C Series
High Temperature Application
Type:
C1005 [EIA CC0402]
C1608 [EIA CC0603]
C2012 [EIA CC0805]
C3216 [EIA CC1206]
C3225 [EIA CC1210]
Issue date:
April 2011
TDK MLCC
US Catalog
Version B11
REMINDERS
Please read before using this product
SAFETY REMINDERS
REMINDERS
1.
2.
3.
4.
5.
6.
7.
If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other
damage, you must contact our company’s sales window.
We may modify products or discontinue production of a product listed in this catalog without prior
notification.
We provide “Delivery Specification” that explain precautions for the specifications and safety of each
product listed in this catalog. We strongly recommend that you exchange these delivery specifications
with customers that use one of these products.
If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according
to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export
permission in harmony with this law.
Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from
our company.
We are not responsible for problems that occur related to the intellectual property rights or other rights of
our company or a third party when you use a product listed in this catalog. We do not grant license of
these rights.
This catalog only applies to products purchased through our company or one of our company’s official
agencies. This catalog does not apply to products that are purchased through other third parties.
TDK MLCC US Catalog
Page 118
Version B11
C Series
Type: C1005, C1608, C2012, C3216, C3225
Features
• These products have no polarity.
• Their electrostatic capacity temperature response is
stable at 15% even in high temperature ranges (up to
150°C).
Parameters
Specifications
Temperature
Characteristics
Operating Temperature
Dissipation Factor
Insulation Resistance
-55 to +150ºC
ΔC/C = ±15%
-55 to +150ºC
3% maximum
10 GΩ or 500 MΩ • µF minimum
Voltage Proof
2.5 • rated voltage for 1 to 5
seconds
Charge/Discharge ≤ 50 mA
Applications
• Automotive (underhood)
• Measurement instruments used at high
temperature environments
• LCD display
• Sensor Module
Shape &
Dimensions
L
W
T
B
Body Length
Body Width
Body Height
Terminal Width
Dimensions in mm
Part Number
Construction
C
Series Name
Dimensions L x W (mm)
Case Code
C1005
C1608
C2012
C3216
C3225
Length
1.00 ± 0.05
1.60 ± 0.10
2.00 ± 0.20
3.20 ± 0.20
3.20 ± 0.40
Temperature Characteristic
Temperature
Characteristics
X8R
Capacitance
Change
± 15%
3225
X8R 1E 335 K T XXXX
Width
0.50 ± 0.05
0.80 ± 0.10
1.25 ± 0.20
1.60 ± 0.20
2.50 ± 0.30
Style
Tape & Reel
Tolerance Code
K
Tolerance
± 10%
Nominal Capacitance (pF)
The capacitance is expressed in three
digit codes and in units of pico Farads
(pF). The first and second digits identify
the first and second significant figures of
the capacitance. The third digit identifies
the multiplier. R designates a decimal
point.
Temperature
Range
-55 to +150ºC
Voltage (DC)
25V
50V
100V
TDK MLCC US Catalog
Packaging Code
T
Capacitance Tolerance
Rated Voltage (DC)
Voltage Code
1E
1H
2A
Internal Codes
Packaging Style
Capacitance Code
0R5
010
