C2012X7R2A223K125AA.
    TDK(东电化)
    TDK - C2012X7R2A223K125AA. - CERAMIC CAPACITOR 0.022UF 100V, X7R, 10%, 0805, FULL REEL
C2012X7R2A223K125AA. 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS C Series Commercial Grade Mid Voltage (100 to 630V) Type: C1005 [EIA CC0402] C1608 [EIA CC0603] C2012 [EIA CC0805] C3216 [EIA CC1206] C3225 [EIA CC1210] C4532 [EIA CC1812] C5750 [EIA CC2220] Issue date: Mar 2015 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS REMINDERS Please read before using this product SAFETY REMINDERS REMINDERS 1. If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other damage, you must contact our company’s sales window. 2. We may modify products or discontinue production of a product listed in this catalog without prior notification. 3. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. 4. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export permission in harmony with this law. 5. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. 6. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. 7. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging specification detail. This new catalog number should be referenced on all catalog orders going forward, and is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will differ from the item description (internal control number) on the product label. Contact your local TDK Sales representative for more information. (Example) Catalog Issued date Catalog Number Item Description (On Delivery Label) Prior to January 2013 C1608C0G1E103J C1608C0G1E103JT000N January 2013 and Later C1608C0G1E103J080AA C1608C0G1E103JT000N Page 1 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS C Series Mid Voltage (100 to 630V) Type: C1005 [EIA CC0402], C1608 [EIA CC0603], C2012 [EIA CC0805], C3216 [EIA CC1206], C3225 [EIA CC1210], C4532 [EIA CC1812], C5750 [EIA CC2220] Features • 9ROWDJHUDWLQJRI9WR9ZLWKFDSDFLWDQFHUDQJHXSWRȝ) • High capacitance has been achieved through precision technologies that enable the use of multiple thinner ceramic dielectric layers. • Low residual inductance assures superior frequency characteristics. • Excellent DC Bias properties. • A lineup with wide-ranging rated voltages that enables selections that are suitable for needs. Applications • • • • • • Snubber in power supply Electric flash circuits in digital still camera Power factor improvement Input-output filter in power supply Driver circuit in plasma display Noise bypass Shape & Dimensions Catalog Number Construction L W T B G Body Length Body Width Body Height Terminal Width Terminal Spacing C • 3225 • X7R • 2A • 105 • K • 200 • A • A Series Name Dimensions L x W (mm) Code C1005 C1608 C2012 C3216 C3225 C4532 C5750 Length 1.00 ± 0.05 1.60 ± 0.10 2.00 ± 0.20 3.20 ± 0.20 3.20 ± 0.40 4.50 ± 0.40 5.70 ± 0.40 Width 0.50 ± 0.05 0.80 ± 0.10 1.25 ± 0.20 1.60 ± 0.20 2.50 ± 0.30 3.20 ± 0.40 5.00 ± 0.40 Terminal 0.10 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. *Dimension tolerance are typical values Temperature Characteristics Temperature Temperature Coefficient or Characteristics Capacitance Change 0±60 ppm/°C CH 0±30 ppm/°C C0G ±10% JB ±15% X5R ±22% X6S ±15% X7R ±22% X7S X7T +22/-33% Temperature Range -25 to +85°C -55 to +125°C -25 to +85°C -55 to +85°C -55 to +105°C -55 to +125°C -55 to +125°C -55 to +125°C Rated Voltage (DC) Code 2A 2E 2V 2W 2J Voltage (DC) 100V 250V 350V 450V 630V Nominal Capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. Ex. 0R2 = 0.2pF; 103 = 10,000pF; 105 = 1,000,000pF = 100nF Capacitance Tolerance Code Tolerance C D F G J K M ± 0.25pF ± 0.50pF ± 1% ± 2% ± 5% ± 10% ± 20% Nominal Thickness Code Thickness Code Thickness 050 060 080 085 115 125 0.50 mm 0.60 mm 0.80 mm 0.85 mm 1.15 mm 1.25 mm 130 160 200 230 250 280 320 1.30 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm 2.80 mm 3.20 mm Packaging Style Code A B K Style 178 mm Reel, 4 mm Pitch 178 mm Reel, 2 mm Pitch 178 mm Reel, 8 mm Pitch Special Reserved Code Code Description A, B, C TDK Internal Code Page 2 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC0402 [C1005] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), CH (0 ± 60ppm/ºC), X7S Rated Voltage: 100V (2A) Capacitance (pF) 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,500 2,200 3,300 4,700 6,800 10,000 C0G Code 101 121 151 181 221 271 331 391 471 561 681 821 102 152 222 332 472 682 103 Tolerance CH X7S 2A 2A 2A (100V) (100V) (100V) J: ± 5% K: ± 10% M: ± 20% Standard Thickness 0.50 mm Page 3 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC0603 [C1608] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), CH (0 ± 60ppm/ºC), JB ( ±10%), X5R (±15%), X7R (±15%), X7S (±22%) Rated Voltage: 250V (2E), 100V (2A) Capacitance (pF) 1 1.5 2 2.2 3 3.3 4 4.7 5 6 6.8 7 8 9 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 C0G Code 010 1R5 020 2R2 030 3R3 040 4R7 050 060 6R8 070 080 090 100 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 153 223 333 473 683 104 Tolerance CH JB X5R X7R X7S 2E 2A 2E 2A 2A 2A 2A 2A (250V) (100V) (250V) (100V) (100V) (100V) (100V) (100V) C : ± 0.25pF D : ± 0.50pF F : ± 1% G : ± 2% J : ± 5% K : ± 10% M : ± 20% Standard Thickness 0.80 mm Page 4 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC0805 [C2012] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), CH (0 ± 60ppm/ºC) Rated Voltage: 450V (2W), 250V (2E), 100V (2A) Capacitance (pF) 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 C0G Code 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 153 223 333 Tolerance CH 2W 2E 2A 2W 2E 2A (450V) (250V) (100V) (450V) (250V) (100V) J : ± 5% K : ± 10% M : ± 20% Standard Thickness 0.60 mm 0.85 mm 1.25 mm Capacitance Range Chart Temperature Characteristics: JB (±10%), X5R (±15%), X7R (±15%), X7S (±22%), X7T (+22/-33%) Rated Voltage: 450V (2W), 350V (2V), 250V (2E),100V (2A) Capacitance (pF) 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 JB Code 102 152 222 332 472 682 103 153 223 333 473 683 104 154 224 334 474 684 105 Tolerance X5R X7R X7S X7T 2E 2A 2E 2A 2E 2A 2A 2W 2V 2E (250V) (100V) (250V) (100V) (250V) (100V) (100V) (450V) (350V) (250V) J: ± 5% K: ± 10% M: ± 20% Standard Thickness 0.85 mm 1.25 mm Page 5 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC1206 [C3216] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), CH (0 ± 60ppm/ºC), JB (±10%), X5R (±15%), X7S (±22%) Rated Voltage: 630V (2J), 450V (2W), 250V (2E), 100V (2A) C0G Capacitance (pF) 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 Code Tolerance 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 335 CH JB X5R X7S 2J 2W 2E 2A 2J 2W 2E 2A 2J 2E 2A 2J 2E 2A 2A (630V) (450V) (250V) (100V) (630V) (450V) (250V) (100V) (630V) (250V) (100V) (630V) (250V) (100V) (100V) J : ± 5% K : ± 10% M : ± 20% Standard Thickness 0.60 mm 0.85 mm 1.15 mm 1.30 mm 1.60 mm Page 6 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC1206 [C3216] Capacitance Range Chart Temperature Characteristics: X7R (±15%), X7S (±22%), X7T (+22/-33%) Rated Voltage: 630V (2J), 450V (2W), 350V (2V), 250V (2E), 100V (2A) Capacitance (pF) 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 X7R Code 102 152 222 332 472 682 103 153 223 333 473 683 104 154 224 334 474 684 105 Tolerance X7T 2J 2E 2A 2J 2W 2V 2E (630V) (250V) (100V) (630V) (450V) (350V) (250V) K: ± 10% M: ± 20% Standard Thickness 0.85 mm 1.15 mm 1.30 mm 1.60 mm Page 7 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC1210 [C3225] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), CH (0 ± 60ppm/ºC), JB (±10%) Rated Voltage: 630V (2J), 450V (2W), 250V (2E), 100V (2A) Capacitance (pF) 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 C0G Code 392 472 562 682 822 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 Tolerance CH JB 2W 2A 2J 2E 2A 2J 2E 2A 2J 2W 2E (630V) (450V) (250V) (100V) (630V) (450V) (250V) (100V) (630V) (250V) (100V) J : ± 5% K : ± 10% M : ± 20% Standard Thickness 1.25 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm Capacitance Range Chart Temperature Characteristics: : X5R (±15%), X7R (±15%), X7S (±22%), X7T (+22/-33%) Rated Voltage: 630V (2J), 450V (2W), 250V (2E), 100V (2A) Capacitance (pF) 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 X5R Code 473 683 104 154 224 334 474 684 105 155 225 335 475 Tolerance X7R X7S X7T 2J 2E 2A 2J 2E 2A 2A 2J 2W 2E (630V) (250V) (100V) (630V) (250V) (100V) (100V) (630V) (450V) (250V) K: ± 10% M: ± 20% Standard Thickness 1.60 mm 2.00 mm 2.30 mm Page 8 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC1812 [C4532] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), CH (0 ± 60ppm/ºC), JB (±10%) Rated Voltage: 630V (2J), 450V (2W), 250V (2E), 100V (2A) C0G Capacitance (pF) 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 680,000 1,000,000 1,500,000 2,200,000 Code 822 103 153 223 333 473 683 104 154 224 334 684 105 155 225 Tolerance CH JB 2J 2W 2E 2A 2J 2W 2E 2A 2J 2E 2A (630V) (450V) (250V) (100V) (630V) (450V) (250V) (100V) (630V) (250V) (100V) J : ± 5% K : ± 10% M : ± 20% Standard Thickness 1.60 mm 2.00 mm 2.30 mm 2.50 mm 3.20 mm Capacitance Range Chart Temperature Characteristics: X5R (±15%), X7R (±15%), X7S (±22%), X7T(+22%/-33%) Rated Voltage: 630V (2J), 450V (2W), 250V (2E), 100V (2A) Capacitance (pF) 68,000 100,000 150,000 220,000 300,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 X5R Code 683 104 154 224 304 334 474 684 105 155 225 335 475 Tolerance X7R X7S X7T 2J 2E 2J 2E 2A 2A 2J 2W 2E (630V) (250V) (630V) (250V) (100V) (100V) (630V) (450V) (250V) K: ± 10% M: ± 20% Standard Thickness 1.60 mm 2.00 mm 2.30 mm 2.50 mm Page 9 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC2220 [C5750] Capacitance Range Chart Temperature Characteristics: C0G (0 ±30ppm/ºC), CH (0 ±60ppm/ºC) Rated Voltage: 630V (2J), 450V (2W), 250V (2E), 100V (2A) C0G Capacitance (pF) 68,000 100,000 150,000 Code 683 104 154 Tolerance CH 2J 2W 2E 2A 2J 2W 2E 2A (630V) (450V) (250V) (100V) (630V) (450V) (250V) (100V) Standard Thickness 2.30 mm K : ± 10% J : ± 5% 2.80 mm 2 Capacitance Range Chart Temperature Characteristics: JB (±10%), X5R (±15%), X6S (±22%) Rated Voltage: 630V (2J), 250V (2E), 100V (2A) Capacitance (pF) 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 JB Code 154 224 334 474 684 105 155 225 335 475 Tolerance X5R X6S 2J 2E 2A 2J 2E 2A 2W (630V) (250V) (100V) (630V) (250V) (100V) (450V) K: ± 10% M: ± 20% Standard Thickness 1.60 mm 2.30 mm 2.50 mm Capacitance Range Chart Temperature Characteristics: X7R (±15%), X7S (±22%), X7T (+22/-33%) Rated Voltage: 630V (2J), 450V (2W), 250V (2E), 100V (2A) X7R Capacitance (pF) Code 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 154 224 334 474 684 105 155 225 335 475 685 106 156 Tolerance X7S X7T 2J 2E 2A 2A 2J 2W 2E (630V) (250V) (100V) (100V) (630V) (450V) (250V) K: ± 10% M: ± 20% Standard Thickness 1.60 mm 2.00 mm 2.30 mm 2.50 mm Page 10 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to +125ºC, 0±30 ppm/ºC) Capacitance Size Thickness (mm) Capacitance Tolerance 1 pF 1.5 pF 2 pF 2.2 pF 3 pF 3.3 pF 4 pF 4.7 pF 5 pF 6 pF 6.8 pF 7 pF 8 pF 9 pF 10 pF 12 pF 15 pF 18 pF 22 pF 27 pF 33 pF 39 pF 47 pF 56 pF 68 pF 82 pF 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.60 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.60 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.60 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.60 ± 0.15 ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 10% ± 5% ± 10% ± 5% ± 2% ± 1% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% 100 pF 120 pF 150 pF 180 pF Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 450V Rated Voltage Edc: 250V C1608C0G2E101K080AA C1608C0G2E101J080AA Rated Voltage Edc: 100V C1608C0G2A010C080AA C1608C0G2A1R5C080AA C1608C0G2A020C080AA C1608C0G2A2R2C080AA C1608C0G2A030C080AA C1608C0G2A3R3C080AA C1608C0G2A040C080AA C1608C0G2A4R7C080AA C1608C0G2A050C080AA C1608C0G2A060D080AA C1608C0G2A6R8D080AA C1608C0G2A070D080AA C1608C0G2A080D080AA C1608C0G2A090D080AA C1608C0G2A100D080AA C1608C0G2A120J080AA C1608C0G2A150J080AA C1608C0G2A180J080AA C1608C0G2A220J080AA C1608C0G2A270J080AA C1608C0G2A330J080AA C1608C0G2A390J080AA C1608C0G2A470J080AA C1608C0G2A560J080AA C1608C0G2A680J080AA C1608C0G2A820J080AA C1005C0G2A101K050BA C1005C0G2A101J050BA C1608C0G2A101K080AA C1608C0G2A101J080AA C1608C0G2A101G080AA C1608C0G2A101F080AA C2012C0G2W101K060AA C2012C0G2W101J060AA C3216C0G2J101K060AA C3216C0G2J101J060AA C1608C0G2E121K080AA C1608C0G2E121J080AA C1005C0G2A121K050BA C1005C0G2A121J050BA C1608C0G2A121K080AA C1608C0G2A121J080AA C1608C0G2E151K080AA C1608C0G2E151J080AA C1005C0G2A151K050BA C1005C0G2A151J050BA C1608C0G2A151K080AA C1608C0G2A151J080AA C1608C0G2E181K080AA C1608C0G2E181J080AA C1005C0G2A181K050BA C1005C0G2A181J050BA C1608C0G2A181K080AA C1608C0G2A181J080AA C2012C0G2W121K060AA C2012C0G2W121J060AA C3216C0G2J121K060AA C3216C0G2J121J060AA C2012C0G2W151K060AA C2012C0G2W151J060AA C3216C0G2J151K060AA C3216C0G2J151J060AA C2012C0G2W181K060AA C2012C0G2W181J060AA C3216C0G2J181K060AA C3216C0G2J181J060AA Page 11 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to +125ºC, 0±30 ppm/ºC) Capacitance Size Thickness (mm) 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.60 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.60 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.60 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.60 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.85 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.85 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.85 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.85 ± 0.15 220 pF 270 pF 330 pF 390 pF 470 pF 560 pF 680 pF 820 pF Capacitance Tolerance ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 450V Rated Voltage Edc: 250V C1608C0G2E221K080AA C1608C0G2E221J080AA Rated Voltage Edc: 100V C1005C0G2A221K050BA C1005C0G2A221J050BA C1608C0G2A221K080AA C1608C0G2A221J080AA C1608C0G2E271K080AA C1608C0G2E271J080AA C1005C0G2A271K050BA C1005C0G2A271J050BA C1608C0G2A271K080AA C1608C0G2A271J080AA C1608C0G2E331K080AA C1608C0G2E331J080AA C1005C0G2A331K050BA C1005C0G2A331J050BA C1608C0G2A331K080AA