C5750X7R1H106M230KB..
    TDK(东电化)
    TDK - C5750X7R1H106M230KB.. - SMD Multilayer Ceramic Capacitor, 10 µF, 50 V, 2220 [5650 Metric], ± 2...
C5750X7R1H106M230KB.. 数据手册
Multilayer Ceramic Chip Capacitors General use C series Type: C0402[EIA CC01005] C0603[EIA CC0201] C1005[EIA CC0402] C1608[EIA CC0603] C2012[EIA CC0805] C3216[EIA CC1206] C3225[EIA CC1210] C4532[EIA CC1812] C5750[EIA CC2220] Issue date: September 2011 • All specifications are subject to change without notice. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. (1/30) REMINDERS Please read this before using the product. SAFETY REMINDERS REMINDERS 1. If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other damage, you must contact our company’s sales window. 2. We may modify products or discontinue production of a product listed in this catalog without prior notification. 3. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. 4. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export permission in harmony with this law. 5. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. 6. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. 7. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. 8. The descriptions in this catalog apply as of September, 2011. • All specifications are subject to change without notice. 007-02 / 20110907 / e412_c.fm (2/30) Multilayer Ceramic Chip Capacitors General Use Conformity to RoHS Directive C Series APPLICATION EXAMPLES • Decoupling and ripple filters for general electronic devices • Time constant circuits, resonance circuits, coupling circuits (Products with CH or C0G temperature characteristics are recommended. Use as a replacement for film capacitors is also possible.) SHAPES AND DIMENSIONS W L B T FEATURES • An electrostatic capacity has been obtained that reaches the electrolytic capacitor range through precision technology that enables the use of multiple thinner ceramic dielectric layers. • Since these capacitors are composed of only ceramics and metals and have a monolithic structure, they offer a long service life and high reliability. • Low ESL and excellent frequency characteristics allow for a circuit design that closely conforms to theoretical values. • Low self-heating and high ripple resistance due to low ESR. DIMENSIONS The dimensions of each product are described within the product name. Dimensions L×W The 4-digit number in the product name corresponds to the dimensions of L×W. Refer to the table below for specific values. Dimensions in mm Dimension code L W 0402 0.4±0.02 0.2±0.02 0603 0.6±0.03 0.3±0.03 1005 1.0±0.05 0.5±0.05 1608 1.6±0.1 0.8±0.1 2012 2.0±0.2 1.25±0.2 3216 3.2±0.2 1.6±0.2 3225 3.2±0.4 2.5±0.3 4532 4.5±0.4 3.2±0.4 5750 5.7±0.4 5.0±0.4 • Dimension tolerances are typical values. B 0.07min. 0.1min. 0.1min. 0.2min. 0.2min. 0.2min. 0.2min. 0.2min. 0.2min. Product’s Thickness T The value in parentheses at the end of the product name corresponds to thickness T. Refer to the table of "CAPACITANCE RANGES" for specific values. • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (3/30) PRODUCT IDENTIFICATION C 1005 CH 1H 100 C ( 050 B A ) (1) (2) (3) (4) (5) (6) (7) (8) (9) (1) Series name (5) Nominal capacitance The capacitance is expressed in three digit codes and in units of pico farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. (2) Dimensions L×W 0402 0603 1005 1608 2012 3216 3225 4532 5750 0.4×0.2mm 0.6×0.3mm 1.0×0.5mm 1.6×0.8mm 2.0×1.25mm 3.2×1.6mm 3.2×2.5mm 4.5×3.2mm 5.7×5.0mm (3) Capacitance temperature characteristics Class 1 (Temperature compensation) Temperature characteristics C0G CH Capacitance change Temperature range 0±30ppm/°C 0±60ppm/°C –55 to +125°C –25 to +85°C Class 2 (Temperature stable and general purpose) Temperature characteristics X5R X6S X7R JB Y5V JF Capacitance change Temperature range ±15% ±22% ±15% ±10% +22, –82% +30, –80% –55 to +85°C –55 to +105°C –55 to +125°C –25 to +85°C –30 to +85°C –25 to +85°C (4) Rated voltage Edc 0G 0J 1A 1C 1E 1V 1H 0R5 R75 010 100 471 102 333 474 225 0.5pF 0.75pF 1pF 10pF 470pF 1,000pF 33,000pF 470,000pF 2,200,000pF (2.2µF) (6) Capacitance tolerance Symbol Tolerance B C D J K M Z ±0.1pF ±0.25pF ±0.5pF ±5% ±10% ±20% +80, –20% 10pF or less Over 10pF (7) Dimensions T Expressed by a three-digit number in mm units. The second and third digits denote the first and second decimal places, respectively. 050 085 125 4V 6.3V 10V 16V 25V 35V 50V Applicable capacitance range 0.50mm 0.85mm 1.25mm (8) Packaging style A B C D E F H J K ø178mm reel with 4mm-pitch ø178mm reel with 2mm-pitch ø178mm reel with 1mm-pitch ø330mm reel with 4mm-pitch ø330mm reel with 2mm-pitch ø330mm reel with 1mm-pitch Bulk(bag) ø330mm reel with 8mm-pitch ø178mm reel with 8mm-pitch (9) TDK internal code In brochures issued in August, 2011 and later, the product thickness and packing specifications are described at the end of the ordering name [the product name described in brochures] in parentheses. Since the existing ordering name could not clearly express the product thickness and packing specifications, it has been changed to a new product description method that solves this inconvenience. Please be aware that the last five digits of the ordering name on the delivery label and those in the brochure differ. No changes have been made to the delivery name. (Example) Brochure issued date Prior to July, 2011 August, 2011 or later Ordering name (description in the brochure) C1608X5R1C105K C1608X5R1C105K(080AA) Delivery name (description on the delivery label) C1608X5R1C105KT000N C1608X5R1C105KT000N • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (4/30) CAPACITANCE RANGES: CLASS 1 (TEMPERATURE COMPENSATION) TEMPERATURE CHARACTERISTICS: C0G(0±30ppm/°C) Capacitance Dimension Thickness L×W T(mm) 0402 0603 0.5pF 0.75pF 1pF 1.5pF 2pF 3pF 4pF 5pF 6pF 7pF 8pF 9pF 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 0402 0603 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 0402 0603 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 0402 0603 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 Capacitance Part No. tolerance Rated voltage Edc: 50V Rated voltage Edc: 35V ±0.25pF ±0.25pF C0603C0G1H0R5C(030BA) ±0.1pF C1005C0G1H0R5B(050BA) ±0.25pF C1005C0G1H0R5C(050BA) ±0.25pF C1608C0G1H0R5C(080AA) ±0.25pF ±0.25pF C0603C0G1HR75C(030BA) ±0.1pF C1005C0G1HR75B(050BA) ±0.25pF C1005C0G1HR75C(050BA) ±0.25pF C1608C0G1HR75C(080AA) ±0.25pF ±0.25pF C0603C0G1H010C(030BA) ±0.1pF C1005C0G1H010B(050BA) ±0.25pF C1005C0G1H010C(050BA) ±0.25pF C1608C0G1H010C(080AA) ±0.25pF ±0.25pF C0603C0G1H1R5C(030BA) ±0.1pF C1005C0G1H1R5B(050BA) ±0.25pF C1005C0G1H1R5C(050BA) ±0.25pF C1608C0G1H1R5C(080AA) ±0.25pF ±0.25pF C0603C0G1H020C(030BA) ±0.1pF C1005C0G1H020B(050BA) ±0.25pF C1005C0G1H020C(050BA) ±0.25pF C1608C0G1H020C(080AA) ±0.25pF ±0.25pF C0603C0G1H030C(030BA) ±0.1pF C1005C0G1H030B(050BA) ±0.25pF C1005C0G1H030C(050BA) ±0.25pF C1608C0G1H030C(080AA) ±0.25pF ±0.25pF C0603C0G1H040C(030BA) ±0.1pF C1005C0G1H040B(050BA) ±0.25pF C1005C0G1H040C(050BA) ±0.25pF C1608C0G1H040C(080AA) ±0.25pF ±0.25pF C0603C0G1H050C(030BA) ±0.1pF C1005C0G1H050B(050BA) ±0.25pF C1005C0G1H050C(050BA) ±0.25pF C1608C0G1H050C(080AA) ±0.5pF ±0.5pF C0603C0G1H060D(030BA) ±0.25pF C1005C0G1H060C(050BA) ±0.5pF C1005C0G1H060D(050BA) ±0.25pF C1608C0G1H060C(080AA) ±0.5pF C1608C0G1H060D(080AA) ±0.5pF ±0.5pF C0603C0G1H070D(030BA) ±0.25pF C1005C0G1H070C(050BA) ±0.5pF C1005C0G1H070D(050BA) ±0.25pF C1608C0G1H070C(080AA) ±0.5pF C1608C0G1H070D(080AA) ±0.5pF ±0.5pF C0603C0G1H080D(030BA) ±0.25pF C1005C0G1H080C(050BA) ±0.5pF C1005C0G1H080D(050BA) ±0.25pF C1608C0G1H080C(080AA) ±0.5pF C1608C0G1H080D(080AA) ±0.5pF ±0.5pF C0603C0G1H090D(030BA) ±0.25pF C1005C0G1H090C(050BA) ±0.5pF C1005C0G1H090D(050BA) ±0.25pF C1608C0G1H090C(080AA) ±0.5pF C1608C0G1H090D(080AA) Rated voltage Edc: 25V Rated voltage Edc: 16V C0402C0G1C0R5C(020BA) C0603C0G1E0R5C(030BA) C0402C0G1CR75C(020BA) C0603C0G1ER75C(030BA) C0402C0G1C010C(020BA) C0603C0G1E010C(030BA) C0402C0G1C1R5C(020BA) C0603C0G1E1R5C(030BA) C0402C0G1C020C(020BA) C0603C0G1E020C(030BA) C0402C0G1C030C(020BA) C0603C0G1E030C(030BA) C0402C0G1C040C(020BA) C0603C0G1E040C(030BA) C0402C0G1C050C(020BA) C0603C0G1E050C(030BA) C0402C0G1C060D(020BA) C0603C0G1E060D(030BA) C0402C0G1C070D(020BA) C0603C0G1E070D(030BA) C0402C0G1C080D(020BA) C0603C0G1E080D(030BA) C0402C0G1C090D(020BA) C0603C0G1E090D(030BA) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (5/30) CAPACITANCE RANGES: CLASS 1 (TEMPERATURE COMPENSATION) TEMPERATURE CHARACTERISTICS: C0G(0±30ppm/°C) Capacitance 10pF 12pF 15pF 18pF 22pF 27pF 33pF 39pF 47pF 56pF 68pF 82pF 100pF 120pF 150pF 180pF 220pF 270pF 330pF 390pF 470pF 560pF 680pF 820pF Dimension Thickness L×W T(mm) 0402 0603 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 0402 0603 1005 1608 0402 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 0.20±0.02 0.30±0.03 0.50±0.05 0.80±0.10 0.20±0.02 0.30±0.03 0.50±0.05 0.80±0.10 0.30±0.03 0.50±0.05 0.80±0.10 0.30±0.03 0.50±0.05 0.80±0.10 0.30±0.03 0.50±0.05 0.80±0.10 0.30±0.03 0.50±0.05 0.80±0.10 0.30±0.03 0.50±0.05 0.80±0.10 0.30±0.03 0.50±0.05 0.80±0.10 0.30±0.03 0.50±0.05 0.80±0.10 0.30±0.03 0.50±0.05 0.80±0.10 0.30±0.03 0.50±0.05 0.80±0.10 0.30±0.03 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 Capacitance Part No. tolerance Rated voltage Edc: 50V Rated voltage