CGA3EANP02A472J080AC
    TDK(东电化)
CGA3EANP02A472J080AC 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS April 2019 MULTILAYER CERAMIC CHIP CAPACITORS Automotive grade, ESD protection  CGA3EA series CGA3EA 1608 [0603 inch] * Dimensions code: JIS[EIA] (2/7) MULTILAYER CERAMIC CHIP CAPACITORS REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS 1. The products listed in this specification are intended for use in automotive applications under normal operation and usage conditions. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality requires a more stringent level of safety or reliability, or whose failure, malfunction or defect could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in this specification, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (excepting Pharmaceutical Affairs Law classification Class1,2) (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 2. 3. 4. 5. 6. 7. In addition, although the products listed in this specification are intended for use in automotive applications as described above, they are not prohibited to use in general electronic equipment, whose performance and/or quality doesn’t require a more stringent level of safety or reliability, or whose failure, malfunction or defect could not cause serious damage to society, person or property. Therefore, the description of this caution will be applied, when the products are used in general electronic equipment under a normal operation and usage conditions. We may modify products or discontinue production of a product listed in this catalog without prior notification. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export permission in harmony with this law. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging specification detail. This new catalog number should be referenced on all catalog orders going forward, and is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will differ from the item description (internal control number) on the product label. Contact your local TDK Sales representative for more information. (Example) Catalog issued date Prior to January 2013 January 2013 and later Catalog number C1608C0G1E103J(080AA) C1608C0G1E103J080AA Item description (on delivery label) C1608C0G1E103JT000N C1608C0G1E103JT000N 20190409 / mlcc_automotive_esd_en.fm (3/7) MULTILAYER CERAMIC CHIP CAPACITORS CGA3EA series Cl Br ESD protection RoHS REACH Halogen Free SVHC-Free Pb Lead Free Type: CGA3EA/1608 [0603 inch] ■ SERIES OVERVIEW ESD protection CGA3EA series, automotive grade of TDK's multilayer ceramic chip capacitor, is a product which has passed the most rigorous level 4 (8000V and above) of ESD tests for contact discharge under the IEC61000-4-2 international standard. The operating temperature range is up to 150°C, and so it is available for under high temperature environment. The capacitance range is up to 10nF. ■ FEATURES ■ APPLICATIONS • Compliant with the IEC 61000-4-2 (level 4) for ESD immunity • Operating temperature range is up to 150°C (NP0: 0±30ppm/°C, –55 to +150°C) • AEC-Q200 compliant. • Input/output parts of various ECUs (Engine ECU, EPS, TCM, ABS, etc.) that require ESD protection. ■ SHAPE & DIMENSIONS ■ PRODUCT STRUCTURE W L T Sn Ni Cu G B L W T B G The structure which multiple sheets of dielectric and conductive material are layered alternately. The superior mechanical strength and reliability are realized by the monolithic and simple structure. Body length Body width Body height Terminal width Terminal spacing Type L W CGA3EA 1.60±0.10 0.80±0.10 Dimensional tolerances are typical values. T 0.80±0.10 Dimensions in mm B G 0.20min. 0.30min. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190409 / mlcc_automotive_esd_en.fm (4/7) MULTILAYER CERAMIC CHIP CAPACITORS ■ CATALOG NUMBER CONSTRUCTION CGA 3 E A NP0 2A 103 J 080 A C (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (1) Series (2) Dimensions L x W (mm) Code 3 EIA CC0603 Length 1.60 Width 0.80 Terminal width 0.20 (3) Thickness code Code E (Example)0R5 = 0.5pF 101 = 100pF 225 = 2,200,000pF = 2.2µF Thickness 0.80 mm (8) Capacitance tolerance (4) Function identification code Symbol A Code J Condition ESD protection Temperature coefficient Temperature range 0±30 ppm/°C 0±30 ppm/°C –55 to +125°C –55 to +150°C (6) Rated voltage (DC) Code 2A Voltage (DC) 100V Tolerance ±5% (9) Thickness (5) Temperature characteristics Temperature characteristics C0G NP0 (7) Nominal capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. Code 080 Thickness 0.80 mm (10) Packaging style Code A Style 178mm reel, 4mm pitch (11) Special reserved code Code A,C Description TDK internal code Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190409 / mlcc_automotive_esd_en.fm (5/7) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) 1,000 1,500 2,200 3,300 4,700 6,800 10,000 Code C0G NP0 ESD resistance 2A (100V) 2A (100V) (V) 102 152 222 332 472 682 103 Standard thickness  CGA3/1608 [0603 inch] 8,000 10,000 12,000 16,000 16,000 22,000 30,000 0.80mm ■ Please refer to the capacitance range table at P-6 and after for the details such as product thickness and capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190409 / mlcc_automotive_esd_en.fm (6/7) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions 1nF 1.5nF 2.2nF 3.3nF 4.7nF 6.8nF 10nF 1608 1608 1608 1608 1608 1608 1608 Temperature characteristics: C0G (–55 to +125°C, 0±30ppm/°C) Thickness (mm) Capacitance tolerance Catalog number Rated voltage Edc: 100V 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 ±5% ±5% ±5% ±5% ±5% ±5% ±5% CGA3EAC0G2A102J080AA CGA3EAC0G2A152J080AC CGA3EAC0G2A222J080AC CGA3EAC0G2A332J080AC CGA3EAC0G2A472J080AC CGA3EAC0G2A682J080AC CGA3EAC0G2A103J080AC Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190409 / mlcc_automotive_esd_en.fm (7/7) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions 1nF 1.5nF 2.2nF 3.3nF 4.7nF 6.8nF 10nF 1608 1608 1608 1608 1608 1608 1608 Temperature characteristics: NP0 (–55 to +150°C, 0±30ppm/°C) Thickness (mm) Capacitance tolerance Catalog number Rated voltage Edc: 100V 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 ±5% ±5% ±5% ±5% ±5% ±5% ±5% CGA3EANP02A102J080AA CGA3EANP02A152J080AC CGA3EANP02A222J080AC CGA3EANP02A332J080AC CGA3EANP02A472J080AC CGA3EANP02A682J080AC CGA3EANP02A103J080AC Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190409 / mlcc_automotive_esd_en.fm
CGA3EANP02A472J080AC 价格&库存
很抱歉,暂时无法提供与“CGA3EANP02A472J080AC”相匹配的价格&库存,您可以联系我们找货
  • 4000+0.47891
  • 24000+0.47398
  • 40000+0.46084
  • 4000+0.649774000+0.08335
  • 8000+0.610708000+0.07834
  • 12000+0.5911312000+0.07583
  • 20000+0.5694620000+0.07305
  • 28000+0.5567928000+0.07142
  • 40000+0.5445940000+0.06986
库存:38466
  • 1+2.827181+0.36265
  • 10+1.6760410+0.21499
  • 50+1.2228450+0.15686
  • 100+1.08351100+0.13898
  • 500+0.84948500+0.10897
  • 1000+0.777211000+0.09970
库存:38466
    库存:4000
