CGA6M2NP02A333J200AA
    TDK(东电化)
    贴片电容(MLCC) 1210 33nF ±5% 100V C0G(NP0)
CGA6M2NP02A333J200AA 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS CGA Series Automotive Grade High Temperature Application Type: CGA2 [EIA CC0402] CGA3 [EIA CC0603] CGA4 [EIA CC0805] CGA5 [EIA CC1206] CGA6 [EIA CC1210] CGA8 [EIA CC1812] CGA9 [EIA CC2220] Issue date: Apr 2015 20150410 / mlcc_automotive_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS REMINDERS Please read before using this product SAFETY REMINDERS REMINDERS 1. If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other damage, you must contact our company’s sales window. 2. We may modify products or discontinue production of a product listed in this catalog without prior notification. 3. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. 4. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export permission in harmony with this law. 5. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. 6. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. 7. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging specification detail. This new catalog number should be referenced on all catalog orders going forward, and is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will differ from the item description (internal control number) on the product label. Contact your local TDK Sales representative for more information. (Example) Catalog Issued date Catalog Number Item Description (On Delivery Label) Prior to January 2013 C1608C0G1E103J C1608C0G1E103JT000N January 2013 and Later C1608C0G1E103J080AA C1608C0G1E103JT000N Page 1 20150410 / mlcc_automotive_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS CGA Series High Temperature Application Type: CGA2 [EIA CC0402], CGA3 [EIA CC0603], CGA4 [EIA CC0805], CGA5 [EIA CC1206], CGA6 [EIA CC1210], CGA8 [EIA CC1812], CGA9 [EIA CC2220] Features Applications • With a maximum temperature of 150°C and a capacitance change within ±15%, the series is suited for devices that operate in high-temperature environments. • Excellent DC bias properties. • AEC-Q200 compliant. Parameters Temperature Characteristics Operating Temperature Dissipation Factor Specifications -55 to 150°C ¨C/C: ±15% or 0±30ppm -55 to +150°C 5% maximum Insulation Resistance 10 GŸ or 500 MŸ • ȝF minimum 2.5 • RV or 3 • RV for 1~5s Charge/Discharge ”50 mA Voltage Proof Catalog Number Construction • Automotive applications (engine rooms) • Peripheral circuits of IGDT, SiC, GaN used at high temperature environments • Sensor Module • Smoothing and decoupling applications for other devices that operate at high temperature Shape & Dimensions L W T B G Body Length Body Width Body Height Terminal Width Terminal Spacing CGA • 6 • P • 3 • X8R • 1C • 106 • K • 250 • A • B Series Name Dimensions L x W (mm) Code 2 3 4 5 6 8 9 Length 1.00 ± 0.05 1.60 ± 0.10 2.00 ± 0.20 3.20 ± 0.20 3.20 ± 0.40 4.50 ± 0.40 5.70 ± 0.40 Width 0.50 ± 0.05 0.80 ± 0.10 1.25 ± 0.20 1.60 ± 0.20 2.50 ± 0.30 3.20 ± 0.40 5.00 ± 0.40 Terminal 0.10 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. *Dimension tolerance are typical values Thickness T Code (mm) Code B C E F H J L M N P Q R Thickness 0.50 