C1608X8R1H473K080AA.
    TDK(东电化)
    TDK - C1608X8R1H473K080AA. - CERAMIC CAPACITOR, 0.047UF, 50V, X8R, 0603
C1608X8R1H473K080AA. 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS C Series Commercial Grade High Temperature Application Type: C1005 [EIA CC0402] C1608 [EIA CC0603] C2012 [EIA CC0805] C3216 [EIA CC1206] C3225 [EIA CC1210] C4532 [EIA CC1812] C5750 [EIA CC2220] Issue date: Jun 2015 20150616 / mlcc_commercial_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS REMINDERS Please read before using this product SAFETY REMINDERS REMINDERS 1. If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other damage, you must contact our company’s sales window. 2. We may modify products or discontinue production of a product listed in this catalog without prior notification. 3. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. 4. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export permission in harmony with this law. 5. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. 6. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. 7. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging specification detail. This new catalog number should be referenced on all catalog orders going forward, and is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will differ from the item description (internal control number) on the product label. Contact your local TDK Sales representative for more information. (Example) Catalog Issued date Catalog Number Item Description (On Delivery Label) Prior to January 2013 C1608C0G1E103J C1608C0G1E103JT000N January 2013 and Later C1608C0G1E103J080AA C1608C0G1E103JT000N Page 1 20150616 / mlcc_commercial_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS C Series High Temperature Application Type: C1005 [EIA CC0402], C1608 [EIA CC0603], C2012 [EIA CC0805], C3216 [EIA CC1206], C3225 [EIA CC1210], C4532 [EIA CC1812], C5750 [EIA CC2220] Features Applications • With a maximum temperature of 150°C and a capacitance change within ±15%, the series is suited for devices that operate in high-temperature environments. • Excellent DC bias properties. Parameters Specifications -55 to 150°C ¨C/C: ±15% or 0 ± 30ppm -55 to +150°C 5% maximum 10 GŸ or 500 MŸ • ȝF minimum 2.5 • Rated Voltage or 3 • Rated Voltage for 1 to 5 seconds Charge/Discharge ” 50 mA Temperature Characteristics Operating Temperature Dissipation Factor Insulation Resistance Voltage Proof Catalog Number Construction • Automotive applications (engine rooms) • Measurement instruments used at high temperature environments • LCD display • Sensor Module • Smoothing and decoupling applications for other devices that operate at high temperature Shape & Dimensions L W T B G Body Length Body Width Body Height Terminal Width Terminal Spacing C • 3225 • X8R • 1C • 106 • K • 250 • A • B Series Name Dimensions L x W (mm) Code C1005 C1608 C2012 C3216 C3225 C4532 C5750 Length 1.00 ± 0.05 1.60 ± 0.10 2.00 ± 0.20 3.20 ± 0.20 3.20 ± 0.40 4.50 ± 0.40 5.70 ± 0.40 Width 0.50 ± 0.80 ± 1.25 ± 1.60 ± 2.50 ± 