CGA4J1X7R1V475M125AC
    TDK(东电化)
    贴片电容(MLCC) 0805
CGA4J1X7R1V475M125AC 数据手册
AC11010004 DELIVERY SPECIFICATION To SPEC. No. A-General-j D A T E : March, 2021 Upon the acceptance of this spec. previous spec. (C2014-0057) shall be abolished. Non-Controlled Copy CUSTOMER’S PRODUCT NAME TDK'S PRODUCT NAME Multilayer Ceramic Chip Capacitors Bulk and Tape packaging 【RoHS compliant】 CGA1,CGA2,CGA3,CGA4,CGA5,CGA6,CGA8,CGA9Type C0G,NP0,X7R,X7S,X7T,X8R,X8L Characteristics Please return this specification to TDK representatives with your signature. If orders are placed without returned specification, please allow us to judge that specification is accepted by your side. RECEIPT CONFIRMATION DATE: YEAR MONTH DAY Test conditions in this specification based on AEC-Q200 for automotive application. TDK Corporation Sales Electronic Components Sales & Marketing Group APPROVED Person in charge Engineering Electronic Components Business Company Ceramic Capacitors Business Group APPROVED CHECKED Person in charge AC11010004 ■CATALOG NUMBER CONSTRUCTION CGA 6 (1) (2) P 1 (3) X7T (4) (5) 0G (6) 107 (7) M (8) 250 (9) (1) Series (6) Rated voltage (DC) (2) Dimensions L x W (mm) Code 0E Voltage (DC) 2.5V 0G 4V 6.3V 10V 16V Code EIA Length Width Terminal width 1 2 3 CC0201 CC0402 CC0603 0.60 1.00 0.30 0.50 0.10 0.10 0J 1A 1C 1.60 0.80 0.20 1E 25V 4 5 6 CC0805 CC1206 CC1210 2.00 3.20 3.20 1.25 1.60 2.50 0.20 0.20 0.20 1V 1H 1N 35V 50V 75V 8 9 CC1812 CC2220 4.50 5.70 3.20 5.00 0.20 0.20 (3) Thickness code Code Thickness A 0.30mm B 0.50mm C 0.60mm E 0.80mm F 0.85mm H 1.15mm J 1.25mm L 1.60mm M 2.00mm N 2.30mm P 2.50mm Q 2.80mm R 3.20mm 3 0R5 = 0.5pF 101 = 100pF 225 = 2,200,000pF = 2.2μF (8) Capacitance tolerance Code Tolerance C ±0.25pF D ±0.50pF ±5% J K ±10% ±20% M Condition 1 x R.V. (9) Thickness Thickness Code 2 x R.V. 1.5 x R.V. 030 050 (5) Temperature characteristics 0.30mm 0.50mm 0.60mm Temperature characteristics Temperature coefficient Temperature or capacitance change range 060 080 085 C0G X5R X7R X7S 0±30ppm/℃ ±15% 115 125 1.15mm 1.25mm 160 200 230 250 1.60mm 2.00mm 2.30mm 2.50mm 280 320 2.80mm 3.20mm X7T ±15% ±22% +22,-33% -55 to +125℃ -55 to +85℃ -55 to +125℃ -55 to +125℃ -55 to +125℃ 0.80mm 0.85mm (10) Packaging style Code Style A B 178mm reel, 4mm pitch 178mm reel, 2mm pitch K 178mm reel, 8mm pitch (11) Special reserved code Code Description A,B,C — 1 — C (11) (7) Nominal capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. (Example) (4) Voltage condition for life test Symbol 1 2 A (10) TDK internal code AC11010004 ■CATALOG NUMBER CONSTRUCTION CGA 9 (1) P (2) 3 (3) (4) X7S (5) 2A (6) 156 (7) M (8) 250 (9) K (10) B (11) (6) Rated voltage (DC) (1) Series (2) Dimensions L x W (mm) Code EIA Length Width 2 3 4 5 6 8 9 CC0402 CC0603 CC0805 CC1206 CC1210 CC1812 CC2220 1.00 1.60 2.00 3.20 3.20 4.50 5.70 0.50 0.80 1.25 1.60 2.50 3.20 5.00 Terminal width 0.20min 0.20min 0.20min (3) Thickness code Code Thickness B 0.50mm 0.60mm C E 0.80mm F 0.85mm H 1.15mm J 1.25mm K 1.30mm L 1.60mm M 2.00mm N 2.30mm P 2.50mm Q 2.80mm R 3.20mm Code Voltage (DC) 2A 100V 2E 250V 450V 630V 2W 2J (7) Nominal capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. (Example) 0R5 = 0.5pF 101 = 100pF 225 = 2,200,000pF = 2.2μF (8) Capacitance tolerance Code Tolerance ±0.25pF C D J K M (4) Voltage condition for life test Symbol Condition 1 1 x R.V. 2 2 x R.V. 3 1.5 x R.V. 4 1.2 x R.V. ±0.50pF ±5% ±10% ±20% (9) Thickness Code Thickness 050 0.50mm 060 0.60mm (5) Temperature characteristics 080 0.80mm 085 110 0.85mm 1.10mm Temperature characteristics Temperature coefficient Temperature or capacitance change range 130 1.30mm C0G 0±30ppm/℃ -55 to +125℃ 160 1.60mm X7R ±15% -55 to +125℃ 200 2.00mm X7S ±22% -55 to +125℃ 230 2.30mm X7T +22%,-33% -55 to +125℃ 250 2.50mm 280 2.80mm (10) Packaging style Code Style A B K 178mm reel, 4mm pitch 178mm reel, 2mm pitch 178mm reel, 8mm pitch (11) Special reserved code Code A,B,C,N — 2 — Description TDK internal code AC11010004 ■CATALOG NUMBER CONSTRUCTION CGA 6 (1) (2) P 1 (3) X8L (4) (5) 1C (6) (1) Series (2) Dimensions L x W (mm) Code EIA Length Width 2 3 4 5 6 8 9 CC0402 CC0603 CC0805 CC1206 CC1210 CC1812 CC2220 1.00 1.60 2.00 3.20 3.20 4.50 5.70 0.50 0.80 1.25 1.60 2.50 3.20 5.00 Terminal width 0.10 0.20 0.20 0.20 0.20 0.20 0.20 (3) Thickness code Code Thickness B 0.50mm C 0.60mm E 0.80mm F 0.85mm H 1.15mm J 1.25mm L 1.60mm M 2.00mm N 2.30mm P 2.50mm Q 2.80mm R 3.20mm (4) Voltage Symbol 1 2 3 4 226 (7) M (8) 250 (9) A (10) (7) Nominal capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. (Example) 0R5 = 0.5pF 101 = 100pF 225 = 2,200,000pF = 2.2μF (8) Capacitance tolerance Code Tolerance C ±0.25pF D ±0.50pF J ±5% K ±10% M ±20% 1.5 x R.V. 280 280mm 1.2 x R.V. 320 3.20mm (5) Temperature characteristics (10) Packaging style Temperature characteristics Temperature coefficient Temperature or capacitance change range Code Style NP0 178mm reel, 4mm pitch X8R 0±30ppm/℃ ±15% -55 to +125℃ A B K 178mm reel, 2mm pitch 178mm reel, 8mm pitch X8L +15,-40% -55 to +150℃ -55 to +150℃ (11) Special reserved code Description Code (6) Rated voltage (DC) Code Voltage (DC) 0G A,B,C,N 4V 0J 1A 1C 6.3V 10V 16V 1E 25V 1H 2A 50V 100V 2E 250V 2W 450V 2J 630V (11) (9) Thickness Code Thickness 050 0.50mm 060 0.60mm 080 0.80mm 085 0.85mm 115 1.15mm 125 1.25mm 160 1.60mm 200 2.00mm 230 2.30mm 250 2.50mm condition for life test Condition 1 x R.V. 2 x R.V. — 3 — C Conductive epoxy application AC11010004 SCOPE This delivery specification shall be applied to Multilayer ceramic chip capacitors to be delivered to . PRODUCTION PLACES Production places defined in this specification shall be TDK Corporation, TDK(Suzhou)Co.,Ltd and TDK Components U.S.A.,Inc. PRODUCT NAME The name of the product to be defined in this specifications shall be CGA◇◇◇○○○△△□□□×. REFERENCE STANDARD JIS C 5101-1:2010 C 5101-21:2014 Fixed capacitors for use in electronic equipment-Part 1: Generic specification Fixed capacitors for use in electronic equipment-Part21 : Sectional specification : Fixed surface mount multilayer capacitors of ceramic dielectric,Class1 C 5101-22:2014 Fixed capacitors for use in electronic equipment-Part22 : Sectional specification : Fixed surface mount multilayer capacitors of ceramic dielectric,Class 2 C 0806-3:2014 Packaging of components for automatic handling - Part 3: Packaging of surface mount components on continuous tapes JEITA RCR-2335 C 2014 Safety application guide for fixed ceramic capacitors for use in electronic equipment CONTENTS 1. CODE CONSTRUCTION 2. COMBINATION OF RATED CAPACITANCE AND TOLERANCE 3. OPERATING TEMPERATURE RANGE 4. STORING CONDITION AND TERM 5. P.C. BOARD 