CGA5F1X7T2J153K085AC
    TDK(东电化)
    0.015 µF ±10% 630V 陶瓷电容器 X7T 1206(3216 公制)
CGA5F1X7T2J153K085AC 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS CGA Series Automotive Grade Mid Voltage (100 to 630V) Type: CGA2 [EIA CC0402] CGA3 [EIA CC0603] CGA4 [EIA CC0805] CGA5 [EIA CC1206] CGA6 [EIA CC1210] CGA8 [EIA CC1812] CGA9 [EIA CC2220] Issue date: Mar 2015 20150309 / mlcc_automotive_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS REMINDERS Please read before using this product SAFETY REMINDERS REMINDERS 1. If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other damage, you must contact our company’s sales window. 2. We may modify products or discontinue production of a product listed in this catalog without prior notification. 3. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. 4. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export permission in harmony with this law. 5. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. 6. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. 7. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging specification detail. This new catalog number should be referenced on all catalog orders going forward, and is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will differ from the item description (internal control number) on the product label. Contact your local TDK Sales representative for more information. (Example) Catalog Issued date Catalog Number Item Description (On Delivery Label) Prior to January 2013 C1608C0G1E103J C1608C0G1E103JT000N January 2013 and Later C1608C0G1E103J080AA C1608C0G1E103JT000N Page 1 20150309 / mlcc_automotive_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS CGA Series Mid Voltage (100 to 630V) Type: CGA2 [EIA CC0402], CGA3 [EIA CC0603], CGA4 [EIA CC0805], CGA5 [EIA CC1206], CGA6 [EIA CC1210], CGA8 [EIA CC1812], CGA9 [EIA CC2220] Features ‡9ROWDJHUDWLQJRI9WR9ZLWKFDSDFLWDQFHUDQJHXSWRȝ) • High capacitance has been achieved through precision technologies that enable the use of multiple thinner ceramic dielectric layers. • Low residual inductance assures superior frequency characteristics. • Excellent DC Bias properties. • A lineup with wide-ranging rated voltages that enables selections that are suitable for needs. • AEC-Q200 compliant. Catalog Number Construction Applications • Application in decoupling, smoothing, and snubber circuits of inverters or DC-DC converters of HEVs or EVs • Countermeasure against voltage surge and noise in connectors Shape & Dimensions L W T B G Body Length Body Width Body Height Terminal Width Terminal Spacing CGA • 9 • P • 3 • X7S • 2A • 156 • M • 250 • K • B Series Name Dimensions L x W (mm) Code 2 3 4 5 6 8 9 Length 1.00 ± 0.05 1.60 ± 0.10 2.00 ± 0.20 3.20 ± 0.20 3.20 ± 0.40 4.50 ± 0.40 5.70 ± 0.40 Width 0.50 ± 0.05 0.80 ± 0.10 1.25 ± 0.20 1.60 ± 0.20 2.50 ± 0.30 3.20 ± 0.40 5.00 ± 0.40 Terminal 0.10 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. *Dimension tolerance are typical values Thickness T Code (mm) Code B C E F H J K L M N P Q R Thickness 0.50 mm 0.60 mm 0.80 mm 0.85 mm 1.15 mm 1.25 mm 1.30 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm 2.80 mm 3.20 mm Voltage Condition for Life Test Symbol Condition 1 × R.V. 1 2 × R.V. 2 Symbol Condition 1.5 × R.V. 3 1.2 × R.V. 4 Temperature Characteristics Temperature Coefficient or Temperature Characteristics Capacitance Change 0±30 ppm/°C C0G ±15% X7R ±22% X7S X7T +22/-33% Temperature Range -55 to +125°C -55 to +125°C -55 to +125°C -55 to +125°C Rated Voltage (DC) Code 2A 2E 2W 2J Voltage (DC) 100V 250V 450V 630V Nominal Capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. Ex. 0R2 = 0.2pF; 103 = 10,000pF; 105 = 1,000,000pF = 1,000nF = 1ȝF Capacitance Tolerance Code C D J K M Tolerance ± 0.25pF ± 0.50pF ± 5% ± 10% ± 20% Nominal Thickness Code 050 060 125 230 280 320 Thickness 0.50 mm 0.60 mm 1.25 mm 2.30 mm 2.80 mm 3.20 mm Packaging Style Code A B K Style 178 mm Reel, 4 mm Pitch 178 mm Reel, 2 mm Pitch 178 mm Reel, 8 mm Pitch Special Reserved Code Code Description A, B, C TDK Internal Code *See Thickness T Code for complete list Page 2 • All specifications are subject to change without notice. 20150309 / mlcc_automotive_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA2(1005) [EIA CC0402] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), X7S (±22%) Rated Voltage: 100V (2A) C0G Capacitance (pF) Code 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,500 2,200 3,300 4,700 6,800 10,000 101 121 151 181 221 271 331 391 471 561 681 821 102 152 222 332 472 682 103 Tolerance X7S 2A 2A (100V) (100V) J: ± 5% K: ± 10% M: ± 20% Standard Thickness 0.50 mm Page 3 • All specifications are subject to change without notice. 20150309 / mlcc_automotive_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA3(1608) [EIA CC0603] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), X7R (±15%), X7S (±22%) Rated Voltage: 250V (2E), 100V (2A) Capacitance (pF) 1 1.5 2 2.2 3 3.3 4 4.7 5 6 6.8 7 8 9 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 Code 010 1R5 020 2R2 030 3R3 040 4R7 050 060 6R8 070 080 090 100 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 153 223 333 473 683 104 Tolerance C: ± D: ± J :± K:± M: ± C0G X7R X7S 2E 2A 2A 2A (250V) (100V) (100V) (100V) 0.25pF 0.50pF 5% 10% 20% Standard Thickness 0.80 mm Page 4 • All specifications are subject to change without notice. 20150313 / mlcc_automotive_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA4(2012) [EIA CC0805] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), X7R (±15%), X7S (±22%), X7T (+22/-33%) Rated Voltage: 450V (2W), 250V (2E), 100V (2A) C0G Capacitance (pF) Code 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 330,000 470,000 680,000 1,000,000 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 153 223 333 473 683 104 334 474 684 105 Tolerance X7R X7S X7T 2W 2E 2A 2E 2A 2A 2W 2E (450V) (250V) (100V) (250V) (100V) (100V) (450V) (250V) J : ± 5% K : ± 10% M: ± 20% Standard Thickness 0.60 mm 0.85 mm 1.25 mm Page 5 • All specifications are subject to change without notice. 20150309 / mlcc_automotive_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA5(3216) [EIA CC1206] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), X7R (±15%), X7S (±22%), X7T (+22/-33%) Rated Voltage: 630V (2J), 450V (2W), 250V (2E), 100V (2A) Capacitance (pF) 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 C0G Code 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 335 Tolerance X7R X7S X7T 2J 2W 2E 2A 2J 2E 2A 2A 2J 2W 2E (630V) (450V) (250V) (100V) (630V) (250V) (100V) (100V) (630V) (450V) (250V) J : ± 5% K : ± 10% M: ± 20% Standard Thickness 0.60 mm 0.85 mm 1.15 mm 1.30 mm 1.60 mm Page 6 • All specifications are subject to change without notice. 