3.20 ± 5.00 ± 0.05 0.10 0.20 0.20 0.30 0.40 0.40 Terminal 0.10 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. *Dimensional tolerances are typical values. Temperature Characteristics Temperature Characteristics NP0 X8R Temperature Coefficient or Capacitance Change 0 ± 30ppm/°C ± 15% Temperature Range -55 to +150°C -55 to +150°C Rated Voltage (DC) Code 1C 1E 1H Voltage (DC) 16V 25V 50V Code 2A 2E 2W 2J Voltage (DC) 100V 250V 450V 630V Nominal Capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. Ex. 0R2 = 0.2pF; 103 = 10,000pF; 105 = 1,000,000pF = 1,000nF Capacitance Tolerance Code C D J K M Tolerance ± 0.25pF ± 0.50pF ± 5% ± 10% ± 20% Nominal Thickness Code 050 060 080 085 115 125 160 200 Thickness 0.50 mm 0.60 mm 0.80 mm 0.85 mm 1.15 mm 1.25 mm 1.60 mm 2.00 mm Code 230 250 280 320 Thickness 2.30 mm 2.50 mm 2.80 mm 3.20 mm Packaging Style Code A B K Style 178 mm Reel, 4 mm Pitch 178 mm Reel, 2 mm Pitch 178 mm Reel, 8 mm Pitch Special Reserved Code Code A, B Description TDK Internal Code Page 2   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150616 / mlcc_commercial_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC0402 [C1005] Capacitance Range Chart Temperature Characteristics: NP0 (0 ± 30ppm/ºC), X8R (± 15%) Rated Voltage: 100V (2A), 50V (1H), 25V (1E), 16V (1C) Capacitance (pF) 1 1.5 2 2.2 3 3.3 4 4.7 5 6 6.8 7 8 9 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 NP0 Code 010 1R5 020 2R2 030 3R3 040 4R7 050 060 6R8 070 080 090 100 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 152 222 332 472 682 103 153 223 333 473 Tolerance X8R 2A 1H 2A 1H (100V) (50V) (100V) (50V) 1E (25V) 1C (16V) C: ± 0.25pF D: ± 0.50pF J: ± 5% K: ± 10% M: ± 20% Standard Thickness 0.50 mm Page 3   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150616 / mlcc_commercial_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC0603 [C1608] Capacitance Range Chart Temperature Characteristics: NP0 (0 ± 30ppm/ºC), X8R (±15%) Rated Voltage: 250V (2E), 100V (2A), 50V (1H), 25V (1E), 16V (1C) Capacitance (pF) 1 2 2 2 3 3 4 5 5 6 7 7 8 9 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 NP0 Code 010 1R5 020 2R2 030 3R3 040 4R7 050 060 6R8 070 080 090 100 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 Tolerance C: ± 0.25pF D: ± 0.50pF J: ± 5% 2E 2A 1H (250V) (100V) (50V) X8R Capacitance (pF) Code 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 102 152 222 332 472 682 103 153 223 333 473 683 104 154 224 334 474 Tolerance 2A 1H (100V) (50V) 1E (25V) 1C (16V) K: ± 10% M: ± 20% Standard Thickness 0.80 mm Page 4   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150616 / mlcc_commercial_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC0805 [C2012] Capacitance Range Chart Temperature Characteristics: NP0 (0 ± 30ppm/ºC), X8R (±15%) Rated Voltage: 450V(2W), 250V(2E), 100V (2A), 50V (1H), 25V (1E), 16V (1C) Capacitance (pF) 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 NP0 Code 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 153 223 333 473 683 104 154 