CGA4J1X8R1E105K125AC 数据手册
TDK Item Description : CGA4J1X8R1E105KT****
Equivalent C2012X8R1E105K for Automotive
DC Bias Characteristic
10
Application & Main Feature
Cap. Change/%
Automotive Grade ( High Temperature Application )
Series
CGA4(2012) [EIA 0805]
-10
-20
-30
-40
-50
2.00mm
1.25mm
1.25mm
0.20mm
0.50mm
+/-0.2mm
+/-0.2mm
+/-0.2mm
Min.
Min.
Temperature Characteristic
X8R (-55 to 150 deg +/-15%)
1000
|Z|, ESR vs. Freq. Characteristics
15
30
Rated Voltage
10
10
-20
-30
1
-40
-50
0.1
-60
-70
0.01
1E (25Vdc)
0.001
0.001
Capacitance
-80
0.01
0.1
1
10
100
1000
|Z|
-80
-60
-40
K (+/-10%)
10
ESR
Cap. vs. Freq. Characteristic
1
AEC-Q200
Yes
0.1
1
Frequency/MHz
80
100 120 140 160 180
10
100
1000
TCBias(1/2Rated)
10
5
1
1.5
2
2.5
3
Current/Arms
100kHz
All specifications are subject to change without notice.
40
Ripple Temperature Rise Characteristics
25
5% Max.
0.01
Temp.Chara.
Dissipation Factor
0.1
0.001
-20
Temperature/degC
Temperature Rise/degC
Capacitance Tolerance
500Mohm Min.
-90
Frequency/MHz
1uF
Insulation Resistance
Temperature Characteristics
Cap./uF
Characterization Sheet ( Multilayer Ceramic Chip Capacitors )
10
Cap. Change/%
L
W
T
B
G
5
DC Bias/V
|Z|, ESR/ohm
Dimensions
500kHz
1MHz
June 5, 2018
CGA4J1X8R1E105K125AC 价格&库存
很抱歉,暂时无法提供与“CGA4J1X8R1E105K125AC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.445631+0.44785
- 10+2.0289810+0.26372
- 50+1.4943250+0.19423
- 100+1.33025100+0.17290
- 500+1.05189500+0.13672
- 国内价格 香港价格
- 2000+0.845872000+0.10995
- 6000+0.763606000+0.09925
