CGA5L3X7R1H225M160AE
    TDK(东电化)
    2.2UF ±20% 50V
CGA5L3X7R1H225M160AE 数据手册
June 2016 MULTILAYER CERAMIC CHIP CAPACITORS CGA Series Automotive Grade Soft Termination Type: CGA2 [EIA CC0402] CGA3 [EIA CC0603] CGA4 [EIA CC0805] CGA5 [EIA CC1206] CGA6 [EIA CC1210] CGA7 [EIA CC1808] CGA8 [EIA CC1812] CGA9 [EIA CC2220] (1/1) MULTILAYER CERAMIC CHIP CAPACITORS REMINDERS Please read before using this product SAFETY REMINDERS REMINDERS 1. If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other damage, 2. We may modify products or discontinue production of a product listed in this catalog without prior notification. 3. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product you must contact our company’s sales window. listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. 4. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item accordingto the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire exportpermission in harmony with this law. 5. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. 6. We are not responsible for problems that occur related to the intellectual property rights or other rights of our 7. This catalog only applies to products purchased through our company or one of our company’s official agencies. company or a third party when you use a product listed in this catalog. We do not grant license of these rights. This catalog does not apply to products that are purchased through other third parties. Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging specification detail. This new catalog number should be referenced on all catalog orders going forward, and is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will differ from the item description (internal control number) on the product label. Contact your local TDK Sales representative for more information. (Example) Catalog Issued date Prior to January 2013 January 2013 and Later Catalog Number C1608C0G1E103J(080AA) C1608C0G1E103J080AA Item Description (On Delivery Label) C1608C0G1E103JT000N C1608C0G1E103JT000N 20160602 / mlcc_reminders.fm (1/12) MULTILAYER CERAMIC CHIP CAPACITORS Pb Lead Free CGA Series RoHS COMPLIANT Ecological Soft Termination Type: CGA2 [EIA CC0402], CGA3 [EIA CC0603], CGA4 [EIA CC0805], CGA5 [EIA CC1206], CGA6 [EIA CC1210], CGA7 [EIA CC1808], CGA8 [EIA CC1812], CGA9 [EIA CC2220] Features • Improved board bending resistance, drop impact resistance, thermal shock resistance, and heat cycle properties. • Conductive resin absorb external stress to protect solder joint parts and capacitor body. • Compliance with the RoHS Directive. • AEC-Q200 compliant. Standard Product Soft Termination • • • • Applications Switching power supply Telecom base station Electronic circuits mounted on alumina substrate SMT application which requires bending robustness in which solder joint reliability is problematic Shape & Dimensions L Body Length W Body Width T Body Height Terminal Width Terminal Spacing B G Catalog Number Construction CGA 6 P 3 X7S 1H 106 K 250 A E Series Name Dimensions L x W (mm) Code 2 3 4 5 6 7 8 9 Length 1.00 + 0.15/-0.05 1.60 + 0.20/-0.10 2.00 + 0.45/-0.20 3.20 + 0.40/-0.20 3.20 + 0.50/-0.40 4.50 + 0.30/-0.20 4.50 + 0.50/-0.40 5.70 + 0.50/-0.40 Width 0.50 + 0.10/-0.05 0.80 + 0.15/-0.10 1.25 + 0.25/-0.20 1.60 + 0.30/-0.20 