102
105
Page 119
Capacitance
0.5pF
1pF
1,000pF (1nF)
1,000,000pF (1µF)
Version B11
Capacitance
Range Chart
C1005 [EIA CC0402]
Capacitance Range Chart
Temperature Characteristics: X8R (± 15%)
Rated Voltage: 50V (1H), 25V (1E)
Capacitance
(pF)
X8R
Cap
Code
150
220
330
470
680
1,000
1,500
2,200
3,300
4,700
6,800
10,000
151
221
331
471
681
102
152
222
332
472
682
103
Tolerance
1H
(50V)
1E
(25V)
K: ± 10%
Standard Thickness
0.50 mm
Capacitance
Range Table
C1005 [EIA CC0402]
Class 2 (Temperature Stable)
Temperature Characteristics: X8R (-55 to +150ºC, ±15%)
TDK Part Number
(Ordering Code)
Temperature
Characteristics
Rated
Voltage
Capacitance
(pF)
Capacitance
Tolerance
Thickness
(mm)
C1005X8R1E682K
X8R
25V
6,800
± 10%
0.50 ± 0.05
C1005X8R1E103K
X8R
25V
10,000
± 10%
0.50 ± 0.05
C1005X8R1H151K
X8R
50V
150
± 10%
0.50 ± 0.05
C1005X8R1H221K
X8R
50V
220
± 10%
0.50 ± 0.05
C1005X8R1H331K
X8R
50V
330
± 10%
0.50 ± 0.05
C1005X8R1H471K
X8R
50V
470
± 10%
0.50 ± 0.05
C1005X8R1H681K
X8R
50V
680
± 10%
0.50 ± 0.05
C1005X8R1H102K
X8R
50V
1,000
± 10%
0.50 ± 0.05
C1005X8R1H152K
X8R
50V
1,500
± 10%
0.50 ± 0.05
C1005X8R1H222K
X8R
50V
2,200
± 10%
0.50 ± 0.05
C1005X8R1H332K
X8R
50V
3,300
± 10%
0.50 ± 0.05
C1005X8R1H472K
X8R
50V
4,700
± 10%
0.50 ± 0.05
TDK MLCC US Catalog
Page 120
Version B11
Capacitance
Range Chart
C1608 [EIA CC0603]
Rated Voltage: 100V (2A), 50V (1H), 25V (1E)
Capacitance
(pF)
X8R
Cap
Code
1,000
1,500
2,200
3,300
4,700
6,800
10,000
15,000
22,000
33,000
47,000
68,000
100,000
102
152
222
332
472
682
103
153
223
333
473
683
104
Tolerance
2A
(100V)
1H
(50V)
1E
(25V)
K: ± 10%
Standard Thickness
0.80 mm
Capacitance
Range Table
C1608 [EIA CC0603]
TDK Part Number
Temperature
Rated
(Ordering Code)
Characteristics
Voltage
Capacitance
(pF)
Capacitance
Tolerance
Thickness
(mm)
C1608X8R1E683K
X8R
25V
68,000
± 10%
0.80 ± 0.10
C1608X8R1E104K
X8R
25V
100,000
± 10%
0.80 ± 0.10
C1608X8R1H102K
X8R
50V
1,000
± 10%
0.80 ± 0.10
C1608X8R1H152K
X8R
50V
1,500
± 10%
0.80 ± 0.10
C1608X8R1H222K
X8R
50V
2,200
± 10%
0.80 ± 0.10
C1608X8R1H332K
X8R
50V
3,300
± 10%
0.80 ± 0.10
C1608X8R1H472K
X8R
50V
4,700
± 10%
0.80 ± 0.10
C1608X8R1H682K
X8R
50V
6,800
± 10%
0.80 ± 0.10
C1608X8R1H103K
X8R
50V
10,000
± 10%
0.80 ± 0.10
C1608X8R1H153K
X8R
50V
15,000
± 10%
0.80 ± 0.10
C1608X8R1H223K
X8R
50V
22,000
± 10%
0.80 ± 0.10
C1608X8R1H333K
X8R
50V
33,000
± 10%
0.80 ± 0.10
C1608X8R1H473K
X8R
50V
47,000
± 10%
0.80 ± 0.10
C1608X8R2A102K
X8R
100V
1,000
± 10%
0.80 ± 0.10
C1608X8R2A152K
X8R
100V
1,500
± 10%
0.80 ± 0.10
C1608X8R2A222K
X8R
100V
2,200
± 10%
0.80 ± 0.10
C1608X8R2A332K
X8R
100V
3,300
± 10%
0.80 ± 0.10
C1608X8R2A472K
X8R
100V
4,700
± 10%
0.80 ± 0.10
C1608X8R2A682K
X8R
100V
6,800
± 10%
0.80 ± 0.10
C1608X8R2A103K
X8R
100V
10,000
± 10%
0.80 ± 0.10
C1608X8R2A153K
X8R
100V
15,000
± 10%
0.80 ± 0.10
TDK MLCC US Catalog
Page 121
Version B11
Capacitance
Range Chart
C2012 [EIA CC0805]
Capacitance
(pF)
22,000
68,000
100,000
150,000
220,000
330,000
X8R
Cap
Code
223
683
104
154
224
334
Tolerance
2A
(100V)
1H
(50V)
1E
(25V)
K: ± 10%
Standard Thickness
0.85 mm
1.25 mm
Capacitance
