CGA3E3NP02E122J080AA
    TDK(东电化)
    CAP CER 1200PF 250V NP0 0603
CGA3E3NP02E122J080AA 数据手册
CGA3E3NP02E122J080AA TDK Item Description : CGA3E3NP02E122T**** Equivalent C1608NP02E122J for Automotive Application & Main Feature Automotive Grade ( High Temperature Application ) ) Series CGA3(1608) [EIA CC0603] 1.60mm +/-0.1mm 0.8mm +/-0.1mm 0.8mm +/-0.1mm 0.2mm Min. 0.3mm Min. Temperature Characteristic 4 3 10 Rated Voltage 2E (250Vdc) 1 0.1 0.01 0.001 Capacitance 1 0 -1 -2 -3 -5 1 10 100 1000 10000 0 50 100 |Z| J (+/-5%) 200 250 300 ESR Cap. vs. Freq. Characteristic 10 150 DC Bias/V Frequency/MHz Capacitance Tolerance Temperature Characteristics 0.5 0.4 0.3 Cap. Change/% Q Factor 1000 Min. 10Gohm Min 2 -4 1.2nF Insulation Resistance DC Bias Characteristic 5 Cap./nF Characterization Sheet ( Multilayer Ceramic Chip Capacitors ) NP0 (-55 to 150 degC 0+/-30ppm/degC) |Z|, ESR vs. Freq. Characteristics 100 Cap. Change/% L W T B G |Z|, ESR/ohm Dimensions AEC-Q200 Yes 0.2 0.1 0 -0.1 -0.2 -0.3 -0.4 1 -0.5 1 10 100 Frequency/MHz All specifications are subject to change without notice. 1000 10000 -60 -40 -20 0 20 40 60 80 100 120 140 160 Temperature/degC Temp.Chara. TCBias(1/2Rated) April 13, 2016
CGA3E3NP02E122J080AA 价格&库存
很抱歉,暂时无法提供与“CGA3E3NP02E122J080AA”相匹配的价格&库存,您可以联系我们找货
  • 4000+0.650664000+0.08383