mm 0.60 mm 0.80 mm 0.85 mm 1.15 mm 1.25 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm 2.80 mm 3.20 mm Voltage Condition for Life Test Symbol 2 3 Condition 2 × R.V. 1.5 × R.V. Temperature Characteristics Temperature Temperature Coefficient or Temperature Characteristics Capacitance Change Range 0±30ppm/°C ±15% NP0 X8R -55 to +150°C -55 to +150°C Rated Voltage (DC) Code 1C 1E 1H Voltage (DC) 16V 25V 50V Capacitance Tolerance Code C D J K M Tolerance ± 0.25pF ± 0.50pF ± 5% ± 10% ± 20% Code 2A 2E 2W 2J Voltage (DC) 100V 250V 450V 630V Nominal Capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. Ex. 0R2 = 0.2pF; 103 = 10,000pF; 105 = 1,000,000pF = 100nF = 1ȝF Nominal Thickness Code 050 060 080 085 115 125 Thickness 0.50 mm 0.60 mm 0.80 mm 0.85 mm 1.15 mm 1.25 mm Code 160 200 230 250 280 320 Thickness 1.60 mm 2.00 mm 2.30 mm 2.50 mm 2.80 mm 3.20 mm Packaging Style Code A B K Style 178 mm Reel, 4 mm Pitch 178 mm Reel, 2 mm Pitch 178 mm Reel, 8 mm Pitch Special Reserved Code Code A, B Description TDK Internal Code Page 2   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150410 / mlcc_automotive_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA2(1005) [EIA CC0402] Capacitance Range Chart Temperature Characteristics: NP0 (0 ± 30ppm/ºC), X8R (±15%) Rated Voltage: 100V (2A), 50V (1H), 25V (1E), 16V (1C) Capacitance (pF) 1 1.5 2 2.2 3 3.3 4 4.7 5 6 6.8 7 8 9 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 NP0 Code 010 1R5 020 2R2 030 3R3 040 4R7 050 060 6R8 070 080 090 100 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 152 222 332 472 682 103 153 223 333 473 Tolerance X8R 2A 1H 2A 1H (100V) (50V) (100V) (50V) 1E (25V) 1C (16V) C: ± 0.25pF D: ± 0.50pF J : ± 5% K : ± 10% M: ± 20% Standard Thickness 0.50 mm Page 3   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150410 / mlcc_automotive_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA3(1608) [EIA CC0603] Capacitance Range Chart Temperature Characteristics: NP0 (0 ± 30ppm/ºC), X8R (±15%) Rated Voltage: 250V (2E), 100V (2A), 50V(1H), 25V (1E), 16V (1C) Capacitance (pF) 1 2 2 2 3 3 4 5 5 6 7 7 8 9 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 NP0 Code 010 1R5 020 2R2 030 3R3 040 4R7 050 060 6R8 070 080 090 100 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 Tolerance C: ± 0.25pF D: ± 0.50pF J: ± 5% 2E 2A 1H (250V) (100V) (50V) X8R Capacitance (pF) Code 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 102 152 222 332 472 682 103 153 223 333 473 683 104 154 224 334 474 Tolerance 2A 1H (100V) (50V) 1E (25V) 1C (16V) K: ± 10% M: ± 20% Standard Thickness 0.80 mm Page 4   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150410 / mlcc_automotive_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA4(2012) [EIA CC0805] Capacitance Range Chart Temperature Characteristics: NP0 (0 ± 30ppm/ºC), X8R (±15%) Rated Voltage: 450V(2W), 250V(2E), 100V (2A), 50V (1H), ) 25V (1E), 16V (1C Capacitance (pF) 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 NP0 Code 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 153 223 333 473 683 104 154 224 334 474 684 105 Tolerance X8R 2W 2E 2A 1H 2A 1H (450V) (250V) (100V) (50V) (100V) (50V) 