CD45-E2GA222M-VKA
CD45-E2GA222M-VKA
    TDK(东电化)
    CAP_D9X6MM_TM
    安规电容 CAP_D9X6MM_TM 2.2nF ±20% 440V
CD45-E2GA222M-VKA 数据手册
C A P A C I T O R S February 2016 Disc Type Capacitors with Lead High Voltage Ceramic Capacitors Commercial Grade, Safety Standard Approved CD45 series Type: CD45 [SL, B, E characteristics, Eac: X1=440V, Y1=400V] (2/9) C A P A C I T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and product temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications Please refer to the guideline of notabilia for fixed ceramic capacitors issued by JEITA(Japan Electronics and Information Technology Association, EIAJ RCR-2335). When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 20160219 / leaddisc_commercial_cd45_en.fm (3/9) C A P A C I T O R S Disc Type Capacitors with Lead Product compatible with RoHS directive Halogen-free High Voltage Ceramic Capacitors, Commercial Grade, Safety Standard Approved Overview of CD45 Series FEATURES Compliant with IEC and the safety standards of various countries. This ceramic capacitor meets reinforced insulation's Safety Standards. Since it is rated at a withstand voltage of AC.4000V, it can be used in single-unit configurations within European Class II devices. Flame-resistant reinforced outer insulation prevents fires, electrical shock, and other potential hazards. These products shall conform to RoHS Directive due to lead(Pb) free of lead wire and internal solder material. Compatible with halogen-free external resin coating. APPLICATION For use in Y capacitor for AC adapter, charger, power supplies PART NUMBER CONSTRUCTION CD45 Series name E 2GA 102 M Temperature characteristics Rated voltage Nominal capacitance Capacitance tolerance SL +350 to –1000ppm/°C B E ±10% +20, –55% 2GA X1: 440V Y1: 400V 100 102 222 10pF 1,000pF 2,200pF J K M ±5% ±10% ±20% - G N V □ K A Lead type Application classification Internal code Long lead Short lead Taping K Safety standard A Halogen-free Please refer to P-6 ∼ 8 about the product dimensions. OPERATING TEMPERATURE RANGE Temperature characteristics SL B E Temperature range Operating temperature (°C) –25 to +125 –25 to +125 –25 to +125 Storage temperature (°C) –25 to +125 –25 to +125 –25 to +125 The maximum operating temperature of 125°C includes capacitor self-generated heat of up to 20°C. The storage temperature range applies to after MLCC is mounted on board. RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_cd45_en.fm (4/9) C A P A C I T O R S Overview of CD45 Series PACKAGE QUANTITY Package quantity Type CD45 Taping (pieces / box) Bulk (pieces / bag) 1000 1000 CERTIFIED STATUS OF VARIOUS COUNTRIES Safety standard ENEC UL cUL/CSA SAA CQC KTL IEC standard No. Standard No. Temperature characteristics Class Rated voltage X1, Y1 X1:440V AC Y1:400V AC EN 60384-14 UL60384-14 IEC 60384-14 AS3250 IEC 60384-14 K60384-14 SL,B,E X1 Y1 440V AC 400V AC Approval report No.* Taiwan Xiamen ENEC-01048 E37861 CS6268 CQC14001112767 CQC14001112447 SZ03001-12002 SU03047-12002 SZ03001-12004 SU03047-12004 * Certificate numbers shall be changed owing to the revisions of the related standards. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_cd45_en.fm (5/9) C A P A C I T O R S Overview of CD45 RECOMMENDED FLOW PROFILE Soldering Preheating Natural cooling T: Temperature T2 T1 t1 t2 t3 t: Time Preheating Temp. T1 110°C min. Time t1 30 to 60s. Peak Temp. T2 260°C Time t2 Within 10s. Natural cooling Time t3 Over 60s. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_cd45_en.fm (6/9) C A P A C I T O R S CD45 Type CAPACITANCE AND DIMENSIONS Temperature Characteristics: SL (+350 to -1000ppm/°C) Rated Voltage Eac: X1=440V, Y1=400V Capacitance (pF) Capacitance tolerance 10 15 22 33 47 68 ±5% ±5% ±5% ±5% ±5% ±5% Dimensions (mm) D max. T max. 7.0 7.0 7.0 7.0 8.0 9.0 6.0 6.0 6.0 6.0 6.0 6.0 F (Applied to bulk) 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 F (Applied to taping) 10.0±1.0 10.0±1.0 10.0±1.0 10.0±1.0 10.0±1.0 10.0±1.0 Part No. d CD45SL2GA100J-□KA CD45SL2GA150J-□KA CD45SL2GA220J-□KA CD45SL2GA330J-□KA CD45SL2GA470J-□KA CD45SL2GA680J-□KA 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 * The part numbers are TDK’s standard specification products. The " □ " of the Part Number contains the lead wire type G, N or V. Please refer to the details of each shape is shown below. • Please refer to P-9 about the taping dimemsions. LIST OF STANDARD LEAD SHAPES Dimemsions in mm D Symbol V Taping T D T 16+1.5 –0.5 4max. T 4max. D Symbol N Bulk/Short lead 4max. Symbol G Bulk/Long lead F F d 5±1 25min. Vertical kink F d d • TDK’s standard product is vertical kink. • TDK’s recommendation is short lead type with the symbol N for bulk products. MARKINGS Item 1. Series 2. Nominal capacitance 3. Capacitance tolerance 4. Rated voltage Eac 5. TDK’s logogram 6. Date code Markings CD 10 J 440∼X1 400∼Y1 54 Specifications CD45 series 10pF ±5% X1: AC.440V Y1: AC.400V Production base code 2015.4 Marking examples Front CD 10J Back 54 (Marking position is reference.) Year and month of production: last digit of year + month denoted by 1, 2, 3, 4, 5, 6, 7, 8, 9, O (October), N (November), or D (December). The expression has become simplified due to a revision in the standards. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_cd45_en.fm (7/9) C A P A C I T O R S CD45 Type CAPACITANCE AND DIMENSIONS Temperature Characteristics: B (±10%) Rated Voltage Eac: X1=440V, Y1=400V Capacitance (pF) Capacitance tolerance 100 150 220 330 470 ±10% ±10% ±10% ±10% ±10% Dimensions (mm) D max. T max. 6.5 6.5 6.5 7.0 8.0 6.0 6.0 6.0 6.0 6.0 F (Applied to bulk) 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 F (Applied to taping) 10.0±1.0 10.0±1.0 10.0±1.0 10.0±1.0 10.0±1.0 Part No. d CD45-B2GA101K-□KA CD45-B2GA151K-□KA CD45-B2GA221K-□KA CD45-B2GA331K-□KA CD45-B2GA471K-□KA 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 * The part numbers are TDK’s standard specification products. The " □ " of the Part Number contains the lead wire type G, N or V. Please refer to the details of each shape is shown below. • Please refer to P-9 about the taping dimemsions. LIST OF STANDARD LEAD SHAPES Dimemsions in mm D Symbol V Taping T D T 16+1.5 –0.5 4max. T 4max. D Symbol N Bulk/Short lead 4max. Symbol G Bulk/Long lead F F d 5±1 25min. Vertical kink F d d • TDK’s standard product is vertical kink. • TDK’s recommendation is short lead type with the symbol N for bulk products. MARKINGS Item 1. Series 2. Nominal capacitance 3. Capacitance tolerance 4. Rated voltage Eac 5. TDK’s logogram 6. Date code Markings CD 101 K 440∼X1 400∼Y1 54 Specifications CD45 series 100pF ±10% X1: AC.440V Y1: AC.400V Production base code 2015.4 Marking examples Front CD 101K Back 54 (Marking position is reference.) Year and month of production: last digit of year + month denoted by 1, 2, 3, 4, 5, 6, 7, 8, 9, O (October), N (November), or D (December). The expression has become simplified due to a revision in the standards. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_cd45_en.fm (8/9) C A P A C I T O R S CD45 Type CAPACITANCE AND DIMENSIONS Temperature Characteristics: E (+20, –55%) Rated Voltage Eac: X1=440V, Y1=400V Capacitance (pF) Capacitance tolerance 680 1,000 1,500 2,200 3,300 4,700 ±20% ±20% ±20% ±20% ±20% ±20% Dimensions (mm) D max. T max. 6.5 7.0 8.0 9.0 11.0 13.0 6.0 6.0 6.0 6.0 6.0 6.0 F (Applied to bulk) 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 F (Applied to taping) 10.0±1.0 10.0±1.0 10.0±1.0 10.0±1.0 10.0±1.0 10.0±1.0 Part No. d CD45-E2GA681M-□KA CD45-E2GA102M-□KA CD45-E2GA152M-□KA CD45-E2GA222M-□KA CD45-E2GA332M-□KA CD45-E2GA472M-□KA 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 * The part numbers are TDK’s standard specification products. The " □ " of the Part Number contains the lead wire type G, N or V. Please refer to the details of each shape is shown below. • Please refer to P-9 about the taping dimemsions. LIST OF STANDARD LEAD SHAPES Dimemsions in mm D Symbol V Taping T D T 16+1.5 –0.5 4max. T 4max. D Symbol N Bulk/Short lead 4max. Symbol G Bulk/Long lead F F d 5±1 25min. Vertical kink F d d • TDK’s standard product is vertical kink. • TDK’s recommendation is short lead type with the symbol N for bulk products. MARKINGS Item 1. Series 2. Nominal capacitance 3. Capacitance tolerance 4. Rated voltage Eac 5. TDK’s logogram 6. Date code Markings CD 102 M 440∼X1 400∼Y1 54 Specifications CD45 series 1000pF ±20% X1: AC.440V Y1: AC.400V Production base code 2015.4 Marking examples Front CD 102M Back 54 (Marking position is reference.) Year and month of production: last digit of year + month denoted by 1, 2, 3, 4, 5, 6, 7, 8, 9, O (October), N (November), or D (December). The expression has become simplified due to a revision in the standards. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_cd45_en.fm (9/9) C A P A C I T O R S CD45 Type TAPING DIMEMSIONS P2 P1 P D T Δh S t W0 W L W1 H0 H1 H0 W2 C A Δh D0 F P0 ød Item Symbol Dimensions(mm) Body diameter D Depends on the specification of each product. Body thickness T Depends on the specification of each product. Lead-wire diameter ød 0.6±0.05 Pitch of component P 15.0±0.10 Including the slant of body Feed hole pitch P0 15.0±0.3 Excepting the tape splicing part Feed hole center to lead P1 10.0±0.7 Feed hole center to component center P2 15.0±1.3 Lead-to lead distance F 10±1 Measuring point is bottom kink Component alignment 'h 0±2.0 Including the slanting body due to bending lead-wire Tape width W 18.0+1.0, –0.5 Adhesive tape width W0 10.0min. Hole position W1 9.0±0.5 Adhesive tape position W2 4.0max. Bottom of kink from tape center H0 16.0+1.5, –0.5 Height of body from tape center H1 46.0max. Feed hole diameter D0 4.0±0.2 Total tape thickness t 0.6±0.3 Length of snipped lead L 11.0max. Lead-wire protrusion Remarks Adhesive tape do not stick out the tape 1.0max. Coating on lead C 4.0max. Height of kink A 4.0max. Spring action S 2.0max. Including adhesive tape Measuring point is bottom kink 320max. AMMO PACK INNER BOX SIZE x. ma 340max. 60 Dimensions in mm • For more information about products with other capacitance or other data, please contact us. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_cd45_en.fm
CD45-E2GA222M-VKA 价格&库存
很抱歉,暂时无法提供与“CD45-E2GA222M-VKA”相匹配的价格&库存,您可以联系我们找货
CD45-E2GA222M-VKA
  • 5+0.53684
库存:37
CD45-E2GA222M-VKA
  • 1000+0.942101000+0.12204
  • 2000+0.854872000+0.11074
  • 3000+0.819983000+0.10622
  • 5000+0.758925000+0.09831
  • 7000+0.732757000+0.09492
  • 10000+0.6978510000+0.09040
  • 12000+0.6891312000+0.08927
CD45-E2GA222M-VKA
    • 100+0.30180
    库存:6070
    CD45-E2GA222M-VKA
    • 1000+0.344601000+0.04460
    库存:13000
    CD45-E2GA222M-VKA
      库存:5000
