CC15-2412SRH-E
CC15-2412SRH-E
    TDK(东电化)
    SMD-17P,38.4x29.6mm
    CC15-2412SRH-E
CC15-2412SRH-E 数据手册
• Compact Footprint / Low Profile • 24V & 48V Inputs • 3.3V to 15V Outputs • Input - Output Isolation • Through Hole or SMT Versions • DC OK signal • Sequencing pin • 5 Year Warranty CC-P-E Series Key Market Segments & Applications Process Control Instrumentation Datacom & Telecom Ultra Compact, 15W to 30W DC-DC Converters CC-E Features and Benefits Features Benefits • Compact • Five Sided Shielding (cased version) • Parallel Operation Specifications • Less PCB Area Used • Lower radiated EMI • Provides additional power Nominal Output Voltage DC Input Efficiency Initial set accuracy Total Regulation limits Output Adjustment Temperature Coefficient Preload Output Ripple Overcurrent Protection Overvoltage protection Remote On/Off (RC) Alarm (ALM) Sequencing (PO) V VDC % % % %/°C A mV - Cooling Operating Temp. Range Storage Temperature Humidity (Non condensing) Isolation Voltage (Cased version) Isolation Voltage (Uncased version) Isolation Resistance (Cased version) Isolation Resistance (Uncased version) Shock (Non operating) Vibration (non operating) Safety Agency Certifications Weight Size (LxWxH) (Thru hole ver., w/ case) Warranty °C °C %RH VDC VDC Ω Ω g mm yrs 3.3V 5V 12V 15V 24V Nominal: 18-36V, 48V Nominal: 36-76V 89 to 92% model dependant ±1% +5%, -3% None 103% of nominal rating Operates at 115 - 145% of nominal voltage Logic high (pull high to shutdown), referenced to -Vin Low On Fail, referenced to -Vin. 20 units maximum Connecting PO terminals on multiple power supplies ensures all simulataneously start up (20 units maximum) Convection -40°C to +85°C -40°C to +85°C 5 - 95%RH Input/Output 1000VDC, Input/Case 500VDC, Output/Case 500VDC, 100mA for 1 min Input/Output 1500VDC, 100mA for 1 min >50MΩ at 25°C and 70% RH, 500VDC Input/Output, Input/Case, Output/Case >50MΩ at 25°C and 70% RH, 500VDC Input/Output 980m/s2 (100G), 6ms, 6 directions, 3 times 10-55-10 Hz (sweep for 15 min.) 1.52mm amplitude, 2 hour X, Y, Z IEC/EN/UL/CSA60950-1, IEC/EN/UL/CSA62368-1 and CE Mark With case: CC15 15g, CC30 20g. Without case: CC15 10g, CC30 15g CC15: 38.4 x 29.6 x 6.8mm, CC30: 38.4 x 33.5 x 8.3mm 5 Notes: See Installation Manual for full specifications, test methods of parameters and application notes. CC-P-E Series 1 Model Selector Output Voltage (V) 3.3 Output Current (A) Max O/P Power (W) 4.5 3.3 15 9 5 1.25 15 1 12 CC15-2405SFP-E 30 CC30-2405SFP-E 15 2.5 15 CC30-2403SFP-E 15 6 12 CC15-2403SFP-E 30 3 5 24V Input CC15-2412SFP-E 30 CC30-2412SFP-E 15 2 CC15-2415SFP-E 30 CC30-2415SFP-E 48V Input CC15-4803SFP-E* CC30-4803SFP-E* CC15-4805SFP-E* CC30-4805SFP-E* CC15-4812SFP-E* CC30-4812SFP-E* CC15-4815SFP-E* CC30-4815SFP-E* *CC15 & CC30 48Vin models - last time buy March 2019 Options Version PIN CCxx-yyyySFH-E Through hole CCxx-yyyySFP-E* CCxx-yyyySRP-E CCxx-yyyySRH-E Through hole Yes SMT Yes SMT Where xx is output power & yyyy is input and output voltage combination. * denotes