C4532X7R2A105M/3
C4532X7R2A105M/3
    TDK(东电化)
    贴片电容(MLCC) 1812 1µF ±20% 100V X7R
C4532X7R2A105M/3 数据手册
C Series Mid Voltage Application Type: C1005 [EIA CC0402] C1608 [EIA CC0603] C2012 [EIA CC0805] C3216 [EIA CC1206] C3225 [EIA CC1210] C4532 [EIA CC1812] C5750 [EIA CC2220] Issue date: April 2011 TDK MLCC US Catalog Version B11 REMINDERS Please read before using this product SAFETY REMINDERS REMINDERS 1. 2. 3. 4. 5. 6. 7. If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other damage, you must contact our company’s sales window. We may modify products or discontinue production of a product listed in this catalog without prior notification. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export permission in harmony with this law. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. TDK MLCC US Catalog Page 76 Version B11 C Series Mid Voltage Application Type: C1005, C1608, C2012, C3216, C3225, C4532, C5750 Features • Unique electrode design allows higher voltage application in smaller case size • SMT package will help down sizing and lightening of the weight of the product • A monolithic structure ensures superior mechanical strength and reliability. • High capacitance has been achieved through precision technologies that enable the use of multiple thinner ceramic dielectric layers. • Owing to their low ESR and excellent frequency characteristics, these products are optimally suited for high frequency and high-density type power supplies. • High-accuracy automatic mounting is facilitated through the maintenance of very precise dimensional tolerances. • Low residual inductance assures superior frequency characteristics. • Low stray capacitance ensures high conformity with nominal values, thereby simplifying the circuit design process. • Voltage rating of up to 630V • High mechanical strength • No polarity Applications • • • • • • • • • Snubber in switching power supply Ringer cap in telephone set and modem Flash light in camera DSU/TA in ISDN lines HID (High Intensity Discharge Lamp) Output bypass in power supply Driver circuit in plasma display Noise bypass in automotive Other mid voltage applications Shape & Dimensions L W T B Body Length Body Width Body Height Terminal Width Dimensions in mm Part Number Construction Series Name Dimensions L x W (mm) Case Code C1005 C1608 C2012 C3216 C3225 C4532 C5750 Length 1.00 ± 0.05 1.60 ± 0.10 2.00 ± 0.20 3.20 ± 0.20 3.20 ± 0.40 4.50 ± 0.40 5.70 ± 0.40 C 3216 X7R 2J 103 K T XXXX Width 0.50 ± 0.05 0.80 ± 0.10 1.25 ± 0.20 1.60 ± 0.20 2.50 ± 0.30 3.20 ± 0.40 5.00 ± 0.40 Packaging Code T Capacitance Change 0±30 ppm/ºC ± 22% ± 15% ± 22% +22/-33% Tolerance Code J K M The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. Capacitance Code 0R5 010 102 105 Voltage (DC) 100V 250V 450V 630V TDK MLCC US Catalog Tolerance ± 5% ± 10% ± 20% Nominal Capacitance (pF) Temperature Range -55 to +125ºC -55 to +105ºC -55 to +125ºC -55 to +125ºC -55 to +125ºC Rated Voltage (DC) Voltage Code 2A 2E 2W 2J Style Tape & Reel Capacitance Tolerance Temperature Characteristic Temperature Characteristics C0G X6S X7R X7S X7T Internal Codes Packaging Style Page 77 Capacitance 0.5pF 1pF 1,000pF (1nF) 1,000,000pF (1µF) Version B11 Capacitance Range Chart C1005 [EIA CC0402] Capacitance Range Chart Temperature Characteristics: X7R (± 15%), X5R (± 15%), Y5V (+22/-82%) Rated Voltage: 100V (2A) Capacitance (pF) 1,000 1,500 2,200 3,300 4,700 6,800 10,000 X7S Cap Code 102 152 222 332 472 682 103 Tolerance 2A (100V) K: ± 10% M: ± 20% TDK MLCC US Catalog Standard Thickness 0.50 mm Page 78 Version B11 Capacitance Range Table C1005 [EIA CC0402] Class 2 (Temperature Stable) Temperature Characteristics: X7S (-55 to +125ºC, ±22%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C1005X7S2A102K X7S 100V 1,000 ± 10% 0.50 ± 0.05 C1005X7S2A102M X7S 100V 1,000 ± 20% 0.50 ± 0.05 C1005X7S2A152K X7S 100V 1,500 ± 10% 0.50 ± 0.05 C1005X7S2A152M X7S 100V 1,500 ± 20% 0.50 ± 0.05 C1005X7S2A222K X7S 100V 2,200 ± 10% 0.50 ± 0.05 C1005X7S2A222M X7S 100V 2,200 ± 20% 0.50 ± 0.05 C1005X7S2A332K X7S 100V 3,300 ± 10% 0.50 ± 0.05 C1005X7S2A332M X7S 100V 3,300 ± 20% 0.50 ± 0.05 C1005X7S2A472K X7S 100V 4,700 ± 10% 0.50 ± 0.05 C1005X7S2A472M X7S 100V 4,700 ± 20% 0.50 ± 0.05 C1005X7S2A682K X7S 100V 6,800 ± 10% 0.50 ± 0.05 C1005X7S2A682M X7S 100V 6,800 ± 20% 0.50 ± 0.05 C1005X7S2A103K X7S 100V 10,000 ± 10% 0.50 ± 0.05 C1005X7S2A103M X7S 100V 10,000 ± 20% 0.50 ± 0.05 TDK MLCC US Catalog Page 79 Version B11 Capacitance Range Chart C1608 [EIA CC0603] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC) Rated Voltage: 250V (2E), 100V (2A) Capacitance (pF) 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 C0G Cap Code 101 121 151 181 221 271 331 391 471 561 681 821 102 122 Tolerance 2E (250V) 2A (100V) J: ± 5% Capacitance Range Chart Temperature Characteristics: X7R (±15%), X7S (±22%) Rated Voltage: 100V (2A) Capacitance (pF) 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 Cap Code 102 152 222 332 472 682 103 153 223 333 473 683 104 Tolerance X7R X7S 2A (100V) 2A (100V) K: ± 10% M: ± 20% Standard Thickness 0.80 mm TDK MLCC US Catalog Page 80 Version B11 Capacitance Range Table C1608 [EIA CC0603] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C1608C0G2A101J C0G 100V 100 ± 5% 0.80 ± 0.10 C1608C0G2A121J C0G 100V 120 ± 5% 0.80 ± 0.10 C1608C0G2A151J C0G 100V 150 ± 5% 0.80 ± 0.10 