CGA1A2C0G1E100D030BA
    TDK(东电化)
    ±0.5PF 10PF 25V
CGA1A2C0G1E100D030BA 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS CGA Series Automotive Grade General (Up to 50V) Type: CGA1 [EIA CC0201] CGA2 [EIA CC0402] CGA3 [EIA CC0603] CGA4 [EIA CC0805] CGA5 [EIA CC1206] CGA6 [EIA CC1210] CGA8 [EIA CC1812] CGA9 [EIA CC2220] Issue date: Dec 2014 20141219 / mlcc_automotive_general_en MULTILAYER CERAMIC CHIP CAPACITORS REMINDERS Please read before using this product SAFETY REMINDERS REMINDERS 1. If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other damage, you must contact our company’s sales window. 2. We may modify products or discontinue production of a product listed in this catalog without prior notification. 3. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. 4. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export permission in harmony with this law. 5. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. 6. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. 7. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging specification detail. This new catalog number should be referenced on all catalog orders going forward, and is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will differ from the item description (internal control number) on the product label. Contact your local TDK Sales representative for more information. (Example) Catalog Issued date Catalog Number Item Description (On Delivery Label) Prior to January 2013 C1608C0G1E103J C1608C0G1E103JT000N January 2013 and Later C1608C0G1E103J080AA C1608C0G1E103JT000N Page 1 20141219 / mlcc_automotive_general_en MULTILAYER CERAMIC CHIP CAPACITORS CGA Series General (Up to 50V) Type: CGA1 [EIA CC0201], CGA2 [EIA CC0402], CGA3 [EIA CC0603], CGA4 [EIA CC0805], CGA5 [EIA CC1206], CGA6 [EIA CC1210], CGA8 [EIA CC1812], CGA9 [EIA CC2220] Features • High capacitance has been achieved through precision technologies that enable the use of multiple thinner ceramic dielectric layers. • A monolithic structure ensures superior mechanical strength and reliability. • Low ESL and excellent frequency characteristics allow for a circuit design that closely conforms to theoretical values. • Low self-heating and high ripple resistance due to low ESR. • AEC-Q200 compliant. Catalog Number Construction Applications • • • • • Automotive engine control units Automotive sensor modules Automotive battery line smoothing Applications requiring higher reliability Switching power supply smoothing Shape & Dimensions L W T B G Body Length Body Width Body Height Terminal Width Terminal Spacing CGA • 6 • P • 1 • X7S • 0J • 476 • M • 250 • A • C Series Name Dimensions L x W (mm) Code 1 2 3 4 5 6 8 9 Length 0.60 ± 0.03 1.00 ± 0.05 1.60 ± 0.10 2.00 ± 0.20 3.20 ± 0.20 3.20 ± 0.40 4.50 ± 0.40 5.70 ± 0.40 Width 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 1.25 ± 0.20 1.60 ± 0.20 2.50 ± 0.30 3.20 ± 0.40 5.00 ± 0.40 Terminal 0.10 min. 0.10 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. *Dimension tolerance are typical values Thickness T Code (mm) Code A B C E F H J L M N P Q R Thickness 0.30 mm 0.50 mm 0.60 mm 0.80 mm 0.85 mm 1.15 mm 1.25 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm 2.80 mm 3.20 mm Voltage Condition for Life Test Symbol 1 2 3 Condition 1 × R.V. 2 × R.V. 1.5 × R.V. Temperature Characteristics Temperature Characteristics C0G X5R X7R X7S Temperature Coefficient or Capacitance Change 0±30 ppm/°C ±15% ±15% ±22% Temperature Range -55 to +125°C -55 to + 85°C -55 to +125°C -55 to +125°C Rated Voltage (DC) Code 0J 1A 1C 1E 1V 1H Voltage (DC) 6.3V 10V 16V 25V 35V 50V Nominal Capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. Ex. 0R2 = 0.2pF; 103 = 10,000pF; 105 = 1,000,000pF = 1,000nF = 1ȝF Capacitance Tolerance Code C D J K M Tolerance ± 0.25pF ± 0.50pF ± 5% ± 10% ± 20% Nominal Thickness Code 030 050 060 125 Thickness 0.30 mm 0.50 mm 0.60 mm 1.25 mm Packaging Style Code A B K Style 178 mm Reel, 4 mm Pitch 178 mm Reel, 2 mm Pitch 178 mm Reel, 8 mm Pitch Special Reserved Code Code A, B Description TDK Internal Code *See Thickness T Code for complete list Page 2 • All specifications are subject to change without notice. 20141219 / mlcc_automotive_general_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA1(0603) [EIA CC0201] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), X7R (±15%) Rated Voltage: 50V (1H), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J) Capacitance (pF) 1 1.5 2 2.2 3 3.3 4 4.7 5 6 6.8 7 8 9 10 12 15 18 22 27 33 39 47 56 68 82 100 150 220 330 470 680 1000 1500 2200 3300 4700 6800 10000 X7R C0G Code 010 1R5 020 2R2 030 3R3 040 4R7 050 060 6R8 070 080 090 100 120 150 180 220 270 330 390 470 560 680 820 101 151 221 331 471 681 102 152 222 332 472 682 103 Tolerance 1H (50V) 1E (25V) 1H (50V) 1E 1C (25V) (16V) 1A (10V) 0J (6.3V) C: ± 0.25pF D: ± 0.50pF J : ± 5% K : ± 10% M: ± 20% Standard Thickness 0.30 mm Page 3 • All specifications are subject to change without notice. 