CGA2B2C0G1H010CT0Y0F
    TDK(东电化)
    贴片电容(MLCC) 0402 1pF ±0.25pF 50V C0G(NP0)
CGA2B2C0G1H010CT0Y0F 数据手册
CGA2B2C0G1H010C050BA TDK Item Description : CGA2B2C0G1H010CT**** Equivalent C1005C0G1H010C for Automotive Application & Main Feature Automotive Grade ( General (Up to 50V) ) Series CGA2(1005) [EIA CC0402] 1.00mm 0.50mm 0.50mm 0.10mm 0.30mm +/-0.05mm +/-0.05mm +/-0.05mm Min. Min. Temperature Characteristic DC Bias Characteristic 5 4 100 10 1 Rated Voltage 10 Capacitance 1 0 -1 -2 -3 100 1000 0 10000 10 20 30 |Z| Capacitance Tolerance 50 60 ESR Temperature Characteristics Cap. vs. Freq. Characteristic C (+/-0.25pF) 40 DC Bias/V Frequency/MHz 1pF 0.5 10 0.4 Cap. Change/% Q Factor 420 Min. 10Gohm Min. 2 -5 0.1 1 Insulation Resistance 3 -4 1H (50Vdc) Cap./pF Characterization Sheet ( Multilayer Ceramic Chip Capacitors ) C0G (-55 to 125 degC 0+/-30ppm/degC) |Z|, ESR vs. Freq. Characteristics 1000 Cap. Change/% L W T B G |Z|, ESR/ohm Dimensions 1 AEC-Q200 0.3 0.2 0.1 0 -0.1 -0.2 -0.3 -0.4 Yes -0.5 0.1 -60 1 10 100 Frequency/MHz All specifications are subject to change without notice. 1000 10000 -40 -20 0 20 40 60 80 100 120 140 160 Temperature/degC Temp.Chara. TCBias(1/2Rated) January 4, 2016
CGA2B2C0G1H010CT0Y0F 价格&库存
很抱歉,暂时无法提供与“CGA2B2C0G1H010CT0Y0F”相匹配的价格&库存,您可以联系我们找货
  • 50+0.06250
  • 500+0.05350
  • 1500+0.04680
  • 5000+0.03950
  • 25000+0.03750
库存:5563
  • 50+0.05722
  • 2000+0.04287
  • 4000+0.03613
  • 10000+0.03559
库存:4310