C1608C0G2A331J080AA C1608C0G2E391K080AA C1608C0G2E391J080AA C1005C0G2A391K050BA C1005C0G2A391J050BA C1608C0G2A391K080AA C1608C0G2A391J080AA C1608C0G2E471K080AA C1608C0G2E471J080AA C1005C0G2A471K050BA C1005C0G2A471J050BA C1608C0G2A471K080AA C1608C0G2A471J080AA C1608C0G2E561K080AA C1608C0G2E561J080AA C1005C0G2A561K050BC C1005C0G2A561J050BC C1608C0G2A561K080AA C1608C0G2A561J080AA C1608C0G2E681K080AA C1608C0G2E681J080AA C1005C0G2A681K050BC C1005C0G2A681J050BC C1608C0G2A681K080AA C1608C0G2A681J080AA C2012C0G2W221K060AA C2012C0G2W221J060AA C3216C0G2J221K060AA C3216C0G2J221J060AA C2012C0G2W271K060AA C2012C0G2W271J060AA C3216C0G2J271K060AA C3216C0G2J271J060AA C2012C0G2W331K060AA C2012C0G2W331J060AA C3216C0G2J331K060AA C3216C0G2J331J060AA C2012C0G2W391K060AA C2012C0G2W391J060AA C3216C0G2J391K060AA C3216C0G2J391J060AA C2012C0G2W471K060AA C2012C0G2W471J060AA C3216C0G2J471K085AA C3216C0G2J471J085AA C2012C0G2W561K060AA C2012C0G2W561J060AA C3216C0G2J561K085AA C3216C0G2J561J085AA C2012C0G2W681K060AA C2012C0G2W681J060AA C3216C0G2J681K085AA C3216C0G2J681J085AA C2012C0G2W821K060AA C2012C0G2W821J060AA C1608C0G2E821K080AA C1608C0G2E821J080AA C2012C0G2E821K060AA C2012C0G2E821J060AA C1005C0G2A821K050BC C1005C0G2A821J050BC C1608C0G2A821K080AA C1608C0G2A821J080AA C3216C0G2J821K085AA C3216C0G2J821J085AA Page 12 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to +125ºC, 0±30 ppm/ºC) Capacitance Size 1005 1608 Thickness (mm) 0.50 ± 0.05 0.80 ± 0.10 1 nF 0.60 ± 0.15 2012 0.85 ± 0.15 3216 0.85 ± 0.15 1608 0.80 ± 0.10 0.60 ± 0.15 1.2 nF 2012 0.85 ± 0.15 3216 0.85 ± 0.15 1608 0.80 ± 0.10 0.60 ± 0.15 1.5 nF 2012 0.85 ± 0.15 3216 1.15 ± 0.15 1608 0.80 ± 0.10 0.85 ± 0.15 1.8 nF 2012 1.25 ± 0.20 3216 1.15 ± 0.15 0.80 ± 0.10 1608 0.80 +0.15/-0.1 2.2 nF 0.85 ± 0.15 2012 1.25 ± 0.20 2.7 nF 3216 1.15 ± 0.15 1608 0.80 +0.15/-0.1 2012 1.25 ± 0.20 3216 1.60 ± 0.20 1608 0.80 +0.15/-0.1 0.85 ± 0.15 2012 3.3 nF 1.25 ± 0.20 0.85 ± 0.15 3216 1.60 ± 0.20 Capacitance Tolerance ± 10% ± 5% ± 10% ± 5% ± 2% ± 1% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 450V Rated Voltage Edc: 250V C1608C0G2E102K080AA C1608C0G2E102J080AA C2012C0G2W102K060AA C2012C0G2W102J060AA Rated Voltage Edc: 100V C1005C0G2A102K050BC C1005C0G2A102J050BC C1608C0G2A102K080AA C1608C0G2A102J080AA C1608C0G2A102G080AA C1608C0G2A102F080AA C2012C0G2A102J060AA C2012C0G2E102K085AA C2012C0G2E102J085AA C3216C0G2J102K085AA C3216C0G2J102J085AA C1608C0G2E122K080AA C1608C0G2E122J080AA C2012C0G2W122K060AA C2012C0G2W122J060AA C1608C0G2A122K080AA C1608C0G2A122J080AA C2012C0G2A122J060AA C2012C0G2E122K085AA C2012C0G2E122J085AA C3216C0G2J122K085AA C3216C0G2J122J085AA C1608C0G2E152K080AA C1608C0G2E152J080AA C2012C0G2W152K085AA C2012C0G2W152J085AA C1608C0G2A152K080AA C1608C0G2A152J080AA C2012C0G2A152K060AA C2012C0G2A152J060AA C2012C0G2E152K085AA C2012C0G2E152J085AA C3216C0G2J152K115AA C3216C0G2J152J115AA C1608C0G2E182K080AA C1608C0G2E182J080AA C2012C0G2W182K085AA C2012C0G2W182J085AA C1608C0G2A182K080AA C1608C0G2A182J080AA C2012C0G2A182K085AA C2012C0G2A182J085AA C2012C0G2E182K125AA C2012C0G2E182J125AA C3216C0G2J182K115AA C3216C0G2J182J115AA C1608C0G2A222K080AA C1608C0G2A222J080AA C1608C0G2E222K080AA C1608C0G2E222J080AA C2012C0G2W222K085AA C2012C0G2W222J085AA C2012C0G2A222K085AA C2012C0G2A222J085AA C2012C0G2E222K125AA C2012C0G2E222J125AA C3216C0G2J222K115AA C3216C0G2J222J115AA C2012C0G2W272K125AA C2012C0G2W272J125AA C2012C0G2E272K125AA C2012C0G2E272J125AA C1608C0G2A272K080AA C1608C0G2A272J080AA C2012C0G2A272K125AA C2012C0G2A272J125AA C3216C0G2J272K160AA C3216C0G2J272J160AA C1608C0G2A332K080AA C1608C0G2A332J080AA C2012C0G2E332K085AA C2012C0G2E332J085AA C2012C0G2W332K125AA C2012C0G2W332J125AA C2012C0G2A332K125AA C2012C0G2A332J125AA C3216C0G2E332K085AA C3216C0G2E332J085AA C3216C0G2J332K160AA C3216C0G2J332J160AA Page 13 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to +125ºC, 0±30 ppm/ºC) Capacitance Size Thickness (mm) 1608 0.80 ± 0.10 2012 1.25 ± 0.20 0.60 ± 0.15 3.9 nF 3216 0.85 ± 0.15 1.15 ± 0.15 3225 1.25 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 4.7 nF 0.85 ± 0.15 3216 1.15 ± 0.15 3225 1.60 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 5.6 nF 0.85 ± 0.15 3216 1.15 ± 0.15 3225 1.60 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 1.15 ± 0.15 6.8 nF 3216 1.60 ± 0.20 3225 2.00 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 1.15 ± 0.15 8.2 nF 3216 1.60 ± 0.20 3225 1.25 ± 0.20 4532 1.60 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 10 nF 1.15 ± 0.15 3216 1.60 ± 0.20 Capacitance Tolerance ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 450V Rated Voltage Edc: 250V C2012C0G2W392K125AA C2012C0G2W392J125AA C2012C0G2E392K125AA C2012C0G2E392J125AA Rated Voltage Edc: 100V C1608C0G2A392K080AC C1608C0G2A392J080AC C2012C0G2A392K125AA C2012C0G2A392J125AA C3216C0G2A392K060AA C3216C0G2A392J060AA C3216C0G2J392K085AA C3216C0G2J392J085AA C3216C0G2E392K115AA C3216C0G2E392J115AA C3225C0G2J392K125AA C3225C0G2J392J125AA C2012C0G2W472K125AA C2012C0G2W472J125AA C2012C0G2E472K125AA C2012C0G2E472J125AA C3216C0G2J472K085AA C3216C0G2J472J085AA C1608C0G2A472K080AC C1608C0G2A472J080AC C2012C0G2A472K125AA C2012C0G2A472J125AA C3216C0G2A472K085AA C3216C0G2A472J085AA C3216C0G2E472K115AA C3216C0G2E472J115AA C3225C0G2J472K160AA C3225C0G2J472J160AA C2012C0G2W562K125AA C2012C0G2W562J125AA C3216C0G2J562K115AA C3216C0G2J562J115AA C3225C0G2J562K160AA C3225C0G2J562J160AA C2012C0G2E562K125AA C2012C0G2E562J125AA C3216C0G2E562K115AA C3216C0G2E562J115AA C2012C0G2E682K125AA C2012C0G2E682J125AA C3216C0G2J682K115AA C3216C0G2J682J115AA C1608C0G2A562K080AC C1608C0G2A562J080AC C2012C0G2A562K125AA C2012C0G2A562J125AA C3216C0G2A562K085AA C3216C0G2A562J085AA C3216C0G2W682K115AA C3216C0G2W682J115AA C1608C0G2A682K080AC C1608C0G2A682J080AC C2012C0G2A682K125AA C2012C0G2A682J125AA C3216C0G2A682K115AA C3216C0G2A682J115AA C3216C0G2E682K160AA C3216C0G2E682J160AA C3225C0G2J682K200AA C3225C0G2J682J200AA C2012C0G2E822K125AA C2012C0G2E822J125AA C3216C0G2W822K115AA C3216C0G2W822J115AA C3216C0G2J822K160AA C3216C0G2J822J160AA C3225C0G2J822K125AA C3225C0G2J822J125AA C4532C0G2J822K160KA C4532C0G2J822J160KA C3216C0G2E822K160AA C3216C0G2E822J160AA C2012C0G2E103K125AA C2012C0G2E103J125AA C3216C0G2E103K115AA C3216C0G2E103J115AA C3216C0G2J103K160AA C3216C0G2J103J160AA C1608C0G2A822K080AC C1608C0G2A822J080AC C2012C0G2A822K125AA C2012C0G2A822J125AA C3216C0G2A822K115AA C3216C0G2A822J115AA C1608C0G2A103K080AC C1608C0G2A103J080AC C2012C0G2A103K125AA C2012C0G2A103J125AA C3216C0G2A103K115AA C3216C0G2A103J115AA C3216C0G2W103K160AA C3216C0G2W103J160AA Page 14 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to +125ºC, 0±30 ppm/ºC) Capacitance Size Thickness (mm) 1.25 ± 0.20 3225 10 nF 1.60 ± 0.20 4532 1.60 ± 0.20 2012 0.85 ± 0.15 1.15 ± 0.15 3216 1.60 ± 0.20 1.60 +0.3/-0.1 15 nF 1.25 ± 0.20 3225 1.60 ± 0.20 2.00 ± 0.20 4532 2.50 ± 0.30 2012 1.25 ± 0.20 1.60 ± 0.20 3216 1.60 +0.3/-0.1 1.60 ± 0.20 22 nF 3225 2.30 ± 0.20 1.60 ± 0.20 4532 3.20 ± 0.30 2012 1.25 ± 0.20 3216 1.60 +0.3/-0.1 2.00 ± 0.20 33 nF 3225 2.30 ± 0.20 2.50 ± 0.30 4532 2.00 ± 0.20 