20141219 / mlcc_automotive_general_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA2(1005) [EIA CC0402] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), X5R (±15%), X7R (±15%) , X7S (±22%) Rated Voltage: 50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3 (0J) Capacitance (pF) 1 1.5 2 2.2 3 3.3 4 4.7 5 6 6.8 7 8 9 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 C0G Code 010 1R5 020 2R2 030 3R3 040 4R7 050 060 6R8 070 080 090 100 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 152 222 332 472 682 103 153 223 333 473 683 104 154 224 334 474 Tolerance 1H (50V) X5R 1H (50V) 1V (35V) 1E (25V) X7R 1C (16V) 1A (10V) 1H (50V) 1V (35V) 1E (25V) X7S 1C (16V) 1A 0J 1C (10V) (6.3V) (16V) 1A (10V) C : ± 0.25pF D : ± 0.50pF J : ± 5% K : ± 10% M: ± 20% Standard Thickness 0.50 mm Page 4 • All specifications are subject to change without notice. 20141219 / mlcc_automotive_general_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA3(1608) [EIA CC0603] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC) Rated Voltage: 50V (1H) Capacitance (pF) 1 1.5 2 2.2 3 3.3 4 4.7 5 6 6.8 7 8 9 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 C0G Code 010 1R5 020 2R2 030 3R3 040 4R7 050 060 6R8 070 080 090 100 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 Tolerance 1H (50V) C: ± 0.25pF D: ± 0.50pF J: ± 5% K: ± 10% M: ± 20% Standard Thickness 0.80 mm Page 5 • All specifications are subject to change without notice. 20141219 / mlcc_automotive_general_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA3(1608) [EIA CC0603] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), X5R (±15%), X7R (±15%), X7S (±22%) Rated Voltage: 50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J) Capacitance Code Tolerance (pF) 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 102 122 152 182 222 272 332 392 472 562 682 822 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 335 475 C0G 1H (50V) X5R 1H (50V) 1V (35V) 1E (25V) X7R 1C (16V) 1A (10V) 0J 1H (6.3V) (50V) 1V (35V) 1E (25V) X7S 1C (16V) 0J (6.3V) 1C (16V) 1A (10V) J : ± 5% K : ± 10% M: ± 20% Standard Thickness 0.80 mm Page 6 • All specifications are subject to change without notice. 20141219 / mlcc_automotive_general_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA4(2012) [EIA CC0805] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), X5R (±15%), X7R (±15%), X7S (±22%) Rated Voltage: 50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J) C0G Capacitance (pF) Code Tolerance 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 102 122 152 182 222 272 332 392 472 562 682 822 103 153 223 333 104 154 224 334 474 684 105 155 225 335 475 685 106 J : ± 5% K : ± 10% M: ± 20% 1H (50V) X5R 1H (50V) 1V (35V) 1E (25V) X7R 1C (16V) 1A (10V) 1H (50V) 1V (35V) 1E (25V) X7S 1C (16V) 1A (10V) 0J 1C (6.3V) (16V) 1A (10V) Standard Thickness 0.60 mm 0.85 mm 1.25 mm Page 7 • All specifications are subject to change without notice. 20141219 / mlcc_automotive_general_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA5(3216) [EIA CC1206] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), X5R (±15%), X7R (±15%) Rated Voltage: 50V (1H), 35V (1V), 25V (1E), 16V (1C), 6.3V (0J) C0G Capacitance (pF) Code 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 472 562 682 822 103 153 223 333 473 683 104 474 684 105 155 225 335 475 685 106 156 226 Tolerance 1H (50V) X5R 1H (50V) 1V (35V) X7R 1E (25V) 1C (16V) 1H (50V) 1V (35V) 1E (25V) 1C (16V) 0J (6.3V) J: ± 5% K: ± 10% M: ± 20% Standard Thickness 0.60 mm 0.85 mm 1.15 mm 1.60 mm Capacitance Range Chart CGA6(3225) [EIA CC1210] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), X7R (±15%), X7S (±22%) Rated Voltage: 50V (1H), 25V (1E), 16V (1C), 6.3V (0J) C0G Capacitance (pF) Code 22,000 33,000 47,000 68,000 100,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 33,000,000 47,000,000 223 333 473 683 104 105 155 225 335 475 685 106 156 226 336 476 Tolerance 1H (50V) X7R 1H (50V) 1E (25V) X7S 1C (16V) 1H (50V) 0J (6.3V) J: ± 5% K: ± 10% M: ± 20% Standard Thickness 1.25 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm Page 8 • All specifications are subject to change without notice. 