CEU3E2X7R2A102M080AE
    TDK(东电化)
    贴片电容(MLCC) 0603 1nF ±20% 100V X7R
CEU3E2X7R2A102M080AE 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS April 2019 MULTILAYER CERAMIC CHIP CAPACITORS Automotive grade, serial design   CEU series CEU3 1608 [0603 inch] CEU4 2012 [0805 inch] * Dimensions code: JIS[EIA] (2/6) MULTILAYER CERAMIC CHIP CAPACITORS REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS 1. The products listed in this specification are intended for use in automotive applications under normal operation and usage conditions. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality requires a more stringent level of safety or reliability, or whose failure, malfunction or defect could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in this specification, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (excepting Pharmaceutical Affairs Law classification Class1,2) (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 2. 3. 4. 5. 6. 7. In addition, although the products listed in this specification are intended for use in automotive applications as described above, they are not prohibited to use in general electronic equipment, whose performance and/or quality doesn’t require a more stringent level of safety or reliability, or whose failure, malfunction or defect could not cause serious damage to society, person or property. Therefore, the description of this caution will be applied, when the products are used in general electronic equipment under a normal operation and usage conditions. We may modify products or discontinue production of a product listed in this catalog without prior notification. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export permission in harmony with this law. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging specification detail. This new catalog number should be referenced on all catalog orders going forward, and is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will differ from the item description (internal control number) on the product label. Contact your local TDK Sales representative for more information. (Example) Catalog issued date Prior to January 2013 January 2013 and later Catalog number C1608C0G1E103J(080AA) C1608C0G1E103J080AA Item description (on delivery label) C1608C0G1E103JT000N C1608C0G1E103JT000N 20190402 / mlcc_automotive_serial_en.fm (3/6) MULTILAYER CERAMIC CHIP CAPACITORS CEU series Cl Br Serial design RoHS REACH Halogen Free SVHC-Free Pb Lead Free Type: CEU3/1608 [0603 inch], CEU4/2012 [0805 inch] ■ SERIES OVERVIEW Serial design CEU series, automotive grade of TDK's multilayer ceramic chip capacitor, is a product which has two capacitors in series in single body construction. The structure decreases risk of short circuit failures due to mechanical flex cracks. Additionally, CEU series has higher mechanical endurance by flexible resin layers which absorbs thermal and mechanical stress. The capacitance range is up to 100nF. ■ FEATURES ■ APPLICATIONS • Serial structure decreases risk of short circuit failures due to mechanical flex cracks. • Higher mechanical endurance is realized by flexible resin layers. • AEC-Q200 compliant. • Fail-safe design in battery line. • For circuits requiring safer design ■ SHAPE & DIMENSIONS ■ PRODUCT STRUCTURE General Serial design W L T Sn Ni Conductive resin layer Cu G B L W T B G Body length Body width Body height Terminal width Terminal spacing Type L W CEU3 1.60+0.20,–0.10 0.80+0.15,–0.10 CEU4 2.00+0.30,–0.20 1.25+0.25,–0.20 Dimensional tolerances are typical values. A general structure which opposite inner electrodes are alternately stacked. T 0.80+0.15,–0.10 1.25+0.25,–0.20 A product which has two capacitors in series in single body construction and flexible resin layer. Dimensions in mm B G 0.20min. 0.30min. 0.20min. 0.50min. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190402 / mlcc_automotive_serial_en.fm (4/6) MULTILAYER CERAMIC CHIP CAPACITORS ■ CATALOG NUMBER CONSTRUCTION CEU 4 J 2 X7R 1H 104 K 125 A E (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (1) Series (2) Dimensions L x W (mm) Code 3 4 EIA CC0603 CC0805 Length 1.60 2.00 Width 0.80 1.25 Terminal width 0.20 0.20 (Example)0R5 = 0.5pF 101 = 100pF 225 = 2,200,000pF = 2.2µF (3) Thickness code Code E J Thickness 0.80 mm 1.25 mm (8) Capacitance tolerance Code K M (4) Voltage condition for life test Symbol 2 (7) Nominal capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. Condition 2 × R.V. Tolerance ±10% ±20% (9) Thickness (5) Temperature characteristics Temperature characteristics X7R Capacitance change Temperature range ±15% –55 to +125°C Code 080 125 Thickness 0.80 mm 1.25 mm (10) Packaging style (6) Rated voltage (DC) Code A Code 1H 2A (11) Special reserved code Voltage (DC) 50V 100V Code E Style 178mm reel, 4mm pitch Description Soft termination Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190402 / mlcc_automotive_serial_en.fm (5/6) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 Code CEU3/1608 [0603 inch] X7R 2A (100V) 1H (50V) 102 152 222 332 472 682 103 153 223 333 473 Standard thickness  0.80mm Background gray: The product which is not recommended to a new design. ■ Please refer to the capacitance range table at P-6 for the details such as product thickness and capacitance tolerance. Capacitance range chart Capacitance (pF) 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 Code CEU4/2012 [0805 inch] X7R 2A (100V) 1H (50V) 102 152 222 332 472 682 103 153 223 333 473 683 104 Standard thickness  1.25 mm Background gray: The product which is not recommended to a new design. ■ Please refer to the capacitance range table at P-6 for the details such as product thickness and capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190402 / mlcc_automotive_serial_en.fm (6/6) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions Thickness (mm) 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 68nF 2012 1.25+0.25,-0.20 100nF 2012 1.25+0.25,-0.20 1nF 1.5nF 2.2nF 3.3nF 4.7nF 6.8nF 10nF 15nF 22nF 33nF 47nF Temperature characteristics: X7R (–55 to +125°C, ±15%) Capacitance tolerance Catalog number Rated voltage Edc: 100V ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% CEU3E2X7R2A102K080AE CEU3E2X7R2A102M080AE CEU4J2X7R2A102K125AE CEU4J2X7R2A102M125AE CEU3E2X7R2A152K080AE CEU3E2X7R2A152M080AE CEU4J2X7R2A152K125AE CEU4J2X7R2A152M125AE CEU3E2X7R2A222K080AE CEU3E2X7R2A222M080AE CEU4J2X7R2A222K125AE CEU4J2X7R2A222M125AE CEU3E2X7R2A332K080AE CEU3E2X7R2A332M080AE CEU4J2X7R2A332K125AE CEU4J2X7R2A332M125AE Rated voltage Edc: 50V CEU3E2X7R1H472K080AE CEU3E2X7R1H472M080AE CEU4J2X7R2A472K125AE CEU4J2X7R2A472M125AE CEU3E2X7R1H682K080AE CEU3E2X7R1H682M080AE CEU4J2X7R2A682K125AE CEU4J2X7R2A682M125AE CEU3E2X7R1H103K080AE CEU3E2X7R1H103M080AE CEU4J2X7R2A103K125AE CEU4J2X7R2A103M125AE CEU3E2X7R1H153K080AE CEU3E2X7R1H153M080AE CEU4J2X7R2A153K125AE CEU4J2X7R2A153M125AE CEU3E2X7R1H223K080AE CEU3E2X7R1H223M080AE CEU4J2X7R1H223K125AE CEU4J2X7R1H223M125AE CEU3E2X7R1H333K080AE CEU3E2X7R1H333M080AE CEU4J2X7R1H333K125AE CEU4J2X7R1H333M125AE CEU3E2X7R1H473K080AE CEU3E2X7R1H473M080AE CEU4J2X7R1H473K125AE CEU4J2X7R1H473M125AE CEU4J2X7R1H683K125AE CEU4J2X7R1H683M125AE CEU4J2X7R1H104K125AE CEU4J2X7R1H104M125AE ■ Gray item: The product which is not recommended to a new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190402 / mlcc_automotive_serial_en.fm
物料型号: - CEU3 1608 [0603 inch] - CEU4 2012 [0805 inch]
器件简介: - 这是TDK的汽车级多层陶瓷片式电容器系列,具有串联设计,可以减少由于机械弯曲裂纹导致的短路故障风险。CEU系列通过柔性树脂层实现更高的机械耐久性。
引脚分配: - 文档中未明确提供引脚分配信息,但提到了产品结构,其中提到了导电树脂层和铜。
参数特性: - 电容范围高达100nF。 - 符合AEC-Q200标准。 - 温度特性:X7R ±15%,工作温度范围为-55到+125°C。 - 额定电压:2A (100V) 和 1H (50V)。 - 电容公差:K±10% 和 M±20%。 - 产品尺寸和厚度:CEU3为1.60mm x 0.80mm x 0.80mm,CEU4为2.00mm x 1.25mm x 1.25mm。
功能详解: - 串联设计减少了机械弯曲裂纹导致的短路故障风险。 - 柔性树脂层提高了机械耐久性。 - 适用于需要更安全设计的电路,如电池线路的故障安全设计。
应用信息: - 用于电池线路的故障安全设计。 - 适用于需要更安全设计的电路。
封装信息: - 封装类型包括CEU3和CEU4,具体尺寸如上所述。 - 产品符合REACH SVHC-Free、无铅、RoHS和卤素免费标准。
CEU3E2X7R2A102M080AE 价格&库存
很抱歉,暂时无法提供与“CEU3E2X7R2A102M080AE”相匹配的价格&库存,您可以联系我们找货
  • 1+1.325221+0.17097
  • 10+0.7246010+0.09348
  • 50+0.5091450+0.06569
  • 100+0.44363100+0.05724
  • 500+0.33161500+0.04278
  • 1000+0.297231000+0.03835
库存:687
  • 4000+0.238814000+0.03081
  • 8000+0.220298000+0.02842
  • 12000+0.2110312000+0.02723
  • 20000+0.2007620000+0.02590
  • 28000+0.1947728000+0.02513
  • 40000+0.1890140000+0.02439
库存:687
  • 4000+0.18326
  • 8000+0.16937
  • 12000+0.16554
  • 20000+0.16098
  • 4000+0.197964000+0.02554
  • 8000+0.182198000+0.02351
  • 12000+0.1786912000+0.02306
  • 20000+0.1734320000+0.02238
