CGA3EANP02A103J080AC
    TDK(东电化)
    10NF ±5% 100V
CGA3EANP02A103J080AC 数据手册
CGA3EANP02A103J080AC TDK Item Description : CGA3EANP02A103JT**** Equivalent C1608NP02A103J for Automotive DC Bias Characteristic 0.5 Application & Main Feature 0.4 0.3 Cap. Change/% Automotive Grade ( ESD Protection ) Series 0.2 0.1 0 -0.1 CGA3EA(1608) [EIA 0603] -0.2 -0.3 -0.4 -0.5 1.60mm 0.80mm 0.80mm 0.20mm 0.30mm ±0.10mm ±0.10mm ±0.10mm Min. Min. Temperature Characteristic Rated Voltage 60 80 100 120 0.4 0.3 0.2 10 0.1 1 0.1 0.001 Capacitance -0.2 -0.3 -0.4 0.1 1 10 100 1000 |Z| Capacitance Tolerance J (±5%) -60 -40 -20 0 100 10 Yes 1 0.1 1 10 Frequency/MHz 60 80 100 120 140 160 100 1000 TCBias(1/2Rated) Ripple Temperature Rise Characteristics 25 Temperature Rise/degC 1000 Min. 40 Temp.Chara. Cap. vs. Freq. Characteristic 1000 20 Temperature/degC ESR Q Factor 10Gohm Min -0.5 Frequency/MHz 10nF Insulation Resistance 0 -0.1 0.01 2A(100Vdc) AEC-Q200 40 Temperature Characteristics 0.5 100 Cap./nF Characterization Sheet ( Multilayer Ceramic Chip Capacitors ) NP0 (-55 to 150 degC 0+/-30ppm/degC) |Z|, ESR vs. Freq. Characteristics 1000 Cap. Change/% L W T B G 20 DC Bias/V |Z|, ESR/ohm Dimensions 0 20 15 10 5 0 0 0.5 1 1.5 2 2.5 3 3.5 Current/Arms 1MHz All specifications are subject to change without notice. July 2, 2019
CGA3EANP02A103J080AC 价格&库存
很抱歉,暂时无法提供与“CGA3EANP02A103J080AC”相匹配的价格&库存,您可以联系我们找货
  • 1+3.179651+0.41319
  • 10+1.8789810+0.24417
  • 50+1.3781350+0.17909
  • 100+1.22385100+0.15904
  • 500+0.96371500+0.12523
库存:3250
    库存:4000