20141219 / mlcc_automotive_general_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA8(4532) [EIA CC1812] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), X7R (±15%) Rated Voltage: 50V (1H), 25V (1E), 16V (1C) C0G Capacitance (pF) Code 47,000 68,000 100,000 150,000 220,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 33,000,000 473 683 104 154 224 155 225 335 475 685 106 156 226 336 Tolerance 1H (50V) X7R 1H (50V) 1E (25V) 1C (16V) J: ± 5% K: ± 10% M: ± 20% Standard Thickness 1.60 mm 2.00 mm 2.30 mm 2.50 mm 2.80 mm 3.20 mm Capacitance Range Chart CGA9(5750) [EIA CC2220] Capacitance Range Chart Temperature Characteristics: X7R (±15%) Rated Voltage: 50V (1H), 25V (1E), 16V (1C) X7R Capacitance (pF) Code 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 47,000,000 475 685 106 156 226 476 Tolerance 1H (50V) K: ± 10% M: ± 20% 1E (25V) 1C (16V) Standard Thickness 2.00 mm 2.30 mm 2.50 mm Page 9 • All specifications are subject to change without notice. 20141219 / mlcc_automotive_general_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to +125ºC, 0 ± 30 ppm/ºC) Capacitance 1 pF 1.5 pF 2 pF 2.2 pF 3 pF 3.3 pF 4 pF 4.7 pF 5 pF 6 pF 6.8 pF 7 pF 8 pF 9 pF 10 pF 12 pF 15 pF 18 pF 22 pF 27 pF Size Thickness (mm) Capacitance Tolerance 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% Catalog Number Rated Voltage Edc: 50V CGA1A2C0G1H010C030BA CGA2B2C0G1H010C050BA CGA3E2C0G1H010C080AA CGA1A2C0G1H1R5C030BA CGA2B2C0G1H1R5C050BA CGA3E2C0G1H1R5C080AA CGA1A2C0G1H020C030BA CGA2B2C0G1H020C050BA CGA3E2C0G1H020C080AA CGA1A2C0G1H2R2C030BA CGA2B2C0G1H2R2C050BA CGA3E2C0G1H2R2C080AA CGA1A2C0G1H030C030BA CGA2B2C0G1H030C050BA CGA3E2C0G1H030C080AA CGA1A2C0G1H3R3C030BA CGA2B2C0G1H3R3C050BA CGA3E2C0G1H3R3C080AA CGA1A2C0G1H040C030BA CGA2B2C0G1H040C050BA CGA3E2C0G1H040C080AA CGA1A2C0G1H4R7C030BA CGA2B2C0G1H4R7C050BA CGA3E2C0G1H4R7C080AA CGA1A2C0G1H050C030BA CGA2B2C0G1H050C050BA CGA3E2C0G1H050C080AA CGA1A2C0G1H060D030BA CGA2B2C0G1H060D050BA CGA3E2C0G1H060D080AA CGA1A2C0G1H6R8D030BA CGA2B2C0G1H6R8D050BA CGA3E2C0G1H6R8D080AA CGA1A2C0G1H070D030BA CGA2B2C0G1H070D050BA CGA3E2C0G1H070D080AA CGA1A2C0G1H080D030BA CGA2B2C0G1H080D050BA CGA3E2C0G1H080D080AA CGA1A2C0G1H090D030BA CGA2B2C0G1H090D050BA CGA3E2C0G1H090D080AA CGA1A2C0G1H100D030BA CGA2B2C0G1H100D050BA CGA3E2C0G1H100D080AA CGA1A2C0G1H120J030BA CGA2B2C0G1H120J050BA CGA3E2C0G1H120J080AA CGA1A2C0G1H150J030BA CGA2B2C0G1H150J050BA CGA3E2C0G1H150J080AA CGA1A2C0G1H180J030BA CGA2B2C0G1H180J050BA CGA3E2C0G1H180J080AA CGA1A2C0G1H220J030BA CGA2B2C0G1H220J050BA CGA3E2C0G1H220J080AA CGA1A2C0G1H270J030BA CGA2B2C0G1H270J050BA CGA3E2C0G1H270J080AA Rated Voltage Edc: 25V CGA1A2C0G1E010C030BA CGA1A2C0G1E1R5C030BA CGA1A2C0G1E020C030BA CGA1A2C0G1E2R2C030BA CGA1A2C0G1E030C030BA CGA1A2C0G1E3R3C030BA CGA1A2C0G1E040C030BA CGA1A2C0G1E4R7C030BA CGA1A2C0G1E050C030BA CGA1A2C0G1E060D030BA CGA1A2C0G1E6R8D030BA CGA1A2C0G1E070D030BA CGA1A2C0G1E080D030BA CGA1A2C0G1E090D030BA CGA1A2C0G1E100D030BA CGA1A2C0G1E120J030BA CGA1A2C0G1E150J030BA CGA1A2C0G1E180J030BA CGA1A2C0G1E220J030BA CGA1A2C0G1E270J030BA Page 10 • All specifications are subject to change without notice. 20141219 / mlcc_automotive_general_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to +125ºC, 0 ± 30 ppm/ºC) Capacitance 33 pF 39 pF 47 pF 56 pF 68 pF 82 pF 100 pF 120 pF 150 pF 180 pF 220 pF 270 pF 330 pF 390 pF 470 pF 560 pF 680 pF 820 pF 1 nF 1.2 nF 1.5 nF 1.8 nF 2.2 nF 2.7 nF 3.3 nF 3.9 nF Size Thickness (mm) Capacitance Tolerance 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 0603 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 2012 1608 2012 1608 2012 1608 2012 1608 2012 1608 2012 1608 2012 1608 2012 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% Catalog Number Rated Voltage Edc: 50V CGA1A2C0G1H330J030BA CGA2B2C0G1H330J050BA CGA3E2C0G1H330J080AA CGA1A2C0G1H390J030BA CGA2B2C0G1H390J050BA CGA3E2C0G1H390J080AA CGA1A2C0G1H470J030BA CGA2B2C0G1H470J050BA CGA3E2C0G1H470J080AA CGA1A2C0G1H560J030BA CGA2B2C0G1H560J050BA CGA3E2C0G1H560J080AA CGA1A2C0G1H680J030BA CGA2B2C0G1H680J050BA CGA3E2C0G1H680J080AA CGA1A2C0G1H820J030BA CGA2B2C0G1H820J050BA CGA3E2C0G1H820J080AA CGA1A2C0G1H101J030BA CGA2B2C0G1H101J050BA CGA3E2C0G1H101J080AA CGA2B2C0G1H121J050BA CGA3E2C0G1H121J080AA CGA2B2C0G1H151J050BA CGA3E2C0G1H151J080AA CGA2B2C0G1H181J050BA CGA3E2C0G1H181J080AA CGA2B2C0G1H221J050BA CGA3E2C0G1H221J080AA CGA2B2C0G1H271J050BA CGA3E2C0G1H271J080AA CGA2B2C0G1H331J050BA CGA3E2C0G1H331J080AA CGA2B2C0G1H391J050BA CGA3E2C0G1H391J080AA CGA2B2C0G1H471J050BA CGA3E2C0G1H471J080AA CGA2B2C0G1H561J050BA CGA3E2C0G1H561J080AA CGA2B2C0G1H681J050BA CGA3E2C0G1H681J080AA CGA2B2C0G1H821J050BA CGA3E2C0G1H821J080AA CGA2B2C0G1H102J050BA CGA3E2C0G1H102J080AA CGA4C2C0G1H102J060AA CGA3E2C0G1H122J080AA CGA4C2C0G1H122J060AA CGA3E2C0G1H152J080AA CGA4C2C0G1H152J060AA CGA3E2C0G1H182J080AA CGA4C2C0G1H182J060AA CGA3E2C0G1H222J080AA CGA4C2C0G1H222J060AA CGA3E2C0G1H272J080AA CGA4C2C0G1H272J060AA CGA3E2C0G1H332J080AA CGA4C2C0G1H332J060AA CGA3E2C0G1H392J080AA CGA4C2C0G1H392J060AA Rated Voltage Edc: 25V CGA1A2C0G1E330J030BA CGA1A2C0G1E390J030BA CGA1A2C0G1E470J030BA CGA1A2C0G1E560J030BA CGA1A2C0G1E680J030BA CGA1A2C0G1E820J030BA CGA1A2C0G1E101J030BA Page 11 • All specifications are subject to change without notice. 