CGA5L4C0G2W103J160AE
    TDK(东电化)
    10NF ±5% 450V
CGA5L4C0G2W103J160AE 数据手册
CGA5L4C0G2W103J160AE TDK Item Description : CGA5L4C0G2W103JT***S Equivalent C3216C0G2W103J for Automotive DC Bias Characteristic 0.5 Application & Main Feature 0.4 0.3 Cap. Change/% Automotive Grade ( Soft Termination ) Series 0.2 0.1 0 -0.1 CGA5(3216) [EIA 1206] -0.2 -0.3 -0.4 -0.5 3.20mm 1.60mm 1.60mm 0.20mm 1.00mm +0.4,-0.2mm +0.3,-0.2mm +0.3,-0.2mm Min. Min. Temperature Characteristic 200 300 400 500 Rated Voltage 2W(450Vdc) 0.4 0.3 100 0.2 0.1 10 1 -0.2 0.1 -0.3 -0.4 -0.5 0.001 10nF 0.1 1 10 Frequency/MHz |Z| Capacitance Tolerance J (±5%) 100 Temperature Rise/degC AEC-Q200 Yes 0.1 1 0 10 Frequency/MHz 20 40 60 100 1000 80 100 120 140 160 Temperature/degC TCBias(1/2Rated) Ripple Temperature Rise Characteristics 25 10 1 -20 Temp.Chara. 1000 Min. 10Gohm Min -40 ESR Cap. vs. Freq. Characteristic 100 -60 1000 Q Factor Insulation Resistance 0 -0.1 0.01 Capacitance Temperature Characteristics 0.5 (Simulation Data) 1000 Cap./nF Characterization Sheet ( Multilayer Ceramic Chip Capacitors ) C0G (-55 to 125 degC 0+/-30ppm/degC) |Z|, ESR vs. Freq. Characteristics Cap. Change/% L W T B G 100 DC Bias/V |Z|, ESR/ohm Dimensions 0 20 15 10 5 0 0 1 2 3 4 Current/Arms 1MHz All specifications are subject to change without notice. June 24, 2019
CGA5L4C0G2W103J160AE 价格&库存
很抱歉,暂时无法提供与“CGA5L4C0G2W103J160AE”相匹配的价格&库存,您可以联系我们找货
    • 2000+1.390352000+0.18010
    • 6000+1.271886000+0.16476
    库存:4506
    • 1+5.027551+0.65125
    • 10+3.1072610+0.40250
    • 50+2.3338150+0.30231
    • 100+2.09727100+0.27167
    • 500+1.69727500+0.21986
    库存:4506
