CC3-1205SR-E
CC3-1205SR-E
    TDK(东电化)
    DIP
CC3-1205SR-E 数据手册
CC-E Series https://product.tdk.com/en/power/cc-e www.emea.lambda.tdk.com/cc-e 1.3 to 10W DC-DC Converters The low profile, lightweight CC-E series of isolated DC-DC converters operate from 4.5 to 9V, 9 to 18V, 18 to 36V or 36 to 76V inputs with 1.5W, 3W, 6W and 10W power levels and output voltages from 3.3V to 30V(1)(2). Both single and dual output models can be adjusted using the trim terminal. The CC-E can operate in ambient temperatures of -40 to 85°C and have an input to output isolation of 500Vac. Both through hole and surface mount packages are offered. The five-sided metal case reduces radiated noise. Features Benefits • Low Profile • Supports Vertical Mount Cards • Remote on/off • Individual Control • Five Sided Metal Case Design • Reduced Radiated Noise • Reduced Derating at High Ambient Temperatures • More Useable Power • No Potting • Low Weight Part Numbering Scheme CC Series Name CC 1R5 Output Power 1R5 = 1.5W, 3 = 3W 6 = 6W, 10 = 10W -05 Input Voltage 05 = 4.5 - 9V 12 = 9 - 18V 24 = 18 - 36V 48 = 36 - 76V 03 Output Voltage 03 = 3.3V 05 = 5V 12 = 12V 15 = 15V CC-E Series S S = Single Output D = Dual Output F -E Mounting Type F = Through hole R = Surface Mount S = Vertical SIP (CC3 only) 1 Model Selector - Single Output Model Note:Letter “”x”” indicates mounting type Input x=F through hole, x=R surface mount Voltage x=S SIP (CC3 only) (V) CC1R5-0503Sx-E CC3-0503Sx-E CC6-0503Sx-E CC10-0503Sx-E CC1R5-0505Sx-E CC3-0505Sx-E 4.5 - 9 CC6-0505Sx-E CC10-0505Sx-E CC1R5-0512Sx-E CC3-0512Sx-E CC6-0512Sx-E CC10-0512Sx-E CC1R5-1203Sx-E CC3-1203Sx-E CC6-1203Sx-E CC10-1203Sx-E CC1R5-1205Sx-E CC3-1205Sx-E 9 - 18 CC6-1205Sx-E CC10-1205Sx-E CC1R5-1212Sx-E CC3-1212Sx-E CC6-1212Sx-E CC10-1212Sx-E CC1R5-2403Sx-E CC3-2403Sx-E CC6-2403Sx-E CC10-2403Sx-E CC1R5-2405Sx-E CC3-2405Sx-E 18 - 36 CC6-2405Sx-E CC10-2405Sx-E CC1R5-2412Sx-E CC3-2412Sx-E CC6-2412Sx-E CC10-2412Sx-E CC1R5-4803Sx-E CC3-4803Sx-E CC6-4803Sx-E CC10-4803Sx-E CC1R5-4805Sx-E CC3-4805Sx-E 36 - 76 CC6-4805Sx-E CC10-4805Sx-E CC1R5-4812Sx-E CC3-4812Sx-E CC6-4812Sx-E CC10-4812Sx-E 2 Output Voltage(1) (V) 3.3 3.3 3.3 3.3 5 5 5 5 12 / 15 12 / 15 12 / 15 12 / 15 3.3 3.3 3.3 3.3 5 5 5 5 12 / 15 12 / 15 12 / 15 12 / 15 3.3 3.3 3.3 3.3 5 5 5 5 12 / 15 12 / 15 12 / 15 12 / 15 3.3 3.3 3.3 3.3 5 5 5 5 12 / 15 12 / 15 12 / 15 12 / 15 Output Current(1) (A) 0.4 0.8 1.2 2.5 0.3 0.6 1 2 0.125 / 0.1 0.25 / 0.2 0.5 / 0.4 0.8 / 0.64 0.4 0.8 1.2 2.5 0.3 0.6 1.2 2 0.125 / 0.1 0.25 / 0.2 0.5 / 0.4 1 / 0.8 0.4 0.8 1.2 2.5 0.3 0.6 1.2 2 0.125 / 0.1 0.25 / 0.2 0.5 / 0.4 1 / 0.8 0.4 0.8 1.2 2.5 0.3 0.6 1.2 2 0.125 / 0.1 0.25 / 0.2 0.5 / 0.4 1 / 0.8 Maximum Power (W) 1.32 2.64 3.96 8.25 1.5 3 5 10 1.5 3 6 9.6 1.32 2.64 3.96 8.25 1.5 3 6 10 1.5 3 6 12 1.32 2.64 3.96 8.25 1.5 3 6 10 1.5 3 6 12 1.32 2.64 3.96 8.25 1.5 3 6 10 1.5 3 6 12 CC-E Series Input Current at nominal input (A) 0.372 0.732 1.042 1.964 0.39 0.779 1.266 2.381 0.375 0.732 1.463 2.286 0.151 0.297 0.423 0.818 0.16 0.316 0.61 0.969 0.152 0.305 0.588 1.136 0.076 0.151 0.214 0.409 0.081 0.16 0.309 0.484 0.077 0.152 0.287 0.575 0.039 0.075 0.107 0.205 0.041 0.079 0.154 0.242 0.039 0.077 0.145 0.284 Efficiency (%) (100% load, nominal input) 71 73 76 84 77 77 79 84 80 82 82 84 73 74 78 84 78 79 82 86 82 82 85 88 72 73 77 84 77 78 81 86 81 82 87 87 70 73 77 84 76 79 81 86 80 81 86 88 Line / Load Regulation (mV) 