20141219 / mlcc_automotive_general_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to +125ºC, 0 ± 30 ppm/ºC) Capacitance 4.7 nF 5.6 nF 6.8 nF 8.2 nF 10 nF 15 nF 22 nF 33 nF 47 nF 68 nF 100 nF 150 nF 220 nF Size Thickness (mm) Capacitance Tolerance 1608 2012 3216 1608 2012 3216 1608 2012 3216 1608 2012 3216 1608 2012 3216 2012 3216 2012 3216 3225 2012 3216 3225 3216 3225 4532 3216 3225 4532 3216 3225 4532 4532 4532 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.85 ± 0.15 0.60 ± 0.15 1.25 ± 0.20 0.60 ± 0.15 1.25 ± 0.20 1.25 ± 0.20 0.85 ± 0.15 1.60 ± 0.20 1.15 ± 0.15 2.00 ± 0.20 1.60 ± 0.20 1.60 ± 0.20 2.00 ± 0.20 1.60 ± 0.20 1.60 ± 0.20 2.50 ± 0.30 2.00 ± 0.20 2.50 ± 0.30 3.20 ± 0.30 ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% Catalog Number Rated Voltage Edc: 50V CGA3E2C0G1H472J080AA CGA4C2C0G1H472J060AA CGA5C2C0G1H472J060AA CGA3E2C0G1H562J080AA CGA4C2C0G1H562J060AA CGA5C2C0G1H562J060AA CGA3E2C0G1H682J080AA CGA4C2C0G1H682J060AA CGA5C2C0G1H682J060AA CGA3E2C0G1H822J080AA CGA4C2C0G1H822J060AA CGA5C2C0G1H822J060AA CGA3E2C0G1H103J080AA CGA4C2C0G1H103J060AA CGA5C2C0G1H103J060AA CGA4F2C0G1H153J085AA CGA5C2C0G1H153J060AA CGA4J2C0G1H223J125AA CGA5C2C0G1H223J060AA CGA6J2C0G1H223J125AA CGA4J2C0G1H333J125AA CGA5F2C0G1H333J085AA CGA6L2C0G1H333J160AA CGA5H2C0G1H473J115AA CGA6M2C0G1H473J200AA CGA8L2C0G1H473J160KA CGA5L2C0G1H683J160AA CGA6M2C0G1H683J200AA CGA8L2C0G1H683J160KA CGA5L2C0G1H104J160AA CGA6P2C0G1H104J250AA CGA8M2C0G1H104J200KA CGA8P2C0G1H154J250KA CGA8R2C0G1H224J320KA Rated Voltage Edc: 25V Class 2 (Temperature Stable) Temperature Characteristics: X5R (-55 to +85ºC, ±15%) Capacitance Size Thickness (mm) 220 pF 1005 0.50 ± 0.05 330 pF 1005 0.50 ± 0.05 470 pF 1005 0.50 ± 0.05 680 pF 1005 0.50 ± 0.05 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1 nF 1.5 nF 2.2 nF Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 50V CGA2B2X5R1H221K050BA CGA2B2X5R1H221M050BA CGA2B2X5R1H331K050BA CGA2B2X5R1H331M050BA CGA2B2X5R1H471K050BA CGA2B2X5R1H471M050BA CGA2B2X5R1H681K050BA CGA2B2X5R1H681M050BA CGA2B2X5R1H102K050BA CGA2B2X5R1H102M050BA CGA3E2X5R1H102K080AA CGA3E2X5R1H102M080AA CGA2B2X5R1H152K050BA CGA2B2X5R1H152M050BA CGA3E2X5R1H152K080AA CGA3E2X5R1H152M080AA CGA2B2X5R1H222K050BA CGA2B2X5R1H222M050BA CGA3E2X5R1H222K080AA CGA3E2X5R1H222M080AA Rated Voltage Edc: 35V Rated Voltage Edc: 25V Rated Voltage Edc: 16V Page 12 • All specifications are subject to change without notice. 20141219 / mlcc_automotive_general_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X5R (-55 to +85ºC, ±15%) Capacitance Size Thickness (mm) 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 1.25 ± 0.20 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 1.25 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3.3 nF 4.7 nF 6.8 nF 10 nF 15 nF 22 nF 33 nF 47 nF 68 nF 100 nF 150 nF 220 nF 330 nF Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 50V CGA2B2X5R1H332K050BA CGA2B2X5R1H332M050BA CGA3E2X5R1H332K080AA CGA3E2X5R1H332M080AA CGA2B2X5R1H472K050BA CGA2B2X5R1H472M050BA CGA3E2X5R1H472K080AA CGA3E2X5R1H472M080AA CGA2B2X5R1H682K050BA CGA2B2X5R1H682M050BA CGA3E2X5R1H682K080AA CGA3E2X5R1H682M080AA CGA2B3X5R1H103K050BB CGA2B3X5R1H103M050BB CGA3E2X5R1H103K080AA CGA3E2X5R1H103M080AA CGA2B3X5R1H153K050BB CGA2B3X5R1H153M050BB CGA3E2X5R1H153K080AA CGA3E2X5R1H153M080AA CGA2B3X5R1H223K050BB CGA2B3X5R1H223M050BB CGA3E2X5R1H223K080AA CGA3E2X5R1H223M080AA CGA2B3X5R1H333K050BB CGA2B3X5R1H333M050BB CGA3E2X5R1H333K080AA CGA3E2X5R1H333M080AA CGA2B3X5R1H473K050BB CGA2B3X5R1H473M050BB CGA3E2X5R1H473K080AA CGA3E2X5R1H473M080AA CGA2B3X5R1H683K050BB CGA2B3X5R1H683M050BB CGA3E2X5R1H683K080AA CGA3E2X5R1H683M080AA CGA2B3X5R1H104K050BB CGA2B3X5R1H104M050BB CGA3E2X5R1H104K080AA CGA3E2X5R1H104M080AA Rated Voltage Edc: 35V Rated Voltage Edc: 25V Rated Voltage Edc: 16V CGA2B3X5R1V103K050BB CGA2B2X5R1E103K050BA CGA2B3X5R1V103M050BB CGA2B2X5R1E103M050BA CGA2B3X5R1V153K050BB CGA2B2X5R1E153K050BA CGA2B3X5R1V153M050BB CGA2B2X5R1E153M050BA CGA2B3X5R1V223K050BB CGA2B2X5R1E223K050BA CGA2B3X5R1V223M050BB CGA2B2X5R1E223M050BA CGA2B3X5R1V333K050BB CGA2B2X5R1E333K050BA CGA2B2X5R1C333K050BA CGA2B3X5R1V333M050BB CGA2B2X5R1E333M050BA CGA2B2X5R1C333M050BA CGA2B3X5R1V473K050BB CGA2B2X5R1E473K050BA CGA2B2X5R1C473K050BA CGA2B3X5R1V473M050BB CGA2B2X5R1E473M050BA CGA2B2X5R1C473M050BA CGA2B3X5R1V683K050BB CGA2B3X5R1E683K050BB CGA2B2X5R1C683K050BA CGA2B3X5R1V683M050BB CGA2B3X5R1E683M050BB CGA2B2X5R1C683M050BA CGA2B3X5R1V104K050BB CGA2B3X5R1E104K050BB CGA2B2X5R1C104K050BA CGA2B3X5R1V104M050BB