CD90-B2GA331KYNS
CD90-B2GA331KYNS
    TDK(东电化)
    Radial
    贴片电容(MLCC) 径向 330pF ±10% 250V B
CD90-B2GA331KYNS 数据手册
Mid-high Voltage Ceramic Capacitors Disk type with lead Safety standard approved CD series Issue date: October 2011 • All specifications are subject to change without notice. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. (1/2) Mid-high Voltage Ceramic Capacitors(Disk with Lead) Safety Standard Approved CD Series Conformity to RoHS Directive REINFORCED INSULATION TYPE/Operating temperature range: –25 to +105°C(UL standard: –25 to +85°C) CLASS 2 HIGH DIELECTRIC FEATURES • Flame-resistant reinforced outer insulation prevents fires, electrical shock, and other potential hazards. • Compliant with the safety standards of 11 countries. • This ceramic capacitor meets European Class II (reinforced insulation) Safety Standards VDE, SEV, SEMKO, BS. Since it is rated at a withstand voltage of AC.4000V, it can be used in single-unit configurations within European Class II devices. • This product is compatible with halogen-free external resin coating (we recommend halogen-free products as standard). PRODUCT IDENTIFICATION CD 12 -E 2GA 222 M Y N S A (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (1) Type (2) Shape (3) Capacitance temperature characteristics (4) Rated voltage (5) Nominal capacitance (6) Capacitance tolerance (7) Class (8) Lead type (9) Safety standard (10) Halogen-free compatible product CAPACITANCE TEMPERATURE CHARACTERISTICS AND TOLERANCE Temperature characteristics B(±10%) E(+20, –55%) Test temperature range –25 to +85°C –25 to +85°C Capacitance tolerance K(±10%) M(±20%) CAPACITANCE AND DIMENSIONS Part No. Halogen-free product Current product CD70-B2GA101KY†∗SA CD70-B2GA101KY†∗S CD70-B2GA151KY†SA CD85-B2GA221KY†SA CD90-B2GA331KY†SA CD90-B2GA391KY†SA CD95-B2GA471KY†SA CD75-E2GA681MY†SA CD85-E2GA102MY†SA CD10-E2GA152MY†SA CD12-E2GA222MY†SA CD14-E2GA332MY†SA CD15-E2GA392MY†SA CD16-E2GA472MY†SA CD70-B2GA151KY†S CD85-B2GA221KY†S CD90-B2GA331KY†S CD90-B2GA391KY†S CD95-B2GA471KY†S CD75-E2GA681MY†S CD85-E2GA102MY†S CD10-E2GA152MY†S CD12-E2GA222MY†S CD14-E2GA332MY†S CD15-E2GA392MY†S CD16-E2GA472MY†S ∗ Capacitance temperature characteristics B(±10%) E(+20, –55%) Capacitance (pF) Capacitance tolerance 100 150 220 330 390 470 680 1,000 1,500 2,200 3,300 3,900 4,700 K(±10%) K(±10%) K(±10%) K(±10%) K(±10%) K(±10%) M(±20%) M(±20%) M(±20%) M(±20%) M(±20%) M(±20%) M(±20%) Dimensions(mm) D max. T max. F d 7.0 7.0 8.5 9.0 9.0 9.5 7.5 8.5 10.0 11.5 13.5 14.5 15.5 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 7.0 7.0 7.0 7.0 7.0 7.0 7.0 7.0 7.0 7.0 7.0 7.0 7.0 10+2, –1 10+2, –1 10+2, –1 10+2, –1 10+2, –1 10+2, –1 10+2, –1 10+2, –1 10+2, –1 10+2, –1 10+2, –1 10+2, –1 10+2, –1 † : Lead shape symbol LIST OF STANDARD LEAD SHAPES The lead type is indicated by the letter which is the 15th character of the product name. Example) TDK Product Name: CD12-E2GA222MYNSA N: Lead type (Vertical kink, Short) Dimensions in mm Long lead Symbol G T D T 4max. 4max. D Short lead Symbol N F F d 5±1 25min. Vertical kink d • We recommend using a vertical kink type. • For bulk products, we recommend a short lead type with the symbol N. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20111003 / e4b3_cd.fm (2/2) HALOGEN-FREE PRODUCT MARKINGS Item 1. Series 2. Nominal capacitance 3. Capacitance tolerance 4. Rated voltage Eac 5. Sub-class of safety performance 6. TDK’s logogram 7. Date code ∗ ∗ Marking examples CD 222(2200pF) M(±20%) (AC.250V) 250V X1Y1 CD222M 250 X1Y1 15 15 (2011.5)∗ (Marking position is reference.) Year and month of production: last digit of year + month denoted by 1, 2, 3, 4, 5, 6, 7, 8, 9, O (October), N (November), or D (December). The expression has become simplified due to a revision in the standards. INTERNATIONALLY CERTIFIED STATUS / IEC60384-14 EN60384-14 Approved Safety standard VDE SEV SEMKO NEMKO DEMKO FIMKO IMQ SAA UL Standard No. of IEC IEC 60065 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60065 — CSA CQC BSI Temperature Insulation characteristics sub-class Standard No. BS EN 60065 BS EN60384-14 EN 60384-14 EN 60384-14 EN 60384-14 EN 60384-14 EN 60384-14 EN 60384-14 EN 60384-14 AS3250 UL 1414 Rated voltage Eac(V) Approval report No. Japan Taiwan Xiamen B, E X1, Y1 250 KM37103 KM37103 KM37103 B, E B, E B, E B, E B, E B, E B, E B, E B, E X1, Y1 X1, Y1 X1, Y1 X1, Y1 X1, Y1 X1, Y1 X1, Y1 — (X, Y) 250 250 250 250 250 250 250 400 250 IEC 60384-14 CAN/CSA-E60384-14 B, E (X, Y) 250 IEC 60384-14 GB-T 14472-1998 B, E X1, Y1 250 40029780 10.0121 912465 P09211658 315294-01 FI 25522 V3691 CS6268 E37861 2278970 (LR 35801) CQC10001051611 40029780 10.0121 912465 P09211658 315294-01 FI 25522 V3691 CS6268 E37861 2278970 (LR 35801) CQC10001051638 40029780 10.0121 912465 P09211658 315294-01 FI 25522 V3691 CS6268 E37861 2278970 (LR 35801) CQC03001004816 • Certificate numbers shall be changed owing to the revisions of the related standards. CURRENT PRODUCT MARKINGS Item 1. Series 2. Nominal capacitance 3. Capacitance tolerance 4. Rated voltage Eac 5. Withstand voltage Eac 6. Sub-class of safety performance 7. TDK’s logogram 8. Date code 9. Regulatory body safety standards compliance markings BSI (U.K.) ∗ BSI SEV (Switzerland) SEMKO (Sweden) UL (U.S.A.) VDE (Germany) CSA (Canada) TJ508 Marking examples CD 222(2200pF) M(±20%) (AC.250V) 250V (AC.4kV ) T4KV X1Y1 Back Front CD222M 250V X1Y1 BSI T4KV TJ508 94 15 (2011.5)∗ (Marking position of the monogram is reference.) FIMKO (Finland) NEMKO (Norway) DEMKO (Denmark) IMQ (Italy) Year and month of production: last digit of year + month denoted by 1, 2, 3, 4, 5, 6, 7, 8, 9, O (October), N (November), or D (December). INTERNATIONALLY CERTIFIED STATUS / IEC60384-14 EN60384-14 Approved Safety standard BSI VDE SEV SEMKO NEMKO DEMKO FIMKO IMQ SAA UL CSA Standard No. of IEC IEC 60065 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60065 — — Standard No. BS EN 60065 BS EN60384-14 EN60384-14 EN60384-14 EN60384-14 EN60384-14 EN60384-14 EN60384-14 EN60384-14 AS3250 UL 1414 CSA C22.2 No.0 & No.1 Temperature characteristics Insulation sub-class Rated voltage Eac(V) Approval report No. Japan Taiwan Xiamen B, E X1, Y1 250 226495 226495 226495 B, E B, E B, E B, E B, E B, E B, E B, E B, E B, E X1, Y1 X1, Y1 X1, Y1 X1, Y1 X1, Y1 X1, Y1 X1, Y1 — (X, Y) (X, Y) 250 250 250 250 250 250 250 400 250 250 138526 09.0963 915564 P09211509 315180-01 FI 25452 V3691 6268 E37861 LR35801 138550 09.0963 915564 P09211509 315180-01 FI 25452 V3691 6268 E37861 LR65972 124321 09.0963 915396 P08209310 314712-02 FI 24307 V3691 6268 E37861 LR65972 • Certificate numbers shall be changed owing to the revisions of the related standards. • For more information about products with other capacitance or other data, please contact us. • All specifications are subject to change without notice. 005-03 / 20111003 / e4b3_cd.fm
CD90-B2GA331KYNS 价格&库存
很抱歉,暂时无法提供与“CD90-B2GA331KYNS”相匹配的价格&库存,您可以联系我们找货
