CGA6M2X8R1E225M200AD
    TDK(东电化)
    2.2 µF ±20% 25V 陶瓷电容器 X8R 1210(3225 公制)
CGA6M2X8R1E225M200AD 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS May 2019 MULTILAYER CERAMIC CHIP CAPACITORS Automotive grade, conductive epoxy application  CGA series CGA2 CGA3 CGA4 CGA5 CGA6 1005 [0402 inch] 1608 [0603 inch] 2012 [0805 inch] 3216 [1206 inch] 3225 [1210 inch] * Dimensions code: JIS[EIA] (2/16) MULTILAYER CERAMIC CHIP CAPACITORS REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS 1. The products listed in this specification are intended for use in automotive applications under normal operation and usage conditions. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality requires a more stringent level of safety or reliability, or whose failure, malfunction or defect could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in this specification, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (excepting Pharmaceutical Affairs Law classification Class1,2) (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 2. 3. 4. 5. 6. 7. In addition, although the products listed in this specification are intended for use in automotive applications as described above, they are not prohibited to use in general electronic equipment, whose performance and/or quality doesn’t require a more stringent level of safety or reliability, or whose failure, malfunction or defect could not cause serious damage to society, person or property. Therefore, the description of this caution will be applied, when the products are used in general electronic equipment under a normal operation and usage conditions. We may modify products or discontinue production of a product listed in this catalog without prior notification. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export permission in harmony with this law. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging specification detail. This new catalog number should be referenced on all catalog orders going forward, and is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will differ from the item description (internal control number) on the product label. Contact your local TDK Sales representative for more information. (Example) Catalog issued date Prior to January 2013 January 2013 and later Catalog number C1608C0G1E103J(080AA) C1608C0G1E103J080AA Item description (on delivery label) C1608C0G1E103JT000N C1608C0G1E103JT000N 20190508 / mlcc_automotive_epoxy_en.fm (3/16) MULTILAYER CERAMIC CHIP CAPACITORS CGA series Cl Br Conductive epoxy application RoHS REACH Halogen Free SVHC-Free Pb Lead Free Type: CGA2/1005 [0402 inch], CGA3/1608 [0603 inch], CGA4/2012 [0805 inch], CGA5/3216 [1206 inch], CGA6/3225 [1210 inch] ■ SERIES OVERVIEW Conductive epoxy application CGA series, automotive grade of TDK's multilayer ceramic chip capacitor, is a product for conductive glue mounting, not for solder mounting. The risk of silver migration is reduced due to AgPdCu termination. The maximum operating temperature is 150°C and the capacitance range is up to 10µF. ■ FEATURES ■ APPLICATIONS • The risk of silver migration is reduced due to AgPdCu termination. • The maximum operating temperature is 150°C (X8R). • C0G temperature characteristic