CC-E Series
https://product.tdk.com/en/power/cc-e
www.emea.lambda.tdk.com/cc-e
1.3 to 10W DC-DC Converters
The low profile, lightweight CC-E series of isolated DC-DC converters operate from 4.5 to 9V, 9 to 18V, 18 to 36V or 36 to 76V inputs with 1.5W, 3W, 6W and 10W
power levels and output voltages from 3.3V to 30V(1)(2). Both single and dual output models can be adjusted using the trim terminal. The CC-E can operate in ambient
temperatures of -40 to 85°C and have an input to output isolation of 500Vac. Both through hole and surface mount packages are offered. The five-sided metal case
reduces radiated noise.
Features
Benefits
• Low Profile
• Supports Vertical Mount Cards
• Remote on/off
• Individual Control
• Five Sided Metal Case Design
• Reduced Radiated Noise
• Reduced Derating at High Ambient Temperatures
• More Useable Power
• No Potting
• Low Weight
Part Numbering Scheme
CC
Series Name
CC
1R5
Output Power
1R5 = 1.5W, 3 = 3W
6 = 6W, 10 = 10W
-05
Input Voltage
05 = 4.5 - 9V
12 = 9 - 18V
24 = 18 - 36V
48 = 36 - 76V
03
Output Voltage
03 = 3.3V
05 = 5V
12 = 12V
15 = 15V
CC-E Series
S
S = Single Output
D = Dual Output
F
-E
Mounting Type
F = Through hole
R = Surface Mount
S = Vertical SIP
(CC3 only)
1
Model Selector - Single Output
Model
Note:Letter “”x”” indicates mounting type
Input
x=F through hole, x=R surface mount
Voltage
x=S SIP (CC3 only)
(V)
CC1R5-0503Sx-E
CC3-0503Sx-E
CC6-0503Sx-E
CC10-0503Sx-E
CC1R5-0505Sx-E
CC3-0505Sx-E
4.5 - 9
CC6-0505Sx-E
CC10-0505Sx-E
CC1R5-0512Sx-E
CC3-0512Sx-E
CC6-0512Sx-E
CC10-0512Sx-E
CC1R5-1203Sx-E
CC3-1203Sx-E
CC6-1203Sx-E
CC10-1203Sx-E
CC1R5-1205Sx-E
CC3-1205Sx-E
9 - 18
CC6-1205Sx-E
CC10-1205Sx-E
CC1R5-1212Sx-E
CC3-1212Sx-E
CC6-1212Sx-E
CC10-1212Sx-E
CC1R5-2403Sx-E
CC3-2403Sx-E
CC6-2403Sx-E
CC10-2403Sx-E
CC1R5-2405Sx-E
CC3-2405Sx-E
18 - 36
CC6-2405Sx-E
CC10-2405Sx-E
CC1R5-2412Sx-E
CC3-2412Sx-E
CC6-2412Sx-E
CC10-2412Sx-E
CC1R5-4803Sx-E
CC3-4803Sx-E
CC6-4803Sx-E
CC10-4803Sx-E
CC1R5-4805Sx-E
CC3-4805Sx-E
36 - 76
CC6-4805Sx-E
CC10-4805Sx-E
CC1R5-4812Sx-E
CC3-4812Sx-E
CC6-4812Sx-E
CC10-4812Sx-E
2
Output
Voltage(1)
(V)
3.3
3.3
3.3
3.3
5
5
5
5
12 / 15
12 / 15
12 / 15
12 / 15
3.3
3.3
3.3
3.3
5
5
5
5
12 / 15
12 / 15
12 / 15
12 / 15
3.3
3.3
3.3
3.3
5
5
5
5
12 / 15
12 / 15
12 / 15
12 / 15
3.3
3.3
3.3
3.3
5
5
5
5
12 / 15
12 / 15
12 / 15
12 / 15
Output
Current(1)
(A)
0.4
0.8
1.2
2.5
0.3
0.6
1
2
0.125 / 0.1
0.25 / 0.2
0.5 / 0.4
0.8 / 0.64
0.4
0.8
1.2
2.5
0.3
0.6
1.2
2
0.125 / 0.1
0.25 / 0.2
0.5 / 0.4
1 / 0.8
0.4
0.8
1.2
2.5
0.3
0.6
1.2
2
0.125 / 0.1
0.25 / 0.2
0.5 / 0.4
1 / 0.8
0.4
0.8
1.2
2.5
0.3
0.6
1.2
2
0.125 / 0.1
0.25 / 0.2
0.5 / 0.4
1 / 0.8
Maximum
Power
(W)
1.32
2.64
3.96
8.25
1.5
3
5
10
1.5
3
6
9.6
1.32
2.64
3.96
8.25
1.5
3
6
10
1.5
3
6
12
1.32
2.64
3.96
8.25
1.5
3
6
10
1.5
3
6
12
1.32
2.64
3.96
8.25
1.5
3
6
10
1.5
3
6
12
CC-E Series
Input Current at
nominal input
(A)
0.372
0.732
1.042
1.964
0.39
0.779
1.266
2.381
0.375
0.732
1.463
2.286
0.151
0.297
0.423
0.818
0.16
0.316
0.61
0.969
0.152
0.305
0.588
1.136
0.076
0.151
0.214
0.409
0.081
0.16
0.309
0.484
0.077
0.152
0.287
0.575
0.039
0.075
0.107
0.205
0.041
0.079
0.154
0.242
0.039
0.077
0.145
0.284
Efficiency (%)
(100% load,
nominal input)
71
73
76
84
77
77