Range Table
C2012 [EIA CC0805]
TDK Part Number
Temperature
Rated
(Ordering Code)
Characteristics
Voltage
Capacitance
(pF)
Capacitance
Tolerance
Thickness
(mm)
C2012X8R1E154K/0.85
X8R
25V
150,000
± 10%
0.85 ± 0.10
C2012X8R1E224K
X8R
25V
220,000
± 10%
1.25 ± 0.20
C2012X8R1E334K
X8R
25V
330,000
± 10%
1.25 ± 0.20
C2012X8R1H683K
X8R
50V
68,000
± 10%
1.25 ± 0.20
C2012X8R1H104K
X8R
50V
100,000
± 10%
1.25 ± 0.20
C2012X8R2A223K
X8R
100V
22,000
± 10%
1.25 ± 0.20
TDK MLCC US Catalog
Page 122
Version B11
Capacitance
Range Chart
C3216 [EIA CC1206]
Capacitance
(pF)
33,000
47,000
68,000
100,000
150,000
220,000
330,000
470,000
680,000
1,000,000
X8R
Cap
Code
333
473
683
104
154
224
334
474
684
105
Tolerance
2A
(100V)
1H
(50V)
1E
(25V)
K: ± 10%
Standard Thickness
0.85 mm
1.15 mm
1.60 mm
Capacitance
Range Table
C3216 [EIA CC1206]
TDK Part Number
Temperature
Rated
(Ordering Code)
Characteristics
Voltage
Capacitance
(pF)
Capacitance
Tolerance
Thickness
(mm)
C3216X8R1E334K
X8R
25V
330,000
± 10%
0.85 ± 0.10
C3216X8R1E474K
X8R
25V
470,000
± 10%
0.85 ± 0.10
C3216X8R1E684K
X8R
25V
680,000
± 10%
1.15 ± 0.10
C3216X8R1E105K
X8R
25V
1,000,000
± 10%
1.60 ± 0.30
C3216X8R1H154K
X8R
50V
150,000
± 10%
0.85 ± 0.10
C3216X8R1H224K
X8R
50V
220,000
± 10%
1.15 ± 0.10
C3216X8R1H334K
X8R
50V
330,000
± 10%
1.60 ± 0.30
C3216X8R1H474K
X8R
50V
470,000
± 10%
1.60 ± 0.30
C3216X8R2A333K
X8R
100V
33,000
± 10%
0.85 ± 0.10
C3216X8R2A473K
X8R
100V
47,000
± 10%
0.85 ± 0.10
C3216X8R2A683K
X8R
100V
68,000
± 10%
1.15 ± 0.10
C3216X8R2A104K
X8R
100V
100,000
± 10%
1.15 ± 0.10
C3216X8R2A154K
X8R
100V
150,000
± 10%
1.60 ± 0.30
TDK MLCC US Catalog
Page 123
Version B11
Capacitance
Range Chart
C3225 [EIA CC1210]
Capacitance
(pF)
1,500,000
2,200,000
3,300,000
X8R
Cap
Code
155
225
335
Tolerance
2A
(100V)
1H
(50V)
1E
(25V)
Standard Thickness
1.60 mm
2.00 mm
K: ± 10%
2.50 mm
Capacitance
Range Table
C3225 [EIA CC1210]
TDK Part Number
Temperature
Rated
(Ordering Code)
Characteristics
Voltage
Capacitance
(pF)
Capacitance
Tolerance
Thickness
(mm)
C3225X8R1E155K
X8R
25V
1,500,000
± 10%
1.60 ± 0.30
C3225X8R1E225K
X8R
25V
2,200,000
± 10%
2.00 ± 0.20
C3225X8R1E335K
X8R
25V
3,300,000
± 10%
2.50 ± 0.30
TDK MLCC US Catalog
Page 124
Version B11
General
Specifications
C Series – High Temperature Application
No.
Item
Performance
Test or Inspection Method
1
External
Appearance
No defects which may affect
performance.
Inspect with magnifying glass (3×).
2
Insulation
Resistance
10,000MΩ or 500 MΩ・μF min.
Apply rated voltage for 60s.
3
Voltage Proof
Withstand test voltage without
insulation breakdown or other damage.
2.5 x VDC rated voltage shall be applied for 1~5s.
Charge / discharge current shall not exceed 50mA.
4
Capacitance
Within the specified tolerance.
5
6
Dissipation
Factor
Temperature
Characteristics
of Capacitance
T.C.
D.F.
X8R
0.03 max.
Measuring
Frequency
Measuring
Voltage
1kHz±10%
1.0±0.2Vrms
See No.4 in this table for measuring condition.
Capacitance Change (%)
Capacitance shall be measured by the steps shown in
the following table after thermal equilibrium is obtained
for each step.