6. INDUSTRIAL WASTE DISPOSAL 7. PERFORMANCE 8. INSIDE STRUCTURE AND MATERIAL 9. PACKAGING 10. RECOMMENDATION 11. SOLDERING CONDITION 12. CAUTION 13. TAPE PACKAGING SPECIFICATION When the mistrust in the spec arises, this specification is given priority. And it will be confirmed by written spec change after conference of both posts involved. This specification warrants the quality of the ceramic chip capacitor. Capacitors should be evaluated or confirmed a state of mounted on your product. If the use of the capacitors goes beyond the bounds of this specification, we can not afford to guarantee. Division Date SPEC. No. Ceramic Capacitors Business Group March, 2021 A-General-j — 4 — AC11010004 1. CODE CONSTRUCTION (Example) CGA CGA (1) 2 6 (2) B P (3) 3 3 (4) X7R X7S (5) 1E 1H (6) 104 106 (7) (1) Series (2) Case size K K (8) T T (9) ○○○○ ○○○○ (10) Symbol Series CGA For automotive application Terminal electrode L B W G B T Internal electrode Ceramic dielectric Case size Case size Symbol (EIA style) 1 CGA1 (CC0201) 2 CGA2 (CC0402) 3 CGA3 (CC0603) L 0.60±0.03 +0.10 0.60 -0.03 1.00±0.05 1.00±0.10 +0.10 1.00 -0.05 1.60±0.10 1.60±0.15 1.60±0.20 +0.30 1.60 -0.10 2.00±0.20 4 CGA4 (CC0805) 2.00 +0.25 -0.15 2.00 +0.30 -0.15 3.20±0.20 5 CGA5 (CC1206) 3.20 +0.30 -0.10 3.20 +0.40 -0.10 3.20±0.40 6 CGA6 (CC1210) 3.20 +0.45 -0.40 3.20±0.40 * As for each item, please refer to Dimensions (mm) W T 0.30±0.03 0.30±0.03 +0.10 +0.10 0.30 0.30 -0.03 -0.03 0.50±0.05 0.50±0.05 0.50±0.10 0.50±0.10 +0.10 +0.10 0.50 0.50 -0.05 -0.05 0.80±0.10 0.80±0.10 0.80±0.15 0.80±0.15 0.80±0.20 0.80±0.20 +0.30 +0.30 0.80 0.80 -0.10 -0.10 0.60±0.15 1.25±0.20 0.85±0.15 1.25±0.20 1.25 +0.25 1.25 +0.25 -0.15 -0.15 +0.30 1.25 1.25 +0.30 -0.15 -0.15 0.60±0.15 0.85±0.15 1.15±0.15 1.60±0.20 1.30±0.20 1.60±0.20 +0.30 1.60 1.60 +0.30 -0.10 -0.10 +0.40 1.60 1.60 +0.40 -0.10 -0.10 1.25±0.20 1.60±0.20 2.50±0.30 2.00±0.20 2.30±0.20 2.50±0.30 +0.35 2.50 2.50 +0.35 -0.30 -0.30 +0.40 2.50 2.50 +0.40 -0.30 -0.30 detail page on TDK web. — 5 — B G 0.10 min. 0.20 min. 0.10 min. 0.30 min. 0.20 min. 0.30 min. 0.20 min. 0.50 min. 0.20 min. 1.00 min. 0.20 min. ―― AC11010004 Dimensions (mm) Case size Case size Symbol (EIA style) L W 8 CGA8 (CC1812) 4.50±0.40 3.20±0.40 9 CGA9 (CC2220) 5.70±0.40 5.00±0.40 T 1.60±0.20 2.00±0.20 2.30±0.20 2.50±0.30 3.20±0.30 1.60±0.20 2.00±0.20 2.30±0.20 2.50±0.30 2.80±0.30 B G 0.20 min. ―― 0.20 min. ―― * As for each item, please refer to detail page on TDK web. (3) Thickness Symbol A B C E F H J Dimension(mm) 0.30 0.50 0.60 0.80 0.85 1.15 1.25 (4) Voltage condition in the life test * Details are shown in table 1 No.16 at 7.PERFORMANCE. Symbol K L M N P Q R Dimension(mm) 1.30 1.60 2.00 2.30 2.50 2.80 3.20 Symbol Condition 1 Rated Voltage 2 Rated Voltage x 2 3 Rated Voltage x 1.5 4 Rated Voltage x 1.2 (5) Temperature Characteristics * Details are shown in table 1 No.6 and No.7 at 7.PERFORMANCE. (6) Rated Voltage Symbol Rated Voltage Symbol Rated Voltage 2J DC 630 V 1E DC 25 V 2W DC 450 V 1C DC 16 V 2E DC 250 V 1A DC 10 V 2A DC 100 V 0J DC 6.3 V 1N DC 75 V 0G DC 4 1H DC 50 V 0E DC 2.5 V 1V DC 35 V Symbol Rated Capacitance (Example) (7) Rated Capacitance Stated in three digits and in units of pico farads (pF). The first and Second digits identify the first and second significant figures of the capacitance, the third digit identifies the multiplier. R is designated for a decimal point. — 6 — V 2R2 2.2 pF 104 100,000 pF AC11010004 (8) Capacitance tolerance * M tolerance shall be standard for over 10uF. Symbol Tolerance C ± 0.25 pF D ± 0.5 J ± K ± 10 % *M ± 20 % (9) Packaging * CGA1 and CGA2 types are applicable to tape packaging only. (10) TDK internal code — 7 — pF Capacitance 10pF and under 5% Over 10pF Symbol Packaging B Bulk T Taping AC11010004 2. COMBINATION OF RATED CAPACITANCE AND TOLERANCE Class Temperature Characteristics Capacitance tolerance 10pF and under C0G NP0 1 X7R X7S X7T X8R X8L 2 Rated capacitance C (±0.25pF) 1, 1.5, 2, 2.2, 3, 3.3, 4, 4.7, 5 D (±0.5pF) 6, 6.8, 7, 8, 9, 10 12pF to 10,000pF Over 10,000pF J (± 0.1uF and under K (± 10 %) Over 0.1uF K (± 10 %) M (± 20 %) E – 12 series 5 %) E – 6 series E – 6 series Capacitance Step in E series E series Capacitance Step E- 6 1.0 E-12 1.0 1.5 1.2 1.5 2.2 1.8 2.2 2.7 3.3 3.3 4.7 3.9 4.7 5.6 6.8 6.8 8.2 3. OPERATING TEMPERATURE RANGE T.C. Min. operating Temperature Max. operating Temperature Reference Temperature C0G -55°C 125°C 25°C NP0 -55°C 150°C 25°C X7R/X7S/X7T -55°C 125°C 25°C X8R/X8L -55°C 150°C 25°C 4. STORING CONDITION AND TERM Storing temperature Storing humidity Storing term 5~40°C 20~70%RH Within 6 months upon receipt. 5. P.C. BOARD When mounting on an aluminum substrate, large case size such as CGA6 [CC1210] and larger are more likely to be affected by heat stress from the substrate. Please inquire separate specification for the large case sizes when mounted on the substrate. 6. INDUSTRIAL WASTE DISPOSAL Dispose this product as industrial waste in accordance with the Industrial Waste Law. — 8 — AC11010004 7. PERFORMANCE Table 1 No. Item Performance Test or inspection method 1 External Appearance No defects which may affect performance. Inspect with magnifying glass (3×) In case of CGA1[CC0201] type, with magnifying glass(10×). 2 Insulation Resistance 10,000MΩ or 500MΩ·μF min. (As for the capacitors of rated voltage 16V DC and lower, 10,000 MΩ or 100MΩ·μF min.), whichever smaller. Measuring voltage:Rated voltage (As for the capacitor of rated voltage 630V DC, apply 500V DC.) Voltage application time:60s. 3 Voltage Proof Withstand test voltage without insulation breakdown or other damage. Class 1 2 Rated voltage(RV) Apply voltage RV≦100V 3 × rated voltage 100V<RV≦500V 1.5 × rated voltage 500V<RV 1.3 × rated voltage RV≦100V 2.5 × rated voltage 100V<RV≦500V 1.5 × rated voltage 500V<RV 1.3 × rated voltage Voltage application time : 1s. Charge / discharge current : 50mA or lower 4 Capacitance Within the specified tolerance. 《Class 1》 Capacitance Measuring frequency 1000pF and under 1MHz±10% Over 1000pF 1kHz±10% Measuring voltage 0.5 ~ 5 Vrms. 《Class 2》 Capacitance Measuring frequency Measuring voltage 10uF and under 1kHz±10% 1.0±0.2Vrms Over 10uF 120Hz±20% 0.5±0.2Vrms. As for the capacitors of rated voltage 6.3V DC, 0.5Vrms is applied. As an exception, 1.0Vrms is applied for 10uF and under on X8L characteristics. 