20150309 / mlcc_automotive_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA6(3225) [EIA CC1210] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), X7R (±15%), X7S (±22%), X7T (+22/-33%) Rated Voltage: 630V (2J), 450V (2W), 250V (2E), 100V (2A) Capacitance (pF) 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 C0G Code 392 472 562 682 822 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 335 475 Tolerance X7R X7S X7T 2J 2W 2E 2A 2J 2E 2A 2A 2J 2W 2E (630V) (450V) (250V) (100V) (630V) (250V) (100V) (100V) (630V) (450V) (250V) J : ± 5% K : ± 10% M: ± 20% Standard Thickness 1.25 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm Page 7 • All specifications are subject to change without notice. 20150309 / mlcc_automotive_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA8(4532) [EIA CC1812] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), X7R (±15%), X7S (±22%), X7T (+22/-33%) Rated Voltage: 630V (2J), 450V (2W), 250V (2E), 100V (2A) Capacitance (pF) 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 C0G Code 822 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 335 475 Tolerance X7R X7S X7T 2J 2W 2E 2A 2J 2E 2A 2A 2J 2W 2E (630V) (450V) (250V) (100V) (630V) (250V) (100V) (100V) (630V) (450V) (250V) J : ± 5% K : ± 10% M: ± 20% Standard Thickness 1.60 mm 2.00 mm 2.30 mm 3.20 mm Capacitance Range Chart CGA9(5750) [EIA CC2220] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), X7R (±15%), X7S (±22%), X7T (+22/-33%) Rated Voltage: 630V (2J), 450V (2W), 250V (2E), 100V (2A) Capacitance (pF) 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 C0G Code 683 104 154 224 334 474 684 105 155 225 335 475 685 106 156 Tolerance X7R X7S X7T 2J 2W 2E 2A 2J 2E 2A 2A 2J 2W 2E (630V) (450V) (250V) (100V) (630V) (250V) (100V) (100V) (630V) (450V) (250V) J : ± 5% K : ± 10% M: ± 20% Standard Thickness 1.60 mm 2.00 mm 2.30 mm 2.50 mm 2.80 mm Page 8 • All specifications are subject to change without notice. 20150309 / mlcc_automotive_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to +125ºC, 0 ± 30 ppm/ºC) Capacitance Size Thickness (mm) Capacitance Tolerance 1 pF 1.5 pF 2 pF 2.2 pF 3 pF 3.3 pF 4 pF 4.7 pF 5 pF 6 pF 6.8 pF 7 pF 8 pF 9 pF 10 pF 12 pF 15 pF 18 pF 22 pF 27 pF 33 pF 39 pF 47 pF 56 pF 68 pF 82 pF 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1005 1608 2012 3216 1005 1608 2012 3216 1005 1608 2012 3216 1005 1608 2012 3216 1005 1608 2012 3216 1005 1608 2012 3216 1005 1608 2012 3216 1005 1608 2012 3216 1005 1608 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% 100 pF 120 pF 150 pF 180 pF 220 pF 270 pF 330 pF 390 pF 470 pF Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 450V Rated Voltage Edc: 250V CGA3E3C0G2E101J080AA CGA4C4C0G2W101J060AA Rated Voltage Edc: 100V CGA3E2C0G2A010C080AA CGA3E2C0G2A1R5C080AA CGA3E2C0G2A020C080AA CGA3E2C0G2A2R2C080AA CGA3E2C0G2A030C080AA CGA3E2C0G2A3R3C080AA CGA3E2C0G2A040C080AA CGA3E2C0G2A4R7C080AA CGA3E2C0G2A050C080AA CGA3E2C0G2A060D080AA CGA3E2C0G2A6R8D080AA CGA3E2C0G2A070D080AA CGA3E2C0G2A080D080AA CGA3E2C0G2A090D080AA CGA3E2C0G2A100D080AA CGA3E2C0G2A120J080AA CGA3E2C0G2A150J080AA CGA3E2C0G2A180J080AA CGA3E2C0G2A220J080AA CGA3E2C0G2A270J080AA CGA3E2C0G2A330J080AA CGA3E2C0G2A390J080AA CGA3E2C0G2A470J080AA CGA3E2C0G2A560J080AA CGA3E2C0G2A680J080AA CGA3E2C0G2A820J080AA CGA2B2C0G2A101J050BA CGA3E2C0G2A101J080AA CGA4C2C0G2A101J060AA CGA5C4C0G2J101J060AA CGA3E3C0G2E121J080AA CGA2B2C0G2A121J050BA CGA3E2C0G2A121J080AA CGA3E3C0G2E151J080AA CGA2B2C0G2A151J050BA