7R1E222M X7R 25V 2,200 ± 20% 0.30 ± 0.03 C0603X7R1E332K X7R 25V 3,300 ± 10% 0.30 ± 0.03 C0603X7R1E332M X7R 25V 3,300 ± 20% 0.30 ± 0.03 C0603X7R1C101K X7R 16V 100 ± 10% 0.30 ± 0.03 C0603X7R1C101M X7R 16V 100 ± 20% 0.30 ± 0.03 C0603X7R1C151K X7R 16V 150 ± 10% 0.30 ± 0.03 C0603X7R1C151M X7R 16V 150 ± 20% 0.30 ± 0.03 C0603X7R1C221K X7R 16V 220 ± 10% 0.30 ± 0.03 C0603X7R1C221M X7R 16V 220 ± 20% 0.30 ± 0.03 C0603X7R1C331K X7R 16V 330 ± 10% 0.30 ± 0.03 C0603X7R1C331M X7R 16V 330 ± 20% 0.30 ± 0.03 C0603X7R1C471K X7R 16V 470 ± 10% 0.30 ± 0.03 C0603X7R1C471M X7R 16V 470 ± 20% 0.30 ± 0.03 C0603X7R1C681K X7R 16V 680 ± 10% 0.30 ± 0.03 C0603X7R1C681M X7R 16V 680 ± 20% 0.30 ± 0.03 C0603X7R1C102K X7R 16V 1,000 ± 10% 0.30 ± 0.03 C0603X7R1C102M X7R 16V 1,000 ± 20% 0.30 ± 0.03 C0603X7R1C152K X7R 16V 1,500 ± 10% 0.30 ± 0.03 C0603X7R1C152M X7R 16V 1,500 ± 20% 0.30 ± 0.03 C0603X7R1C222K X7R 16V 2,200 ± 10% 0.30 ± 0.03 C0603X7R1C222M X7R 16V 2,200 ± 20% 0.30 ± 0.03 C0603X7R1C332K X7R 16V 3,300 ± 10% 0.30 ± 0.03 C0603X7R1C332M X7R 16V 3,300 ± 20% 0.30 ± 0.03 C0603X7R1C472K X7R 16V 4,700 ± 10% 0.30 ± 0.03 C0603X7R1C472M X7R 16V 4,700 ± 20% 0.30 ± 0.03 C0603X7R1A682K X7R 10V 6,800 ± 10% 0.30 ± 0.03 C0603X7R1A682M X7R 10V 6,800 ± 20% 0.30 ± 0.03 C0603X7R1A103K X7R 10V 10,000 ± 10% 0.30 ± 0.03 C0603X7R1A103M X7R 10V 10,000 ± 20% 0.30 ± 0.03 TDK MLCC US Catalog Page 18 Version B11 Capacitance Range Table C0603 [EIA CC0201] Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%), X6S(-55 to 105ºC, ±22%), X5R (-55 to +85ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C0603X7R0J103K X7R 6.3V 10,000 ± 10% 0.30 ± 0.03 C0603X7R0J103M X7R 6.3V 10,000 ± 20% 0.30 ± 0.03 C0603X6S0G104K X6S 4V 100,000 ± 10% 0.30 ± 0.03 C0603X6S0G104M X6S 4V 100,000 ± 20% 0.30 ± 0.03 C0603X5R1H101K X5R 50V 100 ± 10% 0.30 ± 0.03 C0603X5R1H101M X5R 50V 100 ± 20% 0.30 ± 0.03 C0603X5R1H151K X5R 50V 150 ± 10% 0.30 ± 0.03 C0603X5R1H151M X5R 50V 150 ± 20% 0.30 ± 0.03 C0603X5R1H221K X5R 50V 220 ± 10% 0.30 ± 0.03 C0603X5R1H221M X5R 50V 220 ± 20% 0.30 ± 0.03 C0603X5R1H331K X5R 50V 330 ± 10% 0.30 ± 0.03 C0603X5R1H331M X5R 50V 330 ± 20% 0.30 ± 0.03 C0603X5R1H471K X5R 50V 470 ± 10% 0.30 ± 0.03 C0603X5R1H471M X5R 50V 470 ± 20% 0.30 ± 0.03 C0603X5R1E101K X5R 25V 100 ± 10% 0.30 ± 0.03 C0603X5R1E101M X5R 25V 100 ± 20% 0.30 ± 0.03 C0603X5R1E151K X5R 25V 150 ± 10% 0.30 ± 0.03 C0603X5R1E151M X5R 25V 150 ± 20% 0.30 ± 0.03 C0603X5R1E221K X5R 25V 220 ± 10% 0.30 ± 0.03 C0603X5R1E221M X5R 25V 220 ± 20% 0.30 ± 0.03 C0603X5R1E331K X5R 25V 330 ± 10% 0.30 ± 0.03 C0603X5R1E331M X5R 25V 330 ± 20% 0.30 ± 0.03 C0603X5R1E471K X5R 25V 470 ± 10% 0.30 ± 0.03 C0603X5R1E471M X5R 25V 470 ± 20% 0.30 ± 0.03 C0603X5R1E681K X5R 25V 680 ± 10% 0.30 ± 0.03 C0603X5R1E681M X5R 25V 680 ± 20% 0.30 ± 0.03 C0603X5R1E102K X5R 25V 1,000 ± 10% 0.30 ± 0.03 C0603X5R1E102M X5R 25V 1,000 ± 20% 0.30 ± 0.03 C0603X5R1E152K X5R 25V 1,500 ± 10% 0.30 ± 0.03 C0603X5R1E152M X5R 25V 1,500 ± 20% 0.30 ± 0.03 C0603X5R1E222K X5R 25V 2,200 ± 10% 0.30 ± 0.03 C0603X5R1E222M X5R 25V 2,200 ± 20% 0.30 ± 0.03 C0603X5R1E332K X5R 25V 3,300 ± 10% 0.30 ± 0.03 C0603X5R1E332M X5R 25V 3,300 ± 20% 0.30 ± 0.03 C0603X5R1C222K X5R 16V 2,200 ± 10% 0.30 ± 0.03 C0603X5R1C222M X5R 16V 2,200 ± 20% 0.30 ± 0.03 C0603X5R1C332K X5R 16V 3,300 ± 10% 0.30 ± 0.03 C0603X5R1C332M X5R 16V 3,300 ± 20% 0.30 ± 0.03 C0603X5R1C472K X5R 16V 4,700 ± 10% 0.30 ± 0.03 C0603X5R1C472M X5R 16V 4,700 ± 20% 0.30 ± 0.03 C0603X5R1C104K X5R 16V 100,000 ± 10% 0.30 ± 0.03 C0603X5R1C154K X5R 16V 150,000 ± 10% 0.30 ± 0.03 C0603X5R1C224K X5R 16V 220,000 ± 10% 0.30 ± 0.03 C0603X5R1C224M X5R 16V 220,000 ± 20% 0.30 ± 0.03 TDK MLCC US Catalog Page 19 Version B11 Capacitance Range Table C0603 [EIA CC0201] Class 2 (Temperature Stable) Temperature Characteristics: X5R (-55 to +85ºC, ±15%), Y5V(-30 to +85ºC, +22/-82%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C0603X5R1A682K X5R 10V 6,800 ± 10% 0.30 ± 0.03 C0603X5R1A682M X5R 10V 6,800 ± 20% 0.30 ± 0.03 C0603X5R1A103K X5R 10V 10,000 ± 10% 0.30 ± 0.03 C0603X5R1A103M X5R 10V 10,000 ± 20% 0.30 ± 0.03 C0603X5R1A104K X5R 10V 100,000 ± 10% 0.30 ± 0.03 C0603X5R1A154K X5R 10V 150,000 ± 10% 0.30 ± 0.03 C0603X5R1A224K X5R 10V 220,000 ± 10% 0.30 ± 0.03 C0603X5R1A224M X5R 10V 220,000 ± 20% 0.30 ± 0.03 C0603X5R0J103K X5R 6.3V 10,000 ± 10% 0.30 ± 0.03 C0603X5R0J103M X5R 6.3V 10,000 ± 20% 0.30 ± 0.03 C0603X5R0J153K X5R 6.3V 15,000 ± 10% 0.30 ± 0.03 C0603X5R0J153M X5R 6.3V 15,000 ± 20% 0.30 ± 0.03 C0603X5R0J223K X5R 6.3V 22,000 ± 10% 0.30 ± 0.03 C0603X5R0J223M X5R 6.3V 22,000 ± 20% 0.30 ± 0.03 C0603X5R0J333K X5R 6.3V 33,000 ± 10% 0.30 ± 0.03 C0603X5R0J333M X5R 6.3V 33,000 ± 20% 0.30 ± 0.03 C0603X5R0J473K X5R 6.3V 47,000 ± 10% 0.30 ± 0.03 C0603X5R0J473M X5R 6.3V 47,000 ± 20% 0.30 ± 0.03 C0603X5R0J683K X5R 6.3V 68,000 ± 10% 0.30 ± 0.03 C0603X5R0J683M X5R 6.3V 68,000 ± 20% 0.30 ± 0.03 C0603X5R0J104K X5R 6.3V 100,000 ± 10% 0.30 ± 0.03 C0603X5R0J104M X5R 6.3V 100,000 ± 20% 0.30 ± 0.03 C0603X5R0J154K X5R 6.3V 150,000 ± 10% 0.30 ± 0.03 C0603X5R0J154M X5R 6.3V 150,000 ± 20% 0.30 ± 0.03 C0603X5R0J224K X5R 6.3V 220,000 ± 10% 0.30 ± 0.03 C0603X5R0J224M X5R 6.3V 220,000 ± 20% 0.30 ± 0.03 C0603Y5V1C103Z Y5V 16V 10,000 +80/-20% 0.30 ± 0.03 TDK MLCC US Catalog Page 20 Version B11 Capacitance Range Chart C1005 [EIA CC0402] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC) Rated Voltage: 50V (1H), 25V (1E) Capacitance (pF) 0.1 0.5 0.75 1 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10 11 12 13 15 16 18 20 22 24 27 C0G Cap Code 0R1 0R5 R75 010 1R2 1R5 1R8 2R2 2R7 3R3 3R9 4R7 5R6 6R8 8R2 100 110 120 130 150 160 180 200 220 240 270 Tolerance 1H (50V) Capacitance (pF) 30 33 36 39 43 47 51 56 62 68 75 82 91 100 120 150 180 220 270 330 390 470 560 680 820 1,000 B: ± 0.10pF C: ± 0.25pF D: ± 0.50pF C: ± 0.25pF D: ± 0.50pF J: ± 5% Cap Code 300 330 360 390 430 470 510 560 620 680 750 820 910 101 121 151 181 221 271 331 391 471 561 681 821 102 C0G Tolerance 1H (50V) 1E (25V) J: ± 5% • Standard capacitance is shown. Please refer to Capacitance Range Table for additional capacitance values. Capacitance Range Chart Temperature Characteristics: X7R (± 15%) Rated Voltage: 50V (1H), 35V (1V), 25V (1E), 16V(1C), 10V (1A) Capacitance (pF) 220 330 470 680 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 X7R Cap Code 221 331 471 681 102 152 222 332 472 682 103 153 223 333 473 683 104 154 224 Tolerance 1H (50V) 1V (35V) 1E (25V) 1C (16V) 1A (10V) K: ± 10% M: ± 20% Standard Thickness 0.50 mm TDK MLCC US Catalog Page 21 Version B11 Capacitance Range Chart C1005 [EIA CC0402] Capacitance Range Chart Temperature Characteristics: X5R (± 15%), X6S (± 22%), Y5V (+22/-82%) Rated Voltage: 50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V (0G) Capacitance (pF) 10,000 22,000 47,000 100,000 220,000 470,000 1,000,000 2,200,000 Capacitance (pF) 220 330 470 680 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 220,000 330,000 470,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 Capacitance (pF) 10,000 100,000 220,000 470,000 1,000,000 X6S Cap Code 103 223 473 104 224 474 105 225 Tolerance 1E (25V) 1H (50V) 1V (35V) 1E (25V) 1H (50V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) 0G (4V) 1C (16V) 1A (10V) 0J (6.3V) 0G (4V) 1A (10V) 0J (6.3V) X5R Tolerance K: ± 10% M: ± 20% Y5V Cap Code 103 104 224 474 105 1V (35V) K: ± 10% M: ± 20% Cap Code 221 331 471 681 102 152 222 332 472 682 103 153 223 333 473 683 104 224 334 474 105 155 225 335 475 1H (50V) Tolerance 1C (16V) Z: +80/-20% Standard Thickness 0.50 mm TDK MLCC US Catalog Page 22 Version B11 Capacitance Range Table C1005 [EIA CC0402] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C1005C0G1H0R5B C0G 50V 0.5 ± 0.10pF 0.50 ± 0.05 C1005C0G1H0R5C C0G 50V 0.5 ± 0.25pF 0.50 ± 0.05 C1005C0G1HR75C C0G 50V 0.75 ± 0.25pF 0.50 ± 0.05 C1005C0G1H010B C0G 50V 1.0 ± 0.10pF 0.50 ± 0.05 C1005C0G1H010C C0G 50V 1.0 ± 0.25pF 0.50 ± 0.05 C1005C0G1H1R2B C0G 50V 1.2 ± 0.10pF 0.50 ± 0.05 C1005C0G1H1R2C C0G 50V 1.2 ± 0.25pF 0.50 ± 0.05 C1005C0G1H1R5B C0G 50V 1.5 ± 0.10pF 0.50 ± 0.05 C1005C0G1H1R5C C0G 50V 1.5 ± 0.25pF 0.50 ± 0.05 C1005C0G1H1R8B C0G 50V 1.8 ± 0.10pF 0.50 ± 0.05 C1005C0G1H1R8C C0G 50V 1.8 ± 0.25pF 0.50 ± 0.05 C1005C0G1H020B C0G 50V 2.0 ± 0.10pF 0.50 ± 0.05 C1005C0G1H020C C0G 50V 2.0 ± 0.25pF 0.50 ± 0.05 C1005C0G1H2R2B C0G 50V 2.2 ± 0.10pF 0.50 ± 0.05 C1005C0G1H2R2C C0G 50V 2.2 ± 0.25pF 0.50 ± 0.05 C1005C0G1H2R5C C0G 50V 2.5 ± 0.25pF 0.50 ± 0.05 C1005C0G1H2R7B C0G 50V 2.7 ± 0.10pF 0.50 ± 0.05 C1005C0G1H2R7C C0G 50V 2.7 ± 0.25pF 0.50 ± 0.05 C1005C0G1H030B C0G 50V 3.0 ± 0.10pF 0.50 ± 0.05 C1005C0G1H030C C0G 50V 3.0 ± 0.25pF 0.50 ± 0.05 C1005C0G1H3R3B C0G 50V 3.3 ± 0.10pF 0.50 ± 0.05 C1005C0G1H3R3C C0G 50V 3.3 ± 0.25pF 0.50 ± 0.05 C1005C0G1H3R5C C0G 50V 3.5 ± 0.25pF 0.50 ± 0.05 C1005C0G1H3R9B C0G 50V 3.9 ± 0.10pF 0.50 ± 0.05 C1005C0G1H3R9C C0G 50V 3.9 ± 0.25pF 0.50 ± 0.05 C1005C0G1H040B C0G 50V 4.0 ± 0.10pF 0.50 ± 0.05 C1005C0G1H040C C0G 50V 4.0 ± 0.25pF 0.50 ± 0.05 C1005C0G1H4R7B C0G 50V 4.7 ± 0.10pF 0.50 ± 0.05 C1005C0G1H4R7C C0G 50V 4.7 ± 0.25pF 0.50 ± 0.05 C1005C0G1H050B C0G 50V 5.0 ± 0.10pF 0.50 ± 0.05 C1005C0G1H050C C0G 50V 5.0 ± 0.25pF 0.50 ± 0.05 C1005C0G1H5R6C C0G 50V 5.6 ± 0.25pF 0.50 ± 0.05 C1005C0G1H5R6D C0G 50V 5.6 ± 0.50pF 0.50 ± 0.05 C1005C0G1H060C C0G 50V 6.0 ± 0.25pF 0.50 ± 0.05 C1005C0G1H060D C0G 50V 6.0 ± 0.50pF 0.50 ± 0.05 C1005C0G1H6R8C C0G 50V 6.8 ± 0.25pF 0.50 ± 0.05 C1005C0G1H6R8D C0G 50V 6.8 ± 0.50pF 0.50 ± 0.05 C1005C0G1H070C C0G 50V 7.0 ± 0.25pF 0.50 ± 0.05 C1005C0G1H070D C0G 50V 7.0 ± 0.50pF 0.50 ± 0.05 C1005C0G1H080C C0G 50V 8.0 ± 0.25pF 0.50 ± 0.05 C1005C0G1H080D C0G 50V 8.0 ± 0.50pF 0.50 ± 0.05 C1005C0G1H8R2C C0G 50V 8.2 ± 0.25pF 0.50 ± 0.05 C1005C0G1H8R2D C0G 50V 8.2 ± 0.50pF 0.50 ± 0.05 C1005C0G1H090C C0G 50V 9.0 ± 0.25pF 0.50 ± 0.05 TDK MLCC US Catalog Page 23 Version B11 Capacitance Range Table C1005 [EIA CC0402] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C1005C0G1H090D C0G 50V 9.0 ± 0.50pF 0.50 ± 0.05 C1005C0G1H100C C0G 50V 10 ± 0.25pF 0.50 ± 0.05 C1005C0G1H100D C0G 50V 10 ± 0.50pF 0.50 ± 0.05 C1005C0G1H110J C0G 50V 11 ± 5% 0.50 ± 0.05 C1005C0G1H120J C0G 50V 12 ± 5% 0.50 ± 0.05 C1005C0G1H130J C0G 50V 13 ± 5% 0.50 ± 0.05 C1005C0G1H150J C0G 50V 15 ± 5% 0.50 ± 0.05 C1005C0G1H160J C0G 50V 16 ± 5% 0.50 ± 0.05 C1005C0G1H180J C0G 50V 18 ± 5% 0.50 ± 0.05 C1005C0G1H200J C0G 50V 20 ± 5% 0.50 ± 0.05 C1005C0G1H220J C0G 50V 22 ± 5% 0.50 ± 0.05 C1005C0G1H240J C0G 50V 24 ± 5% 0.50 ± 0.05 C1005C0G1H270J C0G 50V 27 ± 5% 0.50 ± 0.05 C1005C0G1H300J C0G 50V 30 ± 5% 0.50 ± 0.05 C1005C0G1H330J C0G 50V 33 ± 5% 0.50 ± 0.05 C1005C0G1H360J C0G 50V 36 ± 5% 0.50 ± 0.05 C1005C0G1H390J C0G 50V 39 ± 5% 0.50 ± 0.05 C1005C0G1H430J C0G 50V 43 ± 5% 0.50 ± 0.05 C1005C0G1H470J C0G 50V 47 ± 5% 0.50 ± 0.05 C1005C0G1H510J C0G 50V 51 ± 5% 0.50 ± 0.05 C1005C0G1H560J C0G 50V 56 ± 5% 0.50 ± 0.05 C1005C0G1H620J C0G 50V 62 ± 5% 0.50 ± 0.05 C1005C0G1H680J C0G 50V 68 ± 5% 0.50 ± 0.05 C1005C0G1H750J C0G 50V 75 ± 5% 0.50 ± 0.05 C1005C0G1H820J C0G 50V 82 ± 5% 0.50 ± 0.05 C1005C0G1H910J C0G 50V 91 ± 5% 0.50 ± 0.05 C1005C0G1H101J C0G 50V 100 ± 5% 0.50 ± 0.05 C1005C0G1H121J C0G 50V 120 ± 5% 0.50 ± 0.05 C1005C0G1H151J C0G 50V 150 ± 5% 0.50 ± 0.05 C1005C0G1H181J C0G 50V 180 ± 5% 0.50 ± 0.05 C1005C0G1H221J C0G 50V 220 ± 5% 0.50 ± 0.05 C1005C0G1H271J C0G 50V 270 ± 5% 0.50 ± 0.05 C1005C0G1H331J C0G 50V 330 ± 5% 0.50 ± 0.05 C1005C0G1H391J C0G 50V 390 ± 5% 0.50 ± 0.05 C1005C0G1H471J C0G 50V 470 ± 5% 0.50 ± 0.05 C1005C0G1H561J C0G 50V 560 ± 5% 0.50 ± 0.05 C1005C0G1H681J C0G 50V 680 ± 5% 0.50 ± 0.05 C1005C0G1H821J C0G 50V 820 ± 5% 0.50 ± 0.05 C1005C0G1H102J C0G 50V 1,000 ± 5% 0.50 ± 0.05 C1005C0G1E561J C0G 25V 560 ± 5% 0.50 ± 0.05 C1005C0G1E681J C0G 25V 680 ± 5% 0.50 ± 0.05 C1005C0G1E821J C0G 25V 820 ± 5% 0.50 ± 0.05 C1005C0G1E102J C0G 25V 1,000 ± 5% 0.50 ± 0.05 TDK MLCC US Catalog