5 6 Q Class1 Dissipation Factor Class2 Temperature Characteristics of Capacitance (Class1) Please refer to detail page on TDK web. T.C. Temperature Coefficient (ppm/°C) C0G 0 ± 30 NP0 0 ± 30 Capacitance Within ± 0.2% or ± 0.05pF, drift whichever larger. — 9 — See No.4 in this table for measuring condition. Temperature coefficient shall be calculated based on values at 25°C and 85°C temperature. Measuring temperature below 25°C shall be -10°C and -25°C. AC11010004 (continued) No. 7 Item Temperature Characteristics of Capacitance (Class2) Performance Capacitance Change (%) No voltage applied X7R : ± 15 X7S : ± 22 +22 X7T : -33 X8R : ± 15 X8L : +15 -40 Test or inspection method Capacitance shall be measured by the steps shown in the following table after thermal equilibrium is obtained for each step. ∆C be calculated ref. STEP3 reading Step Temperature(°C) 1 Reference temp. ± 2 2 Min. operating temp. ± 2 3 Reference temp. ± 2 4 Max. operating temp. ± 2 As for Min./ Max. operating temp. and Reference temp., please refer to "3.OPERATING TEMPERATURE RANGE". As for measuring voltage, please contact with our sales representative. 8 Robustness of Terminations No sign of termination coming off, breakage of ceramic, or other abnormal signs. Reflow solder the capacitors on a P.C.Board shown in Appendix 2. Apply a pushing force gradually at the center of a specimen in a horizontal direction of P.C.board. Pushing force : 17.7N (2N is applied for CGA1 and CGA2 type.) Holding time : 10±1s. Pushing force P.C.Board Capacitor 9 Bending No mechanical damage. Reflow solder the capacitors on a P.C.Board shown in Appendix 1. (1mm is applied for 0.85mm thickness of Class2 items.) 20 50 F R230 2 45 45 (Unit : mm) 10 Solderability New solder to cover over 75% of termination. 25% may have pin holes or rough spots but not concentrated in one spot. Ceramic surface of A sections shall not be exposed due to melting or shifting of termination material. A section — 10 — Solder : Sn-3.0Ag-0.5Cu Flux : Isopropyl alcohol (JIS K 8839) Rosin (JIS K 5902) 25% solid solution. Solder temp. : 245±5°C Dwell time : 3±0.3s. Solder position : Until both terminations are completely soaked. AC11010004 (continued) No. 11 Item Performance Resistance External No cracks are allowed and to solder appearance terminations shall be covered at heat least 60% with new solder. Test or inspection method Solder : Sn-3.0Ag-0.5Cu Flux : Isopropyl alcohol (JIS K 8839) Rosin (JIS K 5902) 25% solid solution. Solder temp. : 260±5°C Dwell time : 10±1s. Solder position : Until both terminations are completely soaked. Pre-heating : Temp. ― 110~140°C Time ― 30~60s. Capacitance Characteristics Q Change from the value before test Class1 C0G NP0 ± 2.5% or ± 0.25pF, whichever larger. Class2 X7R X7S X7T X8R X8L ± 7.5 % Meet the initial spec. (Class1) 12 Vibration Leave the capacitors in ambient condition for Class 1 : 6~24h Class 2 : 24±2h before measurement. D.F. (Class2) Meet the initial spec. Insulation Resistance Meet the initial spec. Voltage proof No insulation breakdown or other damage. External appearance No mechanical damage. Capacitance Characteristics Q Class1 C0G NP0 Class2 X7R X7S X7T X8R X8L Change from the value before test ± 2.5% or ± 0.25pF, whichever larger. ± 7.5 % Meet the initial spec. (Class1) D.F. (Class2) Meet the initial spec. — 11 — Applied force : 5G max. Frequency : 10~2,000Hz Reciprocating sweep time : 20 min. Cycle : 12 cycles in each 3 mutually perpendicular directions. Reflow solder the capacitors on a P.C.Board shown in Appendix 2 before testing. AC11010004 (continued) No. Item 13 Temperature External appearance cycle Performance No mechanical damage. Capacitance Characteristics Change from the value before test Test or inspection method Expose the capacitors in the condition step1 through step 4 listed in the following table. Temp. cycle:1,000 cycles Step Class1 Class2 C0G NP0 X7R X7S X7T X8R X8L 1 Please contact with our sales representative. 2 3 4 Q Meet the initial spec. Min. operating temp. ±3 Ambient Temp. Max. operating temp. ±2 Ambient Temp. Time (min.) 30 ± 3 2~5 30 ± 2 2~5 As for Min./ Max. operating temp., please refer to "3.OPERATING TEMPERATURE RANGE". (Class1) 14 Temperature(°C) D.F. (Class2) Meet the initial spec. Insulation Resistance Meet the initial spec. Leave the capacitors in ambient condition for Class 1 : 6~24h Class 2 : 24±2h before measurement. Voltage proof No insulation breakdown or other damage. Reflow solder the capacitors on a P.C.Board shown in Appendix 2 before testing. Moisture No mechanical damage. External appearance Resistance (Steady Capacitance Change from the Characteristics State) value before test Q (Class1) D.F. (Class2) Insulation Resistance Class1 C0G NP0 Class2 X7R X7S X7T X8R X8L Please contact with our sales representative. Capacitance Q 30pF and over 350 min. 10pF and over under 30pF 275+5/2×C min. Under 10pF 200+10×C min. C : Rated capacitance (pF) 200% of initial spec. max. 1,000MΩ or 50MΩ·μF min. (As for the capacitors of rated voltage 16V DC and lower, 1,000 MΩ or 10MΩ·μF min.), whichever smaller. — 12 — Test temp.:40±2°C Test humidity:90~95%RH Test time:500 +24,0h Leave the capacitors in ambient condition for Class 1 : 6~24h Class 2 : 24±2h before measurement. Reflow solder the capacitors on a P.C.Board shown in Appendix2 before testing. AC11010004 (continued) No. Item 15 Moisture External Resistance appearance Performance No mechanical damage. Capacitance Characteristics Q (Class1) D.F. (Class2) 16 Life Test or inspection method Class1 C0G NP0 Class2 X7R X7S X7T X8R X8L Change from the value before test Charge/discharge current:50mA or lower Please contact with our sales representative. Capacitance Q 30pF and over 200 min. Under 30pF 100+10/3×C min. C : Rated capacitance (pF) 200% of initial spec. max. Insulation Resistance 500MΩ or 25MΩ·μF min. (As for the capacitors of rated voltage 16V DC and lower, 500 MΩ or 5MΩ·μF min.), whichever smaller. External appearance No mechanical damage. Capacitance Characteristics Class1 Class2 Q (Class1) Change from the value before test C0G NP0 X7R X7S X7T X8R X8L Q 30pF and over 350 min. 10pF and over to 275+5/2×C min. under 30pF D.F. (Class2) Insulation Resistance Leave the capacitors in ambient condition for Class 1 : 6~24h Class 2 : 24±2h before measurement. Reflow solder the capacitors on a P.C.Board shown in Appendix2 before testing. Initial value setting (only for class 2) Voltage conditioning 《After voltage treat the capacitors under testing temperature and voltage for 1 hour,》 leave the capacitors in ambient condition for 24±2h before measurement. Use this measurement for initial value. Test temp.:Maximum operating temperature±2°C Applied voltage:Please contact with our sales representative. Test time:1,000 +48,0h Charge/discharge current:50mA or lower Please contact with our sales representative. Capacitance Under 10pF Test temp.:85±2°C Test humidity:85%RH Applied voltage:Rated