C1608C0G2A181J C0G 100V 180 ± 5% 0.80 ± 0.10 C1608C0G2A221J C0G 100V 220 ± 5% 0.80 ± 0.10 C1608C0G2A271J C0G 100V 270 ± 5% 0.80 ± 0.10 C1608C0G2A331J C0G 100V 330 ± 5% 0.80 ± 0.10 C1608C0G2A391J C0G 100V 390 ± 5% 0.80 ± 0.10 C1608C0G2A471J C0G 100V 470 ± 5% 0.80 ± 0.10 C1608C0G2A561J C0G 100V 560 ± 5% 0.80 ± 0.10 C1608C0G2A681J C0G 100V 680 ± 5% 0.80 ± 0.10 C1608C0G2A821J C0G 100V 820 ± 5% 0.80 ± 0.10 C1608C0G2A102J C0G 100V 1,000 ± 5% 0.80 ± 0.10 C1608C0G2A122J C0G 100V 1,200 ± 5% 0.80 ± 0.10 C1608C0G2E101J C0G 250V 100 ± 5% 0.80 ± 0.10 C1608C0G2E121J C0G 250V 120 ± 5% 0.80 ± 0.10 C1608C0G2E151J C0G 250V 150 ± 5% 0.80 ± 0.10 C1608C0G2E181J C0G 250V 180 ± 5% 0.80 ± 0.10 C1608C0G2E221J C0G 250V 220 ± 5% 0.80 ± 0.10 C1608C0G2E271J C0G 250V 270 ± 5% 0.80 ± 0.10 C1608C0G2E331J C0G 250V 330 ± 5% 0.80 ± 0.10 C1608C0G2E391J C0G 250V 390 ± 5% 0.80 ± 0.10 C1608C0G2E471J C0G 250V 470 ± 5% 0.80 ± 0.10 C1608C0G2E561J C0G 250V 560 ± 5% 0.80 ± 0.10 C1608C0G2E681J C0G 250V 680 ± 5% 0.80 ± 0.10 Capacitance Tolerance Thickness (mm) Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) C1608X7R2A102K X7R 100V 1,000 ± 10% 0.80 ± 0.10 C1608X7R2A102M X7R 100V 1,000 ± 20% 0.80 ± 0.10 C1608X7R2A152K X7R 100V 1,500 ± 10% 0.80 ± 0.10 C1608X7R2A152M X7R 100V 1,500 ± 20% 0.80 ± 0.10 C1608X7R2A222K X7R 100V 2,200 ± 10% 0.80 ± 0.10 C1608X7R2A222M X7R 100V 2,200 ± 20% 0.80 ± 0.10 C1608X7R2A332K X7R 100V 3,300 ± 10% 0.80 ± 0.10 C1608X7R2A332M X7R 100V 3,300 ± 20% 0.80 ± 0.10 C1608X7R2A472K X7R 100V 4,700 ± 10% 0.80 ± 0.10 C1608X7R2A472M X7R 100V 4,700 ± 20% 0.80 ± 0.10 C1608X7R2A682K X7R 100V 6,800 ± 10% 0.80 ± 0.10 C1608X7R2A682M X7R 100V 6,800 ± 20% 0.80 ± 0.10 C1608X7R2A103K X7R 100V 10,000 ± 10% 0.80 ± 0.10 C1608X7R2A103M X7R 100V 10,000 ± 20% 0.80 ± 0.10 C1608X7R2A153K X7R 100V 15,000 ± 10% 0.80 ± 0.10 TDK MLCC US Catalog Page 81 Version B11 Capacitance Range Table C1608 [EIA CC0603] Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%), X7S (-55 to +125ºC, ±22%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C1608X7R2A153M X7R 100V 15,000 ± 20% 0.80 ± 0.10 C1608X7R2A223K X7R 100V 22,000 ± 10% 0.80 ± 0.10 C1608X7R2A223M X7R 100V 22,000 ± 20% 0.80 ± 0.10 C1608X7S2A333K X7S 100V 33,000 ± 10% 0.80 ± 0.10 C1608X7S2A333M X7S 100V 33,000 ± 20% 0.80 ± 0.10 C1608X7S2A473K X7S 100V 47,000 ± 10% 0.80 ± 0.10 C1608X7S2A473M X7S 100V 47,000 ± 20% 0.80 ± 0.10 C1608X7S2A683K X7S 100V 68,000 ± 10% 0.80 ± 0.10 C1608X7S2A683M X7S 100V 68,000 ± 20% 0.80 ± 0.10 C1608X7S2A104K X7S 100V 100,000 ± 10% 0.80 ± 0.10 C1608X7S2A104M X7S 100V 100,000 ± 20% 0.80 ± 0.10 TDK MLCC US Catalog Page 82 Version B11 Capacitance Range Chart C2012 [EIA CC0805] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC) Rated Voltage: 250V (2E), 100V (2A) Capacitance (pF) 100 220 470 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 C0G Cap Code 101 221 471 821 102 122 152 182 222 272 332 392 472 Tolerance 2E (250V) 2A (100V) J: ± 5% Capacitance Range Chart Temperature Characteristics: X7R (±15%), X7S (±22%), X7T (+22/-33%) Rated Voltage: 450V (2W), 250V (2E), 100V (2A) Capacitance (pF) 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 1,000,000 X7R Cap Code 102 152 222 332 472 682 103 153 223 333 473 683 104 154 224 334 474 105 Tolerance 2E (250V) 2A (100V) X7S 2A (100V) X7T 2W (450V) 2E (250V) K: ± 10% M: ± 20% Standard Thickness 0.60 mm 0.85 mm 1.25 mm TDK MLCC US Catalog Page 83 Version B11 Capacitance Range Table C2012 [EIA CC0805] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C2012C0G2A101J C0G 100V 100 ± 5% 0.60 ± 0.10 C2012C0G2A221J C0G 100V 220 ± 5% 0.60 ± 0.10 C2012C0G2A471J C0G 100V 470 ± 5% 0.60 ± 0.10 C2012C0G2A102J C0G 100V 1,000 ± 5% 0.60 ± 0.10 C2012C0G2A122J C0G 100V 1,200 ± 5% 0.60 ± 0.10 C2012C0G2A152J C0G 100V 1,500 ± 5% 0.60 ± 0.10 C2012C0G2A182J C0G 100V 1,800 ± 5% 0.85 ± 0.10 C2012C0G2A222J C0G 100V 2,200 ± 5% 0.85 ± 0.10 C2012C0G2A272J C0G 100V 2,700 ± 5% 1.25 ± 0.20 C2012C0G2A332J C0G 100V 3,300 ± 5% 1.25 ± 0.20 C2012C0G2A392J C0G 100V 3,900 ± 5% 1.25 ± 0.20 C2012C0G2A472J C0G 100V 4,700 ± 5% 1.25 ± 0.20 C2012C0G2E101J C0G 250V 100 ± 5% 0.60 ± 0.10 C2012C0G2E821J C0G 250V 820 ± 5% 0.60 ± 0.10 C2012C0G2E102J C0G 250V 1,000 ± 5% 0.85 ± 0.10 C2012C0G2E122J C0G 250V 1,200 ± 5% 0.85 ± 0.10 C2012C0G2E152J C0G 250V 1,500 ± 5% 0.85 ± 0.10 C2012C0G2E182J C0G 250V 1,800 ± 5% 1.25 ± 0.20 C2012C0G2E222J C0G 250V 2,200 ± 5% 1.25 ± 0.20 C2012C0G2E272J C0G 250V 2,700 ± 5% 1.25 ± 0.20 Capacitance Tolerance Thickness (mm) Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) C2012X7R2A102K X7R 100V 1,000 ± 10% 0.85 ± 0.10 C2012X7R2A102M X7R 100V 1,000 ± 20% 0.85 ± 0.10 C2012X7R2A152K X7R 100V 1,500 ± 10% 0.85 ± 0.10 C2012X7R2A152M X7R 100V 1,500 ± 20% 0.85 ± 0.10 C2012X7R2A222K X7R 100V 2,200 ± 10% 0.85 ± 0.10 C2012X7R2A222M X7R 100V 2,200 ± 20% 0.85 ± 0.10 C2012X7R2A332K X7R 100V 3,300 ± 10% 0.85 ± 0.10 C2012X7R2A332M X7R 100V 3,300 ± 20% 0.85 ± 0.10 C2012X7R2A472K X7R 100V 4,700 ± 10% 0.85 ± 0.10 C2012X7R2A472M X7R 100V 4,700 ± 20% 0.85 ± 0.10 C2012X7R2A682K X7R 100V 6,800 ± 10% 0.85 ± 0.10 C2012X7R2A682M X7R 100V 6,800 ± 20% 0.85 ± 0.10 C2012X7R2A103K X7R 100V 10,000 ± 10% 0.85 ± 0.10 C2012X7R2A103M X7R 100V 10,000 ± 20% 0.85 ± 0.10 C2012X7R2A153K X7R 100V 15,000 ± 10% 1.25 ± 0.20 C2012X7R2A153M X7R 100V 15,000 ± 20% 1.25 ± 0.20 C2012X7R2A223K X7R 100V 22,000 ± 10% 1.25 ± 0.20 C2012X7R2A223M X7R 100V 