Edc: 35V ±0.5pF ±0.5pF C0603C0G1H100D(030BA) ±0.25pF C1005C0G1H100C(050BA) ±0.5pF C1005C0G1H100D(050BA) ±0.25pF C1608C0G1H100C(080AA) ±0.5pF C1608C0G1H100D(080AA) ±5% ±5% C0603C0G1H120J(030BA) ±5% C1005C0G1H120J(050BA) ±5% C1608C0G1H120J(080AA) ±5% ±5% C0603C0G1H150J(030BA) ±5% C1005C0G1H150J(050BA) ±5% C1608C0G1H150J(080AA) ±5% C0603C0G1H180J(030BA) ±5% C1005C0G1H180J(050BA) ±5% C1608C0G1H180J(080AA) ±5% C0603C0G1H220J(030BA) ±5% C1005C0G1H220J(050BA) ±5% C1608C0G1H220J(080AA) ±5% C0603C0G1H270J(030BA) ±5% C1005C0G1H270J(050BA) ±5% C1608C0G1H270J(080AA) ±5% C0603C0G1H330J(030BA) ±5% C1005C0G1H330J(050BA) ±5% C1608C0G1H330J(080AA) ±5% C0603C0G1H390J(030BA) ±5% C1005C0G1H390J(050BA) ±5% C1608C0G1H390J(080AA) ±5% C0603C0G1H470J(030BA) ±5% C1005C0G1H470J(050BA) ±5% C1608C0G1H470J(080AA) ±5% C0603C0G1H560J(030BA) ±5% C1005C0G1H560J(050BA) ±5% C1608C0G1H560J(080AA) ±5% C0603C0G1H680J(030BA) ±5% C1005C0G1H680J(050BA) ±5% C1608C0G1H680J(080AA) ±5% C0603C0G1H820J(030BA) ±5% C1005C0G1H820J(050BA) ±5% C1608C0G1H820J(080AA) ±5% C0603C0G1H101J(030BA) ±5% C1005C0G1H101J(050BA) ±5% C1608C0G1H101J(080AA) ±5% C1005C0G1H121J(050BA) ±5% C1608C0G1H121J(080AA) ±5% C1005C0G1H151J(050BA) ±5% C1608C0G1H151J(080AA) ±5% C1005C0G1H181J(050BA) ±5% C1608C0G1H181J(080AA) ±5% C1005C0G1H221J(050BA) ±5% C1608C0G1H221J(080AA) ±5% C1005C0G1H271J(050BA) ±5% C1608C0G1H271J(080AA) ±5% C1005C0G1H331J(050BA) ±5% C1608C0G1H331J(080AA) ±5% C1005C0G1H391J(050BA) ±5% C1608C0G1H391J(080AA) ±5% C1005C0G1H471J(050BA) ±5% C1608C0G1H471J(080AA) ±5% C1005C0G1H561J(050BA) ±5% C1608C0G1H561J(080AA) ±5% C1005C0G1H681J(050BA) ±5% C1608C0G1H681J(080AA) ±5% C1005C0G1H821J(050BA) ±5% C1608C0G1H821J(080AA) Rated voltage Edc: 25V Rated voltage Edc: 16V C0402C0G1C100D(020BA) C0603C0G1E100D(030BA) C0402C0G1C120J(020BA) C0603C0G1E120J(030BA) C0402C0G1C150J(020BA) C0603C0G1E150J(030BA) C0603C0G1E180J(030BA) C0603C0G1E220J(030BA) C0603C0G1E270J(030BA) C0603C0G1E330J(030BA) C0603C0G1E390J(030BA) C0603C0G1E470J(030BA) C0603C0G1E560J(030BA) C0603C0G1E680J(030BA) C0603C0G1E820J(030BA) C0603C0G1E101J(030BA) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (6/30) CAPACITANCE RANGES: CLASS 1 (TEMPERATURE COMPENSATION) TEMPERATURE CHARACTERISTICS: C0G(0±30ppm/°C) Capacitance 1nF 1.2nF 1.5nF 1.8nF 2.2nF 2.7nF 3.3nF Dimension Thickness L×W T(mm) 1005 1608 2012 1608 2012 1608 2012 1608 2012 1608 2012 1608 2012 1608 2012 1608 3.9nF 2012 1608 4.7nF 2012 1608 5.6nF 2012 1608 6.8nF 2012 1608 8.2nF 10nF 15nF 22nF 33nF 47nF 68nF 100nF 150nF 220nF 2012 1608 2012 3216 2012 3216 2012 3216 2012 3216 3216 3225 4532 3216 3225 4532 3216 3225 4532 4532 4532 0.50±0.05 0.80±0.10 0.60±0.10 0.80±0.10 0.60±0.10 0.80±0.10 0.60±0.10 0.80±0.10 0.60±0.10 0.80±0.10 0.60±0.10 0.85±0.10 1.25±0.10 0.80±0.10 0.60±0.10 0.80±0.10 0.60±0.10 0.85±0.10 1.25±0.10 0.80±0.10 0.60±0.10 0.85±0.10 1.25±0.10 0.80±0.10 0.60±0.10 0.85±0.10 1.25±0.10 0.80±0.10 0.60±0.10 0.85±0.10 1.25±0.10 0.80±0.10 0.60±0.10 1.25±0.10 0.80±0.10 0.60±0.10 1.25±0.10 0.80±0.10 0.60±0.10 0.60+0.10/–0.20 0.85±0.10 0.60+0.10/–0.20 1.25±0.10 0.60+0.10/–0.20 1.25±0.10 0.85±0.10 1.15±0.10 2.00±0.20 1.60±0.15 1.60±0.10 2.00±0.20 1.60±0.15 1.60±0.20 2.50±0.30 2.00±0.20 2.50±0.30 3.20±0.30 Capacitance Part No. tolerance Rated voltage Edc: 50V ±5% C1005C0G1H102J(050BA) ±5% C1608C0G1H102J(080AA) ±5% C2012C0G1H102J(060AA) ±5% C1608C0G1H122J(080AA) ±5% C2012C0G1H122J(060AA) ±5% C1608C0G1H152J(080AA) ±5% C2012C0G1H152J(060AA) ±5% C1608C0G1H182J(080AA) ±5% C2012C0G1H182J(060AA) ±5% C1608C0G1H222J(080AA) ±5% C2012C0G1H222J(060AA) ±5% C2012C0G1H222J(085AA) ±5% C2012C0G1H222J(125AA) ±5% C1608C0G1H272J(080AA) ±5% C2012C0G1H272J(060AA) ±5% C1608C0G1H332J(080AA) ±5% C2012C0G1H332J(060AA) ±5% C2012C0G1H332J(085AA) ±5% C2012C0G1H332J(125AA) ±5% C1608C0G1H392J(080AA) ±5% C2012C0G1H392J(060AA) ±5% C2012C0G1H392J(085AA) ±5% C2012C0G1H392J(125AA) ±5% C1608C0G1H472J(080AA) ±5% C2012C0G1H472J(060AA) ±5% C2012C0G1H472J(085AA) ±5% C2012C0G1H472J(125AA) ±5% C1608C0G1H562J(080AA) ±5% C2012C0G1H562J(060AA) ±5% C2012C0G1H562J(085AA) ±5% C2012C0G1H562J(125AA) ±5% C1608C0G1H682J(080AA) ±5% C2012C0G1H682J(060AA) ±5% C2012C0G1H682J(125AA) ±5% C1608C0G1H822J(080AA) ±5% C2012C0G1H822J(060AA) ±5% C2012C0G1H822J(125AA) ±5% C1608C0G1H103J(080AA) ±5% C2012C0G1H103J(060AA) ±5% C3216C0G1H103J(060AA) ±5% C2012C0G1H153J(085AA) ±5% C3216C0G1H153J(060AA) ±5% C2012C0G1H223J(125AA) ±5% C3216C0G1H223J(060AA) ±5% C2012C0G1H333J(125AA) ±5% C3216C0G1H333J(085AA) ±5% C3216C0G1H473J(115AA) ±5% C3225C0G1H473J(200AA) ±5% C4532C0G1H473J(160KA) ±5% C3216C0G1H683J(160AA) ±5% C3225C0G1H683J(200AA) ±5% C4532C0G1H683J(160KA) ±5% C3216C0G1H104J(160AA) ±5% C3225C0G1H104J(250AA) ±5% C4532C0G1H104J(200KA) ±5% C4532C0G1H154J(250KA) ±5% C4532C0G1H224J(320KA) Rated voltage Edc: 35V Rated voltage Edc: 25V Rated voltage Edc: 16V • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (7/30) CAPACITANCE RANGES: CLASS 1 (TEMPERATURE COMPENSATION) TEMPERATURE CHARACTERISTICS: CH(0±60ppm/°C) Capacitance 0.5pF 0.75pF 1pF 1.5pF 2pF 3pF 4pF 5pF 6pF 7pF 8pF 9pF Dimension Thickness L×W T(mm) 0402 0603 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 0402 0603 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 0402 0603 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 0402 0603 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 Capacitance Part No. tolerance Rated voltage Edc: 50V ±0.25pF ±0.25pF C0603CH1H0R5C(030BA) ±0.1pF C1005CH1H0R5B(050BA) ±0.25pF C1005CH1H0R5C(050BA) ±0.25pF C1608CH1H0R5C(080AA) ±0.25pF ±0.25pF C0603CH1HR75C(030BA) ±0.1pF C1005CH1HR75B(050BA) ±0.25pF C1005CH1HR75C(050BA) ±0.25pF C1608CH1HR75C(080AA) ±0.25pF ±0.25pF C0603CH1H010C(030BA) ±0.1pF C1005CH1H010B(050BA) ±0.25pF C1005CH1H010C(050BA) ±0.25pF C1608CH1H010C(080AA) ±0.25pF ±0.25pF C0603CH1H1R5C(030BA) ±0.1pF C1005CH1H1R5B(050BA) ±0.25pF C1005CH1H1R5C(050BA) ±0.25pF C1608CH1H1R5C(080AA) ±0.25pF ±0.25pF C0603CH1H020C(030BA) ±0.1pF C1005CH1H020B(050BA) ±0.25pF C1005CH1H020C(050BA) ±0.25pF C1608CH1H020C(080AA) ±0.25pF ±0.25pF C0603CH1H030C(030BA) ±0.1pF C1005CH1H030B(050BA) ±0.25pF C1005CH1H030C(050BA) ±0.25pF C1608CH1H030C(080AA) ±0.25pF ±0.25pF C0603CH1H040C(030BA) ±0.1pF C1005CH1H040B(050BA) ±0.25pF C1005CH1H040C(050BA) ±0.25pF C1608CH1H040C(080AA) ±0.25pF ±0.25pF C0603CH1H050C(030BA) ±0.1pF C1005CH1H050B(050BA) ±0.25pF C1005CH1H050C(050BA) ±0.25pF C1608CH1H050C(080AA) ±0.5pF ±0.5pF C0603CH1H060D(030BA) ±0.25pF C1005CH1H060C(050BA) ±0.5pF C1005CH1H060D(050BA) ±0.25pF C1608CH1H060C(080AA) ±0.5pF C1608CH1H060D(080AA) ±0.5pF ±0.5pF C0603CH1H070D(030BA) ±0.25pF C1005CH1H070C(050BA) ±0.5pF C1005CH1H070D(050BA) ±0.25pF C1608CH1H070C(080AA) ±0.5pF C1608CH1H070D(080AA) ±0.5pF ±0.5pF C0603CH1H080D(030BA) ±0.25pF C1005CH1H080C(050BA) ±0.5pF C1005CH1H080D(050BA) ±0.25pF C1608CH1H080C(080AA) ±0.5pF C1608CH1H080D(080AA) ±0.5pF ±0.5pF C0603CH1H090D(030BA) ±0.25pF C1005CH1H090C(050BA) ±0.5pF C1005CH1H090D(050BA) ±0.25pF C1608CH1H090C(080AA) ±0.5pF C1608CH1H090D(080AA) Rated voltage Edc: 35V Rated voltage Edc: 25V Rated voltage Edc: 16V C0402CH1C0R5C(020BA) C0603CH1E0R5C(030BA) C0402CH1CR75C(020BA) C0603CH1ER75C(030BA) C0402CH1C010C(020BA) C0603CH1E010C(030BA) C0402CH1C1R5C(020BA) C0603CH1E1R5C(030BA) C0402CH1C020C(020BA) C0603CH1E020C(030BA) C0402CH1C030C(020BA) C0603CH1E030C(030BA) C0402CH1C040C(020BA) C0603CH1E040C(030BA) C0402CH1C050C(020BA) C0603CH1E050C(030BA) C0402CH1C060D(020BA) C0603CH1E060D(030BA) C0402CH1C070D(020BA) C0603CH1E070D(030BA) C0402CH1C080D(020BA) C0603CH1E080D(030BA) C0402CH1C090D(020BA) C0603CH1E090D(030BA) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (8/30) CAPACITANCE RANGES: CLASS 1 (TEMPERATURE COMPENSATION) TEMPERATURE CHARACTERISTICS: CH(0±60ppm/°C) Capacitance 10pF 12pF 15pF 18pF 22pF 27pF 33pF 39pF 47pF 56pF 68pF 82pF 100pF 120pF 150pF 180pF 220pF 270pF 330pF 390pF 470pF 560pF 680pF 820pF Dimension Thickness L×W T(mm) 0402 0603 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 0402 0603 1005 1608 0402 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 0.20±0.02 0.30±0.03 0.50±0.05 0.80±0.10 0.20±0.02 0.30±0.03 0.50±0.05 0.80±0.10 0.30±0.03 0.50±0.05 0.80±0.10 0.30±0.03 0.50±0.05 0.80±0.10 0.30±0.03 0.50±0.05 0.80±0.10 0.30±0.03 0.50±0.05 0.80±0.10 0.30±0.03 0.50±0.05 0.80±0.10 0.30±0.03 0.50±0.05 0.80±0.10 0.30±0.03 0.50±0.05 0.80±0.10 0.30±0.03 0.50±0.05 0.80±0.10 0.30±0.03 0.50±0.05 0.80±0.10 0.30±0.03 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 Capacitance Part No. tolerance Rated voltage Edc: 50V ±0.5pF ±0.5pF C0603CH1H100D(030BA) ±0.25pF C1005CH1H100C(050BA) ±0.5pF C1005CH1H100D(050BA) ±0.25pF C1608CH1H100C(080AA) ±0.5pF