voltage Test time:1,000 +48,0h 200+10×C min. C : Rated capacitance (pF) 200% of initial spec. max. 1,000MΩ or 50MΩ·μF min. (As for the capacitors of rated voltage 16V DC and lower, 1,000 MΩ or 10MΩ·μF min.), whichever smaller. Leave the capacitors in ambient condition for Class 1 : 6~24h Class 2 : 24±2h before measurement. Reflow solder the capacitors on a P.C.Board shown in Appendix2 before testing. Initial value setting (only for class 2) Voltage conditioning 《After voltage treat the capacitors under testing temperature and voltage for 1 hour,》 leave the capacitors in ambient condition for 24±2h before measurement. Use this measurement for initial value. *As for the initial measurement of capacitors (Class2) on number 7,11,12,13 and 14 leave capacitors at 150 0,–10°C for 1 hour and measure the value after leaving capacitors for 24±2h in ambient condition. — 13 — AC11010004 Appendix1 P.C.Board for bending test (CGA1,CGA2) (CGA3,CGA4,CGA5,CGA6,CGA8,CGA9) 100 100 b b 40 Solder resist 40 a a Solder resist 1.0 1.0 c c Copper Copper Appendix2 P.C. Board for reliability test 100 c b a 40 *Slit Solder resist Copper * It is recommended to provide a slit on P.C.Board for CGA6,CGA8 and CGA9. (Unit:mm) Symbol Dimensions a b c CGA1 (CC0201) 0.3 0.8 0.3 CGA2 (CC0402) 0.4 1.5 0.5 CGA3 (CC0603) 1.0 3.0 1.2 CGA4 (CC0805) 1.2 4.0 1.65 CGA5 (CC1206) 2.2 5.0 2.0 CGA6 (CC1210) 2.2 5.0 2.9 CGA8 (CC1812) 3.5 7.0 3.7 CGA9 (CC2220) 4.5 8.0 5.6 Case size 1. Material : Glass Epoxy(As per JIS C6484 GE4) 2. Thickness : Appendix 1 ― 0.8mm ― 1.6mm : Appendix 2 ― 1.6mm (CGA1,CGA2) (CGA3,CGA4,CGA5,CGA6,CGA8,CGA9) Copper(Thickness:0.035mm) Solder resist — 14 — AC11010004 8. INSIDE STRUCTURE AND MATERIAL 3 4 5 2 1 MATERIAL No. NAME 1 Dielectric 2 Electrode Class1 Class2 CaZrO 3 BaTiO 3 Nickel ( Ni) 3 Copper (Cu) 4 Termination Nickel (Ni) 5 Tin (Sn) 9. PACKAGING Packaging shall be done to protect the components from the damage during transportation and storing, and a label which has the following information shall be attached. 9.1 Each plastic bag for bulk packaging contains 1000pcs. And the minimum quantity for Bulk packaging is 1000pcs. 9.2 Tape packaging is as per 13. TAPE PACKAGING SPECIFICATION. * CGA1 [CC0201] and CGA2 [CC0402] types are applicable to tape packaging only. 1) Inspection No. 2) TDK P/N 3) Customer's P/N 4) Quantity *Composition of Inspection No. Example F 1 A – 23 – 001 (a) (b) (c) (d) (e) (a) Line code (b) Last digit of the year (c) Month and A for January and B for February and so on. (Skip I) (d) Inspection Date of the month. (e) Serial No. of the day *Composition of new Inspection No. (Implemented on and after May 1, 2019 in sequence) Example I F 1 E (a) (b) (c) (d) 2 3 A 0 0 1 (e) (f) (g) (a) Prefix (b) Line code (c) Last digit of the year (d) Month and A for January and B for February and so on. (Skip I) (e) Inspection Date of the month. (f) Serial No. of the day(00 ~ ZZ) (g) Suffix(00 ~ ZZ) * It was shifted to the new inspection No. on and after May 2019, but the implementation timing may be different depending on shipment bases. Until the shift is completed, either current or new composition of inspection No. will be applied. — 15 — AC11010004 10. RECOMMENDATION As for CGA6 [CC1210] and larger, It is recommended to provide a slit (about 1mm width) in the board under the components to improve washing Flux. And please make sure to dry detergent up completely before. 11. SOLDERING CONDITION As for CGA1 [CC0201], CGA2 [CC0402], CGA6 [CC1210] and larger, reflow soldering only. For other case sizes than the above, reflow soldering is recommended. — 16 — AC11010004 12. CAUTION No. 1 Process Operating Condition (Storage, Use, Transportation) Condition 1-1. Storage, Use The capacitors must be stored in an ambient temperature of 5 to 40°C with a relative humidity of 20 to 70%RH. JIS C 60721-3-1 Class 1K2 should be followed for the other climatic conditions. 1) High temperature and humidity environment may affect a capacitor's solder ability because it accelerates terminal oxidization. They also deteriorate performance of taping and packaging. Therefore, SMD capacitors shall be used within 6 months. For capacitors with terminal electrodes consisting of silver or silver-palladium which tend to become oxidized or sulfurized, use as soon as possible, such as within one month after opening the bag. 2) When capacitors are stored for a longer time period than 6 months, confirm the solderability of the capacitors prior to use. During storage, keep the minimum packaging unit in its original packaging without opening it. Do not deviate from the above temperature and humidity conditions even for a short term. 3) Corrosive gasses in the air or atmosphere may result in deterioration of the reliability, such as poor solderability of the terminal electrodes. Do not store capacitors where they will be exposed to corrosive gas (e.g., hydrogen sulfide, sulfur dioxide, chlorine ammonia etc.) 4) Solderability and electrical performance may deteriorate due to photochemical change in the terminal electrode if stored in direct sunlight, or due to condensation from rapid changes in humidity. The capacitors especially which use resin material must be operated and stored in an environment free of dew condensation, as moisture absorption due to condensation may affect the performance. 5) Refer to JIS C 60721-3-1, class 1K2 for other climate conditions. 1-2. Handling in transportation In case of the transportation of the capacitors, the performance of the capacitors may be deteriorated depending on the transportation condition. (Refer to JEITA RCR-2335C 9.2 Handling in transportation) 2 Circuit design ! Caution △ E A 2-1. Operating temperature 1) Upper category temperature (maximum operating temperature) is specified. It is necessary to select a capacitor whose rated temperature us higher than the operating temperature. Also, it is necessary to consider the temperature distribution in the equipment and seasonal temperature variation. 2) Do not use capacitors above the maximum allowable operating temperature. Surface temperature including self heating should be below maximum operating temperature. (Due to dielectric loss, capacitors will heat itself when AC is applied. Especially for high frequency circuit, the heat might be so extreme that it may damage itself or the product mounted on. Please design the circuit so that the maximum temperature of the capacitors including the self heating to be below the maximum allowable operating temperature. Temperature rise at capacitor surface shall be below 20°C) 3) The electrical characteristics of the capacitors will vary depending on the temperature. The capacitors should be selected and designed in taking the temperature into consideration. 