CGA2B3X5R1E104M050BB CGA2B2X5R1C104M050BA CGA3E2X5R1E104K080AA CGA3E2X5R1E104M080AA CGA2B1X5R1C154K050BC CGA2B1X5R1C154M050BC CGA3E3X5R1H154K080AB CGA3E3X5R1V154K080AB CGA3E2X5R1E154K080AA CGA3E3X5R1H154M080AB CGA3E3X5R1V154M080AB CGA3E2X5R1E154M080AA CGA4J2X5R1H154K125AA CGA4J2X5R1H154M125AA CGA2B1X5R1C224K050BC CGA2B1X5R1C224M050BC CGA3E3X5R1H224K080AB CGA3E3X5R1V224K080AB CGA3E2X5R1E224K080AA CGA3E2X5R1C224K080AA CGA3E3X5R1H224M080AB CGA3E3X5R1V224M080AB CGA3E2X5R1E224M080AA CGA3E2X5R1C224M080AA CGA4J2X5R1H224K125AA CGA4J2X5R1H224M125AA CGA3E3X5R1H334K080AB CGA3E3X5R1V334K080AB CGA3E3X5R1E334K080AB CGA3E2X5R1C334K080AA CGA3E3X5R1H334M080AB CGA3E3X5R1V334M080AB CGA3E3X5R1E334M080AB CGA3E2X5R1C334M080AA CGA4J2X5R1H334K125AA CGA4J2X5R1H334M125AA Page 13 • All specifications are subject to change without notice. 20141219 / mlcc_automotive_general_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X5R (-55 to +85ºC, ±15%) Capacitance 470 nF 680 nF 1 μF 1.5 μF Size Thickness (mm) 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 1.60 +0.30/-0.10 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 1.60 +0.30/-0.10 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 1.60 +0.30/-0.10 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 1.60 +0.30/-0.10 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 1.60 +0.30/-0.10 2012 1.25 ± 0.20 3216 1.60 +0.30/-0.10 2012 1.25 ± 0.20 3216 1.60 +0.30/-0.10 2012 1.25 ± 0.20 3216 1.60 +0.30/-0.10 2012 1.25 ± 0.20 3216 1.60 +0.30/-0.10 3216 3216 1.60 +0.30/-0.10 1.60 +0.30/-0.10 2.2 μF 2.2 μF 3.3 μF 4.7 μF 6.8 μF 10 μF 15 μF 22 μF Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 20% ± 20% Catalog Number Rated Voltage Edc: 50V CGA3E3X5R1H474K080AB CGA3E3X5R1H474M080AB CGA4J3X5R1H474K125AB CGA4J3X5R1H474M125AB CGA5L2X5R1H474K160AA CGA5L2X5R1H474M160AA CGA3E3X5R1V684K080AB CGA3E3X5R1H684M080AB CGA4J3X5R1H684K125AB CGA4J3X5R1H684M125AB CGA5L2X5R1H684K160AA CGA5L2X5R1H684M160AA CGA3E3X5R1H105K080AB CGA3E3X5R1H105M080AB CGA4J3X5R1H105K125AB CGA4J3X5R1H105M125AB CGA5L2X5R1H105K160AA CGA5L2X5R1H105M160AA CGA4J3X5R1H155K125AB CGA4J3X5R1H155M125AB CGA5L3X5R1H155K160AB CGA5L3X5R1H155M160AB CGA4J3X5R1H225K125AB CGA4J3X5R1H225M125AB CGA5L3X5R1H225K160AB CGA5L3X5R1H225M160AB CGA4J3X5R1H335K125AB CGA4J3X5R1H335M125AB CGA5L3X5R1H335K160AB CGA5L3X5R1H335M160AB CGA4J3X5R1H475K125AB CGA4J3X5R1H475M125AB CGA5L3X5R1H475K160AB CGA5L3X5R1H475M160AB CGA5L3X5R1H685K160AB CGA5L3X5R1H685M160AB CGA5L3X5R1H106K160AB CGA5L3X5R1H106M160AB Rated Voltage Edc: 35V CGA3E3X5R1V474K080AB CGA3E3X5R1V474M080AB CGA4J3X5R1V474K125AB CGA4J3X5R1V474M125AB Rated Voltage Edc: 25V Rated Voltage Edc: 16V CGA3E3X5R1E474K080AB CGA3E2X5R1C474K080AA CGA3E3X5R1E474M080AB CGA3E2X5R1C474M080AA CGA4J2X5R1E474K125AA CGA4J2X5R1E474M125AA CGA3E3X5R1H684K080AB CGA3E3X5R1V684M080AB CGA4J3X5R1V684K125AB CGA4J3X5R1V684M125AB CGA3E3X5R1E684K080AB CGA3E3X5R1E684M080AB CGA4J2X5R1E684K125AA CGA4J2X5R1E684M125AA CGA3E2X5R1C684K080AA CGA3E2X5R1C684M080AA CGA4J2X5R1C684K125AA CGA4J2X5R1C684M125AA CGA3E3X5R1V105K080AB CGA3E3X5R1V105M080AB CGA4J3X5R1V105K125AB CGA4J3X5R1V105M125AB CGA3E3X5R1E105K080AB CGA3E3X5R1E105M080AB CGA4J2X5R1E105K125AA CGA4J2X5R1E105M125AA CGA3E1X5R1C105K080AC CGA3E1X5R1C105M080AC CGA4J2X5R1C105K125AA CGA4J2X5R1C105M125AA CGA3E1X5R1C155K080AC CGA3E1X5R1C155M080AC CGA4J3X5R1V155K125AB CGA4J3X5R1E155K125AB CGA4J2X5R1C155K125AA CGA4J3X5R1V155M125AB CGA4J3X5R1E155M125AB CGA4J2X5R1C155M125AA CGA5L3X5R1V155K160AB CGA5L2X5R1E155K160AA CGA5L3X5R1V155M160AB CGA5L2X5R1E155M160AA CGA3E1X5R1C225K080AC CGA3E1X5R1C225M080AC CGA4J3X5R1V225K125AB CGA4J3X5R1E225K125AB CGA4J2X5R1C225K125AA CGA4J3X5R1V225M125AB CGA4J3X5R1E225M125AB CGA4J2X5R1C225M125AA CGA5L3X5R1V225K160AB CGA5L2X5R1E225K160AA CGA5L3X5R1V225M160AB CGA5L2X5R1E225M160AA CGA4J3X5R1V335K125AB CGA4J3X5R1E335K125AB CGA4J3X5R1C335K125AB CGA4J3X5R1V335M125AB CGA4J3X5R1E335M125AB CGA4J3X5R1C335M125AB CGA5L3X5R1V335K160AB CGA5L2X5R1E335K160AA CGA5L3X5R1V335M160AB CGA5L2X5R1E335M160AA CGA4J3X5R1V475K125AB CGA4J3X5R1E475K125AB CGA4J3X5R1C475K125AB CGA4J3X5R1V475M125AB CGA4J3X5R1E475M125AB CGA4J3X5R1C475M125AB CGA5L3X5R1V475K160AB CGA5L2X5R1E475K160AA CGA5L2X5R1C475K160AA CGA5L3X5R1V475M160AB CGA5L2X5R1E475M160AA CGA5L2X5R1C475M160AA CGA4J1X5R1C685K125AC CGA4J1X5R1C685M125AC CGA5L3X5R1V685K160AB CGA5L3X5R1E685K160AB CGA5L2X5R1C685K160AA CGA5L3X5R1V685M160AB CGA5L3X5R1E685M160AB CGA5L2X5R1C685M160AA CGA4J1X5R1C106K125AC CGA4J1X5R1C106M125AC CGA5L3X5R1V106K160AB CGA5L3X5R1E106K160AB CGA5L1X5R1C106K160AC CGA5L3X5R1V106M160AB CGA5L3X5R1E106M160AB CGA5L1X5R1C106M160AC CGA5L1X5R1C156M160AC CGA5L1X5R1C226M160AC Page 14 • All specifications are subject to change without notice. 