1E (25V) 1C (16V) J: ± 5% K: ± 10% M: ± 20% Standard Thickness 0.60 mm 0.85 mm 1.25 mm Page 5   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150410 / mlcc_automotive_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA5(3216) [EIA CC1206] Capacitance Range Chart Temperature Characteristics: NP0 (0 ± 30ppm/ºC), X8R (±15%) Rated Voltage: 630V(2J), 450V(2W), 250V(2E), 100V (2A), 50V (1H), 25V (1E), 16V (1C) Capacitance (pF) 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 NP0 Code 392 472 562 682 822 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 335 475 Tolerance X8R 2J 2W 2E 2A 1H 2A 1H (630V) (450V) (250V) (100V) (50V) (100V) (50V) 1E (25V) 1C (16V) J : ± 5% K : ± 10% M: ± 20% Standard Thickness 0.60 mm 0.85 mm 1.15 mm 1.60 mm Capacitance Range Chart CGA6(3225) [EIA CC1210] Capacitance Range Chart Temperature Characteristics: NP0 (0 ± 30ppm/ºC), X8R (±15%) Rated Voltage: 630V(2J), 450V(2W), 250V(2E),100V (2A), 50V (1H), 25V (1E), 16V (1C) Capacitance (pF) 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 470,000 680,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 NP0 Code 822 103 153 223 333 473 683 104 474 684 155 225 335 475 685 106 Tolerance X8R 1 2J 2W 2E 2A 1H 2A 1E 25V) (630V) (450V) (250V) (100V) (50V) (100V) (25 1C (16V) J : ± 5% K : ± 10% M: ± 20% Standard Thickness 1.25 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm Page 6   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150410 / mlcc_automotive_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGA8(4532) [EIA CC1812] Capacitance Range Chart Temperature Characteristics: NP0 (0 ± 30ppm/ºC) Rated Voltage: 630V(2J), 450V(2W), 250V(2E), 100V (2A), 50V (1H) Capacitance (pF) 33,000 47,000 68,000 100,000 150,000 220,000 NP0 Code 333 473 683 104 154 224 Tolerance 2J 2W 2E 2A 1H (630V) (450V) (250V) (100V) (50V) Standard Thickness 1.60 mm J: ± 5% 2.00 mm 2.30 mm 2.50 mm 3.20 mm Capacitance Range Chart CGA9(5750) [EIA CC2220] Capacitance Range Chart Temperature Characteristics: NP0 (0 ± 30ppm/ºC) Rated Voltage: 450V(2W), 250V(2E), 100V (2A) Capacitance (pF) 100,000 150,000 NP0 Code 104 154 Tolerance J: ± 5% 2W 2E 2A (450V) (250V) (100V) Standard Thickness 2.30 mm 2.80 mm Page 7   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150410 / mlcc_automotive_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: NP0 (-55 to +150ºC, 0±30 ppm/ºC) Capacitance Size 1 pF 1.5 pF 2 pF 2.2 pF 3 pF 3.3 pF 4 pF 4.7 pF 5 pF 6 pF 6.8 pF 7 pF 8 pF 9 pF 10 pF 12 pF 15 pF 18 pF 22 pF 27 pF 33 pF 39 pF 47 pF 56 pF 68 pF 82 pF 100 pF 120 pF 150 pF 180 pF 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 Thickness (mm) 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 Catalog Number Capacitance Tolerance Rated Voltage Edc: 630V ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 0.50pF ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% Rated Voltage Edc: 450V Rated Voltage Edc: 250V Rated Voltage Edc: 100V CGA3E2NP02A010C080AA CGA3E2NP02A1R5C080AA CGA3E2NP02A020C080AA CGA3E2NP02A2R2C080AA CGA3E2NP02A030C080AA CGA3E2NP02A3R3C080AA CGA3E2NP02A040C080AA CGA3E2NP02A4R7C080AA CGA3E2NP02A050C080AA CGA3E2NP02A060D080AA CGA3E2NP02A6R8D080AA