22,000 ± 20% 1.25 ± 0.20 C2012X7R2A333K X7R 100V 33,000 ± 10% 1.25 ± 0.20 C2012X7R2A333M X7R 100V 33,000 ± 20% 1.25 ± 0.20 TDK MLCC US Catalog Page 84 Version B11 Capacitance Range Table C2012 [EIA CC0805] Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%), X7S (-55 to +125ºC, ±22%), X7T (-55 to +125ºC, +22/-33%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C2012X7R2A473K X7R 100V 47,000 ± 10% 1.25 ± 0.20 C2012X7R2A473M X7R 100V 47,000 ± 20% 1.25 ± 0.20 C2012X7R2A683K X7R 100V 68,000 ± 10% 0.85 ± 0.10 C2012X7R2A683M X7R 100V 68,000 ± 20% 0.85 ± 0.10 C2012X7R2A104K X7R 100V 100,000 ± 10% 1.25 ± 0.20 C2012X7R2A104M X7R 100V 100,000 ± 20% 1.25 ± 0.20 C2012X7R2E102K X7R 250V 1,000 ± 10% 0.85 ± 0.10 C2012X7R2E102M X7R 250V 1,000 ± 20% 0.85 ± 0.10 C2012X7R2E152K X7R 250V 1,500 ± 10% 0.85 ± 0.10 C2012X7R2E152M X7R 250V 1,500 ± 20% 0.85 ± 0.10 C2012X7R2E222K X7R 250V 2,200 ± 10% 0.85 ± 0.10 C2012X7R2E222M X7R 250V 2,200 ± 20% 0.85 ± 0.10 C2012X7R2E332K X7R 250V 3,300 ± 10% 0.85 ± 0.10 C2012X7R2E332M X7R 250V 3,300 ± 20% 0.85 ± 0.10 C2012X7R2E472K X7R 250V 4,700 ± 10% 0.85 ± 0.10 C2012X7R2E472M X7R 250V 4,700 ± 20% 0.85 ± 0.10 C2012X7R2E682K X7R 250V 6,800 ± 10% 1.25 ± 0.20 C2012X7R2E682M X7R 250V 6,800 ± 20% 1.25 ± 0.20 C2012X7R2E103K X7R 250V 10,000 ± 10% 1.25 ± 0.20 C2012X7R2E103M X7R 250V 10,000 ± 20% 1.25 ± 0.20 C2012X7R2E153K X7R 250V 15,000 ± 10% 1.25 ± 0.20 C2012X7R2E153M X7R 250V 15,000 ± 20% 1.25 ± 0.20 C2012X7R2E223K X7R 250V 22,000 ± 10% 1.25 ± 0.20 C2012X7R2E223M X7R 250V 22,000 ± 20% 1.25 ± 0.20 C2012X7S2A154K X7S 100V 150,000 ± 10% 0.85 ± 0.10 C2012X7S2A154M X7S 100V 150,000 ± 20% 0.85 ± 0.10 C2012X7S2A224K X7S 100V 220,000 ± 10% 0.85 ± 0.10 C2012X7S2A224M X7S 100V 220,000 ± 20% 0.85 ± 0.10 C2012X7S2A334K X7S 100V 330,000 ± 10% 1.25 ± 0.20 C2012X7S2A334M X7S 100V 330,000 ± 20% 1.25 ± 0.20 C2012X7S2A474K X7S 100V 470,000 ± 10% 1.25 ± 0.20 C2012X7S2A474M X7S 100V 470,000 ± 20% 1.25 ± 0.20 C2012X7S2A105K X7S 100V 1,000,000 ± 10% 1.25 ± 0.20 C2012X7S2A105M X7S 100V 1,000,000 ± 20% 1.25 ± 0.20 C2012X7T2E333K X7T 250V 33,000 ± 10% 1.25 ± 0.20 C2012X7T2E473K X7T 250V 47,000 ± 10% 1.25 ± 0.20 C2012X7T2E683K X7T 250V 68,000 ± 10% 1.25 ± 0.20 C2012X7T2E104K X7T 250V 100,000 ± 10% 1.25 ± 0.20 C2012X7T2W103K X7T 450V 10,000 ± 10% 0.85 ± 0.10 C2012X7T2W153K X7T 450V 15,000 ± 10% 0.85 ± 0.10 C2012X7T2W223K X7T 450V 22,000 ± 10% 1.25 ± 0.20 C2012X7T2W333K X7T 450V 33,000 ± 10% 1.25 ± 0.20 C2012X7T2W473K X7T 450V 47,000 ± 10% 1.25 ± 0.20 TDK MLCC US Catalog Page 85 Version B11 Capacitance Range Chart C3216 [EIA CC1206] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC) Rated Voltage: 630V (2J), 250V (2E), 100V (2A) Capacitance (pF) 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 C0G Cap Code 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 Tolerance 2J (630V) 2E (250V) 2A (100V) J: ± 5% Capacitance Range Chart Temperature Characteristics: X7R (±15%), X7S (±22%), X7T (+22/-33%) Rated Voltage: 630V (2J), 450V (2W), 250V (2E), 100V (2A) Capacitance (pF) 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 1,000,000 2,200,000 X7R Cap Code 102 152 222 332 472 682 103 153 223 333 473 683 104 154 224 334 474 105 225 Tolerance 2J (630V) 2E (250V) X7S 2A (100V) 2A (100V) X7T 2J (630V) 2W (450V) 2E (250V) K: ± 10% M: ± 20% Standard Thickness 0.60 mm TDK MLCC US Catalog 0.85 mm 1.15 mm 1.30 mm Page 86 1.60 mm Version B11 Capacitance Range Table C3216 [EIA CC1206] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C3216C0G2A392J C0G 100V 3,900 ± 5% 0.60 ± 0.10 C3216C0G2A472J C0G 100V 4,700 ± 5% 0.85 ± 0.10 C3216C0G2A562J C0G 100V 5,600 ± 5% 0.85 ± 0.10 C3216C0G2A682J C0G 100V 6,800 ± 5% 1.15 ± 0.10 C3216C0G2A822J C0G 100V 8,200 ± 5% 1.15 ± 0.10 C3216C0G2A103J C0G 100V 10,000 ± 5% 1.15 ± 0.10 C3216C0G2E332J C0G 250V 3,300 ± 5% 0.85 ± 0.10 C3216C0G2E392J C0G 250V 3,900 ± 5% 1.15 ± 0.10 C3216C0G2E472J C0G 250V 4,700 ± 5% 1.15 ± 0.10 C3216C0G2E562J C0G 250V 5,600 ± 5% 1.15 ± 0.10 C3216C0G2E682J C0G 250V 6,800 ± 5% 1.60 ± 0.30 C3216C0G2E822J C0G 250V 8,200 ± 5% 1.60 ± 0.30 C3216C0G2J101J C0G 630V 100 ± 5% 0.60 ± 0.10 C3216C0G2J121J C0G 630V 120 ± 5% 0.60 ± 0.10 C3216C0G2J151J C0G 630V 150 ± 5% 0.60 ± 0.10 C3216C0G2J181J C0G 630V 180 ± 5% 0.60 ± 0.10 C3216C0G2J221J C0G 630V 220 ± 5% 0.60 ± 0.10 C3216C0G2J271J C0G 630V 270 ± 5% 0.60 ± 0.10 C3216C0G2J331J C0G 630V 330 ± 5% 0.60 ± 0.10 C3216C0G2J391J C0G 630V 390 ± 5% 0.60 ± 0.10 C3216C0G2J471J C0G 630V 470 ± 5% 0.85 ± 0.10 C3216C0G2J561J C0G 630V 560 ± 5% 0.85 ± 0.10 C3216C0G2J681J C0G 630V 680 ± 5% 0.85 ± 0.10 C3216C0G2J821J C0G 630V 820 ± 5% 0.85 ± 0.10 C3216C0G2J102J C0G 630V 1,000 ± 5% 0.85 ± 0.10 C3216C0G2J122J C0G 630V 1,200 ± 5% 0.85 ± 0.10 C3216C0G2J152J C0G 630V 1,500 ± 5% 1.15 ± 0.10 C3216C0G2J182J C0G 630V 1,800 ± 5% 1.15 ± 0.10 C3216C0G2J222J C0G 630V 2,200 ± 5% 1.15 ± 0.10 C3216C0G2J272J C0G 630V 2,700 ± 5% 1.60 ± 0.30 C3216C0G2J332J C0G 630V 3,300 ± 5% 1.60 ± 0.30 Capacitance Tolerance Thickness (mm) Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) C3216X7R2A333K X7R 100V 33,000 ± 10% 1.15 ± 0.10 C3216X7R2A333M X7R 100V 33,000 ± 20% 1.15 ± 0.10 C3216X7R2A473K X7R 100V 47,000 ± 10% 1.15 ± 0.10 C3216X7R2A473M X7R 100V 47,000 ± 20% 1.15 ± 0.10 C3216X7R2A683K X7R 100V 68,000 ± 10% 1.60 ± 0.30 C3216X7R2A683M X7R 100V 68,000 ± 20% 1.60 ± 0.30 C3216X7R2A104K X7R 100V 100,000 ± 10% 1.60 ± 0.30 C3216X7R2A104M X7R 