Page 24 Version B11 Capacitance Range Table C1005 [EIA CC0402] Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C1005X7R1H221K X7R 50V 220 ± 10% 0.50 ± 0.05 C1005X7R1H221M X7R 50V 220 ± 20% 0.50 ± 0.05 C1005X7R1H331K X7R 50V 330 ± 10% 0.50 ± 0.05 C1005X7R1H331M X7R 50V 330 ± 20% 0.50 ± 0.05 C1005X7R1H471K X7R 50V 470 ± 10% 0.50 ± 0.05 C1005X7R1H471M X7R 50V 470 ± 20% 0.50 ± 0.05 C1005X7R1H681K X7R 50V 680 ± 10% 0.50 ± 0.05 C1005X7R1H681M X7R 50V 680 ± 20% 0.50 ± 0.05 C1005X7R1H102K X7R 50V 1,000 ± 10% 0.50 ± 0.05 C1005X7R1H102M X7R 50V 1,000 ± 20% 0.50 ± 0.05 C1005X7R1H152K X7R 50V 1,500 ± 10% 0.50 ± 0.05 C1005X7R1H152M X7R 50V 1,500 ± 20% 0.50 ± 0.05 C1005X7R1H222K X7R 50V 2,200 ± 10% 0.50 ± 0.05 C1005X7R1H222M X7R 50V 2,200 ± 20% 0.50 ± 0.05 C1005X7R1H332K X7R 50V 3,300 ± 10% 0.50 ± 0.05 C1005X7R1H332M X7R 50V 3,300 ± 20% 0.50 ± 0.05 C1005X7R1H472K X7R 50V 4,700 ± 10% 0.50 ± 0.05 C1005X7R1H472M X7R 50V 4,700 ± 20% 0.50 ± 0.05 C1005X7R1H682K X7R 50V 6,800 ± 10% 0.50 ± 0.05 C1005X7R1H682M X7R 50V 6,800 ± 20% 0.50 ± 0.05 C1005X7R1H103K X7R 50V 10,000 ± 10% 0.50 ± 0.05 C1005X7R1H103M X7R 50V 10,000 ± 20% 0.50 ± 0.05 C1005X7R1H153K X7R 50V 15,000 ± 10% 0.50 ± 0.05 C1005X7R1H153M X7R 50V 15,000 ± 20% 0.50 ± 0.05 C1005X7R1H223K X7R 50V 22,000 ± 10% 0.50 ± 0.05 C1005X7R1H223M X7R 50V 22,000 ± 20% 0.50 ± 0.05 C1005X7R1H333K X7R 50V 33,000 ± 10% 0.50 ± 0.05 C1005X7R1H333M X7R 50V 33,000 ± 20% 0.50 ± 0.05 C1005X7R1H473K X7R 50V 47,000 ± 10% 0.50 ± 0.05 C1005X7R1H473M X7R 50V 47,000 ± 20% 0.50 ± 0.05 C1005X7R1H683K X7R 50V 68,000 ± 10% 0.50 ± 0.05 C1005X7R1H683M X7R 50V 68,000 ± 20% 0.50 ± 0.05 C1005X7R1H104K X7R 50V 100,000 ± 10% 0.50 ± 0.05 C1005X7R1H104M X7R 50V 100,000 ± 20% 0.50 ± 0.05 C1005X7R1V103K X7R 35V 10,000 ± 10% 0.50 ± 0.05 C1005X7R1V103M X7R 35V 10,000 ± 20% 0.50 ± 0.05 C1005X7R1V223K X7R 35V 22,000 ± 10% 0.50 ± 0.05 C1005X7R1V223M X7R 35V 22,000 ± 20% 0.50 ± 0.05 C1005X7R1V473K X7R 35V 47,000 ± 10% 0.50 ± 0.05 C1005X7R1V473M X7R 35V 47,000 ± 20% 0.50 ± 0.05 C1005X7R1V104K X7R 35V 100,000 ± 10% 0.50 ± 0.05 C1005X7R1V104M X7R 35V 100,000 ± 20% 0.50 ± 0.05 C1005X7R1E102K X7R 25V 1,000 ± 10% 0.50 ± 0.05 C1005X7R1E102M X7R 25V 1,000 ± 20% 0.50 ± 0.05 TDK MLCC US Catalog Page 25 Version B11 Capacitance Range Table C1005 [EIA CC0402] Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C1005X7R1E152K X7R 25V 1,500 ± 10% 0.50 ± 0.05 C1005X7R1E152M X7R 25V 1,500 ± 20% 0.50 ± 0.05 C1005X7R1E222K X7R 25V 2,200 ± 10% 0.50 ± 0.05 C1005X7R1E222M X7R 25V 2,200 ± 20% 0.50 ± 0.05 C1005X7R1E332K X7R 25V 3,300 ± 10% 0.50 ± 0.05 C1005X7R1E332M X7R 25V 3,300 ± 20% 0.50 ± 0.05 C1005X7R1E472K X7R 25V 4,700 ± 10% 0.50 ± 0.05 C1005X7R1E472M X7R 25V 4,700 ± 20% 0.50 ± 0.05 C1005X7R1E682K X7R 25V 6,800 ± 10% 0.50 ± 0.05 C1005X7R1E682M X7R 25V 6,800 ± 20% 0.50 ± 0.05 C1005X7R1E103J X7R 25V 10,000 ± 5% 0.50 ± 0.05 C1005X7R1E103K X7R 25V 10,000 ± 10% 0.50 ± 0.05 C1005X7R1E103M X7R 25V 10,000 ± 20% 0.50 ± 0.05 C1005X7R1E153K X7R 25V 15,000 ± 10% 0.50 ± 0.05 C1005X7R1E153M X7R 25V 15,000 ± 20% 0.50 ± 0.05 C1005X7R1E223K X7R 25V 22,000 ± 10% 0.50 ± 0.05 C1005X7R1E223M X7R 25V 22,000 ± 20% 0.50 ± 0.05 C1005X7R1E333K X7R 25V 33,000 ± 10% 0.50 ± 0.05 C1005X7R1E333M X7R 25V 33,000 ± 20% 0.50 ± 0.05 C1005X7R1E473K X7R 25V 47,000 ± 10% 0.50 ± 0.05 C1005X7R1E473M X7R 25V 47,000 ± 20% 0.50 ± 0.05 C1005X7R1E683K X7R 25V 68,000 ± 10% 0.50 ± 0.05 C1005X7R1E683M X7R 25V 68,000 ± 20% 0.50 ± 0.05 C1005X7R1E104K X7R 25V 100,000 ± 10% 0.50 ± 0.05 C1005X7R1E104M X7R 25V 100,000 ± 20% 0.50 ± 0.05 C1005X7R1C103K X7R 16V 10,000 ± 10% 0.50 ± 0.05 C1005X7R1C103M X7R 16V 10,000 ± 20% 0.50 ± 0.05 C1005X7R1C153K X7R 16V 15,000 ± 10% 0.50 ± 0.05 C1005X7R1C153M X7R 16V 15,000 ± 20% 0.50 ± 0.05 C1005X7R1C223K X7R 16V 22,000 ± 10% 0.50 ± 0.05 C1005X7R1C223M X7R 16V 22,000 ± 20% 0.50 ± 0.05 C1005X7R1C333K X7R 16V 33,000 ± 10% 0.50 ± 0.05 C1005X7R1C333M X7R 16V 33,000 ± 20% 0.50 ± 0.05 C1005X7R1C473K X7R 16V 47,000 ± 10% 0.50 ± 0.05 C1005X7R1C473M X7R 16V 47,000 ± 20% 0.50 ± 0.05 C1005X7R1C683K X7R 16V 68,000 ± 10% 0.50 ± 0.05 C1005X7R1C683M X7R 16V 68,000 ± 20% 0.50 ± 0.05 C1005X7R1C104K X7R 16V 100,000 ± 10% 0.50 ± 0.05 C1005X7R1C104M X7R 16V 100,000 ± 20% 0.50 ± 0.05 C1005X7R1C154K X7R 16V 150,000 ± 10% 0.50 ± 0.05 C1005X7R1C154M X7R 16V 150,000 ± 20% 0.50 ± 0.05 C1005X7R1C224K X7R 16V 220,000 ± 10% 0.50 ± 0.05 C1005X7R1C224M X7R 16V 220,000 ± 20% 0.50 ± 0.05 C1005X7R1A473K X7R 10V 47,000 ± 10% 0.50 ± 0.05 TDK MLCC US Catalog Page 26 Version B11 Capacitance Range Table C1005 [EIA CC0402] Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%), X6S(-55 to 105ºC, ±22%), X5R (-55 to +85ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C1005X7R1A473M X7R 10V 47,000 ± 20% 0.50 ± 0.05 C1005X7R1A683K X7R 10V 68,000 ± 10% 0.50 ± 0.05 C1005X7R1A683M X7R 10V 68,000 ± 20% 0.50 ± 0.05 C1005X7R1A104K X7R 10V 100,000 ± 10% 0.50 ± 0.05 C1005X7R1A104M X7R 10V 100,000 ± 20% 0.50 ± 0.05 C1005X7R1A224K X7R 10V 220,000 ± 10% 0.50 ± 0.05 C1005X7R1A224M X7R 10V 220,000 ± 20% 0.50 ± 0.05 C1005X6S1H103K X6S 50V 10,000 ± 10% 0.50 ± 0.05 C1005X6S1H103M X6S 50V 10,000 ± 20% 0.50 ± 0.05 C1005X6S1H223K X6S 50V 22,000 ± 10% 0.50 ± 0.05 C1005X6S1H223M X6S 50V 22,000 ± 20% 0.50 ± 0.05 C1005X6S1H473K X6S 50V 47,000 ± 10% 0.50 ± 0.05 C1005X6S1H473M X6S 50V 47,000 ± 20% 0.50 ± 0.05 C1005X6S1H104K X6S 50V 100,000 ± 10% 0.50 ± 0.05 C1005X6S1H104M X6S 50V 100,000 ± 20% 0.50 ± 0.05 C1005X6S1V104K X6S 35V 100,000 ± 10% 0.50 ± 0.05 C1005X6S1V104M X6S 35V 100,000 ± 20% 0.50 ± 0.05 C1005X6S1E104K X6S 25V 100,000 ± 10% 0.50 ± 0.05 C1005X6S1E104M X6S 25V 100,000 ± 20% 0.50 ± 0.05 C1005X6S1E224K X6S 25V 220,000 ± 10% 0.50 ± 0.05 C1005X6S1E224M X6S 25V 220,000 ± 20% 0.50 ± 0.05 C1005X6S1C224K X6S 16V 220,000 ± 10% 0.50 ± 0.05 C1005X6S1C224M X6S 16V 220,000 ± 20% 0.50 ± 0.05 C1005X6S1A474K X6S 10V 470,000 ± 10% 0.50 ± 0.05 C1005X6S1A474M X6S 10V 470,000 ± 20% 0.50 ± 0.05 C1005X6S1A105K X6S 10V 1,000,000 ± 10% 0.50 ± 0.05 C1005X6S1A105M X6S 10V 1,000,000 ± 20% 0.50 ± 0.05 C1005X6S0J474K X6S 6.3V 470,000 ± 10% 0.50 ± 0.05 C1005X6S0J474M X6S 6.3V 470,000 ± 20% 0.50 ± 0.05 C1005X6S0J105K X6S 6.3V 1,000,000 ± 10% 0.50 ± 0.05 C1005X6S0J105M X6S 6.3V 1,000,000 ± 20% 0.50 ± 0.05 C1005X6S0G105K X6S 4V 1,000,000 ± 10% 0.50 ± 0.05 C1005X6S0G105M X6S 4V 1,000,000 ± 20% 0.50 ± 0.05 C1005X6S0G225M X6S 4V 2,200,000 ± 20% 0.50 ± 0.05 C1005X5R1H221K X5R 50V 220 ± 10% 0.50 ± 0.05 C1005X5R1H331K X5R 50V 330 ± 10% 0.50 ± 0.05 C1005X5R1H471K X5R 50V 470 ± 10% 0.50 ± 0.05 C1005X5R1H681K X5R 50V 680 ± 10% 0.50 ± 0.05 C1005X5R1H102K X5R 50V 1,000 ± 10% 0.50 ± 0.05 C1005X5R1H152K X5R 50V 1,500 ± 10% 0.50 ± 0.05 C1005X5R1H222K X5R 50V 2,200 ± 10% 0.50 ± 0.05 C1005X5R1H332K X5R 50V 3,300 ± 10% 0.50 ± 0.05 C1005X5R1H472K X5R 50V 4,700 ± 10% 0.50 ± 0.05 C1005X5R1H682K X5R 50V 6,800 ± 10% 0.50 ± 0.05 TDK MLCC US Catalog Page 27 Version B11 Capacitance Range Table C1005 [EIA CC0402] Class 2 (Temperature Stable) Temperature Characteristics: X5R (-55 to +85ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C1005X5R1H473K X5R 50V 47,000 ± 10% 0.50 ± 0.05 C1005X5R1H473M X5R 50V 47,000 ± 20% 0.50 ± 0.05 C1005X5R1H683K X5R 50V 68,000 ± 10% 0.50 ± 0.05 C1005X5R1H683M X5R 50V 68,000 ± 20% 0.50 ± 0.05 C1005X5R1H104K X5R 50V 100,000 ± 10% 0.50 ± 0.05 C1005X5R1H104M X5R 50V 100,000 ± 20% 0.50 ± 0.05 C1005X5R1V104K X5R 35V 100,000 ± 10% 0.50 ± 0.05 C1005X5R1V104M X5R 35V 100,000 ± 20% 0.50 ± 0.05 C1005X5R1E103K X5R 25V 10,000 ± 10% 0.50 ± 0.05 C1005X5R1E153K X5R 25V 15,000 ± 10% 0.50 ± 0.05 C1005X5R1E223K X5R 25V 22,000 ± 10% 0.50 ± 0.05 C1005X5R1E333K X5R 25V 33,000 ± 10% 0.50 ± 0.05 C1005X5R1E473K X5R 25V 47,000 ± 10% 0.50 ± 0.05 C1005X5R1E473M X5R 25V 47,000 ± 20% 0.50 ± 0.05 C1005X5R1E683K X5R 25V 68,000 ± 10% 0.50 ± 0.05 C1005X5R1E683M X5R 25V 68,000 ± 20% 0.50 ± 0.05 C1005X5R1E104K X5R 25V 100,000 ± 10% 0.50 ± 0.05 C1005X5R1E104M X5R 25V 100,000 ± 20% 0.50 ± 0.05 C1005X5R1E224K X5R 25V 220,000 ± 10% 0.50 ± 0.05 C1005X5R1E224M X5R 25V 220,000 ± 20% 0.50 ± 0.05 C1005X5R1C473K X5R 16V 47,000 ± 10% 0.50 ± 0.05 C1005X5R1C473M X5R 16V 47,000 ± 20% 0.50 ± 0.05 C1005X5R1C683K X5R 16V 68,000 ± 10% 0.50 ± 0.05 C1005X5R1C683M X5R 16V 68,000 ± 20% 0.50 ± 0.05 C1005X5R1C104K X5R 16V 100,000 ± 10% 0.50 ± 0.05 C1005X5R1C104M X5R 16V 100,000 ± 20% 0.50 ± 0.05 C1005X5R1C224K X5R 16V 220,000 ± 10% 0.50 ± 0.05 C1005X5R1C224M X5R 16V 220,000 ± 20% 0.50 ± 0.05 C1005X5R1C334K X5R 16V 330,000 ± 10% 0.50 ± 0.05 C1005X5R1C334M X5R 16V 330,000 ± 20% 0.50 ± 0.05 C1005X5R1C474K X5R 16V 470,000 ± 10% 0.50 ± 0.05 C1005X5R1C474M X5R 16V 470,000 ± 20% 0.50 ± 0.05 C1005X5R1C105K X5R 16V 1,000,000 ± 10% 0.50 ± 0.05 C1005X5R1C105M X5R 16V 1,000,000 ± 20% 0.50 ± 0.05 C1005X5R1A473K X5R 10V 47,000 ± 10% 0.50 ± 0.05 C1005X5R1A473M X5R 10V 47,000 ± 20% 0.50 ± 0.05 C1005X5R1A683K X5R 10V 68,000 ± 10% 0.50 ± 0.05 C1005X5R1A683M X5R 10V 68,000 ± 20% 0.50 ± 0.05 C1005X5R1A104K X5R 10V 100,000 ± 10% 0.50 ± 0.05 C1005X5R1A104M X5R 10V 100,000 ± 20% 0.50 ± 0.05 C1005X5R1A224K X5R 10V 220,000 ± 10% 0.50 ± 0.05 C1005X5R1A224M X5R 10V 220,000 ± 20% 0.50 ± 0.05 C1005X5R1A334K X5R 10V 330,000 ± 10% 0.50 ± 0.05 C1005X5R1A334M X5R 10V 330,000 ± 20% 0.50 ± 0.05 TDK MLCC US Catalog Page 28 Version B11 Capacitance Range Table C1005 [EIA CC0402] Class 2 (Temperature Stable) Temperature Characteristics: X5R (-55 to +85ºC, ±15%), Y5V(-30 to +85ºC, +22/-82%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C1005X5R1A474K X5R 10V 470,000 ± 10% 0.50 ± 0.05 C1005X5R1A474M X5R 10V 470,000 ± 20% 0.50 ± 0.05 C1005X5R1A105K X5R 10V 1,000,000 ± 10% 0.50 ± 0.05 C1005X5R1A105M X5R 10V 1,000,000 ± 20% 0.50 ± 0.05 C1005X5R1A155K X5R 10V 1,500,000 ± 10% 0.50 ± 0.05 C1005X5R1A155M X5R 10V 1,500,000 ± 20% 0.50 ± 0.05 C1005X5R1A225K X5R 10V 2,200,000 ± 10% 0.50 ± 0.05 C1005X5R1A225M X5R 10V 2,200,000 ± 20% 0.50 ± 0.05 C1005X5R0J104K X5R 6.3V 100,000 ± 10% 0.50 ± 0.05 C1005X5R0J104M X5R 6.3V 100,000 ± 20% 0.50 ± 0.05 C1005X5R0J224K X5R 6.3V 220,000 ± 10% 0.50 ± 0.05 C1005X5R0J224M X5R 6.3V 220,000 ± 20% 0.50 ± 0.05 C1005X5R0J334K X5R 6.3V 330,000 ± 10% 0.50 ± 0.05 C1005X5R0J334M X5R 6.3V 330,000 ± 20% 0.50 ± 0.05 C1005X5R0J474K X5R 6.3V 470,000 ± 10% 0.50 ± 0.05 C1005X5R0J474M X5R 6.3V 470,000 ± 20% 0.50 ± 0.05 C1005X5R0J105K X5R 6.3V 1,000,000 ± 10% 0.50 ± 0.05 C1005X5R0J105M X5R 6.3V 1,000,000 ± 20% 0.50 ± 0.05 C1005X5R0J225K X5R 6.3V 2,200,000 ± 10% 0.50 ± 0.05 C1005X5R0J225M X5R 6.3V 2,200,000 ± 20% 0.50 ± 0.05 C1005X5R0J335K X5R 6.3V 3,300,000 ± 10% 0.50 ± 0.15 C1005X5R0J335M X5R 6.3V 3,300,000 ± 20% 0.50 ± 0.15 C1005X5R0J475K X5R 6.3V 4,700,000 ± 10% 0.50 ± 0.15 C1005X5R0J475M X5R 6.3V 4,700,000 ± 20% 0.50 ± 0.15 C1005X5R0G225K X5R 4V 2,200,000 ± 10% 0.50 ± 0.05 C1005X5R0G225M X5R 4V 2,200,000 ± 20% 0.50 ± 0.05 C1005X5R0G335K X5R 4V 3,300,000 ± 10% 0.50 ± 0.15 C1005X5R0G335M X5R 4V 3,300,000 ± 20% 0.50 ± 0.15 C1005X5R0G475K X5R 4V 4,700,000 ± 10% 0.50 ± 0.15 C1005X5R0G475M X5R 4V 4,700,000 ± 20% 0.50 ± 0.15 C1005Y5V1H103Z Y5V 50V 10,000 +80/-20% 0.50 ± 0.05 C1005Y5V1E104Z Y5V 25V 100,000 +80/-20% 0.50 ± 0.05 C1005Y5V1E224Z Y5V 25V 220,000 +80/-20% 0.50 ± 0.05 C1005Y5V1C104Z Y5V 16V 100,000 +80/-20% 0.50 ± 0.05 C1005Y5V1C224Z Y5V 16V 220,000 +80/-20% 0.50 ± 0.05 C1005Y5V1A224Z Y5V 10V 220,000 +80/-20% 0.50 ± 0.05 C1005Y5V1A474Z Y5V 10V 470,000 +80/-20% 0.50 ± 0.05 C1005Y5V0J105Z Y5V 6.3V 1,000,000 +80/-20% 0.50 ± 0.05 TDK MLCC US Catalog Page 29 Version B11 Capacitance Range Chart C1608 [EIA CC0603] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC) Rated Voltage: 50V (1H), 25V (1E) Capacitance (pF) 0.1 0.5 0.75 1 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10 11 12 13 15 16 18 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 C0G Cap Code 0R1 0R5 R75 010 1R2 1R5 1R8 2R2 2R7 3R3 3R9 4R7 5R6 6R8 8R2 100 110 120 130 150 160 