CGA6P1X7S0J476MTJY0N
    TDK(东电化)
    47UF ±20% 6.3V
CGA6P1X7S0J476MTJY0N 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS December 2024 MULTILAYER CERAMIC CHIP CAPACITORS Automotive grade, soft termination CGA series CGA2 1005 [0402 inch] CGA3 1608 [0603 inch] CGA4 2012 [0805 inch] CGA5 3216 [1206 inch] CGA6 3225 [1210 inch] CGA7 4520 [1808 inch] CGA8 4532 [1812 inch] CGA9 5750 [2220 inch] CGAD 7563 [3025 inch] * Dimensions code: JIS[EIA] (2/19) MULTILAYER CERAMIC CHIP CAPACITORS REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products REMINDERS 1. The products listed in this specification are intended for use in automotive applications under normal operation and usage conditions. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality requires a more stringent level of safety or reliability, or whose failure, malfunction or defect could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in this specification, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (excepting Pharmaceutical Affairs Law classification Class1,2) (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment involving the Products, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc. in your equipment, to ensure higher safety. 2. We may modify products or discontinue production of a product listed in this catalog without prior notification. 3. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. 4. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export permission in harmony with this law. 5. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. 6. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. 7. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging specification detail. This new catalog number should be referenced on all catalog orders going forward, and is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will differ from the item description (internal control number) on the product label. Contact your local TDK Sales representative for more information. (Example) Catalog issued date Catalog number Item description (on delivery label) Prior to January 2013 January 2013 and later C1608C0G1E103J(080AA) C1608C0G1E103J080AA C1608C0G1E103JT000N C1608C0G1E103JT000N Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20241209 / mlcc_automotive_soft_en (3/19) MULTILAYER CERAMIC CHIP CAPACITORS CGA series soft termination Type: CGA2/1005 [0402 inch]、CGA3/1608 [0603 inch]、CGA4/2012 [0805 inch]、 CGA5/3216 [1206 inch]、CGA6/3225 [1210 inch]、CGA7/4520 [1808 inch]、 CGA8/4532 [1812 inch]、CGA9/5750 [2220 inch]、CGAD/7563 [3025 inch] ■SERIES OVERVIEW Automotive grade Soft termination CGA series is a product incorporating a conductive resin layer into the terminal electrodes. The resin layer protects the ceramic body from cracks by relieving stress caused by thermal shock and board flexure. ■FEATURES ■APPLICATION ⃝High resistance to mechanical stress and thermal shock by resin layers ⃝X8R and X8L type whose maximum temperature are up to 150°C are available ⃝C0G type having excellent stable temperature and DCbias characteristics is also available ⃝Qualified based on AEC-Q200 ⃝Qualified based on VW80808-2 (Qualification of MLCCs with Soft Termination) *Rated voltage is 100V or less ■SHAPE & DIMENSIONS ■TERMINAL ELECTRODE STRUCTURES W L ⃝Fail-safe design for battery line ⃝Prevention of ceramic element crack by board bending ⃝Prevention of solder crack by thermal shock ⃝Equipment such as mobile devices and smart key having a high possibility of drop General type Soft termination T Sn Ni Conductive resin layer Cu G B L W T B G Body length Body width Body height Terminal width Terminal spacing 3-layer structure of Cu, Ni and Sn. 4-layer structure including conductive resin layer. Dimensions in mm Type L W CGA2 1.00+0.15,-0.05 0.50+0.10,-0.05 CGA3 1.60+0.20,-0.10 0.80+0.15,-0.10 CGA4 2.00+0.45,-0.20 1.25+0.25,-0.20 CGA5 3.20+0.40,-0.20 1.60+0.30,-0.20 CGA6 3.20+0.50,-0.40 2.50±0.30 CGA7 4.50+0.50,-0.40 2.00+0.30,-0.20 CGA8 4.50+0.50,-0.40 3.20±0.40 CGA9 5.70+0.50,-0.40 5.00±0.40 CGAD 7.50±0.50 6.30±0.50 * Dimensional tolerances are typical values. T B G 0.50+0.10,-0.05 0.80+0.15,-0.10 1.25+0.25,-0.20 1.60+0.30,-0.20 2.50±0.30 1.30±0.20 2.50±0.30 2.50±0.30 2.50 max. 0.10 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.30 min. 0.30 min. 0.30 min. 0.50 min. 1.00 min. — — — — — Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20241209 / mlcc_automotive_soft_en (4/19) MULTILAYER CERAMIC CHIP CAPACITORS ■CATALOG NUMBER CONSTRUCTION CGA 4 J 1 X7R 0J 106 K 125 A E (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (6)Rated voltage (DC) (1)Series (2)Dimensions L x W (mm) Code EIA Length Width Terminal width 2 3 4 5 6 7 8 9 D CC0402 CC0603 CC0805 CC1206 CC1210 CC1808 CC1812 CC2220 CC3025 1.00 1.60 2.00 3.20 3.20 4.50 4.50 5.70 7.50 0.50 0.80 1.25 1.60 2.50 2.00 3.20 5.00 6.30 0.10 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.30 (3)Thickness code Code Thickness B C E F H J K L M N P 0.50 mm 0.60 mm 0.80 mm 0.85 mm 1.15 mm 1.25 mm 1.30 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm Code Voltage (DC) 0J 1A 1C 1E 1V 1H 1N 2A 2E 2W 2J 3A 3D 3F 6.3V 10V 16V 25V 35V 50V 75V 100V 250V 450V 630V 1000V 2000V 3000V (7)Nominal capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. (Example)0R5 = 0.5pF 101 = 100pF 225 = 2,200,000pF = 2.2μF (8)Capacitance tolerance (4)Voltage condition for life test Code Tolerance Symbol Condition 1 2 3 4 1 x R.V. 2 x R.V. 1.5 x R.V. 1.2 x R.V. G J K M ±2% ±5% ±10% ±20% (9)Thickness (5)Temperature characteristics Code Thickness Temperature characteristics Temperature coefficient Temperature range or capacitance change C0G X7R X7S X7T X8R X8L 0±30 ppm/°C ±15% ±22% +22, –33% ±15% +15, –40% 050 060 080 085 115 125 130 160 200 230 250 0.50 mm 0.60 mm 0.80 mm 0.85 mm 1.15 mm 1.25 mm 1.30 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm -55 to +125°C -55 to +125°C -55 to +125°C -55 to +125°C -55 to +150°C -55 to +150°C (10)Packaging style Code Style A B K L 178mm reel, 4mm pitch 178mm reel, 2mm pitch 178mm reel, 8mm pitch 330mm reel, 12mm pitch (11)Special reserved code Code Description E Soft termination Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20241209 / mlcc_automotive_soft_en (5/19) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) Code 100 150 220 330 470 680 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 100,000 220,000 470,000 101 151 221 331 471 681 102 152 222 332 472 682 103 153 223 333 473 104 224 474 Standard thickness CGA2/1005 [0402 inch] C0G 2A (100V) 1H (50V) X7R 1H (50V) 1V (35V) 1E (25V) X7S 1C (16V) 1C (16V) 1A (10V) X8R 2A (100V) 1H (50V) 1E (25V) 1C (16V) 0.50 mm Background gray: These products are not recommended for new designs. ■Click the charts for details. ■For details such as the catalog numbers, please refer to the capacitance range table on page 11 and after. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20241209 / mlcc_automotive_soft_en (6/19) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) 100 330 470 680 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 1,000,000 2,200,000 Code CGA3/1608 [0603 inch] C0G 2E 2A (250V) (100V) X7R 1H (50V) 2A (100V) 1H (50V) 1V (35V) X7S 1E (25V) 2A (100V) 1C (16V) X8R 1A (10V) 2A (100V) 1H (50V) 1E (25V) 1C (16V) 101 331 471 681 102 122 152 182 222 272 332 392 472 562 682 822 103 153 223 333 473 683 104 154 224 334 474 105 225 Standard thickness 0.80 mm Background gray: These products are not recommended for new designs. ■Click the charts for details. ■For details such as the catalog numbers, please refer to the capacitance range table on page 11 and after. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20241209 / mlcc_automotive_soft_en (7/19) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) 100 150 220 330 470 680 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 10,000 15,000 22,000 33,000 47,000 100,000 220,000 470,000 1,000,000 2,200,000 4,700,000 10,000,000 Code 10,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 2,200,000 4,700,000 10,000,000 C0G 2W 2E 2A (450V) (250V) (100V) X7R 1H 2E 2A (50V) (250V) (100V) X7S 1H (50V) 1V (35V) 1H (50V) 1V (35V) 1E (25V) 1C (16V) 0J 2A (6.3V) (100V) 1N (75V) 1E (25V) 1C (16V) 1A (10V) 101 151 221 331 471 681 102 122 152 182 222 272 332 392 472 562 682 103 153 223 333 473 104 224 474 105 225 475 106 Capacitance (pF) CGA4/2012 [0805 inch] Code X7T 2W 2E 2A (450V) (250V) (100V) X8R 1H (50V) 1E (25V) X8L 1C (16V) 1E (25V) 1A (10V) 103 223 333 473 683 104 154 224 334 474 684 105 225 475 106 Standard thickness 0.60 mm 0.85 mm 1.25 mm Background gray: These products are not recommended for new designs. ■Click the charts for details. ■For details such as the catalog numbers, please refer to the capacitance range table on page 11 and after. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20241209 / mlcc_automotive_soft_en (8/19) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) Code 1,000 2,200 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 220,000 470,000 1,000,000 2,200,000 4,700,000 10,000,000 22,000,000 102 222 332 392 472 562 682 822 103 153 223 333 473 683 104 224 474 105 225 475 106 226 Capacitance (pF) 47,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 10,000,000 Code CGA5/3216 [1206 inch] C0G 2J 2W 2E 2A (630V) (450V) (250V) (100V) X7T 2J 2W 2E 2A (630V) (450V) (250V) (100V) X7R 1H 2J 2E 2A (50V) (630V) (250V) (100V) X8R 1H (50V) 1E (25V) 1H (50V) X7S 1V (35V) 1E (25V) 0J 2A (6.3V) (100V) 1N (75V) X8L 1C (16V) 1E (25V) 473 104 154 224 334 474 684 105 155 225 335 475 106 Standard thickness 0.85 mm 1.15 mm 1.30 mm 1.60 mm ■Click the charts for details. ■For details such as the catalog numbers, please refer to the capacitance range table on page 11 and after. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20241209 / mlcc_automotive_soft_en (9/19) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) Code 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 1,000,000 2,200,000 3,300,000 4,700,000 10,000,000 22,000,000 102 122 152 182 222 272 332 392 472 562 682 822 153 223 333 473 683 104 154 224 334 474 105 225 335 475 106 226 C0G 3A (1kV) Capacitance (pF) 470,000 680,000 3,300,000 4,700,000 10,000,000 Code CGA6/3225 [1210 inch] X7R 2J 2W 2E 2A 2J 2E 2A (630V) (450V) (250V) (100V) (630V) (250V) (100V) X7S 1H (50V) 1E (25V) 2A (100V) 1N (75V) X7T 1H 2J 2W 2E (50V) (630V) (450V) (250V) X8R 2A (100V) 1E (25V) 1C (16V) 474 684 335 475 106 Standard thickness 1.60 mm 2.00 mm 2.30 mm 2.50 mm ■Click the charts for details. ■For details such as the catalog numbers, please refer to the capacitance range table on page 11 and after. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20241209 / mlcc_automotive_soft_en (10/19) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance X7R (pF) 3D (2kV) 1,000 Code CGA7/4520 [1808 inch] 102 Standard thickness 1.30 mm ■Click the charts for details. ■For details such as the catalog numbers, please refer to the capacitance range table on page 11 and after. Capacitance range chart Capacitance (pF) 330 2,200 33,000 100,000 220,000 470,000 1,000,000 Code CGA8/4532 [1812 inch] C0G 3F (3kV) 2J (630V) X7R 3D (2kV) X7T 2J 2E 2J 2W 2E (630V) (250V) (630V) (450V) (250V) 331 222 333 104 224 474 105 Standard thickness 1.30 mm 2.00 mm 2.30 mm 2.50 mm ■Click the charts for details. ■For details such as the catalog numbers, please refer to the capacitance range table on page 11 and after. Capacitance range chart Capacitance (pF) 68,000 150,000 220,000 470,000 1,000,000 2,200,000 10,000,000 Code C0G CGA9/5750 [2220 inch] X7R X7S X7T 2J 2E 2A 2J 2E 2A 2J 2W 2E (630V) (250V) (100V) (630V) (250V) (100V) (630V) (450V) (250V) 683 154 224 474 105 225 106 Standard thickness 2.30 mm 2.50 mm ■Click the charts for details. ■For details such as the catalog numbers, please refer to the capacitance range table on page 11 and after. Capacitance range chart Capacitance (pF) Code 47,000,000 476 CGAD/7563 [3025 inch] X7R 1E (25V) Standard thickness 2.30 mm ■Click the charts for details. ■For details such as the catalog numbers, please refer to the capacitance range table on page 11 and after. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20241209 / mlcc_automotive_soft_en (11/19) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance 100pF 150pF 220pF 330pF 470pF 680pF 1nF 1.2nF 1.5nF 1.8nF 2.2nF 2.7nF 3.3nF 3.9nF 4.7nF Thickness (mm) Capacitance tolerance 2012 2012 2012 2012 4532 2012 2012 2012 0.60±0.15 0.60±0.15 0.60±0.15 0.60±0.15 2.50±0.30 0.60±0.15 0.60±0.15 0.60±0.15 3225 2.00+0.30,-0.20 ±5% ±5% ±5% ±5% ±10% ±5% ±5% ±5% ±2% ±5% ±5% ±2% ±5% ±5% ±2% ±5% ±5% ±2% ±5% ±5% ±2% ±5% ±5% ±2% ±5% ±5% ±2% ±5% ±5% ±2% ±5% ±2% ±5% ±2% ±5% ±2% ±5% ±2% ±5% ±2% ±5% ±2% ±5% ±5% ±2% ±5% ±2% ±5% ±2% ±5% ±2% ±5% ±2% ±5% ±5% ±2% ±5% Dimensions 2012 0.60±0.15 3225 2.00+0.30,-0.20 2012 0.85±0.15 3225 2.00+0.30,-0.20 2012 0.85±0.15 3225 2.00+0.30,-0.20 2012 0.85±0.15 3225 2.00+0.30,-0.20 2012 1.25+0.25,-0.20 3225 2.00+0.30,-0.20 2012 1.25+0.25,-0.20 3225 2.00+0.30,-0.20 2012 1.25+0.25,-0.20 3216 0.85±0.15 3225 2.00+0.30,-0.20 3225 2.00+0.30,-0.20 