CGA3EAC0G2A472J080AC
    TDK(东电化)
    贴片电容(MLCC) 0603
CGA3EAC0G2A472J080AC 数据手册
CGA3EAC0G2A472J080AC TDK Item Description : CGA3EAC0G2A472JT**** Equivalent C1608C0G2A472J for Automotive DC Bias Characteristic 0.5 Application & Main Feature 0.4 0.3 Cap. Change/% Automotive Grade ( ESD Protection ) Series 0.2 0.1 0 -0.1 CGA3EA(1608) [EIA 0603] -0.2 -0.3 -0.4 -0.5 1.60mm 0.80mm 0.80mm 0.20mm 0.30mm ±0.10mm ±0.10mm ±0.10mm Min. Min. Temperature Characteristic Rated Voltage 60 80 100 120 0.4 0.3 0.2 10 0.1 1 0.1 0.001 Capacitance -0.2 -0.3 -0.4 0.1 1 10 100 1000 |Z| Capacitance Tolerance J (±5%) -60 -40 -20 100 10 Yes 1 0.1 1 10 Frequency/MHz 40 60 80 100 120 140 160 100 1000 TCBias(1/2Rated) Ripple Temperature Rise Characteristics 25 Temperature Rise/degC 1000 Min. 20 Temp.Chara. Cap. vs. Freq. Characteristic 1000 0 Temperature/degC ESR Q Factor 10Gohm Min -0.5 Frequency/MHz 4.7nF Insulation Resistance 0 -0.1 0.01 2A(100Vdc) AEC-Q200 40 Temperature Characteristics 0.5 100 Cap./nF Characterization Sheet ( Multilayer Ceramic Chip Capacitors ) C0G (-55 to 125 degC 0+/-30ppm/degC) |Z|, ESR vs. Freq. Characteristics 1000 Cap. Change/% L W T B G 20 DC Bias/V |Z|, ESR/ohm Dimensions 0 20 15 10 5 0 0 0.5 1 1.5 2 2.5 Current/Arms 1MHz All specifications are subject to change without notice. July 2, 2019
CGA3EAC0G2A472J080AC 价格&库存
很抱歉,暂时无法提供与“CGA3EAC0G2A472J080AC”相匹配的价格&库存,您可以联系我们找货
  • 4000+0.509974000+0.06600
  • 8000+0.492508000+0.06374
  • 4000+0.47258
  • 8000+0.45634
    • 4000+0.650494000+0.08418
    • 8000+0.611378000+0.07912
    • 12000+0.5917812000+0.07658
    • 20000+0.5700920000+0.07378
    • 28000+0.5574028000+0.07213
    • 40000+0.5451940000+0.07055
    库存:26898
    • 1+2.830291+0.36626
    • 10+1.6778810+0.21713
    • 50+1.2241850+0.15842
    • 100+1.08470100+0.14037
    • 500+0.85041500+0.11005
    • 1000+0.778071000+0.10069
    库存:26898