3216 1.15 ± 0.15 2.30 ± 0.20 3225 2.50 ± 0.30 47 nF 2.00 ± 0.20 4532 2.30 ± 0.20 3.20 ± 0.30 Capacitance Tolerance ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% Catalog Number Rated Voltage Edc: 630V C3225C0G2J103K125AA C3225C0G2J103J125AA Rated Voltage Edc: 450V Rated Voltage Edc: 250V Rated Voltage Edc: 100V C3225C0G2E103K160AA C3225C0G2E103J160AA C4532C0G2J103K160KA C4532C0G2J103J160KA C2012C0G2A153K085AC C2012C0G2A153J085AC C3216C0G2A153K115AA C3216C0G2A153J115AA C3216C0G2E153K160AA C3216C0G2E153J160AA C3216C0G2W153K160AA C3216C0G2W153J160AA C3225C0G2A153K125AA C3225C0G2A153J125AA C3225C0G2J153K160AA C3225C0G2J153J160AA C3225C0G2E153K200AA C3225C0G2E153J200AA C4532C0G2J153K250KA C4532C0G2J153J250KA C2012C0G2A223K125AC C2012C0G2A223J125AC C3216C0G2A223K160AA C3216C0G2A223J160AA C3216C0G2E223K160AA C3216C0G2E223J160AA C3225C0G2E223K160AA C3225C0G2E223J160AA C3225C0G2J223K230AA C3225C0G2J223J230AA C3225C0G2A223K160AA C3225C0G2A223J160AA C3225C0G2W223K230AA C3225C0G2W223J230AA C4532C0G2E223K160KA C4532C0G2E223J160KA C4532C0G2J223K320KA C4532C0G2J223J320KA C2012C0G2A333K125AC C2012C0G2A333J125AC C3216C0G2A333K160AA C3216C0G2A333J160AA C3225C0G2A333K200AA C3225C0G2A333J200AA C3225C0G2E333K230AA C3225C0G2E333J230AA C3225C0G2J333K250AA C3225C0G2J333J250AA C4532C0G2J333K200KA C4532C0G2J333J200KA C3225C0G2W333K250AA C3225C0G2W333J250AA C4532C0G2E333K200KA C4532C0G2E333J200KA C3216C0G2A473K115AC C3216C0G2A473J115AC C3225C0G2A473K230AA C3225C0G2A473J230AA C3225C0G2E473K250AA C3225C0G2E473J250AA C4532C0G2A473K200KA C4532C0G2A473J200KA C4532C0G2W473K230KA C4532C0G2W473J230KA C4532C0G2J473K320KA C4532C0G2J473J320KA C4532C0G2E473K320KA C4532C0G2E473J320KA Page 15 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to +125ºC, 0±30 ppm/ºC) Capacitance Size Thickness (mm) 3216 1.60 ± 0.20 3225 2.30 ± 0.20 2.30 ± 0.20 68 nF 4532 2.50 ± 0.30 3.20 ± 0.30 100 nF 150 nF 5750 2.30 ± 0.20 3216 1.60 ± 0.20 4532 3.20 ± 0.30 5750 2.80 ± 0.30 5750 2.30 ± 0.20 Capacitance Tolerance ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 450V Rated Voltage Edc: 250V Rated Voltage Edc: 100V C3216C0G2A683K160AC C3216C0G2A683J160AC C3225C0G2A683K230AA C3225C0G2A683J230AA C4532C0G2E683K230KN C4532C0G2E683J230KN C4532C0G2A683K250KA C4532C0G2A683J250KA C4532C0G2W683K320KA C4532C0G2W683J320KA C5750C0G2J683K230KC C5750C0G2J683J230KC C5750C0G2J104K280KC C5750C0G2J104J280KC C4532C0G2E104K320KN C4532C0G2E104J320KN C3216C0G2A104K160AC C3216C0G2A104J160AC C4532C0G2A104K320KA C4532C0G2A104J320KA C5750C0G2E154K230KN C5750C0G2E154J230KN C5750C0G2A154K230KA C5750C0G2A154J230KA C5750C0G2W104J280KA C5750C0G2W104K280KA Page 16 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: CH (-25 to +85ºC, 0±60 ppm/ºC) Capacitance Size Thickness (mm) Capacitance Tolerance 1 pF 1.5 pF 2 pF 2.2 pF 3 pF 3.3 pF 4 pF 4.7 pF 5 pF 6 pF 6.8 pF 7 pF 8 pF 9 pF 10 pF 12 pF 15 pF 18 pF 22 pF 27 pF 33 pF 39 pF 47 pF 56 pF 68 pF 82 pF 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.60 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.60 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.60 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.60 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% 100 pF 120 pF 150 pF 180 pF 220 pF Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 450V Rated Voltage Edc: 250V C1608CH2E101K080AA C1608CH2E101J080AA Rated Voltage Edc: 100V C1608CH2A010C080AA C1608CH2A1R5C080AA C1608CH2A020C080AA C1608CH2A2R2C080AA C1608CH2A030C080AA C1608CH2A3R3C080AA C1608CH2A040C080AA C1608CH2A4R7C080AA C1608CH2A050C080AA C1608CH2A060D080AA C1608CH2A6R8D080AA C1608CH2A070D080AA C1608CH2A080D080AA C1608CH2A090D080AA C1608CH2A100D080AA C1608CH2A120J080AA C1608CH2A150J080AA C1608CH2A180J080AA C1608CH2A220J080AA C1608CH2A270J080AA C1608CH2A330J080AA C1608CH2A390J080AA C1608CH2A470J080AA C1608CH2A560J080AA C1608CH2A680J080AA C1608CH2A820J080AA C1005CH2A101K050BA C1005CH2A101J050BA C1608CH2A101K080AA C1608CH2A101J080AA C1608CH2E121K080AA C1608CH2E121J080AA C1005CH2A121K050BA C1005CH2A121J050BA C1608CH2A121K080AA C1608CH2A121J080AA C1608CH2E151K080AA C1608CH2E151J080AA C1005CH2A151K050BA C1005CH2A151J050BA C1608CH2A151K080AA C1608CH2A151J080AA C1608CH2E181K080AA C1608CH2E181J080AA C1005CH2A181K050BA C1005CH2A181J050BA C1608CH2A181K080AA C1608CH2A181J080AA C1608CH2E221K080AA C1608CH2E221J080AA C1005CH2A221K050BA C1005CH2A221J050BA C1608CH2A221K080AA C1608CH2A221J080AA C2012CH2W101K060AA C2012CH2W101J060AA C3216CH2J101K060AA C3216CH2J101J060AA C2012CH2W121K060AA C2012CH2W121J060AA C3216CH2J121K060AA C3216CH2J121J060AA C2012CH2W151K060AA C2012CH2W151J060AA C3216CH2J151K060AA C3216CH2J151J060AA C2012CH2W181K060AA C2012CH2W181J060AA C3216CH2J181K060AA C3216CH2J181J060AA Page 17 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: CH (-25 to +85ºC, 0±60 ppm/ºC) Capacitance Size Thickness (mm) 2012 0.60 ± 0.15 3216 0.60 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.60 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.60 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.60 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.85 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.85 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.85 ± 0.15 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 0.60 ± 0.15 3216 0.85 ± 0.15 220 pF 270 pF 330 pF 390 pF 470 pF 560 pF 680 pF 820 pF Capacitance Tolerance ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 450V C2012CH2W221K060AA C2012CH2W221J060AA Rated Voltage Edc: 250V Rated Voltage Edc: 100V C1608CH2E271K080AA C1608CH2E271J080AA C1005CH2A271K050BA C1005CH2A271J050BA C1608CH2A271K080AA C1608CH2A271J080AA C1608CH2E331K080AA C1608CH2E331J080AA C1005CH2A331K050BA C1005CH2A331J050BA C1608CH2A331K080AA C1608CH2A331J080AA C1608CH2E391K080AA C1608CH2E391J080AA C1005CH2A391K050BA C1005CH2A391J050BA C1608CH2A391K080AA C1608CH2A391J080AA C1608CH2E471K080AA C1608CH2E471J080AA C1005CH2A471K050BA C1005CH2A471J050BA C1608CH2A471K080AA C1608CH2A471J080AA C1608CH2E561K080AA C1608CH2E561J080AA C1005CH2A561K050BC C1005CH2A561J050BC C1608CH2A561K080AA C1608CH2A561J080AA C1608CH2E681K080AA C1608CH2E681J080AA C1005CH2A681K050BC C1005CH2A681J050BC C1608CH2A681K080AA C1608CH2A681J080AA C3216CH2J221K060AA C3216CH2J221J060AA C2012CH2W271K060AA C2012CH2W271J060AA C3216CH2J271K060AA C3216CH2J271J060AA C2012CH2W331K060AA C2012CH2W331J060AA C3216CH2J331K060AA C3216CH2J331J060AA C2012CH2W391K060AA C2012CH2W391J060AA C3216CH2J391K060AA C3216CH2J391J060AA C2012CH2W471K060AA C2012CH2W471J060AA C3216CH2J471K085AA C3216CH2J471J085AA C2012CH2W561K060AA C2012CH2W561J060AA C3216CH2J561K085AA C3216CH2J561J085AA C2012CH2W681K060AA C2012CH2W681J060AA C3216CH2J681K085AA C3216CH2J681J085AA C2012CH2W821K060AA C2012CH2W821J060AA C1608CH2E821K080AA C1608CH2E821J080AA C2012CH2E821K060AA C2012CH2E821J060AA C1005CH2A821K050BC C1005CH2A821J050BC C1608CH2A821K080AA C1608CH2A821J080AA C3216CH2J821K085AA C3216CH2J821J085AA Page 18 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: CH (-25 to +85ºC, 0±60 ppm/ºC) Capacitance Size