3216 1.15±0.15 3225 2.00+0.30,-0.20 3216 1.15±0.15 3225 2.00+0.30,-0.20 5.6nF 6.8nF 1.15±0.15 3216 8.2nF 1.60+0.30,-0.20 3225 2.30+0.30,-0.20 10nF 3216 1.60+0.30,-0.20 15nF 3225 1.60+0.30,-0.20 3225 2.50±0.30 4532 2.00+0.30,-0.20 5750 2.30+0.30,-0.20 33nF 68nF Temperature characteristic: C0G (-55 to +125°C,0±30ppm/°C) Catalog number Rated voltage Edc: 3kV Rated voltage Edc: 1kV Rated voltage Edc: 630V Rated voltage Edc: 450V CGA4C4C0G2W101J060AE CGA4C4C0G2W151J060AE CGA4C4C0G2W221J060AE CGA4C4C0G2W331J060AE CGA8P1C0G3F331K250KE CGA4C4C0G2W471J060AE CGA4C4C0G2W681J060AE CGA4C4C0G2W102J060AE CGA6M1C0G3A102G200AE CGA6M1C0G3A102J200AE CGA4C4C0G2W122J060AE CGA6M1C0G3A122G200AE CGA6M1C0G3A122J200AE CGA4F4C0G2W152J085AE CGA6M1C0G3A152G200AE CGA6M1C0G3A152J200AE CGA4F4C0G2W182J085AE CGA6M1C0G3A182G200AE CGA6M1C0G3A182J200AE CGA4F4C0G2W222J085AE CGA6M1C0G3A222G200AE CGA6M1C0G3A222J200AE CGA4J4C0G2W272J125AE CGA6M1C0G3A272G200AE CGA6M1C0G3A272J200AE CGA4J4C0G2W332J125AE CGA6M1C0G3A332G200AE CGA6M1C0G3A332J200AE CGA4J4C0G2W392J125AE CGA5F4C0G2J392G085AE CGA5F4C0G2J392J085AE CGA6M1C0G3A392G200AE CGA6M1C0G3A392J200AE CGA6M1C0G3A472G200AE CGA6M1C0G3A472J200AE CGA5H4C0G2J562G115AE CGA5H4C0G2J562J115AE CGA6M1C0G3A562G200AE CGA6M1C0G3A562J200AE CGA5H4C0G2J682G115AE CGA5H4C0G2J682J115AE CGA5H4C0G2W682J115AE CGA6M1C0G3A682G200AE CGA6M1C0G3A682J200AE CGA5H4C0G2W822J115AE CGA5L4C0G2J822G160AE CGA5L4C0G2J822J160AE CGA6N1C0G3A822G230AE CGA6N1C0G3A822J230AE CGA5L4C0G2J103G160AE CGA5L4C0G2J103J160AE CGA5L4C0G2W103J160AE CGA6L4C0G2J153G160AE CGA6L4C0G2J153J160AE CGA6P4C0G2J333G250AE CGA6P4C0G2J333J250AE CGA6P4C0G2W333J250AE CGA8M4C0G2J333J200KE CGA9N1C0G2J683G230KE CGA9N1C0G2J683J230KE Click the part numbers for details. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20241209 / mlcc_automotive_soft_en (12/19) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance 100pF 150pF 220pF 330pF 470pF 680pF 1nF 1.2nF 1.5nF 1.8nF 2.2nF 2.7nF 3.3nF 3.9nF 4.7nF 5.6nF 6.8nF 8.2nF 10nF 15nF 22nF 33nF 47nF 68nF 100nF 150nF Dimensions 1005 1608 1005 1005 1005 1608 1005 1608 1005 1608 1005 1608 1608 1608 1608 1608 1608 1608 2012 1608 2012 1608 2012 1608 2012 1608 2012 1608 1608 3216 2012 3216 2012 3225 2012 3216 3216 3225 3216 5750 Temperature characteristic: C0G (-55 to +125°C,0±30ppm/°C) Thickness (mm) Capacitance tolerance 0.50+0.10,-0.05 0.80+0.15,-0.10 0.50+0.10,-0.05 0.50+0.10,-0.05 0.50+0.10,-0.05 0.80+0.15,-0.10 0.50+0.10,-0.05 0.80+0.15,-0.10 0.50+0.10,-0.05 0.80+0.15,-0.10 0.50+0.10,-0.05 0.80+0.15,-0.10 0.80+0.15,-0.10 0.80+0.15,-0.10 0.80+0.15,-0.10 0.80+0.15,-0.10 0.80+0.15,-0.10 0.80+0.15,-0.10 0.85±0.15 0.80+0.15,-0.10 1.25+0.25,-0.20 0.80+0.15,-0.10 1.25+0.25,-0.20 0.80+0.15,-0.10 1.25+0.25,-0.20 0.80+0.15,-0.10 1.25+0.25,-0.20 0.80+0.15,-0.10 0.80+0.15,-0.10 1.15±0.15 0.85±0.15 1.60+0.30,-0.20 1.25+0.25,-0.20 1.60+0.30,-0.20 1.25+0.25,-0.20 1.15±0.15 1.60+0.30,-0.20 2.30+0.30,-0.20 1.60+0.30,-0.20 2.30+0.30,-0.20 ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% Catalog number Rated voltage Edc: 250V CGA3E3C0G2E102J080AE CGA3E3C0G2E122J080AE CGA3E3C0G2E152J080AE CGA3E3C0G2E182J080AE Rated voltage Edc: 100V Rated voltage Edc: 50V CGA2B2C0G2A101J050BE CGA2B2C0G1H101J050BE CGA3E2C0G1H101J080AE CGA2B2C0G2A151J050BE CGA2B2C0G1H151J050BE CGA2B2C0G2A221J050BE CGA2B2C0G1H221J050BE CGA2B2C0G2A331J050BE CGA2B2C0G1H331J050BE CGA3E2C0G2A331J080AE CGA3E2C0G1H331J080AE CGA2B1C0G2A471J050BE CGA2B2C0G1H471J050BE CGA3E2C0G2A471J080AE CGA3E2C0G1H471J080AE CGA2B1C0G2A681J050BE CGA2B2C0G1H681J050BE CGA3E2C0G2A681J080AE CGA3E2C0G1H681J080AE CGA2B1C0G2A102J050BE CGA2B2C0G1H102J050BE CGA3E2C0G2A102J080AE CGA3E2C0G1H102J080AE CGA3E2C0G2A122J080AE CGA3E2C0G1H122J080AE CGA3E2C0G2A152J080AE CGA3E2C0G1H152J080AE CGA3E2C0G2A182J080AE CGA3E2C0G1H182J080AE CGA3E2C0G2A222J080AE CGA3E2C0G1H222J080AE CGA3E1C0G2A272J080AE CGA3E2C0G1H272J080AE CGA3E1C0G2A332J080AE CGA3E2C0G1H332J080AE CGA4F3C0G2E332J085AE CGA3E1C0G2A392J080AE CGA3E2C0G1H392J080AE CGA4J3C0G2E392J125AE CGA3E1C0G2A472J080AE CGA3E2C0G1H472J080AE CGA4J3C0G2E472J125AE CGA3E1C0G2A562J080AE CGA3E2C0G1H562J080AE CGA4J3C0G2E562J125AE CGA3E1C0G2A682J080AE CGA3E2C0G1H682J080AE CGA4J3C0G2E682J125AE CGA3E1C0G2A822J080AE CGA3E2C0G1H822J080AE CGA3E1C0G2A103J080AE CGA3E2C0G1H103J080AE CGA5H3C0G2E103J115AE CGA4F1C0G2A153J085AE CGA4F2C0G1H153J085AE CGA5L3C0G2E153J160AE CGA4J1C0G2A223J125AE CGA4J2C0G1H223J125AE CGA4J1C0G2A333J125AE CGA5H1C0G2A473J115AE CGA5L1C0G2A683J160AE CGA6N2C0G2A683J230AE CGA5L1C0G2A104J160AE CGA9N4C0G2E154J230KE CGA9N2C0G2A154J230KE CGA4J2C0G1H333J125AE CGA5H2C0G1H473J115AE CGA5L2C0G1H683J160AE CGA6L3C0G2E223J160AE CGA5L2C0G1H104J160AE Click the part numbers for details. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20241209 / mlcc_automotive_soft_en (13/19) MULTILAYER CERAMIC CHIP CAPACITORS Temperature characteristic: X7R (–55 to +125°C,±15%) Capacitance range table Capacitance 1nF 2.2nF 3.3nF Dimensions Thickness (mm) 1005 0.50+0.10,-0.05 1608 0.80 +0.15,-0.10 2012 0.85±0.15 3216 1.15±0.15 4520 1.30±0.20 1005 0.50+0.10,-0.05 1608 0.80+0.15,-0.10 2012 0.85±0.15 3216 1.15±0.15 4532 1.30±0.20 3216 1.15±0.15 1005 0.50+0.10,-0.05 1608 0.80+0.15,-0.10 2012 0.85±0.15 3216 1.15±0.15 1005 0.50+0.10,-0.05 1608 0.80 +0.15,-0.10 4.7nF 10nF 0.85±0.15 2012 1.25 +0.25,-0.20 22nF 3216 1.15±0.15 1005 0.50+0.10,-0.05 1608 0.80+0.15,-0.10 2012 1.25 +0.25,-0.20 1.15±0.15 3216 1.30±0.20 33nF 3216 1.60+0.30,-0.20 Capacitance tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Catalog number Rated voltage Edc: 2kV Rated voltage Edc: 630V Rated voltage Edc: 250V Rated voltage Edc: 100V Rated voltage Edc: 50V CGA2B2X7R1H102K050BE CGA2B2X7R1H102M050BE CGA3E2X7R2A102K080AE CGA3E2X7R1H102K080AE CGA3E2X7R2A102M080AE CGA3E2X7R1H102M080AE CGA4F3X7R2E102K085AE CGA4F2X7R2A102K085AE CGA4F3X7R2E102M085AE CGA4F2X7R2A102M085AE CGA5H4X7R2J102K115AE CGA5H4X7R2J102M115AE CGA7K1X7R3D102K130KE CGA7K1X7R3D102M130KE CGA2B2X7R1H222K050BE CGA2B2X7R1H222M050BE CGA3E2X7R2A222K080AE CGA3E2X7R1H222K080AE CGA3E2X7R2A222M080AE CGA3E2X7R1H222M080AE CGA4F3X7R2E222K085AE CGA4F2X7R2A222K085AE CGA4F3X7R2E222M085AE CGA4F2X7R2A222M085AE CGA5H4X7R2J222K115AE CGA5H4X7R2J222M115AE CGA8K1X7R3D222K130KE CGA8K1X7R3D222M130KE CGA5H4X7R2J332K115AE CGA5H4X7R2J332M115AE CGA2B2X7R1H472K050BE CGA2B2X7R1H472M050BE CGA3E2X7R2A472K080AE CGA3E2X7R1H472K080AE CGA3E2X7R2A472M080AE CGA3E2X7R1H472M080AE CGA4F3X7R2E472K085AE CGA4F2X7R2A472K085AE CGA4F3X7R2E472M085AE CGA4F2X7R2A472M085AE CGA5H4X7R2J472K115AE CGA5H4X7R2J472M115AE CGA2B3X7R1H103K050BE CGA2B3X7R1H103M050BE CGA3E2X7R2A103K080AE CGA3E2X7R1H103K080AE CGA3E2X7R2A103M080AE CGA3E2X7R1H103M080AE CGA4F2X7R2A103K085AE CGA4F2X7R2A103M085AE CGA4J3X7R2E103K125AE CGA4J3X7R2E103M125AE CGA5H4X7R2J103K115AE CGA5H4X7R2J103M115AE CGA2B3X7R1H223K050BE CGA2B3X7R1H223M050BE CGA3E2X7R2A223K080AE CGA3E2X7R1H223K080AE CGA3E2X7R2A223M080AE CGA3E2X7R1H223M080AE CGA4J3X7R2E223K125AE CGA4J2X7R2A223K125AE CGA4J3X7R2E223M125AE CGA4J2X7R2A223M125AE CGA5H3X7R2E223K115AE CGA5H3X7R2E223M115AE CGA5K4X7R2J223K130AE CGA5K4X7R2J223M130AE CGA5L4X7R2J333K160AE CGA5L4X7R2J333M160AE ■Gray items: These products are not recommended for new designs. Click the part numbers for details. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20241209 / mlcc_automotive_soft_en (14/19) MULTILAYER CERAMIC CHIP CAPACITORS Temperature characteristic: X7R (–55 to +125°C,±15%) Capacitance range table Capacitance 47nF 68nF Dimensions Thickness (mm) 1005 0.50+0.10,-0.05 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 3216 1.60+0.30,-0.20 3225 2.00+0.30,-0.20 3225 2.00+0.30,-0.20 1005 0.50+0.10,-0.05 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 3216 1.60+0.30,-0.20 3225 2.00+0.30,-0.20 4532 2.30+0.30,-0.20 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 3216 1.15±0.15 3225 2.00+0.30,-0.20 5750 2.30+0.30,-0.20 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 3216 1.60+0.30,-0.20 3225 2.00+0.30,-0.20 4532 2.30+0.30,-0.20 2012 1.25+0.25,-0.20 3216 1.60+0.30,-0.20 100nF 220nF 470nF 1μF 1.60+0.30,-0.20 3225 2.00+0.30,-0.20 5750 2.30+0.30,-0.20 2012 1.25+0.25,-0.20 3216 1.60+0.30,-0.20 2.2μF 2.00+0.30,-0.20 3225 2.30+0.30,-0.20 2012 1.25+0.25,-0.20 4.7μF 3216 1.60+0.30,-0.20 10μF 3225 3216 2.50±0.30 1.60+0.30,-0.20 Capacitance tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±10% ±20% ±10% ±10% Catalog number Rated voltage Edc: 630V Rated voltage Edc: 250V Rated voltage Edc: 100V Rated voltage Edc: 50V CGA2B3X7R1H473K050BE CGA2B3X7R1H473M050BE CGA3E2X7R1H473K080AE CGA3E2X7R1H473M080AE CGA4J2X7R2A473K125AE CGA4J2X7R2A473M125AE CGA5L3X7R2E473K160AE CGA5L3X7R2E473M160AE CGA6M4X7R2J473K200AE CGA6M4X7R2J473M200AE CGA6M4X7R2J683K200AE CGA6M4X7R2J683M200AE CGA2B3X7R1H104K050BE