20141219 / mlcc_automotive_general_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X5R (-55 to +85ºC, ±15%) Capacitance Size Thickness (mm) 100 nF 1005 0.50 ± 0.05 150 nF 1005 0.50 ± 0.05 220 nF 1005 0.50 ± 0.05 330 nF 1608 0.80 ± 0.10 470 nF 1608 0.80 ± 0.10 680 nF 1608 0.80 ± 0.10 1 μF 1608 0.80 ± 0.10 1608 0.80 ± 0.10 2012 1.25 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 6.8 μF 2012 1.25 ± 0.20 10 μF 2012 1.25 ± 0.20 1.5 μF 2.2 μF 3.3 μF 4.7 μF Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 10V CGA2B2X5R1A104K050BA CGA2B2X5R1A104M050BA CGA2B3X5R1A154K050BB CGA2B3X5R1A154M050BB CGA2B3X5R1A224K050BB CGA2B3X5R1A224M050BB CGA3E2X5R1A334K080AA CGA3E2X5R1A334M080AA CGA3E2X5R1A474K080AA CGA3E2X5R1A474M080AA CGA3E2X5R1A684K080AA CGA3E2X5R1A684M080AA CGA3E2X5R1A105K080AA CGA3E2X5R1A105M080AA CGA3E3X5R1A155K080AB CGA3E3X5R1A155M080AB CGA4J2X5R1A155K125AA CGA4J2X5R1A155M125AA CGA3E3X5R1A225K080AB CGA3E3X5R1A225M080AB CGA4J2X5R1A225K125AA CGA4J2X5R1A225M125AA CGA3E1X5R1A335K080AC CGA3E1X5R1A335M080AC CGA4J2X5R1A335K125AA CGA4J2X5R1A335M125AA Rated Voltage Edc: 6.3V CGA3E3X5R0J335K080AB CGA3E3X5R0J335M080AB CGA3E1X5R0J475K080AC CGA3E1X5R0J475M080AC CGA4J2X5R1A475K125AA CGA4J2X5R1A475M125AA CGA4J3X5R1A685K125AB CGA4J3X5R1A685M125AB CGA4J3X5R1A106K125AB CGA4J3X5R1A106M125AB Page 15 • All specifications are subject to change without notice. 20141219 / mlcc_automotive_general_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) Capacitance Size Thickness (mm) 100 pF 0603 0.30 ± 0.03 150 pF 0603 0.30 ± 0.03 0603 0.30 ± 0.03 1005 0.50 ± 0.05 0603 0.30 ± 0.03 1005 0.50 ± 0.05 0603 0.30 ± 0.03 1005 0.50 ± 0.05 0603 0.30 ± 0.03 1005 0.50 ± 0.05 0603 0.30 ± 0.03 1005 0.50 ± 0.05 1608 0.80 ± 0.10 0603 0.30 ± 0.03 1005 0.50 ± 0.05 1608 0.80 ± 0.10 0603 0.30 ± 0.03 1005 0.50 ± 0.05 1608 0.80 ± 0.10 0603 0.30 ± 0.03 1005 0.50 ± 0.05 1608 0.80 ± 0.10 0603 0.30 ± 0.03 1005 0.50 ± 0.05 1608 0.80 ± 0.10 0603 0.30 ± 0.03 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 220 pF 330 pF 470 pF 680 pF 1 nF 1.5 nF 2.2 nF 3.3 nF 4.7 nF 6.8 nF 10 nF Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 50V CGA1A2X7R1H101K030BA CGA1A2X7R1H101M030BA CGA1A2X7R1H151K030BA CGA1A2X7R1H151M030BA CGA1A2X7R1H221K030BA CGA1A2X7R1H221M030BA CGA2B2X7R1H221K050BA CGA2B2X7R1H221M050BA CGA1A2X7R1H331K030BA CGA1A2X7R1H331M030BA CGA2B2X7R1H331K050BA CGA2B2X7R1H331M050BA CGA1A2X7R1H471K030BA CGA1A2X7R1H471M030BA CGA2B2X7R1H471K050BA CGA2B2X7R1H471M050BA Rated Voltage Edc: 35V Rated Voltage Edc: 25V Rated Voltage Edc: 16V CGA1A2X7R1E101K030BA CGA1A2X7R1C101K030BA CGA1A2X7R1E101M030BA CGA1A2X7R1C101M030BA CGA1A2X7R1E151K030BA CGA1A2X7R1C151K030BA CGA1A2X7R1E151M030BA CGA1A2X7R1C151M030BA CGA1A2X7R1E221K030BA CGA1A2X7R1C221K030BA CGA1A2X7R1E221M030BA CGA1A2X7R1C221M030BA CGA1A2X7R1E331K030BA CGA1A2X7R1C331K030BA CGA1A2X7R1E331M030BA CGA1A2X7R1C331M030BA CGA1A2X7R1E471K030BA CGA1A2X7R1C471K030BA CGA1A2X7R1E471M030BA CGA1A2X7R1C471M030BA CGA1A2X7R1E681K030BA CGA1A2X7R1C681K030BA CGA1A2X7R1E681M030BA CGA1A2X7R1C681M030BA CGA2B2X7R1H681K050BA CGA2B2X7R1H681M050BA CGA1A2X7R1E102K030BA CGA1A2X7R1C102K030BA CGA1A2X7R1E102M030BA CGA1A2X7R1C102M030BA CGA2B2X7R1H102K050BA CGA2B2X7R1H102M050BA CGA3E2X7R1H102K080AA CGA3E2X7R1H102M080AA CGA1A2X7R1E152K030BA CGA1A2X7R1C152K030BA CGA1A2X7R1E152M030BA CGA1A2X7R1C152M030BA CGA2B2X7R1H152K050BA CGA2B2X7R1H152M050BA CGA3E2X7R1H152K080AA CGA3E2X7R1H152M080AA CGA1A2X7R1E222K030BA CGA1A2X7R1C222K030BA CGA1A2X7R1E222M030BA CGA1A2X7R1C222M030BA CGA2B2X7R1H222K050BA CGA2B2X7R1H222M050BA CGA3E2X7R1H222K080AA CGA3E2X7R1H222M080AA CGA1A2X7R1E332K030BA CGA1A2X7R1C332K030BA CGA1A2X7R1E332M030BA CGA1A2X7R1C332M030BA CGA2B2X7R1H332K050BA CGA2B2X7R1H332M050BA CGA3E2X7R1H332K080AA CGA3E2X7R1H332M080AA CGA1A2X7R1C472K030BA CGA1A2X7R1C472M030BA CGA2B2X7R1H472K050BA CGA2B2X7R1H472M050BA CGA3E2X7R1H472K080AA CGA3E2X7R1H472M080AA CGA1A2X7R1C682K030BA CGA1A2X7R1C682M030BA CGA2B2X7R1H682K050BA CGA2B2X7R1H682M050BA CGA3E2X7R1H682K080AA CGA3E2X7R1H682M080AA CGA2B3X7R1H103K050BB CGA2B3X7R1V103K050BB CGA2B3X7R1H103M050BB CGA2B3X7R1V103M050BB CGA3E2X7R1H103K080AA CGA3E2X7R1H103M080AA CGA2B2X7R1E103K050BA CGA2B2X7R1E103M050BA Page 16 • All specifications are subject to change without notice. 