which has excellent stable temperature and DC-bias characteristics is available. • AEC-Q200 compliant. • For only conductive glue mounting, not for solder mounting. • ABS, transmission, engine sensors, etc. ■ SHAPE & DIMENSIONS ■ PRODUCT STRUCTURE General type Conductive epoxy type W L T Sn Ni Cu G B L W T B G Body length Body width Body height Terminal width Terminal spacing Type L W CGA2 1.00±0.15 0.50±0.10 CGA3 1.60±0.15 0.80±0.15 CGA4 2.00±0.25 1.25±0.25 CGA5 3.20+0.30,-0.10 1.60+0.30,-0.10 CGA6 3.20±0.45 2.50±0.30 Dimensional tolerances are typical values. Termination consists of 3 layers by Cu, Ni and Sn. T 0.50±0.10 0.80±0.15 1.25±0.25 1.60+0.30,-0.10 2.50±0.30 AgPdCu Cu The risk of silver migration is reduced due to AgPdCu termination. Dimensions in mm B G 0.10min. 0.30min. 0.20min. 0.30min. 0.20min. 0.50min. 0.20min. 1.00min. 0.20min. — Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190508 / mlcc_automotive_epoxy_en.fm (4/16) MULTILAYER CERAMIC CHIP CAPACITORS ■ CATALOG NUMBER CONSTRUCTION CGA 6 P 1 X8R 1E 106 K 250 A D (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (1) Series (2) Dimensions L x W (mm) Code 2 3 4 5 6 EIA CC0402 CC0603 CC0805 CC1206 CC1210 Length 1.00 1.60 2.00 3.20 3.20 Width 0.50 0.80 1.25 1.60 2.50 Terminal width 0.10 0.20 0.20 0.20 0.20 (7) Nominal capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. (Example)0R5 = 0.5pF 101 = 100pF 225 = 2,200,000pF = 2.2µF (3) Thickness code (8) Capacitance tolerance Code B C E F H J L M P Code C D J K M Thickness 0.50mm 0.60mm 0.80mm 0.85mm 1.15mm 1.25mm 1.60mm 2.00mm 2.50mm (9) Thickness Code 050 060 080 085 115 125 160 200 250 (4) Voltage condition for life test Symbol 1 2 3 Condition 1 × R.V. 2 × R.V. 1.5 × R.V. (5) Temperature characteristics Temperature characteristics C0G X7R X8R Temperature coefficient or capacitance change 0±30 ppm/°C ±15% ±15% Tolerance ±0.25pF ±0.50pF ±5% ±10% ±20% Temperature range –55 to +125°C –55 to +125°C –55 to +150°C Thickness 0.50mm 0.60mm 0.80mm 0.85mm 1.15mm 1.25mm 1.60mm 2.00mm 2.50mm (10) Packaging style Code A B Style 178mm reel, 4mm pitch 178mm reel, 2mm pitch (11) Special reserved code (6) Rated voltage (DC) Code 0J 1C 1E 1V 1H 2A Voltage (DC) 6.3V 16V 25V 35V 50V 100V Code D Description Conductive epoxy application Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190508 / mlcc_automotive_epoxy_en.fm (5/16) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance C0G (pF) 1H (50V) Code 1 1.5 2 2.2 3 3.3 4 4.7 5 6 6.8 7 8 9 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 CGA2/1005 [0402 inch] X7R 1H (50V) 1E (25V) X8R 1C (16V) 1H (50V) 1E (25V) 1C (16V) 010 1R5 020 2R2 030 3R3 040 4R7 050 060 6R8 070 080 090 100 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 152 222 332 472 682 103 153 223 333 473 683 104 Standard thickness   0.50mm Background gray: The product which is not recommended to a new design. ■ Please refer to the capacitance range table at P-10 and after for the details such as product thickness and capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190508 / mlcc_automotive_epoxy_en.fm (6/16) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) Code 1 1.5 2 2.2 3 3.3 4 4.7 5 6 6.8 7 8 9 