100V 100,000 ± 20% 1.60 ± 0.30 C3216X7R2A154K X7R 100V 150,000 ± 10% 1.60 ± 0.30 TDK MLCC US Catalog Page 87 Version B11 Capacitance Range Table C3216 [EIA CC1206] Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%), X7S (-55 to +125ºC, ±22%), X7T (-55 to +125ºC, +22/-33%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C3216X7R2A154M X7R 100V 150,000 ± 20% 1.60 ± 0.30 C3216X7R2A224K X7R 100V 220,000 ± 10% 1.15 ± 0.10 C3216X7R2A224M X7R 100V 220,000 ± 20% 1.15 ± 0.10 C3216X7R2A334K X7R 100V 330,000 ± 10% 1.30 ± 0.15 C3216X7R2A334M X7R 100V 330,000 ± 20% 1.30 ± 0.15 C3216X7R2A474K X7R 100V 470,000 ± 10% 1.60 ± 0.30 C3216X7R2A474M X7R 100V 470,000 ± 20% 1.60 ± 0.30 C3216X7R2A105K X7R 100V 1,000,000 ± 10% 1.60 ± 0.30 C3216X7R2A105M X7R 100V 1,000,000 ± 20% 1.60 ± 0.30 C3216X7R2E153K X7R 250V 15,000 ± 10% 1.15 ± 0.10 C3216X7R2E153M X7R 250V 15,000 ± 20% 1.15 ± 0.10 C3216X7R2E223K X7R 250V 22,000 ± 10% 1.15 ± 0.10 C3216X7R2E223M X7R 250V 22,000 ± 20% 1.15 ± 0.10 C3216X7R2E333K X7R 250V 33,000 ± 10% 1.60 ± 0.30 C3216X7R2E333M X7R 250V 33,000 ± 20% 1.60 ± 0.30 C3216X7R2E473K X7R 250V 47,000 ± 10% 1.60 ± 0.30 C3216X7R2E473M X7R 250V 47,000 ± 20% 1.60 ± 0.30 C3216X7R2E683K X7R 250V 68,000 ± 10% 1.60 ± 0.30 C3216X7R2E683M X7R 250V 68,000 ± 20% 1.60 ± 0.30 C3216X7R2E104K X7R 250V 100,000 ± 10% 1.60 ± 0.30 C3216X7R2E104M X7R 250V 100,000 ± 20% 1.60 ± 0.30 C3216X7R2J102K X7R 630V 1,000 ± 10% 1.15 ± 0.10 C3216X7R2J102M X7R 630V 1,000 ± 20% 1.15 ± 0.10 C3216X7R2J152K X7R 630V 1,500 ± 10% 1.15 ± 0.10 C3216X7R2J152M X7R 630V 1,500 ± 20% 1.15 ± 0.10 C3216X7R2J222K X7R 630V 2,200 ± 10% 1.15 ± 0.10 C3216X7R2J222M X7R 630V 2,200 ± 20% 1.15 ± 0.10 C3216X7R2J332K X7R 630V 3,300 ± 10% 1.15 ± 0.10 C3216X7R2J332M X7R 630V 3,300 ± 20% 1.15 ± 0.10 C3216X7R2J472K X7R 630V 4,700 ± 10% 1.15 ± 0.10 C3216X7R2J472M X7R 630V 4,700 ± 20% 1.15 ± 0.10 C3216X7R2J682K X7R 630V 6,800 ± 10% 1.15 ± 0.10 C3216X7R2J682M X7R 630V 6,800 ± 20% 1.15 ± 0.10 C3216X7R2J103K X7R 630V 10,000 ± 10% 1.15 ± 0.10 C3216X7R2J103M X7R 630V 10,000 ± 20% 1.15 ± 0.10 C3216X7R2J153K X7R 630V 15,000 ± 10% 1.30 ± 0.15 C3216X7R2J153M X7R 630V 15,000 ± 20% 1.30 ± 0.15 C3216X7R2J223K X7R 630V 22,000 ± 10% 1.30 ± 0.15 C3216X7R2J223M X7R 630V 22,000 ± 20% 1.30 ± 0.15 C3216X7R2J333K X7R 630V 33,000 ± 10% 1.60 ± 0.30 C3216X7R2J333M X7R 630V 33,000 ± 20% 1.60 ± 0.30 C3216X7S2A225K X7S 100V 2,200,000 ± 10% 1.60 ± 0.30 C3216X7S2A225M X7S 100V 2,200,000 ± 20% 1.60 ± 0.30 C3216X7T2E154K X7T 250V 150,000 ± 10% 1.30 ± 0.15 TDK MLCC US Catalog Page 88 Version B11 Capacitance Range Table C3216 [EIA CC1206] Class 2 (Temperature Stable) Temperature Characteristics: X7T (-55 to +125ºC, +22/-33%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C3216X7T2E224K X7T 250V 220,000 ± 10% 1.60 ± 0.30 C3216X7T2W683K X7T 450V 68,000 ± 10% 1.30 ± 0.15 C3216X7T2W104K X7T 450V 100,000 ± 10% 1.60 ± 0.30 C3216X7T2J103K X7T 630V 10,000 ± 10% 0.85 ± 0.10 C3216X7T2J153K X7T 630V 15,000 ± 10% 0.85 ± 0.10 C3216X7T2J223K X7T 630V 22,000 ± 10% 1.15 ± 0.10 C3216X7T2J333K X7T 630V 33,000 ± 10% 1.15 ± 0.10 C3216X7T2J473K X7T 630V 47,000 ± 10% 1.60 ± 0.30 TDK MLCC US Catalog Page 89 Version B11 Capacitance Range Chart C3225 [EIA CC1210] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC) Rated Voltage: 630V (2J), 250V (2E), 100V (2A) Capacitance (pF) 3,900 4,700 5,600 6,800 10,000 15,000 22,000 33,000 47,000 C0G Cap Code 392 472 562 682 103 153 223 333 473 Tolerance 2J (630V) 2E (250V) 2A (100V) J: ± 5% Capacitance Range Chart Temperature Characteristics: X7R (±15%), X7S (±22%), X7T (+22/-33%) Rated Voltage: 630V (2J), 450V (2W), 250V (2E), 100V (2A) Capacitance (pF) Cap Code 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 2,200,000 3,300,000 4,700,000 473 683 104 154 224 334 474 684 105 225 335 475 X7R Tolerance 2J (630V) 2E (250V) X7S 2A (100V) 2A (100V) X7T 2J (630V) 2W (450V) 2E (250V) K: ± 10% M: ± 20% Standard Thickness 1.25 mm 1.60 mm 2.00 mm 2.30 mm TDK MLCC US Catalog Page 90 Version B11 Capacitance Range Table C3225 [EIA CC1210] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C3225C0G2A153J C0G 100V 15,000 ± 5% 1.30 ± 0.15 C3225C0G2A223J C0G 100V 22,000 ± 5% 1.60 ± 0.30 C3225C0G2A333J C0G 100V 33,000 ± 5% 2.00 ± 0.20 C3225C0G2A473J C0G 100V 47,000 ± 5% 2.30 ± 0.20 C3225C0G2E103J C0G 250V 10,000 ± 5% 1.60 ± 0.30 C3225C0G2E153J C0G 250V 15,000 ± 5% 2.00 ± 0.20 C3225C0G2J392J C0G 630V 3,900 ± 5% 1.30 ± 0.15 C3225C0G2J472J C0G 630V 4,700 ± 5% 1.60 ± 0.30 C3225C0G2J562J C0G 630V 5,600 ± 5% 1.60 ± 0.30 C3225C0G2J682J C0G 630V 6,800 ± 5% 2.00 ± 0.20 Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%), X7S (-55 to +125ºC, ±22%), X7T (-55 to +125ºC, +22/-33%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C3225X7R2A334K X7R 100V 330,000 ± 10% 2.00 ± 0.20 C3225X7R2A334M X7R 100V 330,000 ± 20% 2.00 ± 0.20 C3225X7R2A474K X7R 100V 470,000 ± 10% 2.00 ± 0.20 C3225X7R2A474M X7R 100V 470,000 ± 20% 2.00 ± 0.20 C3225X7R2A684K X7R 100V 680,000 ± 10% 1.60 ± 0.30 C3225X7R2A684M X7R 100V 680,000 ± 20% 1.60 ± 0.30 C3225X7R2A105K X7R 100V 1,000,000 ± 10% 2.00 ± 0.20 C3225X7R2A105M X7R 100V 1,000,000 ± 20% 2.00 ± 0.20 C3225X7R2A225K X7R 100V 2,200,000 ± 10% 2.30 ± 0.20 C3225X7R2A225M X7R 100V 2,200,000 ± 20% 2.30 ± 0.20 C3225X7R2E104K X7R 250V 100,000 ± 10% 2.00 ± 0.20 C3225X7R2E104M X7R 250V 100,000 ± 20% 2.00 ± 0.20 C3225X7R2E154K X7R 250V 150,000 ± 10% 2.00 ± 0.20 C3225X7R2E154M X7R 250V 150,000 ± 20% 2.00 ± 0.20 C3225X7R2E224K X7R 250V 220,000 ± 10% 2.00 ± 0.20 C3225X7R2E224M X7R 250V 220,000 ± 20% 2.00 ± 0.20 C3225X7R2J473K X7R 630V 47,000 ± 10% 2.00 ± 0.20 C3225X7R2J473M X7R 630V 47,000 ± 20% 2.00 ± 0.20 C3225X7R2J683K X7R 630V 68,000 ± 10% 2.00 ± 0.20 C3225X7R2J683M X7R 630V 68,000 ± 20% 2.00 ± 0.20 C3225X7S2A335K X7S 100V 3,300,000 ± 10% 2.00 ± 0.20 C3225X7S2A335M X7S 100V 3,300,000 ± 20% 2.00 ± 0.20 C3225X7S2A475K X7S 100V 4,700,000 ± 10% 2.00 ± 0.20 C3225X7S2A475M X7S 100V 4,700,000 ± 20% 2.00 ± 0.20 C3225X7T2E334K X7T 250V 330,000 ± 10% 2.00 ± 0.20 C3225X7T2W224K X7T 450V 220,000 ± 10% 2.00 ± 0.20 C3225X7T2J104K X7T 630V 100,000 ± 10% 1.60 ± 0.30 C3225X7T2J154K X7T 630V 150,000 ± 10% 2.00 ± 0.20 TDK MLCC US Catalog Page 91 Version B11 Capacitance Range Chart C4532 [EIA CC1812] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC) Rated Voltage: 630V (2J), 250V (2E), 100V (2A) Capacitance (pF) C0G Cap Code 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 822 103 153 223 333 473 683 104 Tolerance 2J (630V) 2E (250V) 2A (100V) J: ± 5% Capacitance Range Chart Temperature Characteristics: X7R (±15%), X7S (±22%), X7T (+22/-33%) Rated Voltage: 630V (2J), 450V (2W), 250V (2E), 100V (2A) Capacitance (pF) Cap Code 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 4,700,000 683 104 154 224 334 474 684 105 155 225 475 X7R Tolerance 2J (630V) 2E (250V) X7S 2A (100V) 2A (100V) X7T 2J (630V) 2W (450V) 2E (250V) K: ± 10% M: ± 20% Standard Thickness 1.60 mm 2.00 mm 2.30 mm 2.50 mm 3.20 mm TDK MLCC US Catalog Page 92 Version B11 Capacitance Range Table C4532 [EIA CC1812] Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to 125ºC, 0±30 ppm/ºC) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C4532C0G2A473J C0G 100V 47,000 ± 5% 2.00 ± 0.20 C4532C0G2A683J C0G 100V 68,000 ± 5% 2.50 ± 0.30 C4532C0G2A104J C0G 100V 100,000 ± 5% 3.20 ± 0.30 C4532C0G2E223J C0G 250V 22,000 ± 5% 1.60 ± 0.30 C4532C0G2E333J C0G 250V 33,000 ± 5% 2.00 ± 0.20 C4532C0G2E473J C0G 250V 47,000 ± 5% 3.20 ± 0.30 C4532C0G2J822J C0G 630V 8,200 ± 5% 1.60 ± 0.30 C4532C0G2J103J C0G 630V 10,000 ± 5% 1.60 ± 0.30 C4532C0G2J153J C0G 630V 15,000 ± 5% 2.50 ± 0.30 C4532C0G2J223J C0G 630V 22,000 ± 5% 3.20 ± 0.30 Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%), X7S (-55 to +125ºC, ±22%), X7T (-55 to +125ºC, +22/-33%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C4532X7R2A684K X7R 100V 680,000 ± 10% 2.30 ± 0.20 C4532X7R2A684M X7R 100V 680,000 ± 20% 2.30 ± 0.20 C4532X7R2A105K X7R 100V 1,000,000 ± 10% 2.30 ± 0.20 C4532X7R2A105M X7R 100V 1,000,000 ± 20% 2.30 ± 0.20 C4532X7R2A155K X7R 100V 1,500,000 ± 10% 2.30 ± 0.20 C4532X7R2A155M X7R 100V 1,500,000 ± 20% 2.30 ± 0.20 C4532X7R2A225K X7R 100V 2,200,000 ± 10% 2.30 ± 0.20 C4532X7R2A225M X7R 100V 2,200,000 ± 20% 2.30 ± 0.20 C4532X7R2E154K X7R 250V 150,000 ± 10% 1.60 ± 0.30 C4532X7R2E154M X7R 250V 150,000 ± 20% 1.60 ± 0.30 C4532X7R2E224K X7R 250V 220,000 ± 10% 2.30 ± 0.20 C4532X7R2E224M X7R 250V 220,000 ± 20% 2.30 ± 0.20 C4532X7R2E334K X7R 250V 330,000 ± 10% 2.30 ± 0.20 C4532X7R2E334M X7R 250V 330,000 ± 20% 2.30 ± 0.20 C4532X7R2E474K X7R 250V 470,000 ± 10% 2.30 ± 0.20 C4532X7R2E474M X7R 250V 470,000 ± 20% 2.30 ± 0.20 C4532X7R2J683K X7R 630V 68,000 ± 10% 1.60 ± 0.30 C4532X7R2J683M X7R 630V 68,000 ± 20% 1.60 ± 0.30 C4532X7R2J104K X7R 630V 100,000 ± 10% 2.30 ± 0.20 C4532X7R2J104M X7R 630V 100,000 ± 20% 2.30 ± 0.20 C4532X7S2A475M X7S 100V 4,700,000 ± 20% 2.30 ± 0.20 C4532X7T2E684K X7T 250V 680,000 ± 10% 1.60 ± 0.30 C4532X7T2E105K X7T 250V 1,000,000 ± 10% 2.50 ± 0.30 C4532X7T2W334K X7T 450V 330,000 ± 10% 1.60 ± 0.30 C4532X7T2W474K X7T 450V 470,000 ± 10% 2.30 ± 0.20 C4532X7T2J154K X7T 630V 150,000 ± 10% 1.60 ± 0.30 C4532X7T2J224K X7T 630V 220,000 ± 10% 2.00 ± 0.20 TDK MLCC US Catalog Page 93 Version B11 Capacitance Range Chart C5750 [EIA CC2220] Capacitance Range Chart Temperature Characteristics: X7R (±15%), X7S (±22%), X7T (+22/-33%), X6S (±22%) Rated Voltage: 630V (2J), 450V (2W), 250V (2E), 100V (2A) Capacitance (pF) Cap Code 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 10,000,000 15,000,000 154 224 334 474 684 105 155 225 335 475 106 156 X7R Tolerance 2J (630V) 2E (250V) X7S 2A (100V) 2A (100V) X7T 2J (630V) 2W (450V) X6S 2E (250V) 2W (450V) K: ± 10% M: ± 20% Standard Thickness 1.60 mm 2.00 mm 2.30 mm 2.50 mm TDK MLCC US Catalog Page 94 Version B11 Capacitance Range Table C5750 [EIA CC2220] Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%), X7S (-55 to +125ºC, ±22%), X7T (-55 to +125ºC, +22/-33%), X6S (-55 to +105ºC, ±22%) TDK Part Number (Ordering Code) Temperature Characteristics Rated Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) C5750X7R2A105K X7R 100V 1,000,000 ± 10% 2.30 ± 0.20 C5750X7R2A105M X7R 100V 1,000,000 ± 20% 2.30 ± 0.20 C5750X7R2A155K X7R 100V 1,500,000 ± 10% 2.30 ± 0.20 C5750X7R2A155M X7R 100V 1,500,000 ± 20% 2.30 ± 0.20 C5750X7R2A225K X7R 100V 2,200,000 ± 10% 2.30 ± 0.20 C5750X7R2A225M X7R 100V 2,200,000 ± 20% 2.30 ± 0.20 C5750X7R2A335K X7R 100V 3,300,000 ± 10% 2.30 ± 0.20 C5750X7R2A335M X7R 100V 3,300,000 ± 20% 2.30 ± 0.20 C5750X7R2A475K X7R 100V 4,700,000 ± 10% 2.30 ± 0.20 C5750X7R2A475M X7R 100V 4,700,000 ± 20% 2.30 ± 0.20 C5750X7R2E334K X7R 250V 330,000 ± 10% 1.60 ± 0.30 C5750X7R2E334M X7R 250V 330,000 ± 20% 1.60 ± 0.30 C5750X7R2E474K X7R 250V 470,000 ± 10% 2.30 ± 0.20 