20 / 40 20 / 40 20 / 40 20 / 40 20 / 40 20 / 40 20 / 40 20 / 40 40 / 100 40 / 100 40 / 100 40 / 100 20 / 40 20 / 40 20 / 40 20 / 40 20 / 40 20 / 40 20 / 40 20 / 40 40 / 100 40 / 100 40 / 100 40 / 100 20 / 40 20 / 40 20 / 40 20 / 40 20 / 40 20 / 40 20 / 40 20 / 40 40 / 100 40 / 100 40 / 100 40 / 100 20 / 40 20 / 40 20 / 40 20 / 40 20 / 40 20 / 40 20 / 40 20 / 40 40 / 100 40 / 100 40 / 100 40 / 100 Model Selector - Dual Output Model Note:Letter “”x”” indicates mounting type x=F through hole, x=R surface mount Input Voltage (V) Output Voltage(1)(2) (V) Output Current(1) (A) Maximum Power (W) Input Current at nominal input (A) Efficiency (%) (100% load, nominal input) Line / Load Regulation(3) (mV) CC1R5-0512Dx-E CC3-0512Dx-E 4.5 - 9 CC6-0512DF-E CC10-0512DF-E CC1R5-1212Dx-E CC3-1212Dx-E 9 - 18 CC6-1212Dx-E CC10-1212Dx-E CC1R5-2412Dx-E CC3-2412Dx-E 18 - 36 CC6-2412Dx-E CC10-2412Dx-E CC1R5-4812Dx-E CC3-4812Dx-E 36 - 76 CC6-4812Dx-E CC10-4812Dx-E ±12 / ±15 ±12 / ±15 ±12 / ±15 ±12 / ±15 ±12 / ±15 ±12 / ±15 ±12 / ±15 ±12 / ±15 ±12 / ±15 ±12 / ±15 ±12 / ±15 ±12 / ±15 ±12 / ±15 ±12 / ±15 ±12 / ±15 ±12 / ±15 ±0.06 / ±0.05 ±0.125 / ±0.1 ±0.25 / ±0.2 ±0.4 / ±0.32 ±0.06 / ±0.05 ±0.125 / ±0.1 ±0.25 / ±0.2 ±0.45 / ±0.36 ±0.06 / ±0.05 ±0.125 / ±0.1 ±0.25 / ±0.2 ±0.45 / ±0.36 ±0.06 / ±0.05 ±0.125 / ±0.1 ±0.25 / ±0.2 ±0.45 / ±0.36 1.5 3 6 9.6 1.5 3 6 10.8 1.5 3 6 10.8 1.5 3 6 10.8 0.38 0.741 1.463 2.313 0.154 0.309 0.588 1.047 0.079 0.154 0.291 0.523 0.04 0.078 0.145 0.262 79 81 82 83 81 81 85 86 79 81 86 86 79 80 86 86 80 / 600 80 / 600 80 / 600 80 / 600 80 / 600 80 / 600 80 / 600 80 / 600 80 / 600 80 / 600 80 / 600 80 / 600 80 / 600 80 / 600 80 / 600 80 / 600 Notes (1) 12V single and dual output models can be set to 15V by connecting the trim terminal to -Vout. See Instruction Manual for further details (2) ±12V dual output models can provide a 24V single output by utilizing just the +Vout and -Vout pins, leaving the COM unconnected. Similarly ±15V dual output models can be used as a 30V single output. (3) Based upon equal load current from both outputs Specifications Model Input Input Voltage Range - Efficiency - Conducted & Radiated EMI - Safety Certifications and Markings - Output Output Voltage Tolerance % Output Voltage Adjustment V Total Regulation % Ripple & Noise mV Temperature Coefficient %/°C Minimum Load - Overcurrent Protection % Overvoltage Protection - Overtemperature Protection - Remote Sense - Remote On/Off - Parallel Operation - CC1R5 CC3 CC6 CC10 See model selector table See model selector table See Instruction Manual on website for suggested external filtering IEC/UL/CSA/EN62368-1, CE Mark and UKCA Mark ±3 3.3V: 3.15-3.6, 5V: 4.75-6.0, 12V: 11.4-15 Single output: ±3, dual output: ±5 3.3/5V: 120 (40 typical), 12/15V 120 (30 typical) 0.02 No minimum load required Hiccup mode. >105 - - No remote sense Negative Logic ON: Short , OFF: Open Not possible CC-E Series 3 Specifications Model CC1R5 CC3 CC6 CC10 Environmental Operating Temperature °C -40 to +85 (Ambient). See derating guide below and installation manual. Storage Temperature °C -40 to +85 Humidity (non condensing) %RH
CC3-1205SR-E 价格&库存
很抱歉,暂时无法提供与“CC3-1205SR-E”相匹配的价格&库存,您可以联系我们找货
CC3-1205SR-E
  • 1+146.845801+19.05313
  • 10+139.0689110+18.04408
  • 25+136.0963325+17.65839
  • 50+133.8851050+17.37148
  • 100+131.70762100+17.08896
  • 250+128.87838250+16.72187
  • 500+126.77622500+16.44911
库存:284
