CD70-B2GA101KYVKA
CD70-B2GA101KYVKA
    TDK(东电化)
    插件,P=10mm
    CAP CER 100PF 440VAC RADIAL
CD70-B2GA101KYVKA 数据手册
Disc Type Capacitors with Lead High Voltage Ceramic Capacitors Commercial Grade Safety Standard Approved CD series Issue date: February 2013 • All specifications are subject to change without notice. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. (1/3) Disc Type Capacitors with Lead Conformity to RoHS Directive High Voltage Ceramic Capacitors Commercial Grade Safety Standard Approved CD Series REINFORCED INSULATION TYPE CLASS 2 HIGH DIELECTRIC FEATURES • Compliant with IEC and the safety standards of various countries. • This ceramic capacitor meets reinforced insulation's Safety Standards. Since it is rated at a withstand voltage of AC.4000V, it can be used in single-unit configurations within European Class II devices. • Flame-resistant reinforced outer insulation prevents fires, electrical shock, and other potential hazards. • Compatible with halogen-free external resin coating. OPERATING TEMPERATURE RANGE: –25 to +125°C PRODUCT IDENTIFICATION CD 90 ZU 2GA 222 M Y N K A (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (1) Type (2) Shape (3) Temperature characteristics (4) Rated voltage (5) Nominal capacitance (6) Capacitance tolerance (7) Class (8) Lead type (9) Safety standard (10) Halogen-free compatible product TEMPERATURE CHARACTERISTICS AND TOLERANCE Temperature characteristics SL (+350 to –1000ppm/°C) B (±10%) Z5U (+22, –56%) Test temperature range +20 to +85°C –25 to +85°C +10 to +85°C Capacitance tolerance J (±5%) K (±10%) M (±20%) • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 006-01 / 20130207 / leaddisc_commercial_cd_en.fm (2/3) CAPACITANCE AND DIMENSIONS Part No. CD45SL2GA100JYKA CD45SL2GA150JYKA CD45SL2GA220JYKA CD45SL2GA330JYKA CD45SL2GA470JYKA CD45SL2GA680JYKA CD70-B2GA101KYKA CD70-B2GA151KYKA CD70-B2GA221KYKA CD75-B2GA331KYKA CD85-B2GA471KYKA CD65ZU2GA681MYKA CD70ZU2GA102MYKA CD80ZU2GA152MYKA CD90ZU2GA222MYKA CD11ZU2GA332MYKA CD12ZU2GA472MYKA  Capacitance (pF) 10 15 22 33 47 68 100 150 220 330 470 680 1,000 1,500 2,200 3,300 4,700 Temperature characteristics SL (+350 to –1000ppm/°C) B (±10%) Z5U (+22, –56%) Capacitance tolerance J (±5%) J (±5%) J (±5%) J (±5%) J (±5%) J (±5%) K (±10%) K (±10%) K (±10%) K (±10%) K (±10%) M (±20%) M (±20%) M (±20%) M (±20%) M (±20%) M (±20%) Dimensions (mm) D max. T max. 7.0 7.0 7.0 7.0 7.0 7.0 7.0 7.0 8.0 7.0 9.0 7.0 7.0 7.0 7.0 7.0 7.0 7.0 7.5 7.0 9.0 7.0 7.0 7.0 7.0 7.0 8.0 7.0 9.5 7.0 12.0 7.0 13.5 7.0 F 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 10.0+2.0, –1.0 d 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05  : Lead shape symbol LIST OF STANDARD LEAD SHAPES The lead type is indicated by the letter which is the 15th character of the product name. Example) TDK Product Name: CD90ZU2GA222MYNKA N: Lead type (Vertical kink, Short) Dimensions in mm Long lead Symbol G Symbol N T D T 4max. 4max. D Short lead F F d 5±1 25min. Vertical kink d • We recommend using a vertical kink type. • For bulk products, we recommend a short lead type with the symbol N. MARKINGS Item 1. Series 2. Nominal capacitance 3. Capacitance tolerance 4. Rated voltage Eac 5. TDK’s logogram 6. Date code Markings CD 222 M 440∼X1 400∼Y1 29 Specifications CD series 2200pF ±20% X1: AC.440V Y1: AC.400V Production base code 2012.9 Marking examples CD222M 29 (Marking position is reference.)   Year and month of production: last digit of year + month denoted by 1, 2, 3, 4, 5, 6, 7, 8, 9, O (October), N (November), or D (December). The expression has become simplified due to a revision in the standards. • For more information about products with other capacitance or other data, please contact us. • All specifications are subject to change without notice. 006-01 / 20130207 / leaddisc_commercial_cd_en.fm (3/3) CERTIFIED STATUS OF VARIOUS COUNTRIES Safety standard BSI VDE SEV SEMKO NEMKO DEMKO FIMKO IMQ SAA UL CSA CQC Standard No. Temperature characteristics Insulation sub-class Rated voltage BS EN60384-14 EN 60384-14 EN 60384-14 EN 60384-14 EN 60384-14 EN 60384-14 EN 60384-14 EN 60384-14 AS3250 UL 60384-14 CAN/CSA-E60384-14 GB/T14472-1998 SL, B, Z5U X1, Y1 X1: AC.440V Y1: AC.400V Approval report No. Taiwan KM37103 40017931 12.0223 1125241 P12215264 D-01094 FI 27387 V3691 CS6268 E37861 1785504 CQC12001082617 Xiamen KM37103 40017931 12.0223 1125241 P12215264 D-01094 FI 27387 V3691 CS6268 E37861 1785504 CQC10001052863 • Certificate numbers shall be changed owing to the revisions of the related standards. • All specifications are subject to change without notice. 006-01 / 20130207 / leaddisc_commercial_cd_en.fm
CD70-B2GA101KYVKA 价格&库存
很抱歉,暂时无法提供与“CD70-B2GA101KYVKA”相匹配的价格&库存,您可以联系我们找货
CD70-B2GA101KYVKA
  • 1+0.22880
  • 50+0.13420
  • 1000+0.12100
库存:2000
CD70-B2GA101KYVKA
    • 1+2.69470
    • 10+1.84840
    • 100+0.93090
    • 500+0.83070
    库存:50