2.50 ± 0.30 2.00 ± 0.15 3.20 ± 0.40 5.00 ± 0.40 Terminal 0.10 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. *Dimension tolerance are typical values Thickness T Code (mm) Code B E F H J K L M N P Voltage Condition for Life Test Thickness 0.50 mm 0.80 mm 0.85 mm 1.15 mm 1.25 mm 1.30 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm Symbol 1 2 3 4 Condition 1 × R.V. 2 × R.V. 1.5 × R.V. 1.2 × R.V. Temperature Characteristics Temperature Characteristics C0G X7R X7S X7T X8R Temperature Coefficient or Capacitance Change 0 ±30ppm/°C ±15% ±22% +22/-33% ±15% Temperature Range -55 to +125°C -55 to +125°C -55 to +125°C -55 to +125°C -55 to +150°C Nominal Capacitance (pF) Rated Voltage (DC) Code Voltage (DC) 6.3V 0J 10V 1A 16V 1C 25V 1E 35V 1V 50V 1H 100V 2A The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. Code 2E 2W 2J 3A 3D 3F Capacitance Tolerance Ex. 0R2 = 0.2pF; 103 = 10,000pF; 105 = 1,000,000pF = 1,000nF = 1 Nominal Thickness Code 050 080 085 115 125 Thickness 0.50mm 0.80mm 0.85mm 1.15mm 1.25mm Code 130 160 200 230 250 Thickness 1.30mm 1.60mm 2.00mm 2.30mm 2.50mm Voltage (DC) 250V 450V 630V 1000V 2000V 3000V Code J K M Tolerance ± 5% ± 10% ± 20% Packaging Style Code Style A 178mm Reel, 4mm Pitch B 178mm Reel, 2mm Pitch K 178mm Reel, 8mm Pitch Special Reserved Code Code E Description Soft Termination *See Thickness T Code for complete list Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160602 / mlcc_automotive_soft_en.fm (2/12) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA2(1005) [EIA CC0402] Capacitance Range Chart   Temperature Characteristics : C0G (0±30 ppm/℃), X7R (±15%), X7S (±22%), X8R (±15%)   Rated Voltage : 100V (2A), 50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A) Capacitance C0G Tolerance (pF) 100 150 220 330 470 680 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 100,000 220,000 470,000 Code 101 151 221 331 471 681 102 152 222 332 472 682 103 153 223 333 473 104 224 474 1H (50V) X7R 1H (50V) 1V (35V) 1E (25V) X7S 1C (16V) 1C (16V) X8R 1A 2A 1H (10V) (100V) (50V) 1E (25V) 1C (16V) J: ±5% K: ±10% M: ±20% 0.50 mm Standard Thickness   Capacitance Range Chart CGA3(1608) [EIA CC0603] Capacitance Range Chart   Temperature Characteristics : C0G (0±30 ppm/℃), X7R (±15%), X7S (±22%), X8R (±15%)   Rated Voltage : 100V (2A), 50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A) Capacitance C0G Tolerance (pF) 100 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 1,000,000 2,200,000 Code 101 102 152 222 332 472 682 103 153 223 333 473 683 104 154 224 334 474 105 225 Standard Thickness   X7R 1H 2A 1H (50V) (100V) (50V) 1V (35V) X7S 1E 2A 1C (25V) (100V) (16V) X8R 1A 2A 1H (10V) (100V) (50V) 1E (25V) 1C (16V) J: ±5% K: ±10% M: ±20% 0.80 mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160602 / mlcc_automotive_soft_en.fm (3/12) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA4(2012) [EIA CC0805] Capacitance Range Chart   Temperature Characteristics : X7R (±15%), X7S (±22%)   Rated Voltage : 250V (2E), 100V (2A), 50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A) Capacitance X7R Tolerance (pF) 1,000 2,200 4,700 10,000 22,000 47,000 100,000 220,000 470,000 1,000,000 2,200,000 4,700,000 10,000,000 Code 102 222 472 103 223 473 104 224 474 105 225 475 106 2E 2A 