180 200 220 240 270 300 330 360 390 430 470 510 560 620 680 750 820 Tolerance Capacitance (pF) 1H (50V) 91 100 110 120 130 150 160 180 200 220 240 270 300 330 360 390 430 470 510 560 620 680 750 820 910 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 B: ± 0.10pF C: ± 0.25pF C: ± 0.25pF D: ± 0.50pF J: ± 5% Cap Code 910 101 111 121 131 151 161 181 201 221 241 271 301 331 361 391 431 471 511 561 621 681 751 821 911 102 122 152 182 222 272 332 392 472 562 682 822 103 C0G Tolerance 1H (50V) 1E (25V) J: ± 5% • Standard capacitance is shown. Please refer to Capacitance Range Table for additional capacitance values. Capacitance Range Chart Temperature Characteristics: X6S (± 22%) Rated Voltage: 50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V (0G) Capacitance (pF) 220,000 470,000 1,000,000 2,200,000 4,700,000 10,000,000 X6S Cap Code 224 474 105 225 475 106 Tolerance 1H (50V) 1V (35V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) 0G (4V) K: ± 10% M: ± 20% Standard Thickness 0.80 mm 0.50 mm TDK MLCC US Catalog Page 30 Version B11 Capacitance Range Chart C1608 [EIA CC0603] Capacitance Range Chart Temperature Characteristics: X7R (± 15%), X5R (± 15%), Y5V (+22/-82%) Rated Voltage: 50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V (0G) Capacitance (pF) 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 Capacitance (pF) 100 220 330 470 680 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 2,200,000 Capacitance (pF) 100,000 220,000 470,000 1,000,000 2,200,000 4,700,000 10,000,000 X5R Cap Code 104 154 224 334 474 684 105 155 225 335 475 685 106 Tolerance 1E (25V) 1H (50V) 1V (35V) 1E (25V) 1H (50V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) 1C (16V) 1A (10V) 0J (6.3V) 1A (10V) 0J (6.3V) 0G (4V) X7R Tolerance K: ± 10% M: ± 20% Y5V Cap Code 104 224 474 105 225 475 106 1V (35V) K: ± 10% M: ± 20% Cap Code 101 221 331 471 681 102 152 222 332 472 682 103 153 223 333 473 683 104 154 224 334 474 684 105 225 1H (50V) Tolerance 1C (16V) Z: +80/-20% TDK MLCC US Catalog Standard Thickness 0.80 mm Page 31 Version B11 Capacitance Range Table C1608 [EIA CC0603] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C1608C0G1H0R5B C0G 50V 0.5 ± 0.10pF 0.80 ± 0.10 C1608C0G1H0R5C C0G 50V 0.5 ± 0.25pF 0.80 ± 0.10 C1608C0G1HR75C C0G 50V 0.75 ± 0.25pF 0.80 ± 0.10 C1608C0G1H010B C0G 50V 1.0 ± 0.10pF 0.80 ± 0.10 C1608C0G1H010C C0G 50V 1.0 ± 0.25pF 0.80 ± 0.10 C1608C0G1H1R2B C0G 50V 1.2 ± 0.10pF 0.80 ± 0.10 C1608C0G1H1R2C C0G 50V 1.2 ± 0.25pF 0.80 ± 0.10 C1608C0G1H1R5B C0G 50V 1.5 ± 0.10pF 0.80 ± 0.10 C1608C0G1H1R5C C0G 50V 1.5 ± 0.25pF 0.80 ± 0.10 C1608C0G1H1R8B C0G 50V 1.8 ± 0.10pF 0.80 ± 0.10 C1608C0G1H1R8C C0G 50V 1.8 ± 0.25pF 0.80 ± 0.10 C1608C0G1H020B C0G 50V 2.0 ± 0.10pF 0.80 ± 0.10 C1608C0G1H020C C0G 50V 2.0 ± 0.25pF 0.80 ± 0.10 C1608C0G1H2R2B C0G 50V 2.2 ± 0.10pF 0.80 ± 0.10 C1608C0G1H2R2C C0G 50V 2.2 ± 0.25pF 0.80 ± 0.10 C1608C0G1H2R7B C0G 50V 2.7 ± 0.10pF 0.80 ± 0.10 C1608C0G1H2R7C C0G 50V 2.7 ± 0.25pF 0.80 ± 0.10 C1608C0G1H030B C0G 50V 3.0 ± 0.10pF 0.80 ± 0.10 C1608C0G1H030C C0G 50V 3.0 ± 0.25pF 0.80 ± 0.10 C1608C0G1H3R3B C0G 50V 3.3 ± 0.10pF 0.80 ± 0.10 C1608C0G1H3R3C C0G 50V 3.3 ± 0.25pF 0.80 ± 0.10 C1608C0G1H3R9B C0G 50V 3.9 ± 0.10pF 0.80 ± 0.10 C1608C0G1H3R9C C0G 50V 3.9 ± 0.25pF 0.80 ± 0.10 C1608C0G1H040B C0G 50V 4.0 ± 0.10pF 0.80 ± 0.10 C1608C0G1H040C C0G 50V 4.0 ± 0.25pF 0.80 ± 0.10 C1608C0G1H4R7B C0G 50V 4.7 ± 0.10pF 0.80 ± 0.10 C1608C0G1H4R7C C0G 50V 4.7 ± 0.25pF 0.80 ± 0.10 C1608C0G1H050B C0G 50V 5.0 ± 0.10pF 0.80 ± 0.10 C1608C0G1H050C C0G 50V 5.0 ± 0.25pF 0.80 ± 0.10 C1608C0G1H5R6C C0G 50V 5.6 ± 0.25pF 0.80 ± 0.10 C1608C0G1H5R6D C0G 50V 5.6 ± 0.50pF 0.80 ± 0.10 C1608C0G1H060C C0G 50V 6.0 ± 0.25pF 0.80 ± 0.10 C1608C0G1H060D C0G 50V 6.0 ± 0.50pF 0.80 ± 0.10 C1608C0G1H6R8C C0G 50V 6.8 ± 0.25pF 0.80 ± 0.10 C1608C0G1H6R8D C0G 50V 6.8 ± 0.50pF 0.80 ± 0.10 C1608C0G1H070C C0G 50V 7.0 ± 0.25pF 0.80 ± 0.10 C1608C0G1H070D C0G 50V 7.0 ± 0.50pF 0.80 ± 0.10 C1608C0G1H080C C0G 50V 8.0 ± 0.25pF 0.80 ± 0.10 C1608C0G1H080D C0G 50V 8.0 ± 0.50pF 0.80 ± 0.10 C1608C0G1H8R2C C0G 50V 8.2 ± 0.25pF 0.80 ± 0.10 C1608C0G1H8R2D C0G 50V 8.2 ± 0.50pF 0.80 ± 0.10 C1608C0G1H090C C0G 50V 9.0 ± 0.25pF 0.80 ± 0.10 C1608C0G1H090D C0G 50V 9.0 ± 0.50pF 0.80 ± 0.10 C1608C0G1H100C C0G 50V 10 ± 0.25pF 0.80 ± 0.10 TDK MLCC US Catalog Page 32 Version B11 Capacitance Range Table C1608 [EIA CC0603] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C1608C0G1H100D C0G 50V 10 ± 0.50pF 0.80 ± 0.10 C1608C0G1H110J C0G 50V 11 ± 5% 0.80 ± 0.10 C1608C0G1H120J C0G 50V 12 ± 5% 0.80 ± 0.10 C1608C0G1H130J C0G 50V 13 ± 5% 0.80 ± 0.10 C1608C0G1H150J C0G 50V 15 ± 5% 0.80 ± 0.10 C1608C0G1H160J C0G 50V 16 ± 5% 0.80 ± 0.10 C1608C0G1H180J C0G 50V 18 ± 5% 0.80 ± 0.10 C1608C0G1H200J C0G 50V 20 ± 5% 0.80 ± 0.10 C1608C0G1H220J C0G 50V 22 ± 5% 0.80 ± 0.10 C1608C0G1H240J C0G 50V 24 ± 5% 0.80 ± 0.10 C1608C0G1H270J C0G 50V 27 ± 5% 0.80 ± 0.10 C1608C0G1H300J C0G 50V 30 ± 5% 0.80 ± 0.10 C1608C0G1H330J C0G 50V 33 ± 5% 0.80 ± 0.10 C1608C0G1H360J C0G 50V 36 ± 5% 0.80 ± 0.10 C1608C0G1H390J C0G 50V 39 ± 5% 0.80 ± 0.10 C1608C0G1H430J C0G 50V 43 ± 5% 0.80 ± 0.10 C1608C0G1H470J C0G 50V 47 ± 5% 0.80 ± 0.10 C1608C0G1H510J C0G 50V 51 ± 5% 0.80 ± 0.10 C1608C0G1H560J C0G 50V 56 ± 5% 0.80 ± 0.10 C1608C0G1H620J C0G 50V 62 ± 5% 0.80 ± 0.10 C1608C0G1H680J C0G 50V 68 ± 5% 0.80 ± 0.10 C1608C0G1H750J C0G 50V 75 ± 5% 0.80 ± 0.10 C1608C0G1H820J C0G 50V 82 ± 5% 0.80 ± 0.10 C1608C0G1H910J C0G 50V 91 ± 5% 0.80 ± 0.10 C1608C0G1H101J C0G 50V 100 ± 5% 0.80 ± 0.10 C1608C0G1H111J C0G 50V 110 ± 5% 0.80 ± 0.10 C1608C0G1H121J C0G 50V 120 ± 5% 0.80 ± 0.10 C1608C0G1H131J C0G 50V 130 ± 5% 0.80 ± 0.10 C1608C0G1H151J C0G 50V 150 ± 5% 0.80 ± 0.10 C1608C0G1H161J C0G 50V 160 ± 5% 0.80 ± 0.10 C1608C0G1H181J C0G 50V 180 ± 5% 0.80 ± 0.10 C1608C0G1H201J C0G 50V 200 ± 5% 0.80 ± 0.10 C1608C0G1H221J C0G 50V 220 ± 5% 0.80 ± 0.10 C1608C0G1H241J C0G 50V 240 ± 5% 0.80 ± 0.10 C1608C0G1H271J C0G 50V 270 ± 5% 0.80 ± 0.10 C1608C0G1H301J C0G 50V 300 ± 5% 0.80 ± 0.10 C1608C0G1H331J C0G 50V 330 ± 5% 0.80 ± 0.10 C1608C0G1H361J C0G 50V 360 ± 5% 0.80 ± 0.10 C1608C0G1H391J C0G 50V 390 ± 5% 0.80 ± 0.10 C1608C0G1H431J C0G 50V 430 ± 5% 0.80 ± 0.10 C1608C0G1H471J C0G 50V 470 ± 5% 0.80 ± 0.10 C1608C0G1H511J C0G 50V 510 ± 5% 0.80 ± 0.10 C1608C0G1H561J C0G 50V 560 ± 5% 0.80 ± 0.10 C1608C0G1H621J C0G 50V 620 ± 5% 0.80 ± 0.10 TDK MLCC US Catalog Page 33 Version B11 Capacitance Range Table C1608 [EIA CC0603] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C1608C0G1H681J C0G 50V 680 ± 5% 0.80 ± 0.10 C1608C0G1H751J C0G 50V 750 ± 5% 0.80 ± 0.10 C1608C0G1H821J C0G 50V 820 ± 5% 0.80 ± 0.10 C1608C0G1H911J C0G 50V 910 ± 5% 0.80 ± 0.10 C1608C0G1H102J C0G 50V 1,000 ± 5% 0.80 ± 0.10 C1608C0G1H122J C0G 50V 1,200 ± 5% 0.80 ± 0.10 C1608C0G1H152J C0G 50V 1,500 ± 5% 0.80 ± 0.10 C1608C0G1H182J C0G 50V 1,800 ± 5% 0.80 ± 0.10 C1608C0G1H222J C0G 50V 2,200 ± 5% 0.80 ± 0.10 C1608C0G1H272J C0G 50V 2,700 ± 5% 0.80 ± 0.10 C1608C0G1H332J C0G 50V 3,300 ± 5% 0.80 ± 0.10 C1608C0G1H392J C0G 50V 3,900 ± 5% 0.80 ± 0.10 C1608C0G1H472J C0G 50V 4,700 ± 5% 0.80 ± 0.10 C1608C0G1H562J C0G 50V 5,600 ± 5% 0.80 ± 0.10 C1608C0G1H682J C0G 50V 6,800 ± 5% 0.80 ± 0.10 C1608C0G1H822J C0G 50V 8,200 ± 5% 0.80 ± 0.10 C1608C0G1H103J C0G 50V 10,000 ± 5% 0.80 ± 0.10 C1608C0G1E392J C0G 25V 3,900 ± 5% 0.80 ± 0.10 C1608C0G1E472J C0G 25V 4,700 ± 5% 0.80 ± 0.10 C1608C0G1E562J C0G 25V 5,600 ± 5% 0.80 ± 0.10 C1608C0G1E682J C0G 25V 6,800 ± 5% 0.80 ± 0.10 C1608C0G1E822J C0G 25V 8,200 ± 5% 0.80 ± 0.10 C1608C0G1E103J C0G 25V 10,000 ± 5% 0.80 ± 0.10 Capacitance Tolerance Thickness (mm) Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) C1608X7R1H101K X7R 50V 100 ± 10% 0.80 ± 0.10 C1608X7R1H101M X7R 50V 100 ± 20% 0.80 ± 0.10 C1608X7R1H221K X7R 50V 220 ± 10% 0.80 ± 0.10 C1608X7R1H221M X7R 50V 220 ± 20% 0.80 ± 0.10 C1608X7R1H331K X7R 50V 330 ± 10% 0.80 ± 0.10 C1608X7R1H331M X7R 50V 330 ± 20% 0.80 ± 0.10 C1608X7R1H471K X7R 50V 470 ± 10% 0.80 ± 0.10 C1608X7R1H471M X7R 50V 470 ± 20% 0.80 ± 0.10 C1608X7R1H681K X7R 50V 680 ± 10% 0.80 ± 0.10 C1608X7R1H681M X7R 50V 680 ± 20% 0.80 ± 0.10 C1608X7R1H102J X7R 50V 1,000 ± 5% 0.80 ± 0.10 C1608X7R1H102K X7R 50V 1,000 ± 10% 0.80 ± 0.10 C1608X7R1H102M X7R 50V 1,000 ± 20% 0.80 ± 0.10 C1608X7R1H152K X7R 50V 1,500 ± 10% 0.80 ± 0.10 C1608X7R1H152M X7R 50V 1,500 ± 20% 0.80 ± 0.10 C1608X7R1H222K X7R 50V 2,200 ± 10% 0.80 ± 0.10 C1608X7R1H222M X7R 50V 2,200 ± 20% 0.80 ± 0.10 TDK MLCC US Catalog Page 34 Version B11 Capacitance Range Table C1608 [EIA CC0603] Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C1608X7R1H332K X7R 50V 3,300 ± 10% 0.80 ± 0.10 C1608X7R1H332M X7R 50V 3,300 ± 20% 0.80 ± 0.10 C1608X7R1H472K X7R 50V 4,700 ± 10% 0.80 ± 0.10 C1608X7R1H472M X7R 50V 4,700 ± 20% 0.80 ± 0.10 C1608X7R1H682K X7R 50V 6,800 ± 10% 0.80 ± 0.10 C1608X7R1H682M X7R 50V 6,800 ± 20% 0.80 ± 0.10 C1608X7R1H103J X7R 50V 10,000 ± 5% 0.80 ± 0.10 C1608X7R1H103K X7R 50V 10,000 ± 10% 0.80 ± 0.10 C1608X7R1H103M X7R 50V 10,000 ± 20% 0.80 ± 0.10 C1608X7R1H153K X7R 50V 15,000 ± 10% 0.80 ± 0.10 C1608X7R1H153M X7R 50V 15,000 ± 20% 0.80 ± 0.10 C1608X7R1H223K X7R 50V 22,000 ± 10% 0.80 ± 0.10 C1608X7R1H223M X7R 50V 22,000 ± 20% 0.80 ± 0.10 C1608X7R1H333K X7R 50V 33,000 ± 10% 0.80 ± 0.10 C1608X7R1H333M X7R 50V 33,000 ± 20% 0.80 ± 0.10 C1608X7R1H473K X7R 50V 47,000 ± 10% 0.80 ± 0.10 C1608X7R1H473M X7R 50V 47,000 ± 20% 0.80 ± 0.10 C1608X7R1H683K X7R 50V 68,000 ± 10% 0.80 ± 0.10 C1608X7R1H683M X7R 50V 68,000 ± 20% 0.80 ± 0.10 C1608X7R1H104K X7R 50V 100,000 ± 10% 0.80 ± 0.10 C1608X7R1H104M X7R 50V 100,000 ± 20% 0.80 ± 0.10 C1608X7R1H154K X7R 50V 150,000 ± 10% 0.80 ± 0.10 C1608X7R1H154M X7R 50V 150,000 ± 20% 0.80 ± 0.10 C1608X7R1H224K X7R 50V 220,000 ± 10% 0.80 ± 0.10 C1608X7R1H224M X7R 50V 220,000 ± 20% 0.80 ± 0.10 C1608X7R1H334K X7R 50V 330,000 ± 10% 0.80 ± 0.10 C1608X7R1H334M X7R 50V 330,000 ± 20% 0.80 ± 0.10 C1608X7R1H474K X7R 50V 470,000 ± 10% 0.80 ± 0.10 C1608X7R1H474M X7R 50V 470,000 ± 20% 0.80 ± 0.10 C1608X7R1V334K X7R 35V 330,000 ± 10% 0.80 ± 0.10 C1608X7R1V334M X7R 35V 330,000 ± 20% 0.80 ± 0.10 C1608X7R1V474K X7R 35V 470,000 ± 10% 0.80 ± 0.10 C1608X7R1V474M X7R 35V 470,000 ± 20% 0.80 ± 0.10 C1608X7R1V105K X7R 35V 1,000,000 ± 10% 0.80 ± 0.10 C1608X7R1V105M X7R 35V 1,000,000 ± 20% 0.80 ± 0.10 C1608X7R1E103J X7R 25V 10,000 ± 5% 0.80 ± 0.10 C1608X7R1E103K X7R 25V 10,000 ± 10% 0.80 ± 0.10 C1608X7R1E103M X7R 25V 10,000 ± 20% 0.80 ± 0.10 C1608X7R1E153K X7R 25V 15,000 ± 10% 0.80 ± 0.10 C1608X7R1E153M X7R 25V 15,000 ± 20% 0.80 ± 0.10 C1608X7R1E223K X7R 25V 22,000 ± 10% 0.80 ± 0.10 C1608X7R1E223M X7R 25V 22,000 ± 20% 0.80 ± 0.10 C1608X7R1E333K X7R 25V 33,000 ± 10% 0.80 ± 0.10 C1608X7R1E333M X7R 25V 33,000 ± 20% 0.80 ± 0.10 TDK MLCC US Catalog Page 35 Version B11 Capacitance Range Table C1608 [EIA CC0603] Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C1608X7R1E473K X7R 25V 47,000 ± 10% 0.80 ± 0.10 C1608X7R1E473M X7R 25V 47,000 ± 20% 0.80 ± 0.10 C1608X7R1E683K X7R 25V 68,000 ± 10% 0.80 ± 0.10 C1608X7R1E683M X7R 25V 68,000 ± 20% 0.80 ± 0.10 C1608X7R1E104K X7R 25V 100,000 ± 10% 0.80 ± 0.10 C1608X7R1E104M X7R 25V 100,000 ± 20% 0.80 ± 0.10 C1608X7R1E154K X7R 25V 150,000 ± 10% 0.80 ± 0.10 C1608X7R1E154M X7R 25V 150,000 ± 20% 0.80 ± 0.10 C1608X7R1E224K X7R 25V 220,000 ± 10% 0.80 ± 0.10 C1608X7R1E224M X7R 25V 220,000 ± 20% 0.80 ± 0.10 C1608X7R1E334K X7R 25V 330,000 ± 10% 0.80 ± 0.10 C1608X7R1E334M X7R 25V 330,000 ± 20% 0.80 ± 0.10 C1608X7R1E474K X7R 25V 470,000 ± 10% 0.80 ± 0.10 C1608X7R1E474M X7R 25V 470,000 ± 20% 0.80 ± 0.10 C1608X7R1E684K X7R 25V 680,000 ± 10% 0.80 ± 0.10 C1608X7R1E684M X7R 25V 680,000 ± 20% 0.80 ± 0.10 C1608X7R1E105K X7R 25V 1,000,000 ± 10% 0.80 ± 0.10 C1608X7R1E105M X7R 25V 1,000,000 ± 20% 0.80 ± 0.10 C1608X7R1C223K X7R 16V 22,000 ± 10% 0.80 ± 0.10 C1608X7R1C223M X7R 16V 22,000 ± 20% 0.80 ± 0.10 C1608X7R1C333K