2-2. When overvoltage is applied Applying overvoltage to a capacitor may cause dielectric breakdown and result in a short circuit. The duration until dielectric breakdown depends on the applied voltage and the ambient temperature. — 17 — AC11010004 No. Process Condition 2 Circuit design ! Caution 2-3. Operating voltage 1) Operating voltage across the terminals should be below the rated voltage. When AC and DC are super imposed, V 0-P must be below the rated voltage. — (1) and (2) AC or pulse with overshooting, V P-P must be below the rated voltage. — (3), (4) and (5) When the voltage is started to apply to the circuit or it is stopped applying, the irregular voltage may be generated for a transit period because of resonance or switching. Be sure to use the capacitors within rated voltage containing these Irregular voltage. △ A E A R R Voltage (1) DC voltage Positional Measurement V 0-P (Rated voltage) R (2) DC+AC voltage V 0-P R (3) AC voltage V P-P R 0 Voltage R R 0 0 (4) Pulse voltage (A) (5) Pulse voltage (B) Positional Measurement V P-P (Rated voltage) V P-P R R 0 0 2) Even below the rated voltage, if repetitive high frequency AC or pulse is applied, the reliability of the capacitors may be reduced. 3) The effective capacitance will vary depending on applied DC and AC voltages. The capacitors should be selected and designed in taking the voltages into consideration. 4) Abnormal voltage (surge voltage, static electricity, pulse voltage, etc.) shall not exceed the rated voltage. 5) When capacitors are used in a series connection, it is necessary to add a balancing circuit such as voltage dividing resistors in order to avoid an imbalance in the voltage applied to each capacitor. 2-4. Frequency When the capacitors (Class 2) are used in AC and/or pulse voltages, the capacitors may vibrate themselves and generate audible sound. — 18 — AC11010004 No. 3 Process Designing P.C.board Condition The amount of solder at the terminations has a direct effect on the reliability of the capacitors. 1) The greater the amount of solder, the higher the stress on the chip capacitors, and the more likely that it will break. When designing a P.C.board, determine the shape and size of the solder lands to have proper amount of solder on the terminations. 2) Avoid using common solder land for multiple terminations and provide individual solder land for each terminations. 3) Size and recommended land dimensions. Chip capacitors Solder land C B Reflow soldering Case size CGA1 (CC0201) Symbol Solder resist A CGA2 (CC0402) CGA3 (CC0603) (mm) CGA4 (CC0805) A 0.25 ~ 0.35 0.3 ~ 0.5 0.6 ~ 0.8 0.9 ~ 1.2 B 0.20 ~ 0.30 0.35 ~ 0.45 0.6 ~ 0.8 0.7 ~ 0.9 C 0.25 ~ 0.35 0.4 ~ 0.6 0.6 ~ 0.8 0.9 ~ 1.2 CGA5 (CC1206) CGA6 (CC1210) CGA8 (CC1812) CGA9 (CC2220) A 2.0 ~ 2.4 2.0 ~ 2.4 3.1 ~ 3.7 4.1 ~ 4.8 B 1.0 ~ 1.2 1.0 ~ 1.2 1.2 ~ 1.4 1.2 ~ 1.4 C 1.1 ~ 1.6 1.9 ~ 2.5 2.4 ~ 3.2 4.0 ~ 5.0 Flow soldering (Unrecommend) Case size CGA3 CGA4 (CC0603) (CC0805) Symbol (mm) Case size Symbol CGA5 (CC1206) A 0.7 ~ 1.0 1.0 ~ 1.3 2.1 ~ 2.5 B 0.8 ~ 1.0 1.0 ~ 1.2 1.1 ~ 1.3 C 0.6 ~ 0.8 0.8 ~ 1.1 1.0 ~ 1.3 — 19 — AC11010004 No. 3 Process Designing P.C.board Condition 4) Recommended chip capacitors layout is as following. Disadvantage against bending stress Advantage against bending stress Perforation or slit Perforation or slit Break P.C.board with mounted side up. Break P.C.board with mounted side down. Mounting face Mount perpendicularly to perforation or slit Mount in parallel with perforation or slit Perforation or slit Perforation or slit Chip arrangement (Direction) Closer to slit is higher stress ℓ1 Away from slit is less stress ℓ2 R Distance from slit (ℓ1< ℓ2 ) R — 20 — R R R R R (ℓ1< ℓ2 ) AC11010004 No. 3 Process Designing P.C.board Condition 5) Mechanical stress varies according to location of chip capacitors on the P.C.board. E D Perforation C B A Stress force A>B>E A>D>E A>C Slit When dividing printed wiring boards, the intensities of mechanical stress applied to capacitors are different according to each dividing method in the order of : Push-back < Slit < V-groove < Perforation. Therefore consider not only position of capacitors, but also the way of the dividing the printed wiring boards. 6) Layout recommendation Example Use of common solder land Soldering with chassis Use of common solder land with other SMD Lead wire Chassis Chip Solder land Excessive solder Solder Need to avoid Excessive solder PCB Adhesive Solder land ℓ1 Missing solder Lead wire Solder land Solder resist Solder resist Recommendation Solder resist ℓ2 ℓ2 >ℓ1 — 21 — AC11010004 No. 4 Process Mounting Condition 4-1. Stress from mounting head If the mounting head is adjusted too low, it may induce excessive stress in the chip capacitors to result in cracking. Please take following precautions. 1) Adjust the bottom dead center of the mounting head to reach on the P.C.board surface and not press it. 2) Adjust the mounting head pressure to be 1 to 3N of static weight. 3) To minimize the impact energy from mounting head, it is important to provide support from the bottom side of the P.C.board. See following examples. Not recommended Recommended Crack Single-sided mounting Support pin A support pin is not to be underneath the capacitor. Double-sides mounting Solder peeling Crack Support pin When the centering jaw is worn out, it may give mechanical impact on the capacitors to cause crack. Please control the close up dimension of the centering jaw and provide sufficient preventive maintenance and replacement of it. 4-2. Amount of adhesive a a b c c Example : CGA4 (CC0805), CGA5 (CC1206) a 0.2mm min. b 70 ~ 100μm c Do not touch the solder land — 22 — AC11010004 No. Process Condition 5 Soldering 5-1. Flux selection Flux can seriously affect the performance of capacitors. Confirm the following to select the appropriate flux. 1) It is recommended to use a mildly activated rosin flux (less than 0.1wt% chlorine). Strong flux is not recommended. 2) Excessive flux must be avoided. Please provide proper amount of flux. 3) When water-soluble flux is used, enough washing is necessary. 5-2. Recommended soldering profile : Reflow method Refer to the following temperature profile at Reflow soldering. Reflow soldering Soldering Natural cooling Preheating Temp.. (°C) Peak Temp ∆T 0 Over 60 sec. Peak Temp time Reflow soldering is recommended for CGA3,CGA4,CGA5 types, but only reflow soldering is allowed for other case sizes. 