CGA3E2NP02A070D080AA CGA3E2NP02A080D080AA CGA3E2NP02A090D080AA CGA3E2NP02A100D080AA CGA3E2NP02A120J080AA CGA3E2NP02A150J080AA CGA3E2NP02A180J080AA CGA3E2NP02A220J080AA CGA3E2NP02A270J080AA CGA3E2NP02A330J080AA CGA3E2NP02A390J080AA CGA3E2NP02A470J080AA CGA3E2NP02A560J080AA CGA3E2NP02A680J080AA CGA3E2NP02A820J080AA CGA2B2NP02A101J050BA CGA3E2NP02A101J080AA Rated Voltage Edc: 50V CGA2B2NP01H010C050BA CGA3E2NP01H010C080AA CGA2B2NP01H1R5C050BA CGA3E2NP01H1R5C080AA CGA2B2NP01H020C050BA CGA3E2NP01H020C080AA CGA2B2NP01H2R2C050BA CGA3E2NP01H2R2C080AA CGA2B2NP01H030C050BA CGA3E2NP01H030C080AA CGA2B2NP01H3R3C050BA CGA3E2NP01H3R3C080AA CGA2B2NP01H040C050BA CGA3E2NP01H040C080AA CGA2B2NP01H4R7C050BA CGA3E2NP01H4R7C080AA CGA2B2NP01H050C050BA CGA3E2NP01H050C080AA CGA2B2NP01H060D050BA CGA3E2NP01H060D080AA CGA2B2NP01H6R8D050BA CGA3E2NP01H6R8D080AA CGA2B2NP01H070D050BA CGA3E2NP01H070D080AA CGA2B2NP01H080D050BA CGA3E2NP01H080D080AA CGA2B2NP01H090D050BA CGA3E2NP01H090D080AA CGA2B2NP01H100D050BA CGA3E2NP01H100D080AA CGA2B2NP01H120J050BA CGA3E2NP01H120J080AA CGA2B2NP01H150J050BA CGA3E2NP01H150J080AA CGA2B2NP01H180J050BA CGA3E2NP01H180J080AA CGA2B2NP01H220J050BA CGA3E2NP01H220J080AA CGA2B2NP01H270J050BA CGA3E2NP01H270J080AA CGA2B2NP01H330J050BA CGA3E2NP01H330J080AA CGA2B2NP01H390J050BA CGA3E2NP01H390J080AA CGA2B2NP01H470J050BA CGA3E2NP01H470J080AA CGA2B2NP01H560J050BA CGA3E2NP01H560J080AA CGA2B2NP01H680J050BA CGA3E2NP01H680J080AA CGA2B2NP01H820J050BA CGA3E2NP01H820J080AA CGA2B2NP01H101J050BA CGA3E2NP01H101J080AA CGA4C4NP02W101J060AA CGA2B2NP02A121J050BA CGA2B2NP01H121J050BA CGA3E2NP02A121J080AA CGA3E2NP01H121J080AA CGA4C4NP02W121J060AA CGA2B2NP02A151J050BA CGA2B2NP01H151J050BA CGA3E2NP02A151J080AA CGA3E2NP01H151J080AA CGA4C4NP02W151J060AA CGA2B2NP02A181J050BA CGA2B2NP01H181J050BA CGA3E2NP02A181J080AA CGA3E2NP01H181J080AA CGA4C4NP02W181J060AA Page 8   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150410 / mlcc_automotive_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: NP0 (-55 to +150ºC, 0±30 ppm/ºC) Capacitance Size 220 pF 270 pF 330 pF 390 pF 470 pF 560 pF 680 pF 820 pF 1 nF 1.2 nF 1.5 nF 1.8 nF 2.2 nF 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 1608 2012 1608 2012 1608 2012 1608 2012 1608 2.7 nF 2012 1608 3.3 nF 2012 1608 3.9 nF 2012 3216 1608 4.7 nF 2012 3216 1608 2012 5.6 nF 3216 Catalog Number Capacitance Tolerance Rated Voltage Edc: 630V 0.50 ± 0.05 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.50 ± 0.05 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.50 ± 0.05 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.50 ± 0.05 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.50 ± 0.05 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.50 ± 0.05 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.50 ± 0.05 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.50 ± 0.05 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.50 ± 0.05 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 0.85 ± 0.15 ± 5% 0.80 ± 0.10 ± 5% 0.85 ± 0.15 ± 5% 0.80 ± 0.10 ± 5% 0.85 ± 0.15 ± 5% 0.80 ± 0.10 ± 5% 0.80 + 0.15/-0.1 ± 5% 0.60 ± 0.15 ± 5% 1.25 ± 0.20 ± 5% 0.80 ± 0.10 ± 5% 0.80 + 0.15/-0.1 ± 5% 0.60 ± 0.15 ± 