C1608CH1H100D(080AA) ±5% ±5% C0603CH1H120J(030BA) ±5% C1005CH1H120J(050BA) ±5% C1608CH1H120J(080AA) ±5% ±5% C0603CH1H150J(030BA) ±5% C1005CH1H150J(050BA) ±5% C1608CH1H150J(080AA) ±5% C0603CH1H180J(030BA) ±5% C1005CH1H180J(050BA) ±5% C1608CH1H180J(080AA) ±5% C0603CH1H220J(030BA) ±5% C1005CH1H220J(050BA) ±5% C1608CH1H220J(080AA) ±5% C0603CH1H270J(030BA) ±5% C1005CH1H270J(050BA) ±5% C1608CH1H270J(080AA) ±5% C0603CH1H330J(030BA) ±5% C1005CH1H330J(050BA) ±5% C1608CH1H330J(080AA) ±5% C0603CH1H390J(030BA) ±5% C1005CH1H390J(050BA) ±5% C1608CH1H390J(080AA) ±5% C0603CH1H470J(030BA) ±5% C1005CH1H470J(050BA) ±5% C1608CH1H470J(080AA) ±5% C0603CH1H560J(030BA) ±5% C1005CH1H560J(050BA) ±5% C1608CH1H560J(080AA) ±5% C0603CH1H680J(030BA) ±5% C1005CH1H680J(050BA) ±5% C1608CH1H680J(080AA) ±5% C0603CH1H820J(030BA) ±5% C1005CH1H820J(050BA) ±5% C1608CH1H820J(080AA) ±5% C0603CH1H101J(030BA) ±5% C1005CH1H101J(050BA) ±5% C1608CH1H101J(080AA) ±5% C1005CH1H121J(050BA) ±5% C1608CH1H121J(080AA) ±5% C1005CH1H151J(050BA) ±5% C1608CH1H151J(080AA) ±5% C1005CH1H181J(050BA) ±5% C1608CH1H181J(080AA) ±5% C1005CH1H221J(050BA) ±5% C1608CH1H221J(080AA) ±5% C1005CH1H271J(050BA) ±5% C1608CH1H271J(080AA) ±5% C1005CH1H331J(050BA) ±5% C1608CH1H331J(080AA) ±5% C1005CH1H391J(050BA) ±5% C1608CH1H391J(080AA) ±5% C1005CH1H471J(050BA) ±5% C1608CH1H471J(080AA) ±5% C1005CH1H561J(050BA) ±5% C1608CH1H561J(080AA) ±5% C1005CH1H681J(050BA) ±5% C1608CH1H681J(080AA) ±5% C1005CH1H821J(050BA) ±5% C1608CH1H821J(080AA) Rated voltage Edc: 35V Rated voltage Edc: 25V Rated voltage Edc: 16V C0402CH1C100D(020BA) C0603CH1E100D(030BA) C0402CH1C120J(020BA) C0603CH1E120J(030BA) C0402CH1C150J(020BA) C0603CH1E150J(030BA) C0603CH1E180J(030BA) C0603CH1E220J(030BA) C0603CH1E270J(030BA) C0603CH1E330J(030BA) C0603CH1E390J(030BA) C0603CH1E470J(030BA) C0603CH1E560J(030BA) C0603CH1E680J(030BA) C0603CH1E820J(030BA) C0603CH1E101J(030BA) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (9/30) CAPACITANCE RANGES: CLASS 1 (TEMPERATURE COMPENSATION) TEMPERATURE CHARACTERISTICS: CH(0±60ppm/°C) Capacitance 1nF 1.2nF 1.5nF 1.8nF 2.2nF 2.7nF 3.3nF Dimension Thickness L×W T(mm) 1005 1608 2012 1608 2012 1608 2012 1608 2012 1608 2012 1608 2012 1608 2012 1608 3.9nF 2012 1608 4.7nF 2012 1608 5.6nF 2012 1608 6.8nF 2012 1608 8.2nF 10nF 15nF 22nF 33nF 47nF 68nF 100nF 150nF 220nF 2012 1608 2012 3216 2012 3216 2012 3216 2012 3216 3216 3225 4532 3216 3225 4532 3216 3225 4532 4532 4532 0.50±0.05 0.80±0.10 0.60±0.10 0.80±0.10 0.60±0.10 0.80±0.10 0.60±0.10 0.80±0.10 0.60±0.10 0.80±0.10 0.60±0.10 0.85±0.10 1.25±0.10 0.80±0.10 0.60±0.10 0.80±0.10 0.60±0.10 1.25±0.10 0.80±0.10 0.60±0.10 0.85±0.10 1.25±0.10 0.80±0.10 0.60±0.10 0.85±0.10 1.25±0.10 0.80±0.10 0.60±0.10 0.85±0.10 1.25±0.10 0.80±0.10 0.60±0.10 1.25±0.10 0.80±0.10 0.60±0.10 1.25±0.10 0.80±0.10 0.60±0.10 0.60+0.10/–0.20 0.85±0.10 0.60+0.10/–0.20 1.25±0.10 0.60+0.10/–0.20 1.25±0.20 0.85±0.10 1.15±0.10 2.00±0.20 1.60±0.15 1.60±0.10 2.00±0.20 1.60±0.15 1.60±0.20 2.50±0.30 2.00±0.20 2.50±0.30 3.20±0.30 Capacitance Part No. tolerance Rated voltage Edc: 50V ±5% C1005CH1H102J(050BA) ±5% C1608CH1H102J(080AA) ±5% C2012CH1H102J(060AA) ±5% C1608CH1H122J(080AA) ±5% C2012CH1H122J(060AA) ±5% C1608CH1H152J(080AA) ±5% C2012CH1H152J(060AA) ±5% C1608CH1H182J(080AA) ±5% C2012CH1H182J(060AA) ±5% C1608CH1H222J(080AA) ±5% C2012CH1H222J(060AA) ±5% C2012CH1H222J(085AA) ±5% C2012CH1H222J(125AA) ±5% C1608CH1H272J(080AA) ±5% C2012CH1H272J(060AA) ±5% C1608CH1H332J(080AA) ±5% C2012CH1H332J(060AA) ±5% C2012CH1H332J(125AA) ±5% C1608CH1H392J(080AA) ±5% C2012CH1H392J(060AA) ±5% C2012CH1H392J(085AA) ±5% C2012CH1H392J(125AA) ±5% C1608CH1H472J(080AA) ±5% C2012CH1H472J(060AA) ±5% C2012CH1H472J(085AA) ±5% C2012CH1H472J(125AA) ±5% C1608CH1H562J(080AA) ±5% C2012CH1H562J(060AA) ±5% C2012CH1H562J(085AA) ±5% C2012CH1H562J(125AA) ±5% C1608CH1H682J(080AA) ±5% C2012CH1H682J(060AA) ±5% C2012CH1H682J(125AA) ±5% C1608CH1H822J(080AA) ±5% C2012CH1H822J(060AA) ±5% C2012CH1H822J(125AA) ±5% C1608CH1H103J(080AA) ±5% C2012CH1H103J(060AA) ±5% C3216CH1H103J(060AA) ±5% C2012CH1H153J(085AA) ±5% C3216CH1H153J(060AA) ±5% C2012CH1H223J(125AA) ±5% C3216CH1H223J(060AA) ±5% C2012CH1H333J(125AA) ±5% C3216CH1H333J(085AA) ±5% C3216CH1H473J(115AA) ±5% C3225CH1H473J(200AA) ±5% C4532CH1H473J(160KA) ±5% C3216CH1H683J(160AA) ±5% C3225CH1H683J(200AA) ±5% C4532CH1H683J(160KA) ±5% C3216CH1H104J(160AA) ±5% C3225CH1H104J(250AA) ±5% C4532CH1H104J(200KA) ±5% C4532CH1H154J(250KA) ±5% C4532CH1H224J(320KA) Rated voltage Edc: 35V Rated voltage Edc: 25V Rated voltage Edc: 16V • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (10/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: X5R(±15%) Capacitance Dimension Thickness L×W T(mm) 0402 0.20±0.02 0603 0.30±0.03 0402 0.20±0.02 0603 0.30±0.03 0402 0.20±0.02 0603 0.30±0.03 1005 0.50±0.05 0402 0.20±0.02 0603 0.30±0.03 1005 0.50±0.05 0402 0.20±0.02 0603 0.30±0.03 1005 0.50±0.05 0402 0.20±0.02 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 1005 0.50±0.05 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 100pF 150pF 220pF 330pF 470pF 680pF 1nF 1.5nF 2.2nF 3.3nF 4.7nF 6.8nF 10nF 15nF Capacitance tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Part No. Rated voltage Edc: 50V Rated voltage Edc: 35V Rated voltage Edc: 25V Rated voltage Edc: 16V C0402X5R1C101K(020BA) C0402X5R1C101M(020BA) C0603X5R1E101K(030BA) C0603X5R1E101M(030BA) C0402X5R1C151K(020BA) C0402X5R1C151M(020BA) C0603X5R1E151K(030BA) C0603X5R1E151M(030BA) C0402X5R1C221K(020BA) C0402X5R1C221M(020BA) C0603X5R1E221K(030BA) C0603X5R1E221M(030BA) C1005X5R1H221K(050BA) C1005X5R1H221M(050BA) C0402X5R1C331K(020BA) C0402X5R1C331M(020BA) C0603X5R1E331K(030BA) C0603X5R1E331M(030BA) C1005X5R1H331K(050BA) C1005X5R1H331M(050BA) C0402X5R1C471K(020BA) C0402X5R1C471M(020BA) C0603X5R1E471K(030BA) C0603X5R1E471M(030BA) C1005X5R1H471K(050BA) C1005X5R1H471M(050BA) C0402X5R1C681K(020BA) C0402X5R1C681M(020BA) C0603X5R1E681K(030BA) C0603X5R1E681M(030BA) C1005X5R1H681K(050BA) C1005X5R1H681M(050BA) C0603X5R1E102K(030BA) C0603X5R1E102M(030BA) C1005X5R1H102K(050BA) C1005X5R1H102M(050BA) C0603X5R1E152K(030BA) C0603X5R1E152M(030BA) C1005X5R1H152K(050BA) C1005X5R1H152M(050BA) C0603X5R1E222K(030BA) C0603X5R1E222M(030BA) C1005X5R1H222K(050BA) C1005X5R1H222M(050BA) C0603X5R1E332K(030BA) C0603X5R1E332M(030BA) C1005X5R1H332K(050BA) C1005X5R1H332M(050BA) C0603X5R1C472K(030BA) C0603X5R1C472M(030BA) C1005X5R1H472K(050BA) C1005X5R1H472M(050BA) C1005X5R1H682K(050BA) C1005X5R1H682M(050BA) C1005X5R1H103K(050BB) C1005X5R1H103M(050BB) C1608X5R1H103K(080AA) C1608X5R1H103M(080AA) C1005X5R1H153K(050BB) C1005X5R1H153M(050BB) C1608X5R1H153K(080AA) C1608X5R1H153M(080AA) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (11/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: X5R(±15%) Capacitance Dimension Thickness L×W T(mm) 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 0603 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 2012 0.85±0.10 1005 0.50±0.05 1608 0.80±0.10 2012 0.85±0.10 0603 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 2012 1.25±0.10 1005 0.50±0.05 1608 0.80±0.10 2012 1.25±0.20 1005 0.50±0.05 1608 0.80±0.10 2012 1.25±0.10 1005 0.50±0.05 1608 0.80±0.10 2012 1.25±0.10 22nF 33nF 47nF 68nF 100nF 150nF 220nF 330nF 470nF 680nF Capacitance tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Part No. Rated voltage Edc: 50V Rated voltage Edc: 35V Rated voltage Edc: 25V Rated voltage Edc: 16V C1005X5R1H223K(050BB) C1005X5R1H223M(050BB) C1608X5R1H223K(080AA) C1608X5R1H223M(080AA) C1005X5R1H333K(050BB) C1005X5R1H333M(050BB) C1608X5R1H333K(080AA) C1608X5R1H333M(080AA) C1005X5R1H473K(050BB) C1005X5R1H473M(050BB) C1608X5R1H473K(080AA) C1608X5R1H473M(080AA) C1005X5R1H683K(050BB) C1005X5R1V683K(050BB) C1005X5R1E683K(050BB) C1005X5R1H683M(050BB) C1005X5R1V683M(050BB) C1005X5R1E683M(050BB) C1608X5R1H683K(080AA) C1608X5R1H683M(080AA) C0603X5R1C104K(030BC) C0603X5R1C104M(030BC) C1005X5R1H104K(050BB) C1005X5R1V104K(050BB) C1005X5R1E104K(050BB) C1005X5R1C104K(050BA) C1005X5R1H104M(050BB) C1005X5R1V104M(050BB) C1005X5R1E104M(050BB) C1005X5R1C104M(050BA) C1608X5R1H104K(080AA) C1608X5R1H104M(080AA) C2012X5R1H104K(085AA) C2012X5R1H104M(085AA) C1005X5R1E154K(050BC) C1005X5R1C154K(050BB) C1005X5R1E154M(050BC) C1005X5R1C154M(050BB) C1608X5R1H154K(080AB) C1608X5R1V154K(080AB) C1608X5R1E154K(080AA) C1608X5R1H154M(080AB) C1608X5R1V154M(080AB) C1608X5R1E154M(080AA) C2012X5R1H154K(085AA) C2012X5R1H154M(085AA) C0603X5R1C224K(030BC) C0603X5R1C224M(030BC) C1005X5R1E224K(050BC) C1005X5R1C224K(050BB) C1005X5R1E224M(050BC) C1005X5R1C224M(050BB) C1608X5R1H224K(080AB) C1608X5R1V224K(080AB) C1608X5R1E224K(080AA) C1608X5R1H224M(080AB) C1608X5R1V224M(080AB) C1608X5R1E224M(080AA) C2012X5R1H224K(125AA) C2012X5R1H224M(125AA) C1005X5R1C334K(050BC) C1005X5R1C334M(050BC) C1608X5R1H334K(080AB) C1608X5R1V334K(080AB) C1608X5R1E334K(080AB) C1608X5R1H334M(080AB) C1608X5R1V334M(080AB) C1608X5R1E334M(080AB) C2012X5R1H334K(125AA) C2012X5R1H334M(125AA) C1005X5R1V474K(050BC) C1005X5R1E474K(050BB) C1005X5R1V474M(050BC) C1005X5R1E474M(050BB) C1608X5R1H474K(080AB) C1608X5R1V474K(080AB) C1608X5R1E474K(080AB) C1608X5R1C474K(080AA) C1608X5R1H474M(080AB) C1608X5R1V474M(080AB) C1608X5R1E474M(080AB) C1608X5R1C474M(080AA) C2012X5R1H474K(125AB) C2012X5R1H474M(125AB) C1005X5R1C684K(050BC) C1005X5R1C684M(050BC) C1608X5R1H684K(080AB) C1608X5R1V684K(080AB) C1608X5R1E684K(080AB) C1608X5R1C684K(080AA) C1608X5R1H684M(080AB) C1608X5R1V684M(080AB) C1608X5R1E684M(080AB) C1608X5R1C684M(080AA) C2012X5R1H684K(125AB) C2012X5R1H684M(125AB) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (12/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: X5R(±15%) Capacitance Dimension Thickness L×W T(mm) 1005 0.50±0.05 1608 0.80±0.10 0.85±0.10 1µF 2012 1.25±0.10 1.25±0.20 3216 1.60±0.10 1608 0.80±0.10 0.85±0.10 1.5µF 2012 1.25±0.10 1.25±0.20 3216 1.60±0.10 1608 0.80±0.10 0.85±0.10 2.2µF 2012 1.25±0.20 3216 1.60±0.20 1608 0.80±0.10 0.60±0.10 0.85±0.10 3.3µF 2012 1.25±0.10 1.25±0.20 3216 1.60±0.10 1608 0.80±0.10 0.60±0.10 0.85±0.10 