1H (250V) (100V) (50V) X7S 1V (35V) 1E (25V) 1C 2A 1C (16V) (100V) (16V) 1A (10V) K: ±10% M: ±20% Standard Thickness 0.85 mm 1.25 mm Capacitance Range Chart   Temperature Characteristics : X7T (+22/-33%), X8R (±15%)   Rated Voltage : 450V (2W), 250V (2E), 100V (2A), 50V (1H), 25V (1E), 16V (1C) Capacitance X7T Tolerance (pF) 10,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 Code 103 223 333 473 683 104 154 224 334 474 684 105 X8R 2W 2E 2A 1H (450V) (250V) (100V) (50V) 1E (25V) 1C (16V) K: ±10% M: ±20% Standard Thickness 0.85 mm 1.25 mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160602 / mlcc_automotive_soft_en.fm (4/12) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA5(3216) [EIA CC1206] Capacitance Range Chart   Temperature Characteristics : X7R (±15%), X7S (±22%)   Rated Voltage : 630V (2J), 250V (2E), 100V (2A), 50V (1H), 35V (1V), 25V (1E), 6.3V (0J) Capacitance X7R Tolerance (pF) 1,000 2,200 3,300 4,700 10,000 22,000 33,000 47,000 100,000 220,000 470,000 1,000,000 2,200,000 4,700,000 10,000,000 22,000,000 Code 102 222 332 472 103 223 333 473 104 224 474 105 225 475 106 226 2J 2E 2A 1H (630V) (250V) (100V) (50V) X7S 1V (35V) 1E (25V) 0J 2A (6.3V) (100V) K: ±10% M: ±20% Standard Thickness 1.15 mm  1.30 mm  1.60 mm M: ±20% Capacitance Range Chart   Temperature Characteristics : X7T (+22/-33%), X8R (±15%)   Rated Voltage : 630V (2J), 450V (2W), 250V (2E), 100V (2A), 50V (1H), 25V (1E), 16V (1C) Capacitance X7T Tolerance (pF) 47,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 Code 473 104 154 224 334 474 684 105 155 225 335 475 X8R 2E 2A 1H 2J 2W (630V) (450V) (250V) (100V) (50V) 1E (25V) 1C (16V) K: ±10% M: ±20% Standard Thickness 1.15 mm 1.60 mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160602 / mlcc_automotive_soft_en.fm (5/12) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA6(3225) [EIA CC1210] Capacitance Range Chart   Temperature Characteristics : X7R (±15%), X7S (±22%), X7T (+22/-33%), X8R (±15%)   Rated Voltage : 630V (2J), 450V (2W), 250V (2E), 100V (2A), 50V (1H), 25V (1E) Capacitance X7R Tolerance (pF) 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 2,200,000 3,300,000 4,700,000 10,000,000 Code 473 683 104 154 224 334 474 684 105 225 335 475 106 X7S X7T X8R 2E 2A 2J 2E 2A 1H 2A 1H 2J 2W 1E (630V) (250V) (100V) (50V) (100V) (50V) (630V) (450V) (250V) (100V) (25V) K: ±10% M: ±20% Standard Thickness   1.60 mm  2.00 mm  2.30 mm  Capacitance Range Chart 2.50 mm CGA7(4520) [EIA CC1808] Capacitance Range Chart   Temperature Characteristics : X7R (±15%)   Rated Voltage : 2000V (3D) Capacitance X7R Tolerance (pF) 1,000 Code 102 3D (2000V) K: ± 10% M: ± 20% Standard Thickness 1.30 mm Capacitance Range Chart CGA8(4532) [EIA CC1812] Capacitance Range Chart   Temperature Characteristics : C0G (0 ± 30ppm/℃) , X7R (±15%), X7T (+22/-33%)   Rated Voltage : 3000V (3F), 2000V (3D), 630V (2J), 450V (2W), 250V (2E) Capacitance C0G Tolerance (pF) 330 2,200 100,000 220,000 470,000 1,000,000 Code 331 222 104 224 474 105 K: ± 10% K: ± 10% M: ± 20% X7R X7T 3F 3D 2J 2E 2J 2W 2E (3000V) (2000V) (630V) (250V) (630V) (450V) (250V) Standard Thickness 1.30 mm 2.00 mm 2.30 mm 2.50 mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160602 / mlcc_automotive_soft_en.fm (6/12) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA9(5750) [EIA CC2220] Capacitance Range Chart   Temperature Characteristics : X7R (±15%), X7S (±22%), X7T (+22/-33%)   Rated Voltage : 630V (2J), 450V (2W), 250V (2E), 100V (2A) Capacitance X7R Tolerance (pF) 220,000 470,000 1,000,000 2,200,000 10,000,000 Code 224 474 105 225 106 K: ± 10% M: ± 20% X7S X7T 2J 2E 2A 2J 2W 2E (630V) (250V) (100V) (630V) (450V) (250V) Standard Thickness 2.30 mm 2.50 mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160602 / mlcc_automotive_soft_en.fm (7/12) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating)  Temperature Characteristics:C0G(-55 to +125℃, 0 ± 30 ppm/℃) Capacitance 100pF 330pF Size Thickness (mm) Capacitance Tolerance 1005 0.50+0.10/-0.05 1608 4532 0.80+0.15/-0.10 2.50 ± 0.20 ±5% ±5% ±10% Catalog Number Rated Voltage Edc:3000V Rated Voltage Edc:50V CGA2B2C0G1H101J050BE CGA3E2C0G1H101J080AE CGA8P1C0G3F331K250KE Class 2 (Temperature Stable)  Temperature Characteristics:X7R(-55 to +125℃, ±15%) Capacitance 1nF 2.2nF 3.3nF Size Thickness (mm) 1005 0.50+0.10/-0.05 1608 0.80 +0.15/-0.10 2012 0.85±0.15 3216 1.15±0.15 4520 1.30±0.15 1005 0.50+0.10/-0.05 1608 0.80+0.15/-0.10 2012 0.85±0.15 3216 1.15±0.15 4532 1.30±0.15 3216 1.15±0.15 1005 0.50+0.10/-0.05 1608 0.80+0.15/-0.10 2012 0.85±0.15 3216 1.15±0.15 1005 0.50+0.10/-0.05 1608 0.80 +0.15/-0.10 4.7nF 10nF 0.85±0.15 2012 1.25 +0.25/-0.20 22nF 3216 1.15±0.15 1005 0.50+0.10/-0.05 1608 0.80+0.15/-0.10 2012 1.25 +0.25/-0.20 1.15±0.15 3216 1.30±0.20 33nF 3216 1.60+0.30/-0.20 Catalog Number Capacitance Tolerance Rated Voltage Edc:2000V Rated Voltage Edc:630V ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Rated Voltage Edc:250V Rated Voltage Edc:100V Rated Voltage Edc:50V CGA2B2X7R1H102K050BE CGA2B2X7R1H102M050BE CGA3E2X7R2A102K080AE CGA3E2X7R1H102K080AE CGA3E2X7R2A102M080AE CGA3E2X7R1H102M080AE CGA4F3X7R2E102K085AE CGA4F2X7R2A102K085AE CGA4F3X7R2E102M085AE CGA4F2X7R2A102M085AE CGA5H4X7R2J102K115AE CGA5H4X7R2J102M115AE CGA7K1X7R3D102K130KE CGA7K1X7R3D102M130KE CGA2B2X7R1H222K050BE CGA2B2X7R1H222M050BE CGA3E2X7R2A222K080AE CGA3E2X7R1H222K080AE CGA3E2X7R2A222M080AE CGA3E2X7R1H222M080AE CGA4F3X7R2E222K085AE CGA4F2X7R2A222K085AE CGA4F3X7R2E222M085AE CGA4F2X7R2A222M085AE CGA5H4X7R2J222K115AE CGA5H4X7R2J222M115AE CGA8K1X7R3D222K130KE CGA8K1X7R3D222M130KE CGA5H4X7R2J332K115AE CGA5H4X7R2J332M115AE CGA2B2X7R1H472K050BE CGA2B2X7R1H472M050BE CGA3E2X7R2A472K080AE CGA3E2X7R1H472K080AE CGA3E2X7R2A472M080AE CGA3E2X7R1H472M080AE CGA4F3X7R2E472K085AE CGA4F2X7R2A472K085AE CGA4F3X7R2E472M085AE CGA4F2X7R2A472M085AE CGA5H4X7R2J472K115AE CGA5H4X7R2J472M115AE CGA2B3X7R1H103K050BE CGA2B3X7R1H103M050BE CGA3E2X7R2A103K080AE CGA3E2X7R1H103K080AE CGA3E2X7R2A103M080AE CGA3E2X7R1H103M080AE CGA4F2X7R2A103K085AE CGA4F2X7R2A103M085AE CGA4J3X7R2E103K125AE CGA4J3X7R2E103M125AE CGA5H4X7R2J103K115AE CGA5H4X7R2J103M115AE CGA2B3X7R1H223K050BE CGA2B3X7R1H223M050BE CGA3E2X7R2A223K080AE CGA3E2X7R1H223K080AE CGA3E2X7R2A223M080AE CGA3E2X7R1H223M080AE CGA4J3X7R2E223K125AE CGA4J2X7R2A223K125AE CGA4J3X7R2E223M125AE CGA4J2X7R2A223M125AE CGA5H3X7R2E223K115AE CGA5H3X7R2E223M115AE CGA5K4X7R2J223K130AE CGA5K4X7R2J223M130AE CGA5L4X7R2J333K160AE CGA5L4X7R2J333M160AE Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160602 / mlcc_automotive_soft_en.fm (8/12) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable)  Temperature Characteristics:X7R(-55 to +125℃, ±15%) Capacitance 47nF 68nF Size Thickness (mm) 1005 0.50+0.10/-0.05 1608 0.80+0.15/-0.10 2012 1.25+0.25/-0.20 3216 1.60+0.30/-0.20 3225 2.00 +0.30/-0.20 3225 2.00+0.30/-0.20 1005 0.50+0.10/-0.05 1608 0.80 +0.15/-0.10 2012 1.25 +0.25/-0.20 3216 1.60 +0.30/-0.20 3225 2.00 +0.30/-0.20 4532 2.30+0.30/-0.20 1608 0.80+0.15/-0.10 2012 1.25+0.25/-0.20 3216 1.15±0.15 3225 2.00 +0.30/-0.20 5750 2.30+0.30/-0.20 1608 0.80 +0.15/-0.10 2012 1.25 +0.25/-0.20 3216 1.60 +0.30/-0.20 3225 2.00+0.30/-0.20 4532 2.30 +0.30/-0.20 2012 1.25 +0.25/-0.20 3216 1.60 +0.30/-0.20 100nF 220nF 470nF 1μF 1.60 +0.30/-0.20 3225 2.00+0.30/-0.20 5750 2.30 +0.30/-0.20 2012 1.25 +0.25/-0.20 3216 1.60 +0.30/-0.20 2.2μF 2.00+0.30/-0.20 3225 2.30 +0.30/-0.20 4.7μF 3216 1.60 +0.30/-0.20 Catalog Number Capacitance Tolerance Rated Voltage Edc:630V ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Rated Voltage Edc:250V Rated Voltage Edc:100V Rated Voltage Edc:50V CGA2B3X7R1H473K050BE CGA2B3X7R1H473M050BE CGA3E2X7R1H473K080AE CGA3E2X7R1H473M080AE CGA4J2X7R2A473K125AE CGA4J2X7R2A473M125AE CGA5L3X7R2E473K160AE CGA5L3X7R2E473M160AE CGA6M4X7R2J473K200AE CGA6M4X7R2J473M200AE CGA6M4X7R2J683K200AE CGA6M4X7R2J683M200AE CGA2B3X7R1H104K050BE CGA2B3X7R1H104M050BE CGA3E2X7R1H104K080AE CGA3E2X7R1H104M080AE CGA4J2X7R2A104K125AE CGA4J2X7R1H104K125AE CGA4J2X7R2A104M125AE CGA4J2X7R1H104M125AE CGA5L3X7R2E104K160AE CGA5L2X7R2A104K160AE CGA5L3X7R2E104M160AE CGA5L2X7R2A104M160AE CGA6M3X7R2E104K200AE CGA6M3X7R2E104M200AE CGA8N4X7R2J104K230KE CGA8N4X7R2J104M230KE CGA3E3X7R1H224K080AE CGA3E3X7R1H224M080AE CGA4J2X7R1H224K125AE CGA4J2X7R1H224M125AE CGA5H2X7R2A224K115AE CGA5H2X7R2A224M115AE CGA6M3X7R2E224K200AE CGA6M3X7R2E224M200AE CGA9N4X7R2J224K230KE CGA9N4X7R2J224M230KE CGA3E3X7R1H474K080AE CGA3E3X7R1H474M080AE CGA4J3X7R1H474K125AE CGA4J3X7R1H474M125AE CGA5L2X7R2A474K160AE CGA5L2X7R2A474M160AE CGA6M2X7R2A474K200AE CGA6M2X7R2A474M200AE CGA8N3X7R2E474K230KE CGA8N3X7R2E474M230KE CGA4J3X7R1H105K125AE CGA4J3X7R1H105M125AE CGA5L2X7R2A105K160AE CGA5L3X7R1H105K160AE CGA5L2X7R2A105M160AE CGA5L3X7R1H105M160AE CGA6L2X7R1H105K160AE CGA6L2X7R1H105M160AE CGA6M2X7R2A105K200AE CGA6M2X7R2A105M200AE CGA9N3X7R2E105K230KE CGA9N3X7R2E105M230KE CGA4J3X7R1H225K125AE CGA4J3X7R1H225M125AE CGA5L3X7R1H225K160AE CGA5L3X7R1H225M160AE CGA6M3X7R1H225K200AE CGA6M3X7R1H225M200AE CGA6N3X7R2A225K230AE CGA6N3X7R2A225M230AE CGA5L3X7R1H475K160AE CGA5L3X7R1H475M160AE Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160602 / mlcc_automotive_soft_en.fm (9/12) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable)  Temperature Characteristics:X7R(-55 to +125℃, ±15%) Size Thickness (mm) 1005 0.50+0.10/-0.05 1608 0.80+0.15/-0.10 1608 0.80+0.15/-0.10 1608 0.80+0.15/-0.10 2012 1.25+0.25/-0.20 2012 1.25 +0.25/-0.20 3216 1.60+0.30/-0.20 2012 1.25 +0.25/-0.20 3216 1.60 +0.30/-0.20 10μF 3216 1.60 +0.30/-0.20 22μF 3216 1.60+0.30/-0.20 Capacitance 220nF 470nF 1μF 2.2μF 4.7μF Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% Catalog Number Rated Voltage Edc:35V CGA2B1X7R1V224K050BE CGA2B1X7R1V224M050BE CGA3E3X7R1V224K080AE CGA3E3X7R1V224M080AE CGA3E1X7R1V474K080AE CGA3E1X7R1V474M080AE CGA3E1X7R1V105K080AE CGA3E1X7R1V105M080AE