5% 0.85 ± 0.15 ± 5% 1.25 ± 0.20 ± 5% 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 1.25 ± 0.20 ± 5% 0.60 ± 0.15 ± 5% 0.85 ± 0.15 ± 5% CGA5F4NP02J392J085AA 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 1.25 ± 0.20 ± 5% 0.60 ± 0.15 ± 5% 0.85 ± 0.15 ± 5% CGA5F4NP02J472J085AA 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 1.25 ± 0.20 ± 5% 0.60 ± 0.15 ± 5% 0.85 ± 0.15 ± 5% 1.15 ± 0.15 ± 5% CGA5H4NP02J562J115AA Thickness (mm) Rated Voltage Edc: 450V Rated Voltage Edc: 250V Rated Voltage Edc: 100V Rated Voltage Edc: 50V CGA2B2NP02A221J050BA CGA2B2NP01H221J050BA CGA3E2NP02A221J080AA CGA3E2NP01H221J080AA CGA4C4NP02W221J060AA CGA2B2NP02A271J050BA CGA2B2NP01H271J050BA CGA3E2NP02A271J080AA CGA3E2NP01H271J080AA CGA4C4NP02W271J060AA CGA2B2NP02A331J050BA CGA2B2NP01H331J050BA CGA3E2NP02A331J080AA CGA3E2NP01H331J080AA CGA4C4NP02W331J060AA CGA2B2NP02A391J050BA CGA2B2NP01H391J050BA CGA3E2NP02A391J080AA CGA3E2NP01H391J080AA CGA4C4NP02W391J060AA CGA2B2NP02A471J050BA CGA2B2NP01H471J050BA CGA3E2NP02A471J080AA CGA3E2NP01H471J080AA CGA4C4NP02W471J060AA CGA3E2NP02A561J080AA CGA2B2NP01H561J050BA CGA3E2NP01H561J080AA CGA3E2NP02A681J080AA CGA2B2NP01H681J050BA CGA3E2NP01H681J080AA CGA3E2NP02A821J080AA CGA2B2NP01H821J050BA CGA3E2NP01H821J080AA CGA4C4NP02W561J060AA CGA4C4NP02W681J060AA CGA3E3NP02E821J080AA CGA4C4NP02W821J060AA CGA3E3NP02E102J080AA CGA4C4NP02W102J060AA CGA3E3NP02E122J080AA CGA4C4NP02W122J060AA CGA3E3NP02E152J080AA CGA2B2NP01H102J050BA CGA3E2NP02A102J080AA CGA3E2NP01H102J080AA CGA4C2NP02A102J060AA CGA3E2NP02A122J080AA CGA3E2NP01H122J080AA CGA4C2NP02A122J060AA CGA3E2NP02A152J080AA CGA3E2NP01H152J080AA CGA4C2NP02A152J060AA CGA4F4NP02W152J085AA CGA3E3NP02E182J080AA CGA4F4NP02W182J085AA CGA3E3NP02E222J080AA CGA4F4NP02W222J085AA CGA3E2NP02A182J080AA CGA4F2NP02A182J085AA CGA3E2NP02A222J080AA CGA4F2NP02A222J085AA CGA3E2NP01H182J080AA CGA3E2NP01H222J080AA CGA3E2NP01H272J080AA CGA3E2NP02A272J080AA CGA4C2NP01H272J060AA CGA4J4NP02W272J125AA CGA4J2NP02A272J125AA CGA3E2NP01H332J080AA CGA3E2NP02A332J080AA CGA4C2NP01H332J060AA CGA4F3NP02E332J085AA CGA4J4NP02W332J125AA CGA4J2NP02A332J125AA CGA3E2NP01H392J080AA CGA4C2NP01H392J060AA CGA4J4NP02W392J125AA CGA4J3NP02E392J125AA CGA4J2NP02A392J125AA CGA5C2NP02A392J060AA CGA3E2NP01H472J080AA CGA4C2NP01H472J060AA CGA4J4NP02W472J125AA CGA4J3NP02E472J125AA CGA4J2NP02A472J125AA CGA5C2NP01H472J060AA CGA5F2NP02A472J085AA CGA3E2NP01H562J080AA CGA4C2NP01H562J060AA CGA4J4NP02W562J125AA CGA4J3NP02E562J125AA CGA4J2NP02A562J125AA CGA5C2NP01H562J060AA CGA5F2NP02A562J085AA Page 9   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150410 / mlcc_automotive_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: NP0 (-55 to +150ºC, 0±30 ppm/ºC) Capacitance Size 1608 6.8 nF 2012 3216 1608 2012 8.2 nF 3216 3225 1608 2012 10 nF 3216 3225 2012 15 nF 3216 3225 2012 3216 22 nF 3225 2012 3216 33 nF 3225 4532 3216 3225 47 nF 4532 3216 3225 68 nF 4532 3216 3225 100 nF 150 nF 220 nF 4532 5750 4532 5750 4532 Catalog Number Capacitance Tolerance Rated Voltage Edc: 630V 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 1.25 ± 0.20 ± 5% 0.60 ± 0.15 ± 5% 1.15 ± 0.15 ± 5% CGA5H4NP02J682J115AA 