CAA573X7R1V157M670LH
    TDK(东电化)
    堆栈式SMD,2条J型引线
    150 µF ±20% 35V 陶瓷电容器 X7R 堆栈式 SMD,2条 J 型引线
CAA573X7R1V157M670LH 数据手册
CAA573X7R1V157M670LH TDK item description : CAA573X7R1V157MT**** DC Bias Characteristic 10 Application & Main Feature 0 Cap. Change/% Commercial grade (MEGACAP (Low resistance/Inline)) Series CAA573(5750) [EIA 2220] -10 -20 -30 -40 -50 -60 -70 0 mm mm mm mm 100 25 30 35 40 20 Cap. Change/% 0 1 0.1 0.01 0.001 -10 -20 -30 -40 -50 -60 -70 -80 0.0001 0.001 Capacitance 150μF -90 0.01 0.1 1 10 100 1000 -80 -60 -40 |Z| Capacitance Tolerance M (±20%) 10000 ESR Cap. vs. Freq. Characteristic 20 40 60 80 100 120 140 Temperature Rise/degC 100 TCBias(1/2Rated) Ripple Temperature Rise Characteristics 25 1000 10 0.001 0 Temp.Chara. DF 5 % max. -20 Temperature/degC Frequency/MHz Cap./μF Characterization Sheet ( Multilayer Ceramic Chip Capacitors ) 20 10 Rated Voltage 1V (35Vdc) AEC-Q200 Not Applicable 15 Temperature Characteristics |Z|, ESR vs. Freq. Characteristics 10 Temperature Characteristic X7R (-55 to +125 degC, ±15%) Insulation Resistance 3 Mohm min. 10 DC Bias/V |Z|, ESR/ohm Dimensions L 6.25±0.50 W 7.50±0.50 T 6.70±0.50 E 1.20±0.20 5 20 15 10 5 0 0.01 0.1 1 Frequency/MHz 10 100 1000 0 0.5 1 1.5 100kHz All specifications are subject to change without notice. 2 2.5 3 Current/Arms 500kHz 1MHz July 1, 2022
CAA573X7R1V157M670LH 价格&库存
很抱歉,暂时无法提供与“CAA573X7R1V157M670LH”相匹配的价格&库存,您可以联系我们找货
  • 1+172.401071+22.33197
  • 10+136.2133710+17.64440
  • 50+121.7355250+15.76901
  • 100+117.25266100+15.18832
  • 400+104.37944400+13.52079
  • 800+102.01350800+13.21432