CGA4J3X7R1V105K125AE CGA4J3X7R1V105M125AE CGA4J1X7R1V225K125AE CGA4J1X7R1V225M125AE CGA5L3X7R1V225K160AE CGA5L3X7R1V225M160AE CGA4J1X7R1V475K125AE CGA4J1X7R1V475M125AE CGA5L1X7R1V475K160AE CGA5L1X7R1V475M160AE CGA5L1X7R1V106K160AE CGA5L1X7R1V106M160AE Rated Voltage Edc:25V CGA2B3X7R1E224K050BE CGA2B3X7R1E224M050BE Rated Voltage Edc:16V CGA2B2X7R1C224K050BE CGA2B2X7R1C224M050BE Rated Voltage Edc:6.3V CGA3E3X7R1E474K080AE CGA3E3X7R1E474M080AE CGA3E1X7R1E105K080AE CGA3E1X7R1E105M080AE CGA4J3X7R1E225K125AE CGA4J3X7R1E225M125AE CGA5L2X7R1E225K160AE CGA5L2X7R1E225M160AE CGA4J1X7R1E475K125AE CGA4J1X7R1E475M125AE CGA4J3X7R1C475K125AE CGA4J3X7R1C475M125AE CGA5L1X7R1E106K160AE CGA5L1X7R1E106M160AE CGA5L1X7R0J226M160AE Class 2 (Temperature Stable)  Temperature Characteristics:X7S (-55 to +125℃, ±22%) Capacitance Size Thickness (mm) 47nF 1608 0.80+0.15/-0.10 100nF 1608 0.80+0.15/-0.10 220nF 2012 0.85±0.15 1005 0.50+0.10/-0.05 2012 1.25 +0.25/-0.20 2012 1.25 +0.25/-0.20 1608 0.80+0.15/-0.10 3216 1.60 +0.30/-0.20 3.3μF 3225 2.00+0.30/-0.20 4.7μF 3225 470nF 1μF 2.2μF 2.00 +0.30/-0.20 2.30 +0.30/-0.20 10μF 2012 1.25+0.25/-0.20 3225 2.50±0.30 5750 2.30 +0.30/-0.20 Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Catalog Number Rated Voltage Edc:100V CGA3E3X7S2A473K080AE CGA3E3X7S2A473M080AE CGA3E3X7S2A104K080AE CGA3E3X7S2A104M080AE CGA4F3X7S2A224K085AE CGA4F3X7S2A224M085AE Rated Voltage Edc:50V Rated Voltage Edc:16V Rated Voltage Edc:10V CGA2B1X7S1C474K050BE CGA2B1X7S1C474M050BE CGA2B3X7S1A474K050BE CGA2B3X7S1A474M050BE CGA3E1X7S1C225K080AE CGA3E1X7S1C225M080AE CGA3E3X7S1A225K080AE CGA3E3X7S1A225M080AE CGA4J1X7S1C106K125AE CGA4J1X7S1C106M125AE CGA4J3X7S1A106K125AE CGA4J3X7S1A106M125AE CGA4J3X7S2A474K125AE CGA4J3X7S2A474M125AE CGA4J3X7S2A105K125AE CGA4J3X7S2A105M125AE CGA5L3X7S2A225K160AE CGA5L3X7S2A225M160AE CGA6M3X7S2A335K200AE CGA6M3X7S2A335M200AE CGA6M3X7S2A475K200AE CGA6M3X7S2A475M200AE CGA6N3X7S1H475K230AE CGA6N3X7S1H475M230AE CGA6P3X7S1H106K250AE CGA6P3X7S1H106M250AE CGA9N3X7S2A106K230KE CGA9N3X7S2A106M230KE Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160602 / mlcc_automotive_soft_en.fm (10/12) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable)  Temperature Characteristics:X7T (-55 to +125℃, +22/-33%) Capacitance Size Thickness (mm) 10 nF 2012 0.85 ± 0.15 22 nF 2012 1.25 +0.25/-0.20 2012 1.25 +0.25/-0.20 3216 1.60 +0.30/-0.20 2012 1.25 +0.25/-0.20 3216 1.60 +0.30/-0.20 3225 1.60 +0.30/-0.20 3225 2.00+0.30/-0.20 3216 1.60 +0.30/-0.20 3225 2.00 +0.30/-0.20 4532 2.00 +0.30/-0.20 3225 2.00+0.30/-0.20 4532 2.30 +0.30/-0.20 5750 2.50 ± 0.30 4532 2.50 ± 0.30 5750 2.50 ± 0.30 5750 2.50 ± 0.30 47 nF 100 nF 150nF 220 nF 330nF 470 nF 1 μF 2.2 uF Catalog Number Capacitance Tolerance Rated Voltage Edc:630V ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ±10% CGA6L1X7T2J104K160AE CGA6L1X7T2J104M160AE CGA6M1X7T2J154K200AE ±20% CGA6M1X7T2J154M200AE ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ±10% ±20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Rated Voltage Edc:450V Rated Voltage Edc:250V CGA4F4X7T2W103K085AE CGA4F4X7T2W103M085AE CGA4J4X7T2W223K125AE CGA4J4X7T2W223M125AE CGA4J4X7T2W473K125AE CGA4J3X7T2E473K125AE CGA4J4X7T2W473M125AE CGA4J3X7T2E473M125AE CGA5L1X7T2J473K160AE CGA5L1X7T2J473M160AE CGA4J3X7T2E104K125AE