C5750X7R2E474M X7R 250V 470,000 ± 20% 2.30 ± 0.20 C5750X7R2E684K X7R 250V 680,000 ± 10% 2.30 ± 0.20 C5750X7R2E684M X7R 250V 680,000 ± 20% 2.30 ± 0.20 C5750X7R2E105K X7R 250V 1,000,000 ± 10% 2.30 ± 0.20 C5750X7R2E105M X7R 250V 1,000,000 ± 20% 2.30 ± 0.20 C5750X7R2J154K X7R 630V 150,000 ± 10% 1.60 ± 0.30 C5750X7R2J154M X7R 630V 150,000 ± 20% 1.60 ± 0.30 C5750X7R2J224K X7R 630V 220,000 ± 10% 2.30 ± 0.20 C5750X7R2J224M X7R 630V 220,000 ± 20% 2.30 ± 0.20 C5750X7S2A106M X7S 100V 10,000,000 ± 20% 2.30 ± 0.20 C5750X7S2A156M X7S 100V 15,000,000 ± 20% 2.50 ± 0.30 C5750X7T2E155K X7T 250V 1,500,000 ± 10% 2.00 ± 0.20 C5750X7T2E225K X7T 250V 2,200,000 ± 10% 2.50 ± 0.30 C5750X7T2W684K X7T 450V 680,000 ± 10% 2.00 ± 0.20 C5750X7T2W105K X7T 450V 1,000,000 ± 10% 2.50 ± 0.30 C5750X7T2J334K X7T 630V 330,000 ± 10% 2.00 ± 0.20 C5750X7T2J474K X7T 630V 470,000 ± 10% 2.50 ± 0.30 C5750X6S2W105K X6S 450V 1,000,000 ± 10% 2.50 ± 0.30 C5750X6S2W225K X6S 450V 2,200,000 ± 10% 2.50 ± 0.30 TDK MLCC US Catalog Page 95 Version B11 General Specifications C Series – Mid Voltage Application No. Item Performance Test or Inspection Method 1 External Appearance No defects which may affect performance. Inspect with magnifying glass (3×). 2 Insulation Resistance 10,000MΩ or 500MΩ•μF min. whichever smaller. Apply rated voltage for 60s. As for the rated voltage 630V DC, apply 500V DC. 3 Voltage Proof Withstand test voltage without insulation breakdown or other damage. Class Class 1 Class 2 Rated Voltage Apply voltage 100V 3 ×rated voltage Over 100V 1.5 ×rated voltage 100V 2.5 ×rated voltage Over 100V 1.5 ×rated voltage Above DC voltage shall be applied for 1 to 5s. Charge / discharge current shall not exceed 50mA. 4 Capacitance Within the specified tolerance. Class Class 1 Class 2 5 Q (Class 1) 6 Dissipation Factor (Class 2) 7 Temperature Characteristics of Capacitance (Class 1) TDK MLCC US Catalog 1,000 min. Rated Capacitance Measuring Frequency 1000pF and under 1MHz±10% Over 1000pF 1kHz±10% 10uF and under 1kHz±10% Over 10uF 120Hz±20% Measuring voltage 0.5 - 5 Vrms 0.5±0.2Vrms 1.0±0.2Vrms 0.5±0.2 Vrms See No.4 in this table for measuring condition. See No.4 in this table for measuring condition. T.C. D.F. X7R X7S X7T 0.05 max. 0.05 max. 0.025 max. T.C. Temperature Coefficient C0G 0 ± 30 (ppm/ºC) Capacitance drift within ± 0.2% Page 96 Temperature coefficient shall be calculated based on values at 25ºC and 85ºC temperature. Measuring temperature below 20ºC shall be -10ºC and -25ºC. Version B11 General Specifications C Series – Mid Voltage Application No. Item Performance Test or Inspection Method 8 Temperature Characteristics of Capacitance (Class 2) Capacitance Change (%) Capacitance shall be measured by the steps shown in the following table after thermal equilibrium is obtained for each step. ∆C be calculated ref. STEP 3 reading 9 Robustness of Terminations No Voltage Applied X7R: ± 15% X7S: ± 22% X7T: +22/-33% Step No sign of termination coming off, breakage of ceramic, or other abnormal signs. Temperature (ºC) 1 Reference temp. ± 2 2 Min. operating temp. ± 2 3 Reference temp. ± 2 4 Max. operating temp. ± 2 Reflow solder the capacitors on P.C. board (shown in Appendix 1a or Appendix 1b) and apply a pushing force of 2N (C1005) or 5N (C1608, C2012, C3216, C3225, C4532, C5750) with 10±1s. Pushing force P.C. board Capacitor 10 Bending No mechanical damage. Reflow solder the capacitors on P.C. board (shown in Appendix 2a or Appendix 2b) and bend 1mm. 20 50 F R230 1 45 11 Solderability 45 New solder to cover over 75% of termination. Completely soak both terminations in solder at 235±5°C for 2±0.5s. 25% may have pin holes or rough spots but not concentrated in one spot. Solder : H63A (JIS Z 3282) Ceramic surface of A sections shall not be exposed due to melting or shifting of termination material. Unit: mm Flux : Isopropyl alcohol (JIS K 8839) Rosin (JIS K 5902) 25% solid solution. A section TDK MLCC US Catalog Page 97 Version B11 General Specifications C Series – Mid Voltage Application No. Item 12 Resistance to solder heat External appearance Capacitance 13 Performance Test or Inspection Method No cracks are allowed and terminations shall be covered at least 60% with new solder Characteristics Change from the value before test Class 1 C0G ±2.5 % Class 2 X7R X7S X7T ± 7.5 % D.F. (Class 2) Meet the initial spec. Insulation Resistance Meet the initial spec. Voltage Proof No insulation breakdown or other damage. Vibration Reflow solder the capacitor on a P.C. board (shown in Appendix 1a or Appendix 1b) before testing. No mechanical damage. Characteristics Change from the value before test Class 1 C0G ±2.5 % Class 2 X7R X7S X7T ± 7.5 % Q (Class 1) 1,000 min. D.F. (Class 2) Meet the initial spec. TDK MLCC US Catalog Flux: Isopropyl alcohol (JIS K 8839) Rosin (JIS K 5902) 25% solid solution. Leave the capacitor in ambient conditions for 6 to 24h (Class 1) or 24±2h (Class 2) before measurement. 