∆C be calculated ref. STEP3 reading
No Voltage Applied
X8R: ± 15%
Step
7
Robustness of
Terminations
No sign of termination coming off,
breakage of ceramic, or other abnormal
signs.
Temperature (ºC)
1
Reference temp. ± 2
2
Min. operating temp. ± 2
3
Reference temp. ± 2
4
Max. operating temp. ± 2
Reflow solder the capacitor on a P.C. board (shown in
Appendix 1) and apply a pushing force of 5N (C1608,
C2012, C3216, C3225 type) and 2N (C1005 type) for
10±1s.
Pushing force
P.C. board
Capacitor
8
Bending
No mechanical damage.
Appendix 2) and bend 1mm as illustrated:
F
R230
1
45
45
Unit: mm
TDK MLCC US Catalog
Page 125
Version B11
General
Specifications
No.
Item
Performance
9
Solderability
New solder to cover over 75% of
termination.
Completely soak both terminations in
solder at 235±5ºC for 2±0.5s.
25% may have pinholes or rough spots
but not concentrated in one spot.
Solder: H63A (JIS Z 3282)
Ceramic surface of ”A sections” shall
not be exposed due to melting or
shifting of termination material.
Flux: Isopropyl alcohol (JIS K 8839)
Rosin (JIS K 5902) 25% solid solution.
A section
10
Resistance to solder heat
External
appearance
Capacitance
11
No cracks are allowed and terminations
shall be covered at
least 60% with new solder.
Characteristics
Change from the
value before test
Class 2
± 7.5 %
X8R
D.F. (Class 2)
Meet the initial spec.
Insulation
Resistance
Voltage
Proof
No insulation breakdown or
other damage.
Capacitance
D.F. (Class 2)
TDK MLCC US Catalog
Leave the capacitor in ambient conditions for 48±4h
before measurement.
Appendix 1) before testing.
Characteristics
Change from the
value before test
Class 2
± 7.5 %
X8R
Preheating condition
Temp. : 150±10ºC
Time : 1~2min.
Solder: H63A(JIS Z 3282)
Vibration
External
appearance
Completely soak both terminations in solder at
260±5ºC for 5±1s.
Vibrate the capacitor with amplitude of 1.5mm P-P
sweeping the frequencies from 10Hz to 55Hz and back
to 10Hz in after 1min.
Repeat this for 2h each in 3 perpendicular directions.
Page 126
Version B11
General
Specifications
No.
Item
12
Temperature cycle
External
appearance
Performance
13
Characteristics
Change from the
value before test
Class 2
± 7.5 %
X8R
Insulation
Resistance
Voltage
Proof
No insulation breakdown or other
damage.
Moisture Resistance (Steady State)
External
appearance
Capacitance
14
Reflow solder the capacitors on P.C. board (shown in
Capacitance
D.F. (Class 2)
Characteristics
Change from the
value before test
Class 2
± 12.5 %
D.F. (Class 2)
200% of initial spec max.
Insulation
Resistance
1,000MΩ or 50 MΩ・μF min.
Moisture Resistance
External
appearance
Capacitance
Characteristics
Change from the
value before test
Class 2
± 12.5 %
D.F. (Class 2)
Insulation
Resistance
500MΩ or 25 MΩ・μF min.
Step
Temperature (ºC)
Time (min.)
1
Min. operating temp. ±3
30 ± 3
2
Reference Temp.
2–5
3
30 ± 2
4
Reference Temp.
2-5
Leave at temperature 40±2ºC, 90 to 95%RH for 500
+24,0h.
before measurement.
Reflow solder the capacitor on P.C. board (shown in
X8R
Leave the capacitors in ambient conditions for 48±4h
before measurement.
X8R
Expose the capacitor in the condition step 1 through 4,
and repeat 5 times consecutively.
Apply the rated voltage at temperature 40±2ºC and 90
to 95%RH for 500+24,0h.
Charge/discharge current shall not exceed 50mA.
before measurement.
Voltage conditioning:
Voltage treats the capacitor under testing temperature
and voltage for 1 hour.
Leave the capacitor in ambient condition for 48±4h
before measurement.
Use this measurement for initial value.
TDK MLCC US Catalog
Page 127
Version B11
General
Specifications
No.
Item
15
Life
External
appearance
Capacitance
Performance
Apply 2× rated voltage at maximum operating
temperature ±3ºC for 1,000 +48.0h.