224 334 474 684 105 Tolerance X8R 2W 2E 2A 1H 2A 1H (450V) (250V) (100V) (50V) (100V) (50V) 1E (25V) 1C (16V) J: ± 5% K: ± 10% M: ± 20% Standard Thickness 0.60 mm 0.85 mm 1.25 mm Page 5   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150616 / mlcc_commercial_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC1206 [C3216] Capacitance Range Chart Temperature Characteristics: NP0 (0 ± 30ppm/ºC), X8R (±15%) Rated Voltage: 630V(2J), 450V(2W), 250V(2E), 100V (2A), 50V (1H), 25V (1E), 16V (1C) Capacitance (pF) 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 NP0 Code 392 472 562 682 822 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 335 475 Tolerance X8R 2J 2W 2E 2A 1H 2A 1H (630V) (450V) (250V) (100V) (50V) (100V) (50V) 1E (25V) 1C (16V) J: ± 5% K: ± 10% M: ± 20% Standard Thickness 0.60 mm 0.85 mm 1.15 mm 1.60 mm Capacitance Range Chart EIA CC1210 [C3225] Capacitance Range Chart Temperature Characteristics: NP0 (0 ± 30ppm/ºC), X8R (±15%) Rated Voltage: 630V(2J), 450V(2W), 250V(2E), 100V (2A), 50V (1H), 25V (1E), 16V (1C) Capacitance (pF) 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 470,000 680,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 NP0 Code 822 103 153 223 333 473 683 104 474 684 155 225 335 475 685 106 Tolerance X8R 2J 2W 2E 2A 1H 2A 1E (630V) (450V) (250V) (100V) (50V) (100V) ( 25V) 1C (16V) J: ± 5% K: ± 10% M: ± 20% Standard Thickness 1.25 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm Page 6   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150616 / mlcc_commercial_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC1812 [C4532] Capacitance Range Chart Temperature Characteristics: NP0 (0 ± 30ppm/ºC) Rated Voltage: 630V(2J), 450V(2W), 250V(2E), 100V (2A), 50V (1H) Capacitance (pF) 33,000 47,000 68,000 100,000 150,000 220,000 NP0 Code 333 473 683 104 154 224 Tolerance 2J 2W 2E 2A 1H (630V) (450V) (250V) (100V) (50V) Standard Thickness 1.60 mm J: ± 5% 2.00 mm 2.30 mm 2.50 mm 3.20 mm Capacitance Range Chart EIA CC2220 [C5750] Capacitance Range Chart Temperature Characteristics: NP0 (0 ± 30ppm/ºC) Rated Voltage: 450V(2W), 250V(2E), 100V (2A) Capacitance (pF) 100,000 150,000 NP0 Code 104 154 Tolerance J: ± 5% 2W 2E 2A (450V) (250V) (100V) Standard Thickness 2.30 mm 2.80 mm Page 7   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150616 / mlcc_commercial_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: NP0 (-55 to +150ºC, 0±30 ppm/ºC) Capacitance Size 1 pF 1.5 pF 2 pF 2.2 pF 3 pF 3.3 pF 4 pF 4.7 pF 5 pF 6 pF 6.8 pF 7 pF 8 pF 9 pF 10 pF 12 pF 15 pF 18 pF 22 pF 27 pF 33 pF 39 pF 47 pF 56 pF 68 pF 82 pF 100 pF 120 pF 150 pF 180 pF 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 Thickness (mm) 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 Catalog Number Capacitance Tolerance Rated Voltage Edc: 630V ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% Rated Voltage Edc: 450V Rated Voltage Edc: 250V Rated Voltage Edc: 100V C1608NP02A010C080AA C1608NP02A1R5C080AA C1608NP02A020C080AA C1608NP02A2R2C080AA