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1000 1200 1500 1800 2200 2700 3300 3900 4700 5600 6800 8200 10000 C0G 2A (100V) 1H (50V) CGA3/1608 [0603 inch] X7R 1H (50V) X8R 2A (100V) 1H (50V) 010 1R5 020 2R2 030 3R3 040 4R7 050 060 6R8 070 080 090 100 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 Standard thickness  0.80mm Background gray: The product which is not recommended to a new design. ■ Please refer to the capacitance range table at P-10 and after for the details such as product thickness and capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190508 / mlcc_automotive_epoxy_en.fm (7/16) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) Code 15000 22000 33000 47000 68000 100000 150000 220000 330000 470000 680000 1000000 CGA3/1608 [0603 inch] X7R 1H (50V) 1V (35V) 1E (25V) X8R 1C (16V) 2A (100V) 1H (50V) 1E (25V) 1C (16V) 153 223 333 473 683 104 154 224 334 474 684 105 Standard thickness  0.80mm Background gray: The product which is not recommended to a new design. ■ Please refer to the capacitance range table at P-10 and after for the details such as product thickness and capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190508 / mlcc_automotive_epoxy_en.fm (8/16) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance C0G (pF) 1H (50V) Code 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 CGA4/2012 [0805 inch] X7R 1H (50V) 1E (25V) 1C (16V) X8R 0J (6.3V) 2A (100V) 1H (50V) 1E (25V) 1C (16V) 272 332 392 472 562 682 822 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 335 475 685 106 Standard thickness   0.60 mm  0.85 mm  1.25 mm Background gray: The product which is not recommended to a new design. ■ Please refer to the capacitance range table at P-10 and after for the details such as product thickness and capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190508 / mlcc_automotive_epoxy_en.fm (9/16) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance C0G (pF) 1H (50V) Code 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 CGA5/3216 [1206 inch] X7R 1H (50V) X8R 1E (25V) 1C (16V) 2A (100V) 1H (50V) 1E (25V) 1C (16V) 472 562 682 822 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 335 475 685 106 Standard thickness   0.60 mm  0.85 mm  1.15 mm  1.60 mm Background gray: The product which is not recommended to a new design. ■ Please refer to the capacitance range table at P-10 and after for the details such as product thickness and capacitance tolerance. Capacitance range chart Capacitance (pF) 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 Code CGA6/3225 [1210 inch] X7R 1H (50V) 1E (25V) X8R 2A (100V) 1E (25V) 1C (16V) 474 684 105 155 225 335 475 685 106 Standard thickness   1.60 mm  2.00 mm  2.50 mm ■ Please refer to the capacitance range table at P-10 and after for the details such as product thickness and capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190508 / mlcc_automotive_epoxy_en.fm (10/16) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions 1pF 1.5pF 2pF 2.2pF 3pF 3.3pF 4pF 4.7pF 5pF 6pF 6.8pF 7pF 8pF 9pF 10pF 12pF 15pF 18pF 22pF 27pF 33pF 39pF 47pF 56pF 68pF 82pF 100pF 120pF 150pF 180pF 220pF 270pF 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 Thickness (mm) Capacitance tolerance 