Thickness (mm) 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1 nF 0.60 ± 0.15 2012 0.85 ± 0.15 3216 0.85 ± 0.15 1608 0.80 ± 0.10 0.60 ± 0.15 1.2 nF 2012 0.85 ± 0.15 3216 0.85 ± 0.15 1608 0.80 ± 0.10 0.60 ± 0.15 1.5 nF 2012 0.85 ± 0.15 3216 1.15 ± 0.15 1608 0.80 ± 0.10 0.85 ± 0.15 1.8 nF 2012 1.25 ± 0.20 3216 1.15 ± 0.15 0.80 ± 0.10 1608 0.80 +0.15/-0.1 2.2 nF 0.85 ± 0.15 2012 1.25 ± 0.20 2.7 nF 3216 1.15 ± 0.15 1608 0.80 +0.15/-0.1 2012 1.25 ± 0.20 3216 1.60 ± 0.20 1608 0.80 +0.15/-0.1 0.85 ± 0.15 2012 3.3 nF 1.25 ± 0.20 0.85 ± 0.15 3216 1.60 ± 0.20 Capacitance Tolerance ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 450V Rated Voltage Edc: 250V C1608CH2E102K080AA C1608CH2E102J080AA C2012CH2W102K060AA C2012CH2W102J060AA Rated Voltage Edc: 100V C1005CH2A102K050BC C1005CH2A102J050BC C1608CH2A102K080AA C1608CH2A102J080AA C2012CH2A102J060AA C2012CH2E102K085AA C2012CH2E102J085AA C3216CH2J102K085AA C3216CH2J102J085AA C1608CH2E122K080AA C1608CH2E122J080AA C2012CH2W122K060AA C2012CH2W122J060AA C1608CH2A122K080AA C1608CH2A122J080AA C2012CH2A122J060AA C2012CH2E122K085AA C2012CH2E122J085AA C3216CH2J122K085AA C3216CH2J122J085AA C1608CH2E152K080AA C1608CH2E152J080AA C2012CH2W152K085AA C2012CH2W152J085AA C1608CH2A152K080AA C1608CH2A152J080AA C2012CH2A152K060AA C2012CH2A152J060AA C2012CH2E152K085AA C2012CH2E152J085AA C3216CH2J152K115AA C3216CH2J152J115AA C1608CH2E182K080AA C1608CH2E182J080AA C2012CH2W182K085AA C2012CH2W182J085AA C1608CH2A182K080AA C1608CH2A182J080AA C2012CH2A182K085AA C2012CH2A182J085AA C2012CH2E182K125AA C2012CH2E182J125AA C3216CH2J182K115AA C3216CH2J182J115AA C1608CH2A222K080AA C1608CH2A222J080AA C1608CH2E222K080AA C1608CH2E222J080AA C2012CH2W222K085AA C2012CH2W222J085AA C2012CH2A222K085AA C2012CH2A222J085AA C2012CH2E222K125AA C2012CH2E222J125AA C3216CH2J222K115AA C3216CH2J222J115AA C2012CH2W272K125AA C2012CH2W272J125AA C2012CH2E272K125AA C2012CH2E272J125AA C1608CH2A272K080AA C1608CH2A272J080AA C2012CH2A272K125AA C2012CH2A272J125AA C3216CH2J272K160AA C3216CH2J272J160AA C1608CH2A332K080AA C1608CH2A332J080AA C2012CH2E332K085AA C2012CH2E332J085AA C2012CH2W332K125AA C2012CH2W332J125AA C2012CH2A332K125AA C2012CH2A332J125AA C3216CH2E332K085AA C3216CH2E332J085AA C3216CH2J332K160AA C3216CH2J332J160AA Page 19 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: CH (-25 to +85ºC, 0±60 ppm/ºC) Capacitance Size Thickness (mm) 1608 0.80 ± 0.10 2012 1.25 ± 0.20 0.60 ± 0.15 3.9 nF 3216 0.85 ± 0.15 1.15 ± 0.15 3225 1.25 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 4.7 nF 0.85 ± 0.15 3216 1.15 ± 0.15 3225 1.60 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 5.6 nF 0.85 ± 0.15 3216 1.15 ± 0.15 3225 1.60 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 1.15 ± 0.15 6.8 nF 3216 1.60 ± 0.20 3225 2.00 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 1.15 ± 0.15 8.2 nF 3216 1.60 ± 0.20 3225 1.25 ± 0.20 4532 1.60 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 10 nF 1.15 ± 0.15 3216 1.60 ± 0.20 Capacitance Tolerance ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 450V Rated Voltage Edc: 250V C2012CH2W392K125AA C2012CH2W392J125AA C2012CH2E392K125AA C2012CH2E392J125AA Rated Voltage Edc: 100V C1608CH2A392K080AC C1608CH2A392J080AC C2012CH2A392K125AA C2012CH2A392J125AA C3216CH2A392K060AA C3216CH2A392J060AA C3216CH2J392K085AA C3216CH2J392J085AA C3216CH2E392K115AA C3216CH2E392J115AA C3225CH2J392K125AA C3225CH2J392J125AA C2012CH2W472K125AA C2012CH2W472J125AA C2012CH2E472K125AA C2012CH2E472J125AA C3216CH2J472K085AA C3216CH2J472J085AA C1608CH2A472K080AC C1608CH2A472J080AC C2012CH2A472K125AA C2012CH2A472J125AA C3216CH2A472K085AA C3216CH2A472J085AA C3216CH2E472K115AA C3216CH2E472J115AA C3225CH2J472K160AA C3225CH2J472J160AA C2012CH2W562K125AA C2012CH2W562J125AA C3216CH2J562K115AA C3216CH2J562J115AA C3225CH2J562K160AA C3225CH2J562J160AA C2012CH2E562K125AA C2012CH2E562J125AA C3216CH2E562K115AA C3216CH2E562J115AA C2012CH2E682K125AA C2012CH2E682J125AA C3216CH2J682K115AA C3216CH2J682J115AA C1608CH2A562K080AC C1608CH2A562J080AC C2012CH2A562K125AA C2012CH2A562J125AA C3216CH2A562K085AA C3216CH2A562J085AA C3216CH2W682K115AA C3216CH2W682J115AA C1608CH2A682K080AC C1608CH2A682J080AC C2012CH2A682K125AA C2012CH2A682J125AA C3216CH2A682K115AA C3216CH2A682J115AA C3216CH2E682K160AA C3216CH2E682J160AA C3225CH2J682K200AA C3225CH2J682J200AA C2012CH2E822K125AA C2012CH2E822J125AA C3216CH2W822K115AA C3216CH2W822J115AA C3216CH2J822K160AA C3216CH2J822J160AA C3225CH2J822K125AA C3225CH2J822J125AA C4532CH2J822K160KA C4532CH2J822J160KA C3216CH2E822K160AA C3216CH2E822J160AA C2012CH2E103K125AA C2012CH2E103J125AA C3216CH2E103K115AA C3216CH2E103J115AA C3216CH2J103K160AA C3216CH2J103J160AA C1608CH2A822K080AC C1608CH2A822J080AC C2012CH2A822K125AA C2012CH2A822J125AA C3216CH2A822K115AA C3216CH2A822J115AA C1608CH2A103K080AC C1608CH2A103J080AC C2012CH2A103K125AA C2012CH2A103J125AA C3216CH2A103K115AA C3216CH2A103J115AA C3216CH2W103K160AA C3216CH2W103J160AA Page 20 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: CH (-25 to +85ºC, 0±60 ppm/ºC) Capacitance Size Thickness (mm) 1.25 ± 0.20 3225 10 nF 1.60 ± 0.20 4532 1.60 ± 0.20 2012 0.85 ± 0.15 1.15 ± 0.15 3216 1.60 ± 0.20 1.60 +0.3/-0.1 15 nF 1.25 ± 0.20 3225 1.60 ± 0.20 2.00 ± 0.20 4532 2.50 ± 0.30 2012 1.25 ± 0.20 1.60 ± 0.20 3216 1.60 +0.3/-0.1 1.60 ± 0.20 22 nF 3225 2.30 ± 0.20 1.60 ± 0.20 4532 3.20 ± 0.30 2012 1.25 ± 0.20 3216 1.60 +0.3/-0.1 2.00 ± 0.20 33 nF 3225 2.30 ± 0.20 2.50 ± 0.30 4532 2.00 ± 0.20 3216 1.15 ± 0.15 2.30 ± 0.20 3225 2.50 ± 0.30 47 nF 2.00 ± 0.20 4532 2.30 ± 0.20 3.20 ± 0.30 Capacitance Tolerance ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% Catalog Number Rated Voltage Edc: 630V C3225CH2J103K125AA C3225CH2J103J125AA Rated Voltage Edc: 450V Rated Voltage Edc: 250V Rated Voltage Edc: 100V C3225CH2E103K160AA C3225CH2E103J160AA C4532CH2J103K160KA C4532CH2J103J160KA C2012CH2A153K085AC C2012CH2A153J085AC C3216CH2A153K115AA C3216CH2A153J115AA C3216CH2E153K160AA C3216CH2E153J160AA C3216CH2W153K160AA C3216CH2W153J160AA C3225CH2A153K125AA C3225CH2A153J125AA C3225CH2J153K160AA C3225CH2J153J160AA C3225CH2E153K200AA C3225CH2E153J200AA C4532CH2J153K250KA C4532CH2J153J250KA C2012CH2A223K125AC C2012CH2A223J125AC C3216CH2A223K160AA C3216CH2A223J160AA C3216CH2E223K160AA C3216CH2E223J160AA C3225CH2E223K160AA C3225CH2E223J160AA C3225CH2J223K230AA C3225CH2J223J230AA C3225CH2A223K160AA C3225CH2A223J160AA C3225CH2W223K230AA C3225CH2W223J230AA C4532CH2E223K160KA C4532CH2E223J160KA C4532CH2J223K320KA C4532CH2J223J320KA C2012CH2A333K125AC C2012CH2A333J125AC C3216CH2A333K160AA C3216CH2A333J160AA C3225CH2A333K200AA C3225CH2A333J200AA C3225CH2E333K230AA C3225CH2E333J230AA C3225CH2J333K250AA C3225CH2J333J250AA C3225CH2W333K250AA C3225CH2W333J250AA C4532CH2E333K200KA C4532CH2E333J200KA C3216CH2A473K115AC C3216CH2A473J115AC C3225CH2A473K230AA C3225CH2A473J230AA C3225CH2E473K250AA C3225CH2E473J250AA C4532CH2A473K200KA C4532CH2A473J200KA C4532CH2W473K230KA C4532CH2W473J230KA C4532CH2J473K320KA C4532CH2J473J320KA C4532CH2E473K320KA C4532CH2E473J320KA Page 21 