CGA3E2C0G2A151J080AA CGA3E3C0G2E181J080AA CGA2B2C0G2A181J050BA CGA3E2C0G2A181J080AA CGA4C4C0G2W121J060AA CGA5C4C0G2J121J060AA CGA4C4C0G2W151J060AA CGA5C4C0G2J151J060AA CGA4C4C0G2W181J060AA CGA5C4C0G2J181J060AA CGA3E3C0G2E221J080AA CGA4C4C0G2W221J060AA CGA2B2C0G2A221J050BA CGA3E2C0G2A221J080AA CGA4C2C0G2A221J060AA CGA5C4C0G2J221J060AA CGA3E3C0G2E271J080AA CGA2B2C0G2A271J050BA CGA3E2C0G2A271J080AA CGA3E3C0G2E331J080AA CGA2B2C0G2A331J050BA CGA3E2C0G2A331J080AA CGA3E3C0G2E391J080AA CGA2B2C0G2A391J050BA CGA3E2C0G2A391J080AA CGA3E3C0G2E471J080AA CGA2B2C0G2A471J050BA CGA3E2C0G2A471J080AA CGA4C4C0G2W271J060AA CGA5C4C0G2J271J060AA CGA4C4C0G2W331J060AA CGA5C4C0G2J331J060AA CGA4C4C0G2W391J060AA CGA5C4C0G2J391J060AA Page 9 • All specifications are subject to change without notice. 20150309 / mlcc_automotive_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to +125ºC, 0 ± 30 ppm/ºC) Capacitance 470 pF 560 pF 680 pF 820 pF 1 nF Size 2012 3216 1005 1608 2012 3216 1005 1608 2012 3216 1005 1608 2012 3216 1005 1608 2012 3216 1608 1.2 nF 2012 3216 1608 1.5 nF 2012 3216 1608 1.8 nF 2012 3216 1608 2.2 nF 2.7 nF 3.3 nF 2012 3216 1608 2012 3216 1608 2012 3216 1608 2012 3.9 nF 3216 3225 1608 2012 4.7 nF 3216 3225 1608 2012 5.6 nF 3216 3225 Thickness (mm) Capacitance Tolerance 0.60 ± 0.15 0.85 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.85 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.85 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.85 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.85 ± 0.15 0.85 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.85 ± 0.15 0.85 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.85 ± 0.15 1.15 ± 0.15 0.80 ± 0.10 0.85 ± 0.15 1.25 ± 0.20 1.15 ± 0.15 0.80 ± 0.10 0.80 +0.15/-0.1 0.85 ± 0.15 1.25 ± 0.20 1.15 ± 0.15 0.80 +0.15/-0.1 1.25 ± 0.20 1.60 ± 0.20 0.80 +0.15/-0.1 0.85 ± 0.15 1.25 ± 0.20 0.85 ± 0.15 1.60 ± 0.20 0.80 ± 0.10 1.25 ± 0.20 0.60 ± 0.15 0.85 ± 0.15 1.15 ± 0.15 1.25 ± 0.20 0.80 ± 0.10 1.25 ± 0.20 0.85 ± 0.15 1.15 ± 0.15 1.60 ± 0.20 0.80 ± 0.10 1.25 ± 0.20 0.85 ± 0.15 1.15 ± 0.15 1.60 ± 0.20 ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 450V CGA4C4C0G2W471J060AA Rated Voltage Edc: 250V Rated Voltage Edc: 100V CGA4C2C0G2A471J060AA CGA5F4C0G2J471J085AA CGA3E3C0G2E561J080AA CGA2B1C0G2A561J050BC CGA3E2C0G2A561J080AA CGA3E3C0G2E681J080AA CGA2B1C0G2A681J050BC CGA3E2C0G2A681J080AA CGA4C4C0G2W561J060AA CGA5F4C0G2J561J085AA CGA4C4C0G2W681J060AA CGA5F4C0G2J681J085AA CGA3E3C0G2E821J080AA CGA4C4C0G2W821J060AA CGA4C3C0G2E821J060AA CGA2B1C0G2A821J050BC CGA3E2C0G2A821J080AA CGA5F4C0G2J821J085AA CGA3E3C0G2E102J080AA CGA4C4C0G2W102J060AA CGA2B1C0G2A102J050BC CGA3E2C0G2A102J080AA CGA4C2C0G2A102J060AA CGA4F3C0G2E102J085AA CGA5F4C0G2J102J085AA CGA3E3C0G2E122J080AA CGA4C4C0G2W122J060AA CGA3E2C0G2A122J080AA CGA4C2C0G2A122J060AA CGA4F3C0G2E122J085AA CGA5F4C0G2J122J085AA CGA3E3C0G2E152J080AA CGA4F4C0G2W152J085AA CGA3E2C0G2A152J080AA CGA4C2C0G2A152J060AA CGA4F3C0G2E152J085AA CGA5H4C0G2J152J115AA CGA3E3C0G2E182J080AA CGA4F4C0G2W182J085AA CGA3E2C0G2A182J080AA CGA4F2C0G2A182J085AA CGA4J3C0G2E182J125AA CGA5H4C0G2J182J115AA CGA3E2C0G2A222J080AA CGA3E3C0G2E222J080AA CGA4F4C0G2W222J085AA CGA4F2C0G2A222J085AA CGA4J3C0G2E222J125AA CGA5H4C0G2J222J115AA CGA4J4C0G2W272J125AA CGA4J3C0G2E272J125AA CGA3E2C0G2A272J080AA CGA4J2C0G2A272J125AA CGA5L4C0G2J272J160AA CGA3E2C0G2A332J080AA CGA4F3C0G2E332J085AA CGA4J4C0G2W332J125AA