X7R 16V 33,000 ± 10% 0.80 ± 0.10 C1608X7R1C333M X7R 16V 33,000 ± 20% 0.80 ± 0.10 C1608X7R1C473K X7R 16V 47,000 ± 10% 0.80 ± 0.10 C1608X7R1C473M X7R 16V 47,000 ± 20% 0.80 ± 0.10 C1608X7R1C683K X7R 16V 68,000 ± 10% 0.80 ± 0.10 C1608X7R1C683M X7R 16V 68,000 ± 20% 0.80 ± 0.10 C1608X7R1C104K X7R 16V 100,000 ± 10% 0.80 ± 0.10 C1608X7R1C104M X7R 16V 100,000 ± 20% 0.80 ± 0.10 C1608X7R1C154K X7R 16V 150,000 ± 10% 0.80 ± 0.10 C1608X7R1C154M X7R 16V 150,000 ± 20% 0.80 ± 0.10 C1608X7R1C224K X7R 16V 220,000 ± 10% 0.80 ± 0.10 C1608X7R1C224M X7R 16V 220,000 ± 20% 0.80 ± 0.10 C1608X7R1C334K X7R 16V 330,000 ± 10% 0.80 ± 0.10 C1608X7R1C334M X7R 16V 330,000 ± 20% 0.80 ± 0.10 C1608X7R1C474K X7R 16V 470,000 ± 10% 0.80 ± 0.10 C1608X7R1C474M X7R 16V 470,000 ± 20% 0.80 ± 0.10 C1608X7R1C684K X7R 16V 680,000 ± 10% 0.80 ± 0.10 C1608X7R1C684M X7R 16V 680,000 ± 20% 0.80 ± 0.10 C1608X7R1C105K X7R 16V 1,000,000 ± 10% 0.80 ± 0.10 C1608X7R1C105M X7R 16V 1,000,000 ± 20% 0.80 ± 0.10 C1608X7R1A224K X7R 10V 220,000 ± 10% 0.80 ± 0.10 C1608X7R1A224M X7R 10V 220,000 ± 20% 0.80 ± 0.10 C1608X7R1A334K X7R 10V 330,000 ± 10% 0.80 ± 0.10 C1608X7R1A334M X7R 10V 330,000 ± 20% 0.80 ± 0.10 TDK MLCC US Catalog Page 36 Version B11 Capacitance Range Table C1608 [EIA CC0603] Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%), X6S (-55 to +105ºC, ±22%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C1608X7R1A474K X7R 10V 470,000 ± 10% 0.80 ± 0.10 C1608X7R1A474M X7R 10V 470,000 ± 20% 0.80 ± 0.10 C1608X7R1A105K X7R 10V 1,000,000 ± 10% 0.80 ± 0.10 C1608X7R1A105M X7R 10V 1,000,000 ± 20% 0.80 ± 0.10 C1608X7R1A225K X7R 10V 2,200,000 ± 10% 0.80 ± 0.10 C1608X7R1A225M X7R 10V 2,200,000 ± 20% 0.80 ± 0.10 C1608X7R0J225K X7R 6.3V 2,200,000 ± 10% 0.80 ± 0.10 C1608X7R0J225M X7R 6.3V 2,200,000 ± 20% 0.80 ± 0.10 C1608X6S1H224K X6S 50V 220,000 ± 10% 0.80 ± 0.10 C1608X6S1H224M X6S 50V 220,000 ± 20% 0.80 ± 0.10 C1608X6S1H474K X6S 50V 470,000 ± 10% 0.80 ± 0.10 C1608X6S1H474M X6S 50V 470,000 ± 20% 0.80 ± 0.10 C1608X6S1H105K X6S 50V 1,000,000 ± 10% 0.80 ± 0.10 C1608X6S1H105M X6S 50V 1,000,000 ± 20% 0.80 ± 0.10 C1608X6S1V224K X6S 35V 220,000 ± 10% 0.80 ± 0.10 C1608X6S1V224M X6S 35V 220,000 ± 20% 0.80 ± 0.10 C1608X6S1V474K X6S 35V 470,000 ± 10% 0.80 ± 0.10 C1608X6S1V474M X6S 35V 470,000 ± 20% 0.80 ± 0.10 C1608X6S1V105K X6S 35V 1,000,000 ± 10% 0.80 ± 0.10 C1608X6S1V105M X6S 35V 1,000,000 ± 20% 0.80 ± 0.10 C1608X6S1E474K X6S 25V 470,000 ± 10% 0.80 ± 0.10 C1608X6S1E474M X6S 25V 470,000 ± 20% 0.80 ± 0.10 C1608X6S1E105K X6S 25V 1,000,000 ± 10% 0.80 ± 0.10 C1608X6S1E105M X6S 25V 1,000,000 ± 20% 0.80 ± 0.10 C1608X6S1C105K X6S 16V 1,000,000 ± 10% 0.80 ± 0.10 C1608X6S1C105M X6S 16V 1,000,000 ± 20% 0.80 ± 0.10 C1608X6S1C225K X6S 16V 2,200,000 ± 10% 0.80 ± 0.10 C1608X6S1C225M X6S 16V 2,200,000 ± 20% 0.80 ± 0.10 C1608X6S1A225K/0.50 X6S 10V 2,200,000 ± 10% 0.50 ± 0.05 C1608X6S1A225M/0.50 X6S 10V 2,200,000 ± 20% 0.50 ± 0.05 C1608X6S1A475K X6S 10V 4,700,000 ± 10% 0.80 ± 0.10 C1608X6S1A475M X6S 10V 4,700,000 ± 20% 0.80 ± 0.10 C1608X6S0J225K X6S 6.3V 2,200,000 ± 10% 0.80 ± 0.10 C1608X6S0J225M X6S 6.3V 2,200,000 ± 20% 0.80 ± 0.10 C1608X6S0J475K X6S 6.3V 4,700,000 ± 10% 0.80 ± 0.10 C1608X6S0J475M X6S 6.3V 4,700,000 ± 20% 0.80 ± 0.10 C1608X6S0G225K/0.50 X6S 4V 2,200,000 ± 10% 0.50 ± 0.05 C1608X6S0G225M/0.50 X6S 4V 2,200,000 ± 20% 0.50 ± 0.05 C1608X6S0G475K/0.50 X6S 4V 4,700,000 ± 10% 0.50 ± 0.05 C1608X6S0G475M/0.50 X6S 4V 4,700,000 ± 20% 0.50 ± 0.05 C1608X6S0G475K/0.80 X6S 4V 4,700,000 ± 10% 0.80 ± 0.10 C1608X6S0G475M/0.80 X6S 4V 4,700,000 ± 20% 0.80 ± 0.10 C1608X6S0G106K X6S 4V 10,000,000 ± 10% 0.80 ± 0.10 C1608X6S0G106M X6S 4V 10,000,000 ± 20% 0.80 ± 0.10 TDK MLCC US Catalog Page 37 Version B11 Capacitance Range Table C1608 [EIA CC0603] Class 2 (Temperature Stable) Temperature Characteristics: X5R (-55 to +85ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C1608X5R1H104K X5R 50V 100,000 ± 10% 0.80 ± 0.10 C1608X5R1H104M X5R 50V 100,000 ± 20% 0.80 ± 0.10 C1608X5R1H154K X5R 50V 150,000 ± 10% 0.80 ± 0.10 C1608X5R1H154M X5R 50V 150,000 ± 20% 0.80 ± 0.10 C1608X5R1H224K X5R 50V 220,000 ± 10% 0.80 ± 0.10 C1608X5R1H224M X5R 50V 220,000 ± 20% 0.80 ± 0.10 C1608X5R1H334K X5R 50V 330,000 ± 10% 0.80 ± 0.10 C1608X5R1H334M X5R 50V 330,000 ± 20% 0.80 ± 0.10 C1608X5R1H474K X5R 50V 470,000 ± 10% 0.80 ± 0.10 C1608X5R1H474M X5R 50V 470,000 ± 20% 0.80 ± 0.10 C1608X5R1H684K X5R 50V 680,000 ± 10% 0.80 ± 0.10 C1608X5R1H684M X5R 50V 680,000 ± 20% 0.80 ± 0.10 C1608X5R1H105K X5R 50V 1,000,000 ± 10% 0.80 ± 0.10 C1608X5R1H105M X5R 50V 1,000,000 ± 20% 0.80 ± 0.10 C1608X5R1V105K X5R 35V 1,000,000 ± 10% 0.80 ± 0.10 C1608X5R1V105M X5R 35V 1,000,000 ± 20% 0.80 ± 0.10 C1608X5R1E154K X5R 25V 150,000 ± 10% 0.80 ± 0.10 C1608X5R1E154M X5R 25V 150,000 ± 20% 0.80 ± 0.10 C1608X5R1E224K X5R 25V 220,000 ± 10% 0.80 ± 0.10 C1608X5R1E224M X5R 25V 220,000 ± 20% 0.80 ± 0.10 C1608X5R1E334K X5R 25V 330,000 ± 10% 0.80 ± 0.10 C1608X5R1E334M X5R 25V 330,000 ± 20% 0.80 ± 0.10 C1608X5R1E474K X5R 25V 470,000 ± 10% 0.80 ± 0.10 C1608X5R1E474M X5R 25V 470,000 ± 20% 0.80 ± 0.10 C1608X5R1E105K X5R 25V 1,000,000 ± 10% 0.80 ± 0.10 C1608X5R1E105M X5R 25V 1,000,000 ± 20% 0.80 ± 0.10 C1608X5R1E155K X5R 25V 1,500,000 ± 10% 0.80 ± 0.10 C1608X5R1E155M X5R 25V 1,500,000 ± 20% 0.80 ± 0.10 C1608X5R1E225K X5R 25V 2,200,000 ± 10% 0.80 ± 0.10 C1608X5R1E225M X5R 25V 2,200,000 ± 20% 0.80 ± 0.10 C1608X5R1C224K X5R 16V 220,000 ± 10% 0.80 ± 0.10 C1608X5R1C224M X5R 16V 220,000 ± 20% 0.80 ± 0.10 C1608X5R1C334K X5R 16V 330,000 ± 10% 0.80 ± 0.10 C1608X5R1C334M X5R 16V 330,000 ± 20% 0.80 ± 0.10 C1608X5R1C474K X5R 16V 470,000 ± 10% 0.80 ± 0.10 C1608X5R1C474M X5R 16V 470,000 ± 20% 0.80 ± 0.10 C1608X5R1C684K X5R 16V 680,000 ± 10% 0.80 ± 0.10 C1608X5R1C684M X5R 16V 680,000 ± 20% 0.80 ± 0.10 C1608X5R1C105K X5R 16V 1,000,000 ± 10% 0.80 ± 0.10 C1608X5R1C105M X5R 16V 1,000,000 ± 20% 0.80 ± 0.10 C1608X5R1C225K/0.50 X5R 16V 2,200,000 ± 10% 0.50 ± 0.05 C1608X5R1C225M/0.50 X5R 16V 2,200,000 ± 20% 0.50 ± 0.05 C1608X5R1C225K/0.80 X5R 16V 2,200,000 ± 10% 0.80 ± 0.10 C1608X5R1C225M/0.80 X5R 16V 2,200,000 ± 20% 0.80 ± 0.10 TDK MLCC US Catalog Page 38 Version B11 Capacitance Range Table C1608 [EIA CC0603] Class 2 (Temperature Stable) Temperature Characteristics: X5R (-55 to +85ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C1608X5R1C335K X5R 16V 3,300,000 ± 10% 0.80 ± 0.10 C1608X5R1C335M X5R 16V 3,300,000 ± 20% 0.80 ± 0.10 C1608X5R1C475K X5R 16V 4,700,000 ± 10% 0.80 ± 0.10 C1608X5R1C475M X5R 16V 4,700,000 ± 20% 0.80 ± 0.10 C1608X5R1A224K X5R 10V 220,000 ± 10% 0.80 ± 0.10 C1608X5R1A224M X5R 10V 220,000 ± 20% 0.80 ± 0.10 C1608X5R1A334K X5R 10V 330,000 ± 10% 0.80 ± 0.10 C1608X5R1A334M X5R 10V 330,000 ± 20% 0.80 ± 0.10 C1608X5R1A474K X5R 10V 470,000 ± 10% 0.80 ± 0.10 C1608X5R1A474M X5R 10V 470,000 ± 20% 0.80 ± 0.10 C1608X5R1A684K X5R 10V 680,000 ± 10% 0.80 ± 0.10 C1608X5R1A684M X5R 10V 680,000 ± 20% 0.80 ± 0.10 C1608X5R1A105K X5R 10V 1,000,000 ± 10% 0.80 ± 0.10 C1608X5R1A105M X5R 10V 1,000,000 ± 20% 0.80 ± 0.10 C1608X5R1A225K/0.50 X5R 10V 2,200,000 ± 10% 0.50 ± 0.05 C1608X5R1A225M/0.50 X5R 10V 2,200,000 ± 20% 0.50 ± 0.05 C1608X5R1A225K/0.80 X5R 10V 2,200,000 ± 10% 0.80 ± 0.10 C1608X5R1A225M/0.80 X5R 10V 2,200,000 ± 20% 0.80 ± 0.10 C1608X5R1A335K X5R 10V 3,300,000 ± 10% 0.80 ± 0.10 C1608X5R1A335M X5R 10V 3,300,000 ± 20% 0.80 ± 0.10 C1608X5R1A475K/0.50 X5R 10V 4,700,000 ± 10% 0.50 ± 0.05 C1608X5R1A475M/0.50 X5R 10V 4,700,000 ± 20% 0.50 ± 0.05 C1608X5R1A475K/0.80 X5R 10V 4,700,000 ± 10% 0.80 ± 0.10 C1608X5R1A475M/0.80 X5R 10V 4,700,000 ± 20% 0.80 ± 0.10 C1608X5R1A685K X5R 10V 6,800,000 ± 10% 0.80 ± 0.10 C1608X5R1A685M X5R 10V 6,800,000 ± 20% 0.80 ± 0.10 C1608X5R1A106K X5R 10V 10,000,000 ± 10% 0.80 ± 0.10 C1608X5R1A106M X5R 10V 10,000,000 ± 20% 0.80 ± 0.10 C1608X5R0J105K X5R 6.3V 1,000,000 ± 10% 0.80 ± 0.10 C1608X5R0J105M X5R 6.3V 1,000,000 ± 20% 0.80 ± 0.10 C1608X5R0J155K X5R 6.3V 1,500,000 ± 10% 0.80 ± 0.10 C1608X5R0J155M X5R 6.3V 1,500,000 ± 20% 0.80 ± 0.10 C1608X5R0J225K X5R 6.3V 2,200,000 ± 10% 0.80 ± 0.10 C1608X5R0J225M X5R 6.3V 2,200,000 ± 20% 0.80 ± 0.10 C1608X5R0J335K X5R 6.3V 3,300,000 ± 10% 0.80 ± 0.15 C1608X5R0J335M X5R 6.3V 3,300,000 ± 20% 0.80 ± 0.15 C1608X5R0J475K/0.50 X5R 6.3V 4,700,000 ± 10% 0.50 ± 0.05 C1608X5R0J475M/0.50 X5R 6.3V 4,700,000 ± 20% 0.50 ± 0.05 C1608X5R0J475K/0.80 X5R 6.3V 4,700,000 ± 10% 0.80 ± 0.15 C1608X5R0J475M/0.80 X5R 6.3V 4,700,000 ± 20% 0.80 ± 0.15 C1608X5R0J685K X5R 6.3V 6,800,000 ± 10% 0.80 ± 0.15 C1608X5R0J685M X5R 6.3V 6,800,000 ± 20% 0.80 ± 0.15 C1608X5R0J106K X5R 6.3V 10,000,000 ± 10% 0.80 ± 0.10 C1608X5R0J106M X5R 6.3V 10,000,000 ± 20% 0.80 ± 0.20 TDK MLCC US Catalog Page 39 Version B11 Capacitance Range Table C1608 [EIA CC0603] Class 2 (Temperature Stable) Temperature Characteristics: X5R (-55 to +85ºC, ±15%), Y5V(-30 to +85ºC, +22/-82%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C1608X5R0G106M X5R 4V 10,000,000 ± 20% 0.80 ± 0.20 C1608Y5V1H104Z Y5V 50V 100,000 +80/-20% 0.80 ± 0.10 C1608Y5V1H224Z Y5V 50V 220,000 +80/-20% 0.80 ± 0.10 C1608Y5V1H474Z Y5V 50V 470,000 +80/-20% 0.80 ± 0.10 C1608Y5V1E104Z Y5V 25V 100,000 +80/-20% 0.80 ± 0.10 C1608Y5V1E224Z Y5V 25V 220,000 +80/-20% 0.80 ± 0.10 C1608Y5V1E474Z Y5V 25V 470,000 +80/-20% 0.80 ± 0.10 C1608Y5V1E105Z Y5V 25V 1,000,000 +80/-20% 0.80 ± 0.10 C1608Y5V1C104Z Y5V 16V 100,000 +80/-20% 0.80 ± 0.10 C1608Y5V1C105Z Y5V 16V 1,000,000 +80/-20% 0.80 ± 0.10 C1608Y5V1C225Z Y5V 16V 2,200,000 +80/-20% 0.80 ± 0.10 C1608Y5V1A105Z Y5V 10V 1,000,000 +80/-20% 0.80 ± 0.10 C1608Y5V1A225Z Y5V 10V 2,200,000 +80/-20% 0.80 ± 0.10 C1608Y5V0J475Z Y5V 6.3V 4,700,000 +80/-20% 0.80 ± 0.10 C1608Y5V0J106Z Y5V 6.3V 10,000,000 +80/-20% 0.80 ± 0.15 TDK MLCC US Catalog Page 40 Version B11 Capacitance Range Chart C2012 [EIA CC0805] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC) Rated Voltage: 50V (1H), 25V (1E) Capacitance (pF) 10 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 C0G Cap Code 100 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 153 223 333 Tolerance 1H (50V) 1E (25V) J: ± 5% • Standard capacitance is shown. Please refer to Capacitance Range Table for additional capacitance values. Capacitance Range Chart Temperature Characteristics: X6S (± 22%) Rated Voltage: 50V (1H), 35V (1V). 