CGA3E2C0G2A332J080AE
    TDK(东电化)
    CAP CER 3300PF 100V C0G/NP0 0603
CGA3E2C0G2A332J080AE 数据手册
CGA3E2C0G2A332J080AE TDK Item Description : CGA3E2C0G2A332JT***S Equivalent C1608C0G2A332J for Automotive DC Bias Characteristic 0.5 Application & Main Feature 0.4 0.3 Cap. Change/% Automotive Grade ( Soft Termination ) Series 0.2 0.1 0 -0.1 CGA3(1608) [EIA 0603] -0.2 -0.3 -0.4 -0.5 1.60mm 0.80mm 0.80mm 0.20mm 0.30mm +0.2,-0.1mm +0.15,-0.1mm +0.15,-0.1mm Min. Min. Temperature Characteristic 20 30 40 50 60 Rated Voltage 2A(100Vdc) 0.4 0.3 100 0.2 0.1 10 1 -0.2 0.1 -0.3 -0.4 -0.5 0.001 3.3nF 0.1 1 10 Frequency/MHz |Z| Capacitance Tolerance J (±5%) 100 Temperature Rise/degC AEC-Q200 Yes 0.1 1 0 10 Frequency/MHz 20 40 60 100 1000 80 100 120 140 160 Temperature/degC TCBias(1/2Rated) Ripple Temperature Rise Characteristics 25 10 1 -20 Temp.Chara. 1000 Min. 10Gohm Min -40 ESR Cap. vs. Freq. Characteristic 100 -60 1000 Q Factor Insulation Resistance 0 -0.1 0.01 Capacitance Temperature Characteristics 0.5 (Simulation Data) 1000 Cap./nF Characterization Sheet ( Multilayer Ceramic Chip Capacitors ) C0G (-55 to 125 degC 0+/-30ppm/degC) |Z|, ESR vs. Freq. Characteristics Cap. Change/% L W T B G 10 DC Bias/V |Z|, ESR/ohm Dimensions 0 20 15 10 5 0 0 0.5 1 1.5 2 Current/Arms 1MHz All specifications are subject to change without notice. June 24, 2019
CGA3E2C0G2A332J080AE 价格&库存
很抱歉,暂时无法提供与“CGA3E2C0G2A332J080AE”相匹配的价格&库存,您可以联系我们找货