Characteristics
Change from the
value before test
Class 2
± 15 %
X8R
before measurement.
D.F.
(Class 2)
Characteristics
X8R: 200% of initial spec. max
Insulation
Resistance
Voltage conditioning :
before measurement.
*As for the initial measurement of capacitors on number 6,10,11,12 and 13, leave capacitor at 150 –10, 0°C for 1h and
measure the value after leaving the capacitor for 48±4h in ambient conditions.
TDK MLCC US Catalog
Page 128
Version B11
General
Specifications
Appendix - 1a
Appendix - 1b
P.C. Board for reliability test
Applied for C1005, C1608, C2012, C3216
Applied for C3225
c
c
Solder Resist
40 mm
b
100 mm
a
40 mm
100 mm
a
Copper
Solder Resist
Slit
Copper
Appendix - 2a
Appendix - 2b
P.C. Board for bending test
Applied for C1005
Applied for C1608, C2012, C3216, C3225
100 mm
a
c
40 mm
a
Solder resist
b
40 mm
b
1.0 mm
100 mm
1.0 mm
b
Copper
Solder Resist
c
b
Copper
Material : Glass Epoxy (As per JIS C6484 GE4)
P.C. Board thickness : Appendix-2a
Appendix-1a, 1b, 2b
Case Code
0.8mm
1.6mm
Copper (thickness 0.035mm)
Solder resist
TDK MLCC US Catalog
Page 129
Dimensions (mm)
JIS
EIA
a
b
c
C1005
CC0402
0.4
1.5
0.5
C1608
CC0603
1.0
3.0
1.2
C2012
CC0805
1.2
4.0
1.65
C3216
CC1206
2.2
5.0
2.0
C3225
CC1210
2.2
5.0
2.9
Version B11
Soldering
Information
• Recommended Soldering Land Pattern
Chip capacitor
• Recommended Soldering Profile
Reflow Soldering
Solder land
Preheating
Wave Soldering
Unit: mm
C1608
[CC0603]
C2012
[CC0805]
C3216
[CC1206]
A
0.7 - 1.0
1.0 - 1.3
2.1 - 2.5
B
0.8 - 1.0
1.0 - 1.2
1.1 - 1.3
C
0.6 - 0.8
0.8 - 1.1
1.0 - 1.3
C1005
[CC0402]
C1608
[CC0603]
C2012
[CC0805]
A
0.3 - 0.5
0.6 - 0.8
0.9 - 1.2
B
0.35 - 0.45
0.6 - 0.8
0.7 - 0.9
C
0.4 - 0.6
0.6 - 0.8
0.9 - 1.2
Type
Reflow Soldering
Type
Symbol
Reflow Soldering
Unit: mm
C3225
[CC1210]
2.0 - 2.4
2.0 - 2.4
B
1.0 - 1.2
1.0 - 1.2
C
1.1 - 1.6
1.9 - 2.5
Symbol
A
Adequate
solder
Insufficient
solder
TDK MLCC US Catalog
Temp (ºC)
∆T
Over 60 sec.
Preheating
Peak Temp time
3sec. (As short as possible)
Manual soldering
(Solder iron)
300
∆T
Preheating
Recommended soldering duration
Temp./
Dura.
Higher tensile
force on the chip
capacitor may
cause cracking.
Maximum amount
Minimum amount
Small solder fillet
may cause
contact failure or
failure to hold the
chip capacitor to
the P.C. board.
Wave Soldering
Reflow Soldering
Peak temp
(°C)
Duration
(sec.)
Peak temp
(°C)
Duration
(sec.)
Sn-Pb
Solder
250 max.
3 max.
230 max.
20 max.
Lead-Free
Solder
260 max.
5 max.
260 max.
10 max.
Solder
• Recommended Solder Amount
Excessive
solder
Unit: mm
C3216
[CC1206]
Type
∆T
Temp (ºC)
Solder resist
Temp (ºC)
A
B
Symbol
300
Peak
Temp
C
Manual soldering
(Solder iron)
Soldering Natural
cooling
Recommended solder compositions
Sn-37Pb (Sn-Pb solder)
Sn-3.0Ag-0.5Cu (Lead Free Solder)
Preheating Condition
Soldering
Wave
soldering
Reflow
soldering
Manual
soldering
Page 130
Case Size - JIS (EIA)
Temp. (ºC)
C1608(CC0603), C2012(CC0805),
C3216(CC1206)
∆T ≤ 150
C1005(CC0402), C1608(CC0603),
C2012(CC0805), C3216(CC1206)
∆T ≤ 150
C3225(CC1210)
∆T ≤ 130
∆T ≤ 150
C3225(CC1210)
∆T ≤ 130
Version B11
Packaging
Information
• Carrier Tape Configuration
Bulk
160mm min.