25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V(0G) Capacitance (pF) Cap Code 1,000,000 2,200,000 4,700,000 10,000,000 22,000,000 47,000,000 105 225 475 106 226 476 X6S Tolerance 1H (50V) 1V (35V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) 0G (4V) K: ± 10% M: ± 20% • Standard thickness is shown. Please refer to Capacitance Range Table for additional thicknesses. Standard Thickness 0.60 mm 0.85 mm 1.25 mm TDK MLCC US Catalog Page 41 Version B11 Capacitance Range Chart C2012 [EIA CC0805] Capacitance Range Chart Temperature Characteristics: X7R (± 15%), X5R (± 15%), Y5V (+22/-82%) Rated Voltage: 50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V (0G) Capacitance (pF) Cap Code 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 33,000,000 47,000,000 105 155 225 335 475 685 106 156 226 336 476 Capacitance (pF) Cap Code 1,000 2,200 4,700 10,000 22,000 47,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 10,000,000 102 222 472 103 223 473 104 154 224 334 474 684 105 155 225 335 475 106 Capacitance (pF) Cap Code 100,000 470,000 1,000,000 2,200,000 4,700,000 10,000,000 22,000,000 104 474 105 225 475 106 226 X5R Tolerance 1H (50V) 1E (25V) 1C (16V) 1H (50V) 1V (35V) 1E (25V) 1A (10V) 0J (6.3V) 0G (4V) 1C (16V) 1A (10V) 0J (6.3V) 1A (10V) 0J (6.3V) K: ± 10% M: ± 20% X7R Tolerance K: ± 10% M: ± 20% Y5V Tolerance 1H (50V) 1E (25V) 1C (16V) Z: +80/-20% Standard Thickness • Standard thickness is shown. Please refer to Capacitance Range Table for additional thicknesses. TDK MLCC US Catalog Page 42 0.60 mm 0.85 mm 1.25 mm Version B11 Capacitance Range Table C2012 [EIA CC0805] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C2012C0G1H100D C0G 50V 10 ± 0.50pF 0.60 ± 0.10 C2012C0G1H101J C0G 50V 100 ± 5% 0.60 ± 0.10 C2012C0G1H121J C0G 50V 120 ± 5% 0.60 ± 0.10 C2012C0G1H151J C0G 50V 150 ± 5% 0.60 ± 0.10 C2012C0G1H181J C0G 50V 180 ± 5% 0.60 ± 0.10 C2012C0G1H221J C0G 50V 220 ± 5% 0.60 ± 0.10 C2012C0G1H271J C0G 50V 270 ± 5% 0.60 ± 0.10 C2012C0G1H331J C0G 50V 330 ± 5% 0.60 ± 0.10 C2012C0G1H391J C0G 50V 390 ± 5% 0.60 ± 0.10 C2012C0G1H471J C0G 50V 470 ± 5% 0.60 ± 0.10 C2012C0G1H561J C0G 50V 560 ± 5% 0.60 ± 0.10 C2012C0G1H681J C0G 50V 680 ± 5% 0.60 ± 0.10 C2012C0G1H821J C0G 50V 820 ± 5% 0.60 ± 0.10 C2012C0G1H102J C0G 50V 1,000 ± 5% 0.60 ± 0.10 C2012C0G1H122J C0G 50V 1,200 ± 5% 0.60 ± 0.10 C2012C0G1H152J C0G 50V 1,500 ± 5% 0.60 ± 0.10 C2012C0G1H182J/0.60 C0G 50V 1,800 ± 5% 0.60 ± 0.10 C2012C0G1H182J/0.85 C0G 50V 1,800 ± 5% 0.85 ± 0.10 C2012C0G1H222J/0.60 C0G 50V 2,200 ± 5% 0.60 ± 0.10 C2012C0G1H222J/0.85 C0G 50V 2,200 ± 5% 0.85 ± 0.10 C2012C0G1H272J/0.60 C0G 50V 2,700 ± 5% 0.60 ± 0.10 C2012C0G1H272J/1.25 C0G 50V 2,700 ± 5% 1.25 ± 0.20 C2012C0G1H332J/0.60 C0G 50V 3,300 ± 5% 0.60 ± 0.10 C2012C0G1H332J/1.25 C0G 50V 3,300 ± 5% 1.25 ± 0.20 C2012C0G1H392J/0.60 C0G 50V 3,900 ± 5% 0.60 ± 0.10 C2012C0G1H392J/0.85 C0G 50V 3,900 ± 5% 0.85 ± 0.10 C2012C0G1H472J/0.60 C0G 50V 4,700 ± 5% 0.60 ± 0.10 C2012C0G1H472J/0.85 C0G 50V 4,700 ± 5% 0.85 ± 0.10 C2012C0G1H562J/0.60 C0G 50V 5,600 ± 5% 0.60 ± 0.10 C2012C0G1H562J/0.85 C0G 50V 5,600 ± 5% 0.85 ± 0.10 C2012C0G1H682J/0.60 C0G 50V 6,800 ± 5% 0.60 ± 0.10 C2012C0G1H682J/1.25 C0G 50V 6,800 ± 5% 1.25 ± 0.20 C2012C0G1H822J/0.60 C0G 50V 8,200 ± 5% 0.60 ± 0.10 C2012C0G1H822J/1.25 C0G 50V 8,200 ± 5% 1.25 ± 0.20 C2012C0G1H103J/0.60 C0G 50V 10,000 ± 5% 0.60 ± 0.10 C2012C0G1H103J/1.25 C0G 50V 10,000 ± 5% 1.25 ± 0.20 C2012C0G1H153J C0G 50V 15,000 ± 5% 0.85 ± 0.10 C2012C0G1H223J C0G 50V 22,000 ± 5% 1.25 ± 0.20 C2012C0G1H333J C0G 50V 33,000 ± 5% 1.25 ± 0.20 C2012C0G1E392J C0G 25V 3,900 ± 5% 0.60 ± 0.10 C2012C0G1E472J C0G 25V 4,700 ± 5% 0.60 ± 0.10 C2012C0G1E562J C0G 25V 5,600 ± 5% 0.60 ± 0.10 C2012C0G1E682J C0G 25V 6,800 ± 5% 0.60 ± 0.10 C2012C0G1E822J C0G 25V 8,200 ± 5% 0.60 ± 0.10 TDK MLCC US Catalog Page 43 Version B11 Capacitance Range Table C2012 [EIA CC0805] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C2012C0G1E103J C0G 25V 10,000 ± 5% 0.60 ± 0.10 C2012C0G1E153J C0G 25V 15,000 ± 5% 0.85 ± 0.10 C2012C0G1E223J C0G 25V 22,000 ± 5% 1.25 ± 0.20 C2012C0G1E333J C0G 25V 33,000 ± 5% 1.25 ± 0.20 Capacitance Tolerance Thickness (mm) Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) C2012X7R1H102K X7R 50V 1,000 ± 10% 0.60 ± 0.10 C2012X7R1H102M X7R 50V 1,000 ± 20% 0.60 ± 0.10 C2012X7R1H222K X7R 50V 2,200 ± 10% 0.60 ± 0.10 C2012X7R1H222M X7R 50V 2,200 ± 20% 0.60 ± 0.10 C2012X7R1H472K X7R 50V 4,700 ± 10% 0.60 ± 0.10 C2012X7R1H472M X7R 50V 4,700 ± 20% 0.60 ± 0.10 C2012X7R1H103K X7R 50V 10,000 ± 10% 0.60 ± 0.10 C2012X7R1H103M X7R 50V 10,000 ± 20% 0.60 ± 0.10 C2012X7R1H223K/0.60 X7R 50V 22,000 ± 10% 0.60 ± 0.10 C2012X7R1H223M/0.60 X7R 50V 22,000 ± 20% 0.60 ± 0.10 C2012X7R1H473K/1.25 X7R 50V 47,000 ± 10% 1.25 ± 0.20 C2012X7R1H473M/1.25 X7R 50V 47,000 ± 20% 1.25 ± 0.20 C2012X7R1H104K/0.85 X7R 50V 100,000 ± 10% 0.85 ± 0.10 C2012X7R1H104M/0.85 X7R 50V 100,000 ± 20% 0.85 ± 0.10 C2012X7R1H104K/1.25 X7R 50V 100,000 ± 10% 1.25 ± 0.20 C2012X7R1H104M/1.25 X7R 50V 100,000 ± 20% 1.25 ± 0.20 C2012X7R1H154K X7R 50V 150,000 ± 10% 1.25 ± 0.20 C2012X7R1H154M X7R 50V 150,000 ± 20% 1.25 ± 0.20 C2012X7R1H224K X7R 50V 220,000 ± 10% 1.25 ± 0.20 C2012X7R1H224M X7R 50V 220,000 ± 20% 1.25 ± 0.20 C2012X7R1H334K X7R 50V 330,000 ± 10% 1.25 ± 0.20 C2012X7R1H334M X7R 50V 330,000 ± 20% 1.25 ± 0.20 C2012X7R1H474K X7R 50V 470,000 ± 10% 1.25 ± 0.20 C2012X7R1H474M X7R 50V 470,000 ± 20% 1.25 ± 0.20 C2012X7R1H684K X7R 50V 680,000 ± 10% 1.25 ± 0.20 C2012X7R1H684M X7R 50V 680,000 ± 20% 1.25 ± 0.20 C2012X7R1H105K X7R 50V 1,000,000 ± 10% 1.25 ± 0.20 C2012X7R1H105M X7R 50V 1,000,000 ± 20% 1.25 ± 0.20 C2012X7R1H155K X7R 50V 1,500,000 ± 10% 1.25 ± 0.20 C2012X7R1H155M X7R 50V 1,500,000 ± 20% 1.25 ± 0.20 C2012X7R1H225K X7R 50V 2,200,000 ± 10% 1.25 ± 0.20 C2012X7R1H225M X7R 50V 2,200,000 ± 20% 1.25 ± 0.20 C2012X7R1V105K X7R 35V 1,000,000 ± 10% 1.25 ± 0.20 C2012X7R1V105M X7R 35V 1,000,000 ± 20% 1.25 ± 0.20 C2012X7R1V225K X7R 35V 2,200,000 ± 10% 1.25 ± 0.20 C2012X7R1V225M X7R 35V 2,200,000 ± 20% 1.25 ± 0.20 TDK MLCC US Catalog Page 44 Version B11 Capacitance Range Table C2012 [EIA CC0805] Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C2012X7R1V335K X7R 35V 3,300,000 ± 10% 1.25 ± 0.20 C2012X7R1V335M X7R 35V 3,300,000 ± 20% 1.25 ± 0.20 C2012X7R1V475K X7R 35V 4,700,000 ± 10% 1.25 ± 0.20 C2012X7R1V475M X7R 35V 4,700,000 ± 20% 1.25 ± 0.20 C2012X7R1E104K/0.85 X7R 25V 100,000 ± 10% 0.85 ± 0.10 C2012X7R1E104M/0.85 X7R 25V 100,000 ± 20% 0.85 ± 0.10 C2012X7R1E104K/1.25 X7R 25V 100,000 ± 10% 1.25 ± 0.20 C2012X7R1E104M/1.25 X7R 25V 100,000 ± 20% 1.25 ± 0.20 C2012X7R1E224K X7R 25V 220,000 ± 10% 1.25 ± 0.20 C2012X7R1E224M X7R 25V 220,000 ± 20% 1.25 ± 0.20 C2012X7R1E334K X7R 25V 330,000 ± 10% 1.25 ± 0.20 C2012X7R1E334M X7R 25V 330,000 ± 20% 1.25 ± 0.20 C2012X7R1E474K X7R 25V 470,000 ± 10% 1.25 ± 0.20 C2012X7R1E474M X7R 25V 470,000 ± 20% 1.25 ± 0.20 C2012X7R1E684K X7R 25V 680,000 ± 10% 1.25 ± 0.20 C2012X7R1E684M X7R 25V 680,000 ± 20% 1.25 ± 0.20 C2012X7R1E105K X7R 25V 1,000,000 ± 10% 1.25 ± 0.20 C2012X7R1E105M X7R 25V 1,000,000 ± 20% 1.25 ± 0.20 C2012X7R1E155K X7R 25V 1,500,000 ± 10% 1.25 ± 0.20 C2012X7R1E155M X7R 25V 1,500,000 ± 20% 1.25 ± 0.20 C2012X7R1E225K X7R 25V 2,200,000 ± 10% 1.25 ± 0.20 C2012X7R1E225M X7R 25V 2,200,000 ± 20% 1.25 ± 0.20 C2012X7R1E335K X7R 25V 3,300,000 ± 10% 1.25 ± 0.20 C2012X7R1E335M X7R 25V 3,300,000 ± 20% 1.25 ± 0.20 C2012X7R1E475K X7R 25V 4,700,000 ± 10% 1.25 ± 0.20 C2012X7R1E475M X7R 25V 4,700,000 ± 20% 1.25 ± 0.20 C2012X7R1C224K X7R 16V 220,000 ± 10% 1.25 ± 0.20 C2012X7R1C224M X7R 16V 220,000 ± 20% 1.25 ± 0.20 C2012X7R1C334K/1.25 X7R 16V 330,000 ± 10% 1.25 ± 0.20 C2012X7R1C334M/1.25 X7R 16V 330,000 ± 20% 1.25 ± 0.20 C2012X7R1C474K X7R 16V 470,000 ± 10% 1.25 ± 0.20 C2012X7R1C474M X7R 16V 470,000 ± 20% 1.25 ± 0.20 C2012X7R1C684K X7R 16V 680,000 ± 10% 1.25 ± 0.20 C2012X7R1C684M X7R 16V 680,000 ± 20% 1.25 ± 0.20 C2012X7R1C105K/0.85 X7R 16V 1,000,000 ± 10% 0.85 ± 0.10 C2012X7R1C105M/0.85 X7R 16V 1,000,000 ± 20% 0.85 ± 0.10 C2012X7R1C105K/1.25 X7R 16V 1,000,000 ± 10% 1.25 ± 0.20 C2012X7R1C105M/1.25 X7R 16V 1,000,000 ± 20% 1.25 ± 0.20 C2012X7R1C155K X7R 16V 1,500,000 ± 10% 1.25 ± 0.20 C2012X7R1C155M X7R 16V 1,500,000 ± 20% 1.25 ± 0.20 C2012X7R1C225K X7R 16V 2,200,000 ± 10% 1.25 ± 0.20 C2012X7R1C225M X7R 16V 2,200,000 ± 20% 1.25 ± 0.20 C2012X7R1C335K X7R 16V 3,300,000 ± 10% 1.25 ± 0.20 C2012X7R1C335M X7R 16V 3,300,000 ± 20% 1.25 ± 0.20 TDK MLCC US Catalog Page 45 Version B11 Capacitance Range Table C2012 [EIA CC0805] Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%), X6S(-55 to 105ºC, ±22%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C2012X7R1C475K X7R 16V 4,700,000 ± 10% 1.25 ± 0.20 C2012X7R1C475M X7R 16V 4,700,000 ± 20% 1.25 ± 0.20 C2012X7R1A105K X7R 10V 1,000,000 ± 10% 1.25 ± 0.20 C2012X7R1A105M X7R 10V 1,000,000 ± 20% 1.25 ± 0.20 C2012X7R1A155K X7R 10V 1,500,000 ± 10% 1.25 ± 0.20 C2012X7R1A155M X7R 10V 1,500,000 ± 20% 1.25 ± 0.20 C2012X7R1A225K X7R 10V 2,200,000 ± 10% 1.25 ± 0.20 C2012X7R1A225M X7R 10V 2,200,000 ± 20% 1.25 ± 0.20 C2012X7R1A335K X7R 10V 3,300,000 ± 10% 1.25 ± 0.20 C2012X7R1A335M X7R 10V 3,300,000 ± 20% 1.25 ± 0.20 C2012X7R1A475K X7R 10V 4,700,000 ± 10% 1.25 ± 0.20 C2012X7R1A475M X7R 10V 4,700,000 ± 20% 1.25 ± 0.20 C2012X7R1A106K X7R 10V 10,000,000 ± 10% 1.25 ± 0.20 C2012X7R1A106M X7R 10V 10,000,000 ± 20% 1.25 ± 0.20 C2012X7R0J106K X7R 6.3V 10,000,000 ± 10% 1.25 ± 0.20 C2012X7R0J106M X7R 6.3V 10,000,000 ± 20% 1.25 ± 0.20 C2012X6S1H105K X6S 50V 1,000,000 ± 10% 1.25 ± 0.20 C2012X6S1H105M X6S 50V 1,000,000 ± 20% 1.25 ± 0.20 C2012X6S1H225K X6S 50V 2,200,000 ± 10% 1.25 ± 0.20 C2012X6S1H225M X6S 50V 2,200,000 ± 20% 1.25 ± 0.20 C2012X6S1H475K X6S 50V 4,700,000 ± 10% 1.25 ± 0.20 C2012X6S1H475M X6S 50V 4,700,000 ± 20% 1.25 ± 0.20 C2012X6S1V475K X6S 35V 4,700,000 ± 10% 1.25 ± 0.20 C2012X6S1V475M X6S 35V 4,700,000 ± 20% 1.25 ± 0.20 C2012X6S1E225K X6S 25V 2,200,000 ± 10% 1.25 ± 0.20 C2012X6S1E225M X6S 25V 2,200,000 ± 20% 1.25 ± 0.20 C2012X6S1E475K X6S 25V 4,700,000 ± 10% 1.25 ± 0.20 C2012X6S1E475M X6S 25V 4,700,000 ± 20% 1.25 ± 0.20 C2012X6S1C225K X6S 16V 2,200,000 ± 10% 0.90 +0.05,-0.10 C2012X6S1C225M X6S 16V 2,200,000 ± 20% 0.90 +0.05,-0.10 C2012X6S1C475K X6S 16V 4,700,000 ± 10% 1.25 ± 0.20 C2012X6S1C475M X6S 16V 4,700,000 ± 20% 1.25 ± 0.20 C2012X6S1C106K X6S 16V 10,000,000 ± 10% 1.25 ± 0.20 C2012X6S1C106M X6S 16V 10,000,000 ± 20% 1.25 ± 0.20 C2012X6S1A106K/0.85 X6S 10V 10,000,000 ± 10% 0.85 ± 0.10 C2012X6S1A106M/0.85 X6S 10V 10,000,000 ± 20% 0.85 ± 0.10 C2012X6S1A226K X6S 10V 22,000,000 ± 10% 1.25 ± 0.20 C2012X6S1A226M X6S 10V 22,000,000 ± 20% 1.25 ± 0.20 C2012X6S0J106K X6S 6.3V 10,000,000 ± 10% 0.85 ± 0.10 C2012X6S0J106M X6S 6.3V 10,000,000 ± 20% 0.85 ± 0.10 C2012X6S0J226K X6S 6.3V 22,000,000 ± 10% 1.25 ± 0.20 C2012X6S0J226M X6S 6.3V 22,000,000 ± 20% 1.25 ± 0.20 C2012X6S0G226M X6S 4V 22,000,000 ± 20% 0.85 ± 0.10 C2012X6S0G476M X6S 4V 47,000,000 ± 20% 1.25 ± 0.20 TDK MLCC US Catalog Page 46 Version B11 Capacitance Range Table C2012 [EIA CC0805] Class 2 (Temperature Stable) Temperature Characteristics: X5R (-55 to +85ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C2012X5R1H105K X5R 50V 1,000,000 ± 10% 1.25 ± 0.20 C2012X5R1H105M X5R 50V 1,000,000 ± 20% 1.25 ± 0.20 C2012X5R1H155K X5R 50V 1,500,000 ± 10% 1.25 ± 0.20 C2012X5R1H155M X5R 50V 1,500,000 ± 20% 1.25 ± 0.20 C2012X5R1H225K X5R 50V 2,200,000 ± 10% 1.25 ± 0.20 C2012X5R1H225M X5R 50V 2,200,000 ± 20% 1.25 ± 0.20 C2012X5R1H335K X5R 50V 3,300,000 ± 10% 1.25 ± 0.20 C2012X5R1H335M X5R 50V 3,300,000 ± 20% 1.25 ± 0.20 C2012X5R1H475K X5R 50V 4,700,000 ± 10% 1.25 ± 0.20 C2012X5R1H475M X5R 50V 4,700,000 ± 20% 1.25 ± 0.20 C2012X5R1E105K/0.85 X5R 25V 1,000,000 ± 10% 0.85 ± 0.10 C2012X5R1E105M/0.85 X5R 25V 1,000,000 ± 20% 0.85 ± 0.10 C2012X5R1E105K/1.25 X5R 25V 1,000,000 ± 10% 1.25 ± 0.20 C2012X5R1E105M/1.25 X5R 25V 1,000,000 ± 20% 1.25 ± 0.20 C2012X5R1E155K X5R 25V 1,500,000 ± 10% 1.25 ± 0.20 C2012X5R1E155M X5R 25V 1,500,000 ± 20% 1.25 ± 0.20 C2012X5R1E225K X5R 25V 2,200,000 ± 10% 1.25 ± 0.20 C2012X5R1E225M X5R 25V 2,200,000 ± 20% 1.25 ± 0.20 C2012X5R1E475K X5R 25V 4,700,000 ± 10% 1.25 ± 0.20 C2012X5R1E475M X5R 25V 4,700,000 ± 20% 1.25 ± 0.20 C2012X5R1E685K X5R 25V 6,800,000 ± 10% 1.25 ± 0.20 C2012X5R1E685M X5R 25V 6,800,000 ± 20% 1.25 ± 0.20 C2012X5R1E106K X5R 25V 10,000,000 ± 10% 1.25 ± 0.20 C2012X5R1E106M X5R 25V 10,000,000 ± 20% 1.25 ± 0.20 C2012X5R1C105K/0.85 X5R 16V 1,000,000 ± 10% 0.85 ± 0.10 C2012X5R1C105M/0.85 X5R 16V 1,000,000 ± 20% 0.85 ± 0.10 C2012X5R1C105K/1.25 X5R 16V 1,000,000 ± 10% 1.25 ± 0.20 C2012X5R1C105M/1.25 X5R 16V 1,000,000 ± 20% 1.25 ± 0.20 C2012X5R1C225K/0.85 X5R 16V 2,200,000 ± 10% 0.85 ± 0.10 C2012X5R1C225M/0.85 X5R 16V 2,200,000 ± 20% 0.85 ± 0.10 C2012X5R1C225K/1.25 X5R 16V 2,200,000 ± 10% 1.25 ± 0.20 C2012X5R1C225M/1.25 X5R 16V 2,200,000 ± 20% 1.25 ± 0.20 C2012X5R1C475K/1.25 X5R 16V 4,700,000 ± 10% 1.25 ± 0.20 C2012X5R1C475M/1.25 X5R 16V 4,700,000 ± 20% 1.25 ± 0.20 C2012X5R1C685K X5R 16V 6,800,000 ± 10% 1.25 ± 0.20 C2012X5R1C685M X5R 16V 6,800,000 ± 20% 1.25 ± 0.20 C2012X5R1C106K/0.85 X5R 16V 10,000,000 ± 10% 0.85 ± 0.10 C2012X5R1C106M/0.85 X5R 16V 10,000,000 ± 20% 0.85 ± 0.10 C2012X5R1C106K/1.25 X5R 16V 10,000,000 ± 10% 1.25 ± 0.20 C2012X5R1C106M/1.25 X5R 16V 10,000,000 ± 20% 1.25 ± 0.20 C2012X5R1C226K X5R 16V 22,000,000 ± 10% 1.25 ± 0.20 C2012X5R1C226M X5R 16V 22,000,000 ± 20% 1.25 ± 0.20 C2012X5R1A105K/0.85 