CGA2B2NP02A471J050BA
    TDK(东电化)
    CAP CER 470PF 100V NP0 0402
CGA2B2NP02A471J050BA 数据手册
CGA2B2NP02A471J050BA TDK Item Description : CGA2B2NP02A471T**** Equivalent C1005NP02A471J for Automotive Application & Main Feature Automotive Grade ( High Temperature Application ) ) Series CGA2(1005) [EIA CC0402] 1.00mm +/-0.05mm 0.50mm +/-0.05mm 0.50mm +/-0.05mm 0.10mm Min. 0.3mm Min. Temperature Characteristic 4 Rated Voltage 2A (100Vdc) 3 1 0.1 0.01 0.001 Capacitance 0 -1 -2 -3 10 100 1000 10000 0 20 40 |Z| 80 100 120 ESR Cap. vs. Freq. Characteristic 10000 60 DC Bias/V Frequency/MHz J (+/-5%) Temperature Characteristics 0.5 0.4 0.3 1000 Min. Cap. Change/% Q Factor AEC-Q200 1 -5 1 Capacitance Tolerance 10Gohm Min 2 -4 470pF Insulation Resistance DC Bias Characteristic 5 10 1000 Cap./pF Characterization Sheet ( Multilayer Ceramic Chip Capacitors ) NP0 (-55 to 150 degC 0+/-30ppm/degC) |Z|, ESR vs. Freq. Characteristics 100 Cap. Change/% L W T B G |Z|, ESR/ohm Dimensions 100 10 Yes 0.2 0.1 0 -0.1 -0.2 -0.3 -0.4 1 -0.5 1 10 100 Frequency/MHz All specifications are subject to change without notice. 1000 10000 -60 -40 -20 0 20 40 60 80 100 120 140 160 Temperature/degC Temp.Chara. TCBias(1/2Rated) April 13, 2016
CGA2B2NP02A471J050BA 价格&库存
很抱歉,暂时无法提供与“CGA2B2NP02A471J050BA”相匹配的价格&库存,您可以联系我们找货
    • 10000+0.2078410000+0.02666
    • 20000+0.1938820000+0.02487
    • 30000+0.1869130000+0.02398
    • 50000+0.1791750000+0.02298
    • 70000+0.1746670000+0.02241
    • 100000+0.17030100000+0.02185
    库存:10166
    • 1+1.241111+0.15919
    • 10+0.7082910+0.09085
    • 50+0.4953850+0.06354
    • 100+0.43000100+0.05516
    • 500+0.32136500+0.04122
    • 1000+0.287911000+0.03693
    • 2500+0.252592500+0.03240
    • 5000+0.231405000+0.02968
    库存:10166