5-3. Recommended soldering peak temp and peak temp duration for Reflow soldering Pb free solder is recommended, but if Sn-37Pb must be used, refer to below. Temp./Duration Reflow soldering Peak temp(°C) Duration(sec.) Lead Free Solder 260 max. 10 max. Sn-Pb Solder 230 max. 20 max. Solder Recommended solder compositions Lead Free Solder : Sn-3.0Ag-0.5Cu — 23 — AC11010004 Process 5 Soldering Condition 5-4. Soldering profile : Flow method (Unrecommend) Refer to the following temperature profile at Flow soldering. Flow soldering Soldering Preheating Natural cooling Peak Temp Temp. (°C) No. △T 0 Over 60 sec. Over 60 sec. Peak Temp time Reflow soldering is recommended for CGA3,CGA4,CGA5 types. 5-5. Recommended soldering peak temp and peak temp duration for Flow soldering Pb free solder is recommended, but if Sn-37Pb must be used, refer to below. Temp./Duration Flow soldering Peak temp(°C) Duration(sec.) Lead Free Solder 260 max. 5 max. Sn-Pb Solder 250 max. 3 max. Solder Recommended solder compositions Lead Free Solder : Sn-3.0Ag-0.5Cu 5-6. Avoiding thermal shock 1) Preheating condition Soldering Reflow soldering Flow soldering 2) Case size CGA1(CC0201),CGA2(CC0402) CGA3(CC0603),CGA4(CC0805) CGA5(CC1206) CGA6(CC1210), CGA8(CC1812), CGA9(CC2220) CGA3(CC0603), CGA4(CC0805), CGA5(CC1206) Temp. (°C) ∆T ≦ 150 ∆T ≦ 130 ∆T ≦ 150 Cooling condition Natural cooling using air is recommended. If the chips are dipped into a solvent for cleaning, the temperature difference (∆T) must be less than 100°C. — 24 — AC11010004 No. Process Condition 5 Soldering 5-7. Amount of solder Excessive solder will induce higher tensile force in chip capacitors when temperature changes and it may result in chip cracking. In sufficient solder may detach the capacitors from the P.C.board. Higher tensile force in chip capacitors to cause crack Excessive solder Maximum amount Minimum amount Adequate Low robustness may cause contact failure or chip capacitors come off the P.C.board. Insufficient solder 5-8. Sn-Zn solder Sn-Zn solder affects product reliability. Please contact TDK in advance when utilize Sn-Zn solder. 5-9. Countermeasure for tombstone The misalignment between the mounted positions of the capacitors and the land patterns should be minimized. The tombstone phenomenon may occur especially the capacitors are mounted (in longitudinal direction) in the same direction of the reflow soldering. (Refer to JEITA RCR-2335C Annex A (Informative), Recommendations to prevent the tombstone phenomenon.) — 25 — AC11010004 No. Process 6 Solder repairing Condition Solder repairing is unavoidable, refer to below. 6-1.Soldering rework using spot heater Heat stress during rework may possibly be reduced by using a spot heater (also called a “blower”) rather than a soldering iron. It is applied only to adding solder in the case of insufficient solder amount. 1) Reworking using a spot heater may suppress the occurrence of cracks in the capacitor compared to using a soldering iron. A spot heater can heat up a capacitor uniformly with a small heat gradient which leads to lower thermal stress caused by quick heating and cooling or localized heating. Moreover, where ultra-small capacitors are mounted close together on a printed circuit board, reworking with a spot heater can eliminate the risk of direct contact between the tip of a soldering iron and a capacitor. 2) Rework condition If the blower nozzle of a spot heater is too close to a capacitor, a crack in the capacitor may occur due to heat stress. Below are recommendations for avoiding such an occurrence. Keep more than 5mm between a capacitor and a spot heater nozzle. The blower temperature of the spot heater shall be lower than 400°C. The airflow shall be set as weak as possible. The diameter of the nozzle is recommended to be 2mm(one-outlet type).The size is standard and common. Duration of blowing hot air is recommended to be 10s or less for CGA3 (CC0603), CGA4 (CC0805) and CGA5 (CC1206), and 30s or less for CGA6 (CC1210), CGA8(CC1812) and CGA9 (CC2220), considering surface area of the capacitor and melting temperature of solder. The angle between the nozzle and the capacitor is recommended to be 45degrees in order to work easily and to avoid partial area heating. As is the case when using a soldering iron, preheating reduces thermal stress on capacitors and improves operating efficiency. ・Recommended rework condition(Consult the component manufactures for details.) Distance from nozzle 5mm and over Nozzle angle 45degrees Nozzle temp. 400°C and less Set as weak as possible (The airflow shall be the minimum value necessary for solder to melt in the conditions mentioned above.) φ2mm(one-outlet type) Airflow Nozzle diameter Blowing duration 10s and less (CGA3 [CC0603], CGA4 [CC0805], CGA5 [CC1206]) 30s and less (CGA6 [CC1210], CGA8 [CC1812], CGA9 [CC2220]) ・Example of recommended spot heater use One-outlet type nozzle Angle : 45degrees 3) Amount of solder should be suitable to from a proper fillet shape. Excess solder causes mechanical and thermal stress on a capacitor and results in cracks. Insufficient solder causes weak adherence of the capacitor to the substrate and may result in detachment of a capacitor and deteriorate reliability of the printed wiring board. See the example of appropriate solder fillet shape for 5-5.Amount of solder. — 26 — AC11010004 Process 6 Solder repairing Condition 6-2. Solder repair by solder iron 1) Selection of the soldering iron tip Tip temperature of solder iron varies by its type, P.C.board material and solder land size. The higher the tip temperature, the quicker the operation. However, heat shock may cause a crack in the chip capacitors. Please make sure the tip temp. before soldering and keep the peak temp and time in accordance with following recommended condition. Manual soldering (Solder iron) Peak Temp Temp.. (°C) No. ∆T Preheating 0 3sec. (As short as possible) Recommended solder iron condition (Sn-Pb Solder and Lead Free Solder) Case size Temp. (°C) CGA1(CC0201) CGA2(CC0402) CGA3(CC0603) CGA4(CC0805) CGA5(CC1206) 350 max. CGA6(CC1210) CGA8(CC1812) CGA9(CC2220) 280 max. Duration (sec.) Wattage (W) Shape (mm) 3 max. 20 max. Ø 3.0 max. * Please preheat the chip capacitors with the condition in 6-3 to avoid the thermal shock. 2) Direct contact of the soldering iron with ceramic dielectric of chip capacitors may cause crack. Do not touch the ceramic dielectric and the terminations by solder iron. 6-3. Avoiding thermal shock Preheating condition Soldering Manual soldering Case size CGA1(CC0201),CGA2(CC0402) CGA3(CC0603),CGA4(CC0805) CGA5(CC1206) CGA6(CC1210), CGA8(CC1812), CGA9(CC2220) — 27 — Temp. (°C) ∆T ≦ 150 ∆T ≦ 130 AC11010004 No. Process 7 Cleaning Condition 1) If an unsuitable cleaning fluid is used, flux residue or some foreign articles may stick to chip capacitors surface to deteriorate especially the insulation resistance. 