CD45-B2GA221K-VKA
CD45-B2GA221K-VKA
    TDK(东电化)
    插件,P=10mm
    特性:符合IEC和各国安全标准。满足加强绝缘的安全标准。耐压为4000V AC,适用于欧洲II类设备的单单元配置。阻燃增强外部绝缘,可防止火灾、触电等潜在危险。导线和内部焊接材料无铅,符合RoHS指令...
CD45-B2GA221K-VKA 数据手册
CD45-B2GA221K-VKA --- Disc Type Capacitors with Lead --Application & Main Feature Commercial Grade (Safety Standard Approved) Series CD45 Series Dimensions 6.5mm Max. 6.0mm Max. 10.0mm +/-1.0mm 0.6mm +/-0.05mm 10 |Z|/ohm D T F d |Z| vs. Freq. Characteristic 100 Temperature Characteristic B(+/-10%) 1 Rated Voltage 0.1 400Vac 10 100 1000 Frequency/MHz Withstanding Voltage 4000Vac Capacitance 220pF Temperature Characteristic 20 Capacitance Tolerance 0.35 Insulation Resistance Characterization Sheet 10000Mhorm Min. Leak Current/mArms 2.5% Max. Cap. Change/% +/-10% Dissipation Factor 10 0 -10 AEC-Q200 Not Applicable Lead Length / Package Type Leak Current 0.4 0.3 0.25 0.2 0.15 0.1 0.05 0 -20 -40 -20 0 20 40 Temperature/degC 60 80 100 0 1000 2000 3000 4000 5000 Voltage/Vrms Taping All specifications are subject to change without notice. August 30, 2016
CD45-B2GA221K-VKA 价格&库存
很抱歉,暂时无法提供与“CD45-B2GA221K-VKA”相匹配的价格&库存,您可以联系我们找货
