• Compact Footprint / Low Profile
• 24V & 48V Inputs
• 3.3V to 15V Outputs
• Input - Output Isolation
• Through Hole or SMT Versions
• DC OK signal
• Sequencing pin
• 5 Year Warranty
CC-P-E Series
Key Market Segments & Applications
Process Control
Instrumentation
Datacom & Telecom
Ultra Compact, 15W to 30W
DC-DC Converters
CC-E Features and Benefits
Features
Benefits
• Compact
• Five Sided Shielding (cased version)
• Parallel Operation
Specifications
• Less PCB Area Used
• Lower radiated EMI
• Provides additional power
Nominal Output Voltage
DC Input
Efficiency
Initial set accuracy
Total Regulation limits
Output Adjustment
Temperature Coefficient
Preload
Output Ripple
Overcurrent Protection
Overvoltage protection
Remote On/Off (RC)
Alarm (ALM)
Sequencing (PO)
V
VDC
%/°C
A
mV
Cooling
Operating Temp. Range
Storage Temperature
Humidity (Non condensing)
Isolation Voltage (Cased version)
Isolation Voltage (Uncased version)
Isolation Resistance (Cased version)
Isolation Resistance (Uncased version)
Shock (Non operating)
Vibration (non operating)
Safety Agency Certifications
Weight
Size (LxWxH) (Thru hole ver., w/ case)
Warranty
°C
°C
%RH
VDC
VDC
Ω
Ω
g
mm
yrs
3.3V
5V
12V
15V
24V Nominal: 18-36V, 48V Nominal: 36-76V
89 to 92% model dependant
±1%
+5%, -3%
None
103% of nominal rating
Operates at 115 - 145% of nominal voltage
Logic high (pull high to shutdown), referenced to -Vin
Low On Fail, referenced to -Vin. 20 units maximum
Connecting PO terminals on multiple power supplies ensures all simulataneously
start up (20 units maximum)
Convection
-40°C to +85°C
-40°C to +85°C
5 - 95%RH
Input/Output 1000VDC, Input/Case 500VDC, Output/Case 500VDC, 100mA for 1 min
Input/Output 1500VDC, 100mA for 1 min
>50MΩ at 25°C and 70% RH, 500VDC Input/Output, Input/Case, Output/Case
980m/s2 (100G), 6ms, 6 directions, 3 times
10-55-10 Hz (sweep for 15 min.) 1.52mm amplitude, 2 hour X, Y, Z
IEC/EN/UL/CSA60950-1, IEC/EN/UL/CSA62368-1 and CE Mark
With case: CC15 15g, CC30 20g. Without case: CC15 10g, CC30 15g
CC15: 38.4 x 29.6 x 6.8mm, CC30: 38.4 x 33.5 x 8.3mm
5
Notes: See Installation Manual for full specifications, test methods of parameters and application notes.
CC-P-E Series
1
Model Selector
Output Voltage (V)
3.3
Output Current (A)
Max O/P Power (W)
4.5
3.3
15
9
5
1.25
15
1
12
CC15-2405SFP-E
30
CC30-2405SFP-E
15
2.5
15
CC30-2403SFP-E
15
6
12
CC15-2403SFP-E
30
3
5
24V Input
CC15-2412SFP-E
30
CC30-2412SFP-E
15
2
CC15-2415SFP-E
30
CC30-2415SFP-E
48V Input
CC15-4803SFP-E*
CC30-4803SFP-E*
CC15-4805SFP-E*
CC30-4805SFP-E*
CC15-4812SFP-E*
CC30-4812SFP-E*
CC15-4815SFP-E*
CC30-4815SFP-E*
*CC15 & CC30 48Vin models - last time buy March 2019
Options
Version
PIN
CCxx-yyyySFH-E
Through hole
CCxx-yyyySFP-E*
CCxx-yyyySRP-E
CCxx-yyyySRH-E
Through hole
Yes
SMT
Yes
SMT
Where xx is output power & yyyy is input and output voltage
combination. * denotes preferred model
Pinout SFP-E Models
Pin