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.50pF ±0.50pF ±0.50pF ±0.50pF ±0.50pF ±0.50pF ±0.50pF ±0.50pF ±0.50pF ±0.50pF ±0.50pF ±0.50pF ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% Temperature characteristics: C0G (–55 to +125°C, 0±30ppm/°C) Catalog number Rated voltage Edc: 100V CGA3E2C0G2A010C080AD CGA3E2C0G2A1R5C080AD CGA3E2C0G2A020C080AD CGA3E2C0G2A2R2C080AD CGA3E2C0G2A030C080AD CGA3E2C0G2A3R3C080AD CGA3E2C0G2A040C080AD CGA3E2C0G2A4R7C080AD CGA3E2C0G2A050C080AD CGA3E2C0G2A060D080AD CGA3E2C0G2A6R8D080AD CGA3E2C0G2A070D080AD CGA3E2C0G2A080D080AD CGA3E2C0G2A090D080AD CGA3E2C0G2A100D080AD CGA3E2C0G2A120J080AD CGA3E2C0G2A150J080AD CGA3E2C0G2A180J080AD CGA3E2C0G2A220J080AD CGA3E2C0G2A270J080AD CGA3E2C0G2A330J080AD CGA3E2C0G2A390J080AD CGA3E2C0G2A470J080AD CGA3E2C0G2A560J080AD CGA3E2C0G2A680J080AD CGA3E2C0G2A820J080AD CGA3E2C0G2A101J080AD CGA3E2C0G2A121J080AD CGA3E2C0G2A151J080AD CGA3E2C0G2A181J080AD CGA3E2C0G2A221J080AD CGA3E2C0G2A271J080AD   Rated voltage Edc: 50V CGA2B2C0G1H010C050BD CGA3E2C0G1H010C080AD CGA2B2C0G1H1R5C050BD CGA3E2C0G1H1R5C080AD CGA2B2C0G1H020C050BD CGA3E2C0G1H020C080AD CGA2B2C0G1H2R2C050BD CGA3E2C0G1H2R2C080AD CGA2B2C0G1H030C050BD CGA3E2C0G1H030C080AD CGA2B2C0G1H3R3C050BD CGA3E2C0G1H3R3C080AD CGA2B2C0G1H040C050BD CGA3E2C0G1H040C080AD CGA2B2C0G1H4R7C050BD CGA3E2C0G1H4R7C080AD CGA2B2C0G1H050C050BD CGA3E2C0G1H050C080AD CGA2B2C0G1H060D050BD CGA3E2C0G1H060D080AD CGA2B2C0G1H6R8D050BD CGA3E2C0G1H6R8D080AD CGA2B2C0G1H070D050BD CGA3E2C0G1H070D080AD CGA2B2C0G1H080D050BD CGA3E2C0G1H080D080AD CGA2B2C0G1H090D050BD CGA3E2C0G1H090D080AD CGA2B2C0G1H100D050BD CGA3E2C0G1H100D080AD CGA2B2C0G1H120J050BD CGA3E2C0G1H120J080AD CGA2B2C0G1H150J050BD CGA3E2C0G1H150J080AD CGA2B2C0G1H180J050BD CGA3E2C0G1H180J080AD CGA2B2C0G1H220J050BD CGA3E2C0G1H220J080AD CGA2B2C0G1H270J050BD CGA3E2C0G1H270J080AD CGA2B2C0G1H330J050BD CGA3E2C0G1H330J080AD CGA2B2C0G1H390J050BD CGA3E2C0G1H390J080AD CGA2B2C0G1H470J050BD CGA3E2C0G1H470J080AD CGA2B2C0G1H560J050BD CGA3E2C0G1H560J080AD CGA2B2C0G1H680J050BD CGA3E2C0G1H680J080AD CGA2B2C0G1H820J050BD CGA3E2C0G1H820J080AD CGA2B2C0G1H101J050BD CGA3E2C0G1H101J080AD CGA2B2C0G1H121J050BD CGA3E2C0G1H121J080AD CGA2B2C0G1H151J050BD CGA3E2C0G1H151J080AD CGA2B2C0G1H181J050BD CGA3E2C0G1H181J080AD CGA2B2C0G1H221J050BD CGA3E2C0G1H221J080AD CGA2B2C0G1H271J050BD CGA3E2C0G1H271J080AD ■ Gray item: The product which is not recommended to a new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190508 / mlcc_automotive_epoxy_en.fm (11/16) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions 330pF 390pF 470pF 560pF 680pF 820pF 1nF 1.2nF 1.5nF 1.8nF 2.2nF 2.7nF 3.3nF 3.9nF 4.7nF 5.6nF 6.8nF 8.2nF 10nF 15nF 22nF 33nF 47nF 68nF 100nF 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1608 1608 1608 1608 1608 2012 1608 2012 1608 2012 1608 2012 3216 1608 2012 3216 1608 2012 3216 1608 2012 3216 1608 2012 3216 2012 3216 2012 3216 2012 3216 3216 3216 3216 Thickness (mm) Capacitance tolerance 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.50±0.10 0.80±0.15 0.80±0.15 0.80±0.15 0.80±0.15 0.80±0.15 0.80±0.15 0.60±0.15 0.80±0.15 0.60±0.15 0.80±0.15 0.60±0.15 0.80±0.15 0.60±0.15 0.60±0.15 0.80±0.15 0.60±0.15 0.60±0.15 0.80±0.15 0.60±0.15 0.60±0.15 0.80±0.15 0.60±0.15 