CGA5F1X7S3A102M085AE
    TDK(东电化)
    贴片电容(MLCC) 1206 1nF ±20% 1KV X7S
CGA5F1X7S3A102M085AE 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS February 2021 MULTILAYER CERAMIC CHIP CAPACITORS Automotive grade, high voltage (1,000V and over)  CGA series CGA6 CGA7 CGA8 CGA9 3225 [1210 inch] 4520 [1808 inch] 4532 [1812 inch] 5750 [2220 inch] * Dimensions code: JIS[EIA] (2/7) MULTILAYER CERAMIC CHIP CAPACITORS REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS 1. The products listed in this specification are intended for use in automotive applications under normal operation and usage conditions. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality requires a more stringent level of safety or reliability, or whose failure, malfunction or defect could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in this specification, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (excepting Pharmaceutical Affairs Law classification Class1,2) (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. In addition, although the products listed in this specification are intended for use in automotive applications as described above, they are not prohibited to use in general electronic equipment, whose performance and/or quality doesn’t require a more stringent level of safety or reliability, or whose failure, malfunction or defect could not cause serious damage to society, person or property. Therefore, the description of this caution will be applied, when the products are used in general electronic equipment under a normal operation and usage conditions. 2. We may modify products or discontinue production of a product listed in this catalog without prior notification. 3. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. 4. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export permission in harmony with this law. 5. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. 6. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. 7. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging specification detail. This new catalog number should be referenced on all catalog orders going forward, and is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will differ from the item description (internal control number) on the product label. Contact your local TDK Sales representative for more information. (Example) Catalog issued date Prior to January 2013 January 2013 and later Catalog number C1608C0G1E103J(080AA) C1608C0G1E103J080AA Item description (on delivery label) C1608C0G1E103JT000N C1608C0G1E103JT000N 20210204 / mlcc_automotive_highvoltage_en.fm (3/7) MULTILAYER CERAMIC CHIP CAPACITORS CGA series Cl Br High voltage (1,000V and over) RoHS REACH Halogen Free SVHC-Free Pb Lead Free Type: CGA6/3225 [1210 inch], CGA7/4520 [1808 inch], CGA8/4532 [1812 inch], CGA9/5750 [2220 inch] ■ SERIES OVERVIEW High voltage CGA series, automotive grade of TDK's multilayer ceramic chip capacitor, is a product having a high withstanding voltage characteristic. The lineup is voltage rating of 1,000V to 3,000V with capacitance range up to 33nF. ■ FEATURES ■ APPLICATIONS • Voltage rating of 1,000V, 2,000V and 3,000V • Operating temperature range: –55 to +125°C • C0G type having excellent stable temperature and DC-bias characteristics is also available • AEC-Q200 compliant • Decoupling, snubber and resonant circuits of high voltage circuits • Wireless charging units, DC-DC converter, Inverter ■ SHAPE & DIMENSIONS ■ RECOMMENDED CONDITIONS Slit to improve washing flux W L PC T B SD L W T B Body length Body width Body height Terminal width Type L W CGA6 3.20±0.40 2.50±0.30 CGA7 4.50±0.40 2.00±0.20 CGA8 4.50±0.40 3.20±0.40 CGA9 5.70±0.40 5.00±0.40 Dimensional tolerances are typical values. PB PA • It is recommended to provide a slit (about 1mm width) in the board under the components to improve washing flux. • Please make sure to dry detergent up completely before. • It is recommended to use low activated flux (Chlorine content: less than 0.1wt%) such rosin due to high voltage usage. • When mounting on an aluminum substrate, it is more likely to be affected by heat stress from the substrate. Please inquire separate specification when mounted on the substrate. T 2.50±0.30 2.00±0.20 2.50±0.30 2.80±0.30 Dimensions in mm B 0.20 min. 0.20 min. 0.20 min. 0.20 min. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210204 / mlcc_automotive_highvoltage_en.fm (4/7) MULTILAYER CERAMIC CHIP CAPACITORS ■ CATALOG NUMBER CONSTRUCTION CGA 9 Q 1 C0G 3A 333 J 280 K C (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (6) Rated voltage (DC) (1) Series (2) Dimensions L x W (mm) Code 6 7 8 9 EIA CC1210 CC1808 CC1812 CC2220 Length 3.20 4.50 4.50 5.70 Width 2.50 2.00 3.20 5.00 Terminal width 0.20 min. 0.20 min. 0.20 min. 0.20 min. (3) Thickness code Code F G K L M N P Q Thickness 0.85 mm 1.10 mm 1.30 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm 2.80 mm Voltage (DC) 1,000V 2,000V 3,000V (7) Nominal capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. (Example)0R5 = 0.5pF 101 = 100pF 225 = 2,200,000pF = 2.2µF (8) Capacitance tolerance Code F J K M (4) Voltage condition for life test Symbol 1 Code 3A 3D 3F Condition 1 × R.V. Tolerance ±1pF ±5% ±10% ±20% (9) Thickness (5) Temperature characteristics Temperature characteristics C0G X7R Temperature coefficient or capacitance change 0±30 ppm/°C ±15% Temperature range –55 to +125°C –55 to +125°C Code 085 110 130 160 200 230 250 280 Thickness 0.85 mm 1.10 mm 1.30 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm 2.80 mm (10) Packaging style Code A K Style 178mm reel, 4mm pitch 178mm reel, 8mm pitch (11) Special reserved code Code A,C Description TDK internal code Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210204 / mlcc_automotive_highvoltage_en.fm (5/7) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance C0G (pF) 3A (1kV) 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 12,000 15,000 18,000 22,000 Code CGA6/3225 [1210 inch] 102 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 Standard thickness   2.00 mm  2.30 mm  2.50 mm Background gray: These products are not recommended for new designs. ■ For details such as the catalog numbers, please refer to the capacitance range table on page 7 and after. Capacitance range chart Capacitance C0G (pF) 3F (3kV) 10 12 15 18 22 27 33 39 47 56 68 82 100 470 1,000 Code CGA7/4520 [1808 inch] X7R 3D (2kV) 3A (1kV) 100 120 150 180 220 270 330 390 470 560 680 820 101 471 102 Standard thickness   0.85 mm  1.10 mm  1.30 mm  1.60 mm  2.00 mm  Background gray: These products are not recommended for new designs. ■ For details such as the catalog numbers, please refer to the capacitance range table on page 7 and after. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210204 / mlcc_automotive_highvoltage_en.fm (6/7) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance C0G (pF) 3F (3kV) 100 120 150 180 220 270 330 2,200 4,700 10,000 Code CGA8/4532 [1812 inch] X7R 3D (2kV) 3A (1kV) 101 121 151 181 221 271 331 222 472 103 Standard thickness   1.30 mm  1.60 mm  2.00 mm  2.30 mm  2.50 mm  Background gray: These products are not recommended for new designs. ■ For details such as the catalog numbers, please refer to the capacitance range table on page 7 and after. Capacitance range chart Capacitance C0G (pF) 3A (1kV) 10,000 12,000 15,000 18,000 22,000 27,000 33,000 Code CGA9/5750 [2220 inch] 103 123 153 183 223 273 333 Standard thickness   2.80 mm  Background gray: These products are not recommended for new designs. ■ For details such as the catalog numbers, please refer to the capacitance range table on page 7 and after. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210204 / mlcc_automotive_highvoltage_en.fm (7/7) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions 10pF 12pF 15pF 18pF 22pF 27pF 33pF 39pF 47pF 56pF 68pF 82pF 100pF 120pF 150pF 180pF 220pF 270pF 330pF 1nF 1.2nF 1.5nF 1.8nF 2.2nF 2.7nF 3.3nF 3.9nF 4.7nF 5.6nF 6.8nF 8.2nF 10nF 12nF 15nF 18nF 22nF 27nF 33nF 4520 4520 4520 4520 4520 4520 4520 4520 4520 4520 4520 4520 4520 4532 4532 4532 4532 4532 4532 4532 3225 3225 3225 3225 3225 3225 3225 3225 3225 3225 3225 3225 3225 5750 3225 5750 3225 5750 3225 5750 3225 5750 5750 5750 Temperature characteristic: C0G (–55 to +125°C, 0±30ppm/°C) Thickness (mm) Capacitance tolerance Catalog number Rated voltage Edc: 3kV 0.85±0.15 0.85±0.15 1.10±0.20 1.10±0.20 1.10±0.20 1.60±0.20 1.60±0.20 1.60±0.20 1.60±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 1.60±0.20 1.60±0.20 1.60±0.20 1.60±0.20 2.00±0.20 2.30±0.20 2.50±0.30 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.30±0.20 2.50±0.30 2.80±0.30 2.50±0.30 2.80±0.30 2.50±0.30 2.80±0.30 2.50±0.30 2.80±0.30 2.50±0.30 2.80±0.30 2.80±0.30 2.80±0.30 ±1pF ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% CGA7F1C0G3F100F085KA CGA7F1C0G3F120K085KA CGA7G1C0G3F150K110KA CGA7G1C0G3F180K110KA CGA7G1C0G3F220K110KA CGA7L1C0G3F270K160KA CGA7L1C0G3F330K160KA CGA7L1C0G3F390K160KA CGA7L1C0G3F470K160KA CGA7M1C0G3F560K200KA CGA7M1C0G3F680K200KA CGA7M1C0G3F820K200KA CGA7M1C0G3F101K200KA CGA8L1C0G3F101K160KA CGA8L1C0G3F121K160KA CGA8L1C0G3F151K160KA CGA8L1C0G3F181K160KA CGA8M1C0G3F221K200KA CGA8N1C0G3F271K230KA CGA8P1C0G3F331K250KA Rated voltage Edc: 1kV CGA6M1C0G3A102J200AC CGA6M1C0G3A122J200AC CGA6M1C0G3A152J200AC CGA6M1C0G3A182J200AC CGA6M1C0G3A222J200AC CGA6M1C0G3A272J200AC CGA6M1C0G3A332J200AC CGA6M1C0G3A392J200AC CGA6M1C0G3A472J200AC CGA6M1C0G3A562J200AC CGA6M1C0G3A682J200AC CGA6N1C0G3A822J230AC CGA6P1C0G3A103J250AC CGA9Q1C0G3A103J280KC CGA6P1C0G3A123J250AC CGA9Q1C0G3A123J280KC CGA6P1C0G3A153J250AC CGA9Q1C0G3A153J280KC CGA6P1C0G3A183J250AC CGA9Q1C0G3A183J280KC CGA6P1C0G3A223J250AC CGA9Q1C0G3A223J280KC CGA9Q1C0G3A273J280KC CGA9Q1C0G3A333J280KC ■ Gray items: These products are not recommended for new designs. Click the part numbers for details. Capacitance range table Capacitance Dimensions 470pF 4520 Thickness (mm) 1.30±0.20 1nF 4520 1.30±0.20 2.2nF 4532 1.30±0.20 4.7nF 4532 1.60±0.20 10nF 4532 2.00±0.20 Temperature characteristic: X7R (–55 to +125°C, ±15%) Capacitance tolerance Catalog number Rated voltage Edc: 2kV Rated voltage Edc: 1kV ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% CGA7K1X7R3D471K130KA CGA7K1X7R3A471K130KA CGA7K1X7R3D471M130KA CGA7K1X7R3A471M130KA CGA7K1X7R3D102K130KA CGA7K1X7R3A102K130KA CGA7K1X7R3D102M130KA CGA7K1X7R3A102M130KA CGA8K1X7R3D222K130KA CGA8K1X7R3D222M130KA CGA8L1X7R3A472K160KA CGA8L1X7R3A472M160KA CGA8M1X7R3A103K200KA CGA8M1X7R3A103M200KA ■ Gray items: These products are not recommended for new designs. Click the part numbers for details. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210204 / mlcc_automotive_highvoltage_en.fm
1. 物料型号:文档列出了不同系列和尺寸的型号,例如CGA6(3225[1210英寸])、CGA7(4520[1808英寸])、CGA8(4532[1812英寸])和CGA9(5750[2220英寸])。
2. 器件简介:这些电容器是汽车级、高电压(1000V及以上)的产品,符合AEC-Q200标准,适用于高电压电路的去耦、消振和谐振电路。
3. 引脚分配:文档提供了电容器的尺寸和推荐条件,例如在组件下方的板上提供约1mm宽的切口以改善洗涤通量。
4. 参数特性:包括工作温度范围(-55至+125°C)、电容范围(高达33nF)、额定电压(1000V、2000V和3000V)等。
5. 功能详解:文档详细描述了产品的主要特性,如C0G类型的稳定温度和直流偏置特性,以及符合REACH、无卤素、RoHS无铅等环保标准。
6. 应用信息:适用于无线充电单元、DC-DC转换器、逆变器等。
7. 封装信息:提供了详细的尺寸数据和封装类型,例如178mm卷轴、4mm和8mm节距。
CGA5F1X7S3A102M085AE 价格&库存
很抱歉,暂时无法提供与“CGA5F1X7S3A102M085AE”相匹配的价格&库存,您可以联系我们找货
  • 1+7.427621+0.95823
  • 10+4.7109310+0.60775
  • 50+3.6236150+0.46748
  • 100+3.28857100+0.42426
  • 500+2.72366500+0.35138
  • 1000+2.549121000+0.32886
库存:37
  • 4000+2.221864000+0.28664
  • 8000+2.127318000+0.27444
  • 12000+2.0799412000+0.26833
  • 20000+2.0274220000+0.26156
  • 28000+1.9967328000+0.25760
  • 40000+1.9671840000+0.25379
库存:37