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
2
Pin Name
Stopper
+Vout
+Vout
+Vout
-Vout
-Vout
Stopper
NC
ALM
RC
PO
Stopper
+Vin
+Vin
-Vin
-Vin
NC
Case
Function
Stopper
+DC output
+DC output
+DC output
-DC output
-DC output
Stopper
Not connected
Alarm
Remote control
Start in / out
Stopper
+DC input
+DC input
-DC input
-DC input
Not connected
No
No
Pinout SRP-E Models
Pin
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
CC-P-E Series
Pin Name
NC
+Vout
+Vout
+Vout
-Vout
-Vout
NC
NC
ALM
RC
PO
NC
+Vin
+Vin
-Vin
-Vin
NC
Function
Not connected
+DC output
+DC output
+DC output
-DC output
-DC output
Not connected
Not connected
Alarm
Remote control
Start in / out
Not connected
+DC input
+DC input
-DC input
-DC input
Not connected
Outline Drawing CC15-xxxxSFP-E Series
1 pin mark
Logo mark
P=2.54±0.3 X 5
3.22
Model name
17
1
0.6±0.1
15
3
14
29.6
4
5
P=2.54±0.3 X 9
2.54±0.3
16
2
13
12
10.16
6
11
10
7
2.54±0.3
9
8
Lot.No
3.5
6.8MAX
38.4
Production country
1±0.1
2.54±0.3
37.6
Outline Drawing CC30-xxxxSRP-E Series
1 pin mark
5.17
Logo mark
17
1
14
33.5
4
5
13
12
6
11
P=2.54±0.3 X 9
15
3
0.6±0.1
2.54±0.3
16
2
10.16
10
8
Lot.No
8.3MAX
38.4
2.54±0.3
9
7
Production country
Coplanarity within 0.1
0~10°
P=2.54±0.3 X 5
Model name
1.3±0.3
39.9±0.6
CC-P-E Series
3
TDK-Lambda France SAS
TDK-Lambda Americas
Tel: +33 1 60 12 71 65
tlf.fr-powersolutions@tdk.com
Tel: +1 800-LAMBDA-4 or 1-800-526-2324
tla.powersolutions@tdk.com
www.us.lambda.tdk.com
www.emea.lambda.tdk.com/fr
Italy Sales Office
Tel: +39 02 61 29 38 63
tlf.it-powersolutions@tdk.com
www.emea.lambda.tdk.com/it
TDK Electronics do Brasil Ltda
Tel: +55 11 3289-9599
sales.br@tdk-electronics.tdk.com
www.tdk-electronics.tdk.com/en
Netherlands
tlf.nl-powersolutions@tdk.com
www.emea.lambda.tdk.com/nl
TDK-Lambda Germany GmbH
TDK-Lambda Corporation
Tel: +49 7841 666 0
tlg.powersolutions@tdk.com
www.emea.lambda.tdk.com/de
Tel: +81-3-6778-1113
www.jp.lambda.tdk.com
TDK-Lambda (China) Electronics Co. Ltd.
Tel: +86 21 6485-0777
tlc.powersolutions@tdk.com
www.lambda.tdk.com.cn
Austria Sales Office
Tel: +43 2256 655 84
tlg.at-powersolutions@tdk.com
TDK-Lambda Singapore Pte Ltd.
Tel: +65 6251 7211
tls.marketing@tdk.com
www.sg.lambda.tdk.com
www.emea.lambda.tdk.com/at
Switzerland Sales Office
Tel: +41 44 850 53 53
tlg.ch-powersolutions@tdk.com
TDK India Private Limited, Power Supply Division
www.emea.lambda.tdk.com/ch
Tel: +91 80 4039-0660
mathew.philip@tdk.com
Nordic Sales Office
Tel: +45 8853 8086
tlg.dk-powersolutions@tdk.com
www.emea.lambda.tdk.com/dk
TDK-Lambda UK Ltd.
Tel: +44 (0) 12 71 85 66 66
tlu.powersolutions@tdk.com
www.emea.lambda.tdk.com/uk
TDK-Lambda Ltd.
Tel: +9 723 902 4333
tli.powersolutions@tdk.com
www.emea.lambda.tdk.com/il-en
4
CC-P-E Aug23 v6
Series Series
CC-P-E
For Additional Information, please visit
https://product.tdk.com/en/power/
pg
很抱歉,暂时无法提供与“CC15-2412SRP-E”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+538.906891+69.80729