0.60±0.15 0.80±0.15 0.60±0.15 0.60±0.15 0.85±0.15 0.60±0.15 1.25±0.25 0.60±0.15 1.25±0.25 0.85±0.15 1.15±0.15 1.60+0.30,-0.10 1.60+0.30,-0.10 ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% Temperature characteristics: C0G (–55 to +125°C, 0±30ppm/°C) Catalog number Rated voltage Edc: 100V CGA3E2C0G2A331J080AD CGA3E2C0G2A391J080AD CGA3E2C0G2A471J080AD CGA3E2C0G2A561J080AD CGA3E2C0G2A681J080AD CGA3E2C0G2A821J080AD CGA3E2C0G2A102J080AD CGA3E2C0G2A122J080AD   Rated voltage Edc: 50V CGA2B2C0G1H331J050BD CGA3E2C0G1H331J080AD CGA2B2C0G1H391J050BD CGA3E2C0G1H391J080AD CGA2B2C0G1H471J050BD CGA3E2C0G1H471J080AD CGA2B2C0G1H561J050BD CGA3E2C0G1H561J080AD CGA2B2C0G1H681J050BD CGA3E2C0G1H681J080AD CGA2B2C0G1H821J050BD CGA3E2C0G1H821J080AD CGA2B2C0G1H102J050BD CGA3E2C0G1H102J080AD CGA3E2C0G1H122J080AD CGA3E2C0G1H152J080AD CGA3E2C0G1H182J080AD CGA3E2C0G1H222J080AD CGA3E2C0G1H272J080AD CGA4C2C0G1H272J060AD CGA3E2C0G1H332J080AD CGA4C2C0G1H332J060AD CGA3E2C0G1H392J080AD CGA4C2C0G1H392J060AD CGA3E2C0G1H472J080AD CGA4C2C0G1H472J060AD CGA5C2C0G1H472J060AD CGA3E2C0G1H562J080AD CGA4C2C0G1H562J060AD CGA5C2C0G1H562J060AD CGA3E2C0G1H682J080AD CGA4C2C0G1H682J060AD CGA5C2C0G1H682J060AD CGA3E2C0G1H822J080AD CGA4C2C0G1H822J060AD CGA5C2C0G1H822J060AD CGA3E2C0G1H103J080AD CGA4C2C0G1H103J060AD CGA5C2C0G1H103J060AD CGA4F2C0G1H153J085AD CGA5C2C0G1H153J060AD CGA4J2C0G1H223J125AD CGA5C2C0G1H223J060AD CGA4J2C0G1H333J125AD CGA5F2C0G1H333J085AD CGA5H2C0G1H473J115AD CGA5L2C0G1H683J160AD CGA5L2C0G1H104J160AD ■ Gray item: The product which is not recommended to a new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190508 / mlcc_automotive_epoxy_en.fm (12/16) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions 1nF 1608 Thickness (mm) 0.80±0.15 1.5nF 1608 0.80±0.15 2.2nF 1608 0.80±0.15 3.3nF 1608 0.80±0.15 4.7nF 1608 0.80±0.15 6.8nF 1608 0.80±0.15 1005 0.50±0.10 1608 0.80±0.15 1005 0.50±0.10 1608 0.80±0.15 1005 0.50±0.10 1608 0.80±0.15 1005 0.50±0.10 1608 0.80±0.15 1005 0.50±0.10 1608 0.80±0.15 1005 0.50±0.10 1608 0.80±0.15 1005 0.50±0.10 1608 0.80±0.15 1608 0.80±0.15 2012 1.25±0.25 1608 0.80±0.15 2012 1.25±0.25 1608 0.80±0.15 2012 1.25±0.25 1608 0.80±0.15 2012 1.25±0.25 3216 1.60+0.30,-0.10 1608 0.80±0.15 2012 1.25±0.25 3216 1.60+0.30,-0.10 10nF 15nF 22nF 33nF 47nF 68nF 100nF 150nF 220nF 330nF 470nF 680nF Temperature characteristics: X7R (–55 to +125°C, ±15%) Capacitance tolerance Catalog number Rated voltage Edc: 50V ±10% CGA3E2X7R1H102K080AD ±20% CGA3E2X7R1H102M080AD ±10% CGA3E2X7R1H152K080AD ±20% CGA3E2X7R1H152M080AD ±10% CGA3E2X7R1H222K080AD ±20% CGA3E2X7R1H222M080AD ±10% CGA3E2X7R1H332K080AD ±20% CGA3E2X7R1H332M080AD ±10% CGA3E2X7R1H472K080AD ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% CGA3E2X7R1H472M080AD CGA3E2X7R1H682K080AD CGA3E2X7R1H682M080AD CGA2B3X7R1H103K050BD CGA2B3X7R1H103M050BD CGA3E2X7R1H103K080AD CGA3E2X7R1H103M080AD CGA2B3X7R1H153K050BD CGA2B3X7R1H153M050BD CGA3E2X7R1H153K080AD CGA3E2X7R1H153M080AD CGA2B3X7R1H223K050BD CGA2B3X7R1H223M050BD CGA3E2X7R1H223K080AD CGA3E2X7R1H223M080AD CGA2B3X7R1H333K050BD CGA2B3X7R1H333M050BD CGA3E2X7R1H333K080AD CGA3E2X7R1H333M080AD CGA2B3X7R1H473K050BD CGA2B3X7R1H473M050BD CGA3E2X7R1H473K080AD CGA3E2X7R1H473M080AD CGA2B3X7R1H683K050BD