2012 1.25±0.10 1.25±0.20 4.7µF 0.85±0.10 1.15±0.10 3216 1.60±0.10 1.60±0.20 3225 2.50±0.20 0.85±0.10 2012 1.25±0.10 6.8µF 3216 1.60±0.10 4532 2.50±0.30 Capacitance tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Part No. Rated voltage Edc: 50V C1608X5R1H105K(080AB) C1608X5R1H105M(080AB) C2012X5R1H105K(085AB) C2012X5R1H105M(085AB) C2012X5R1H105K(125AB) C2012X5R1H105M(125AB) Rated voltage Edc: 35V Rated voltage Edc: 25V Rated voltage Edc: 16V C1005X5R1C105K(050BC) C1005X5R1C105M(050BC) C1608X5R1V105K(080AB) C1608X5R1E105K(080AB) C1608X5R1C105K(080AA) C1608X5R1V105M(080AB) C1608X5R1E105M(080AB) C1608X5R1C105M(080AA) C2012X5R1V105K(085AB) C2012X5R1V105M(085AB) C2012X5R1E105K(125AA) C2012X5R1E105M(125AA) C3216X5R1H105K(160AA) C3216X5R1H105M(160AA) C1608X5R1E155K(080AC) C1608X5R1C155K(080AB) C1608X5R1E155M(080AC) C1608X5R1C155M(080AB) C2012X5R1E155K(085AC) C2012X5R1E155M(085AC) C2012X5R1H155K(125AB) C2012X5R1V155K(125AB) C2012X5R1H155M(125AB) C2012X5R1V155M(125AB) C2012X5R1E155K(125AA) C2012X5R1C155K(125AA) C2012X5R1E155M(125AA) C2012X5R1C155M(125AA) C3216X5R1H155K(160AB) C3216X5R1H155M(160AB) C2012X5R1H225K(085AB) C2012X5R1H225M(085AB) C2012X5R1H225K(125AB) C2012X5R1H225M(125AB) C3216X5R1H225K(160AB) C3216X5R1H225M(160AB) C1608X5R1V225K(080AC) C1608X5R1V225M(080AC) C2012X5R1V225K(085AB) C2012X5R1V225M(085AB) C2012X5R1V225K(125AB) C2012X5R1V225M(125AB) C1608X5R1E225K(080AC) C1608X5R1C225K(080AB) C1608X5R1E225M(080AC) C1608X5R1C225M(080AB) C2012X5R1E225K(125AC) C2012X5R1C225K(125AA) C2012X5R1E225M(125AC) C2012X5R1C225M(125AA) C1608X5R1C335K(080AC) C1608X5R1C335M(080AC) C2012X5R1C335K(060AC) C2012X5R1C335M(060AC) C2012X5R1E335K(085AC) C2012X5R1C335K(085AB) C2012X5R1E335M(085AC) C2012X5R1C335M(085AB) C2012X5R1E335K(125AB) C2012X5R1C335K(125AB) C2012X5R1E335M(125AB) C2012X5R1C335M(125AB) C2012X5R1H335K(125AB) C2012X5R1H335M(125AB) C3216X5R1H335K(160AB) C3216X5R1H335M(160AB) C2012X5R1V335K(125AB) C2012X5R1V335M(125AB) C3216X5R1V335K(160AB) C3216X5R1V335M(160AB) C1608X5R1C475K(080AC) C1608X5R1C475M(080AC) C2012X5R1C475K(060AC) C2012X5R1C475M(060AC) C2012X5R1E475K(085AC) C2012X5R1C475K(085AB) C2012X5R1E475M(085AC) C2012X5R1C475M(085AB) C2012X5R1E475K(125AB) C2012X5R1C475K(125AB) C2012X5R1E475M(125AB) C2012X5R1C475M(125AB) C2012X5R1H475K(125AB) C2012X5R1H475M(125AB) C3216X5R1H475K(085AB) C3216X5R1H475M(085AB) C2012X5R1V475K(125AB) C2012X5R1V475M(125AB) C3216X5R1V475K(085AB) C3216X5R1V475M(085AB) C3216X5R1E475K(115AB) C3216X5R1E475M(115AB) C3216X5R1E475K(160AA) C3216X5R1E475M(160AA) C3216X5R1H475K(160AB) C3216X5R1V475K(160AB) C3216X5R1H475M(160AB) C3216X5R1V475M(160AB) C3225X5R1H475K(250AB) C3225X5R1H475M(250AB) C2012X5R1C685K(085AC) C2012X5R1C685M(085AC) C2012X5R1E685K(125AC) C2012X5R1C685K(125AB) C2012X5R1E685M(125AC) C2012X5R1C685M(125AB) C3216X5R1H685K(160AB) C3216X5R1V685K(160AB) C3216X5R1E685K(160AB) C3216X5R1H685M(160AB) C3216X5R1V685M(160AB) C3216X5R1E685M(160AB) C4532X5R1H685K(250KA) C4532X5R1H685M(250KA) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (13/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: X5R(±15%) Capacitance Dimension Thickness L×W T(mm) 0.85±0.10 2012 1.25±0.10 0.85±0.10 3216 1.60±0.10 10µF 1.60±0.20 15µF 22µF 3225 2.50±0.20 4532 2.50±0.30 5750 2.30±0.20 2012 3216 3225 4532 2012 3216 3225 1.25±0.10 1.60±0.20 2.50±0.30 2.50±0.30 1.25±0.10 1.60±0.20 2.50±0.30 2.00±0.20 2.50±0.30 2.50±0.30 1.60±0.20 2.50±0.30 2.00±0.20 1.60±0.20 2.30±0.20 4532 33µF 47µF 5750 3216 4532 5750 3216 5750 Capacitance tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% Part No. Rated voltage Edc: 50V Rated voltage Edc: 35V Rated voltage Edc: 25V C2012X5R1E106K(125AC) C2012X5R1E106M(125AC) C3216X5R1E106K(085AC) C3216X5R1E106M(085AC) Rated voltage Edc: 16V C2012X5R1C106K(085AC) C2012X5R1C106M(085AC) C2012X5R1C106K(125AB) C2012X5R1C106M(125AB) C3216X5R1C106K(085AB) C3216X5R1C106M(085AB) C3216X5R1C106K(160AA) C3216X5R1C106M(160AA) C3216X5R1H106K(160AB) C3216X5R1V106K(160AB) C3216X5R1E106K(160AB) C3216X5R1H106M(160AB) C3216X5R1V106M(160AB) C3216X5R1E106M(160AB) C3225X5R1E106K(250AA) C3225X5R1E106M(250AA) C4532X5R1E106K(250KA) C4532X5R1E106M(250KA) C5750X5R1H106K(230KA) C5750X5R1H106M(230KA) C2012X5R1C156M(125AC) C3216X5R1E156M(160AC) C3216X5R1C156M(160AB) C3225X5R1C156M(250AA) C4532X5R1E156M(250KA) C2012X5R1C226M(125AC) C3216X5R1E226M(160AC) C3216X5R1C226M(160AB) C3225X5R1C226M(250AA) C4532X5R1C226M(200KA) C4532X5R1E226M(250KA) C5750X5R1E226M(250KA) C3216X5R1C336M(160AB) C4532X5R1C336M(250KA) C5750X5R1C336M(200KA) C3216X5R1C476M(160AB) C5750X5R1C476M(230KA) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (14/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: X5R(±15%) Capacitance Dimension Thickness L×W T(mm) 1nF 0402 0.20±0.02 1.5nF 0402 0.20±0.02 2.2nF 0402 0.20±0.02 3.3nF 0402 0.20±0.02 4.7nF 0402 0.20±0.02 0402 0.20±0.02 0603 0.30±0.03 0402 0.20±0.02 0603 0.30±0.03 15nF 0603 0.30±0.03 22nF 0603 0.30±0.03 33nF 0603 0.30±0.03 47nF 0603 0.30±0.03 68nF 0603 0.30±0.03 100nF 0603 0.30±0.03 150nF 0603 0.30±0.03 220nF 0603 0.30±0.03 330nF 1005 0.50±0.05 470nF 1005 0.50±0.05 680nF 1005 0.50±0.05 1µF 1005 0.50±0.05 1.5µF 1005 0.50±0.05 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.10 6.8nF 10nF 2.2µF 3.3µF 0.80+0.15/–0.10 1608 0.80±0.10 1005 0.50+0.15/–0.10 1608 0.80±0.10 4.7µF 0.60±0.10 2012 1.25±0.10 1608 6.8µF 0.80±0.10 0.60±0.10 2012 1.25±0.10 Capacitance Part No. tolerance Rated voltage Edc: 10V ±10% C0402X5R1A102K(020BA) ±20% C0402X5R1A102M(020BA) ±10% C0402X5R1A152K(020BA) ±20% C0402X5R1A152M(020BA) ±10% C0402X5R1A222K(020BA) ±20% C0402X5R1A222M(020BA) ±10% ±20% ±10% ±20% ±10% ±20% ±10% C0603X5R1A682K(030BA) ±20% C0603X5R1A682M(030BA) ±10% ±20% ±10% C0603X5R1A103K(030BA) ±20% C0603X5R1A103M(030BA) ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% C1005X5R1A334K(050BC) ±20% C1005X5R1A334M(050BC) ±10% C1005X5R1A474K(050BC) ±20% C1005X5R1A474M(050BC) ±10% C1005X5R1A684K(050BB) ±20% C1005X5R1A684M(050BB) ±10% C1005X5R1A105K(050BB) ±20% C1005X5R1A105M(050BB) ±10% C1005X5R1A155K(050BC) ±20% C1005X5R1A155M(050BC) ±10% C1005X5R1A225K(050BC) ±20% C1005X5R1A225M(050BC) ±10% C1608X5R1A225K(080AC) ±20% C1608X5R1A225M(080AC) ±20% ±10% ±20% ±10% C1608X5R1A335K(080AB) ±20% C1608X5R1A335M(080AB) ±20% ±10% C1608X5R1A475K(080AB) ±20% C1608X5R1A475M(080AB) ±10% C2012X5R1A475K(060AB) ±20% C2012X5R1A475M(060AB) ±10% C2012X5R1A475K(125AA) ±20% C2012X5R1A475M(125AA) ±10% C1608X5R1A685K(080AC) ±20% C1608X5R1A685M(080AC) ±10% C2012X5R1A685K(060AC) ±20% C2012X5R1A685M(060AC) ±10% C2012X5R1A685K(125AC) ±20% C2012X5R1A685M(125AC) Rated voltage Edc: 6.3V Rated voltage Edc: 4V C0402X5R0J332K(020BA) C0402X5R0J332M(020BA) C0402X5R0J472K(020BB) C0402X5R0J472M(020BB) C0402X5R0J682K(020BB) C0402X5R0J682M(020BB) C0402X5R0J103K(020BB) C0402X5R0J103M(020BB) C0603X5R0J153K(030BA) C0603X5R0J153M(030BA) C0603X5R0J223K(030BC) C0603X5R0J223M(030BC) C0603X5R0J333K(030BC) C0603X5R0J333M(030BC) C0603X5R0J473K(030BC) C0603X5R0J473M(030BC) C0603X5R0J683K(030BC) C0603X5R0J683M(030BC) C0603X5R0J104K(030BC) C0603X5R0J104M(030BC) C0603X5R0J154K(030BA) C0603X5R0J154M(030BA) C0603X5R0J224K(030BA) C0603X5R0J224M(030BA) C1005X5R0J105K(050BC) C1005X5R0J105M(050BC) C1005X5R0J155K(050BB) C1005X5R0J155M(050BB) C1005X5R0J225K(050BC) C1005X5R0G225K(050BB) C1005X5R0J225M(050BB) C1005X5R0G225M(050BB) C1608X5R0J225K(080AB) C1608X5R0J225M(080AB) C1005X5R0J335M(050BC) C1005X5R0G335M(050BB) C1608X5R0J335K(080AB) C1608X5R0J335M(080AB) C1005X5R0J475M(050BC) C1005X5R0G475M(050BB) C1608X5R0J475K(080AB) C1608X5R0J475M(080AB) C1608X5R0J685K(080AB) C1608X5R0J685M(080AB) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (15/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: X5R(±15%) Capacitance Dimension Thickness L×W T(mm) 1608 10µF 0.80±0.10 0.85±0.10 2012 1.25±0.20 15µF 22µF 33µF 47µF 68µF 100µF 2012 2012 3216 2012 3216 2012 3216 3225 3216 3225 5750 3216 3225 4532 5750 0.85±0.10 1.25±0.10 0.85±0.10 1.25±0.10 1.60±0.20 1.25±0.20 1.60±0.20 1.25±0.20 1.60±0.20 2.50±0.30 1.60±0.20 2.00±0.20 2.30±0.20 1.60+0.30/–0.10 2.50±0.30 2.80±0.30 2.80±0.30 Capacitance Part No. tolerance Rated voltage Edc: 10V ±10% C1608X5R1A106K(080AC) ±20% C1608X5R1A106M(080AC) ±10% C2012X5R1A106K(085AB) ±20% C2012X5R1A106M(085AB) ±10% C2012X5R1A106K(125AC) ±20% C2012X5R1A106M(125AC) ±20% C2012X5R1A156M(085AC) ±20% C2012X5R1A156M(125AB) ±20% C2012X5R1A226M(085AC) ±10% ±20% C2012X5R1A226M(125AB) ±20% C3216X5R1A226M(160AC) ±20% ±20% C3216X5R1A336M(160AB) ±20% ±20% C3216X5R1A476M(160AB) ±20% C3225X5R1A476M(250AC) ±20% C3216X5R1A686M(160AC) ±20% ±20% C5750X5R1A686M(230KA) ±20% C3216X5R1A107M(160AC) ±20% ±20% C4532X5R1A107M(280KC) ±20% C5750X5R1A107M(280KC) Rated voltage Edc: 6.3V Rated voltage Edc: 4V C1608X5R0J106K(080AB) C1608X5R0J106M(080AB) C2012X5R0J226M(085AB) C2012X5R0J226K(125AB) C2012X5R0J226M(125AB) C2012X5R0J336M(125AC) C2012X5R0J476M(125AC) C3216X5R0J476M(160AC) C3225X5R0J476M(250AA) C3216X5R0J686M(160AB) C3225X5R0J686M(200AC) C3216X5R0J107M(160AB) C3225X5R0J107M(250AC) C4532X5R0J107M(280KA) C5750X5R0J107M(280KA) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (16/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: X6S(±22%) Capacitance Dimension Thickness L×W T(mm) 10nF 1005 0.50±0.05 15nF 1005 0.50±0.05 22nF 1005 0.50±0.05 33nF 1005 0.50±0.05 47nF 1005 0.50±0.05 68nF 1005 0.50±0.05 100nF 