1,000 min. Capacitance Preheating condition Temp. : 150±10ºC Time : 1 to 2min. Solder: H63A (JIS Z 3282) Q (Class 1) External appearance Completely soak both terminations in solder at 260±5ºC for 5±1s. Page 98 Vibrate the capacitor with amplitude of1.5mm P-P sweeping the frequencies from 10Hz to 55Hz and back to 10Hz in about 1min. Repeat this for 2h each in 3 perpendicular directions. Version B11 General Specifications No. Item 14 Temperature cycle External appearance Capacitance 15 C Series – Mid Voltage Application Performance Test or Inspection Method Reflow solder the capacitors on a P.C. board (shown in Appendix 1a or Appendix 1b) before testing. No mechanical damage. Expose the capacitor in the condition step1 through step 4, and repeat 5 times consecutively. Characteristics Change from the value before test Class 1 C0G ±2.5 % Class 2 X7R X7S X7T ± 7.5 % Q (Class 1) 1,000 min. D.F. (Class 2) Meet the initial spec. Insulation Resistance Meet the initial spec. Voltage Proof No insulation breakdown or other damage. Moisture Resistance (Steady State) External appearance Capacitance Step Temperature (ºC) Time (min.) 1 Min. operating temp. ±3 30 ± 3 2 Reference Temp. 2–5 3 Max. operating temp. ± 2 30 ± 2 4 Reference Temp. 2-5 Reflow solder the capacitor on P.C. board (shown in Appendix 1a or Appendix 1b) before testing. No mechanical damage. Characteristics Change from the value before test Class 1 C0G ±5 % Class 2 X7R X7S X7T ± 12.5 % Q (Class 1) 350 min. D.F. (Class 2) Characteristics X7R: 200% of initial spec. max. X7S: 200% of initial spec. max X7T: 200% of initial spec. max Insulation Resistance 1,000MΩ or 50MΩ•μF min. whichever smaller. TDK MLCC US Catalog Leave the capacitor in ambient conditions for 6 to 24h (Class 1) or 24±2h (Class 2) before measurement. Page 99 Leave at temperature 40±2ºC, 90 to 95%RH for 500 +24,0h. Leave the capacitor in ambient condition for 6 to 24h (Class1) or 24±2h (Class 2) before measurement. Version B11 General Specifications C Series – Mid Voltage Application No. Item 16 Moisture Resistance External appearance Capacitance Test or Inspection Method Reflow solder the capacitors on P.C. board (shown in Appendix 1a or Appendix 1b) before testing. No mechanical damage. Apply the rated voltage at temperature 40±2ºC and 90 to 95%RH for 500 +24,0h. Characteristics Change from the value before test Class 1 C0G ±7.5 % Class 2 X7R X7S X7T ± 12.5 % Voltage conditioning (only for class 2): Voltage treat the capacitors under testing temperature and voltage for 1 hour. 200 min. D.F. (Class 2) Characteristics X7R: 200% of initial spec. max. X7S: 200% of initial spec. max X7T: 200% of initial spec. max Capacitance Use this measurement for initial value. Reflow solder the capacitor on P.C. board (shown in Appendix 1a or Appendix 1b) before testing. No mechanical damage. Apply voltage at 125±2ºC for 1,000 +48, 0h. Applied voltage is 1xRV. Some items may be tested at higher voltage (1.2x, 1.5x or 2xRV). Characteristics Change from the value before test Class 1 C0G ±3 % Charge/discharge current shall not exceed 50mA. Class 2 X7R X7S X7T ± 15 % Leave the capacitors in ambient condition for 6 to 24h (Class 1) or 24±2h (Class 2) before measurement. Q (Class 1) 350 min. D.F. (Class 2) Characteristics X7R: 200% of initial spec. max. X7S: 200% of initial spec. max X7T: 200% of initial spec. max Insulation Resistance Leave the capacitors in ambient condition for 24±2h before measurement. 500MΩ or 25MΩ•μF min. whichever smaller. Life External appearance Charge/discharge current shall not exceed 50mA. Leave the capacitor in ambient conditions for 6 to 24h (Class 1) or 24±2h (Class 2) before measurement. Q (Class 1) Insulation Resistance 17 Performance Voltage conditioning (only for class 2): Voltage treat the capacitor under testing temperature and voltage for 1 hour. Leave the capacitor in ambient conditions for 24±2h before measurement. Use this measurement for initial value. 1,000MΩ or 50MΩ•μF min. whichever smaller. *As for the initial measurement of capacitors (Class 2) on number 8, 12, 13, 14 and 15, leave capacitor at 150 –10, 0°C for 1 hour and measure the value after leaving capacitor for 24±2h in ambient condition. TDK MLCC US Catalog Page 100 Version B11 General Specifications Appendix - 1a Appendix - 1b P.C. Board for reliability test Applied for C1005, C1608, C2012, C3216 P.C. Board for reliability test Applied for C3225, C4532, C5750 c c Solder Resist 40 mm 100 mm a b 40 mm 100 mm a Solder Resist Slit Copper Copper Appendix - 2a Appendix - 2b P.C. Board for bending test Applied for C1005 P.C. Board for bending test Applied for C1608, C2012, C3216, C3225, C4532, C5750 a c 40 mm a Solder resist b 40 mm 100 mm b 1.0 mm 100 mm 1.0 mm b C Series – Mid Voltage Application Copper Solder Resist c b Copper Case Code Material : Glass Epoxy (As per JIS C6484 GE4) P.C. Board thickness : Appendix-2a Appendix-1a, 1b, 2b EIA a b c C1005 CC0402 0.4 1.5 0.5 0.8mm C1608 CC0603 1.0 3.0 1.2 1.6mm C2012 CC0805 1.2 4.0 1.65 C3216 CC1206 2.2 5.0 2.0 C3225 CC1210 2.2 5.0 2.9 C4532 CC1812 3.5 7.0 3.7 C5750 CC2220 4.5 8.0 5.6 Copper (thickness 0.035mm) Solder resist TDK MLCC US Catalog Dimensions (mm) JIS Page 101 Version B11 Soldering Information C Series – Mid Voltage Application • Recommended Soldering Land Pattern Chip capacitor • Recommended Soldering Profile Wave Soldering Solder land Preheating Wave Soldering Unit: mm 0 C1608 [CC0603] C2012 [CC0805] C3216 [CC1206] A 0.7 - 1.0 1.0 - 1.3 2.1 - 2.5 B 0.8 - 1.0 1.0 - 1.2 1.1 - 1.3 C 0.6 - 0.8 0.8 - 1.1 1.0 - 1.3 C1005 [CC0402] C1608 [CC0603] C2012 [CC0805] A 0.3 - 0.5 0.6 - 0.8 0.9 - 1.2 B 0.35 - 0.45 0.6 - 0.8 0.7 - 0.9 C 0.4 - 0.6 0.6 - 0.8 0.9 - 1.2 C3216 [CC1206] C3225 [CC1210] C4532 [CC1812] C5750 [CC2220] A 2.0 - 2.4 2.0 - 2.4 3.1 - 3.7 