X5R 10V 1,000,000 ± 10% 0.85 ± 0.10 C2012X5R1A105M/0.85 X5R 10V 1,000,000 ± 20% 0.85 ± 0.10 TDK MLCC US Catalog Page 47 Version B11 Capacitance Range Table C2012 [EIA CC0805] Class 2 (Temperature Stable) Temperature Characteristics: X5R (-55 to +85ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C2012X5R1A105K/1.25 X5R 10V 1,000,000 ± 10% 1.25 ± 0.20 C2012X5R1A105M/1.25 X5R 10V 1,000,000 ± 20% 1.25 ± 0.20 C2012X5R1A225K/0.85 X5R 10V 2,200,000 ± 10% 0.85 ± 0.10 C2012X5R1A225M/0.85 X5R 10V 2,200,000 ± 20% 0.85 ± 0.10 C2012X5R1A225K/1.25 X5R 10V 2,200,000 ± 10% 1.25 ± 0.20 C2012X5R1A225M/1.25 X5R 10V 2,200,000 ± 20% 1.25 ± 0.20 C2012X5R1A335K X5R 10V 3,300,000 ± 10% 1.25 ± 0.20 C2012X5R1A335M X5R 10V 3,300,000 ± 20% 1.25 ± 0.20 C2012X5R1A475K/0.85 X5R 10V 4,700,000 ± 10% 0.85 ± 0.10 C2012X5R1A475M/0.85 X5R 10V 4,700,000 ± 20% 0.85 ± 0.10 C2012X5R1A475K/1.25 X5R 10V 4,700,000 ± 10% 1.25 ± 0.20 C2012X5R1A475M/1.25 X5R 10V 4,700,000 ± 20% 1.25 ± 0.20 C2012X5R1A106K/0.85 X5R 10V 10,000,000 ± 10% 0.85 ± 0.10 C2012X5R1A106M/0.85 X5R 10V 10,000,000 ± 20% 0.85 ± 0.10 C2012X5R1A106K/1.25 X5R 10V 10,000,000 ± 10% 1.25 ± 0.20 C2012X5R1A106M/1.25 X5R 10V 10,000,000 ± 20% 1.25 ± 0.20 C2012X5R1A156M X5R 10V 15,000,000 ± 20% 1.25 ± 0.20 C2012X5R1A226M/0.85 X5R 10V 22,000,000 ± 20% 0.85 ± 0.10 C2012X5R1A226K/1.25 X5R 10V 22,000,000 ± 10% 1.25 ± 0.20 C2012X5R1A226M/1.25 X5R 10V 22,000,000 ± 20% 1.25 ± 0.20 C2012X5R0J225K/0.85 X5R 6.3V 2,200,000 ± 10% 0.85 ± 0.10 C2012X5R0J225M/0.85 X5R 6.3V 2,200,000 ± 20% 0.85 ± 0.10 C2012X5R0J225K/1.25 X5R 6.3V 2,200,000 ± 10% 1.25 ± 0.20 C2012X5R0J225M/1.25 X5R 6.3V 2,200,000 ± 20% 1.25 ± 0.20 C2012X5R0J335K/1.25 X5R 6.3V 3,300,000 ± 10% 1.25 ± 0.20 C2012X5R0J335M/1.25 X5R 6.3V 3,300,000 ± 20% 1.25 ± 0.20 C2012X5R0J475K/0.85 X5R 6.3V 4,700,000 ± 10% 0.85 ± 0.10 C2012X5R0J475M/0.85 X5R 6.3V 4,700,000 ± 20% 0.85 ± 0.10 C2012X5R0J475K/1.25 X5R 6.3V 4,700,000 ± 10% 1.25 ± 0.20 C2012X5R0J475M/1.25 X5R 6.3V 4,700,000 ± 20% 1.25 ± 0.20 C2012X5R0J685K/1.25 X5R 6.3V 6,800,000 ± 10% 1.25 ± 0.20 C2012X5R0J685M/1.25 X5R 6.3V 6,800,000 ± 20% 1.25 ± 0.20 C2012X5R0J106K/0.85 X5R 6.3V 10,000,000 ± 10% 0.85 ± 0.10 C2012X5R0J106M/0.85 X5R 6.3V 10,000,000 ± 20% 0.85 ± 0.10 C2012X5R0J106K/1.25 X5R 6.3V 10,000,000 ± 10% 1.25 ± 0.20 C2012X5R0J106M/1.25 X5R 6.3V 10,000,000 ± 20% 1.25 ± 0.20 C2012X5R0J156M/0.85 X5R 6.3V 15,000,000 ± 20% 0.85 ± 0.10 C2012X5R0J156M/1.25 X5R 6.3V 15,000,000 ± 20% 1.25 ± 0.20 C2012X5R0J226M/0.85 X5R 6.3V 22,000,000 ± 20% 0.85 ± 0.10 C2012X5R0J226K/1.25 X5R 6.3V 22,000,000 ± 10% 1.25 ± 0.20 C2012X5R0J226M/1.25 X5R 6.3V 22,000,000 ± 20% 1.25 ± 0.20 C2012X5R0J336M X5R 6.3V 33,000,000 ± 20% 1.25 ± 0.20 TDK MLCC US Catalog Page 48 Version B11 Capacitance Range Table C2012 [EIA CC0805] Class 2 (Temperature Stable) Temperature Characteristics: X5R (-55 to +85ºC, ±15%), Y5V(-30 to +85ºC, +22/-82%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C2012X5R0J476M X5R 6.3V 47,000,000 ± 20% 1.25 ± 0.20 C2012X5R0G476M X5R 4V 47,000,000 ± 20% 1.25 ± 0.20 C2012Y5V1H104Z/0.60 Y5V 50V 100,000 +80/-20% 0.60 ± 0.10 C2012Y5V1H104Z/0.85 Y5V 50V 100,000 +80/-20% 0.85 ± 0.10 C2012Y5V1H474Z/0.85 Y5V 50V 470,000 +80/-20% 0.85 ± 0.10 C2012Y5V1H105Z/0.85 Y5V 50V 1,000,000 +80/-20% 0.85 ± 0.10 C2012Y5V1H105Z/1.25 Y5V 50V 1,000,000 +80/-20% 1.25 ± 0.20 C2012Y5V1H225Z Y5V 50V 2,200,000 +80/-20% 1.25 ± 0.20 C2012Y5V1E105Z/0.85 Y5V 25V 1,000,000 +80/-20% 0.85 ± 0.10 C2012Y5V1E105Z/1.25 Y5V 25V 1,000,000 +80/-20% 1.25 ± 0.20 C2012Y5V1E225Z Y5V 25V 2,200,000 +80/-20% 1.25 ± 0.20 C2012Y5V1E475Z Y5V 25V 4,700,000 +80/-20% 1.25 ± 0.20 C2012Y5V1C105Z/0.85 Y5V 16V 1,000,000 +80/-20% 0.85 ± 0.10 C2012Y5V1C105Z/1.25 Y5V 16V 1,000,000 +80/-20% 1.25 ± 0.20 C2012Y5V1C225Z/0.85 Y5V 16V 2,200,000 +80/-20% 0.85 ± 0.10 C2012Y5V1C225Z/1.25 Y5V 16V 2,200,000 +80/-20% 1.25 ± 0.20 C2012Y5V1C475Z/0.85 Y5V 16V 4,700,000 +80/-20% 0.85 ± 0.10 C2012Y5V1C475Z/1.25 Y5V 16V 4,700,000 +80/-20% 1.25 ± 0.20 C2012Y5V1C106Z Y5V 16V 10,000,000 +80/-20% 1.25 ± 0.20 C2012Y5V1A475Z/0.85 Y5V 10V 4,700,000 +80/-20% 0.85 ± 0.10 C2012Y5V1A475Z/1.25 Y5V 10V 4,700,000 +80/-20% 1.25 ± 0.20 C2012Y5V1A106Z Y5V 10V 10,000,000 +80/-20% 1.25 ± 0.20 C2012Y5V0J106Z Y5V 6.3V 10,000,000 +80/-20% 1.25 ± 0.20 C2012Y5V0J226Z Y5V 6.3V 22,000,000 +80/-20% 1.25 ± 0.20 TDK MLCC US Catalog Page 49 Version B11 Capacitance Range Chart C3216 [EIA CC1206] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC) Rated Voltage: 50V (1H), 25V (1E), 10V (1A) Capacitance (pF) C0G Cap Code 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 220,000 392 472 562 682 822 103 153 223 333 473 683 104 224 Tolerance 1H (50V) 1E (25V) SL 1A (10V) J: ± 5% Capacitance Range Chart Temperature Characteristics: X7R (±15%), X6S (± 22%), X5R (±15%), Y5V (+22/-82) Rated Voltage: 50V (1H), 35V (1V). 25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V(0G) Capacitance (pF) 1,000,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 33,000,000 47,000,000 100,000,000 Capacitance (pF) X5R Cap Code 105 225 335 475 685 106 156 226 336 476 107 Tolerance 104 224 334 474 684 105 155 225 335 475 685 106 226 476 1E (25V) 1H (50V) 1V (35V) 1C (16V) X6S 1A (10V) 0J (6.3V) 0G (4V) 1A (10V) 1C (16V) 1A (10V) 1H (50V) 1E (25V) 0J (6.3V) 0G (4V) K: ± 10% M: ± 20% X7R Cap Code 100,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 22,000,000 47,000,000 1H (50V) Tolerance 1E (25V) Y5V 1C (16V) 1A (10V) 0J (6.3V) K: ± 10% M: ± 20% Z: +80/-20% Standard Thickness 0.60 mm 0.85 mm 1.15 mm 1.30 mm 1.60 mm • Standard capacitance and thickness is shown. Please refer to Capacitance Range Table for additional capacitance values and thicknesses. TDK MLCC US Catalog Page 50 Version B11 Capacitance Range Table C3216 [EIA CC1206] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC), SL (-25 to +85ºC, +350/-1000 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C3216C0G1H392J C0G 50V 3,900 ± 5% 0.60 ± 0.10 C3216C0G1H472J/0.60 C0G 50V 4,700 ± 5% 0.60 ± 0.10 C3216C0G1H472J/0.85 C0G 50V 4,700 ± 5% 0.85 ± 0.10 C3216C0G1H562J/0.60 C0G 50V 5,600 ± 5% 0.60 ± 0.10 C3216C0G1H562J/0.85 C0G 50V 5,600 ± 5% 0.85 ± 0.10 C3216C0G1H682J/0.60 C0G 50V 6,800 ± 5% 0.60 ± 0.10 C3216C0G1H822J/0.60 C0G 50V 8,200 ± 5% 0.60 ± 0.10 C3216C0G1H822J/0.85 C0G 50V 8,200 ± 5% 0.85 ± 0.10 C3216C0G1H822J/1.15 C0G 50V 8,200 ± 5% 1.15 ± 0.10 C3216C0G1H103J/0.60 C0G 50V 10,000 ± 5% 0.60 ± 0.10 C3216C0G1H103J/1.15 C0G 50V 10,000 ± 5% 1.15 ± 0.10 C3216C0G1H153J/0.60 C0G 50V 15,000 ± 5% 0.60 ± 0.10 C3216C0G1H153J/1.15 C0G 50V 15,000 ± 5% 1.15 ± 0.10 C3216C0G1H223J/0.60 C0G 50V 22,000 ± 5% 0.60 ± 0.10 C3216C0G1H223J/1.15 C0G 50V 22,000 ± 5% 1.15 ± 0.10 C3216C0G1H333J/0.85 C0G 50V 33,000 ± 5% 0.85 ± 0.10 C3216C0G1H333J/1.60 C0G 50V 33,000 ± 5% 1.60 ± 0.30 C3216C0G1H473J C0G 50V 47,000 ± 5% 1.15 ± 0.10 C3216C0G1H683J C0G 50V 68,000 ± 5% 1.60 ± 0.30 C3216C0G1H104J C0G 50V 100,000 ± 5% 1.60 ± 0.30 C3216C0G1E822J C0G 25V 8,200 ± 5% 0.60 ± 0.20 C3216C0G1E103J C0G 25V 10,000 ± 5% 0.60 ± 0.20 C3216C0G1E153J C0G 25V 15,000 ± 5% 0.60 ± 0.20 C3216C0G1E223J C0G 25V 22,000 ± 5% 0.60 ± 0.10 C3216C0G1E333J C0G 25V 33,000 ± 5% 0.85 ± 0.10 C3216C0G1E473J C0G 25V 47,000 ± 5% 1.15 ± 0.10 C3216C0G1E683J C0G 25V 68,000 ± 5% 1.60 ± 0.30 C3216C0G1E104J C0G 25V 100,000 ± 5% 1.60 ± 0.30 SL 10V 220,000 ± 5% 1.60 ± 0.30 Capacitance Tolerance Thickness (mm) C3216SL1A224J Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) C3216X7R1H104K X7R 50V 100,000 ± 10% 0.85 ± 0.10 C3216X7R1H104M X7R 50V 100,000 ± 20% 0.85 ± 0.10 C3216X7R1H224K X7R 50V 220,000 ± 10% 1.15 ± 0.10 C3216X7R1H224M X7R 50V 220,000 ± 20% 1.15 ± 0.10 C3216X7R1H334K X7R 50V 330,000 ± 10% 1.60 ± 0.30 C3216X7R1H334M X7R 50V 330,000 ± 20% 1.60 ± 0.30 C3216X7R1H474K X7R 50V 470,000 ± 10% 1.60 ± 0.30 C3216X7R1H474M X7R 50V 470,000 ± 20% 1.60 ± 0.30 C3216X7R1H684K X7R 50V 680,000 ± 10% 1.60 ± 0.30 C3216X7R1H684M X7R 50V 680,000 ± 20% 1.60 ± 0.30 C3216X7R1H105K X7R 50V 1,000,000 ± 10% 1.60 ± 0.30 TDK MLCC US Catalog Page 51 Version B11 Capacitance Range Table C3216 [EIA CC1206] Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C3216X7R1H105M X7R 50V 1,000,000 ± 20% 1.60 ± 0.30 C3216X7R1H155K X7R 50V 1,500,000 ± 10% 1.60 ± 0.30 C3216X7R1H155M X7R 50V 1,500,000 ± 20% 1.60 ± 0.30 C3216X7R1H225K X7R 50V 2,200,000 ± 10% 1.60 ± 0.30 C3216X7R1H225M X7R 50V 2,200,000 ± 20% 1.60 ± 0.30 C3216X7R1H335K X7R 50V 3,300,000 ± 10% 1.60 ± 0.30 C3216X7R1H335M X7R 50V 3,300,000 ± 20% 1.60 ± 0.30 C3216X7R1V335K X7R 35V 3,300,000 ± 10% 1.60 ± 0.30 C3216X7R1V475K X7R 35V 4,700,000 ± 10% 1.60 ± 0.30 C3216X7R1E224K X7R 25V 220,000 ± 10% 1.15 ± 0.10 C3216X7R1E224M X7R 25V 220,000 ± 20% 1.15 ± 0.10 C3216X7R1E334K X7R 25V 330,000 ± 10% 1.15 ± 0.10 C3216X7R1E334M X7R 25V 330,000 ± 20% 1.15 ± 0.10 C3216X7R1E474K/0.85 X7R 25V 470,000 ± 10% 0.85 ± 0.10 C3216X7R1E474M/0.85 X7R 25V 470,000 ± 20% 0.85 ± 0.10 C3216X7R1E684K/0.85 X7R 25V 680,000 ± 10% 0.85 ± 0.10 C3216X7R1E684M/0.85 X7R 25V 680,000 ± 20% 0.85 ± 0.10 C3216X7R1E105K/0.85 X7R 25V 1,000,000 ± 10% 0.85 ± 0.10 C3216X7R1E105M/0.85 X7R 25V 1,000,000 ± 20% 0.85 ± 0.10 C3216X7R1E105K/1.60 X7R 25V 1,000,000 ± 10% 1.60 ± 0.30 C3216X7R1E105M/1.60 X7R 25V 1,000,000 ± 20% 1.60 ± 0.30 C3216X7R1E155K X7R 25V 1,500,000 ± 10% 1.60 ± 0.30 C3216X7R1E155M X7R 25V 1,500,000 ± 20% 1.60 ± 0.30 C3216X7R1E225K X7R 25V 2,200,000 ± 10% 1.60 ± 0.30 C3216X7R1E225M X7R 25V 2,200,000 ± 20% 1.60 ± 0.30 C3216X7R1E335K X7R 25V 3,300,000 ± 10% 1.60 ± 0.30 C3216X7R1E335M X7R 25V 3,300,000 ± 20% 1.60 ± 0.30 C3216X7R1E475K X7R 25V 4,700,000 ± 10% 1.60 ± 0.30 C3216X7R1E475M X7R 25V 4,700,000 ± 20% 1.60 ± 0.30 C3216X7R1E685K X7R 25V 6,800,000 ± 10% 1.60 ± 0.30 C3216X7R1E685M X7R 25V 6,800,000 ± 20% 1.60 ± 0.30 C3216X7R1E106K X7R 25V 10,000,000 ± 10% 1.60 ± 0.30 C3216X7R1E106M X7R 25V 10,000,000 ± 20% 1.60 ± 0.30 C3216X7R1C474K X7R 16V 470,000 ± 10% 1.15 ± 0.10 C3216X7R1C474M X7R 16V 470,000 ± 20% 1.15 ± 0.10 C3216X7R1C105K/0.85 X7R 16V 1,000,000 ± 10% 0.85 ± 0.10 C3216X7R1C105M/0.85 X7R 16V 1,000,000 ± 20% 0.85 ± 0.10 C3216X7R1C105K/1.15 X7R 16V 1,000,000 ± 10% 1.15 ± 0.10 C3216X7R1C105K/1.30 X7R 16V 1,000,000 ± 10% 1.30 ± 0.15 C3216X7R1C225K/1.60 X7R 16V 2,200,000 ± 10% 1.60 ± 0.30 C3216X7R1C225M/1.60 X7R 16V 2,200,000 ± 20% 1.60 ± 0.30 C3216X7R1C335K/1.60 X7R 16V 3,300,000 ± 10% 1.60 ± 0.30 C3216X7R1C335M/1.60 X7R 16V 3,300,000 ± 20% 1.60 ± 0.30 C3216X7R1C475K/1.60 X7R 16V 4,700,000 ± 10% 1.60 ± 0.30 TDK MLCC US Catalog Page 52 Version B11 Capacitance Range Table C3216 [EIA CC1206] Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%), X6S(-55 to 105ºC, ±22%), X5R (-55 to +85ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C3216X7R1C475M/1.60 X7R 16V 4,700,000 ± 20% 1.60 ± 0.30 C3216X7R1C685K X7R 16V 6,800,000 ± 10% 1.60 ± 0.30 C3216X7R1C685M X7R 16V 6,800,000 ± 20% 1.60 ± 0.30 C3216X7R1C106K X7R 16V 10,000,000 ± 10% 1.60 ± 0.30 C3216X7R1C106M X7R 16V 10,000,000 ± 20% 1.60 ± 0.30 C3216X7R1A106K X7R 10V 10,000,000 ± 10% 1.60 ± 0.30 C3216X7R1A106M X7R 10V 10,000,000 ± 20% 1.60 ± 0.30 C3216X6S1A476M X6S 10V 47,000,000 ± 20% 1.60 ± 0.30 C3216X6S0J476M X6S 6.3V 47,000,000 ± 20% 1.60 ± 0.30 C3216X6S0G107M X6S 4V 100,000,000 ± 20% 1.60 ± 0.30 C3216X5R1H105K X5R 50V 1,000,000 ± 10% 1.60 ± 0.30 C3216X5R1H105M X5R 50V 1,000,000 ± 20% 1.60 ± 0.30 C3216X5R1H335K X5R 50V 3,300,000 ± 10% 1.60 ± 0.30 C3216X5R1H335M X5R 50V 3,300,000 ± 20% 1.60 ± 0.30 C3216X5R1H475K X5R 50V 4,700,000 ± 10% 1.60 ± 0.30 C3216X5R1H475M X5R 50V 4,700,000 ± 20% 1.60 ± 0.30 C3216X5R1H685K X5R 50V 6,800,000 ± 10% 1.60 ± 0.30 C3216X5R1H685M X5R 50V 6,800,000 ± 20% 1.60 ± 0.30 C3216X5R1H106K X5R 50V 10,000,000 ± 10% 1.60 ± 0.30 C3216X5R1H106M X5R 50V 10,000,000 ± 20% 1.60 ± 0.30 C3216X5R1E225K X5R 25V 2,200,000 ± 10% 1.60 ± 0.30 C3216X5R1E225M X5R 25V 2,200,000 ± 20% 1.60 ± 0.30 C3216X5R1E335K/1.60 