CGA2B3X7R1H104M050BE CGA3E2X7R1H104K080AE CGA3E2X7R1H104M080AE CGA4J2X7R2A104K125AE CGA4J2X7R1H104K125AE CGA4J2X7R2A104M125AE CGA4J2X7R1H104M125AE CGA5L3X7R2E104K160AE CGA5L2X7R2A104K160AE CGA5L3X7R2E104M160AE CGA5L2X7R2A104M160AE CGA6M3X7R2E104K200AE CGA6M3X7R2E104M200AE CGA8N4X7R2J104K230KE CGA8N4X7R2J104M230KE CGA3E3X7R1H224K080AE CGA3E3X7R1H224M080AE CGA4J2X7R1H224K125AE CGA4J2X7R1H224M125AE CGA5H2X7R2A224K115AE CGA5H2X7R2A224M115AE CGA6M3X7R2E224K200AE CGA6M3X7R2E224M200AE CGA9N4X7R2J224K230KE CGA9N4X7R2J224M230KE CGA3E3X7R1H474K080AE CGA3E3X7R1H474M080AE CGA4J3X7R1H474K125AE CGA4J3X7R1H474M125AE CGA5L2X7R2A474K160AE CGA5L2X7R2A474M160AE CGA6M2X7R2A474K200AE CGA6M2X7R2A474M200AE CGA8N3X7R2E474K230KE CGA8N3X7R2E474M230KE CGA4J3X7R1H105K125AE CGA4J3X7R1H105M125AE CGA5L2X7R2A105K160AE CGA5L3X7R1H105K160AE CGA5L2X7R2A105M160AE CGA5L3X7R1H105M160AE CGA6L2X7R1H105K160AE CGA6L2X7R1H105M160AE CGA6M2X7R2A105K200AE CGA6M2X7R2A105M200AE CGA9N3X7R2E105K230KE CGA9N3X7R2E105M230KE CGA4J3X7R1H225K125AE CGA4J3X7R1H225M125AE CGA5L3X7R1H225K160AE CGA5L3X7R1H225M160AE CGA6M3X7R1H225K200AE CGA6M3X7R1H225M200AE CGA6N3X7R2A225K230AE CGA6N3X7R2A225M230AE CGA4J1X7R1H475K125AE CGA5L3X7R1H475K160AE CGA5L3X7R1H475M160AE CGA6P3X7R1H475K250AE CGA5L1X7R1H106K160AE ■Gray items: These products are not recommended for new designs. Click the part numbers for details. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20241209 / mlcc_automotive_soft_en (15/19) MULTILAYER CERAMIC CHIP CAPACITORS Temperature characteristic: X7R (–55 to +125°C,±15%) Capacitance range table Capacitance Dimensions Thickness (mm) 1005 0.50+0.10,-0.05 1608 0.80+0.15,-0.10 1608 0.80+0.15,-0.10 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 2012 1.25+0.25,-0.20 3216 1.60+0.30,-0.20 2012 1.25+0.25,-0.20 3216 1.60+0.30,-0.20 220nF 470nF 1μF 2.2μF 4.7μF 10μF 22μF 47μF 2012 1.25±0.20 3216 1.60+0.30,-0.20 3216 3225 7563 1.60+0.30,-0.20 2.50±0.30 2.30 (2.50max.) Capacitance tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±10% ±20% ±20% ±20% ±20% Catalog number Rated voltage Edc: 35V Rated voltage Edc: 25V Rated voltage Edc: 16V CGA2B1X7R1V224K050BE CGA2B1X7R1V224M050BE CGA3E3X7R1V224K080AE CGA3E3X7R1V224M080AE CGA3E1X7R1V474K080AE CGA3E1X7R1V474M080AE CGA3E1X7R1V105K080AE CGA3E1X7R1V105M080AE CGA4J3X7R1V105K125AE CGA4J3X7R1V105M125AE CGA4J1X7R1V225K125AE CGA4J1X7R1V225M125AE CGA5L3X7R1V225K160AE CGA5L3X7R1V225M160AE CGA4J1X7R1V475K125AE CGA4J1X7R1V475M125AE CGA5L1X7R1V475K160AE CGA5L1X7R1V475M160AE CGA2B3X7R1E224K050BE CGA2B2X7R1C224K050BE CGA2B3X7R1E224M050BE CGA2B2X7R1C224M050BE CGA5L1X7R1V106K160AE CGA5L1X7R1V106M160AE CGA5L1X7R1E106K160AE CGA5L1X7R1E106M160AE Rated voltage Edc: 6.3V CGA3E3X7R1E474K080AE CGA3E3X7R1E474M080AE CGA3E1X7R1E105K080AE CGA3E1X7R1E105M080AE CGA4J3X7R1E225K125AE CGA4J3X7R1E225M125AE CGA5L2X7R1E225K160AE CGA5L2X7R1E225M160AE CGA4J1X7R1E475K125AE CGA4J3X7R1C475K125AE CGA4J1X7R1E475M125AE CGA4J3X7R1C475M125AE CGA4J1X7R0J106K125AE CGA5L1X7R0J226M160AE CGA6P3X7R1E226M250AE CGADN3X7R1E476M230LE Click the part numbers for details. Temperature characteristic: X7S (–55 to +125°C,±22%) Capacitance range table Capacitance Dimensions Thickness (mm) 47nF 1608 0.80+0.15,-0.10 100nF 1608 0.80+0.15,-0.10 220nF 2012 0.85±0.15 1005 0.50+0.10,-0.05 2012 1.25+0.25,-0.20 2012 1.25+0.25,-0.20 1608 0.80+0.15,-0.10 3216 1.60+0.30,-0.20 3.3μF 3225 2.00+0.30,-0.20 4.7μF 3225 470nF 1μF 2.2μF 2.00+0.30,-0.20 2.30+0.30,-0.20 2.50±0.30 2012 10μF 1.25+0.25,-0.20 3225 2.50±0.30 5750 2.30+0.30,-0.20 Capacitance tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±10% ±20% ±10% ±20% ±10% ±20% Catalog number Rated voltage Edc: 100V Rated voltage Edc: 75V Rated voltage Edc: 50V Rated voltage Edc: 25V Rated voltage Edc: 16V Rated voltage Edc: 10V CGA3E3X7S2A473K080AE CGA3E3X7S2A473M080AE CGA3E3X7S2A104K080AE CGA3E3X7S2A104M080AE CGA4F3X7S2A224K085AE CGA4F3X7S2A224M085AE CGA2B1X7S1C474K050BE CGA2B3X7S1A474K050BE CGA2B1X7S1C474M050BE CGA2B3X7S1A474M050BE CGA4J3X7S2A474K125AE CGA4J3X7S2A474M125AE CGA4J3X7S2A105K125AE CGA4J3X7S2A105M125AE CGA4J1X7S1N105K125AE CGA3E1X7S1C225K080AE CGA3E3X7S1A225K080AE CGA3E1X7S1C225M080AE CGA3E3X7S1A225M080AE CGA5L3X7S2A225K160AE CGA5L1X7S1N225K160AE CGA5L3X7S2A225M160AE CGA6M3X7S2A335K200AE CGA6M3X7S2A335M200AE CGA6M3X7S2A475K200AE CGA6M3X7S2A475M200AE CGA6N3X7S1H475K230AE CGA6N3X7S1H475M230AE CGA6P1X7S1N475K250AE CGA4J1X7S1E106K125AE CGA6P1X7S1N106K250AE CGA4J1X7S1C106K125AE CGA4J1X7S1C106M125AE CGA4J3X7S1A106K125AE CGA4J3X7S1A106M125AE CGA6P3X7S1H106K250AE CGA6P3X7S1H106M250AE CGA9N3X7S2A106K230KE CGA9N3X7S2A106M230KE ■Gray items: These products are not recommended for new designs. Click the part numbers for details. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20241209 / mlcc_automotive_soft_en (16/19) MULTILAYER CERAMIC CHIP CAPACITORS Temperature characteristic: X7T (–55 to +125°C,+22, –33%) Capacitance range table Capacitance Dimensions Thickness (mm) 10 nF 2012 0.85±0.15 22 nF 2012 1.25+0.25,-0.20 2012 1.25+0.25,-0.20 3216 1.60+0.30,-0.20 2012 1.25+0.25,-0.20 3216 1.60+0.30,-0.20 3225 1.60+0.30,-0.20 3225 2.00+0.30,-0.20 3216 1.60+0.30,-0.20 3225 2.00+0.30,-0.20 4532 2.00+0.30,-0.20 3225 2.00+0.30,-0.20 4532 2.30+0.30,-0.20 5750 2.50±0.30 4532 2.50±0.30 5750 2.50±0.30 5750 2.50±0.30 47 nF 100 nF 150nF 220 nF 330nF 470 nF 1 μF 2.2 uF Capacitance tolerance ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ±10% ±20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ±10% ±20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% ± 10% ± 20% Catalog number Rated voltage Edc: 630V Rated voltage Edc: 450V Rated voltage Edc: 250V CGA4F4X7T2W103K085AE CGA4F4X7T2W103M085AE CGA4J4X7T2W223K125AE CGA4J4X7T2W223M125AE CGA4J4X7T2W473K125AE CGA4J3X7T2E473K125AE CGA4J4X7T2W473M125AE CGA4J3X7T2E473M125AE CGA5L1X7T2J473K160AE CGA5L1X7T2J473M160AE CGA4J3X7T2E104K125AE CGA4J3X7T2E104M125AE CGA5L4X7T2W104K160AE CGA5L4X7T2W104M160AE CGA6L1X7T2J104K160AE CGA6L1X7T2J104M160AE CGA6M1X7T2J154K200AE CGA6M1X7T2J154M200AE CGA5L3X7T2E224K160AE CGA5L3X7T2E224M160AE CGA6M4X7T2W224K200AE CGA6M4X7T2W224M200AE CGA8M1X7T2J224K200KE CGA8M1X7T2J224M200KE CGA6M3X7T2E334K200AE CGA6M3X7T2E334M200AE CGA8N4X7T2W474K230KE CGA8N4X7T2W474M230KE CGA9P1X7T2J474K250KE CGA9P1X7T2J474M250KE CGA8P3X7T2E105K250KE CGA8P3X7T2E105M250KE CGA9P4X7T2W105K250KE CGA9P4X7T2W105M250KE CGA9P3X7T2E225K250KE CGA9P3X7T2E225M250KE Click the part numbers for details. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20241209 / mlcc_automotive_soft_en (17/19) MULTILAYER CERAMIC CHIP CAPACITORS Temperature characteristic: X8R (–55 to +150°C,±15%) Capacitance range table Capacitance Dimensions Thickness (mm) 150pF 1005 0.50+0.10,-0.05 220pF 1005 0.50+0.10,-0.05 330pF 1005 0.50+0.10,-0.05 470pF 1005 0.50+0.10,-0.05 680pF 1005 0.50+0.10,-0.05 1005 0.50+0.10,-0.05 1608 0.80+0.15,-0.10 1005 0.50+0.10,-0.05 1608 0.80+0.15,-0.10 1005 0.50+0.10,-0.05 1608 0.80+0.15,-0.10 1005 0.50+0.10,-0.05 1608 0.80+0.15,-0.10 1005 0.50+0.10,-0.05 1608 0.80+0.15,-0.10 1005 0.50+0.10,-0.05 1608 0.80+0.15,-0.10 1005 0.50+0.10,-0.05 1608 0.80+0.15,-0.10 1005 0.50+0.10,-0.05 1608 0.80+0.15,-0.10 1005 0.50+0.10,-0.05 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 1005 0.50+0.10,-0.05 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 1005 0.50+0.10,-0.05 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 1nF 1.5nF 2.2nF 3.3nF 4.7nF 6.8nF 10nF 15nF 22nF 33nF 47nF 68nF Capacitance tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Catalog number Rated voltage Edc: 100V Rated voltage Edc: 50V CGA2B2X8R2A151K050BE CGA2B2X8R2A151M050BE CGA2B2X8R2A221K050BE CGA2B2X8R2A221M050BE CGA2B2X8R2A331K050BE CGA2B2X8R2A331M050BE CGA2B2X8R2A471K050BE CGA2B2X8R2A471M050BE CGA2B2X8R2A681K050BE CGA2B2X8R2A681M050BE CGA2B2X8R2A102K050BE CGA2B2X8R2A102M050BE CGA3E2X8R2A102K080AE CGA3E2X8R2A102M080AE CGA2B2X8R2A152K050BE CGA2B2X8R2A152M050BE CGA3E2X8R2A152K080AE CGA3E2X8R2A152M080AE CGA2B2X8R2A222K050BE CGA2B2X8R2A222M050BE CGA3E2X8R2A222K080AE CGA3E2X8R2A222M080AE CGA2B3X8R2A332K050BE CGA2B3X8R2A332M050BE CGA3E2X8R2A332K080AE CGA3E2X8R2A332M080AE CGA2B2X8R1H151K050BE CGA2B2X8R1H151M050BE CGA2B2X8R1H221K050BE CGA2B2X8R1H221M050BE CGA2B2X8R1H331K050BE CGA2B2X8R1H331M050BE CGA2B2X8R1H471K050BE CGA2B2X8R1H471M050BE CGA2B2X8R1H681K050BE CGA2B2X8R1H681M050BE CGA2B2X8R1H102K050BE CGA2B2X8R1H102M050BE CGA3E2X8R1H102K080AE CGA3E2X8R1H102M080AE CGA2B2X8R1H152K050BE CGA2B2X8R1H152M050BE CGA3E2X8R1H152K080AE CGA3E2X8R1H152M080AE CGA2B2X8R1H222K050BE CGA2B2X8R1H222M050BE CGA3E2X8R1H222K080AE CGA3E2X8R1H222M080AE CGA2B2X8R1H332K050BE CGA2B2X8R1H332M050BE CGA3E2X8R1H332K080AE CGA3E2X8R1H332M080AE CGA2B2X8R1H472K050BE CGA2B2X8R1H472M050BE CGA3E2X8R1H472K080AE CGA3E2X8R1H472M080AE CGA2B3X8R1H682K050BE