CGA2B3X7R1H683M050BD CGA3E2X7R1H683K080AD CGA3E2X7R1H683M080AD CGA2B3X7R1H104K050BD CGA2B3X7R1H104M050BD CGA3E2X7R1H104K080AD CGA3E2X7R1H104M080AD CGA3E3X7R1H154K080AD CGA3E3X7R1H154M080AD CGA4J2X7R1H154K125AD CGA4J2X7R1H154M125AD CGA3E3X7R1H224K080AD CGA3E3X7R1H224M080AD CGA4J2X7R1H224K125AD CGA4J2X7R1H224M125AD Rated voltage Edc: 35V Rated voltage Edc: 25V Rated voltage Edc: 16V CGA2B2X7R1E153K050BD CGA2B2X7R1E153M050BD CGA2B2X7R1E223K050BD CGA2B2X7R1E223M050BD CGA2B2X7R1C333K050BD CGA2B2X7R1C333M050BD CGA3E2X7R1E154K080AD CGA3E2X7R1E154M080AD CGA3E2X7R1C224K080AD CGA3E2X7R1C224M080AD CGA3E1X7R1V334K080AD CGA3E1X7R1V334M080AD CGA3E3X7R1E334K080AD CGA3E3X7R1E334M080AD CGA3E1X7R1V474K080AD CGA3E1X7R1V474M080AD CGA3E3X7R1E474K080AD CGA3E3X7R1E474M080AD CGA4J2X7R1E474K125AD CGA4J2X7R1E474M125AD CGA4J2X7R1H334K125AD CGA4J2X7R1H334M125AD CGA5L2X7R1H474K160AD CGA5L2X7R1H474M160AD CGA3E1X7R1E684K080AD CGA3E1X7R1E684M080AD CGA4J3X7R1E684K125AD CGA4J3X7R1E684M125AD CGA4J2X7R1C684K125AD CGA4J2X7R1C684M125AD CGA5L2X7R1H684K160AD CGA5L2X7R1H684M160AD ■ Gray item: The product which is not recommended to a new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190508 / mlcc_automotive_epoxy_en.fm (13/16) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions Thickness (mm) 1608 0.80±0.15 2012 1.25±0.25 3216 1.60+0.30,-0.10 3225 1.60±0.20 2012 1.25±0.25 3225 2.00±0.20 2012 1.25±0.25 3216 1.60+0.30,-0.10 2012 1.25±0.25 2012 1.25+0.30,-0.25 3216 1.60+0.30,-0.10 1µF 1.5µF 2.2µF 3.3µF 4.7µF 2.00±0.20 3225 2.50±0.30 2012 1.25±0.25 3216 1.60+0.30,-0.10 2012 1.25±0.25 3216 1.60+0.30,-0.10 6.8µF 10µF Capacitance tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Temperature characteristics: X7R (–55 to +125°C, ±15%) Catalog number Rated voltage Edc: 50V Rated voltage Edc: 25V Rated voltage Edc: 16V CGA3E1X7R1E105K080AD CGA3E1X7R1E105M080AD CGA4J3X7R1E105K125AD CGA4J3X7R1E105M125AD CGA5L2X7R1E105K160AD CGA5L2X7R1E105M160AD CGA4J2X7R1C105K125AD CGA4J2X7R1C105M125AD Rated voltage Edc: 6.3V CGA6L2X7R1H105K160AD CGA6L2X7R1H105M160AD CGA4J1X7R1E155K125AD CGA4J1X7R1E155M125AD CGA6M2X7R1H155K200AD CGA6M2X7R1H155M200AD CGA4J3X7R1E225K125AD CGA4J3X7R1E225M125AD CGA5L2X7R1E225K160AD CGA5L2X7R1E225M160AD CGA4J1X7R1E335K125AD CGA4J1X7R1E335M125AD CGA4J1X7R1E475K125AD CGA4J1X7R1E475M125AD CGA4J3X7R1C335K125AD CGA4J3X7R1C335M125AD CGA4J3X7R1C475K125AD CGA4J3X7R1C475M125AD CGA5L3X7R1C475K160AD CGA5L3X7R1C475M160AD CGA6M2X7R1E475K200AD CGA6M2X7R1E475M200AD CGA6P3X7R1H475K250AD CGA6P3X7R1H475M250AD CGA4J1X7R0J685K125AD CGA4J1X7R0J685M125AD CGA5L1X7R1E685K160AD CGA5L1X7R1E685M160AD CGA4J1X7R0J106K125AD CGA4J1X7R0J106M125AD CGA5L1X7R1E106K160AD CGA5L1X7R1E106M160AD Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190508 / mlcc_automotive_epoxy_en.fm (14/16) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions Thickness (mm) 150pF 1005 0.50±0.10 220pF 1005 0.50±0.10 330pF 1005 0.50±0.10 470pF 1005 0.50±0.10 680pF 1005 0.50±0.10 1005 0.50±0.10 1608 0.80±0.15 1005 0.50±0.10 1608 0.80±0.15 1005 0.50±0.10 1608 0.80±0.15 1005 0.50±0.10 1608 0.80±0.15 1005 0.50±0.10 1608 0.80±0.15 1005 0.50±0.10 1608 0.80±0.15 1005 0.50±0.10 1608 0.80±0.15 2012 0.85±0.15 1005 0.50±0.10 1608 0.80±0.15 2012 0.85±0.15 1005 