X5R 25V 3,300,000 ± 10% 1.60 ± 0.30 C3216X5R1E335M/1.60 X5R 25V 3,300,000 ± 20% 1.60 ± 0.30 C3216X5R1E475K X5R 25V 4,700,000 ± 10% 1.60 ± 0.30 C3216X5R1E475M X5R 25V 4,700,000 ± 20% 1.60 ± 0.30 C3216X5R1E106K X5R 25V 10,000,000 ± 10% 1.60 ± 0.30 C3216X5R1E106M X5R 25V 10,000,000 ± 20% 1.60 ± 0.30 C3216X5R1E226M X5R 25V 22,000,000 ± 20% 1.60 ± 0.30 C3216X5R1C225K/1.60 X5R 16V 2,200,000 ± 10% 1.60 ± 0.30 C3216X5R1C225M/1.60 X5R 16V 2,200,000 ± 20% 1.60 ± 0.30 C3216X5R1C335K/1.60 X5R 16V 3,300,000 ± 10% 1.60 ± 0.30 C3216X5R1C335M/1.60 X5R 16V 3,300,000 ± 20% 1.60 ± 0.30 C3216X5R1C475K/1.15 X5R 16V 4,700,000 ± 10% 1.15 ± 0.10 C3216X5R1C475M/1.15 X5R 16V 4,700,000 ± 20% 1.15 ± 0.10 C3216X5R1C475K/1.60 X5R 16V 4,700,000 ± 10% 1.60 ± 0.30 C3216X5R1C475M/1.60 X5R 16V 4,700,000 ± 20% 1.60 ± 0.30 C3216X5R1C685K X5R 16V 6,800,000 ± 10% 1.60 ± 0.30 C3216X5R1C685M X5R 16V 6,800,000 ± 20% 1.60 ± 0.30 C3216X5R1C106K X5R 16V 10,000,000 ± 10% 1.60 ± 0.30 C3216X5R1C106M X5R 16V 10,000,000 ± 20% 1.60 ± 0.30 C3216X5R1C226M X5R 16V 22,000,000 ± 20% 1.60 ± 0.30 C3216X5R1C336M X5R 16V 33,000,000 ± 20% 1.60 ± 0.30 C3216X5R1C476M X5R 16V 47,000,000 ± 20% 1.60 ± 0.30 TDK MLCC US Catalog Page 53 Version B11 Capacitance Range Table C3216 [EIA CC1206] Class 2 (Temperature Stable) Temperature Characteristics: X5R (-55 to +85ºC, ±15%), Y5V(-30 to +85ºC, +22/-82%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C3216X5R1A225K/0.85 X5R 10V 2,200,000 ± 10% 0.85 ± 0.10 C3216X5R1A225M/0.85 X5R 10V 2,200,000 ± 20% 0.85 ± 0.10 C3216X5R1A335K/0.85 X5R 10V 3,300,000 ± 10% 0.85 ± 0.10 C3216X5R1A335M/0.85 X5R 10V 3,300,000 ± 20% 0.85 ± 0.10 C3216X5R1A335K/1.15 X5R 10V 3,300,000 ± 10% 1.15 ± 0.10 C3216X5R1A335M/1.15 X5R 10V 3,300,000 ± 20% 1.15 ± 0.10 C3216X5R1A475K X5R 10V 4,700,000 ± 10% 1.60 ± 0.30 C3216X5R1A475M X5R 10V 4,700,000 ± 20% 1.60 ± 0.30 C3216X5R1A106K X5R 10V 10,000,000 ± 10% 1.60 ± 0.30 C3216X5R1A106M X5R 10V 10,000,000 ± 20% 1.60 ± 0.30 C3216X5R1A226M X5R 10V 22,000,000 ± 20% 1.60 ± 0.30 C3216X5R1A336M X5R 10V 33,000,000 ± 20% 1.60 ± 0.30 C3216X5R1A476M X5R 10V 47,000,000 ± 20% 1.60 ± 0.30 C3216X5R1A107M X5R 10V 100,000,000 ± 20% 1.60 ± 0.30 C3216X5R0J106K/0.85 X5R 6.3V 10,000,000 ± 10% 0.85 ± 0.10 C3216X5R0J106M/0.85 X5R 6.3V 10,000,000 ± 20% 0.85 ± 0.10 C3216X5R0J106K/1.60 X5R 6.3V 10,000,000 ± 10% 1.60 ± 0.30 C3216X5R0J106M/1.60 X5R 6.3V 10,000,000 ± 20% 1.60 ± 0.30 C3216X5R0J156M X5R 6.3V 15,000,000 ± 20% 1.60 ± 0.30 C3216X5R0J226M/0.85 X5R 6.3V 22,000,000 ± 20% 0.85 ± 0.10 C3216X5R0J226K/1.60 X5R 6.3V 22,000,000 ± 10% 1.60 ± 0.30 C3216X5R0J226M/1.60 X5R 6.3V 22,000,000 ± 20% 1.60 ± 0.30 C3216X5R0J336M X5R 6.3V 33,000,000 ± 20% 1.30 ± 0.15 C3216X5R0J476M X5R 6.3V 47,000,000 ± 20% 1.60 ± 0.30 C3216X5R0J107M X5R 6.3V 100,000,000 ± 20% 1.60 ± 0.30 C3216X5R0G107M X5R 4V 100,000,000 ± 20% 1.60 ± 0.30 C3216Y5V1H225Z/0.85 Y5V 50V 2,200,000 +80/-20% 0.85 ± 0.10 C3216Y5V1H225Z/1.15 Y5V 50V 2,200,000 +80/-20% 1.15 ± 0.10 C3216Y5V1H475Z Y5V 50V 4,700,000 +80/-20% 1.60 ± 0.30 C3216Y5V1E475Z/0.85 Y5V 25V 4,700,000 +80/-20% 0.85 ± 0.10 C3216Y5V1E475Z/1.15 Y5V 25V 4,700,000 +80/-20% 1.15 ± 0.10 C3216Y5V1E106Z Y5V 25V 10,000,000 +80/-20% 1.60 ± 0.30 C3216Y5V1C475Z/0.85 Y5V 16V 4,700,000 +80/-20% 0.85 ± 0.10 C3216Y5V1C475Z/1.15 Y5V 16V 4,700,000 +80/-20% 1.15 ± 0.10 C3216Y5V1C475Z/1.30 Y5V 16V 4,700,000 +80/-20% 1.30 ± 0.15 C3216Y5V1C106Z Y5V 16V 10,000,000 +80/-20% 1.60 ± 0.30 C3216Y5V1C226Z Y5V 16V 22,000,000 +80/-20% 1.60 ± 0.30 C3216Y5V1A106Z/0.85 Y5V 10V 10,000,000 +80/-20% 0.85 ± 0.10 C3216Y5V1A106Z/1.15 Y5V 10V 10,000,000 +80/-20% 1.15 ± 0.10 C3216Y5V1A226Z Y5V 10V 22,000,000 +80/-20% 1.60 ± 0.30 C3216Y5V0J476Z Y5V 6.3V 47,000,000 +80/-20% 1.60 ± 0.30 TDK MLCC US Catalog Page 54 Version B11 Capacitance Range Chart C3225 [EIA CC1210] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC) Rated Voltage: 50V (1H) Capacitance (pF) 22,000 33,000 47,000 68,000 100,000 C0G Cap Code 223 333 473 683 104 Tolerance 1H (50V) J: ± 5% Capacitance Range Chart Temperature Characteristics: X7R (±15%), X7S (±22%), X5R (±15%), X6S (±22%), Y5V (+22/-82%) Rated Voltage: 50V (1H), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V (0G) Capacitance (pF) Cap Code 4,700,000 10,000,000 15,000,000 22,000,000 33,000,000 47,000,000 68,000,000 100,000,000 475 106 156 226 336 476 686 107 Capacitance (pF) Cap Code 470,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 474 105 155 225 335 475 685 106 156 226 Capacitance (pF) Cap Code 4,700,000 10,000,000 22,000,000 47,000,000 100,000,000 475 106 226 476 107 X5R Tolerance 1H (50V) 1E (25V) 1H (50V) 1E (25V) 1H (50V) 1E (25V) X6S 1C (16V) 1A (10V) 0J (6.3V) 1C (16V) 1A (10V) 1H (50V) 1A (10V) 0J (6.3V) 1H (50V) 0J (6.3V) 0G (4V) K: ± 10% M: ± 20% X7R Tolerance X7S K: ± 10% M: ± 20% Y5V Tolerance 1C (16V) Z: +80/-20% Standard Thickness 1.15 mm 1.25 mm 1.30 mm 1.60 mm 2.00 mm 2.50 mm 2.30 mm • Standard capacitance and thickness is shown. Please refer to Capacitance Range Table for additional capacitance values and thicknesses. TDK MLCC US Catalog Page 55 Version B11 Capacitance Range Table C3225 [EIA CC1210] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C3225C0G1H223J C0G 50V 22,000 ± 5% 1.30 ± 0.15 C3225C0G1H333J C0G 50V 33,000 ± 5% 1.60 ± 0.30 C3225C0G1H473J C0G 50V 47,000 ± 5% 2.00 ± 0.20 C3225C0G1H683J C0G 50V 68,000 ± 5% 2.00 ± 0.20 C3225C0G1H104J C0G 50V 100,000 ± 5% 2.50 ± 0.30 Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%), X7S (-55 to +125ºC, ±22%), X6S (-55 to +105ºC, ±22%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C3225X7R1H474K/1.30 X7R 50V 470,000 ± 10% 1.30 ± 0.15 C3225X7R1H474M/1.30 X7R 50V 470,000 ± 20% 1.30 ± 0.15 C3225X7R1H105K/1.60 X7R 50V 1,000,000 ± 10% 1.60 ± 0.30 C3225X7R1H105M/1.60 X7R 50V 1,000,000 ± 20% 1.60 ± 0.30 C3225X7R1H105K/2.00 X7R 50V 1,000,000 ± 10% 2.00 ± 0.20 C3225X7R1H105M/2.00 X7R 50V 1,000,000 ± 20% 2.00 ± 0.20 C3225X7R1H155K X7R 50V 1,500,000 ± 10% 2.00 ± 0.20 C3225X7R1H155M X7R 50V 1,500,000 ± 20% 2.00 ± 0.20 C3225X7R1H225K/2.00 X7R 50V 2,200,000 ± 10% 2.00 ± 0.20 C3225X7R1H225M/2.00 X7R 50V 2,200,000 ± 20% 2.00 ± 0.20 C3225X7R1H225K/2.50 X7R 50V 2,200,000 ± 10% 2.50 ± 0.30 C3225X7R1H225M/2.50 X7R 50V 2,200,000 ± 20% 2.50 ± 0.30 C3225X7R1H335K X7R 50V 3,300,000 ± 10% 2.50 ± 0.30 C3225X7R1H335M X7R 50V 3,300,000 ± 20% 2.50 ± 0.30 C3225X7R1H475K X7R 50V 4,700,000 ± 10% 2.50 ± 0.30 C3225X7R1H475M X7R 50V 4,700,000 ± 20% 2.50 ± 0.30 C3225X6S1H475K X6S 50V 4,700,000 ± 10% 2.50 ± 0.30 C3225X6S1H475M X6S 50V 4,700,000 ± 20% 2.50 ± 0.30 C3225X7S1H685K X7S 50V 6,800,000 ± 10% 2.50 ± 0.30 C3225X7S1H685M X7S 50V 6,800,000 ± 20% 2.50 ± 0.30 C3225X7S1H106K X7S 50V 10,000,000 ± 10% 2.50 ± 0.30 C3225X7S1H106M X7S 50V 10,000,000 ± 20% 2.50 ± 0.30 C3225X7R1E225K/1.60 X7R 25V 2,200,000 ± 10% 1.60 ± 0.30 C3225X7R1E225M/1.60 X7R 25V 2,200,000 ± 20% 1.60 ± 0.30 C3225X7R1E335K X7R 25V 3,300,000 ± 10% 1.60 ± 0.30 C3225X7R1E335M X7R 25V 3,300,000 ± 20% 1.60 ± 0.30 C3225X7R1E475K X7R 25V 4,700,000 ± 10% 2.00 ± 0.20 C3225X7R1E475M X7R 25V 4,700,000 ± 20% 2.00 ± 0.20 C3225X7R1E685K/2.50 X7R 25V 6,800,000 ± 10% 2.50 ± 0.30 C3225X7R1E685M/2.50 X7R 25V 6,800,000 ± 20% 2.50 ± 0.30 C3225X7R1E106K X7R 25V 10,000,000 ± 10% 2.50 ± 0.30 C3225X7R1E106M X7R 25V 10,000,000 ± 20% 2.50 ± 0.30 C3225X7R1C106K X7R 16V 10,000,000 ± 10% 2.00 ± 0.20 C3225X7R1C106M X7R 16V 10,000,000 ± 20% 2.00 ± 0.20 C3225X7R1C156M X7R 16V 15,000,000 ± 20% 2.50 ± 0.30 TDK MLCC US Catalog Page 56 Version B11 Capacitance Range Table C3225 [EIA CC1210] Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%), X6S (-55 to +105ºC, ±22%), X5R (-55 to +85ºC, ±15%), Y5V(-30 to +85ºC, +22/-82%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C3225X7R1C226K X7R 16V 22,000,000 ± 10% 2.50 ± 0.30 C3225X7R1C226M X7R 16V 22,000,000 ± 20% 2.50 ± 0.30 C3225X7R1A226K/2.30 X7R 10V 22,000,000 ± 10% 2.30 ± 0.20 C3225X7R1A226M/2.30 X7R 10V 22,000,000 ± 20% 2.30 ± 0.20 C3225X5R1H475K X5R 50V 4,700,000 ± 10% 2.50 ± 0.30 C3225X5R1H475M X5R 50V 4,700,000 ± 20% 2.50 ± 0.30 C3225X5R1E106K X5R 25V 10,000,000 ± 10% 2.50 ± 0.30 C3225X5R1E106M X5R 25V 10,000,000 ± 20% 2.50 ± 0.30 C3225X5R1C106K X5R 16V 10,000,000 ± 10% 2.00 ± 0.20 C3225X5R1C106M X5R 16V 10,000,000 ± 20% 2.00 ± 0.20 C3225X5R1C156M X5R 16V 15,000,000 ± 20% 2.50 ± 0.30 C3225X5R1C226K X5R 16V 22,000,000 ± 10% 2.50 ± 0.30 C3225X5R1C226M X5R 16V 22,000,000 ± 20% 2.50 ± 0.30 C3225X5R1A106K X5R 10V 10,000,000 ± 10% 2.00 ± 0.20 C3225X5R1A106M X5R 10V 10,000,000 ± 20% 2.00 ± 0.20 C3225X5R1A156M/2.30 X5R 10V 15,000,000 ± 20% 2.30 ± 0.20 C3225X5R1A226M X5R 10V 22,000,000 ± 20% 2.30 ± 0.20 C3225X5R1A336M X5R 10V 33,000,000 ± 20% 2.00 ± 0.20 C3225X5R1A476M X5R 10V 47,000,000 ± 20% 2.50 ± 0.30 C3225X5R0J226M/1.60 X5R 6.3V 22,000,000 ± 20% 1.60 ± 0.30 C3225X5R0J226K/2.00 X5R 6.3V 22,000,000 ± 10% 2.00 ± 0.20 C3225X5R0J226M/2.00 X5R 6.3V 22,000,000 ± 20% 2.00 ± 0.20 C3225X5R0J226K/2.50 X5R 6.3V 22,000,000 ± 10% 2.50 ± 0.30 C3225X5R0J226M/2.50 X5R 6.3V 22,000,000 ± 20% 2.50 ± 0.30 C3225X5R0J336M/2.00 X5R 6.3V 33,000,000 ± 20% 2.00 ± 0.20 C3225X5R0J336M/2.50 X5R 6.3V 33,000,000 ± 20% 2.50 ± 0.30 C3225X5R0J476M X5R 6.3V 47,000,000 ± 20% 2.50 ± 0.30 C3225X5R0J686M X5R 6.3V 68,000,000 ± 20% 2.00 ± 0.20 C3225X5R0J107M X5R 6.3V 100,000,000 ± 20% 2.50 ± 0.30 C3225X6S0J476M X6S 6.3V 47,000,000 ± 20% 2.50 ± 0.30 C3225X6S0J107M X6S 6.3V 100,000,000 ± 20% 2.50 ± 0.30 C3225X6S0G107M X6S 4V 100,000,000 ± 20% 2.50 ± 0.30 C3225Y5V1H475Z/1.15 Y5V 50V 4,700,000 +80/-20% 1.15 ± 0.10 C3225Y5V1H475Z/1.60 Y5V 50V 4,700,000 +80/-20% 1.60 ± 0.30 C3225Y5V1H106Z Y5V 50V 10,000,000 +80/-20% 1.60 ± 0.30 C3225Y5V1E106Z/1.30 Y5V 25V 10,000,000 +80/-20% 1.30 ± 0.15 C3225Y5V1E106Z/1.60 Y5V 25V 10,000,000 +80/-20% 1.60 ± 0.30 C3225Y5V1E226Z Y5V 25V 22,000,000 +80/-20% 2.00 ± 0.20 C3225Y5V1C106Z/1.15 Y5V 16V 10,000,000 +80/-20% 1.15 ± 0.10 C3225Y5V1C106Z/1.60 Y5V 16V 10,000,000 +80/-20% 1.60 ± 0.30 C3225Y5V1C226Z/1.30 Y5V 16V 22,000,000 +80/-20% 1.30 ± 0.15 C3225Y5V1C226Z/2.00 Y5V 16V 22,000,000 +80/-20% 2.00 ± 0.20 C3225Y5V1C476Z Y5V 16V 47,000,000 +80/-20% 2.30 ± 0.20 C3225Y5V1A226Z/1.15 Y5V 10V 22,000,000 +80/-20% 1.15 ± 0.10 TDK MLCC US Catalog Page 57 Version B11 Capacitance Range Table C3225 [EIA CC1210] Class 2 (Temperature Stable) Temperature Characteristics: Y5V(-30 to +85ºC, +22/-82%) TDK Part Number (Ordering Code) Temperature Characteristics C3225Y5V1A476Z Y5V 10V C3225Y5V0J107Z Y5V 6.3V TDK MLCC US Catalog Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) 47,000,000 +80/-20% 2.00 ± 0.20 100,000,000 +80/-20% 2.50 ± 0.30 Page 58 Version B11 Capacitance Range Chart C4532 [EIA CC1812] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC) Rated Voltage: 50V (1H) Capacitance (pF) 47,000 68,000 100,000 150,000 220,000 C0G Cap Code 473 683 104 154 224 Tolerance 1H (50V) J: ± 5% Capacitance Range Chart Temperature Characteristics: X7R (±15%), X5R (±15%), Y5V (+22/-82%) Rated Voltage: 50V (1H), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J) Capacitance (pF) Cap Code 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 33,000,000 47,000,000 68,000,000 100,000,000 105 155 225 335 475 685 106 156 226 336 476 686 107 Capacitance (pF) Cap Code 10,000,000 22,000,000 47,000,000 100,000,000 106 226 476 107 X7R Tolerance 1H (50V) 1E (25V) 1H (50V) 1E (25V) X5R 1C (16V) 1E (25V) 1C (16V) 1A (10V) 1C (16V) 1A (10V) 0J (6.3V) K: ± 10% M: ± 20% Y5V Tolerance Z: +80/-20% Standard Thickness 2.80 mm 3.20 mm 2.50 mm 1.60 mm 2.00 mm 2.30 mm • Standard capacitance and thickness is shown. Please refer to Capacitance Range Table for additional capacitance values and thicknesses. TDK MLCC US Catalog Page 59 Version B11 Capacitance Range Table C4532 [EIA CC1812] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C4532C0G1H473J C0G 50V 47,000 ± 5% 1.60 ± 0.30 