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 1.25 ± 0.20 ± 5% 0.60 ± 0.15 ± 5% 1.15 ± 0.15 ± 5% 1.60 ± 0.20 ± 5% CGA5L4NP02J822J160AA 1.25 ± 0.20 ± 5% CGA6J4NP02J822J125AA 0.80 ± 0.10 ± 5% 0.60 ± 0.15 ± 5% 1.25 ± 0.20 ± 5% 0.60 ± 0.15 ± 5% 1.15 ± 0.15 ± 5% 1.60 ± 0.20 ± 5% CGA5L4NP02J103J160AA 1.25 ± 0.20 ± 5% CGA6J4NP02J103J125AA 0.85 ± 0.15 ± 5% 0.60 ± 0.15 ± 5% 1.15 ± 0.15 ± 5% 1.60 ± 0.20 ± 5% 1.25 ± 0.20 ± 5% 1.60 ± 0.20 ± 5% CGA6L4NP02J153J160AA 1.25 ± 0.20 ± 5% 0.60 ± 0.15 ± 5% 1.60 ± 0.20 ± 5% 1.25 ± 0.20 ± 5% 1.60 ± 0.20 ± 5% 2.30 ± 0.20 ± 5% CGA6N4NP02J223J230AA 1.25 ± 0.20 ± 5% 0.85 ± 0.15 ± 5% 1.60 + 0.3/-0.1 ± 5% 1.60 ± 0.20 ± 5% 2.00 ± 0.20 ± 5% 2.30 ± 0.20 ± 5% 2.50 ± 0.30 ± 5% CGA6P4NP02J333J250AA 2.00 ± 0.20 ± 5% CGA8M4NP02J333J200KA 1.15 ± 0.15 ± 5% 2.00 ± 0.20 ± 5% 2.30 ± 0.20 ± 5% 2.50 ± 0.30 ± 5% 1.60 ± 0.20 ± 5% 2.00 ± 0.20 ± 5% 2.30 ± 0.20 ± 5% 3.20 ± 0.30 ± 5% CGA8R4NP02J473J320KA 1.60 ± 0.20 ± 5% 2.00 ± 0.20 ± 5% 2.30 ± 0.20 ± 5% 1.60 ± 0.20 ± 5% 2.30 ± 0.20 ± 5% 2.50 ± 0.30 ± 5% 3.20 ± 0.30 ± 5% 1.60 ± 0.20 ± 5% 2.50 ± 0.30 ± 5% 2.00 ± 0.20 ± 5% 3.20 ± 0.30 ± 5% 2.80 ± 0.30 ± 5% 2.50 ± 0.30 ± 5% 2.30 ± 0.20 ± 5% 3.20 ± 0.30 ± 5% Thickness (mm) Rated Voltage Edc: 450V Rated Voltage Edc: 250V Rated Voltage Edc: 100V CGA4J3NP02E682J125AA CGA4J2NP02A682J125AA Rated Voltage Edc: 50V CGA3E2NP01H682J080AA CGA4C2NP01H682J060AA CGA5C2NP01H682J060AA CGA5H4NP02W682J115AA CGA5H2NP02A682J115AA CGA3E2NP01H822J080AA CGA4C2NP01H822J060AA CGA4J3NP02E822J125AA CGA4J2NP02A822J125AA CGA5C2NP01H822J060AA CGA5H4NP02W822J115AA CGA5H2NP02A822J115AA CGA3E2NP01H103J080AA CGA4C2NP01H103J060AA CGA4J3NP02E103J125AA CGA4J2NP02A103J125AA CGA5C2NP01H103J060AA CGA5H3NP02E103J115AA CGA5H2NP02A103J115AA CGA5L4NP02W103J160AA CGA4F2NP01H153J085AA CGA5C2NP01H153J060AA CGA5H2NP02A153J115AA CGA5L4NP02W153J160AA CGA5L3NP02E153J160AA CGA6J2NP02A153J125AA CGA4J2NP01H223J125AA CGA5C2NP01H223J060AA CGA5L3NP02E223J160AA CGA5L2NP02A223J160AA CGA6L3NP02E223J160AA CGA6L2NP02A223J160AA CGA6J2NP01H223J125AA CGA6N4NP02W223J230AA CGA4J2NP01H333J125AA CGA5F2NP01H333J085AA CGA5L2NP02A333J160AA CGA6L2NP01H333J160AA CGA6M2NP02A333J200AA CGA6N3NP02E333J230AA CGA6P4NP02W333J250AA CGA5H2NP01H473J115AA CGA6M2NP01H473J200AA CGA6N2NP02A473J230AA CGA6P3NP02E473J250AA CGA8L2NP01H473J160KA CGA8M2NP02A473J200KA CGA8N4NP02W473J230KA CGA5L2NP01H683J160AA CGA6M2NP01H683J200AA CGA6N2NP02A683J230AA CGA8L2NP01H683J160KA CGA8N4NP02E683J230KN CGA8P2NP02A683J250KA CGA8R4NP02W683J320KA CGA5L2NP01H104J160AA CGA6P2NP01H104J250AA CGA8M2NP01H104J200KA CGA8R4NP02E104J320KN CGA8R2NP02A104J320KA CGA9Q4NP02W104J280KA CGA8P2NP01H154J250KA CGA9N4NP02E154J230KN CGA9N2NP02A154J230KA CGA8R2NP01H224J320KA Page 10   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150410 / mlcc_automotive_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X8R (-55 to +150ºC, ±15%) Capacitance Size Thickness (mm) 150 pF 1005 0.50 ± 0.05 220 pF 1005 0.50 ± 0.05 330 pF 1005 0.50 ± 0.05 470 pF 1005 0.50 ± 0.05 680 pF 1005 0.50 ± 0.05 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 1.25 ± 0.20 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 1.25 ± 0.20 1005 0.50 ± 0.05 1608 0.80 ± 0.10 2012 1.25 ± 0.20 