0.50±0.10 1608 0.80±0.15 2012 1.25±0.25 1005 0.50±0.10 1608 0.80±0.15 2012 1.25±0.25 3216 0.85±0.15 1005 0.50±0.10 1608 0.80±0.15 2012 1.25±0.25 3216 0.85±0.15 1nF 1.5nF 2.2nF 3.3nF 4.7nF 6.8nF 10nF 15nF 22nF 33nF 47nF Capacitance tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Temperature characteristics: X8R (–55 to +150°C, ±15%) Catalog number Rated voltage Edc: 100V CGA3E2X8R2A102K080AD CGA3E2X8R2A102M080AD CGA3E2X8R2A152K080AD CGA3E2X8R2A152M080AD CGA3E2X8R2A222K080AD CGA3E2X8R2A222M080AD CGA3E2X8R2A332K080AD CGA3E2X8R2A332M080AD CGA3E2X8R2A472K080AD CGA3E2X8R2A472M080AD CGA3E2X8R2A682K080AD CGA3E2X8R2A682M080AD CGA3E2X8R2A103K080AD CGA3E2X8R2A103M080AD CGA4F2X8R2A103K085AD CGA4F2X8R2A103M085AD Rated voltage Edc: 50V CGA2B2X8R1H151K050BD CGA2B2X8R1H151M050BD CGA2B2X8R1H221K050BD CGA2B2X8R1H221M050BD CGA2B2X8R1H331K050BD CGA2B2X8R1H331M050BD CGA2B2X8R1H471K050BD CGA2B2X8R1H471M050BD CGA2B2X8R1H681K050BD CGA2B2X8R1H681M050BD CGA2B2X8R1H102K050BD CGA2B2X8R1H102M050BD CGA3E2X8R1H102K080AD CGA3E2X8R1H102M080AD CGA2B2X8R1H152K050BD CGA2B2X8R1H152M050BD CGA3E2X8R1H152K080AD CGA3E2X8R1H152M080AD CGA2B2X8R1H222K050BD CGA2B2X8R1H222M050BD CGA3E2X8R1H222K080AD CGA3E2X8R1H222M080AD CGA2B2X8R1H332K050BD CGA2B2X8R1H332M050BD CGA3E2X8R1H332K080AD CGA3E2X8R1H332M080AD CGA2B2X8R1H472K050BD CGA2B2X8R1H472M050BD CGA3E2X8R1H472K080AD CGA3E2X8R1H472M080AD CGA2B3X8R1H682K050BD CGA2B3X8R1H682M050BD CGA3E2X8R1H682K080AD CGA3E2X8R1H682M080AD CGA2B3X8R1H103K050BD CGA2B3X8R1H103M050BD CGA3E2X8R1H103K080AD CGA3E2X8R1H103M080AD Rated voltage Edc: 25V Rated voltage Edc: 16V CGA2B2X8R1E682K050BD CGA2B2X8R1E682M050BD CGA2B2X8R1E103K050BD CGA2B2X8R1E103M050BD CGA2B3X8R1E153K050BD CGA2B3X8R1E153M050BD CGA3E2X8R2A153K080AD CGA3E2X8R2A153M080AD CGA4F2X8R2A153K085AD CGA4F2X8R2A153M085AD CGA3E2X8R1H153K080AD CGA3E2X8R1H153M080AD CGA2B3X8R1E223K050BD CGA2B3X8R1E223M050BD CGA3E3X8R2A223K080AD CGA3E3X8R2A223M080AD CGA4J2X8R2A223K125AD CGA4J2X8R2A223M125AD CGA3E3X8R2A333K080AD CGA3E3X8R2A333M080AD CGA4J3X8R2A333K125AD CGA4J3X8R2A333M125AD CGA5F2X8R2A333K085AD CGA5F2X8R2A333M085AD CGA3E2X8R1H223K080AD CGA3E2X8R1H223M080AD CGA2B1X8R1E333K050BD CGA2B1X8R1E333M050BD CGA2B3X8R1C333K050BD CGA2B3X8R1C333M050BD CGA2B1X8R1E473K050BD CGA2B1X8R1E473M050BD CGA2B3X8R1C473K050BD CGA2B3X8R1C473M050BD CGA3E2X8R1H333K080AD CGA3E2X8R1H333M080AD CGA3E2X8R1H473K080AD CGA3E2X8R1H473M080AD CGA4J3X8R2A473K125AD CGA4J3X8R2A473M125AD CGA5F2X8R2A473K085AD CGA5F2X8R2A473M085AD ■ Gray item: The product which is not recommended to a new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190508 / mlcc_automotive_epoxy_en.fm (15/16) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions 68nF 100nF Thickness (mm) 1608 0.80±0.15 2012 1.25±0.25 3216 1.15±0.15 1608 0.80±0.15 2012 1.25±0.25 3216 1.15±0.15 1608 0.80±0.15 0.85±0.15 2012 150nF 1.25±0.25 0.85±0.15 3216 1.60+0.30,-0.10 1608 0.80±0.15 2012 1.25±0.25 220nF 1.15±0.15 3216 1.60+0.30,-0.10 1608 0.80±0.15 2012 1.25±0.25 330nF 0.85±0.15 3216 1.60+0.30,-0.10 1608 0.80±0.15 2012 1.25±0.25 470nF 0.85±0.15 3216 1.60+0.30,-0.10 3225 2.00±0.20 2012 1.25±0.25 1.15±0.15 680nF 3216 1.60+0.30,-0.10 3225 2.50±0.30 2012 1.25±0.25 3216 1.60+0.30,-0.10 3216 1.60+0.30,-0.10 3225 1.60±0.20 