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: CH (-25 to +85ºC, 0±60 ppm/ºC) Capacitance Size Thickness (mm) 3216 1.60 ± 0.20 3225 2.30 ± 0.20 2.30 ± 0.20 68 nF 4532 2.50 ± 0.30 3.20 ± 0.30 100 nF 150 nF 5750 2.30 ± 0.20 3216 1.60 ± 0.20 4532 3.20 ± 0.30 5750 2.80 ±0.30 5750 2.30 ± 0.20 Capacitance Tolerance ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% ± 10% ± 5% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 450V Rated Voltage Edc: 250V Rated Voltage Edc: 100V C3216CH2A683K160AC C3216CH2A683J160AC C3225CH2A683K230AA C3225CH2A683J230AA C4532CH2E683K230KN C4532CH2E683J230KN C4532CH2A683K250KA C4532CH2A683J250KA C4532CH2W683K320KA C4532CH2W683J320KA C5750CH2J683K230KC C5750CH2J683J230KC C5750CH2J104K280KC C5750CH2J104J280KC C4532CH2E104K320KN C4532CH2E104J320KN C3216CH2A104K160AC C3216CH2A104J160AC C4532CH2A104K320KA C4532CH2A104J320KA C5750CH2E154K230KN C5750CH2E154J230KN C5750CH2A154K230KA C5750CH2A154J230KA C5750CH2W104J280KA C5750CH2W104K280KA Class 2 (Temperature Stable) Temperature Characteristics: JB (-25 to +85ºC, ±10%) Capacitance 1 nF 1.5 nF 2.2 nF 3.3 nF 4.7 nF Size Thickness (mm) 1608 0.80 ± 0.10 2012 0.85 ± 0.15 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 0.85 ± 0.15 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 0.85 ± 0.15 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 0.85 ± 0.15 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 0.85 ± 0.15 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 0.85 ± 0.15 6.8 nF Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 250V C2012JB2E102K085AA C2012JB2E102M085AA Rated Voltage Edc: 100V C1608JB2A102K080AA C1608JB2A102M080AA C2012JB2A102K085AA C2012JB2A102M085AA C2012JB2E152K085AA C2012JB2E152M085AA C1608JB2A152K080AA C1608JB2A152M080AA C2012JB2A152K085AA C2012JB2A152M085AA C2012JB2E222K085AA C2012JB2E222M085AA C1608JB2A222K080AA C1608JB2A222M080AA C2012JB2A222K085AA C2012JB2A222M085AA C2012JB2E332K085AA C2012JB2E332M085AA C1608JB2A332K080AA C1608JB2A332M080AA C2012JB2A332K085AA C2012JB2A332M085AA C2012JB2E472K085AA C2012JB2E472M085AA C1608JB2A472K080AA C1608JB2A472M080AA C2012JB2A472K085AA C2012JB2A472M085AA C3216JB2J102K115AA C3216JB2J102M115AA C3216JB2J152K115AA C3216JB2J152M115AA C3216JB2J222K115AA C3216JB2J222M115AA C3216JB2J332K115AA C3216JB2J332M115AA C3216JB2J472K115AA C3216JB2J472M115AA C1608JB2A682K080AA C1608JB2A682M080AA C2012JB2A682K085AA C2012JB2A682M085AA Page 22 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: JB (-25 to +85ºC, ±10%) Capacitance Size Thickness (mm) 2012 1.25 ± 0.20 3216 1.15 ± 0.15 1608 0.80 ± 0.10 6.8 nF 0.85 ± 0.15 10 nF 2012 1.25 ± 0.20 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 1.25 ± 0.20 15 nF 1.15 ± 0.15 3216 1.30 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 22 nF 1.15 ± 0.15 3216 1.30 ± 0.20 2012 33 nF 1.25 ± 0.20 1.15 ± 0.15 3216 1.60 ± 0.20 2012 1.25 ± 0.20 1.15 ± 0.15 47 nF 3216 1.60 ± 0.20 3225 2.00 ± 0.20 2012 0.85 ± 0.15 3216 1.60 ± 0.20 3225 2.00 ± 0.20 4532 1.60 ± 0.20 2012 1.25 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 4532 2.30 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 68 nF 100 nF 150 nF Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 250V C2012JB2E682K125AA C2012JB2E682M125AA Rated Voltage Edc: 100V C3216JB2J682K115AA C3216JB2J682M115AA C1608JB2A103K080AA C1608JB2A103M080AA C2012JB2A103K085AA C2012JB2A103M085AA C2012JB2E103K125AA C2012JB2E103M125AA C3216JB2J103K115AA C3216JB2J103M115AA C2012JB2E153K125AA C2012JB2E153M125AA C3216JB2E153K115AA C3216JB2E153M115AA C1608JB2A153K080AA C1608JB2A153M080AA C2012JB2A153K125AA C2012JB2A153M125AA C3216JB2J153K130AA C3216JB2J153M130AA C2012JB2E223K125AA C2012JB2E223M125AA C3216JB2E223K115AA C3216JB2E223M115AA C1608JB2A223K080AA C1608JB2A223M080AA C2012JB2A223K125AA C2012JB2A223M125AA C3216JB2J223K130AA C3216JB2J223M130AA C2012JB2A333K125AA C2012JB2A333M125AA C3216JB2A333K115AA C3216JB2A333M115AA C3216JB2J333K160AA C3216JB2J333M160AA C3216JB2E333K160AA C3216JB2E333M160AA C2012JB2A473K125AA C2012JB2A473M125AA C3216JB2A473K115AA C3216JB2A473M115AA C3216JB2E473K160AA C3216JB2E473M160AA C3225JB2J473K200AA C3225JB2J473M200AA C3216JB2E683K160AA C3216JB2E683M160AA C2012JB2A683K085AA C2012JB2A683M085AA C3216JB2A683K160AA C3216JB2A683M160AA C3225JB2J683K200AA C3225JB2J683M200AA C4532JB2J683K160KA C4532JB2J683M160KA C3216JB2E104K160AA C3216JB2E104M160AA C3225JB2E104K200AA C3225JB2E104M200AA C2012JB2A104K125AA C2012JB2A104M125AA C3216JB2A104K160AA C3216JB2A104M160AA C4532JB2J104K230KA C4532JB2J104M230KA C3216JB2A154K160AA C3216JB2A154M160AA C3225JB2E154K200AA C3225JB2E154M200AA Page 23 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: JB (-25 to +85ºC, ±10%) Capacitance Size Thickness (mm) 4532 1.60 ± 0.20 5750 1.60 ± 0.20 3216 1.15 ± 0.15 3225 2.00 ± 0.20 4532 2.30 ± 0.20 5750 2.30 ± 0.20 3216 1.30 ± 0.20 3225 2.00 ± 0.20 4532 2.30 ± 0.20 5750 1.60 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 4532 2.30 ± 0.20 5750 2.30 ± 0.20 3216 1.60 ± 0.20 3225 1.60 ± 0.20 4532 2.30 ± 0.20 150 nF 220 nF 330 nF 470 nF 680 nF 1.60 ± 0.20 5750 2.30 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 4532 2.30 ± 0.20 5750 2.30 ± 0.20 3225 2.00 ± 0.20 4532 2.30 ± 0.20 5750 2.30 ± 0.20 3225 2.30 ± 0.20 4532 2.30 ± 0.20 5750 2.30 ± 0.20 3.3 μF 5750 2.30 ± 0.20 4.7 μF 5750 2.30 ± 0.20 1 μF 1.5 μF 2.2 μF Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 250V C4532JB2E154K160KA C4532JB2E154M160KA Rated Voltage Edc: 100V C5750JB2J154K160KA C5750JB2J154M160KA C3216JB2A224K115AA C3216JB2A224M115AA C3225JB2E224K200AA C3225JB2E224M200AA C4532JB2E224K230KA C4532JB2E224M230KA C5750JB2J224K230KA C5750JB2J224M230KA C3216JB2A334K130AA C3216JB2A334M130AA C3225JB2A334K200AA C3225JB2A334M200AA C4532JB2E334K230KA C4532JB2E334M230KA C5750JB2E334K160KA C5750JB2E334M160KA C3216JB2A474K160AA C3216JB2A474M160AA C3225JB2A474K200AA C3225JB2A474M200AA C4532JB2E474K230KA C4532JB2E474M230KA C5750JB2E474K230KA C5750JB2E474M230KA C3216JB2A684K160AA C3216JB2A684M160AA C3225JB2A684K160AA C3225JB2A684M160AA C4532JB2A684K230KA C4532JB2A684M230KA C5750JB2A684K160KA C5750JB2A684M160KA C5750JB2E684K230KA C5750JB2E684M230KA C5750JB2E105K230KA C5750JB2E105M230KA C3216JB2A105K160AA C3216JB2A105M160AA C3225JB2A105K200AA C3225JB2A105M200AA C4532JB2A105K230KA C4532JB2A105M230KA C5750JB2A105K230KA C5750JB2A105M230KA C3225JB2A155K200AB C3225JB2A155M200AB C4532JB2A155K230KA C4532JB2A155M230KA C5750JB2A155K230KA C5750JB2A155M230KA C3225JB2A225K230AB C3225JB2A225M230AB C4532JB2A225K230KA C4532JB2A225M230KA C5750JB2A225K230KA C5750JB2A225M230KA C5750JB2A335K230KA C5750JB2A335M230KA C5750JB2A475K230KA C5750JB2A475M230KA Page 24 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X5R (-55 to +85ºC, ±15%) Capacitance 1 nF 1.5 nF 2.2 nF 3.3 nF 4.7 nF 6.8 nF 10 nF 15 nF 22 nF Size Thickness (mm) 1608 0.80 ± 0.10 2012 0.85 ± 0.15 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 0.85 ± 0.15 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 0.85 ± 0.15 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 0.85 ± 0.15 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 