2) If cleaning condition is not suitable, it may damage the chip capacitors. 2)-1. Insufficient washing (1) Terminal electrodes may corrode by Halogen in the flux. (2) Halogen in the flux may adhere on the surface of capacitors, and lower the insulation resistance. (3) Water soluble flux has higher tendency to have above mentioned problems (1) and (2). 2)-2. Excessive washing When ultrasonic cleaning equipment is used, excessive ultrasonic power or direct vibration transfer to a printed wiring board may generate a resonant vibration in the board. This may cause a crack in a capacitor or its solder joints to the board and degradation in the terminal strength of the capacitor. In order to avoid this, the following cleaning conditions are recommended. Power : 20 W/ ℓ max. Frequency : 40 kHz max. Washing time : 5 minutes max. 2)-3. If the cleaning fluid is contaminated, density of Halogen increases, and it may bring the same result as insufficient cleaning. 8 Coating and molding of the P.C.board 1) When the P.C.board is coated, please verify the quality influence on the product. 2) Please verify carefully that there is no harmful decomposing or reaction gas emission during curing which may damage the chip capacitors. 3) Please verify the curing temperature. 9 Handling after chip mounted ! Caution △ E A 1) Please pay attention not to bend or distort the P.C.board after soldering in handling otherwise the chip capacitors may crack. Bend — 28 — Twist AC11010004 No. 9 Process Handling after chip mounted ! Caution △ A E A Condition 2) Printed circuit board cropping should not be carried out by hand, but by using the proper tooling. Printed circuit board cropping should be carried out using a board cropping jig as shown in the following figure or a board cropping apparatus to prevent inducing mechanical stress on the board. (1)Example of a board cropping jig Recommended example: The board should be pushed from the back side, close to the cropping jig so that the board is not bent and the stress applied to the capacitor is compressive. Unrecommended example: If the pushing point is far from the cropping jig and the pushing direction is from the front side of the board, large tensile stress is applied to the capacitor, which may cause cracks. Outline of jig Recommended V-groove Printed circuit board Unrecommended Direction of load Printed circuit board Components Printed circuit board Load point Slot Board cropping jig Direction of load Load point V-groove Components V-groove Slot Slot (2)Example of a board cropping machine An outline of a printed circuit board cropping machine is shown below. The top and bottom blades are aligned with one another along the lines with the V-grooves on printed circuit board when cropping the board. Unrecommended example: Misalignment of blade position between top and bottom, right and left, or front and rear blades may cause a crack in the capacitor. Outline of machine Principle of operation Top blade Top blade Printed circuit board Printed circuit board Bottom blade V-groove Cross-section Printed circuit board V-groove Top blade Bottom blade Unrecommended Recommended Top-bottom misalignment Left-right misalignment Front-rear misalignment Top blade Top blade Top blade Bottom blade Bottom blade Bottom blade Top blade Board Bottom blade — 29 — AC11010004 No. 9 Process Handling after chip mounted ! Caution △ A E A Condition 3) When functional check of the P.C.board is performed, check pin pressure tends to be adjusted higher for fear of loose contact. But if the pressure is excessive and bend the P.C.board, it may crack the chip capacitors or peel the terminations off. Please adjust the check pins not to bend the P.C.board. Item Not recommended Recommended Termination peeling Support pin Board bending Check pin Check pin 10 Handling of loose chip capacitors 1) If dropped the chip capacitors may crack. Once dropped do not use it. Especially, the large case sized chip capacitors are tendency to have cracks easily, so please handle with care. Crack Floor 2) Piling the P.C.board after mounting for storage or handling, the corner of the P.C. board may hit the chip capacitors of another board to cause crack. P.C.board Crack 11 Capacitance aging The capacitors (Class 2) have aging in the capacitance. They may not be used in precision time constant circuit. In case of the time constant circuit, the evaluation should be done well. 12 Estimated life and estimated failure rate of capacitors As per the estimated life and the estimated failure rate depend on the temperature and the voltage. This can be calculated by the equation described in JEITA RCR-2335C Annex F (Informative) Calculation of the estimated lifetime and the estimated failure rate ( Voltage acceleration coefficient : 3 multiplication rule, Temperature acceleration coefficient : 10°C rule) The failure rate can be decreased by reducing the temperature and the voltage but they will not be guaranteed. — 30 — AC11010004 No. 13 Process Caution during operation of equipment Condition 1) A capacitor shall not be touched directly with bare hands during operation in order to avoid electric shock. Electric energy held by the capacitor may be discharged through the human body when touched with a bare hand. Even when the equipment is off, a capacitor may stay charged. The capacitor should be handled after being completely discharged using a resistor. 2) The terminals of a capacitor shall not be short-circuited by any accidental contact with a conductive object. A capacitor shall not be exposed to a conductive liquid such as an acid or alkali solution. A conductive object or liquid, such as acid and alkali, between the terminals may lead to the breakdown of a capacitor due to short circuit 3) Confirm that the environment to which the equipment will be exposed during transportation and operation meets the specified conditions. Do not to use the equipment in the following environments. (1) Environment where a capacitor is spattered with water or oil (2) Environment where a capacitor is exposed to direct sunlight (3) Environment where a capacitor is exposed to Ozone, ultraviolet rays or radiation (4) Environment where a capacitor exposed to corrosive gas(e.g. hydrogen sulfide, sulfur dioxide, chlorine. ammonia gas etc.) (5) Environment where a capacitor exposed to vibration or mechanical shock exceeding the specified limits. (6) Atmosphere change with causes condensation 14 Others △Caution A ! E The product listed in this specification is intended for use in