CGA4J2C0G2A332J125AA CGA5F3C0G2E332J085AA CGA5L4C0G2J332J160AA CGA4J4C0G2W392J125AA CGA4J3C0G2E392J125AA CGA3E1C0G2A392J080AC CGA4J2C0G2A392J125AA CGA5C2C0G2A392J060AA CGA5F4C0G2J392J085AA CGA5H3C0G2E392J115AA CGA6J4C0G2J392J125AA CGA4J4C0G2W472J125AA CGA4J3C0G2E472J125AA CGA5F4C0G2J472J085AA CGA3E1C0G2A472J080AC CGA4J2C0G2A472J125AA CGA5F2C0G2A472J085AA CGA5H3C0G2E472J115AA CGA6L4C0G2J472J160AA CGA4J4C0G2W562J125AA CGA5H4C0G2J562J115AA CGA6L4C0G2J562J160AA CGA4J3C0G2E562J125AA CGA3E1C0G2A562J080AC CGA4J2C0G2A562J125AA CGA5F2C0G2A562J085AA CGA5H3C0G2E562J115AA Page 10 • All specifications are subject to change without notice. 20150309 / mlcc_automotive_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to +125ºC, 0 ± 30 ppm/ºC) Capacitance Size 1608 2012 6.8 nF 8.2 nF 3216 3225 1608 2012 3216 8.2 nF 10 nF 3225 4532 1608 2012 3216 3225 4532 2012 3216 15 nF 3225 4532 2012 3216 22 nF 3225 4532 2012 3216 33 nF 3225 4532 3216 3225 47 nF 4532 3216 3225 68 nF 100 nF 150nF 4532 5750 3216 4532 5750 5750 Thickness (mm) Capacitance Tolerance 0.80 ± 0.10 1.25 ± 0.20 1.15 ± 0.15 1.60 ± 0.20 2.00 ± 0.20 0.80 ± 0.10 1.25 ± 0.20 1.15 ± 0.15 1.60 ± 0.20 1.25 ± 0.20 1.60 ± 0.20 0.80 ± 0.10 1.25 ± 0.20 1.15 ± 0.15 1.60 ± 0.20 1.25 ± 0.20 1.60 ± 0.20 1.60 ± 0.20 0.85 ± 0.15 1.15 ± 0.15 1.60 ± 0.20 1.60 +0.3/-0.1 1.25 ± 0.20 1.60 ± 0.20 2.00 ± 0.20 2.50 ± 0.30 1.25 ± 0.20 1.60 ± 0.20 1.60 +0.3/-0.1 1.60 ± 0.20 2.30 ± 0.20 1.60 ± 0.20 3.20 ± 0.30 1.25 ± 0.20 1.60 +0.3/-0.1 2.00 ± 0.20 2.30 ± 0.20 2.50 ± 0.30 2.00 ± 0.20 1.15 ± 0.15 2.30 ± 0.20 2.50 ± 0.30 2.00 ± 0.20 2.30 ± 0.20 3.20 ± 0.30 1.60 ± 0.20 2.30 ± 0.20 2.30 ± 0.20 2.50 ± 0.30 3.20 ± 0.30 2.30 ± 0.20 1.60 ± 0.20 3.20 ± 0.30 2.80 ± 0.30 2.30 ± 0.20 ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 450V CGA5H4C0G2J682J115AA CGA5H4C0G2W682J115AA Rated Voltage Edc: 250V CGA4J3C0G2E682J125AA Rated Voltage Edc: 100V CGA3E1C0G2A682J080AC CGA4J2C0G2A682J125AA CGA5H2C0G2A682J115AA CGA5L3C0G2E682J160AA CGA6M4C0G2J682J200AA CGA4J3C0G2E822J125AA CGA5H4C0G2W822J115AA CGA5L4C0G2J822J160AA CGA6J4C0G2J822J125AA CGA8L4C0G2J822J160KA CGA5L3C0G2E822J160AA CGA4J3C0G2E103J125AA CGA5H3C0G2E103J115AA CGA5L4C0G2J103J160AA CGA6J4C0G2J103J125AA CGA3E1C0G2A822J080AC CGA4J2C0G2A822J125AA CGA5H2C0G2A822J115AA CGA3E1C0G2A103J080AC CGA4J2C0G2A103J125AA CGA5H2C0G2A103J115AA CGA5L4C0G2W103J160AA CGA6L3C0G2E103J160AA CGA8L4C0G2J103J160KA CGA4F1C0G2A153J085AC CGA5H2C0G2A153J115AA CGA5L3C0G2E153J160AA CGA5L4C0G2W153J160AA CGA6J2C0G2A153J125AA CGA6L4C0G2J153J160AA CGA6M3C0G2E153J200AA CGA8P4C0G2J153J250KA CGA4J1C0G2A223J125AC CGA5L2C0G2A223J160AA CGA5L3C0G2E223J160AA CGA6L3C0G2E223J160AA CGA6N4C0G2J223J230AA CGA6L2C0G2A223J160AA CGA6N4C0G2W223J230AA CGA8L3C0G2E223J160KA CGA8R4C0G2J223J320KA CGA4J1C0G2A333J125AC CGA5L2C0G2A333J160AA CGA6M2C0G2A333J200AA CGA6N3C0G2E333J230AA CGA6P4C0G2J333J250AA CGA8M4C0G2J333J200KA CGA6P4C0G2W333J250AA CGA8M3C0G2E333J200KA CGA5H1C0G2A473J115AC CGA6N2C0G2A473J230AA CGA6P3C0G2E473J250AA CGA8M2C0G2A473J200KA CGA8N4C0G2W473J230KA CGA8R4C0G2J473J320KA CGA8R3C0G2E473J320KA CGA5L1C0G2A683J160AC CGA6N2C0G2A683J230AA CGA8N4C0G2E683J230KN CGA8P2C0G2A683J250KA CGA8R4C0G2W683J320KA CGA9N1C0G2J683J230KC CGA8R4C0G2E104J320KN CGA5L1C0G2A104J160AC CGA8R2C0G2A104J320KA CGA9N4C0G2E154J230KN CGA9N2C0G2A154J230KA CGA9Q1C0G2J104J280KC CGA9Q4C0G2W104J280KA Page 11 • All specifications are subject to change without notice. 