CGA3E1X8R1E334K080AC 数据手册
TDK Item Description : CGA3E1X8R1E334KT****
Equivalent C1608X8R1E334K for Automotive
DC Bias Characteristic
10
Application & Main Feature
Cap. Change/%
Automotive Grade ( High Temperature Application )
Series
CGA3(1608) [EIA 0603]
-10
-20
-30
-40
-50
-60
1.60mm
0.80mm
0.80mm
0.20mm
0.30mm
+/-0.1mm
+/-0.1mm
+/-0.1mm
Min.
Min.
Temperature Characteristic
1000
|Z|, ESR vs. Freq. Characteristics
15
30
10
Rated Voltage
1E (25Vdc)
-20
10
-30
-40
1
-50
-60
0.1
-70
-80
0.01
0.001
Capacitance
0.01
0.1
1
10
100
1000
|Z|
-80
-60
-40
-20
K (+/-10%)
1000
ESR
Cap. vs. Freq. Characteristic
10
Yes
0.01
0.1
1
Frequency/MHz
80
100 120 140 160 180
10
100
1000
TCBias(1/2Rated)
10
5
0.4
0.6
0.8
1
1.2
1.4
Current/Arms
100kHz
All specifications are subject to change without notice.
60
Ripple Temperature Rise Characteristics
25
100
1
0.001
40
Temp.Chara.
Dissipation Factor
5% Max.
Temperature/degC
Temperature Rise/degC
Capacitance Tolerance
1.515Gohm Min
-90
Frequency/MHz
330nF
Insulation Resistance
Temperature Characteristics
Cap./nF
Characterization Sheet ( Multilayer Ceramic Chip Capacitors )
X8R (-55 to 150 deg +/-15%)
AEC-Q200
10
Cap. Change/%
L
W
T
B
G
5
DC Bias/V
|Z|, ESR/ohm
Dimensions
500kHz
1MHz
June 5, 2018
CGA3E1X8R1E334K080AC 价格&库存
很抱歉,暂时无法提供与“CGA3E1X8R1E334K080AC”相匹配的价格&库存,您可以联系我们找货