0.85 ± 0.15 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 1.30 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 1.30 ± 0.20 2012 1.25 ± 0.20 3216 1.60 ± 0.20 33 nF Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 250V Rated Voltage Edc: 100V C1608X5R2A102K080AA C1608X5R2A102M080AA C2012X5R2E102K085AA C2012X5R2E102M085AA C3216X5R2J102K115AA C3216X5R2J102M115AA C1608X5R2A152K080AA C1608X5R2A152M080AA C2012X5R2E152K085AA C2012X5R2E152M085AA C3216X5R2J152K115AA C3216X5R2J152M115AA C1608X5R2A222K080AA C1608X5R2A222M080AA C2012X5R2E222K085AA C2012X5R2E222M085AA C3216X5R2J222K115AA C3216X5R2J222M115AA C1608X5R2A332K080AA C1608X5R2A332M080AA C2012X5R2E332K085AA C2012X5R2E332M085AA C3216X5R2J332K115AA C3216X5R2J332M115AA C1608X5R2A472K080AA C1608X5R2A472M080AA C2012X5R2E472K085AA C2012X5R2E472M085AA C3216X5R2J472K115AA C3216X5R2J472M115AA C1608X5R2A682K080AA C1608X5R2A682M080AA C2012X5R2E682K125AA C2012X5R2E682M125AA C3216X5R2J682K115AA C3216X5R2J682M115AA C1608X5R2A103K080AA C1608X5R2A103M080AA C2012X5R2E103K125AA C2012X5R2E103M125AA C3216X5R2J103K115AA C3216X5R2J103M115AA C1608X5R2A153K080AA C1608X5R2A153M080AA C2012X5R2E153K125AA C2012X5R2E153M125AA C3216X5R2J153K130AA C3216X5R2J153M130AA C1608X5R2A223K080AA C1608X5R2A223M080AA C2012X5R2E223K125AA C2012X5R2E223M125AA C3216X5R2J223K130AA C3216X5R2J223M130AA C2012X5R2A333K125AA C2012X5R2A333M125AA C3216X5R2J333K160AA C3216X5R2J333M160AA C3216X5R2E333K160AA C3216X5R2E333M160AA Page 25 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X5R (-55 to +85ºC, ±15%) Capacitance Size Thickness (mm) 2012 1.25 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 2012 0.85 ± 0.15 3216 1.60 ± 0.20 3225 2.00 ± 0.20 2012 1.25 ± 0.20 3216 1.60 ± 0.20 4532 2.30 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 5750 1.60 ± 0.20 3216 1.15 ± 0.15 3225 2.00 ± 0.20 5750 2.30 ± 0.20 3216 1.30 ± 0.20 4532 2.30 ± 0.20 3216 1.60 ± 0.20 4532 2.30 ± 0.20 3216 1.60 ± 0.20 5750 2.30 ± 0.20 3216 1.60 ± 0.20 5750 2.30 ± 0.20 1.5 μF 3225 2.00 ± 0.20 2.2 μF 3225 2.30 ± 0.20 3.3 μF 5750 2.30 ± 0.20 4.7 μF 5750 2.30 ± 0.20 47 nF 68 nF 100 nF 150 nF 220 nF 330 nF 470 nF 680 nF 1 μF Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 250V Rated Voltage Edc: 100V C2012X5R2A473K125AA C2012X5R2A473M125AA C3216X5R2E473K160AA C3216X5R2E473M160AA C3225X5R2J473K200AA C3225X5R2J473M200AA C2012X5R2A683K085AA C2012X5R2A683M085AA C3216X5R2E683K160AA C3216X5R2E683M160AA C3225X5R2J683K200AA C3225X5R2J683M200AA C2012X5R2A104K125AA C2012X5R2A104M125AA C3216X5R2E104K160AA C3216X5R2E104M160AA C4532X5R2J104K230KA C4532X5R2J104M230KA C3216X5R2A154K160AA C3216X5R2A154M160AA C3225X5R2E154K200AA C3225X5R2E154M200AA C5750X5R2J154K160KA C5750X5R2J154M160KA C3216X5R2A224K115AA C3216X5R2A224M115AA C3225X5R2E224K200AA C3225X5R2E224M200AA C5750X5R2J224K230KA C5750X5R2J224M230KA C3216X5R2A334K130AA C3216X5R2A334M130AA C4532X5R2E334K230KA C4532X5R2E334M230KA C3216X5R2A474K160AA C3216X5R2A474M160AA C4532X5R2E474K230KA C4532X5R2E474M230KA C3216X5R2A684K160AA C3216X5R2A684M160AA C5750X5R2E684K230KA C5750X5R2E684M230KA C3216X5R2A105K160AA C3216X5R2A105M160AA C5750X5R2E105K230KA C5750X5R2E105M230KA C3225X5R2A155K200AB C3225X5R2A155M200AB C3225X5R2A225K230AB C3225X5R2A225M230AB C5750X5R2A335K230KA C5750X5R2A335M230KA C5750X5R2A475K230KA C5750X5R2A475M230KA Page 26 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X6S (-55 to +105ºC, ±22%) Capacitance Size Thickness (mm) 1 μF 5750 2.50 ± 0.30 2.2 μF 5750 2.50 ± 0.30 Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 450V C5750X6S2W105K250KA C5750X6S2W105M250KA C5750X6S2W225K250KA C5750X6S2W225M250KA Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) Capacitance 1 nF 1.5 nF 2.2 nF 3.3 nF 4.7 nF Size Thickness (mm) 1608 0.80 ± 0.10 2012 0.85 ± 0.15 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 0.85 ± 0.15 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 0.85 ± 0.15 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 0.85 ± 0.15 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 0.85 ± 0.15 3216 1.15 ± 0.15 1608 0.80 ± 0.10 0.85 ± 0.15 6.8 nF 2012 1.25 ± 0.20 3216 1.15 ± 0.15 1608 0.80 ± 0.10 0.85 ± 0.15 10 nF 2012 1.25 ± 0.20 3216 1.15 ± 0.15 Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 250V C2012X7R2E102K085AA C2012X7R2E102M085AA Rated Voltage Edc: 100V C1608X7R2A102K080AA C1608X7R2A102M080AA C2012X7R2A102K085AA C2012X7R2A102M085AA C2012X7R2E152K085AA C2012X7R2E152M085AA C1608X7R2A152K080AA C1608X7R2A152M080AA C2012X7R2A152K085AA C2012X7R2A152M085AA C2012X7R2E222K085AA C2012X7R2E222M085AA C1608X7R2A222K080AA C1608X7R2A222M080AA C2012X7R2A222K085AA C2012X7R2A222M085AA C2012X7R2E332K085AA C2012X7R2E332M085AA C1608X7R2A332K080AA C1608X7R2A332M080AA C2012X7R2A332K085AA C2012X7R2A332M085AA C2012X7R2E472K085AA C2012X7R2E472M085AA C1608X7R2A472K080AA C1608X7R2A472M080AA C2012X7R2A472K085AA C2012X7R2A472M085AA C3216X7R2J102K115AA C3216X7R2J102M115AA C3216X7R2J152K115AA C3216X7R2J152M115AA C3216X7R2J222K115AA C3216X7R2J222M115AA C3216X7R2J332K115AA C3216X7R2J332M115AA C3216X7R2J472K115AA C3216X7R2J472M115AA C1608X7R2A682K080AA C1608X7R2A682M080AA C2012X7R2A682K085AA C2012X7R2A682M085AA C2012X7R2E682K125AA C2012X7R2E682M125AA C3216X7R2J682K115AA C3216X7R2J682M115AA C1608X7R2A103K080AA C1608X7R2A103M080AA C2012X7R2A103K085AA C2012X7R2A103M085AA C2012X7R2E103K125AA C2012X7R2E103M125AA C3216X7R2J103K115AA C3216X7R2J103M115AA Page 27 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) Capacitance Size Thickness (mm) 1608 0.80 ± 0.10 2012 1.25 ± 0.20 15 nF 1.15 ± 0.15 3216 1.30 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 22 nF 1.15 ± 0.15 3216 1.30 ± 0.20 2012 1.25 ± 0.20 1.15 ± 0.15 33 nF 3216 1.60 ± 0.20 2012 1.25 ± 0.20 1.15 ± 0.15 47 nF 3216 1.60 ± 0.20 3225 2.00 ± 0.20 2012 0.85 ± 0.15 3216 1.60 ± 0.20 3225 2.00 ± 0.20 4532 1.60 ± 0.20 2012 1.25 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 4532 2.30 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 4532 1.60 ± 0.20 5750 1.60 ± 0.20 3216 1.15 ± 0.15 3225 2.00 ± 0.20 68 nF 100 nF 150 nF 220 nF Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 250V C2012X7R2E153K125AA C2012X7R2E153M125AA C3216X7R2E153K115AA C3216X7R2E153M115AA Rated Voltage Edc: 100V C1608X7R2A153K080AA C1608X7R2A153M080AA C2012X7R2A153K125AA C2012X7R2A153M125AA C3216X7R2J153K130AA C3216X7R2J153M130AA C2012X7R2E223K125AA C2012X7R2E223M125AA C3216X7R2E223K115AA C3216X7R2E223M115AA C1608X7R2A223K080AA C1608X7R2A223M080AA C2012X7R2A223K125AA C2012X7R2A223M125AA C3216X7R2J223K130AA C3216X7R2J223M130AA C2012X7R2A333K125AA C2012X7R2A333M125AA C3216X7R2A333K115AA C3216X7R2A333M115AA C3216X7R2J333K160AA C3216X7R2J333M160AA C3216X7R2E333K160AA C3216X7R2E333M160AA C2012X7R2A473K125AA C2012X7R2A473M125AA C3216X7R2A473K115AA C3216X7R2A473M115AA C3216X7R2E473K160AA C3216X7R2E473M160AA C3225X7R2J473K200AA C3225X7R2J473M200AA C3216X7R2E683K160AA C3216X7R2E683M160AA C2012X7R2A683K085AA C2012X7R2A683M085AA C3216X7R2A683K160AA C3216X7R2A683M160AA C3225X7R2J683K200AA C3225X7R2J683M200AA C4532X7R2J683K160KA