20150309 / mlcc_automotive_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) Capacitance Size Thickness (mm) 1608 0.80 ± 0.10 3216 1.15 ± 0.15 1608 0.80 ± 0.10 3216 1.15 ± 0.15 1608 0.80 ± 0.10 3216 1.15 ± 0.15 1608 0.80 ± 0.10 3216 1.15 ± 0.15 1608 0.80 ± 0.10 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 1.25 ± 0.20 1 nF 1.5 nF 2.2 nF 3.3 nF 4.7 nF 6.8 nF 10 nF 15 nF 1.15 ± 0.15 3216 1.30 ± 0.20 22 nF 22 nF 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 1.15 ± 0.15 3216 1.30 ± 0.20 2012 1.25 ± 0.20 1.15 ± 0.15 33 nF 3216 1.60 ± 0.20 Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 450V Rated Voltage Edc: 250V Rated Voltage Edc: 100V CGA3E2X7R2A102K080AA CGA3E2X7R2A102M080AA CGA5H4X7R2J102K115AA CGA5H4X7R2J102M115AA CGA3E2X7R2A152K080AA CGA3E2X7R2A152M080AA CGA5H4X7R2J152K115AA CGA5H4X7R2J152M115AA CGA3E2X7R2A222K080AA CGA3E2X7R2A222M080AA CGA5H4X7R2J222K115AA CGA5H4X7R2J222M115AA CGA3E2X7R2A332K080AA CGA3E2X7R2A332M080AA CGA5H4X7R2J332K115AA CGA5H4X7R2J332M115AA CGA3E2X7R2A472K080AA CGA3E2X7R2A472M080AA CGA5H4X7R2J472K115AA CGA5H4X7R2J472M115AA CGA3E2X7R2A682K080AA CGA3E2X7R2A682M080AA CGA4J3X7R2E682K125AA CGA4J3X7R2E682M125AA CGA5H4X7R2J682K115AA CGA5H4X7R2J682M115AA CGA3E2X7R2A103K080AA CGA3E2X7R2A103M080AA CGA4J3X7R2E103K125AA CGA4J3X7R2E103M125AA CGA5H4X7R2J103K115AA CGA5H4X7R2J103M115AA CGA3E2X7R2A153K080AA CGA3E2X7R2A153M080AA CGA4J3X7R2E153K125AA CGA4J2X7R2A153K125AA CGA4J3X7R2E153M125AA CGA4J2X7R2A153M125AA CGA5H3X7R2E153K115AA CGA5H3X7R2E153M115AA CGA5K4X7R2J153K130AA CGA5K4X7R2J153M130AA CGA3E2X7R2A223K080AA CGA3E2X7R2A223M080AA CGA4J3X7R2E223K125AA CGA4J2X7R2A223K125AA CGA4J3X7R2E223M125AA CGA4J2X7R2A223M125AA CGA5H3X7R2E223K115AA CGA5H3X7R2E223M115AA CGA5K4X7R2J223K130AA CGA5K4X7R2J223M130AA CGA4J2X7R2A333K125AA CGA4J2X7R2A333M125AA CGA5H2X7R2A333K115AA CGA5H2X7R2A333M115AA CGA5L4X7R2J333K160AA CGA5L4X7R2J333M160AA CGA5L3X7R2E333K160AA CGA5L3X7R2E333M160AA Page 12 • All specifications are subject to change without notice. 20150309 / mlcc_automotive_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) Capacitance Size 2012 Thickness (mm) 1.25 ± 0.20 1.15 ± 0.15 47 nF 3216 1.60 ± 0.20 68 nF 3225 2.00 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 4532 1.60 ± 0.20 2012 1.25 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 4532 2.30 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 4532 1.60 ± 0.20 5750 1.60 ± 0.20 3216 1.15 ± 0.15 3225 2.00 ± 0.20 4532 2.30 ± 0.20 5750 2.30 ± 0.20 3216 1.30 ± 0.20 3225 2.00 ± 0.20 4532 2.30 ± 0.20 5750 1.60 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 4532 2.30 ± 0.20 5750 2.30 ± 0.20 100 nF 150 nF 220 nF 330 nF 470 nF Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 450V Rated Voltage Edc: 250V Rated Voltage Edc: 100V CGA4J2X7R2A473K125AA CGA4J2X7R2A473M125AA CGA5H2X7R2A473K115AA CGA5H2X7R2A473M115AA CGA5L3X7R2E473K160AA CGA5L3X7R2E473M160AA CGA6M4X7R2J473K200AA CGA6M4X7R2J473M200AA CGA5L3X7R2E683K160AA CGA5L2X7R2A683K160AA CGA5L3X7R2E683M160AA CGA5L2X7R2A683M160AA CGA6M4X7R2J683K200AA CGA6M4X7R2J683M200AA CGA8L4X7R2J683K160KA CGA8L4X7R2J683M160KA CGA4J2X7R2A104K125AA CGA4J2X7R2A104M125AA CGA5L3X7R2E104K160AA CGA5L2X7R2A104K160AA CGA5L3X7R2E104M160AA CGA5L2X7R2A104M160AA CGA6M3X7R2E104K200AA CGA6M3X7R2E104M200AA CGA8N4X7R2J104K230KA CGA8N4X7R2J104M230KA CGA5L2X7R2A154K160AA CGA5L2X7R2A154M160AA CGA6M3X7R2E154K200AA CGA6M3X7R2E154M200AA CGA8L3X7R2E154K160KA