C1608NP02A030C080AA C1608NP02A3R3C080AA C1608NP02A040C080AA C1608NP02A4R7C080AA C1608NP02A050C080AA C1608NP02A060D080AA C1608NP02A6R8D080AA C1608NP02A070D080AA C1608NP02A080D080AA C1608NP02A090D080AA C1608NP02A100D080AA C1608NP02A120J080AA C1608NP02A150J080AA C1608NP02A180J080AA C1608NP02A220J080AA C1608NP02A270J080AA C1608NP02A330J080AA C1608NP02A390J080AA C1608NP02A470J080AA C1608NP02A560J080AA C1608NP02A680J080AA C1608NP02A820J080AA C1005NP02A101J050BA C1608NP02A101J080AA Rated Voltage Edc: 50V C1005NP01H010C050BA C1608NP01H010C080AA C1005NP01H1R5C050BA C1608NP01H1R5C080AA C1005NP01H020C050BA C1608NP01H020C080AA C1005NP01H2R2C050BA C1608NP01H2R2C080AA C1005NP01H030C050BA C1608NP01H030C080AA C1005NP01H3R3C050BA C1608NP01H3R3C080AA C1005NP01H040C050BA C1608NP01H040C080AA C1005NP01H4R7C050BA C1608NP01H4R7C080AA C1005NP01H050C050BA C1608NP01H050C080AA C1005NP01H060D050BA C1608NP01H060D080AA C1005NP01H6R8D050BA C1608NP01H6R8D080AA C1005NP01H070D050BA C1608NP01H070D080AA C1005NP01H080D050BA C1608NP01H080D080AA C1005NP01H090D050BA C1608NP01H090D080AA C1005NP01H100D050BA C1608NP01H100D080AA C1005NP01H120J050BA C1608NP01H120J080AA C1005NP01H150J050BA C1608NP01H150J080AA C1005NP01H180J050BA C1608NP01H180J080AA C1005NP01H220J050BA C1608NP01H220J080AA C1005NP01H270J050BA C1608NP01H270J080AA C1005NP01H330J050BA C1608NP01H330J080AA C1005NP01H390J050BA C1608NP01H390J080AA C1005NP01H470J050BA C1608NP01H470J080AA C1005NP01H560J050BA C1608NP01H560J080AA C1005NP01H680J050BA C1608NP01H680J080AA C1005NP01H820J050BA C1608NP01H820J080AA C1005NP01H101J050BA C1608NP01H101J080AA C2012NP02W101J060AA C1005NP02A121J050BA C1005NP01H121J050BA C1608NP02A121J080AA C1608NP01H121J080AA C2012NP02W121J060AA C1005NP02A151J050BA C1005NP01H151J050BA C1608NP02A151J080AA C1608NP01H151J080AA C2012NP02W151J060AA C1005NP02A181J050BA C1005NP01H181J050BA C1608NP02A181J080AA C1608NP01H181J080AA C2012NP02W181J060AA Page 8   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150616 / mlcc_commercial_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: NP0 (-55 to +150ºC, 0±30 ppm/ºC) Capacitance Size 220 pF 270 pF 330 pF 390 pF 470 pF 560 pF 680 pF 820 pF 1 nF 1.2 nF 1.5 nF 1.8 nF 2.2 nF 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 1608 2012 1608 2012 1608 2012 1608 2012 1608 2.7 nF 2012 1608 3.3 nF 2012 1608 3.9 nF 2012 3216 1608 4.7 nF 2012 3216 1608 2012 5.6 nF 3216 Catalog Number Capacitance Tolerance Rated Voltage Edc: 630V 0.50 ± 0.05 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.50 ± 0.05 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.50 ± 0.05 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.50 ± 0.05 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.50 ± 0.05 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.50 ± 0.05 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.50 ± 0.05 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.50 ± 0.05 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.50 ± 0.05 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.85 ± 0.15 ± 5% 0.80 ± 0.10 ± 5% 0.85 ± 0.15 ± 5% 0.80 ± 0.10 ± 5% 0.85 ± 0.15 ± 5% 0.80 ± 0.10 ± 5% 0.80+0.15/-0.1 ± 5% 0.60 ± 0.15 ± 5% 1.25 ± 0.20 ± 5% 0.80 ± 0.10 ± 5% 0.80 + 0.15/-0.1 ± 5% 0.60 ± 0.15 ± 5% 0.85 ± 0.15 ± 5% 1.25 ± 0.20 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 1.25 ± 0.20 ± 5% 0.60 ± 0.15 ± 5% 0.85 ± 0.15 ± 5% C3216NP02J392J085AA 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 1.25 ± 0.20 ± 5% 0.60 ± 0.15 ± 5% 0.85 ± 0.15 ± 5% C3216NP02J472J085AA 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 1.25 ± 0.20 ± 5% 0.60 ± 0.15 ± 5% 0.85 ± 0.15 ± 5% 1.15 ± 0.15 ± 5% C3216NP02J562J115AA Thickness (mm) Rated Voltage Edc: 450V Rated Voltage Edc: 250V Rated Voltage Edc: 100V Rated Voltage Edc: 50V C1005NP02A221J050BA C1005NP01H221J050BA C1608NP02A221J080AA C1608NP01H221J080AA C2012NP02W221J060AA C1005NP02A271J050BA C1005NP01H271J050BA C1608NP02A271J080AA C1608NP01H271J080AA C2012NP02W271J060AA C1005NP02A331J050BA C1005NP01H331J050BA C1608NP02A331J080AA C1608NP01H331J080AA C2012NP02W331J060AA C1005NP02A391J050BA C1005NP01H391J050BA C1608NP02A391J080AA C1608NP01H391J080AA C2012NP02W391J060AA C1005NP02A471J050BA C1005NP01H471J050BA C1608NP02A471J080AA C1608NP01H471J080AA C2012NP02W471J060AA C1005NP01H561J050BA C1608NP02A561J080AA C1608NP01H561J080AA C2012NP02W561J060AA C1005NP01H681J050BA C1608NP02A681J080AA C1608NP01H681J080AA C2012NP02W681J060AA C1005NP01H821J050BA C1608NP02E821J080AA C1608NP02A821J080AA C1608NP01H821J080AA C2012NP02W821J060AA C1005NP01H102J050BA C1608NP02E102J080AA C1608NP02A102J080AA C1608NP01H102J080AA C2012NP02W102J060AA C2012NP02A102J060AA C1608NP02E122J080AA C1608NP02A122J080AA C1608NP01H122J080AA C2012NP02W122J060AA C2012NP02A122J060AA C1608NP02E152J080AA C1608NP02A152J080AA C1608NP01H152J080AA C2012NP02A152J060AA C2012NP02W152J085AA C1608NP02E182J080AA C1608NP02A182J080AA C1608NP01H182J080AA C2012NP02W182J085AA C2012NP02A182J085AA C1608NP02E222J080AA C1608NP02A222J080AA C1608NP01H222J080AA C2012NP02W222J085AA C2012NP02A222J085AA C1608NP01H272J080AA C1608NP02A272J080AA C2012NP01H272J060AA C2012NP02W272J125AA C2012NP02A272J125AA C1608NP01H332J080AA C1608NP02A332J080AA C2012NP01H332J060AA C2012NP02E332J085AA C2012NP02W332J125AA C2012NP02A332J125AA C1608NP01H392J080AA C2012NP01H392J060AA C2012NP02W392J125AA C2012NP02E392J125AA C2012NP02A392J125AA C3216NP02A392J060AA C1608NP01H472J080AA C2012NP01H472J060AA C2012NP02W472J125AA C2012NP02E472J125AA C2012NP02A472J125AA C3216NP01H472J060AA C3216NP02A472J085AA C1608NP01H562J080AA C2012NP01H562J060AA C2012NP02W562J125AA C2012NP02E562J125AA C2012NP02A562J125AA C3216NP01H562J060AA C3216NP02A562J085AA Page 9   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150616 / mlcc_commercial_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: NP0 (-55 to +150ºC, 0±30 ppm/ºC) Capacitance Size 1608 6.8 nF 2012 3216 1608 2012 8.2 nF 3216 3225 1608 2012 10 nF 3216 3225 2012 15 nF 3216 3225 2012 3216 22 nF 3225 2012 3216 33 nF 3225 4532 3216 3225 47 nF 4532 3216 3225 68 nF 4532 3216 3225 100 nF 150 nF 220 nF 4532 5750 4532 