79
84
80
82
82
84
73
74
78
84
78
79
82
86
82
82
85
88
72
73
77
84
77
78
81
86
81
82
87
87
70
73
77
84
76
79
81
86
80
81
86
88
Line / Load
Regulation
(mV)
20 / 40
20 / 40
20 / 40
20 / 40
20 / 40
20 / 40
20 / 40
20 / 40
40 / 100
40 / 100
40 / 100
40 / 100
20 / 40
20 / 40
20 / 40
20 / 40
20 / 40
20 / 40
20 / 40
20 / 40
40 / 100
40 / 100
40 / 100
40 / 100
20 / 40
20 / 40
20 / 40
20 / 40
20 / 40
20 / 40
20 / 40
20 / 40
40 / 100
40 / 100
40 / 100
40 / 100
20 / 40
20 / 40
20 / 40
20 / 40
20 / 40
20 / 40
20 / 40
20 / 40
40 / 100
40 / 100
40 / 100
40 / 100
Model Selector - Dual Output
Model
Input
Voltage
(V)
Output
Voltage(1)(2)
(V)
Output
Current(1)
(A)
Maximum
Power
(W)
Input Current at
nominal input
(A)
Efficiency (%)
(100% load,
nominal input)
Line / Load
Regulation(3)
(mV)
CC1R5-0512Dx-E
CC3-0512Dx-E
4.5 - 9
CC6-0512DF-E
CC10-0512DF-E
CC1R5-1212Dx-E
CC3-1212Dx-E
9 - 18
CC6-1212Dx-E
CC10-1212Dx-E
CC1R5-2412Dx-E
CC3-2412Dx-E
18 - 36
CC6-2412Dx-E
CC10-2412Dx-E
CC1R5-4812Dx-E
CC3-4812Dx-E
36 - 76
CC6-4812Dx-E
CC10-4812Dx-E
±12 / ±15
±12 / ±15
±12 / ±15
±12 / ±15
±12 / ±15
±12 / ±15
±12 / ±15
±12 / ±15
±12 / ±15
±12 / ±15
±12 / ±15
±12 / ±15
±12 / ±15
±12 / ±15
±12 / ±15
±12 / ±15
±0.06 / ±0.05
±0.125 / ±0.1
±0.25 / ±0.2
±0.4 / ±0.32
±0.06 / ±0.05
±0.125 / ±0.1
±0.25 / ±0.2
±0.45 / ±0.36
±0.06 / ±0.05
±0.125 / ±0.1
±0.25 / ±0.2
±0.45 / ±0.36
±0.06 / ±0.05
±0.125 / ±0.1
±0.25 / ±0.2
±0.45 / ±0.36
1.5
3
6
9.6
1.5
3
6
10.8
1.5
3
6
10.8
1.5
3
6
10.8
0.38
0.741
1.463
2.313
0.154
0.309
0.588
1.047
0.079
0.154
0.291
0.523
0.04
0.078
0.145
0.262
79
81
82
83
81
81
85
86
79
81
86
86
79
80
86
86
80 / 600
80 / 600
80 / 600
80 / 600
80 / 600
80 / 600
80 / 600
80 / 600
80 / 600
80 / 600
80 / 600
80 / 600
80 / 600
80 / 600
80 / 600
80 / 600
Notes
(1) 12V single and dual output models can be set to 15V by connecting the trim terminal to -Vout. See Instruction Manual for further details
(2) ±12V dual output models can provide a 24V single output by utilizing just the +Vout and -Vout pins, leaving the COM unconnected.
Similarly ±15V dual output models can be used as a 30V single output.
(3) Based upon equal load current from both outputs
Specifications
Model
Input
Input Voltage Range
Efficiency
Conducted & Radiated EMI
Safety Certifications and Markings
Output
Output Voltage Tolerance
Output Voltage Adjustment
V
Total Regulation
Ripple & Noise
mV
Temperature Coefficient
%/°C
Minimum Load
Overcurrent Protection
Overvoltage Protection
Overtemperature Protection
Remote Sense
Remote On/Off
Parallel Operation
CC1R5
CC3
CC6
CC10
See model selector table
See Instruction Manual on website for suggested external filtering
IEC/UL/CSA/EN62368-1, CE Mark and UKCA Mark
±3
3.3V: 3.15-3.6, 5V: 4.75-6.0, 12V: 11.4-15
Single output: ±3, dual output: ±5
3.3/5V: 120 (40 typical), 12/15V 120 (30 typical)
0.02
No minimum load required
Hiccup mode. >105
No remote sense
Negative Logic ON: Short , OFF: Open
Not possible
CC-E Series
3
Specifications
Model
CC1R5
CC3
CC6
CC10
Environmental
Operating Temperature
°C
-40 to +85 (Ambient). See derating guide below and installation manual.
Storage Temperature
°C
-40 to +85
Humidity (non condensing)
%RH
很抱歉,暂时无法提供与“CC15-2403SF-E”相匹配的价格&库存,您可以联系我们找货