3216 1.60+0.30,-0.10 3225 2.00±0.20 1µF 1.5µF 2.2µF Capacitance tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Temperature characteristics: X8R (–55 to +150°C, ±15%) Catalog number Rated voltage Edc: 100V CGA4J3X8R2A683K125AD CGA4J3X8R2A683M125AD CGA5H2X8R2A683K115AD CGA5H2X8R2A683M115AD Rated voltage Edc: 50V Rated voltage Edc: 25V CGA3E3X8R1H683K080AD CGA3E3X8R1H683M080AD CGA4J2X8R1H683K125AD CGA4J2X8R1H683M125AD CGA3E2X8R1E683K080AD CGA3E2X8R1E683M080AD CGA3E3X8R1H104K080AD CGA3E3X8R1H104M080AD CGA4J2X8R1H104K125AD CGA4J2X8R1H104M125AD CGA3E2X8R1E104K080AD CGA3E2X8R1E104M080AD Rated voltage Edc: 16V CGA5H2X8R2A104K115AD CGA5H2X8R2A104M115AD CGA3E3X8R1E154K080AD CGA3E3X8R1E154M080AD CGA4F2X8R1E154K085AD CGA4F2X8R1E154M085AD CGA4J3X8R1H154K125AD CGA4J3X8R1H154M125AD CGA5F2X8R1H154K085AD CGA5F2X8R1H154M085AD CGA5L2X8R2A154K160AD CGA5L2X8R2A154M160AD CGA4J3X8R1H224K125AD CGA4J3X8R1H224M125AD CGA5H2X8R1H224K115AD CGA5H2X8R1H224M115AD CGA3E3X8R1E224K080AD CGA3E3X8R1E224M080AD CGA4J2X8R1E224K125AD CGA4J2X8R1E224M125AD CGA5L3X8R2A224K160AD CGA5L3X8R2A224M160AD CGA3E1X8R1E334K080AD CGA3E1X8R1E334M080AD CGA4J2X8R1E334K125AD CGA4J2X8R1E334M125AD CGA5F2X8R1E334K085AD CGA5F2X8R1E334M085AD CGA5L3X8R2A334K160AD CGA5L3X8R2A334M160AD CGA3E3X8R1C334K080AD CGA3E3X8R1C334M080AD CGA5L2X8R1H334K160AD CGA5L2X8R1H334M160AD CGA3E3X8R1C474K080AD CGA3E3X8R1C474M080AD CGA4J3X8R1E474K125AD CGA4J3X8R1E474M125AD CGA5F2X8R1E474K085AD CGA5F2X8R1E474M085AD CGA5L2X8R1H474K160AD CGA5L2X8R1H474M160AD CGA6M3X8R2A474K200AD CGA6M3X8R2A474M200AD CGA4J1X8R1E684K125AD CGA4J1X8R1E684M125AD CGA5H2X8R1E684K115AD CGA5H2X8R1E684M115AD CGA4J3X8R1C684K125AD CGA4J3X8R1C684M125AD CGA4J1X8R1E105K125AD CGA4J1X8R1E105M125AD CGA5L2X8R1E105K160AD CGA5L2X8R1E105M160AD CGA5L3X8R1E155K160AD CGA5L3X8R1E155M160AD CGA6L2X8R1E155K160AD CGA6L2X8R1E155M160AD CGA5L3X8R1E225K160AD CGA5L3X8R1E225M160AD CGA6M2X8R1E225K200AD CGA6M2X8R1E225M200AD CGA4J3X8R1C105K125AD CGA4J3X8R1C105M125AD CGA5L3X8R1H684K160AD CGA5L3X8R1H684M160AD CGA6P3X8R2A684K250AD CGA6P3X8R2A684M250AD CGA5L3X8R1H105K160AD CGA5L3X8R1H105M160AD ■ Gray item: The product which is not recommended to a new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190508 / mlcc_automotive_epoxy_en.fm (16/16) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions Thickness (mm) 3216 1.60+0.30,-0.10 3225 2.50±0.30 3216 1.60+0.30,-0.10 3225 2.50±0.30 6.8µF 3225 2.00±0.20 10µF 3225 2.50±0.30 3.3µF 4.7µF Temperature characteristics: X8R (–55 to +150°C, ±15%) Capacitance tolerance Catalog number Rated voltage Edc: 25V ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% CGA5L1X8R1E335K160AD CGA5L1X8R1E335M160AD CGA6P2X8R1E335K250AD CGA6P2X8R1E335M250AD CGA5L1X8R1E475K160AD CGA5L1X8R1E475M160AD CGA6P3X8R1E475K250AD CGA6P3X8R1E475M250AD CGA6M1X8R1E685K200AD CGA6M1X8R1E685M200AD CGA6P1X8R1E106K250AD CGA6P1X8R1E106M250AD Rated voltage Edc: 16V CGA5L3X8R1C335K160AD CGA5L3X8R1C335M160AD CGA5L3X8R1C475K160AD CGA5L3X8R1C475M160AD CGA6M3X8R1C685K200AD CGA6M3X8R1C685M200AD CGA6P3X8R1C106K250AD CGA6P3X8R1C106M250AD Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20190508 / mlcc_automotive_epoxy_en.fm
CGA6M2X8R1E225M200AD 价格&库存
很抱歉,暂时无法提供与“CGA6M2X8R1E225M200AD”相匹配的价格&库存,您可以联系我们找货