CGA4J3X7T2E104M125AE CGA5L4X7T2W104K160AE CGA5L4X7T2W104M160AE CGA5L3X7T2E224K160AE CGA5L3X7T2E224M160AE CGA6M4X7T2W224K200AE CGA6M4X7T2W224M200AE CGA8M1X7T2J224K200KE CGA8M1X7T2J224M200KE CGA6M3X7T2E334K200AE CGA6M3X7T2E334M200AE CGA8N4X7T2W474K230KE CGA8N4X7T2W474M230KE CGA9P1X7T2J474K250KE CGA9P1X7T2J474M250KE CGA8P3X7T2E105K250KE CGA8P3X7T2E105M250KE CGA9P4X7T2W105K250KE CGA9P4X7T2W105M250KE CGA9P3X7T2E225K250KE CGA9P3X7T2E225M250KE Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160602 / mlcc_automotive_soft_en.fm (11/12) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable)  Temperature Characteristics:X8R (-55 to +150℃, ±15%) Capacitance Size Thickness (mm) 150pF 1005 0.50+0.10/-0.05 220pF 1005 0.50+0.10/-0.05 330pF 1005 0.50+0.10/-0.05 470pF 1005 0.50+0.10/-0.05 680pF 1005 0.50+0.10/-0.05 1005 0.50+0.10/-0.05 1608 0.80+0.15/-0.10 1005 0.50+0.10/-0.05 1608 0.80+0.15/-0.10 1005 0.50+0.10/-0.05 1608 0.80+0.15/-0.10 1005 0.50+0.10/-0.05 1608 0.80+0.15/-0.10 1005 0.50+0.10/-0.05 1608 0.80+0.15/-0.10 1005 0.50+0.10/-0.05 1608 0.80+0.15/-0.10 1005 0.50+0.10/-0.05 1608 0.80+0.15/-0.10 1005 0.50+0.10/-0.05 1608 0.80+0.15/-0.10 1005 0.50+0.10/-0.05 1608 0.80+0.15/-0.10 2012 1.25+0.25/-0.20 1005 0.50+0.10/-0.05 1608 0.80+0.15/-0.10 2012 1.25+0.25/-0.20 1005 0.50+0.10/-0.05 1608 0.80+0.15/-0.10 2012 1.25+0.25/-0.20 1608 0.80+0.15/-0.10 2012 1.25+0.25/-0.20 1608 0.80+0.15/-0.10 2012 1.25+0.25/-0.20 3216 1.15±0.15 1nF 1.5nF 2.2nF 3.3nF 4.7nF 6.8nF 10nF 15nF 22nF 33nF 47nF 68nF 100nF Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Catalog Number Rated Voltage Edc:100V CGA2B2X8R2A151K050BE CGA2B2X8R2A151M050BE CGA2B2X8R2A221K050BE CGA2B2X8R2A221M050BE CGA2B2X8R2A331K050BE CGA2B2X8R2A331M050BE CGA2B2X8R2A471K050BE CGA2B2X8R2A471M050BE CGA2B2X8R2A681K050BE CGA2B2X8R2A681M050BE CGA2B2X8R2A102K050BE CGA2B2X8R2A102M050BE CGA3E2X8R2A102K080AE CGA3E2X8R2A102M080AE CGA2B2X8R2A152K050BE CGA2B2X8R2A152M050BE CGA3E2X8R2A152K080AE CGA3E2X8R2A152M080AE CGA2B2X8R2A222K050BE CGA2B2X8R2A222M050BE CGA3E2X8R2A222K080AE CGA3E2X8R2A222M080AE CGA2B3X8R2A332K050BE CGA2B3X8R2A332M050BE CGA3E2X8R2A332K080AE CGA3E2X8R2A332M080AE CGA3E2X8R2A472K080AE CGA3E2X8R2A472M080AE CGA3E2X8R2A682K080AE CGA3E2X8R2A682M080AE CGA3E2X8R2A103K080AE CGA3E2X8R2A103M080AE Rated Voltage Edc:50V CGA2B2X8R1H151K050BE CGA2B2X8R1H151M050BE CGA2B2X8R1H221K050BE CGA2B2X8R1H221M050BE CGA2B2X8R1H331K050BE CGA2B2X8R1H331M050BE CGA2B2X8R1H471K050BE CGA2B2X8R1H471M050BE CGA2B2X8R1H681K050BE CGA2B2X8R1H681M050BE CGA2B2X8R1H102K050BE CGA2B2X8R1H102M050BE CGA3E2X8R1H102K080AE CGA3E2X8R1H102M080AE CGA2B2X8R1H152K050BE CGA2B2X8R1H152M050BE CGA3E2X8R1H152K080AE CGA3E2X8R1H152M080AE CGA2B2X8R1H222K050BE CGA2B2X8R1H222M050BE CGA3E2X8R1H222K080AE CGA3E2X8R1H222M080AE CGA2B2X8R1H332K050BE CGA2B2X8R1H332M050BE CGA3E2X8R1H332K080AE CGA3E2X8R1H332M080AE CGA2B2X8R1H472K050BE CGA2B2X8R1H472M050BE CGA3E2X8R1H472K080AE CGA3E2X8R1H472M080AE CGA2B3X8R1H682K050BE CGA2B3X8R1H682M050BE CGA3E2X8R1H682K080AE CGA3E2X8R1H682M080AE CGA2B3X8R1H103K050BE CGA2B3X8R1H103M050BE CGA3E2X8R1H103K080AE CGA3E2X8R1H103M080AE Rated Voltage Edc:25V Rated Voltage Edc:16V CGA2B2X8R1E682K050BE CGA2B2X8R1E682M050BE CGA2B2X8R1E103K050BE CGA2B2X8R1E103M050BE CGA2B3X8R1E153K050BE CGA2B3X8R1E153M050BE CGA3E2X8R2A153K080AE