1005 0.50±0.05 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 2012 1.25±0.10 1608 0.80±0.10 2012 1.25±0.10 1608 0.80±0.10 150nF 220nF 330nF 470nF 680nF 0.85±0.10 1µF 2012 1.25±0.10 1.5µF 1608 0.80±0.10 2012 1.25±0.10 3216 1.60±0.10 1608 0.80±0.10 0.85±0.10 2.2µF 2012 1.25±0.20 3216 1.60±0.20 1.25±0.10 2012 1.25±0.20 3.3µF 3216 1.60±0.10 Capacitance Part No. tolerance Rated voltage Edc: 50V ±10% C1005X6S1H103K(050BB) ±20% C1005X6S1H103M(050BB) ±10% C1005X6S1H153K(050BB) ±20% C1005X6S1H153M(050BB) ±10% C1005X6S1H223K(050BB) ±20% C1005X6S1H223M(050BB) ±10% C1005X6S1H333K(050BB) ±20% C1005X6S1H333M(050BB) ±10% C1005X6S1H473K(050BB) ±20% C1005X6S1H473M(050BB) ±10% C1005X6S1H683K(050BB) ±20% C1005X6S1H683M(050BB) ±10% C1005X6S1H104K(050BB) ±20% C1005X6S1H104M(050BB) ±10% ±20% ±10% C1608X6S1H154K(080AB) ±20% C1608X6S1H154M(080AB) ±10% ±20% ±10% C1608X6S1H224K(080AB) ±20% C1608X6S1H224M(080AB) ±10% C1608X6S1H334K(080AB) ±20% C1608X6S1H334M(080AB) ±10% ±20% ±10% C1608X6S1H474K(080AB) ±20% C1608X6S1H474M(080AB) ±10% C2012X6S1H474K(125AB) ±20% C2012X6S1H474M(125AB) ±10% C1608X6S1H684K(080AC) ±20% C1608X6S1H684M(080AC) ±10% C2012X6S1H684K(125AB) ±20% C2012X6S1H684M(125AB) ±10% C1608X6S1H105K(080AC) ±20% C1608X6S1H105M(080AC) ±10% C2012X6S1H105K(085AB) ±20% C2012X6S1H105M(085AB) ±10% C2012X6S1H105K(125AB) ±20% C2012X6S1H105M(125AB) ±10% ±20% ±10% C2012X6S1H155K(125AB) ±20% C2012X6S1H155M(125AB) ±10% C3216X6S1H155K(160AB) ±20% C3216X6S1H155M(160AB) ±10% ±20% ±10% C2012X6S1H225K(085AC) ±20% C2012X6S1H225M(085AC) ±10% C2012X6S1H225K(125AB) ±20% C2012X6S1H225M(125AB) ±10% C3216X6S1H225K(160AB) ±20% C3216X6S1H225M(160AB) ±10% ±20% ±10% C2012X6S1H335K(125AC) ±20% C2012X6S1H335M(125AC) ±10% C3216X6S1H335K(160AB) ±20% C3216X6S1H335M(160AB) Rated voltage Edc: 35V Rated voltage Edc: 25V Rated voltage Edc: 16V C1005X6S1V683K(050BB) C1005X6S1V683M(050BB) C1005X6S1V104K(050BB) C1005X6S1V104M(050BB) C1005X6S1E683K(050BB) C1005X6S1E683M(050BB) C1005X6S1E104K(050BB) C1005X6S1E104M(050BB) C1005X6S1E154K(050BC) C1005X6S1C154K(050BB) C1005X6S1E154M(050BC) C1005X6S1C154M(050BB) C1608X6S1V154K(080AB) C1608X6S1V154M(080AB) C1005X6S1E224K(050BC) C1005X6S1C224K(050BB) C1005X6S1E224M(050BC) C1005X6S1C224M(050BB) C1608X6S1V224K(080AB) C1608X6S1V224M(080AB) C1608X6S1V334K(080AB) C1608X6S1E334K(080AB) C1608X6S1V334M(080AB) C1608X6S1E334M(080AB) C1005X6S1C474K(050BC) C1005X6S1C474M(050BC) C1608X6S1V474K(080AB) C1608X6S1E474K(080AB) C1608X6S1V474M(080AB) C1608X6S1E474M(080AB) C1608X6S1V684K(080AB) C1608X6S1E684K(080AB) C1608X6S1C684K(080AB) C1608X6S1V684M(080AB) C1608X6S1E684M(080AB) C1608X6S1C684M(080AB) C1608X6S1V105K(080AB) C1608X6S1V105M(080AB) C2012X6S1V105K(085AB) C2012X6S1V105M(085AB) C1608X6S1E105K(080AB) C1608X6S1C105K(080AC) C1608X6S1E105M(080AB) C1608X6S1C105M(080AC) C2012X6S1E105K(085AB) C2012X6S1E105M(085AB) C1608X6S1C155K(080AC) C1608X6S1C155M(080AC) C2012X6S1V155K(125AB) C2012X6S1V155M(125AB) C1608X6S1C225K(080AC) C1608X6S1C225M(080AC) C2012X6S1V225K(085AB) C2012X6S1E225K(085AB) C2012X6S1C225K(085AB) C2012X6S1V225M(085AB) C2012X6S1E225M(085AB) C2012X6S1C225M(085AB) C2012X6S1V225K(125AB) C2012X6S1E225K(125AB) C2012X6S1V225M(125AB) C2012X6S1E225M(125AB) C2012X6S1C335K(125AB) C2012X6S1C335M(125AB) C2012X6S1V335K(125AB) C2012X6S1E335K(125AB) C2012X6S1V335M(125AB) C2012X6S1E335M(125AB) C3216X6S1V335K(160AB) C3216X6S1V335M(160AB) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (17/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: X6S(±22%) Capacitance Dimension Thickness L×W T(mm) 0.85±0.10 2012 1.25±0.10 1.25±0.20 4.7µF 0.85±0.10 3216 1.60±0.20 3225 2.50±0.20 2012 1.25±0.10 3216 1.60±0.10 2012 1.25±0.10 6.8µF 0.85±0.10 10µF 3216 1.60±0.10 1.60±0.20 15µF 22µF 3216 3216 3225 1.60±0.20 1.60±0.20 2.50±0.30 Capacitance Part No. tolerance Rated voltage Edc: 50V ±10% ±20% ±10% ±20% ±10% C2012X6S1H475K(125AC) ±20% C2012X6S1H475M(125AC) ±10% ±20% ±10% C3216X6S1H475K(160AB) ±20% C3216X6S1H475M(160AB) ±10% C3225X6S1H475K(250AB) ±20% C3225X6S1H475M(250AB) ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±20% ±20% Rated voltage Edc: 35V Rated voltage Edc: 25V Rated voltage Edc: 16V C2012X6S1C475K(085AC) C2012X6S1C475M(085AC) C2012X6S1C475K(125AB) C2012X6S1C475M(125AB) C2012X6S1V475K(125AB) C2012X6S1V475M(125AB) C3216X6S1V475K(085AC) C3216X6S1V475M(085AC) C3216X6S1V475K(160AB) C3216X6S1V475M(160AB) C2012X6S1E475K(125AB) C2012X6S1E475M(125AB) C3216X6S1E475K(085AB) C3216X6S1E475M(085AB) C3216X6S1E475K(160AB) C3216X6S1E475M(160AB) C2012X6S1C685K(125AC) C2012X6S1C685M(125AC) C3216X6S1V685K(160AC) C3216X6S1E685K(160AB) C3216X6S1C685K(160AB) C3216X6S1V685M(160AC) C3216X6S1E685M(160AB) C3216X6S1C685M(160AB) C2012X6S1C106K(125AC) C2012X6S1C106M(125AC) C3216X6S1C106K(085AC) C3216X6S1C106M(085AC) C3216X6S1C106K(160AC) C3216X6S1C106M(160AC) C3216X6S1V106K(160AC) C3216X6S1E106K(160AB) C3216X6S1V106M(160AC) C3216X6S1E106M(160AB) C3216X6S1C156M(160AC) C3216X6S1C226M(160AC) C3225X6S1C226M(250AC) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (18/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: X6S(±22%) Capacitance Dimension Thickness L×W T(mm) 100nF 0603 0.30±0.03 220nF 0603 0.30±0.03 330nF 1005 0.50±0.05 470nF 1005 0.50±0.05 680nF 1005 0.50±0.05 1µF 1005 0.50±0.05 1.5µF 2.2µF 3.3µF 1005 0.50±0.05 1005 0.50±0.05 1608 0.80±0.10 1608 0.80±0.10 1608 0.80±0.10 2012 0.85±0.10 1608 0.80±0.10 4.7µF 0.85±0.10 6.8µF 2012 1.25±0.10 3216 0.85±0.10 1608 0.80+0.20/–0.10 0.80±0.10 0.85±0.10 10µF 2012 1.25±0.10 15µF 22µF 33µF 47µF 68µF 100µF 3216 0.85±0.10 2012 3216 2012 3216 3216 3216 3225 3216 3216 3225 4532 1.25±0.10 1.60±0.20 1.25±0.10 1.60±0.20 1.60±0.20 1.60±0.20 2.50±0.30 1.60±0.20 1.60+0.30/–0.10 2.50±0.30 2.80±0.30 Capacitance Part No. tolerance Rated voltage Edc: 10V ±10% ±20% ±10% ±20% ±10% C1005X6S1A334K(050BB) ±20% C1005X6S1A334M(050BB) ±10% C1005X6S1A474K(050BB) ±20% C1005X6S1A474M(050BB) ±10% C1005X6S1A684K(050BC) ±20% C1005X6S1A684M(050BC) ±10% C1005X6S1A105K(050BC) ±20% C1005X6S1A105M(050BC) ±10% ±20% ±20% ±10% C1608X6S1A225K(080AB) ±20% C1608X6S1A225M(080AB) ±10% C1608X6S1A335K(080AC) ±20% C1608X6S1A335M(080AC) ±10% C1608X6S1A475K(080AC) ±20% C1608X6S1A475M(080AC) ±10% C2012X6S1A475K(085AB) ±20% C2012X6S1A475M(085AB) ±10% ±20% ±10% C2012X6S1A685K(085AC) ±20% C2012X6S1A685M(085AC) ±10% C2012X6S1A685K(125AB) ±20% C2012X6S1A685M(125AB) ±10% C3216X6S1A685K(085AB) ±20% C3216X6S1A685M(085AB) ±20% ±10% ±10% C2012X6S1A106K(085AC) ±20% C2012X6S1A106M(085AC) ±10% C2012X6S1A106K(125AB) ±20% C2012X6S1A106M(125AB) ±10% C3216X6S1A106K(085AB) ±20% C3216X6S1A106M(085AB) ±20% C2012X6S1A156M(125AC) ±20% C3216X6S1A156M(160AB) ±20% C2012X6S1A226M(125AC) ±20% C3216X6S1A226M(160AB) ±20% C3216X6S1A336M(160AC) ±20% C3216X6S1A476M(160AC) ±20% ±20% ±20% ±20% ±20% Rated voltage Edc: 6.3V C0603X6S0J104K(030BC) C0603X6S0J104M(030BC) C0603X6S0J224K(030BC) C0603X6S0J224M(030BC) C1005X6S0J334K(050BB) C1005X6S0J334M(050BB) C1005X6S0J474K(050BC) C1005X6S0J474M(050BC) C1005X6S0J684K(050BB) C1005X6S0J684M(050BB) C1005X6S0J105K(050BB) C1005X6S0J105M(050BB) Rated voltage Edc: 4V C0603X6S0G104K(030BB) C0603X6S0G104M(030BB) C0603X6S0G224K(030BB) C0603X6S0G224M(030BB) C1005X6S0G105K(050BC) C1005X6S0G105M(050BC) C1005X6S0G155K(050BC) C1005X6S0G155M(050BC) C1005X6S0G225M(050BC) C1608X6S0J225K(080AB) C1608X6S0J225M(080AB) C1608X6S0J335K(080AB) C1608X6S0J335M(080AB) C1608X6S0J475K(080AB) C1608X6S0J475M(080AB) C1608X6S0G685K(080AC) C1608X6S0G685M(080AC) C2012X6S0J685K(085AB) C2012X6S0J685M(085AB) C1608X6S0G106M(080AC) C1608X6S0G106K(080AC) C2012X6S0J106K(085AB) C2012X6S0J106M(085AB) C2012X6S0J106K(125AB) C2012X6S0J106M(125AB) C2012X6S0J156M(125AB) C2012X6S0J226M(125AB) C3216X6S0J226M(160AC) C3216X6S0J336M(160AB) C3216X6S0J476M(160AB) C3225X6S0J476M(250AC) C3225X6S0J107M(250AC) C4532X6S0J107M(280KC) C3216X6S0G476M(160AC) C3216X6S0G686M(160AB) C3216X6S0G107M(160AB) C3225X6S0G107M(250AC) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (19/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: X7R(±15%) Capacitance Dimension Thickness L×W T(mm) 100pF 0603 0.30±0.03 150pF 0603 0.30±0.03 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 1005 0.50±0.05 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 220pF 330pF 470pF 680pF 1nF 1.5nF 2.2nF 3.3nF 4.7nF 6.8nF 10nF 15nF 22nF 33nF 47nF 68nF Capacitance Part No. tolerance Rated voltage Edc: 50V ±10% ±20% ±10% ±20% ±10% ±20% ±10% C1005X7R1H221K(050BA) ±20% C1005X7R1H221M(050BA) ±10% ±20% ±10% C1005X7R1H331K(050BA) ±20% C1005X7R1H331M(050BA) ±10% ±20% ±10% C1005X7R1H471K(050BA) ±20% C1005X7R1H471M(050BA) ±10% ±20% ±10% C1005X7R1H681K(050BA) ±20% C1005X7R1H681M(050BA) ±10% ±20% ±10% C1005X7R1H102K(050BA) ±20% C1005X7R1H102M(050BA) ±10% ±20% ±10% C1005X7R1H152K(050BA) ±20% C1005X7R1H152M(050BA) ±10% ±20% ±10% C1005X7R1H222K(050BA) ±20% C1005X7R1H222M(050BA) ±10% ±20% ±10% C1005X7R1H332K(050BA) ±20% C1005X7R1H332M(050BA) ±10% ±20% ±10% C1005X7R1H472K(050BA) ±20% C1005X7R1H472M(050BA) ±10% C1005X7R1H682K(050BA) ±20% C1005X7R1H682M(050BA) ±10% C1005X7R1H103K(050BB) ±20% C1005X7R1H103M(050BB) ±10% C1608X7R1H103K(080AA) ±20% C1608X7R1H103M(080AA) ±10% C1005X7R1H153K(050BB) ±20% C1005X7R1H153M(050BB) ±10% C1608X7R1H153K(080AA) ±20% C1608X7R1H153M(080AA) ±10% C1005X7R1H223K(050BB) ±20% C1005X7R1H223M(050BB) ±10% C1608X7R1H223K(080AA) ±20% C1608X7R1H223M(080AA) ±10% C1005X7R1H333K(050BB) ±20% C1005X7R1H333M(050BB) ±10% C1608X7R1H333K(080AA) ±20% C1608X7R1H333M(080AA) ±10% C1005X7R1H473K(050BB) ±20% C1005X7R1H473M(050BB) ±10% C1608X7R1H473K(080AA) ±20% C1608X7R1H473M(080AA) ±10% C1005X7R1H683K(050BB) ±20% C1005X7R1H683M(050BB) ±10% C1608X7R1H683K(080AA) ±20% C1608X7R1H683M(080AA) Rated