CCT354571-300-24-00
CCT354571-300-24-00
    TDK(东电化)
    CCT354571-300-24-00
CCT354571-300-24-00 数据手册
S E N S O R S September 2016 Clamp Type AC Current Sensors For energy management systems CCT series CCT406393 CCT354571 CCT323047 CCT272440 CCT261631 (2/13) S E N S O R S An attention matter on use Please read this specifications before using this product by all means. An attention matter on security I undertake use with this product, and it is paid attention enough, and please design an attention matter safely. Attention on a design When choosing load resistances used for current detection, be sure to select products with high precision and good temperature characteristics. Magnetic flux to leak out occurs. Please confirm it about influence of magnetic flux beforehand. There is fear to cause false movement of machinery. The product is not quakeproof structure. Accordingly please do not add vibration and a shock to it. There is fear to lose a function. Attention on the handling Please do not use it when you let a product drop. The product produces possibility to lose a function Please avoid the next place. The place that receives a drop of water, trash, the dust, foggy influence. The place where direct rays of the sun hits. There is fear to cause false movement of machinery. Please prohibit safekeeping and use at the next place. Environment to be accompanied with gas corrosion, salt, acid, alkali. There is fear to lose a function. When you carry the product on a base of an electric circuit. Please do not use a metal tool. Because impossible power is added to a product. There is fear to lose a function. Attention I considered the next matter, and we designed a product. Safe standard and power supply voltage and circuit drive condition, drive frequency and Duty ON-TIME. By those conditions, we decided structure and the turns number. Please avoid use in designed condition outside. There are destruction of a circuit part and fear of ignition. This product considered a characteristic of a component and a self temperature rise, and it was made. We select range of humidity as use temperature already. Please avoid use by range more than this. There are the damage and fear of ignition. Please avoid use in the environment next. The environment that trash and the dust stick to a product. There is fear to cause a fire. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 20160916 / sensor_current_cct_en.fm (3/13) S E N S O R S Product compatible with RoHS directive Compatible with lead-free solders Clamp Type AC Current Sensors For energy management systems Overview of the CCT Series FEATURES Clamp type for easy installation on existing power equipment. Accommodates automatic processes from wire wrapping and winding to soldering, eusuring high-quality and stable supply. Equipped with a built-in open-circuit protective device. Product compatible with RoHS directive. APPLICATION For energy management systems such as HEMS, BEMS, FEMS, CEMS PART NUMBER CONSTRUCTION CCT 406393 Series name External 40 63 93 L (Length) W (Width) H (Height) - 600 - Current 600 300 100 80 30 600A 300A 100A 80A 30A 36 Internal clamp section diameter 36 36mm 24 24mm 16 16mm 10 10mm 06 06mm - 00 Internal code OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT Temperature range Operating Storage Type temperature temperature (°C) (°C) CCT406393 –20 to 60 –30 to 60 CCT354571 –20 to 60 –30 to 60 CCT323047 –20 to 60 –30 to 60 CCT272440 –20 to 60 –30 to 60 CCT261631 –20 to 60 –30 to 60 Operating temperature range includes self-temperature rise. The Storage temperature range is for after the assembly. Package quantity Individual weight (pieces/box) 8 24 36 36 60 (g) 535 221 70 41 24 RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160916 / sensor_current_cct_en.fm (4/13) S E N S O R S CCT series CCT406393 Type SHAPE & DIMENSIONS 67.0max. 40.0±1.0 40.0±1.0 96.0max. ø3 6 – +1 0. 