CGA3E2X8R2A153M080AE CGA3E2X8R1H153K080AE CGA3E2X8R1H153M080AE CGA2B3X8R1E223K050BE CGA2B3X8R1E223M050BE CGA3E3X8R2A223K080AE CGA3E3X8R2A223M080AE CGA4J2X8R2A223K125AE CGA4J2X8R2A223M125AE CGA3E2X8R1H223K080AE CGA3E2X8R1H223M080AE CGA2B3X8R1C333K050BE CGA2B3X8R1C333M050BE CGA3E2X8R1H333K080AE CGA3E2X8R1H333M080AE CGA4J3X8R2A333K125AE CGA4J3X8R2A333M125AE CGA2B3X8R1C473K050BE CGA2B3X8R1C473M050BE CGA3E2X8R1H473K080AE CGA3E2X8R1H473M080AE CGA4J3X8R2A473K125AE CGA4J3X8R2A473M125AE CGA4J3X8R2A683K125AE CGA4J3X8R2A683M125AE CGA3E3X8R1H683K080AE CGA3E3X8R1H683M080AE CGA4J2X8R1H683K125AE CGA4J2X8R1H683M125AE CGA3E3X8R1H104K080AE CGA3E3X8R1H104M080AE CGA4J2X8R1H104K125AE CGA4J2X8R1H104M125AE CGA3E2X8R1E683K080AE CGA3E2X8R1E683M080AE CGA3E2X8R1E104K080AE CGA3E2X8R1E104M080AE CGA5H2X8R2A104K115AE CGA5H2X8R2A104M115AE Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160602 / mlcc_automotive_soft_en.fm (12/12) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable)  Temperature Characteristics:X8R (-55 to +150℃, ±15%) Capacitance Size Thickness (mm) 1608 0.80+0.15/-0.10 0.85±0.15 150nF 2012 1.25+0.25/-0.20 3216 1.60+0.30/-0.20 1608 0.80+0.15/-0.10 2012 1.25+0.25/-0.20 3216 1.60+0.30/-0.20 1608 0.80+0.15/-0.10 2012 1.25+0.25/-0.20 3216 1.60+0.30/-0.20 1608 0.80+0.15/-0.10 2012 1.25+0.25/-0.20 3216 1.60+0.30/-0.20 3225 2.00+0.30/-0.20 2012 1.25+0.25/-0.20 3216 1.60+0.30/-0.20 3225 2.50±0.30 2012 1.25+0.25/-0.20 3216 1.60+0.30/-0.20 1.5uF 3216 1.60+0.30/-0.20 2.2uF 3216 1.60+0.30/-0.20 3.3uF 3216 1.60+0.30/-0.20 3216 1.60+0.30/-0.20 3225 2.50±0.30 220nF 330nF 470nF 680nF 1uF 4.7uF Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Catalog Number Rated Voltage Edc:100V Rated Voltage Edc:50V Rated Voltage Edc:25V CGA3E3X8R1E154K080AE CGA3E3X8R1E154M080AE CGA4F2X8R1E154K085AE CGA4F2X8R1E154M085AE Rated Voltage Edc:16V CGA4J3X8R1H154K125AE CGA4J3X8R1H154M125AE CGA5L2X8R2A154K160AE CGA5L2X8R2A154M160AE CGA4J3X8R1H224K125AE CGA4J3X8R1H224M125AE CGA3E3X8R1E224K080AE CGA3E3X8R1E224M080AE CGA4J2X8R1E224K125AE CGA4J2X8R1E224M125AE CGA5L3X8R2A224K160AE CGA5L3X8R2A224M160AE CGA3E3X8R1C334K080AE CGA3E3X8R1C334M080AE CGA4J2X8R1E334K125AE CGA4J2X8R1E334M125AE CGA5L3X8R2A334K160AE CGA5L3X8R2A334M160AE CGA5L2X8R1H334K160AE CGA5L2X8R1H334M160AE CGA3E3X8R1C474K080AE CGA3E3X8R1C474M080AE CGA4J3X8R1E474K125AE CGA4J3X8R1E474M125AE CGA5L2X8R1H474K160AE CGA5L2X8R1H474M160AE CGA6M3X8R2A474K200AE CGA6M3X8R2A474M200AE CGA4J3X8R1C684K125AE CGA4J3X8R1C684M125AE CGA5L3X8R1H684K160AE CGA5L3X8R1H684M160AE CGA6P3X8R2A684K250AE CGA6P3X8R2A684M250AE CGA4J3X8R1C105K125AE CGA4J3X8R1C105M125AE CGA5L3X8R1H105K160AE CGA5L3X8R1H105M160AE CGA5L2X8R1E105K160AE CGA5L2X8R1E105M160AE CGA5L3X8R1E155K160AE CGA5L3X8R1E155M160AE CGA5L3X8R1E225K160AE CGA5L3X8R1E225M160AE CGA5L3X8R1C335K160AE CGA5L3X8R1C335M160AE CGA5L3X8R1C475K160AE CGA5L3X8R1C475M160AE CGA6P3X8R1E475K250AE CGA6P3X8R1E475M250AE Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160602 / mlcc_automotive_soft_en.fm
CGA5L3X7R1H225M160AE 价格&库存
很抱歉,暂时无法提供与“CGA5L3X7R1H225M160AE”相匹配的价格&库存,您可以联系我们找货
  • 2000+2.40878
  • 4000+2.35607
  • 1+9.364731+1.21507
  • 10+5.9957810+0.77795
  • 50+4.6676350+0.60563
  • 100+4.25802100+0.55248
  • 500+3.56497500+0.46255
库存:6827
  • 2000+2.997852000+0.38897
  • 6000+2.791976000+0.36226
库存:6827