voltage Edc: 35V Rated voltage Edc: 25V Rated voltage Edc: 16V C0603X7R1E101K(030BA) C0603X7R1E101M(030BA) C0603X7R1E151K(030BA) C0603X7R1E151M(030BA) C0603X7R1E221K(030BA) C0603X7R1E221M(030BA) C0603X7R1E331K(030BA) C0603X7R1E331M(030BA) C0603X7R1E471K(030BA) C0603X7R1E471M(030BA) C0603X7R1E681K(030BA) C0603X7R1E681M(030BA) C0603X7R1E102K(030BA) C0603X7R1E102M(030BA) C0603X7R1E152K(030BA) C0603X7R1E152M(030BA) C0603X7R1E222K(030BA) C0603X7R1E222M(030BA) C0603X7R1E332K(030BA) C0603X7R1E332M(030BA) C0603X7R1C472K(030BA) C0603X7R1C472M(030BA) C1005X7R1V103K(050BB) C1005X7R1V103M(050BB) C1005X7R1V153K(050BB) C1005X7R1V153M(050BB) C1005X7R1V223K(050BB) C1005X7R1V223M(050BB) C1005X7R1V333K(050BB) C1005X7R1V333M(050BB) C1005X7R1V473K(050BB) C1005X7R1V473M(050BB) C1005X7R1V683K(050BB) C1005X7R1E683K(050BB) C1005X7R1V683M(050BB) C1005X7R1E683M(050BB) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (20/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: X7R(±15%) Capacitance 100nF 150nF 220nF Dimension Thickness L×W T(mm) 1005 0.50±0.05 1608 0.80±0.10 2012 0.85±0.10 1005 0.50±0.05 1608 0.80±0.10 2012 0.85±0.10 1005 0.50±0.05 1608 0.80±0.10 2012 1.25±0.10 1608 0.80±0.10 2012 1.25±0.20 1608 0.80±0.10 2012 1.25±0.10 1608 0.80±0.10 2012 1.25±0.10 1608 0.80±0.10 330nF 470nF 680nF 0.85±0.10 1µF 2012 1.25±0.10 1.25±0.20 3216 1.60±0.10 1.25±0.10 2012 1.25±0.20 1.5µF 3216 1.60±0.10 0.85±0.10 2012 1.25±0.20 2.2µF 3216 1.60±0.20 2012 1.25±0.20 3216 1.60±0.10 3.3µF Capacitance Part No. tolerance Rated voltage Edc: 50V ±10% C1005X7R1H104K(050BB) ±20% C1005X7R1H104M(050BB) ±10% C1608X7R1H104K(080AA) ±20% C1608X7R1H104M(080AA) ±10% C2012X7R1H104K(085AA) ±20% C2012X7R1H104M(085AA) ±10% ±20% ±10% C1608X7R1H154K(080AB) ±20% C1608X7R1H154M(080AB) ±10% C2012X7R1H154K(085AA) ±20% C2012X7R1H154M(085AA) ±10% ±20% ±10% C1608X7R1H224K(080AB) ±20% C1608X7R1H224M(080AB) ±10% C2012X7R1H224K(125AA) ±20% C2012X7R1H224M(125AA) ±10% C1608X7R1H334K(080AC) ±20% C1608X7R1H334M(080AC) ±10% C2012X7R1H334K(125AA) ±20% C2012X7R1H334M(125AA) ±10% C1608X7R1H474K(080AC) ±20% C1608X7R1H474M(080AC) ±10% C2012X7R1H474K(125AB) ±20% C2012X7R1H474M(125AB) ±10% ±20% ±10% C2012X7R1H684K(125AB) ±20% C2012X7R1H684M(125AB) ±10% ±20% ±10% C2012X7R1H105K(085AC) ±20% C2012X7R1H105M(085AC) ±10% C2012X7R1H105K(125AB) ±20% C2012X7R1H105M(125AB) ±10% ±20% ±10% C3216X7R1H105K(160AB) ±20% C3216X7R1H105M(160AB) ±10% C2012X7R1H155K(125AC) ±20% C2012X7R1H155M(125AC) ±10% ±20% ±10% C3216X7R1H155K(160AB) ±20% C3216X7R1H155M(160AB) ±10% ±20% ±10% C2012X7R1H225K(125AC) ±20% C2012X7R1H225M(125AC) ±10% C3216X7R1H225K(160AB) ±20% C3216X7R1H225M(160AB) ±10% ±20% ±10% C3216X7R1H335K(160AC) ±20% C3216X7R1H335M(160AC) Rated voltage Edc: 35V Rated voltage Edc: 25V Rated voltage Edc: 16V C1005X7R1V104K(050BB) C1005X7R1E104K(050BB) C1005X7R1C104K(050BC) C1005X7R1V104M(050BB) C1005X7R1E104M(050BB) C1005X7R1C104M(050BC) C1005X7R1C154K(050BC) C1005X7R1C154M(050BC) C1608X7R1V154K(080AB) C1608X7R1E154K(080AA) C1608X7R1V154M(080AB) C1608X7R1E154M(080AA) C1005X7R1C224K(050BC) C1005X7R1C224M(050BC) C1608X7R1V224K(080AB) C1608X7R1E224K(080AC) C1608X7R1V224M(080AB) C1608X7R1E224M(080AC) C1608X7R1V334K(080AB) C1608X7R1E334K(080AB) C1608X7R1V334M(080AB) C1608X7R1E334M(080AB) C1608X7R1V474K(080AB) C1608X7R1E474K(080AB) C1608X7R1C474K(080AC) C1608X7R1V474M(080AB) C1608X7R1E474M(080AB) C1608X7R1C474M(080AC) C1608X7R1V684K(080AC) C1608X7R1E684K(080AB) C1608X7R1C684K(080AC) C1608X7R1V684M(080AC) C1608X7R1E684M(080AB) C1608X7R1C684M(080AC) C1608X7R1V105K(080AC) C1608X7R1V105M(080AC) C2012X7R1V105K(085AB) C2012X7R1V105M(085AB) C1608X7R1E105K(080AB) C1608X7R1E105M(080AB) C2012X7R1E105K(085AB) C2012X7R1E105M(085AB) C1608X7R1C105K(080AC) C1608X7R1C105M(080AC) C2012X7R1C105K(085AA) C2012X7R1C105M(085AA) C2012X7R1E105K(125AB) C2012X7R1E105M(125AB) C2012X7R1V155K(125AB) C2012X7R1V155M(125AB) C2012X7R1E155K(125AB) C2012X7R1C155K(125AB) C2012X7R1E155M(125AB) C2012X7R1C155M(125AB) C2012X7R1V225K(085AC) C2012X7R1V225M(085AC) C2012X7R1V225K(125AB) C2012X7R1V225M(125AB) C2012X7R1E225K(085AB) C2012X7R1E225M(085AB) C2012X7R1E225K(125AB) C2012X7R1E225M(125AB) C2012X7R1C225K(085AB) C2012X7R1C225M(085AB) C2012X7R1C225K(125AB) C2012X7R1C225M(125AB) C2012X7R1V335K(125AC) C2012X7R1E335K(125AB) C2012X7R1C335K(125AB) C2012X7R1V335M(125AC) C2012X7R1E335M(125AB) C2012X7R1C335M(125AB) C3216X7R1V335K(160AB) C3216X7R1V335M(160AB) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (21/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: X7R(±15%) Capacitance Dimension Thickness L×W T(mm) 2012 1.25±0.20 0.85±0.10 4.7µF 3216 1.60±0.10 1.60±0.20 3225 2.50±0.20 3216 1.60±0.10 4532 2.50±0.30 6.8µF 1.60±0.10 3216 1.60±0.20 10µF 15µF 3225 2.50±0.20 4532 2.50±0.30 5750 2.30±0.20 3225 4532 3225 2.50±0.30 2.50±0.30 2.50±0.30 2.00±0.20 2.50±0.30 2.50±0.30 2.50±0.30 2.00±0.20 2.30±0.20 22µF 4532 33µF 5750 4532 5750 5750 47µF Capacitance Part No. tolerance Rated voltage Edc: 50V ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% C3225X7R1H475K(250AB) ±20% C3225X7R1H475M(250AB) ±10% ±20% ±10% C4532X7R1H685K(250KB) ±20% C4532X7R1H685M(250KB) ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% C5750X7R1H106K(230KB) ±20% C5750X7R1H106M(230KB) ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% Rated voltage Edc: 35V C2012X7R1V475K(125AC) C2012X7R1V475M(125AC) C3216X7R1V475K(085AC) C3216X7R1V475M(085AC) Rated voltage Edc: 25V C2012X7R1E475K(125AB) C2012X7R1E475M(125AB) C3216X7R1E475K(085AB) C3216X7R1E475M(085AB) C3216X7R1E475K(160AC) C3216X7R1E475M(160AC) Rated voltage Edc: 16V C2012X7R1C475K(125AB) C2012X7R1C475M(125AB) C3216X7R1C475K(085AB) C3216X7R1C475M(085AB) C3216X7R1V475K(160AB) C3216X7R1V475M(160AB) C3216X7R1V685K(160AC) C3216X7R1E685K(160AB) C3216X7R1C685K(160AC) C3216X7R1V685M(160AC) C3216X7R1E685M(160AB) C3216X7R1C685M(160AC) C3216X7R1C106K(160AB) C3216X7R1C106M(160AB) C3216X7R1V106K(160AC) C3216X7R1E106K(160AB) C3216X7R1V106M(160AC) C3216X7R1E106M(160AB) C3225X7R1E106K(250AC) C3225X7R1E106M(250AC) C4532X7R1E106K(250KA) C4532X7R1E106M(250KA) C3225X7R1C156M(250AB) C4532X7R1E156M(250KC) C3225X7R1C226M(250AC) C4532X7R1C226M(200KC) C4532X7R1E226M(250KC) C5750X7R1E226M(250KA) C4532X7R1C336M(250KC) C5750X7R1C336M(200KB) C5750X7R1C476M(230KB) TEMPERATURE CHARACTERISTICS: X7R(±15%) Capacitance Dimension Thickness L×W T(mm) 100pF 0402 0.20±0.02 150pF 0402 0.20±0.02 220pF 0402 0.20±0.02 330pF 0402 0.20±0.02 470pF 0402 0.20±0.02 680pF 0402 0.20±0.02 220nF 1005 0.50±0.05 1.5µF 1608 0.80±0.10 2.2µF 1608 0.80±0.10 4.7µF 2012 0.85±0.10 1.25±0.10 6.8µF 2012 1.25±0.10 2012 1.25±0.20 3216 0.85±0.10 10µF Capacitance Part No. tolerance Rated voltage Edc: 10V ±10% C0402X7R1A101K(020BA) ±20% C0402X7R1A101M(020BA) ±10% C0402X7R1A151K(020BA) ±20% C0402X7R1A151M(020BA) ±10% C0402X7R1A221K(020BA) ±20% C0402X7R1A221M(020BA) ±10% C0402X7R1A331K(020BA) ±20% C0402X7R1A331M(020BA) ±10% C0402X7R1A471K(020BA) ±20% C0402X7R1A471M(020BA) ±10% C0402X7R1A681K(020BA) ±20% C0402X7R1A681M(020BA) ±10% C1005X7R1A224K(050BB) ±20% C1005X7R1A224M(050BB) ±10% C1608X7R1A155K(080AC) ±20% C1608X7R1A155M(080AC) ±10% C1608X7R1A225K(080AC) ±20% C1608X7R1A225M(080AC) ±10% C2012X7R1A475K(085AC) ±20% C2012X7R1A475M(085AC) ±10% C2012X7R1A475K(125AC) ±20% C2012X7R1A475M(125AC) ±10% C2012X7R1A685K(125AC) ±20% C2012X7R1A685M(125AC) ±10% C2012X7R1A106K(125AC) ±20% C2012X7R1A106M(125AC) ±10% C3216X7R1A106K(085AC) ±20% C3216X7R1A106M(085AC) Rated voltage Edc: 6.3V Rated voltage Edc: 4V C1608X7R0J155K(080AB) C1608X7R0J155M(080AB) C1608X7R0J225K(080AB) C1608X7R0J225M(080AB) C2012X7R0J475K(085AB) C2012X7R0J475M(085AB) C3216X7R0J106K(085AB) C3216X7R0J106M(085AB) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (22/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: X7S(±22%) Capacitance Dimension Thickness L×W T(mm) 6.8µF 3225 2.50±0.20 10µF 3225 2.50±0.20 Capacitance Part No. tolerance Rated voltage Edc: 50V Rated voltage Edc: 35V ±10% C3225X7S1H685K(250AB) ±20% C3225X7S1H685M(250AB) ±10% C3225X7S1H106K(250AB) ±20% C3225X7S1H106M(250AB) Rated voltage Edc: 25V Rated voltage Edc: 16V TEMPERATURE CHARACTERISTICS: X7S(±22%) Capacitance Dimension Thickness L×W T(mm) 100nF 0603 0.30±0.03 220nF 0603 0.30±0.03 470nF 1005 0.50±0.05 1µF 1005 0.50±0.05 2.2µF 1608 0.80±0.10 4.7µF 1608 0.80±0.10 10µF 2012 0.85±0.10 47µF 3225 2.50±0.30 Capacitance Part No. tolerance Rated voltage Edc: 10V ±10% ±20% ±10% ±20% ±10% C1005X7S1A474K(050BC) ±20% C1005X7S1A474M(050BC) ±10% ±20% ±10% C1608X7S1A225K(080AC) ±20% C1608X7S1A225M(080AC) ±10% ±20% ±10% ±20% ±20% Rated voltage Edc: 6.3V Rated voltage Edc: 4V C0603X7S0G104K(030BC) C0603X7S0G104M(030BC) C0603X7S0G224K(030BC) C0603X7S0G224M(030BC) C1005X7S0J474K(050BB) C1005X7S0J474M(050BB) C1005X7S0G105K(050BC) C1005X7S0G105M(050BC) C1608X7S0J225K(080AB) C1608X7S0J225M(080AB) C1608X7S0G475K(080AC) C1608X7S0G475M(080AC) C2012X7S0G106K(085AC) C2012X7S0G106M(085AC) C3225X7S0J476M(250AC) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (23/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: JB(±10%) Capacitance Dimension Thickness L×W T(mm) 0402 0.20±0.02 0603 0.30±0.03 0402 0.20±0.02 0603 0.30±0.03 0402 0.20±0.02 0603 0.30±0.03 1005 0.50±0.05 0402 0.20±0.02 0603 0.30±0.03 1005 0.50±0.05 0402 0.20±0.02 0603 0.30±0.03 1005 0.50±0.05 0402 0.20±0.02 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 1005 0.50±0.05 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 100pF 150pF 220pF 330pF 470pF 680pF 1nF 1.5nF 2.2nF 3.3nF 4.7nF 6.8nF 10nF 15nF Capacitance Part No. tolerance Rated voltage Edc: 50V ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% C1005JB1H221K(050BA) ±20% C1005JB1H221M(050BA) ±10% ±20% ±10% ±20% ±10% C1005JB1H331K(050BA) ±20% C1005JB1H331M(050BA) ±10% ±20% ±10% ±20% ±10% C1005JB1H471K(050BA) ±20% C1005JB1H471M(050BA) ±10% ±20% ±10% ±20% ±10% C1005JB1H681K(050BA) ±20% C1005JB1H681M(050BA) ±10% ±20% ±10% C1005JB1H102K(050BA) ±20% C1005JB1H102M(050BA) ±10% ±20% ±10% C1005JB1H152K(050BA) ±20% C1005JB1H152M(050BA) ±10% ±20% ±10% C1005JB1H222K(050BA) ±20% C1005JB1H222M(050BA) ±10% ±20% ±10% C1005JB1H332K(050BA) ±20% C1005JB1H332M(050BA) ±10% ±20% ±10% C1005JB1H472K(050BA) ±20% C1005JB1H472M(050BA) ±10% C1005JB1H682K(050BA) ±20% C1005JB1H682M(050BA) ±10% C1005JB1H103K(050BB) ±20% C1005JB1H103M(050BB) ±10% C1608JB1H103K(080AA) ±20% C1608JB1H103M(080AA) ±10% C1005JB1H153K(050BB) ±20% C1005JB1H153M(050BB) ±10% C1608JB1H153K(080AA) ±20% C1608JB1H153M(080AA) Rated voltage Edc: 35V Rated voltage Edc: 25V Rated voltage Edc: 16V C0402JB1C101K(020BA) C0402JB1C101M(020BA) C0603JB1E101K(030BA) C0603JB1E101M(030BA) C0402JB1C151K(020BA) C0402JB1C151M(020BA) C0603JB1E151K(030BA) C0603JB1E151M(030BA) C0402JB1C221K(020BA) C0402JB1C221M(020BA) C0603JB1E221K(030BA) C0603JB1E221M(030BA) C0402JB1C331K(020BA) C0402JB1C331M(020BA) C0603JB1E331K(030BA) C0603JB1E331M(030BA) C0402JB1C471K(020BA) C0402JB1C471M(020BA) C0603JB1E471K(030BA) C0603JB1E471M(030BA) C0402JB1C681K(020BA) C0402JB1C681M(020BA) C0603JB1E681K(030BA) C0603JB1E681M(030BA) C0603JB1E102K(030BA) C0603JB1E102M(030BA) C0603JB1E152K(030BA) C0603JB1E152M(030BA) C0603JB1E222K(030BA) C0603JB1E222M(030BA) C0603JB1E332K(030BA) C0603JB1E332M(030BA) C0603JB1C472K(030BA) C0603JB1C472M(030BA) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (24/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: JB(±10%) Capacitance Dimension Thickness L×W T(mm) 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 0603 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 2012 0.85±0.10 1005 0.50±0.05 1608 0.80±0.10 2012 0.85±0.10 0603 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 2012 1.25±0.10 1005 0.50±0.05 1608 0.80±0.10 2012 1.25±0.20 1005 0.50±0.05 1608 0.80±0.10 2012 1.25±0.10 1005 0.50±0.05 1608 0.80±0.10 2012 1.25±0.10 22nF 33nF 47nF 68nF 100nF 150nF 220nF 330nF 470nF 680nF Capacitance Part No. tolerance Rated voltage Edc: 50V ±10% C1005JB1H223K(050BB) ±20% C1005JB1H223M(050BB) ±10% C1608JB1H223K(080AA) ±20% C1608JB1H223M(080AA) ±10% C1005JB1H333K(050BB) ±20% C1005JB1H333M(050BB) ±10% C1608JB1H333K(080AA) ±20% C1608JB1H333M(080AA) ±10% C1005JB1H473K(050BB) ±20% C1005JB1H473M(050BB) ±10% C1608JB1H473K(080AA) ±20% C1608JB1H473M(080AA) ±10% C1005JB1H683K(050BB) ±20% C1005JB1H683M(050BB) ±10% C1608JB1H683K(080AA) ±20% C1608JB1H683M(080AA) ±10% ±20% ±10% C1005JB1H104K(050BB) ±20% C1005JB1H104M(050BB) ±10% C1608JB1H104K(080AA) ±20% C1608JB1H104M(080AA) ±10% C2012JB1H104K(085AA) ±20% C2012JB1H104M(085AA) ±10% ±20% ±10% C1608JB1H154K(080AB) ±20% C1608JB1H154M(080AB) ±10% C2012JB1H154K(085AA) ±20% C2012JB1H154M(085AA) ±10% ±20% ±10% ±20% ±10% C1608JB1H224K(080AB) ±20% C1608JB1H224M(080AB) ±10% C2012JB1H224K(125AA) ±20% C2012JB1H224M(125AA) ±10% ±20% ±10% C1608JB1H334K(080AB) ±20% C1608JB1H334M(080AB) ±10% C2012JB1H334K(125AA) ±20% C2012JB1H334M(125AA) ±10% ±20% ±10% C1608JB1H474K(080AB) ±20% C1608JB1H474M(080AB) ±10% C2012JB1H474K(125AB) ±20% C2012JB1H474M(125AB) ±10% ±20% ±10% C1608JB1H684K(080AB) ±20% C1608JB1H684M(080AB) ±10% C2012JB1H684K(125AB) ±20% C2012JB1H684M(125AB) Rated voltage Edc: 35V Rated voltage Edc: 25V Rated voltage Edc: 16V C1005JB1V683K(050BB) C1005JB1V683M(050BB) C1005JB1E683K(050BB) C1005JB1E683M(050BB) C1005JB1V104K(050BB) C1005JB1V104M(050BB) C1005JB1E104K(050BB) C1005JB1E104M(050BB) C1608JB1V154K(080AB) C1608JB1V154M(080AB) C1005JB1E154K(050BC) C1005JB1E154M(050BC) C1608JB1E154K(080AA) C1608JB1E154M(080AA) C1608JB1V224K(080AB) C1608JB1V224M(080AB) C1005JB1E224K(050BC) C1005JB1E224M(050BC) C1608JB1E224K(080AA) C1608JB1E224M(080AA) C0603JB1C104K(030BC) C0603JB1C104M(030BC) C1005JB1C104K(050BA) C1005JB1C104M(050BA) C1005JB1C154K(050BB) C1005JB1C154M(050BB) C0603JB1C224K(030BC) C0603JB1C224M(030BC) C1005JB1C224K(050BB) C1005JB1C224M(050BB) C1005JB1C334K(050BC) C1005JB1C334M(050BC) C1608JB1V334K(080AB) C1608JB1V334M(080AB) C1608JB1E334K(080AB) C1608JB1E334M(080AB) C1005JB1V474K(050BC) C1005JB1V474M(050BC) C1608JB1V474K(080AB) C1608JB1V474M(080AB) C1005JB1E474K(050BB) C1005JB1E474M(050BB) C1608JB1E474K(080AB) C1608JB1E474M(080AB) C1608JB1C474K(080AA) C1608JB1C474M(080AA) C1608JB1E684K(080AB) C1608JB1E684M(080AB) C1005JB1C684K(050BC) C1005JB1C684M(050BC) C1608JB1C684K(080AA) C1608JB1C684M(080AA) C1608JB1V684K(080AB) C1608JB1V684M(080AB) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (25/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: JB(±10%) Capacitance Dimension Thickness L×W T(mm) 1005 0.50±0.05 1608 0.80±0.10 0.85±0.10 1µF 2012 1.25±0.10 3216 1.60±0.10 1608 0.80±0.10 0.85±0.10 1.5µF 2012 1.25±0.10 3216 1.60±0.10 1608 0.80±0.10 0.85±0.10 2.2µF 2012 1.25±0.10 1.25±0.20 3216 1.60±0.20 1608 0.80±0.10 0.60±0.10 0.85±0.10 3.3µF 2012 1.25±0.10 1.25±0.20 3216 1.60±0.10 1608 0.80±0.10 0.60±0.10 0.85±0.10 2012 1.25±0.10 1.25±0.20 4.7µF 0.85±0.10 1.15±0.10 3216 1.60±0.10 1.60±0.20 3225 2.50±0.20 0.85±0.10 2012 1.25±0.10 6.8µF 3216 1.60±0.10 4532 2.50±0.30 Capacitance Part No. tolerance Rated voltage Edc: 50V ±10% ±20% ±10% C1608JB1H105K(080AB) ±20% C1608JB1H105M(080AB) ±10% C2012JB1H105K(085AB) ±20% C2012JB1H105M(085AB) ±10% C2012JB1H105K(125AB) ±20% C2012JB1H105M(125AB) ±10% C3216JB1H105K(160AA) ±20% C3216JB1H105M(160AA) ±10% ±20% ±10% ±20% ±10% C2012JB1H155K(125AB) ±20% C2012JB1H155M(125AB) ±10% C3216JB1H155K(160AB) ±20% C3216JB1H155M(160AB) ±10% ±20% ±10% C2012JB1H225K(085AB) ±20% C2012JB1H225M(085AB) ±10% ±20% ±10% C2012JB1H225K(125AB) ±20% C2012JB1H225M(125AB) ±10% C3216JB1H225K(160AB) ±20% C3216JB1H225M(160AB) ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% C2012JB1H335K(125AB) ±20% C2012JB1H335M(125AB) ±10% C3216JB1H335K(160AB) ±20% C3216JB1H335M(160AB) ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% C2012JB1H475K(125AB) ±20% C2012JB1H475M(125AB) ±10% C3216JB1H475K(085AB) ±20% C3216JB1H475M(085AB) ±10% ±20% ±10% ±20% ±10% C3216JB1H475K(160AB) ±20% C3216JB1H475M(160AB) ±10% C3225JB1H475K(250AB) ±20% C3225JB1H475M(250AB) ±10% ±20% ±10% ±20% ±10% C3216JB1H685K(160AB) ±20% C3216JB1H685M(160AB) ±10% C4532JB1H685K(250KA) ±20% C4532JB1H685M(250KA) Rated voltage Edc: 35V Rated voltage Edc: 25V C1608JB1V105K(080AB) C1608JB1V105M(080AB) C2012JB1V105K(085AB) C2012JB1V105M(085AB) C1608JB1E105K(080AB) C1608JB1E105M(080AB) C2012JB1E105K(085AC) C2012JB1E105M(085AC) C2012JB1E105K(125AA) C2012JB1E105M(125AA) C2012JB1V155K(125AB) C2012JB1V155M(125AB) C1608JB1V225K(080AC) C1608JB1V225M(080AC) C2012JB1V225K(085AB) C2012JB1V225M(085AB) Rated voltage Edc: 16V C1005JB1C105K(050BC) C1005JB1C105M(050BC) C1608JB1C105K(080AA) C1608JB1C105M(080AA) C2012JB1C105K(085AC) C2012JB1C105M(085AC) C1608JB1E155K(080AC) C1608JB1E155M(080AC) C2012JB1E155K(085AC) C2012JB1E155M(085AC) C2012JB1E155K(125AB) C2012JB1E155M(125AB) C1608JB1C155K(080AB) C1608JB1C155M(080AB) C2012JB1C155K(125AA) C2012JB1C155M(125AA) C1608JB1E225K(080AC) C1608JB1E225M(080AC) C1608JB1C225K(080AB) C1608JB1C225M(080AB) C2012JB1E225K(125AC) C2012JB1E225M(125AC) C2012JB1C225K(125AA) C2012JB1C225M(125AA) C2012JB1E335K(085AC) C2012JB1E335M(085AC) C2012JB1E335K(125AB) C2012JB1E335M(125AB) C1608JB1C335K(080AC) C1608JB1C335M(080AC) C2012JB1C335K(060AC) C2012JB1C335M(060AC) C2012JB1C335K(085AB) C2012JB1C335M(085AB) C2012JB1C335K(125AB) C2012JB1C335M(125AB) C2012JB1E475K(085AC) C2012JB1E475M(085AC) C2012JB1E475K(125AB) C2012JB1E475M(125AB) C1608JB1C475K(080AC) C1608JB1C475M(080AC) C2012JB1C475K(060AC) C2012JB1C475M(060AC) C2012JB1C475K(085AB) C2012JB1C475M(085AB) C2012JB1C475K(125AB) C2012JB1C475M(125AB) C2012JB1V225K(125AB) C2012JB1V225M(125AB) C2012JB1V335K(125AB) C2012JB1V335M(125AB) C3216JB1V335K(160AB) C3216JB1V335M(160AB) C2012JB1V475K(125AB) C2012JB1V475M(125AB) C3216JB1V475K(085AB) C3216JB1V475M(085AB) C3216JB1E475K(115AB) C3216JB1E475M(115AB) C3216JB1E475K(160AA) C3216JB1E475M(160AA) C3216JB1V475K(160AB) C3216JB1V475M(160AB) C3216JB1V685K(160AB) C3216JB1V685M(160AB) C2012JB1E685K(125AC) C2012JB1E685M(125AC) C3216JB1E685K(160AB) C3216JB1E685M(160AB) C2012JB1C685K(085AC) C2012JB1C685M(085AC) C2012JB1C685K(125AB) C2012JB1C685M(125AB) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (26/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: JB(±10%) Capacitance Dimension Thickness L×W T(mm) 0.85±0.10 2012 1.25±0.10 0.85±0.10 10µF 3216 1.60±0.10 1.60±0.20 15µF 22µF 3225 2.50±0.20 4532 2.50±0.30 2012 3216 3225 4532 2012 3216 3225 1.25±0.10 1.60±0.20 2.50±0.20 2.50±0.30 1.25±0.10 