CGA8L3X7R2E154M160KA CGA9L4X7R2J154K160KA CGA9L4X7R2J154M160KA CGA5H2X7R2A224K115AA CGA5H2X7R2A224M115AA CGA6M3X7R2E224K200AA CGA6M3X7R2E224M200AA CGA8N3X7R2E224K230KA CGA8N3X7R2E224M230KA CGA9N4X7R2J224K230KA CGA9N4X7R2J224M230KA CGA5K2X7R2A334K130AA CGA5K2X7R2A334M130AA CGA6M2X7R2A334K200AA CGA6M2X7R2A334M200AA CGA8N3X7R2E334K230KA ± 20% CGA8N3X7R2E334M230KA ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% CGA9L3X7R2E334K160KA CGA9L3X7R2E334M160KA CGA5L2X7R2A474K160AA CGA5L2X7R2A474M160AA CGA6M2X7R2A474K200AA CGA6M2X7R2A474M200AA CGA8N3X7R2E474K230KA CGA8N3X7R2E474M230KA CGA9N3X7R2E474K230KA CGA9N3X7R2E474M230KA Page 13 • All specifications are subject to change without notice. 20150309 / mlcc_automotive_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) Capacitance Size Thickness (mm) 3216 1.60 ± 0.20 3225 1.60 ± 0.20 4532 2.30 ± 0.20 5750 2.30 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 4532 2.30 ± 0.20 5750 2.30 ± 0.20 3225 2.00 ± 0.20 4532 2.30 ± 0.20 5750 2.30 ± 0.20 3225 2.30 ± 0.20 4532 2.30 ± 0.20 5750 2.30 ± 0.20 3.3 μF 5750 2.30 ± 0.20 4.7 μF 5750 2.30 ± 0.20 680 nF 1 μF 1.5 μF 2.2 μF Capacitance Tolerance Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 450V ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Rated Voltage Edc: 250V CGA9N3X7R2E684K230KA CGA9N3X7R2E684M230KA CGA9N3X7R2E105K230KA CGA9N3X7R2E105M230KA Rated Voltage Edc: 100V CGA5L2X7R2A684K160AA CGA5L2X7R2A684M160AA CGA6L2X7R2A684K160AA CGA6L2X7R2A684M160AA CGA8N2X7R2A684K230KA CGA8N2X7R2A684M230KA CGA9L2X7R2A684K160KA CGA9L2X7R2A684M160KA CGA5L2X7R2A105K160AA CGA5L2X7R2A105M160AA CGA6M2X7R2A105K200AA CGA6M2X7R2A105M200AA CGA8N2X7R2A105K230KA CGA8N2X7R2A105M230KA CGA9N2X7R2A105K230KA CGA9N2X7R2A105M230KA CGA6M3X7R2A155K200AB CGA6M3X7R2A155M200AB CGA8N2X7R2A155K230KA CGA8N2X7R2A155M230KA CGA9N2X7R2A155K230KA CGA9N2X7R2A155M230KA CGA6N3X7R2A225K230AB CGA6N3X7R2A225M230AB CGA8N2X7R2A225K230KA CGA8N2X7R2A225M230KA CGA9N2X7R2A225K230KA CGA9N2X7R2A225M230KA CGA9N2X7R2A335K230KA CGA9N2X7R2A335M230KA CGA9N2X7R2A475K230KA CGA9N2X7R2A475M230KA Page 14 • All specifications are subject to change without notice. 20150309 / mlcc_automotive_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X7S (-55 to +125ºC, ±22%) Capacitance Size Thickness (mm) 1 nF 1005 0.50 ± 0.05 1.5 nF 1005 0.50 ± 0.05 2.2 nF 1005 0.50 ± 0.05 3.3 nF 1005 0.50 ± 0.05 4.7 nF 1005 0.50 ± 0.05 6.8 nF 1005 0.50 ± 0.05 10 nF 1005 0.50 ± 0.05 33 nF 1608 0.80 ± 0.10 47 nF 1608 0.80 ± 0.10 68 nF 1608 0.80 ± 0.10 100 nF 1608 0.80 ± 0.10 330 nF 2012 1.25 ± 0.20 470 nF 2012 1.25 ± 0.20 680 nF 2012 1.25 ± 0.20 1 μF 2012 1.25 ± 0.20 1.5 μF 3216 1.60 ± 0.20 2.2 μF 3216 1.60 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 4532 2.00 ± 0.20 3225 2.00 ± 0.20 4532 2.30 ± 0.20 6.8 μF 5750 2.00 ± 0.20 10 μF 5750 2.30 ± 0.20 15 μF 5750 2.50 ± 0.30 3.3 μF 4.7 μF Capacitance Tolerance Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 450V ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 20% Rated Voltage Edc: 250V Rated Voltage Edc: 100V CGA2B3X7S2A102K050BB CGA2B3X7S2A102M050BB CGA2B3X7S2A152K050BB CGA2B3X7S2A152M050BB CGA2B3X7S2A222K050BB CGA2B3X7S2A222M050BB CGA2B3X7S2A332K050BB CGA2B3X7S2A332M050BB CGA2B3X7S2A472K050BB CGA2B3X7S2A472M050BB CGA2B3X7S2A682K050BB CGA2B3X7S2A682M050BB CGA2B3X7S2A103K050BB CGA2B3X7S2A103M050BB CGA3E3X7S2A333K080AB CGA3E3X7S2A333M080AB CGA3E3X7S2A473K080AB CGA3E3X7S2A473M080AB