1 nF 1.5 nF 2.2 nF 3.3 nF 4.7 nF 6.8 nF 10 nF 15 nF 22 nF 33 nF 47 nF Capacitance Tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog Number Rated Voltage Edc: 100V CGA2B2X8R2A151K050BA CGA2B2X8R2A151M050BA CGA2B2X8R2A221K050BA CGA2B2X8R2A221M050BA CGA2B2X8R2A331K050BA CGA2B2X8R2A331M050BA CGA2B2X8R2A471K050BA CGA2B2X8R2A471M050BA CGA2B2X8R2A681K050BA CGA2B2X8R2A681M050BA CGA2B2X8R2A102K050BA CGA2B2X8R2A102M050BA CGA3E2X8R2A102K080AA CGA3E2X8R2A102M080AA CGA2B2X8R2A152K050BA CGA2B2X8R2A152M050BA CGA3E2X8R2A152K080AA CGA3E2X8R2A152M080AA CGA2B2X8R2A222K050BA CGA2B2X8R2A222M050BA CGA3E2X8R2A222K080AA CGA3E2X8R2A222M080AA CGA2B3X8R2A332K050BB CGA2B3X8R2A332M050BB CGA3E2X8R2A332K080AA CGA3E2X8R2A332M080AA Rated Voltage Edc: 50V CGA2B2X8R1H151K050BA CGA2B2X8R1H151M050BA CGA2B2X8R1H221K050BA CGA2B2X8R1H221M050BA CGA2B2X8R1H331K050BA CGA2B2X8R1H331M050BA CGA2B2X8R1H471K050BA CGA2B2X8R1H471M050BA CGA2B2X8R1H681K050BA CGA2B2X8R1H681M050BA CGA2B2X8R1H102K050BA CGA2B2X8R1H102M050BA CGA3E2X8R1H102K080AA CGA3E2X8R1H102M080AA CGA2B2X8R1H152K050BA CGA2B2X8R1H152M050BA CGA3E2X8R1H152K080AA CGA3E2X8R1H152M080AA CGA2B2X8R1H222K050BA CGA2B2X8R1H222M050BA CGA3E2X8R1H222K080AA CGA3E2X8R1H222M080AA CGA2B2X8R1H332K050BA CGA2B2X8R1H332M050BA CGA3E2X8R1H332K080AA CGA3E2X8R1H332M080AA ± 10% CGA2B2X8R1H472K050BA ± 20% CGA2B2X8R1H472M050BA ± 10% CGA3E2X8R2A472K080AA CGA3E2X8R1H472K080AA ± 20% CGA3E2X8R2A472M080AA CGA3E2X8R1H472M080AA Rated Voltage Edc: 25V ± 10% CGA2B3X8R1H682K050BB ± 20% CGA2B3X8R1H682M050BB CGA2B2X8R1E682M050BA ± 10% CGA3E2X8R2A682K080AA CGA3E2X8R1H682K080AA ± 20% CGA3E2X8R2A682M080AA CGA3E2X8R1H682M080AA CGA2B2X8R1E682K050BA ± 10% CGA2B3X8R1H103K050BB ± 20% CGA2B3X8R1H103M050BB CGA2B2X8R1E103M050BA ± 10% CGA3E2X8R2A103K080AA CGA3E2X8R1H103K080AA ± 20% CGA3E2X8R2A103M080AA CGA3E2X8R1H103M080AA CGA2B2X8R1E103K050BA ± 10% CGA2B3X8R1E153K050BB ± 20% CGA2B3X8R1E153M050BB ± 10% CGA3E2X8R2A153K080AA CGA3E2X8R1H153K080AA ± 20% CGA3E2X8R2A153M080AA CGA3E2X8R1H153M080AA ± 10% CGA2B3X8R1E223K050BB ± 20% CGA2B3X8R1E223M050BB ± 10% CGA3E3X8R2A223K080AB CGA3E2X8R1H223K080AA ± 20% CGA3E3X8R2A223M080AB CGA3E2X8R1H223M080AA ± 10% CGA4J2X8R2A223K125AA ± 20% CGA4J2X8R2A223M125AA Rated Voltage Edc: 16V ± 10% CGA2B3X8R1C333K050BB ± 20% CGA2B3X8R1C333M050BB ± 10% CGA3E3X8R2A333K080AB CGA3E2X8R1H333K080AA ± 20% CGA3E3X8R2A333M080AB CGA3E2X8R1H333M080AA ± 10% CGA4J3X8R2A333K125AB ± 20% CGA4J3X8R2A333M125AB ± 10% CGA2B3X8R1C473K050BB ± 20% CGA2B3X8R1C473M050BB ± 10% CGA3E2X8R1H473K080AA ± 20% CGA3E2X8R1H473M080AA ± 10% CGA4J3X8R2A473K125AB ± 20% CGA4J3X8R2A473M125AB Page 11   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150410 / mlcc_automotive_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X8R (-55 to +150ºC, ±15%) Capacitance Size 1608 68 nF 100 nF 150 nF 2012 Thickness (mm) 0.80 ± 0.10 1.25 ± 0.20 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 1.15 ± 0.15 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 1.60 ± 0.20 1608 0.80 ± 0.10 2012 1.25 ± 0.20 220 nF 1.15 ± 0.15 3216 1.60 ± 0.20 330 nF 1608 0.80 ± 0.10 2012 1.25 ± 0.20 3216 1.60 ± 0.20 1608 0.80 + 0.15/-0.10 2012 1.25 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 