5 K→L 56.0max. 63.0±1.0 White: k 155±15 Black:ℓ * The connector specification differs depending on the last digit number. -00 Output connector Pin contact: SYM-001T-P0.6 (JST) Receptacle housing: SMR-02V-B (JST) -02 Output onnector Pin contact: SPAL-001T-P0.5 (JST) Receptacle housing: PALR-02VF (JST) Dimensions in mm CIRCUIT DIAGRAM k K ℓ L (Primary side) (Second side) Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160916 / sensor_current_cct_en.fm (5/13) S E N S O R S CCT series CCT406393 Type SPECIFICATION Part No. Applied current Maximum allowed current Internal clamp section diameter Nominal current transformation ratio Output current accuracy Phase difference Secondary winding resistance Open-circuit protection Pin contact Output connector Receptacle housing Socket contact Adaptation connector Plug housing Output lead wire Allowable desorption number of times Withstanding Voltage Insulation Resistance Flame retardant grade CCT406393-600-36-00 AC 1.0 to 600Arms (50/60Hz) AC 700Arms continuous 36mm 3000:1 200.0mA±1% (600A, 50/60Hz) 0.35°±0.2°(10, 600A, 50/60Hz) 64 7.5V Clamp element SYM-001T-P0.6 (JST) SMR-02V-B (JST) SHF-001T-0.8BS (JST) SMP-02V (JST) AWG22 155mm About100 times AC2200V, 1min. (Between outer case and output) 100MOver (DC500V) UL 94 V-0 CCT406393-600-36-02 AC 1.0 to 600Arms (50/60Hz) AC 700Arms continuous 36mm 3000:1 200.0mA±1% (600A, 50/60Hz) 0.35°±0.2°(10, 600A, 50/60Hz) 64 7.5V Clamp element SPAL-001T-P0.5 (JST) PALR-02VF (JST) SPHD-001T-P0.5 (JST) PAP-02V-S (JST) AWG22 155mm About100 times AC2200V, 1min. (Between outer case and output) 100MOver (DC500V) UL 94 V-0 ELECTRICAL CHARACTERISTICS MEASURING DIAGRAM Constant current source Through current Ii K k Ambient temperature: 25℃ Output voltage Vo L l V Load resistance RL Current transformer OUTPUT VOLTAGE CHARACTERISTIC 10000 Output voltage Vo(mVrms) 1000 100 RL=1kΩ 10 RL=100Ω 1 RL=10Ω 0.1 0.1 1 10 Through current Ii(Arms) 100 1000 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160916 / sensor_current_cct_en.fm (6/13) S E N S O R S CCT series CCT354571 Type SHAPE & DIMENSIONS 48.5max. 24.0±0.5 35.2±0.5 72.0max. ø2 4 – +1 0. 5 K→L 39.5max. 45.0±0.5 White: k 140±15 Black:ℓ * The connector specification differs depending on the last digit number. -00 Output connector Pin contact: SYM-001T-P0.6 (JST) Receptacle housing: SMR-02V-B (JST) -02 Output connector Pin contact: SPAL-001T-P0.5 (JST) Receptacle housing: PALR-02VF (JST) Dimensions in mm CIRCUIT DIAGRAM k K ℓ L (Primary side) (Second side) Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160916 / sensor_current_cct_en.fm (7/13) S E N S O R S CCT series CCT354571 Type SPECIFICATION Part No. Applied current Maximum allowed current Internal clamp section diameter Nominal current transformation ratio Output current accuracy Phase difference Secondary winding resistance Open-circuit protection Pin contact Output connector Receptacle housing Socket contact Adaptation connector Plug housing Output lead wire Allowable desorption number of times Withstanding Voltage Insulation Resistance Flame retardant grade CCT354571-300-24-00 AC 0.1 to 300Arms (50/60Hz) AC 400Arms continuous 24mm 3000:1 100.0mA±1% (300A, 50/60Hz) 0.7°±0.5° (10, 300A, 50/60Hz) 103 7.5V Clamp element SYM-001T-P0.6 (JST) SMR-02V-B (JST) SHF-001T-0.8BS (JST) SMP-02V (JST) AWG22 140mm AC2200V, 1min. (Between outer case and output) About100 times 100MOver (DC500V) UL 94 V-0 CCT354571-300-24-02 AC 0.1 to 300Arms (50/60Hz) AC 400Arms continuous 24mm 