4.1 - 4.8 B 1.0 - 1.2 1.0 - 1.2 1.2 - 1.4 1.2 - 1.4 C 1.1 - 1.6 1.9 - 2.5 2.4 - 3.2 4.0 - 5.0 Reflow Soldering Symbol Symbol Adequate solder Insufficient solder TDK MLCC US Catalog 0 ∆T Over 60 sec. Peak Temp time Peak Temp time Manual soldering (Solder iron) 300 ∆T Preheating 0 3sec. (As short as possible) Unit: mm • Recommended Solder Amount Excessive solder Over 60 sec. Over 60 sec. Unit: mm Reflow Soldering Type △T Temp (ºC) Type Temp (ºC) Solder resist Soldering Natural cooling Preheating Peak Temp Temp. (ºC) A B Symbol Reflow Soldering Natural cooling Peak Temp C Type Soldering Higher tensile force on the chip capacitor may cause cracking. Maximum amount Minimum amount Small solder fillet may cause contact failure or failure to hold the chip capacitor to the P.C. board. Recommended soldering duration Temp./ Dura. Wave Soldering Reflow Soldering Peak temp (°C) Duration (sec.) Peak temp (°C) Duration (sec.) Sn-Pb Solder 250 max. 3 max. 230 max. 20 max. Lead-Free Solder 260 max. 5 max. 260 max. 10 max. Solder Recommended solder compositions Sn-37Pb (Sn-Pb solder) Sn-3.0Ag-0.5Cu (Lead Free Solder) Preheating Condition Soldering Wave soldering Reflow soldering Manual soldering Page 102 Case Size - JIS (EIA) Temp. (ºC) C1608(CC0603), C2012(CC0805), C3216(CC1206) ∆T ≤ 150 C1005(CC0402), C1608(CC0603), C2012(CC0805), C3216(CC1206) ∆T ≤ 150 C3225(CC1210), C4532(CC1812), C5750(CC2220) ∆T ≤ 130 C1005(CC0402), C1608(CC0603), C2012(CC0805), C3216(CC1206) ∆T ≤ 150 C3225(CC1210), C4532(CC1812), C5750(CC2220) ∆T ≤ 130 Version B11 Packaging Information C Series – Mid Voltage Application • Carrier Tape Configuration Bulk 160mm min. Bulk 160mm min Chips Leader Drawing direction 400mm min • Peel Back Force (Top Tape) Direction & angle of pull Top cover tape Carrier tape 0.05 – 0.7 N 0~15° • Carrier tape shall be flexible enough to be wound around a minimum radius of 30mm with components in tape. • The missing of components shall be less than 0.1% • Components shall not stick to the cover tape. • The cover tape shall not protrude beyond the edges of the carrier tape not shall cover the sprocket holes. • Chip Quantity Per Reel and Structure of Reel (Paper & Plastic) Paper Carrier Tape & Reel Top cover tape Pitch hole Case Code JIS EIA C1005 CC0402 C1608 CC0603 C2012 C3216 CC0805 CC1206 Paper carrier tape Bottom cover tape C3225 CC1210 Plastic Carrier Tape & Reel Top cover tape Pitch hole C4532 CC1812 Plastic carrier tape C5750 TDK MLCC US Catalog CC2220 Chip Thickness 0.50 mm 0.80 mm 0.60 mm 0.85 mm 1.25 mm 0.60 mm 0.85 mm 1.15 mm 1.30 mm 1.60 mm 1.15 mm 1.25 mm 1.30 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm 2.80 mm 3.20 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm 2.80 mm Page 103 Taping Material Paper Paper Paper/Plastic Plastic Paper Paper/Plastic Plastic Chip quantity (pcs.) φ178mm (7”) reel φ330mm (13”) reel 10,000 50,000 4,000 10,000 20,000 4,000 10,000 2,000 4,000 10,000 2,000 2,000 8,000 10,000 2,000 8,000 1,000 5,000 Plastic 1,000 3,000 Plastic 500 2,000 1,000 Plastic 3,000 500 2,000 Version B11 Additional Information C Series – Mid Voltage Application • Shape & Dimensions • Inside Structure & Material System 3 4 Terminal electrode L B B G W 5 T Case Code JIS EIA C1005 CC0402 C1608 CC0603 C2012 CC0805 L 1.00 1.60 2.00 C3216 CC1206 3.20 C3225 CC1210 3.20 C4532 CC1812 4.50 C5750 CC2220 5.70 TDK MLCC US Catalog Dimensions (mm) W T B 0.50 0.50 0.25 0.80 0.80 0.20 0.60 0.20 1.20 0.85 min. 1.25 0.60 0.85 0.20 1.60 1.15 min. 1.30 1.60 0.20 1.15 min. 1.25 0.30 min. 1.30 2.50 1.60 0.20 min. 2.00 2.30 0.30 min. 2.50 1.60 0.20 2.00 min. 2.30 3.20 2.50 0.30 2.80 min. 3.20 1.60 2.00 0.20 5.00 2.30 min. 2.50 2.80 2 1 Internal electrode Ceramic dielectric No. G 0.35 min. 0.30 min. 0.50 min. NAME (1) Ceramic Dielectric (2) Internal Electrode (3) (4) MATERIAL Class 1 Class 2 CaZrO3 BaTiO3 Nickel (Ni) Copper (Cu) Termination (5) Nickel (Ni) Tin (Sn) • Environmental Information 1.00 min. TDK Corporation established internal product environmental assurance standards that include the six hazardous substances banned by the EU RoHS Directive1 enforced on July 1, 2006 along with additional substances independently banned by TDK and has successfully completed making general purpose electronic components conform to the RoHS Directive2. 1.00 min 1. Abbreviation for Restriction on Hazardous Substances, which refers to the regulation EU Directive 2002/95/EC on hazardous substances by the European Union (EU) effective from July 1, 2006. The Directive bans the use of six specific hazardous substances in electric and electronic devices and products handled within the EU. The six substances are lead, mercury, cadmium, hexavalent chromium, PBB (polybrominated biphenyls), and PBDE (polybrominated diphenyl ethers). 2. This means that, in conformity with the EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. 2.00 min 2.00 min. For REACH (SVHC : 15 substances according to ECHA / October 2008) : All TDK MLCC do not contain these 15 substances. For European Directive 2000/53/CE and 2005/673/CE : Cadmium, Hexavalent Chromium, Mercury, Lead are not contained in all TDK MLCC. For European Directive 2003/11/CE : Pentabromodiphenylether, Octabromodiphenyl-ether are not contained in all TDK MLCC. Page 104 Version B11
C4532X7R2A105M/3 价格&库存
很抱歉,暂时无法提供与“C4532X7R2A105M/3”相匹配的价格&库存,您可以联系我们找货