20141219 / mlcc_automotive_general_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) Capacitance Size Thickness (mm) 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 15 nF 22 nF 33 nF 47 nF 68 nF 100 nF 150 nF 220 nF 2012 1.25 ± 0.20 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 1.25 ± 0.20 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 1.25 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 1.60 +0.30/-0.10 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 1.60 +0.30/-0.10 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 1.60 +0.30/-0.10 3225 1.60 ± 0.20 330 nF 470 nF 680 nF 1 μF Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 50V CGA2B3X7R1H153K050BB CGA2B3X7R1H153M050BB CGA3E2X7R1H153K080AA CGA3E2X7R1H153M080AA CGA2B3X7R1H223K050BB CGA2B3X7R1H223M050BB CGA3E2X7R1H223K080AA CGA3E2X7R1H223M080AA CGA2B3X7R1H333K050BB CGA2B3X7R1H333M050BB CGA3E2X7R1H333K080AA CGA3E2X7R1H333M080AA CGA2B3X7R1H473K050BB CGA2B3X7R1H473M050BB CGA3E2X7R1H473K080AA CGA3E2X7R1H473M080AA CGA2B3X7R1H683K050BB CGA2B3X7R1H683M050BB CGA3E2X7R1H683K080AA CGA3E2X7R1H683M080AA CGA2B3X7R1H104K050BB CGA2B3X7R1H104M050BB CGA3E2X7R1H104K080AA CGA3E2X7R1H104M080AA CGA4J2X7R1H104K125AA Rated Voltage Edc: 35V CGA2B3X7R1V153K050BB CGA2B3X7R1V153M050BB Rated Voltage Edc: 25V CGA2B2X7R1E153K050BA CGA2B2X7R1E153M050BA Rated Voltage Edc: 16V CGA2B3X7R1V223K050BB CGA2B3X7R1V223M050BB CGA2B2X7R1E223K050BA CGA2B2X7R1E223M050BA CGA2B3X7R1V333K050BB CGA2B3X7R1V333M050BB CGA2B1X7R1E333K050BC CGA2B2X7R1C333K050BA CGA2B1X7R1E333M050BC CGA2B2X7R1C333M050BA CGA2B3X7R1V473K050BB CGA2B3X7R1V473M050BB CGA2B1X7R1E473K050BC CGA2B2X7R1C473K050BA CGA2B1X7R1E473M050BC CGA2B2X7R1C473M050BA CGA2B3X7R1V683K050BB CGA2B3X7R1V683M050BB CGA2B3X7R1E683K050BB CGA2B1X7R1C683K050BC CGA2B3X7R1E683M050BB CGA2B1X7R1C683M050BC CGA2B3X7R1V104K050BB CGA2B3X7R1V104M050BB CGA2B3X7R1E104K050BB CGA2B1X7R1C104K050BC CGA2B3X7R1E104M050BB CGA2B1X7R1C104M050BC CGA3E2X7R1E104K080AA CGA3E2X7R1E104M080AA CGA2B1X7R1V154K050BC CGA2B1X7R1V154M050BC CGA3E3X7R1H154K080AB CGA3E3X7R1V154K080AB CGA3E3X7R1H154M080AB CGA3E3X7R1V154M080AB CGA4J2X7R1H154K125AA CGA4J2X7R1H154M125AA CGA2B1X7R1V224K050BC CGA2B1X7R1V224M050BC CGA3E3X7R1H224K080AB CGA3E3X7R1V224K080AB CGA3E3X7R1H224M080AB CGA3E3X7R1V224M080AB CGA4J2X7R1H224K125AA CGA4J2X7R1H224M125AA CGA3E3X7R1H334K080AB CGA3E1X7R1V334K080AC CGA3E3X7R1H334M080AB CGA3E1X7R1V334M080AC CGA4J2X7R1H334K125AA CGA4J2X7R1H334M125AA CGA3E3X7R1H474K080AB CGA3E1X7R1V474K080AC CGA3E3X7R1H474M080AB CGA3E1X7R1V474M080AC CGA4J3X7R1H474K125AB CGA4J3X7R1V474K125AB CGA4J3X7R1H474M125AB CGA4J3X7R1V474M125AB CGA5L2X7R1H474K160AA CGA5L2X7R1H474M160AA CGA3E1X7R1V684K080AC CGA3E1X7R1V684M080AC CGA4J3X7R1H684K125AB CGA4J3X7R1V684K125AB CGA4J3X7R1H684M125AB CGA4J3X7R1V684M125AB CGA5L2X7R1H684K160AA CGA5L2X7R1H684M160AA CGA3E1X7R1V105K080AC CGA3E1X7R1V105M080AC CGA4J3X7R1H105K125AB CGA4J3X7R1V105K125AB CGA4J3X7R1H105M125AB CGA4J3X7R1V105M125AB CGA5L3X7R1H105K160AB CGA5L3X7R1H105M160AB CGA6L2X7R1H105K160AA CGA6L2X7R1H105M160AA CGA2B3X7R1E154K050BB CGA2B2X7R1C154K050BA CGA2B3X7R1E154M050BB CGA2B2X7R1C154M050BA CGA3E2X7R1E154K080AA CGA3E2X7R1E154M080AA CGA2B3X7R1E224K050BB CGA2B2X7R1C224K050BA CGA2B3X7R1E224M050BB CGA2B2X7R1C224M050BA CGA3E1X7R1E224K080AC CGA3E2X7R1C224K080AA CGA3E1X7R1E224M080AC CGA3E2X7R1C224M080AA CGA4J2X7R1E224K125AA CGA3E3X7R1E334K080AB CGA3E3X7R1E334M080AB CGA3E1X7R1C334K080AC CGA3E1X7R1C334M080AC CGA3E3X7R1E474K080AB CGA3E3X7R1E474M080AB CGA4J2X7R1E474K125AA CGA4J2X7R1E474M125AA CGA3E1X7R1C474K080AC CGA3E1X7R1C474M080AC CGA4J2X7R1C474K125AA CGA3E1X7R1E684K080AC CGA3E1X7R1C684K080AC CGA3E1X7R1E684M080AC CGA3E1X7R1C684M080AC CGA4J3X7R1E684K125AB CGA4J2X7R1C684K125AA CGA4J3X7R1E684M125AB CGA4J2X7R1C684M125AA CGA3E1X7R1E105K080AC CGA3E1X7R1C105K080AC CGA3E1X7R1E105M080AC CGA3E1X7R1C105M080AC CGA4J3X7R1E105K125AB CGA4J2X7R1C105K125AA CGA4J3X7R1E105M125AB CGA4J2X7R1C105M125AA CGA5L2X7R1E105K160AA CGA5L2X7R1E105M160AA Page 17 • All specifications are subject to change without notice. 20141219 / mlcc_automotive_general_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) Capacitance 1.5 μF 2.2 μF Size Thickness (mm) 2012 1.25 ± 0.20 3216 1.60 +0.30/-0.10 3225 2.00 ± 0.20 4532 1.60 ± 0.20 2012 1.25 ± 0.20 3216 1.60 +0.30/-0.10 3225 2.00 ± 0.20 4532 1.60 ± 0.20 2012 1.25 ± 0.20 1.60 ± 0.20 3.3 μF 3216 1.60 +0.30/-0.10 3225 2.50 ± 0.30 4532 2.00 ± 0.20 2012 1.25 ± 0.20 1.60 ± 0.20 3216 1.60 +0.30/-0.10 4.7 μF 3225 4532 5750 2.50 ± 0.30 1.60 ± 0.20 2.00 ± 0.20 2.00 ± 0.20 1.60 ± 0.20 3216 1.60 +0.30/-0.10 6.8 μF 3225 2.50 ± 0.30 4532 5750 2.50 ± 0.20 2.50 ± 0.30 1.60 ± 0.20 3216 1.60 +0.30/-0.10 10 μF 2.00 ± 0.20 3225 2.50 ± 0.30 4532 5750 15 μF 3225 4532 5750 3225 22 μF 4532 33 μF 47 μF 5750 4532 5750 2.50 ± 0.20 2.00 ± 0.20 2.30 ± 0.20 2.50 ± 0.30 2.80 ± 0.30 2.30 ± 0.20 2.50 ± 0.30 2.30 ± 0.20 2.50 ± 0.20 2.50 ± 0.30 2.50 ± 0.20 2.30 ± 0.20 Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 10% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 10% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% Catalog Number Rated Voltage Edc: 50V CGA4J3X7R1H155K125AB CGA4J3X7R1H155M125AB CGA5L3X7R1H155K160AB CGA5L3X7R1H155M160AB CGA6M2X7R1H155K200AA CGA6M2X7R1H155M200AA CGA8L2X7R1H155K160KA