3000:1 100.0mA±1% (300A, 50/60Hz) 0.7°±0.5° (10, 300A, 50/60Hz) 103 7.5V Clamp element SPAL-001T-P0.5 (JST) PALR-02VF (JST) SPHD-001T-P0.5 (JST) PAP-02V-S (JST) AWG22 140mm AC2200V, 1min. (Between outer case and output) About100 times 100MOver (DC500V) UL 94 V-0 ELECTRICAL CHARACTERISTICS MEASURING DIAGRAM Constant current source Through current Ii K k Ambient temperature: 25℃ Output voltage Vo L l V Load resistance RL Current transformer OUTPUT VOLTAGE CHARACTERISTIC 10000 Output voltage Vo(mVrms) 1000 100 RL=1kΩ 10 RL=100Ω 1 RL=10Ω 0.1 0.1 1 10 Through current Ii(Arms) 100 1000 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160916 / sensor_current_cct_en.fm (8/13) S E N S O R S CCT series CCT323047 Type SHAPE & DIMENSIONS 32.5max. 18.8±0.5 31.5±0.5 47.5max. ø1 6– +1 0. 5 K→L 35.0max. 29.5±0.5 White: k 150±15 Black:ℓ * The connector specification differs depending on the last digit number. -00 Output connector Pin contact: SYM-001T-P0.6 (JST) Receptacle housing: SMR-02V-B (JST) -02 Output connector Pin contact: SPAL-001T-P0.5 (JST) Receptacle housing: PALR-02VF (JST) Dimensions in mm CIRCUIT DIAGRAM k K ℓ L (Primary side) (Second side) Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160916 / sensor_current_cct_en.fm (9/13) S E N S O R S CCT series CCT323047 Type SPECIFICATION Part No. Applied current Maximum allowed current Internal clamp section diameter Nominal current transformation ratio Output current accuracy Phase difference Secondary winding resistance Open-circuit protection Pin contact Output connector Receptacle housing Socket contact Adaptation connector Plug housing Output lead wire Allowable desorption number of times Withstanding Voltage Insulation Resistance Flame retardant grade CCT323047-100-16-00 AC 0.1 to 100Arms (50/60Hz) AC 200Arms continuous 16mm 3000:1 33.3mA±1% (100A, 50/60Hz) 1.2°±0.8° (10,100A, 50/60Hz) 285 7.5V Clamp element SYM-001T-P0.6 (JST) SMR-02V-B (JST) SHF-001T-0.8BS (JST) SMP-02V (JST) AWG22 150mm About100 times AC2200V , 1min. (Between outer case and output) 100MOver (DC500V) UL 94 V-0 CCT323047-100-16-02 AC 0.1 to 100Arms (50/60Hz) AC 200Arms continuous 16mm 3000:1 33.3mA±1% (100A, 50/60Hz) 1.2°±0.8° (10,100A, 50/60Hz) 285 7.5V Clamp element SPAL-001T-P0.5 (JST) PALR-02VF (JST) SPHD-001T-P0.5 (JST) PAP-02V-S (JST) AWG22 150mm About100 times AC2200V , 1min. (Between outer case and output) 100MOver (DC500V) UL 94 V-0 ELECTRICAL CHARACTERISTICS MEASURING DIAGRAM Constant current source Through current Ii K k Ambient temperature: 25℃ Output voltage Vo L V l Load resistance RL Current transformer OUTPUT VOLTAGE CHARACTERISTIC 10000 Output voltage Vo(mVrms) 1000 100 RL=1kΩ 10 RL=100Ω 1 RL=10Ω 0.1 0.1 1 10 100 Through current Ii(Arms) Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160916 / sensor_current_cct_en.fm (10/13) S E N S O R S CCT series CCT272440 Type SHAPE & DIMENSIONS 27.5max. 13.6±0.5 26.5±0.5 41.5max. ø1 0 – +1 0. 5 K→L 30.5max. 23.5±0.5 White: k 155±15 Black:ℓ * The connector specification differs depending on the last digit number. -00 Output connector Pin contact: SYM-001T-P0.6 (JST) Receptacle housing: SMR-02V-B (JST) -02 Output connector Pin contact: SPAL-001T-P0.5 (JST) Receptacle housing: PALR-02VF (JST) Dimensions in mm CIRCUIT DIAGRAM k K ℓ L (Primary side) (Second side) Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160916 / sensor_current_cct_en.fm (11/13) S E N S O R S CCT series CCT272440 Type SPECIFICATION Part No. Applied current Maximum allowed current Internal clamp section diameter Nominal current transformation ratio Output current accuracy Phase difference Secondary winding resistance Open-circuit protection Pin contact Output connector Receptacle