CE-1050-TP
CE-1050-TP
    TDK(东电化)
    SMD10 模块
    DC DC CONVERTER 3.3-12.6V
CE-1050-TP 数据手册
CE-1050 Series 1.2 - 2.5A Point of Load Converter Features u 9 to 26.4V Input u 3.3 to 12.6V Outputs u Surface Mount u Low 5.5mm Profile u Non Isolated Output u Wide range output u Constant switching frequency u Five sided shielding Specifications Model CE-1050 Nominal Output Voltage Input Voltage Range Input Current (max) Output Voltage Tolerance Ripple & Noise (typ) (pk - pk) Total Regulation (typ) Overload Protection (typ) Overvoltage Protection Remote Sense Remote On / Off Sequencing Temperature (operating) Temperature (storage) Humidity (operating) Humidity (storage) Cooling Isolation Voltage Vibration (non operating) Shock Safety Agency Approvals Weight (max) Size Warranty (1) VDC VDC A % mV mV A °C °C VDC g mm - +3.3 to +12.6 9 - 26.4 1.8 N/A 50 (18V input, 5V 2.5A output) Vout=3.3 to 5.0:±3.5%; Vout ≥ 5.0: ±5% 3.5 None None Voltage on pin 5: ON = 3 - 6V; OFF= 0 - 0.6V None -20 to +85°C -20 to +85°C 10-90% RH Non condensing @ max temp 38°C Sealed packaging, see Technical Download Convection or forced air N/A Frequency: 10-2000Hz, Sweep time: 4 minutes per cycle Amplitude: 10G, 30 minutes each x, y, and z direction Peak Acceleration: 100G, Duration: 6msec; three times each axis N/A 3.7 21.3 x 16.4 x 5.5 1 year Notes: (1) Input / output voltage differential must ≥ 4V. OBSOLETE 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 5 CE-1050 Series Derating Curves Model Selector Model Output1 Voltage (V) Output1 Adjust (V) Output Current (A) Efficiency (typ) CE-1050 3.3 - 12.6V 3.3 - 12.6V see curves 90% 1 2 3 4 5 10 9 8 7 6 CE-1050 TDK-XXXX Lot No. 16.4 0.3 P P P P 17.7max. Outline Drawing 0.1min. 5.5max. 21.3 0.3 Pinout Pin Function 1 2 3 4 5 6 7 8 9 10 Vin Vin GND GND On / Off GND GND Vset Vout Vout Description +V input +V input -V input -V input Remote On/Off -V output -V output Output trim +V output +V output Options Suffix Options Blank -TP Tray package Tape and reel (400 per reel) For Additional Information, please visit us.tdk-lambda.com/lp/products/ce-series.htm OBSOLETE 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 6 Revision A2: Nov 2011
CE-1050-TP 价格&库存
很抱歉,暂时无法提供与“CE-1050-TP”相匹配的价格&库存,您可以联系我们找货