1.60±0.20 2.50±0.30 2.00±0.20 2.50±0.30 2.50±0.30 1.60±0.20 2.50±0.30 1.60±0.20 4532 33µF 47µF 5750 3216 4532 3216 Capacitance Part No. tolerance Rated voltage Edc: 50V ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% C3216JB1H106K(160AB) ±20% C3216JB1H106M(160AB) ±10% ±20% ±10% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% Rated voltage Edc: 35V Rated voltage Edc: 25V C2012JB1E106K(125AC) C2012JB1E106M(125AC) C3216JB1E106K(085AC) C3216JB1E106M(085AC) C3216JB1V106K(160AB) C3216JB1V106M(160AB) Rated voltage Edc: 16V C2012JB1C106K(085AC) C2012JB1C106M(085AC) C2012JB1C106K(125AB) C2012JB1C106M(125AB) C3216JB1C106K(085AB) C3216JB1C106M(085AB) C3216JB1C106K(160AC) C3216JB1C106M(160AA) C3216JB1E106K(160AB) C3216JB1E106M(160AB) C3225JB1E106K(250AA) C3225JB1E106M(250AA) C4532JB1E106K(250KA) C4532JB1E106M(250KA) C3216JB1E156M(160AC) C2012JB1C156M(125AC) C3216JB1C156M(160AB) C3225JB1C156M(250AA) C4532JB1E156M(250KA) C3216JB1E226M(160AC) C2012JB1C226M(125AC) C3216JB1C226M(160AB) C3225JB1C226M(250AA) C4532JB1C226M(200KA) C4532JB1E226M(250KA) C5750JB1E226M(250KA) C3216JB1C336M(160AB) C4532JB1C336M(250KA) C3216JB1C476M(160AB) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (27/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: JB(±10%) Capacitance Dimension Thickness L×W T(mm) 1nF 0402 0.20±0.02 1.5nF 0402 0.20±0.02 2.2nF 0402 0.20±0.02 3.3nF 0402 0.20±0.02 4.7nF 0402 0.20±0.02 0402 0.20±0.02 0603 0.30±0.03 0402 0.20±0.02 0603 0.30±0.03 15nF 0603 0.30±0.03 22nF 0603 0.30±0.03 33nF 0603 0.30±0.03 47nF 0603 0.30±0.03 68nF 0603 0.30±0.03 100nF 0603 0.30±0.03 150nF 0603 0.30±0.03 220nF 0603 0.30±0.03 330nF 1005 0.50±0.05 470nF 1005 0.50±0.05 680nF 1005 0.50±0.05 1µF 1005 0.50±0.05 1.5µF 1005 0.50±0.05 1005 0.50±0.05 1608 0.80±0.10 6.8nF 10nF 2.2µF Capacitance Part No. tolerance Rated voltage Edc: 10V ±10% C0402JB1A102K(020BA) ±20% C0402JB1A102M(020BA) ±10% C0402JB1A152K(020BA) ±20% C0402JB1A152M(020BA) ±10% C0402JB1A222K(020BA) ±20% C0402JB1A222M(020BA) ±10% ±20% ±10% ±20% ±10% ±20% ±10% C0603JB1A682K(030BB) ±20% C0603JB1A682M(030BB) ±10% ±20% ±10% C0603JB1A103K(030BB) ±20% C0603JB1A103M(030BB) ±10% C0603JB1A153K(030BB) ±20% C0603JB1A153M(030BB) ±10% C0603JB1A223K(030BB) ±20% C0603JB1A223M(030BB) ±10% C0603JB1A333K(030BB) ±20% C0603JB1A333M(030BB) ±10% C0603JB1A473K(030BB) ±20% C0603JB1A473M(030BB) ±10% C0603JB1A683K(030BB) ±20% C0603JB1A683M(030BB) ±10% C0603JB1A104K(030BB) ±20% C0603JB1A104M(030BB) ±10% C0603JB1A154K(030BB) ±20% C0603JB1A154M(030BB) ±10% C0603JB1A224K(030BB) ±20% C0603JB1A224M(030BB) ±10% C1005JB1A334K(050BC) ±20% C1005JB1A334M(050BC) ±10% C1005JB1A474K(050BC) ±20% C1005JB1A474M(050BC) ±10% C1005JB1A684K(050BB) ±20% C1005JB1A684M(050BB) ±10% C1005JB1A105K(050BB) ±20% C1005JB1A105M(050BB) ±10% C1005JB1A155K(050BC) ±20% C1005JB1A155M(050BC) ±10% C1005JB1A225K(050BC) ±20% C1005JB1A225M(050BC) ±10% C1608JB1A225K(080AC) ±20% C1608JB1A225M(080AC) Rated voltage Edc: 6.3V Rated voltage Edc: 4V C0402JB0J332K(020BA) C0402JB0J332M(020BA) C0402JB0J472K(020BB) C0402JB0J472M(020BB) C0402JB0J682K(020BB) C0402JB0J682M(020BB) C0402JB0J103K(020BB) C0402JB0J103M(020BB) C1005JB0J105K(050BC) C1005JB0J105M(050BC) C1005JB0J155K(050BB) C1005JB0J155M(050BB) C1005JB0J225K(050BC) C1005JB0J225M(050BB) C1608JB0J225K(080AB) C1608JB0J225M(080AB) C1005JB0G225K(050BB) C1005JB0G225M(050BB) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (28/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: JB(±10%) Capacitance Dimension Thickness L×W T(mm) 1005 3.3µF 0.50±0.10 0.80+0.15/–0.10 1608 0.80±0.10 1005 0.50+0.15/–0.10 1608 0.80±0.10 4.7µF 0.60±0.10 2012 1.25±0.10 1608 6.8µF 0.80±0.10 0.60±0.10 2012 1.25±0.10 1608 10µF 0.80±0.10 0.85±0.10 2012 1.25±0.20 15µF 22µF 33µF 47µF 68µF 100µF 2012 2012 3216 2012 3216 2012 3216 3216 3225 3216 3225 0.85±0.10 1.25±0.10 0.85±0.10 1.25±0.10 1.60±0.20 1.25±0.20 1.60±0.20 1.25±0.20 1.60±0.20 1.60±0.20 2.00±0.20 1.60+0.30/–0.10 2.50±0.30 Capacitance Part No. tolerance Rated voltage Edc: 10V ±20% ±10% ±20% ±10% C1608JB1A335K(080AB) ±20% C1608JB1A335M(080AB) ±20% ±10% C1608JB1A475K(080AB) ±20% C1608JB1A475M(080AB) ±10% C2012JB1A475K(060AB) ±20% C2012JB1A475M(060AB) ±10% C2012JB1A475K(125AA) ±20% C2012JB1A475M(125AA) ±10% C1608JB1A685K(080AC) ±20% C1608JB1A685M(080AC) ±10% C2012JB1A685K(060AC) ±20% C2012JB1A685M(060AC) ±10% C2012JB1A685K(125AC) ±20% C2012JB1A685M(125AC) ±10% C1608JB1A106K(080AC) ±20% C1608JB1A106M(080AC) ±10% C2012JB1A106K(085AB) ±20% C2012JB1A106M(085AB) ±10% C2012JB1A106K(125AC) ±20% C2012JB1A106M(125AC) ±20% C2012JB1A156M(085AC) ±20% C2012JB1A156M(125AB) ±20% C2012JB1A226M(085AC) ±20% C2012JB1A226M(125AB) ±20% C3216JB1A226M(160AC) ±20% ±20% C3216JB1A336M(160AB) ±20% ±20% C3216JB1A476M(160AB) ±20% C3216JB1A686M(160AC) ±20% ±20% C3216JB1A107M(160AC) ±20% Rated voltage Edc: 6.3V C1005JB0J335M(050BC) C1608JB0J335K(080AB) C1608JB0J335M(080AB) Rated voltage Edc: 4V C1005JB0G335M(050BB) C1005JB0J475M(050BC) C1608JB0J475K(080AB) C1608JB0J475M(080AB) C1005JB0G475M(050BB) C1608JB0J685K(080AB) C1608JB0J685M(080AB) C1608JB0J106K(080AB) C1608JB0J106M(080AB) C2012JB0J226M(085AB) C2012JB0J226M(125AB) C2012JB0J336M(125AC) C2012JB0J476M(125AC) C3216JB0J476M(160AC) C3216JB0J686M(160AB) C3225JB0J686M(200AC) C3216JB0J107M(160AB) C3225JB0J107M(250AC) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (29/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: Y5V(+22, –82%) Capacitance 100nF 220nF 470nF 1µF 2.2µF 4.7µF 10µF 22µF 47µF 100µF Dimension Thickness L×W T(mm) 1005 1608 1005 1608 1608 1608 2012 1608 2012 2012 3216 2012 3216 3225 3216 3225 5750 3225 5750 5750 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.80±0.10 0.80±0.10 0.85±0.10 0.80±0.10 1.25±0.10 1.25±0.20 1.60±0.10 1.25±0.20 1.60±0.20 1.60±0.20 1.60±0.20 2.00±0.20 2.00±0.20 2.30±0.20 2.00±0.20 2.50±0.30 Capacitance Part No. tolerance Rated voltage Edc: 50V +80%, –20% +80%, –20% C1608Y5V1H104Z(080AA) +80%, –20% +80%, –20% C1608Y5V1H224Z(080AA) +80%, –20% C1608Y5V1H474Z(080AA) +80%, –20% +80%, –20% C2012Y5V1H105Z(085AA) +80%, –20% +80%, –20% C2012Y5V1H225Z(125AA) +80%, –20% +80%, –20% C3216Y5V1H475Z(160AA) +80%, –20% +80%, –20% +80%, –20% C3225Y5V1H106Z(160AA) +80%, –20% +80%, –20% +80%, –20% C5750Y5V1H226Z(200KA) +80%, –20% +80%, –20% +80%, –20% Rated voltage Edc: 35V Rated voltage Edc: 25V C1005Y5V1E104Z(050BA) Rated voltage Edc: 16V C1005Y5V1E224Z(050BA) C1608Y5V1E105Z(080AA) C1608Y5V1C225Z(080AA) C2012Y5V1E475Z(125AA) C2012Y5V1C106Z(125AA) C3216Y5V1E106Z(160AA) C3216Y5V1C226Z(160AA) C3225Y5V1E226Z(200AA) C3225Y5V1C476Z(230AA) C5750Y5V1E476Z(200KA) C5750Y5V1C107Z(250KA) TEMPERATURE CHARACTERISTICS: Y5V(+22, –82%) Capacitance 470nF 1µF 4.7µF 22µF 47µF 100µF Dimension Thickness L×W T(mm) 1005 1005 1608 2012 3216 3225 3225 4532 0.50±0.05 0.50±0.05 0.80±0.10 1.25±0.20 1.60+0.30/–0.10 2.00±0.20 2.50±0.30 2.50±0.30 Capacitance Part No. tolerance Rated voltage Edc: 10V +80%, –20% C1005Y5V1A474Z(050BA) +80%, –20% +80%, –20% +80%, –20% +80%, –20% +80%, –20% C3225Y5V1A476Z(200AA) +80%, –20% +80%, –20% C4532Y5V1A107Z(250KA) Rated voltage Edc: 6.3V Rated voltage Edc: 4V C1005Y5V0J105Z(050BA) C1608Y5V0J475Z(080AA) C2012Y5V0J226Z(125AA) C3216Y5V0J476Z(160AA) C3225Y5V0J107Z(250AA) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm (30/30) CAPACITANCE RANGES: CLASS 2 TEMPERATURE CHARACTERISTICS: JF(+30, –80%) Capacitance 100nF 220nF 470nF 1µF 2.2µF 4.7µF 10µF 22µF 47µF 100µF Dimension Thickness L×W T(mm) 1005 1608 1005 1608 1608 1608 2012 1608 2012 2012 3216 2012 3216 3225 3216 3225 5750 3225 5750 5750 0.50±0.05 0.80±0.10 0.50±0.05 0.80±0.10 0.80±0.10 0.80±0.10 0.85±0.10 0.80±0.10 1.25±0.10 1.25±0.20 1.60±0.10 1.25±0.20 1.60±0.20 1.60±0.20 1.60±0.20 2.00±0.20 2.00±0.20 2.30±0.20 2.00±0.20 2.50±0.30 Capacitance Part No. tolerance Rated voltage Edc: 50V +80%, –20% +80%, –20% C1608JF1H104Z(080AA) +80%, –20% +80%, –20% C1608JF1H224Z(080AA) +80%, –20% C1608JF1H474Z(080AA) +80%, –20% +80%, –20% C2012JF1H105Z(085AA) +80%, –20% +80%, –20% C2012JF1H225Z(125AA) +80%, –20% +80%, –20% C3216JF1H475Z(160AA) +80%, –20% +80%, –20% +80%, –20% C3225JF1H106Z(160AA) +80%, –20% +80%, –20% +80%, –20% C5750JF1H226Z(200KA) +80%, –20% +80%, –20% +80%, –20% Rated voltage Edc: 35V Rated voltage Edc: 25V C1005JF1E104Z(050BA) Rated voltage Edc: 16V C1005JF1E224Z(050BA) C1608JF1E105Z(080AA) C1608JF1C225Z(080AA) C2012JF1E475Z(125AA) C2012JF1C106Z(125AA) C3216JF1E106Z(160AA) C3216JF1C226Z(160AA) C3225JF1E226Z(200AA) C3225JF1C476Z(230AA) C5750JF1E476Z(200KA) C5750JF1C107Z(250KA) TEMPERATURE CHARACTERISTICS: JF(+30, –80%) Capacitance 470nF 1µF 4.7µF 22µF 47µF 100µF Dimension Thickness L×W T(mm) 1005 1005 1608 2012 3216 3225 3225 4532 0.50±0.05 0.50±0.05 0.80±0.10 1.25±0.20 1.60+0.30/–0.10 2.00±0.20 2.50±0.30 2.50±0.30 Capacitance Part No. tolerance Rated voltage Edc: 10V +80%, –20% C1005JF1A474Z(050BA) +80%, –20% +80%, –20% +80%, –20% +80%, –20% +80%, –20% C3225JF1A476Z(200AA) +80%, –20% +80%, –20% C4532JF1A107Z(250KA) Rated voltage Edc: 6.3V Rated voltage Edc: 4V C1005JF0J105Z(050BA) C1608JF0J475Z(080AA) C2012JF0J226Z(125AA) C3216JF0J476Z(160AA) C3225JF0J107Z(250AA) • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. Please read the precautions before using this catalog. 007-02 / 20110907 / e412_c.fm
C5750X7R1H106M230KB.. 价格&库存
很抱歉,暂时无法提供与“C5750X7R1H106M230KB..”相匹配的价格&库存,您可以联系我们找货