C4532X7R2J683M160KA C3216X7R2E104K160AA C3216X7R2E104M160AA C3225X7R2E104K200AA C3225X7R2E104M200AA C2012X7R2A104K125AA C2012X7R2A104M125AA C3216X7R2A104K160AA C3216X7R2A104M160AA C4532X7R2J104K230KA C4532X7R2J104M230KA C3216X7R2A154K160AA C3216X7R2A154M160AA C3225X7R2E154K200AA C3225X7R2E154M200AA C4532X7R2E154K160KA C4532X7R2E154M160KA C5750X7R2J154K160KA C5750X7R2J154M160KA C3216X7R2A224K115AA C3216X7R2A224M115AA C3225X7R2E224K200AA C3225X7R2E224M200AA Page 28 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) Capacitance Size Thickness (mm) 4532 2.30 ± 0.20 5750 2.30 ± 0.20 3216 1.30 ± 0.20 3225 2.00 ± 0.20 4532 2.30 ± 0.20 5750 1.60 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 4532 2.30 ± 0.20 5750 2.30 ± 0.20 3216 1.60 ± 0.20 3225 1.60 ± 0.20 4532 2.30 ± 0.20 220 nF 330 nF 470 nF 680 nF 1.60 ± 0.20 5750 2.30 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 4532 2.30 ± 0.20 5750 2.30 ± 0.20 3225 2.00 ± 0.20 4532 2.30 ± 0.20 5750 2.30 ± 0.20 3225 2.30 ± 0.20 4532 2.30 ± 0.20 5750 2.30 ± 0.20 3.3 μF 5750 2.30 ± 0.20 4.7 μF 5750 2.30 ± 0.20 1 μF 1.5 μF 2.2 μF Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 250V C4532X7R2E224K230KA C4532X7R2E224M230KA Rated Voltage Edc: 100V C5750X7R2J224K230KA C5750X7R2J224M230KA C3216X7R2A334K130AA C3216X7R2A334M130AA C3225X7R2A334K200AA C3225X7R2A334M200AA C4532X7R2E334K230KA C4532X7R2E334M230KA C5750X7R2E334K160KA C5750X7R2E334M160KA C3216X7R2A474K160AA C3216X7R2A474M160AA C3225X7R2A474K200AA C3225X7R2A474M200AA C4532X7R2E474K230KA C4532X7R2E474M230KA C5750X7R2E474K230KA C5750X7R2E474M230KA C3216X7R2A684K160AA C3216X7R2A684M160AA C3225X7R2A684K160AA C3225X7R2A684M160AA C4532X7R2A684K230KA C4532X7R2A684M230KA C5750X7R2A684K160KA C5750X7R2A684M160KA C5750X7R2E684K230KA C5750X7R2E684M230KA C5750X7R2E105K230KA C5750X7R2E105M230KA C3216X7R2A105K160AA C3216X7R2A105M160AA C3225X7R2A105K200AA C3225X7R2A105M200AA C4532X7R2A105K230KA C4532X7R2A105M230KA C5750X7R2A105K230KA C5750X7R2A105M230KA C3225X7R2A155K200AB C3225X7R2A155M200AB C4532X7R2A155K230KA C4532X7R2A155M230KA C5750X7R2A155K230KA C5750X7R2A155M230KA C3225X7R2A225K230AB C3225X7R2A225M230AB C4532X7R2A225K230KA C4532X7R2A225M230KA C5750X7R2A225K230KA C5750X7R2A225M230KA C5750X7R2A335K230KA C5750X7R2A335M230KA C5750X7R2A475K230KA C5750X7R2A475M230KA Page 29 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X7S (-55 to +125ºC, ±22%) Capacitance Size Thickness (mm) 1 nF 1005 0.50 ± 0.05 1.5 nF 1005 0.50 ± 0.05 2.2 nF 1005 0.50 ± 0.05 3.3 nF 1005 0.50 ± 0.05 4.7 nF 1005 0.50 ± 0.05 6.8 nF 1005 0.50 ± 0.05 10 nF 1005 0.50 ± 0.05 33 nF 1608 0.80 ± 0.10 47 nF 1608 0.80 ± 0.10 68 nF 1608 0.80 ± 0.10 100 nF 1608 0.80 ± 0.10 150 nF 2012 0.85 ± 0.15 220 nF 2012 0.85 ± 0.15 330 nF 2012 1.25 ± 0.20 470 nF 2012 1.25 ± 0.20 680 nF 2012 1.25 ± 0.20 1 μF 2012 1.25 ± 0.20 1.5 μF 3216 1.60 ± 0.20 2.2 μF 3216 1.60 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 4532 2.00 ± 0.20 3225 2.00 ± 0.20 4532 2.30 ± 0.20 6.8 μF 5750 2.00 ± 0.20 10 μF 5750 2.30 ± 0.20 15 μF 5750 2.50 ± 0.30 3.3 μF 4.7 μF Capacitance Tolerance Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 250V ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 20% Rated Voltage Edc: 100V C1005X7S2A102K050BB C1005X7S2A102M050BB C1005X7S2A152K050BB C1005X7S2A152M050BB C1005X7S2A222K050BB C1005X7S2A222M050BB C1005X7S2A332K050BB C1005X7S2A332M050BB C1005X7S2A472K050BB C1005X7S2A472M050BB C1005X7S2A682K050BB C1005X7S2A682M050BB C1005X7S2A103K050BB C1005X7S2A103M050BB C1608X7S2A333K080AB C1608X7S2A333M080AB C1608X7S2A473K080AB C1608X7S2A473M080AB C1608X7S2A683K080AB C1608X7S2A683M080AB C1608X7S2A104K080AB C1608X7S2A104M080AB C2012X7S2A154K085AB C2012X7S2A154M085AB C2012X7S2A224K085AB C2012X7S2A224M085AB C2012X7S2A334K125AB C2012X7S2A334M125AB C2012X7S2A474K125AB C2012X7S2A474M125AB C2012X7S2A684K125AB C2012X7S2A684M125AB C2012X7S2A105K125AB C2012X7S2A105M125AB C3216X7S2A155K160AB C3216X7S2A155M160AB C3216X7S2A225K160AB C3216X7S2A225M160AB C3216X7S2A335K160AB C3216X7S2A335M160AB C3225X7S2A335K200AB C3225X7S2A335M200AB C4532X7S2A335K200KB C4532X7S2A335M200KB C3225X7S2A475K200AB C3225X7S2A475M200AB C4532X7S2A475K230KB C4532X7S2A475M230KB C5750X7S2A685K200KB C5750X7S2A685M200KB C5750X7S2A106K230KB C5750X7S2A106M230KB C5750X7S2A156M250KB Page 30 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X7T (-55 to +125ºC, +22/-33%) Size Thickness (mm) 2012 0.85 ± 0.15 3216 0.85 ± 0.15 2012 0.85 ± 0.15 3216 0.85 ± 0.15 2012 1.25 ± 0.20 3216 1.15 ± 0.15 2012 1.25 ± 0.20 3216 1.15 ± 0.15 2012 1.25 ± 0.20 3216 1.60 ± 0.20 2012 1.25 ± 0.20 3216 1.30 ± 0.20 2012 1.25 ± 0.20 3216 1.60 ± 0.20 3225 1.60 ± 0.20 3216 1.30 ± 0.20 3225 2.00 ± 0.20 4532 1.60 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 4532 2.00 ± 0.20 4532 2.00 ± 0.20 3225 2.00 ± 0.20 4532 1.60 ± 0.20 5750 2.00 ± 0.20 4532 2.30 ± 0.20 5750 2.50 ± 0.30 4532 1.60 ± 0.20 5750 2.00 ± 0.20 4532 2.50 ± 0.30 5750 2.50 ± 0.30 1.5 μF 5750 2.00 ± 0.20 2.2 μF 5750 2.50 ± 0.30 Capacitance 10 nF 15 nF 22 nF 33 nF 47 nF 68 nF 100 nF 150 nF 220 nF 300 nF 330 nF 470 nF 680 nF 1 μF Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 450V C2012X7T2W103K085AA C2012X7T2W103M085AA Rated Voltage Edc: 350V C2012X7T2V103K085AA C2012X7T2V103M085AA Rated Voltage Edc: 250V C2012X7T2W153K085AA C2012X7T2W153M085AA C2012X7T2V153K085AA C2012X7T2V153M085AA C2012X7T2W223K125AA C2012X7T2W223M125AA C2012X7T2V223K125AA C2012X7T2V223M125AA C2012X7T2W333K125AA C2012X7T2W333M125AA C2012X7T2V333K125AA C2012X7T2V333M125AA C2012X7T2E333K125AA C2012X7T2E333M125AA C2012X7T2W473K125AA C2012X7T2W473M125AA C2012X7T2V473K125AA C2012X7T2V473M125AA C2012X7T2E473K125AA C2012X7T2E473M125AA C3216X7T2J103K085AC C3216X7T2J103M085AC C3216X7T2J153K085AC C3216X7T2J153M085AC C3216X7T2J223K115AC C3216X7T2J223M115AC C3216X7T2J333K115AC C3216X7T2J333M115AC C3216X7T2J473K160AC C3216X7T2J473M160AC C2012X7T2E683K125AA C2012X7T2E683M125AA C3216X7T2W683K130AA C3216X7T2W683M130AA C3216X7T2V683K130AA C3216X7T2V683M130AA C2012X7T2E104K125AA C2012X7T2E104M125AA C3216X7T2W104K160AA C3216X7T2W104M160AA C3216X7T2V104K160AA C3216X7T2V104M160AA C3225X7T2J104K160AC C3225X7T2J104M160AC C3216X7T2E154K130AA C3216X7T2E154M130AA C3225X7T2J154K200AC C3225X7T2J154M200AC C4532X7T2J154K160KC C4532X7T2J154M160KC C3216X7T2E224K160AA C3216X7T2E224M160AA C3225X7T2W224K200AA C3225X7T2W224M200AA C4532X7T2J224K200KC C4532X7T2J224M200KC C4532X7T2J304K250KA C4532X7T2J304M250KA C3225X7T2E334K200AA C3225X7T2E334M200AA C4532X7T2W334K160KA C4532X7T2W334M160KA C5750X7T2J334K200KC C5750X7T2J334M200KC C4532X7T2W474K230KA C4532X7T2W474M230KA C5750X7T2J474K250KC C5750X7T2J474M250KC C4532X7T2E684K160KA C4532X7T2E684M160KA C5750X7T2W684K200KA C5750X7T2W684M200KA C4532X7T2E105K250KA C4532X7T2E105M250KA C5750X7T2W105K250KA C5750X7T2W105M250KA C5750X7T2E155K200KA C5750X7T2E155M200KA C5750X7T2E225K250KA C5750X7T2E225M250KA Page 31 • All specifications are subject to change without notice. 20150309 / mlcc_commercial_midvoltage_en
C2012X7R2A223K125AA. 价格&库存
很抱歉,暂时无法提供与“C2012X7R2A223K125AA.”相匹配的价格&库存,您可以联系我们找货