preferred model Pinout SFP-E Models Pin 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 2 Pin Name Stopper +Vout +Vout +Vout -Vout -Vout Stopper NC ALM RC PO Stopper +Vin +Vin -Vin -Vin NC Case Function Stopper +DC output +DC output +DC output -DC output -DC output Stopper Not connected Alarm Remote control Start in / out Stopper +DC input +DC input -DC input -DC input Not connected No No Pinout SRP-E Models Pin 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 CC-P-E Series Pin Name NC +Vout +Vout +Vout -Vout -Vout NC NC ALM RC PO NC +Vin +Vin -Vin -Vin NC Function Not connected +DC output +DC output +DC output -DC output -DC output Not connected Not connected Alarm Remote control Start in / out Not connected +DC input +DC input -DC input -DC input Not connected Outline Drawing CC15-xxxxSFP-E Series 1 pin mark Logo mark P=2.54±0.3 X 5 3.22 Model name 17 1 0.6±0.1 15 3 14 29.6 4 5 P=2.54±0.3 X 9 2.54±0.3 16 2 13 12 10.16 6 11 10 7 2.54±0.3 9 8 Lot.No 3.5 6.8MAX 38.4 Production country 1±0.1 2.54±0.3 37.6 Outline Drawing CC30-xxxxSRP-E Series 1 pin mark 5.17 Logo mark 17 1 14 33.5 4 5 13 12 6 11 P=2.54±0.3 X 9 15 3 0.6±0.1 2.54±0.3 16 2 10.16 10 8 Lot.No 8.3MAX 38.4 2.54±0.3 9 7 Production country Coplanarity within 0.1 0~10° P=2.54±0.3 X 5 Model name 1.3±0.3 39.9±0.6 CC-P-E Series 3 TDK-Lambda France SAS TDK-Lambda Americas Tel: +33 1 60 12 71 65 tlf.fr-powersolutions@tdk.com Tel: +1 800-LAMBDA-4 or 1-800-526-2324 tla.powersolutions@tdk.com www.us.lambda.tdk.com www.emea.lambda.tdk.com/fr Italy Sales Office Tel: +39 02 61 29 38 63 tlf.it-powersolutions@tdk.com www.emea.lambda.tdk.com/it TDK Electronics do Brasil Ltda Tel: +55 11 3289-9599 sales.br@tdk-electronics.tdk.com www.tdk-electronics.tdk.com/en Netherlands tlf.nl-powersolutions@tdk.com www.emea.lambda.tdk.com/nl TDK-Lambda Germany GmbH TDK-Lambda Corporation Tel: +49 7841 666 0 tlg.powersolutions@tdk.com www.emea.lambda.tdk.com/de Tel: +81-3-6778-1113 www.jp.lambda.tdk.com TDK-Lambda (China) Electronics Co. Ltd. Tel: +86 21 6485-0777 tlc.powersolutions@tdk.com www.lambda.tdk.com.cn Austria Sales Office Tel: +43 2256 655 84 tlg.at-powersolutions@tdk.com TDK-Lambda Singapore Pte Ltd. Tel: +65 6251 7211 tls.marketing@tdk.com www.sg.lambda.tdk.com www.emea.lambda.tdk.com/at Switzerland Sales Office Tel: +41 44 850 53 53 tlg.ch-powersolutions@tdk.com TDK India Private Limited, Power Supply Division www.emea.lambda.tdk.com/ch Tel: +91 80 4039-0660 mathew.philip@tdk.com www.sg.lambda.tdk.com Nordic Sales Office Tel: +45 8853 8086 tlg.dk-powersolutions@tdk.com www.emea.lambda.tdk.com/dk TDK-Lambda UK Ltd. Tel: +44 (0) 12 71 85 66 66 tlu.powersolutions@tdk.com www.emea.lambda.tdk.com/uk TDK-Lambda Ltd. Tel: +9 723 902 4333 tli.powersolutions@tdk.com www.emea.lambda.tdk.com/il-en 4 CC-P-E Aug23 v6 Series Series CC-P-E For Additional Information, please visit https://product.tdk.com/en/power/ pg
CC15-2412SRH-E 价格&库存
很抱歉,暂时无法提供与“CC15-2412SRH-E”相匹配的价格&库存,您可以联系我们找货
CC15-2412SRH-E
  • 10+471.4594210+61.07049