automotive applications under normal operation and usage conditions. S S A The product is not designed or warranted to meet the requirements of application listed below, whose performance and/or quality requires a more stringent level of safety or reliability, or whose failure, malfunction or defect could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in this specification, please contact us. (1) Aerospace/Aviation equipment (2) Transportation equipment (electric trains, ships etc.) (3) Medical equipment (Excepting Pharmaceutical Affairs Law classification Class1, 2) (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. In addition, although the product listed in this specification is intended for use in automotive applications as described above, it is not prohibited to use for general electronic equipment, whose performance and/or quality doesn’t require a more stringent level of safety or reliability, or whose failure, malfunction or defect could not cause serious damage to society, person or property. Therefore, the description of this caution will be applied, when the product is used in general electronic equipment under a normal operation and usage conditions. — 31 — AC11010004 13. TAPE PACKAGING SPECIFICATION 1. CONSTRUCTION AND DIMENSION OF TAPING 1-1. Dimensions of carrier tape Dimensions of paper tape shall be according to Appendix 3, 4, 5. Dimensions of plastic tape shall be according to Appendix 6, 7. 1-2. Bulk part and leader of taping Trailer(Empty) Empty 160mm min. Chips 160mm min. Leader Drawing direction 400mm min 1-3. Dimensions of reel Dimensions of Ø178 reel shall be according to Appendix 8, 9. Dimensions of Ø330 reel shall be according to Appendix 10, 11. 1-4. Structure of taping 〈Paper〉 〈Plastic〉 Top cover tape Top cover tape Pitch hole Cavity (Chip insert) Paper carrier tape Bottom cover tape (Bottom cover tape is not always applied.) 2. CHIP QUANTITY Please refer to detail page on TDK web. — 32 — Pitch hole Cavity (Chip insert) Plastic carrier tape AC11010004 3. PERFORMANCE SPECIFICATIONS 3-1. Fixing peeling strength (top tape) 0.05N < Peeling strength < 0.7N 〈Paper〉 Direction of cover tape pulling Top cover tape Carrier tape 0~15° Direction of pulling Paper tape should not adhere to top cover tape when pull the cover tape. 〈Plastic〉 Direction of pulling Top cover tape Carrier tape 0~15° Direction of pulling 3-2. Carrier tape shall be flexible enough to be wound around a minimum radius of 30mm with components in tape. 3-3. The missing of components shall be less than 0.1% 3-4. Components shall not stick to fixing tape. 3-5. When removing the cover tape, there shall not be difficulties by unfitting clearance gap, burrs and crushes of cavities. Also the sprocket holes shall not be covered by absorbing dust into the suction nozzle. — 33 — AC11010004 Appendix 3 Paper Tape U Pitch hole Cavity(Chip insert) J E D A C B K H G F T (Unit:mm) Symbol Case size CGA1 (CC0201) Symbol Case size CGA1 (CC0201) A B ( 0.38 ) ( 0.68 ) * ( 0.45 ) * ( 0.75 ) G H 2.00 ± 0.05 4.00 ± 0.05 C D E F 8.00 ± 0.30 3.50 ± 0.05 1.75 ± 0.10 2.00 ± 0.05 J K T Ø 1.50 +0.10 0.35 ± 0.02 0 * 0.43 ± 0.02 0.40 min. * 0.47 min. ( ) Reference value. * Applied to 100nF. Appendix 4 Paper Tape U Pitch hole Cavity(Chip insert) J E A D C B H T G F (Unit : mm) Symbol Case size CGA2 (CC0402) Symbol Case size CGA2 (CC0402) ( A B C D E F ( 0.65 ) ( 1.15 ) 8.00 ± 0.30 3.50 ± 0.05 1.75 ± 0.10 2.00 ± 0.05 G H J T 2.00 ± 0.05 4.00 ± 0.10 Ø 1.50 +0.10 0 ) Reference value. — 34 — 0.60±0.15 AC11010004 Appendix 5 Paper Tape Pitch hole Cavity(Chip insert) J E A D B T H G C F (Unit : mm) Symbol Case size CGA3 (CC0603) CGA4 (CC0805) CGA5 (CC1206) Symbol Case size CGA3 (CC0603) CGA4 (CC0805) CGA5 (CC1206) ( A B ( 1.10 ) ( 1.90 ) ( 1.50 ) ( 2.30 ) ( 1.90 ) ( 3.50 ) G H 2.00 ± 0.05 4.00 ± 0.10 C D E F 8.00 ± 0.30 3.50 ± 0.05 1.75 ± 0.10 4.00 ± 0.10 J T Ø 1.50 +0.10 0 ) Reference value. — 35 — 1.20 max. AC11010004 Appendix 6 Plastic Tape Pitch hole Cavity(Chip insert) J E A D C B T H Q F G K (Unit : mm) Symbol Case size CGA3 (CC0603) CGA4 (CC0805) CGA5 (CC1206) CGA6 (CC1210) Symbol Case size CGA3 (CC0603) CGA4 (CC0805) CGA5 (CC1206) CGA6 (CC1210) ( A B ( 1.10 ) ( 1.90 ) ( 1.50 ) ( 2.30 ) ( 1.90 ) ( 3.50 ) ( 2.90 ) ( 3.60 ) G H C D 8.00 ± 0.30 3.50 ± 0.05 E F 1.75 ± 0.10 4.00 ± 0.10 T Q 0.60 max. Ø 0.50 min. * 12.00 ± 0.30 * 5.50 ± 0.05 J K 1.60 max. 2.00 ± 0.05 4.00 ± 0.10 Ø 1.50 +0.10 0 2.50 max. 3.40 max. ) Reference value. Exceptionally no hole in the cavity is applied. Please inquire if hole in cavity is mandatory. * Applied to thickness, 2.5mm products. — 36 — AC11010004 Appendix 7 Plastic Tape Pitch hole Cavity(Chip insert) J E A D C B T H G Q F K (Unit : mm) Symbol Case size CGA8 (CC1812) CGA9 (CC2220) Symbol Case size CGA8 (CC1812) CGA9 (CC2220) ( A B ( 3.60 ) ( 4.90 ) ( 5.40 ) ( 6.10 ) G H 2.00 ± 0.05 4.00 ± 0.10 C D E F 12.00 ± 0.30 5.50 ± 0.05 1.75 ± 0.10 8.00 ± 0.10 J K T Q 6.50 max. 0.60 max. Ø 1.50 min. Ø 1.50 +0.10 0 ) Reference value. Exceptionally no hole in the cavity is applied. Please inquire if hole in cavity is mandatory. — 37 — AC11010004 Appendix 8 Dimensions of reel (Material : Polystyrene) U U CGA1, CGA2, CGA3, CGA4, CGA5, CGA6 W2 E C B D R W1 A (Unit : mm) Symbol A B C D E W1 Dimension Ø178 ± 2.0 Ø60 ± 2.0 Ø13 ± 0.5 Ø21 ± 0.8 2.0 ± 0.5 9.0 ± 0.3 Symbol W2 R Dimension 13.0 ± 1.4 1.0 R R Appendix 9 Dimensions of reel (Material : Polystyrene) U U CGA6(2.5mm thickness products), CGA8, CGA9 W2 E C B D R W1 A (Unit : mm) Symbol A B C D E W1 Dimension Ø178 ± 2.0 Ø60 ± 2.0 Ø13 ± 0.5 Ø21 ± 0.8 2.0 ± 0.5 13.0 ± 0.3 Symbol W2 R Dimension 17.0 ± 1.4 1.0 R — 38 — R AC11010004 Appendix 10 Dimensions of reel (Material : Polystyrene) U U CGA1, CGA2, CGA3, CGA4, CGA5, CGA6 E C B D R t W A (Unit : mm) Symbol Dimension A Ø382 max. (Nominal Ø330) B C D E W Ø50 min. Ø13 ± 0.5 Ø21 ± 0.8 2.0 ± 0.5 10.0 ± 1.5 Symbol t R Dimension 2.0 ± 0.5 1.0 Appendix 11 Dimensions of reel (Material : Polystyrene) U U CGA6(2.5mm thickness products), CGA8, CGA9 E C B D R W A t (Unit : mm) Symbol Dimension A Ø382 max. (Nominal Ø330) B C D E W Ø50 min. Ø13 ± 0.5 Ø21 ± 0.8 2.0 ± 0.5 14.0 ± 1.5 Symbol t R Dimension 2.0 ± 0.5 1.0 — 39 —
CGA4J1X7R1V475M125AC 价格&库存
很抱歉,暂时无法提供与“CGA4J1X7R1V475M125AC”相匹配的价格&库存,您可以联系我们找货
  • 1+4.424761+0.57115
  • 10+2.6848610+0.34657
  • 50+2.0058250+0.25892
  • 100+1.79766100+0.23205
  • 500+1.44541500+0.18658
  • 1000+1.336711000+0.17255
库存:10332
    库存:2000
    • 2000+1.211692000+0.15641
    • 4000+1.140194000+0.14718
    • 6000+1.104396000+0.14256
    • 10000+1.0647410000+0.13744
    • 14000+1.0415514000+0.13445
    • 20000+1.0192420000+0.13157
    库存:10332