5750 4532 Catalog Number Capacitance Tolerance Rated Voltage Edc: 630V 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 1.25 ± 0.20 ± 5% 0.60 ± 0.15 ± 5% 1.15 ± 0.15 ± 5% C3216NP02J682J115AA 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 1.25 ± 0.20 ± 5% 0.60 ± 0.15 ± 5% 1.15 ± 0.15 ± 5% 1.60 ± 0.20 ± 5% C3216NP02J822J160AA 1.25 ± 0.20 ± 5% C3225NP02J822J125AA 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 1.25 ± 0.20 ± 5% 0.60 ± 0.15 ± 5% 1.15 ± 0.15 ± 5% 1.60 ± 0.20 ± 5% C3216NP02J103J160AA 1.25 ± 0.20 ± 5% C3225NP02J103J125AA 0.85 ± 0.15 ± 5% 0.60 ± 0.15 ± 5% 1.15 ± 0.15 ± 5% 1.60 ± 0.20 ± 5% 1.25 ± 0.20 ± 5% 1.60 ± 0.20 ± 5% C3225NP02J153J160AA 1.25 ± 0.20 ± 5% 0.60 ± 0.15 ± 5% 1.60 ± 0.20 ± 5% 1.25 ± 0.20 ± 5% 1.60 ± 0.20 ± 5% 2.30 ± 0.20 ± 5% C3225NP02J223J230AA 1.25 ± 0.20 ± 5% 0.85 ± 0.15 ± 5% 1.60 + 0.3/-0.1 ± 5% 1.60 ± 0.20 ± 5% 2.00 ± 0.20 ± 5% 2.30 ± 0.20 ± 5% 2.50 ± 0.30 ± 5% C3225NP02J333J250AA 2.00 ± 0.20 ± 5% C4532NP02J333J200KA 1.15 ± 0.15 ± 5% 2.00 ± 0.20 ± 5% 2.30 ± 0.20 ± 5% 2.50 ± 0.30 ± 5% 1.60 ± 0.20 ± 5% 2.00 ± 0.20 ± 5% 2.30 ± 0.20 ± 5% 3.20 ± 0.30 ± 5% C4532NP02J473J320KA 1.60 ± 0.20 ± 5% 2.00 ± 0.20 ± 5% 2.30 ± 0.20 ± 5% 1.60 ± 0.20 ± 5% 2.30 ± 0.20 ± 5% 2.50 ± 0.30 ± 5% 3.20 ± 0.30 ± 5% 1.60 ± 0.20 ± 5% 2.50 ± 0.30 ± 5% 2.00 ± 0.20 ± 5% 3.20 ± 0.30 ± 5% 2.80 ± 0.30 ± 5% 2.50 ± 0.30 ± 5% 2.30 ± 0.20 ± 5% 3.20 ± 0.30 ± 5% Thickness (mm) Rated Voltage Edc: 450V Rated Voltage Edc: 250V Rated Voltage Edc: 100V Rated Voltage Edc: 50V C1608NP01H682J080AA C2012NP01H682J060AA C2012NP02E682J125AA C2012NP02A682J125AA C3216NP01H682J060AA C3216NP02W682J115AA C3216NP02A682J115AA C1608NP01H822J080AA C2012NP01H822J060AA C2012NP02E822J125AA C2012NP02A822J125AA C3216NP01H822J060AA C3216NP02W822J115AA C3216NP02A822J115AA C1608NP01H103J080AA C2012NP01H103J060AA C2012NP02E103J125AA C2012NP02A103J125AA C3216NP01H103J060AA C3216NP02E103J115AA C3216NP02A103J115AA C3216NP02W103J160AA C2012NP01H153J085AA C3216NP01H153J060AA C3216NP02A153J115AA C3216NP02W153J160AA C3216NP02E153J160AA C3225NP02A153J125AA C2012NP01H223J125AA C3216NP01H223J060AA C3216NP02E223J160AA C3216NP02A223J160AA C3225NP01H223J125AA C3225NP02E223J160AA C3225NP02A223J160AA C3225NP02W223J230AA C2012NP01H333J125AA C3216NP01H333J085AA C3216NP02A333J160AA C3225NP01H333J160AA C3225NP02A333J200AA C3225NP02E333J230AA C3225NP02W333J250AA C3216NP01H473J115AA C3225NP01H473J200AA C3225NP02A473J230AA C3225NP02E473J250AA C4532NP01H473J160KA C4532NP02A473J200KA C4532NP02W473J230KA C3216NP01H683J160AA C3225NP01H683J200AA C3225NP02A683J230AA C4532NP01H683J160KA C4532NP02E683J230KN C4532NP02A683J250KA C4532NP02W683J320KA C3216NP01H104J160AA C3225NP01H104J250AA C4532NP01H104J200KA C4532NP02E104J320KN C4532NP02A104J320KA C5750NP02W104J280KA C4532NP01H154J250KA C5750NP02E154J230KN C5750NP02A154J230KA C4532NP01H224J320KA Page 10   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150616 / mlcc_commercial_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X8R (-55 to +150ºC, ±15%) Capacitance Size Thickness (mm) 150 pF 1005 0.50 ± 0.05 220 pF 1005 0.50 ± 0.05 330 pF 1005 0.50 ± 0.05 470 pF 1005 0.50 ± 0.05 680 pF 1005 0.50 ± 0.05 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 1.25 ± 0.20 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 0.85 ± 0.15 1 nF 1.5 nF 2.2 nF 3.3 nF 4.7 nF 6.8 nF 10 nF 15 nF 22 nF 33 nF Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 100V C1005X8R2A151K050BA C1005X8R2A151M050BA C1005X8R2A221K050BA C1005X8R2A221M050BA C1005X8R2A331K050BA C1005X8R2A331M050BA C1005X8R2A471K050BA C1005X8R2A471M050BA C1005X8R2A681K050BA C1005X8R2A681M050BA C1005X8R2A102K050BA C1005X8R2A102M050BA C1608X8R2A102K080AA C1608X8R2A102M080AA C1005X8R2A152K050BA C1005X8R2A152M050BA C1608X8R2A152K080AA C1608X8R2A152M080AA C1005X8R2A222K050BA C1005X8R2A222M050BA C1608X8R2A222K080AA C1608X8R2A222M080AA C1005X8R2A332K050BB C1005X8R2A332M050BB C1608X8R2A332K080AA C1608X8R2A332M080AA C1608X8R2A472K080AA C1608X8R2A472M080AA C1608X8R2A682K080AA C1608X8R2A682M080AA C1608X8R2A103K080AA C1608X8R2A103M080AA Rated Voltage Edc: 50V C1005X8R1H151K050BA C1005X8R1H151M050BA C1005X8R1H221K050BA C1005X8R1H221M050BA C1005X8R1H331K050BA C1005X8R1H331M050BA C1005X8R1H471K050BA C1005X8R1H471M050BA C1005X8R1H681K050BA C1005X8R1H681M050BA C1005X8R1H102K050BA C1005X8R1H102M050BA C1608X8R1H102K080AA C1608X8R1H102M080AA C1005X8R1H152K050BA C1005X8R1H152M050BA C1608X8R1H152K080AA C1608X8R1H152M080AA C1005X8R1H222K050BA C1005X8R1H222M050BA C1608X8R1H222K080AA C1608X8R1H222M080AA C1005X8R1H332K050BA C1005X8R1H332M050BA C1608X8R1H332K080AA C1608X8R1H332M080AA C1005X8R1H472K050BA C1005X8R1H472M050BA C1608X8R1H472K080AA C1608X8R1H472M080AA C1005X8R1H682K050BB C1005X8R1H682M050BB C1608X8R1H682K080AA C1608X8R1H682M080AA C1005X8R1H103K050BB C1005X8R1H103M050BB C1608X8R1H103K080AA C1608X8R1H103M080AA Rated Voltage Edc: 25V Rated Voltage Edc: 16V C1005X8R1E682K050BA C1005X8R1E682M050BA C1005X8R1E103K050BA C1005X8R1E103M050BA C1005X8R1E153K050BB C1005X8R1E153M050BB C1608X8R2A153K080AA C1608X8R2A153M080AA C1608X8R1H153K080AA C1608X8R1H153M080AA C1005X8R1E223K050BB C1005X8R1E223M050BB C1608X8R2A223K080AB C1608X8R2A223M080AB C2012X8R2A223K125AA C2012X8R2A223M125AA C1608X8R1H223K080AA C1608X8R1H223M080AA C1005X8R1C333K050BB C1005X8R1C333M050BB C1608X8R2A333K080AB C1608X8R2A333M080AB C2012X8R2A333K125AB C2012X8R2A333M125AB C3216X8R2A333K085AA C3216X8R2A333M085AA C1608X8R1H333K080AA C1608X8R1H333M080AA Page 11   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150616 / mlcc_commercial_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X8R (-55 to +150ºC, ±15%) Capacitance Size Thickness (mm) 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 0.85 ± 0.15 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 1.15 ± 0.15 1608 0.80 ± 0.10 47 nF 68 nF 100 nF 0.85 ± 0.15 2012 150 nF 1.25 ± 0.20 0.85 ± 0.15 3216 1.60 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 220 nF 1.15 ± 0.15 3216 1.60 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 330 nF 0.85 ± 0.15 3216 1.60 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 