Bulk
160mm min
Chips
Leader
Drawing direction
400mm min
• Peel Back Force (Top Tape)
Carrier tape
Direction & angle of pull
Top cover tape
• Carrier tape shall be flexible enough to be
wound around a minimum radius of 30mm with
components in tape.
• The missing of components shall be less than
0.1%
• Components shall not stick to the cover tape.
• The cover tape shall not protrude beyond the
edges of the carrier tape not shall cover the
sprocket holes.
0.05 – 0.7 N
0~15°
• Chip Quantity Per Reel and Structure of Reel (Paper & Plastic)
Paper Carrier Tape & Reel
Top cover tape
Plastic Carrier Tape & Reel
Top cover tape
Pitch hole
Bottom cover tape
Case Code
JIS
EIA
C1005
CC0402
C1608
CC0603
C2012
CC0805
C3216
CC1206
C3225
CC1210
TDK MLCC US Catalog
Pitch hole
Plastic carrier tape
Paper carrier tape
Chip
Thickness
0.50 mm
0.80 mm
0.85 mm
1.25 mm
0.85 mm
1.15 mm
1.60 mm
1.60 mm
2.00 mm
2.50 mm
Taping
Material
Paper
Paper
Paper
Plastic
Paper
Plastic
Plastic
Chip quantity (pcs.)
φ178mm (7”) reel φ330mm (13”) reel
10,000
50,000
4,000
10,000
4,000
10,000
2,000
4,000
10,000
2,000
8,000
2,000
8,000
1,000
Page 131
5,000
Version B11
Additional
Information
• Shape & Dimensions
• Environmental Information
Terminal electrode
L
B
B
W
G
T
TDK Corporation established internal product environmental
assurance standards that include the six hazardous substances
banned by the EU RoHS Directive1 enforced on July 1, 2006
along with additional substances independently banned by TDK
and has successfully completed making general purpose
electronic components conform to the RoHS Directive2.
1.
Abbreviation for Restriction on Hazardous Substances,
which refers to the regulation EU Directive 2002/95/EC on
hazardous substances by the European Union (EU)
effective from July 1, 2006. The Directive bans the use of
six specific hazardous substances in electric and
electronic devices and products handled within the EU.
The six substances are lead, mercury, cadmium,
hexavalent chromium, PBB (polybrominated biphenyls),
and PBDE (polybrominated diphenyl ethers).
2.
This means that, in conformity with the EU Directive
2002/95/EC, lead, cadmium, mercury, hexavalent
chromium, and specific bromine-based flame retardants,
PBB and PBDE, have not been used, except for
exempted applications.
Internal electrode
Ceramic dielectric
Case Code
JIS
EIA
C1005
CC0402
C1608
CC0603
L
1.00
1.60
C2012
CC0805
2.00
C3216
CC1206
3.20
C3225
CC1210
3.20
Dimensions (mm)
W
T
B
0.50
0.50
0.25
0.80
0.80
0.20 min.
0.85
1.20
0.20 min.
1.25
0.85
1.60
1.15
0.20 min.
1.60
1.60
2.50
2.00
0.20 min.
2.50
G
0.35 min.
0.30 min.
0.50 min.
1.00 min.
1.00 min
• Inside Structure & Material System
3
4
NAME
(1)
Ceramic Dielectric
(2)
Internal Electrode
(3)
(4)
5
2
1
No.
For REACH (SVHC : 15 substances according to ECHA /
October 2008) : All TDK MLCC do not contain these 15
substances.
For European Directive 2000/53/CE and 2005/673/CE :
Cadmium, Hexavalent Chromium, Mercury, Lead are not
contained in all TDK MLCC.
For European Directive 2003/11/CE : Pentabromodiphenyl-ether,
Octabromodiphenyl-ether are not contained in all TDK
MLCC.
MATERIAL
Class 1
Class 2
CaZrO3
BaTiO3
Nickel (Ni)
Copper (Cu)
Termination
(5)
TDK MLCC US Catalog
Nickel (Ni)
Tin (Sn)
Page 132
Version B11