2012 1.25 ± 0.20 470 nF 1.15 ± 0.15 680 nF 3216 1.60 ± 0.20 3225 2.50 ± 0.30 2012 1.25 ± 0.20 3216 1.60 ± 0.20 3216 1.60 ± 0.20 3225 1.60 ± 0.20 3216 1.60 ± 0.20 3225 2.00 ± 0.20 1 μF 1.5 μF 2.2 μF Capacitance Tolerance Catalog Number Rated Voltage Edc: 100V ± 10% ± 20% Rated Voltage Edc: 50V Rated Voltage Edc: 25V CGA3E3X8R1H683K080AB CGA3E2X8R1E683K080AA CGA3E3X8R1H683M080AB CGA3E2X8R1E683M080AA CGA4J3X8R2A683K125AB CGA4J2X8R1H683K125AA ± 20% CGA4J3X8R2A683M125AB CGA4J2X8R1H683M125AA ± 10% CGA5H2X8R2A683K115AA ± 20% CGA5H2X8R2A683M115AA ± 10% ± 10% CGA3E3X8R1H104K080AB CGA3E2X8R1E104K080AA ± 20% CGA3E3X8R1H104M080AB CGA3E2X8R1E104M080AA ± 10% CGA4J2X8R1H104K125AA ± 20% CGA4J2X8R1H104M125AA ± 10% CGA5H2X8R2A104K115AA ± 20% CGA5H2X8R2A104M115AA ± 10% CGA3E3X8R1E154K080AB ± 20% CGA3E3X8R1E154M080AB ± 10% CGA4J3X8R1H154K125AB ± 20% CGA4J3X8R1H154M125AB ± 10% CGA5L2X8R2A154K160AA ± 20% CGA5L2X8R2A154M160AA ± 10% CGA3E3X8R1E224K080AB ± 20% CGA3E3X8R1E224M080AB ± 10% CGA4J3X8R1H224K125AB CGA4J2X8R1E224K125AA ± 20% CGA4J3X8R1H224M125AB CGA4J2X8R1E224M125AA ± 10% CGA5H2X8R1H224K115AA ± 20% CGA5H2X8R1H224M115AA ± 10% CGA5L3X8R2A224K160AB ± 20% CGA5L3X8R2A224M160AB Rated Voltage Edc: 16V ± 10% CGA3E3X8R1C334K080AB ± 20% CGA3E3X8R1C334M080AB ± 10% CGA4J2X8R1E334K125AA ± 20% CGA4J2X8R1E334M125AA ± 10% CGA5L3X8R2A334K160AB CGA5L2X8R1H334K160AA ± 20% CGA5L3X8R2A334M160AB CGA5L2X8R1H334M160AA ± 10% CGA3E3X8R1C474K080AB ± 20% CGA3E3X8R1C474M080AB ± 10% CGA4J3X8R1E474K125AB ± 20% CGA4J3X8R1E474M125AB ± 10% CGA5L2X8R1H474K160AA ± 20% CGA5L2X8R1H474M160AA ± 10% CGA6M3X8R2A474K200AB ± 20% CGA6M3X8R2A474M200AB ± 10% CGA4J3X8R1C684K125AB ± 20% CGA4J3X8R1C684M125AB ± 10% CGA5H2X8R1E684K115AA ± 20% CGA5H2X8R1E684M115AA ± 10% CGA5L3X8R1H684K160AB ± 20% CGA5L3X8R1H684M160AB ± 10% CGA6P3X8R2A684K250AB ± 20% CGA6P3X8R2A684M250AB ± 10% CGA4J3X8R1C105K125AB ± 20% CGA4J3X8R1C105M125AB ± 10% CGA5L3X8R1H105K160AB CGA5L2X8R1E105K160AA ± 20% CGA5L3X8R1H105M160AB CGA5L2X8R1E105M160AA ± 10% CGA5L3X8R1E155K160AB ± 20% CGA5L3X8R1E155M160AB ± 10% CGA6L2X8R1E155K160AA ± 20% CGA6L2X8R1E155M160AA ± 10% CGA5L3X8R1E225K160AB ± 20% CGA5L3X8R1E225M160AB ± 10% CGA6M2X8R1E225K200AA ± 20% CGA6M2X8R1E225M200AA Page 12   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150410 / mlcc_automotive_hightemp_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X8R (-55 to +150ºC, ±15%) Capacitance Size 3216 Thickness (mm) 1.60 ± 0.20 3.3 μF 3225 2.50 ± 0.30 3216 1.60 ± 0.20 3225 2.50 ± 0.30 6.8 μF 3225 2.00 ± 0.20 10 μF 3225 2.50 ± 0.30 4.7 μF Capacitance Tolerance Catalog Number Rated Voltage Edc: 100V Rated Voltage Edc: 50V Rated Voltage Edc: 25V ± 10% Rated Voltage Edc: 16V CGA5L3X8R1C335K160AB ± 20% CGA5L3X8R1C335M160AB ± 10% CGA6P2X8R1E335K250AA ± 20% CGA6P2X8R1E335M250AA ± 10% CGA5L3X8R1C475K160AB ± 20% CGA5L3X8R1C475M160AB ± 10% CGA6P3X8R1E475K250AB ± 20% CGA6P3X8R1E475M250AB ± 10% CGA6M3X8R1C685K200AB ± 20% CGA6M3X8R1C685M200AB ± 10% CGA6P3X8R1C106K250AB ± 20% CGA6P3X8R1C106M250AB Page 13   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20150410 / mlcc_automotive_hightemp_en
CGA6M2NP02A333J200AA 价格&库存
很抱歉,暂时无法提供与“CGA6M2NP02A333J200AA”相匹配的价格&库存,您可以联系我们找货