CGA3E3X7S2A683K080AB CGA3E3X7S2A683M080AB CGA3E3X7S2A104K080AB CGA3E3X7S2A104M080AB CGA4J3X7S2A334K125AB CGA4J3X7S2A334M125AB CGA4J3X7S2A474K125AB CGA4J3X7S2A474M125AB CGA4J3X7S2A684K125AB CGA4J3X7S2A684M125AB CGA4J3X7S2A105K125AB CGA4J3X7S2A105M125AB CGA5L3X7S2A155K160AB CGA5L3X7S2A155M160AB CGA5L3X7S2A225K160AB CGA5L3X7S2A225M160AB CGA5L3X7S2A335K160AB CGA5L3X7S2A335M160AB CGA6M3X7S2A335K200AB CGA6M3X7S2A335M200AB CGA8M3X7S2A335K200KB CGA8M3X7S2A335M200KB CGA6M3X7S2A475K200AB CGA6M3X7S2A475M200AB CGA8N3X7S2A475K230KB CGA8N3X7S2A475M230KB CGA9M3X7S2A685K200KB CGA9M3X7S2A685M200KB CGA9N3X7S2A106K230KB CGA9N3X7S2A106M230KB CGA9P3X7S2A156M250KB Page 15 • All specifications are subject to change without notice. 20150309 / mlcc_automotive_midvoltage_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X7T (-55 to +125ºC, +22/-33%) Capacitance Size Thickness (mm) 2012 1.25 ± 0.20 3216 1.15 ± 0.15 2012 1.25 ± 0.20 3216 1.15 ± 0.15 2012 1.25 ± 0.20 3216 1.60 ± 0.20 2012 1.25 ± 0.20 3216 1.30 ± 0.20 2012 1.25 ± 0.20 3216 1.60 ± 0.20 3225 1.60 ± 0.20 3216 1.30 ± 0.20 3225 2.00 ± 0.20 4532 1.60 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 4532 2.00 ± 0.20 3225 2.00 ± 0.20 4532 1.60 ± 0.20 5750 2.00 ± 0.20 4532 2.30 ± 0.20 5750 2.50 ± 0.30 4532 1.60 ± 0.20 5750 2.00 ± 0.20 4532 2.50 ± 0.30 5750 2.50 ± 0.30 1.5 μF 5750 2.00 ± 0.20 2.2 μF 5750 2.50 ± 0.30 22 nF 33 nF 47 nF 68 nF 100 nF 150 nF 220 nF 330 nF 470 nF 680 nF 1 μF Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 630V Rated Voltage Edc: 450V CGA4J4X7T2W223K125AA CGA4J4X7T2W223M125AA Rated Voltage Edc: 250V CGA4J4X7T2W333K125AA CGA4J4X7T2W333M125AA CGA4J3X7T2E333K125AA CGA4J3X7T2E333M125AA CGA4J4X7T2W473K125AA CGA4J4X7T2W473M125AA CGA4J3X7T2E473K125AA CGA4J3X7T2E473M125AA Rated Voltage Edc: 100V CGA5H1X7T2J223K115AC CGA5H1X7T2J223M115AC CGA5H1X7T2J333K115AC CGA5H1X7T2J333M115AC CGA5L1X7T2J473K160AC CGA5L1X7T2J473M160AC CGA4J3X7T2E683K125AA CGA4J3X7T2E683M125AA CGA5K4X7T2W683K130AA CGA5K4X7T2W683M130AA CGA4J3X7T2E104K125AA CGA4J3X7T2E104M125AA CGA5L4X7T2W104K160AA CGA5L4X7T2W104M160AA CGA6L1X7T2J104K160AC CGA6L1X7T2J104M160AC CGA5K3X7T2E154K130AA CGA5K3X7T2E154M130AA CGA6M1X7T2J154K200AC CGA6M1X7T2J154M200AC CGA8L1X7T2J154K160KC CGA8L1X7T2J154M160KC CGA5L3X7T2E224K160AA CGA5L3X7T2E224M160AA CGA6M4X7T2W224K200AA CGA6M4X7T2W224M200AA CGA8M1X7T2J224K200KC CGA8M1X7T2J224M200KC CGA6M3X7T2E334K200AA CGA6M3X7T2E334M200AA CGA8L4X7T2W334K160KA CGA8L4X7T2W334M160KA CGA9M1X7T2J334K200KC CGA9M1X7T2J334M200KC CGA8N4X7T2W474K230KA CGA8N4X7T2W474M230KA CGA9P1X7T2J474K250KC CGA9P1X7T2J474M250KC CGA8L3X7T2E684K160KA CGA8L3X7T2E684M160KA CGA9M4X7T2W684K200KA CGA9M4X7T2W684M200KA CGA8P3X7T2E105K250KA CGA8P3X7T2E105M250KA CGA9P4X7T2W105K250KA CGA9P4X7T2W105M250KA CGA9M3X7T2E155K200KA CGA9M3X7T2E155M200KA CGA9P3X7T2E225K250KA CGA9P3X7T2E225M250KA Page 16 • All specifications are subject to change without notice. 20150309 / mlcc_automotive_midvoltage_en
物料型号: - TDK的多层陶瓷片式电容器,CGA系列,包括CGA2至CGA9型号,对应不同的EIA标准尺寸。
器件简介: - 这些电容器是汽车级中压产品,电压等级从100V至630V,电容范围可达15μF,适用于混合动力和电动汽车的逆变器或DC-DC转换器的去耦、平滑和缓冲电路。
引脚分配: - 根据封装类型,文档提供了详细的尺寸数据,包括长度、宽度、端头宽度和端头间距。
参数特性: - 电容公差、温度特性(如COG、X7R、X7S、X7T)、额定电压(如2A、2E、2W、2J)等参数均有详细说明。
功能详解: - 产品特性包括低残余电感、优秀的直流偏置特性、耐电压浪涌和噪声等。
应用信息: - 主要应用于汽车电子领域,特别是在混合动力和电动汽车的电源管理系统中。
封装信息: - 提供了不同尺寸的封装信息,包括厚度和包装样式,符合AEC-Q200标准。
CGA5F1X7T2J153K085AC 价格&库存
很抱歉,暂时无法提供与“CGA5F1X7T2J153K085AC”相匹配的价格&库存,您可以联系我们找货