housing Socket contact Adaptation connector Plug housing Output lead wire Allowable desorption number of times Withstanding Voltage Insulation Resistance Flame retardant grade CCT272440-80-10-00 AC 0.1 to 80Arms (50/60Hz) AC 120Arms continuous 10mm 3000:1 26.6mA±1% (80A, 50/60Hz) 1.7°±1.0° (10, 80A, 50/60Hz) 352 7.5V Clamp element SYM-001T-P0.6 (JST) SMR-02V-B (JST) SHF-001T-0.8BS (JST) SMP-02V (JST) AWG22 155mm About100 times AC2200V, 1min. (Between outer case and output) 100MOver (DC500V) UL 94 V-0 CCT272440-80-10-02 AC 0.1 to 80Arms (50/60Hz) AC 120Arms continuous 10mm 3000:1 26.6mA±1% (80A, 50/60Hz) 1.7°±1.0° (10, 80A, 50/60Hz) 352 7.5V Clamp element SPAL-001T-P0.5 (JST) PALR-02VF (JST) SPHD-001T-P0.5 (JST) PAP-02V-S (JST) AWG22 155mm About100 times AC2200V, 1min. (Between outer case and output) 100MOver (DC500V) UL 94 V-0 ELECTRICAL CHARACTERISTICS MEASURING DIAGRAM Constant current source Through current Ii K k Ambient temperature: 25℃ Output voltage Vo L V l Load resistance RL Current transformer OUTPUT VOLTAGE CHARACTERISTIC 10000 Output voltage Vo(mVrms) 1000 100 RL=1kΩ 10 RL=100Ω 1 RL=10Ω 0.1 0.1 1 10 100 Through current Ii(Arms) Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160916 / sensor_current_cct_en.fm (12/13) S E N S O R S CCT series CCT261631 Type SHAPE & DIMENSIONS 18.5max. 13.0±0.5 26.0±0.5 32.0max. ø6 + –0 0.5 .3 K→L 28.6max. 15.8±0.5 White: k 160±15 Black:ℓ * The connector specification differs depending on the last digit number. -00 Output connector Pin contact: SYM-001T-P0.6 (JST) Receptacle housing: SMR-02V-B (JST) -02 Output connector Pin contact: SPAL-001T-P0.5 (JST) Receptacle housing: PALR-02VF (JST) Dimensions in mm CIRCUIT DIAGRAM k K ℓ L (Primary side) (Second side) Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160916 / sensor_current_cct_en.fm (13/13) S E N S O R S CCT series CCT261631 Type SPECIFICATION Part No. Applied current Maximum allowed current Internal clamp section diameter Nominal current transformation ratio Output current accuracy Phase difference Secondary winding resistance Open-circuit protection Pin contact Output connector Receptacle housing Socket contact Adaptation connector Plug housing Output lead wire Allowable desorption number of times Withstanding Voltage Insulation Resistance Flame retardant grade CCT261631-30-06-00 AC 0.1 to 30Arms (50/60Hz) AC 50Arms continuous 6mm 3000:1 10mA±1% (30A, 50/60Hz) 3.0°±1.5° (10,30A, 50/60Hz) 492 7.5V Clamp element SYM-001T-P0.6 (JST) SMR-02V-B (JST) SHF-001T-0.8BS (JST) SMP-02V (JST) AWG22 160mm About100 times AC2200V , 1min. (Between outer case and output) 100MOver (DC500V) UL 94 V-0 CCT261631-30-06-02 AC 0.1 to 30Arms (50/60Hz) AC 50Arms continuous 6mm 3000:1 10mA±1% (30A, 50/60Hz) 3.0°±1.5° (10,30A, 50/60Hz) 492 7.5V Clamp element SPAL-001T-P0.5 (JST) PALR-02VF (JST) SPHD-001T-P0.5 (JST) PAP-02V-S (JST) AWG22 160mm About100 times AC2200V , 1min. (Between outer case and output) 100MOver (DC500V) UL 94 V-0 ELECTRICAL CHARACTERISTICS MEASURING DIAGRAM Constant current source Through current Ii K k Ambient temperature: 25℃ Output voltage Vo L V l Load resistance RL Current transformer OUTPUT VOLTAGE CHARACTERISTIC 10000 Output voltage Vo(mVrms) 1000 100 RL=1kΩ 10 RL=100Ω 1 RL=10Ω 0.1 0.1 1 10 100 Through current Ii(Arms) Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160916 / sensor_current_cct_en.fm
CCT354571-300-24-00 价格&库存
很抱歉,暂时无法提供与“CCT354571-300-24-00”相匹配的价格&库存,您可以联系我们找货
CCT354571-300-24-00
  • 1+451.576081+58.60634
  • 24+389.8884724+50.60041
  • 48+377.4857248+48.99076
  • 72+370.3964972+48.07071
  • 120+361.64104120+46.93441
库存:44
CCT354571-300-24-00
    • 1+155.59560
    • 192+62.08920
    • 504+60.01560
    • 1008+58.98960