CGA4J3X7R1H225K125AB CGA4J3X7R1H225M125AB CGA5L3X7R1H225K160AB CGA5L3X7R1H225M160AB CGA6M3X7R1H225K200AB CGA6M3X7R1H225M200AB CGA8L2X7R1H225K160KA Rated Voltage Edc: 35V CGA4J1X7R1V155K125AC CGA4J1X7R1V155M125AC CGA5L3X7R1V155K160AB CGA5L3X7R1V155M160AB Rated Voltage Edc: 25V CGA4J3X7R1E155K125AB CGA4J3X7R1E155M125AB CGA5L2X7R1E155K160AA CGA5L2X7R1E155M160AA Rated Voltage Edc: 16V CGA4J3X7R1C155K125AB CGA4J3X7R1C155M125AB CGA4J1X7R1V225K125AC CGA4J1X7R1V225M125AC CGA5L3X7R1V225K160AB CGA5L3X7R1V225M160AB CGA4J3X7R1E225K125AB CGA4J3X7R1E225M125AB CGA5L2X7R1E225K160AA CGA5L2X7R1E225M160AA CGA4J3X7R1C225K125AB CGA4J3X7R1C225M125AB CGA4J1X7R1V335K125AC CGA4J1X7R1V335M125AC CGA4J1X7R1E335K125AC CGA4J1X7R1E335M125AC CGA4J3X7R1C335K125AB CGA4J3X7R1C335M125AB CGA5L1X7R1V335K160AC CGA5L1X7R1V335M160AC CGA5L1X7R1E335K160AC CGA5L1X7R1E335M160AC CGA4J1X7R1V475K125AC CGA4J1X7R1V475M125AC CGA4J1X7R1E475K125AC CGA4J1X7R1E475M125AC CGA4J3X7R1C475K125AB CGA4J3X7R1C475M125AB CGA5L1X7R1V475K160AC CGA5L1X7R1V475M160AC CGA5L1X7R1E475K160AC CGA5L1X7R1E475M160AC CGA5L3X7R1C475K160AB CGA5L3X7R1C475M160AB CGA5L3X7R1H335K160AB CGA5L3X7R1H335M160AB CGA6P3X7R1H335K250AB CGA6P3X7R1H335M250AB CGA8M2X7R1H335K200KA CGA5L3X7R1H475K160AB CGA5L3X7R1H475M160AB CGA6P3X7R1H475K250AB CGA6P3X7R1H475M250AB CGA8L2X7R1E475K160KA CGA8L2X7R1E475M160KA CGA8M3X7R1H475K200KB CGA9M2X7R1H475K200KA CGA5L1X7R1V685K160AC CGA5L1X7R1V685M160AC CGA5L1X7R1E685K160AC CGA5L1X7R1E685M160AC CGA6P3X7R1E685K250AB CGA6P3X7R1E685M250AB CGA5L1X7R1C685K160AC CGA5L1X7R1C685M160AC CGA5L1X7R1E106K160AC CGA5L1X7R1E106M160AC CGA5L1X7R1C106K160AC CGA5L1X7R1C106M160AC CGA6M3X7R1C106K200AB CGA6M3X7R1C106M200AB CGA8P3X7R1H685K250KB CGA9P2X7R1H685K250KA CGA5L1X7R1V106K160AC CGA5L1X7R1V106M160AC CGA6P1X7R1E106K250AC CGA6P1X7R1E106M250AC CGA8P2X7R1E106K250KA CGA9M2X7R1E106M200KA CGA9N3X7R1H106K230KB CGA6P3X7R1C156M250AB CGA8Q3X7R1E156M280KB CGA9N2X7R1E156M230KA CGA6P1X7R1C226M250AC CGA8N3X7R1C226M230KB CGA8P1X7R1E226M250KC CGA9P2X7R1E226M250KA CGA8P1X7R1C336M250KC CGA9N3X7R1C476M230KB Page 18 • All specifications are subject to change without notice. 20141219 / mlcc_automotive_general_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) Capacitance Size Thickness (mm) 10 nF 0603 0.30 ± 0.03 150 nF 1005 0.50 ± 0.05 220 nF 1005 0.50 ± 0.05 1.5 μF 1608 0.80 ± 0.10 2.2 μF 1608 0.80 ± 0.10 3.3 μF 4.7 μF 2012 2012 1.25 ± 0.20 1.25 ± 0.20 6.8 μF 2012 1.25 ± 0.20 10 μF 2012 1.25 ± 0.20 22 μF 3216 1.60 +0.30/-0.10 Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 10% ± 10% ± 20% ± 10% ± 20% ± 20% Catalog Number Rated Voltage Edc: 10V CGA1A2X7R1A103K030BA CGA1A2X7R1A103M030BA CGA2B1X7R1A154K050BC CGA2B1X7R1A154M050BC CGA2B1X7R1A224K050BC CGA2B1X7R1A224M050BC Rated Voltage Edc: 6.3V CGA1A2X7R0J103K030BA CGA1A2X7R0J103M030BA CGA2B3X7R0J154K050BB CGA2B3X7R0J154M050BB CGA2B3X7R0J224K050BB CGA2B3X7R0J224M050BB CGA3E1X7R0J155K080AC CGA3E1X7R0J155M080AC CGA3E1X7R0J225K080AC CGA3E1X7R0J225M080AC CGA4J3X7R1A335K125AB CGA4J3X7R1A475K125AB CGA4J1X7R0J685K125AC CGA4J1X7R0J685M125AC CGA4J1X7R0J106K125AC CGA4J1X7R0J106M125AC CGA5L1X7R0J226M160AC Class 2 (Temperature Stable) Temperature Characteristics: X7S (-55 to +125ºC, ±22%) Capacitance Size Thickness (mm) 330 nF 1005 0.50 ± 0.05 470nF 1005 0.50 ± 0.05 1.5 μF 1608 0.80 ± 0.10 2.2 μF 1608 0.80 ± 0.10 4.7 μF 3225 2.30 ± 0.20 2012 1.25 ± 0.20 3225 2.50 ± 0.30 2012 1.25 ± 0.20 3225 2.50 ± 0.30 3225 3225 2.50 ± 0.30 2.50 ± 0.30 6.8 μF 10 μF 33 μF 47 μF Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 20% ± 20% Catalog Number Rated Voltage Edc: 50V Rated Voltage Edc: 16V CGA2B1X7S1C334K050BC CGA2B1X7S1C334M050BC CGA2B1X7S1C474K050BC CGA2B1X7S1C474M050BC CGA3E1X7S1C155K080AC CGA3E1X7S1C155M080AC CGA3E1X7S1C225K080AC CGA3E1X7S1C225M080AC Rated Voltage Edc: 10V CGA2B3X7S1A334K050BB CGA2B3X7S1A334M050BB CGA2B3X7S1A474K050BB CGA2B3X7S1A474M050BB CGA3E3X7S1A155K080AB CGA3E3X7S1A155M080AB CGA3E3X7S1A225K080AB CGA3E3X7S1A225M080AB Rated Voltage Edc: 6.3V CGA6N3X7S1H475K230AB CGA4J1X7S1C685K125AC CGA4J3X7S1A685K125AB CGA4J1X7S1C685M125AC CGA4J3X7S1A685M125AB CGA6P3X7S1H685K250AB CGA6P3X7S1H685M250AB CGA4J1X7S1C106K125AC CGA4J3X7S1A106K125AB CGA4J1X7S1C106M125AC CGA4J3X7S1A106M125AB CGA6P3X7S1H106K250AB CGA6P3X7S1H106M250AB CGA6P1X7S0J336M250AC CGA6P1X7S0J476M250AC Page 19 • All specifications are subject to change without notice. 20141219 / mlcc_automotive_general_en
CGA1A2C0G1E100D030BA 价格&库存
很抱歉,暂时无法提供与“CGA1A2C0G1E100D030BA”相匹配的价格&库存,您可以联系我们找货
      • 15000+0.0691015000+0.00897
      • 45000+0.0606845000+0.00788
      库存:34853
      • 1+0.886071+0.11500
      • 10+0.3085210+0.04004
      • 50+0.2083950+0.02705
      • 100+0.17828100+0.02314
      • 500+0.12730500+0.01652
      库存:34853