470 nF 0.85 ± 0.15 3216 1.60 ± 0.20 3225 2.00 ± 0.20 Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 100V Rated Voltage Edc: 50V Rated Voltage Edc: 25V Rated Voltage Edc: 16V C1005X8R1C473K050BB C1005X8R1C473M050BB C1608X8R1H473K080AA C1608X8R1H473M080AA C2012X8R2A473K125AB C2012X8R2A473M125AB C3216X8R2A473K085AA C3216X8R2A473M085AA C2012X8R2A683K125AB C2012X8R2A683M125AB C3216X8R2A683K115AA C3216X8R2A683M115AA C1608X8R1H683K080AB C1608X8R1H683M080AB C2012X8R1H683K125AA C2012X8R1H683M125AA C1608X8R1E683K080AA C1608X8R1E683M080AA C1608X8R1H104K080AB C1608X8R1H104M080AB C2012X8R1H104K125AA C2012X8R1H104M125AA C1608X8R1E104K080AA C1608X8R1E104M080AA C3216X8R2A104K115AA C3216X8R2A104M115AA C1608X8R1E154K080AB C1608X8R1E154M080AB C2012X8R1E154K085AA C2012X8R1E154M085AA C2012X8R1H154K125AB C2012X8R1H154M125AB C3216X8R1H154K085AA C3216X8R1H154M085AA C3216X8R2A154K160AA C3216X8R2A154M160AA C2012X8R1H224K125AB C2012X8R1H224M125AB C3216X8R1H224K115AA C3216X8R1H224M115AA C1608X8R1E224K080AB C1608X8R1E224M080AB C2012X8R1E224K125AA C2012X8R1E224M125AA C3216X8R2A224K160AB C3216X8R2A224M160AB C1608X8R1C334K080AB C1608X8R1C334M080AB C2012X8R1E334K125AA C2012X8R1E334M125AA C3216X8R1E334K085AA C3216X8R1E334M085AA C3216X8R2A334K160AB C3216X8R2A334M160AB C3216X8R1H334K160AA C3216X8R1H334M160AA C1608X8R1C474K080AB C1608X8R1C474M080AB C2012X8R1E474K125AB C2012X8R1E474M125AB C3216X8R1E474K085AA C3216X8R1E474M085AA C3216X8R1H474K160AA C3216X8R1H474M160AA C3225X8R2A474K200AB C3225X8R2A474M200AB Page 12   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150616 / mlcc_commercial_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X8R (-55 to +150ºC, ±15%) Capacitance Size 2012 Thickness (mm) 1.25 ± 0.20 1.15 ± 0.15 680 nF 3216 1.60 ± 0.20 3225 2.50 ± 0.30 2012 1.25 ± 0.20 3216 1.60 ± 0.20 3216 1.60 ± 0.20 3225 1.60 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 3216 1.60 ± 0.20 3225 2.50 ± 0.30 3216 1.60 ± 0.20 3225 2.50 ± 0.30 6.8 μF 3225 2.00 ± 0.20 10 μF 3225 2.50 ± 0.30 1 μF 1.5 μF 2.2 μF 3.3 μF 4.7 μF Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 100V Rated Voltage Edc: 50V Rated Voltage Edc: 25V Rated Voltage Edc: 16V C2012X8R1C684K125AB C2012X8R1C684M125AB C3216X8R1E684K115AA C3216X8R1E684M115AA C3216X8R1H684K160AB C3216X8R1H684M160AB C3225X8R2A684K250AB C3225X8R2A684M250AB C2012X8R1C105K125AB C2012X8R1C105M125AB C3216X8R1H105K160AB C3216X8R1H105M160AB C3216X8R1E105K160AA C3216X8R1E105M160AA C3216X8R1E155K160AB C3216X8R1E155M160AB C3225X8R1E155K160AA C3225X8R1E155M160AA C3216X8R1E225K160AB C3216X8R1E225M160AB C3225X8R1E225K200AA C3225X8R1E225M200AA C3216X8R1C335K160AB C3216X8R1C335M160AB C3225X8R1E335K250AA C3225X8R1E335M250AA C3216X8R1C475K160AB C3216X8R1C475M160AB C3225X8R1E475K250AB C3225X8R1E475M250AB C3225X8R1C685K200AB C3225X8R1C685M200AB C3225X8R1C106K250AB C3225X8R1C106M250AB Page 13   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150616 / mlcc_commercial_hightemp_en
C1608X8R1H473K080AA. 价格&库存
很抱歉,暂时无法提供与“C1608X8R1H473K080AA.”相匹配的价格&库存,您可以联系我们找货