C4532C0G1H683J C0G 50V 68,000 ± 5% 1.60 ± 0.30 C4532C0G1H104J C0G 50V 100,000 ± 5% 2.00 ± 0.20 C4532C0G1H154J C0G 50V 150,000 ± 5% 2.50 ± 0.30 C4532C0G1H224J C0G 50V 220,000 ± 5% 3.20 ± 0.30 Capacitance Tolerance Thickness (mm) Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%), X5R (-55 to +85ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) C4532X7R1H105K X7R 50V 1,000,000 ± 10% 1.60 ± 0.30 C4532X7R1H105M X7R 50V 1,000,000 ± 20% 1.60 ± 0.30 C4532X7R1H155K/1.60 X7R 50V 1,500,000 ± 10% 1.60 ± 0.30 C4532X7R1H155M/1.60 X7R 50V 1,500,000 ± 20% 1.60 ± 0.30 C4532X7R1H225K X7R 50V 2,200,000 ± 10% 1.60 ± 0.30 C4532X7R1H225M X7R 50V 2,200,000 ± 20% 1.60 ± 0.30 C4532X7R1H335K X7R 50V 3,300,000 ± 10% 2.00 ± 0.20 C4532X7R1H335M X7R 50V 3,300,000 ± 20% 2.00 ± 0.20 C4532X7R1H475K/2.00 X7R 50V 4,700,000 ± 10% 2.00 ± 0.20 C4532X7R1H475M/2.00 X7R 50V 4,700,000 ± 20% 2.00 ± 0.20 C4532X7R1H685K X7R 50V 6,800,000 ± 10% 2.50 ± 0.30 C4532X7R1H685M X7R 50V 6,800,000 ± 20% 2.50 ± 0.30 C4532X7R1E475M/2.00 X7R 25V 4,700,000 ± 20% 2.00 ± 0.20 C4532X7R1E106K X7R 25V 10,000,000 ± 10% 2.50 ± 0.30 C4532X7R1E106M X7R 25V 10,000,000 ± 20% 2.50 ± 0.30 C4532X7R1E156M/2.80 X7R 25V 15,000,000 ± 20% 2.80 ± 0.30 C4532X7R1E226M X7R 25V 22,000,000 ± 20% 2.50 ± 0.30 C4532X7R1C106K X7R 16V 10,000,000 ± 10% 2.30 ± 0.20 C4532X7R1C106M X7R 16V 10,000,000 ± 20% 2.30 ± 0.20 C4532X7R1C226M/2.00 X7R 16V 22,000,000 ± 20% 2.00 ± 0.20 C4532X7R1C226M/2.30 X7R 16V 22,000,000 ± 20% 2.30 ± 0.20 C4532X7R1C336M X7R 16V 33,000,000 ± 20% 2.50 ± 0.30 C4532X5R1E106K X5R 25V 10,000,000 ± 10% 2.50 ± 0.30 C4532X5R1E106M X5R 25V 10,000,000 ± 20% 2.50 ± 0.30 C4532X5R1E156M/2.80 X5R 25V 15,000,000 ± 20% 2.80 ± 0.30 C4532X5R1E226M X5R 25V 22,000,000 ± 20% 2.50 ± 0.30 C4532X5R1C226M/2.00 X5R 16V 22,000,000 ± 20% 2.00 ± 0.20 C4532X5R1C226M/2.30 X5R 16V 22,000,000 ± 20% 2.30 ± 0.20 C4532X5R1C336M X5R 16V 33,000,000 ± 20% 2.50 ± 0.30 C4532X5R1A226M X5R 10V 22,000,000 ± 20% 2.30 ± 0.20 C4532X5R1A336M X5R 10V 33,000,000 ± 20% 2.30 ± 0.20 C4532X5R1A476M X5R 10V 47,000,000 ± 20% 2.80 ± 0.30 C4532X5R1A107M X5R 10V 100,000,000 ± 20% 2.80 ± 0.30 C4532X5R0J476M X5R 6.3V 47,000,000 ± 20% 2.50 ± 0.30 C4532X5R0J686M X5R 6.3V 68,000,000 ± 20% 2.80 ± 0.30 TDK MLCC US Catalog Page 60 Version B11 Capacitance Range Table C4532 [EIA CC1812] Class 2 (Temperature Stable) Temperature Characteristics: X5R (-55 to +85ºC, ±15%), Y5V(-30 to +85ºC, +22/-82%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C4532X5R0J107M X5R 6.3V 100,000,000 ± 20% 2.80 ± 0.30 C4532Y5V1H106Z Y5V 50V 10,000,000 +80/-20% 2.00 ± 0.20 C4532Y5V1E226Z Y5V 25V 22,000,000 +80/-20% 2.00 ± 0.20 C4532Y5V1C476Z Y5V 16V 47,000,000 +80/-20% 2.50 ± 0.30 C4532Y5V1A107Z Y5V 10V 100,000,000 +80/-20% 2.50 ± 0.30 TDK MLCC US Catalog Page 61 Version B11 Capacitance Range Chart C5750 [EIA CC2220] Capacitance Range Chart Temperature Characteristics: X7R (± 15%), X5R (± 15%), Y5V (+22/-82%) Rated Voltage: 50V (1H), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J) Capacitance (pF) Cap Code 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 33,000,000 47,000,000 68,000,000 100,000,000 475 685 106 156 226 336 476 686 107 Capacitance (pF) Cap Code 10,000,000 22,000,000 47,000,000 100,000,000 106 226 476 107 X7R Tolerance 1H (50V) 1E (25V) 1H (50V) 1E (25V) X5R 1C (16V) 1H (50V) 1C (16V) 1A (10V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) K: ± 10% M: ± 20% Y5V Tolerance Z: +80/-20% Standard Thickness 2.00 mm TDK MLCC US Catalog 2.30 mm 2.50 mm 2.80 mm Page 62 Version B11 Capacitance Range Table C5750 [EIA CC2220] Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%), X5R (-55 to +85ºC, ±15%), Y5V(-30 to +85ºC, +22/-82%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C5750X7R1H475K/2.00 X7R 50V 4,700,000 ± 10% 2.00 ± 0.20 C5750X7R1H475M/2.00 X7R 50V 4,700,000 ± 20% 2.00 ± 0.20 C5750X7R1H475M/2.80 X7R 50V 4,700,000 ± 20% 2.80 ± 0.20 C5750X7R1H685K X7R 50V 6,800,000 ± 10% 2.50 ± 0.30 C5750X7R1H685M X7R 50V 6,800,000 ± 20% 2.50 ± 0.30 C5750X7R1H106K X7R 50V 10,000,000 ± 10% 2.30 ± 0.20 C5750X7R1H106M X7R 50V 10,000,000 ± 20% 2.30 ± 0.20 C5750X7R1E106M X7R 25V 10,000,000 ± 20% 2.00 ± 0.20 C5750X7R1E156M X7R 25V 15,000,000 ± 20% 2.30 ± 0.20 C5750X7R1E226M X7R 25V 22,000,000 ± 20% 2.50 ± 0.30 C5750X7R1C226M X7R 16V 22,000,000 ± 20% 2.80 ± 0.20 C5750X7R1C476M X7R 16V 47,000,000 ± 20% 2.30 ± 0.20 C5750X5R1H106K X5R 50V 10,000,000 ± 10% 2.30 ± 0.20 C5750X5R1H106M X5R 50V 10,000,000 ± 20% 2.30 ± 0.20 C5750X5R1E226M X5R 25V 22,000,000 ± 20% 2.30 ± 0.20 C5750X5R1C336M X5R 16V 33,000,000 ± 20% 2.00 ± 0.20 C5750X5R1C476M X5R 16V 47,000,000 ± 20% 2.30 ± 0.20 C5750X5R1A686M X5R 10V 68,000,000 ± 20% 2.30 ± 0.20 C5750X5R1A107M X5R 10V 100,000,000 ± 20% 2.80 ± 0.20 C5750X5R0J107M X5R 6.3V 100,000,000 ± 20% 2.80 ± 0.20 C5750Y5V1H226Z Y5V 50V 22,000,000 +80/-20% 2.00 ± 0.20 C5750Y5V1E476Z Y5V 25V 47,000,000 +80/-20% 2.00 ± 0.20 C5750Y5V1C107Z Y5V 16V 100,000,000 +80/-20% 2.50 ± 0.30 C5750Y5V1A107Z Y5V 10V 100,000,000 +80/-20% 2.50 ± 0.30 TDK MLCC US Catalog Page 63 Version B11 General Specifications C Series – General Application No. Item Performance Test or Inspection Method 1 External Appearance No defects which may affect performance. Inspect with magnifying glass (3×), in case of C0603 type, with magnifying glass (10×). 2 Insulation Resistance 10,000MΩ or 500MΩ•μF min. (As for the capacitors of rated voltage 16, 10 and 6.3V DC, 10,000 MΩ or 100MΩ•μF min.,) whichever smaller. Apply rated voltage for 60s. As for the rated voltage 630V DC, apply 500V DC. 3 Voltage Proof Withstand test voltage without insulation breakdown or other damage. Class Apply voltage Class 1 3 × rated voltage Class 2 2.5 × rated voltage Above DC voltage shall be applied for 1 to 5s. Charge / discharge current shall not exceed 50mA. 4 Capacitance Within the specified tolerance. Class Class 1 Class 2 5 Q (Class 1) Rated Capacitance Measuring Frequency C ≤ 1000pF 1MHz±10% C >1000pF 1kHz±10% C ≤ 10uF 1kHz±10% C > 10uF 120Hz±20% Measuring voltage 0.5 - 5 Vrms 0.5±0.2Vrms 1.0±0.2Vrms 0.5±0.2 Vrms See No.4 in this table for measuring condition. Rated Capacitance Q 30pF and over 1,000 min. Under 30pF 400+20×C min. C : Rated capacitance (pF) 6 Dissipation Factor (Class 2) TDK MLCC US Catalog T.C. Rated Voltage D.F. X5R X7R - 0.03 max. 0.05 max. 0.75 max. 0.1 max. 0.125 max. 0.15 max. Y5V 50VDC 0.05 max. 25VDC 0.075 max. 16VDC 0.10 max. 10VDC 0.125 max. 6.3VDC 0.20 max. See No.4 in this table for measuring condition. Page 64 Version B11 General Specifications No. Item 7 Temperature Characteristics of Capacitance (Class 1) 8 Temperature Characteristics of Capacitance (Class 2) C Series – General Application Performance T.C. Test or Inspection Method Temperature Coefficient C0G 0 ± 30 (ppm/ºC) Temperature coefficient shall be calculated based on values at 25ºC and 85ºC temperature. Capacitance drift Within ± 0.2% or ±0.05pF, whichever larger. Measuring temperature below 20ºC shall be -10ºC and -25ºC. Capacitance Change (%) Capacitance shall be measured by the steps shown in the following table after thermal equilibrium is obtained for each step. ∆C be calculated ref. STEP 3 reading No Voltage Applied X5R: X7R: X6S: X7S: X7T: Y5V: ± 15% ± 15% ± 22% ± 22% +22/-33% + 22/-82% Step Temperature (ºC) 1 Reference temp. ± 2 2 Min. operating temp. ± 2 3 Reference temp. ± 2 4 Max. operating temp. ± 2 Measuring voltage: 0.1, 0.2, 0.5, 1.0Vrms. 9 Robustness of Terminations No sign of termination coming off, breakage of ceramic, or other abnormal signs. Reflow solder the capacitor on P.C. board (shown in Appendix 1a or Appendix 1b) and apply a pushing force of 2N (C0603, C1005) or 5N (C1608, C2012, C3216, C3225, C4532, C5750) for 10±1s. Pushing force P.C. board Capacitor 10 Bending No mechanical damage. Reflow solder the capacitor on P.C. board (shown in Appendix 2a or Appendix 2b) and bend it for 1mm. 20 50 F R230 1 45 TDK MLCC US Catalog Page 65 45 Unit: mm Version B11 General Specifications C Series – General Application No. Item Performance Test or Inspection Method 11 Solderability New solder to cover over 75% of termination. Completely soak both terminations in solder at 235±5ºC for 2±0.5s. 25% may have pinholes or rough spots but not concentrated in one spot. Solder: H63A (JIS Z 3282) Ceramic surface of A sections shall not be exposed due to melting or shifting of termination material. Flux: Isopropyl alcohol (JIS K 8839) Rosin (JIS K 5902) 25% solid solution. A section 12 Resistance to solder heat External appearance Capacitance Q (Class 1) No cracks are allowed and terminations shall be covered at least 60% with new solder. Characteristics Change from the value before test Class 1 C0G Capacitance drift within ±2.5% or ±0.25pF, whichever larger. Class 2 X5R X7R Y5V ± 7.5 % ± 7.5 % ± 20 % Completely soak both terminations in solder at 260±5ºC for 5±1s. Preheating condition Temp.: 150±10ºC Time: 1 to 2min. Flux: Isopropyl alcohol (JIS K 8839) Rosin (JIS K 5902) 25% solid solution. Solder: H63A (JIS Z 3282) Leave the capacitor in ambient conditions for 6 to 24h (Class 1) or 24±2h (Class 2) before measurement. Rated Capacitance Q C ≥ 30pF 1,000 min. C < 30pF 400+20×C min. C : Rated capacitance (pF) D.F. (Class 2) Meet the initial spec. Insulation Resistance Meet the initial spec. Voltage Proof No insulation breakdown or other damage. TDK MLCC US Catalog Page 66 Version B11 General Specifications No. Item 13 Vibration External appearance Capacitance Q (Class 1) C Series – General Application Performance Test or Inspection Method Reflow solder the capacitor on P.C. board (shown in Appendix 1a or Appendix 1b) before testing. No mechanical damage. Characteristics Change from the value before test Class 1 C0G ±2.5% or ±0.25pF, whichever larger. Class 2 X5R X7R Y5V ± 7.5 % ± 7.5 % ± 20 % Rated Capacitance Q C ≥ 30pF 1,000 min. C < 30pF 400+20×C min. Vibrate the capacitor with amplitude of 1.5mm P-P changing the frequencies from 10Hz to 55Hz and back to 10Hz after 1min. Repeat this for 2h each in 3 perpendicular directions. C : Rated capacitance (pF) D.F. (Class 2) 14 Meet the initial spec. Temperature cycle External appearance Capacitance Q (Class 1) Reflow solder the capacitor on P.C. board (shown in Appendix 1a or Appendix 1b) before testing. No mechanical damage. Characteristics Change from the value before test Class 1 C0G ±2.5% or ±0.25pF, whichever larger. Class 2 X5R X7R Y5V ± 15 % ± 15 % ± 20 % Rated Capacitance Q C ≥ 30pF 1,000 min. C < 30pF Expose the capacitor in the condition step1 through step 4 and repeat 5 times consecutively. Leave the capacitor in ambient conditions for 6 to 24h (Class 1) or 24±2h (Class 2) before measurement. Step Temperature (ºC) Time (min.) 1 Min. operating temp. ±3 30 ± 3 2 Reference Temp. 2–5 3 Max. operating temp. ± 2 30 ± 2 4 Reference Temp. 2-5 400+20×C min. C : Rated capacitance (pF) D.F. (Class 2) Meet the initial spec. Insulation Resistance Meet the initial spec. Voltage Proof No insulation breakdown or other damage. TDK MLCC US Catalog Page 67 Version B11 General Specifications C Series – General Application No. Item 15 Moisture Resistance (Steady State) External appearance Capacitance Q (Class 1) Performance Test or Inspection Method Reflow solder the capacitor on P.C. board (shown in Appendix 1a or Appendix 1b) before testing. No mechanical damage. Characteristics Change from the value before test Class 1 C0G ±5% or ±0.5pF, whichever larger. Class 2 X5R X7R Y5V ± 25 % ± 25 % ± 30 % Rated Capacitance Leave at temperature 40±2ºC, 90 to 95%RH for 500 +24,0h. Leave the capacitor in ambient conditions for 6 to 24h (Class 1) or 24±2h (Class 2) before measurement. Q C ≥ 30pF 350 min. 10pF ≤ C < 30pF 275+5/2×C min. C
C1005X7R1H472K/50 价格&库存
很抱歉,暂时无法提供与“C1005X7R1H472K/50”相匹配的价格&库存,您可以联系我们找货