CGA2B3X8R1H682M050BE CGA3E2X8R1H682K080AE CGA3E2X8R1H682M080AE CGA2B3X8R1H103K050BE CGA2B3X8R1H103M050BE CGA3E2X8R1H103K080AE CGA3E2X8R1H103M080AE CGA3E2X8R2A472K080AE CGA3E2X8R2A472M080AE CGA3E2X8R2A682K080AE CGA3E2X8R2A682M080AE CGA3E2X8R2A103K080AE CGA3E2X8R2A103M080AE Rated voltage Edc: 25V Rated voltage Edc: 16V CGA2B2X8R1E682K050BE CGA2B2X8R1E682M050BE CGA2B2X8R1E103K050BE CGA2B2X8R1E103M050BE CGA2B3X8R1E153K050BE CGA2B3X8R1E153M050BE CGA3E2X8R2A153K080AE CGA3E2X8R1H153K080AE CGA3E2X8R2A153M080AE CGA3E2X8R1H153M080AE CGA2B3X8R1E223K050BE CGA2B3X8R1E223M050BE CGA3E3X8R2A223K080AE CGA3E2X8R1H223K080AE CGA3E3X8R2A223M080AE CGA3E2X8R1H223M080AE CGA4J2X8R2A223K125AE CGA4J2X8R2A223M125AE CGA2B1X8R1E333K050BE CGA2B3X8R1C333K050BE CGA2B1X8R1E333M050BE CGA2B3X8R1C333M050BE CGA3E2X8R1H333K080AE CGA3E2X8R1H333M080AE CGA4J3X8R2A333K125AE CGA4J3X8R2A333M125AE CGA2B1X8R1E473K050BE CGA2B3X8R1C473K050BE CGA2B1X8R1E473M050BE CGA2B3X8R1C473M050BE CGA3E2X8R1H473K080AE CGA3E2X8R1H473M080AE CGA4J3X8R2A473K125AE CGA4J3X8R2A473M125AE CGA3E3X8R1H683K080AE CGA3E2X8R1E683K080AE CGA3E3X8R1H683M080AE CGA3E2X8R1E683M080AE CGA4J3X8R2A683K125AE CGA4J2X8R1H683K125AE CGA4J3X8R2A683M125AE CGA4J2X8R1H683M125AE ■Gray items: These products are not recommended for new designs. Click the part numbers for details. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20241209 / mlcc_automotive_soft_en (18/19) MULTILAYER CERAMIC CHIP CAPACITORS Temperature characteristic: X8R (–55 to +150°C,±15%) Capacitance range table Capacitance 100nF Dimensions Thickness (mm) 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 3216 1.15±0.15 1608 0.80+0.15,-0.10 0.85±0.15 150nF 2012 1.25+0.25,-0.20 3216 1.60+0.30,-0.20 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 3216 1.60+0.30,-0.20 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 3216 1.60+0.30,-0.20 1608 0.80+0.15,-0.10 2012 1.25+0.25,-0.20 3216 1.60+0.30,-0.20 3225 2.00+0.30,-0.20 2012 1.25+0.25,-0.20 3216 1.60+0.30,-0.20 3225 2.50±0.30 2012 1.25+0.25,-0.20 3216 1.60+0.30,-0.20 1.5μF 3216 1.60+0.30,-0.20 2.2μF 3216 1.60+0.30,-0.20 3216 1.60+0.30,-0.20 3225 2.50±0.30 3216 1.60+0.30,-0.20 3225 2.50±0.30 3225 2.50±0.30 220nF 330nF 470nF 680nF 1μF 3.3μF 4.7μF 10μF Capacitance tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Catalog number Rated voltage Edc: 100V Rated voltage Edc: 50V Rated voltage Edc: 25V Rated voltage Edc: 16V CGA3E3X8R1H104K080AE CGA3E2X8R1E104K080AE CGA3E3X8R1H104M080AE CGA3E2X8R1E104M080AE CGA4J2X8R1H104K125AE CGA4J2X8R1H104M125AE CGA5H2X8R2A104K115AE CGA5H2X8R2A104M115AE CGA3E3X8R1E154K080AE CGA3E3X8R1E154M080AE CGA4F2X8R1E154K085AE CGA4F2X8R1E154M085AE CGA4J3X8R1H154K125AE CGA4J3X8R1H154M125AE CGA5L2X8R2A154K160AE CGA5L2X8R2A154M160AE CGA3E3X8R1E224K080AE CGA3E3X8R1E224M080AE CGA4J3X8R1H224K125AE CGA4J2X8R1E224K125AE CGA4J3X8R1H224M125AE CGA4J2X8R1E224M125AE CGA5L3X8R2A224K160AE CGA5L3X8R2A224M160AE CGA3E1X8R1E334K080AE CGA3E3X8R1C334K080AE CGA3E1X8R1E334M080AE CGA3E3X8R1C334M080AE CGA4J2X8R1E334K125AE CGA4J2X8R1E334M125AE CGA5L3X8R2A334K160AE CGA5L2X8R1H334K160AE CGA5L3X8R2A334M160AE CGA5L2X8R1H334M160AE CGA3E3X8R1C474K080AE CGA3E3X8R1C474M080AE CGA4J3X8R1E474K125AE CGA4J3X8R1E474M125AE CGA5L2X8R1H474K160AE CGA5L2X8R1H474M160AE CGA6M3X8R2A474K200AE CGA6M3X8R2A474M200AE CGA4J1X8R1E684K125AE CGA4J3X8R1C684K125AE CGA4J1X8R1E684M125AE CGA4J3X8R1C684M125AE CGA5L3X8R1H684K160AE CGA5L3X8R1H684M160AE CGA6P3X8R2A684K250AE CGA6P3X8R2A684M250AE CGA4J1X8R1E105K125AE CGA4J1X8R1E105M125AE CGA5L3X8R1H105K160AE CGA5L2X8R1E105K160AE CGA5L3X8R1H105M160AE CGA5L2X8R1E105M160AE CGA5L3X8R1E155K160AE CGA5L3X8R1E155M160AE CGA5L3X8R1E225K160AE CGA5L3X8R1E225M160AE CGA5L1X8R1E335K160AE CGA5L1X8R1E335M160AE CGA6P2X8R1E335K250AE CGA6P2X8R1E335M250AE CGA5L1X8R1E475K160AE CGA5L1X8R1E475M160AE CGA6P3X8R1E475K250AE CGA6P3X8R1E475M250AE CGA6P1X8R1E106K250AE CGA6P1X8R1E106M250AE CGA4J3X8R1C105K125AE CGA4J3X8R1C105M125AE CGA5L3X8R1C335K160AE CGA5L3X8R1C335M160AE CGA5L3X8R1C475K160AE CGA5L3X8R1C475M160AE CGA6P3X8R1C106K250AE CGA6P3X8R1C106M250AE Click the part numbers for details. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20241209 / mlcc_automotive_soft_en (19/19) MULTILAYER CERAMIC CHIP CAPACITORS Temperature characteristic: X8L (–55 to +150°C,+15,–40%) Capacitance range table Capacitance 470nF 1μF 2.2μF 4.7μF 10μF Dimensions 2012 2012 2012 2012 2012 3216 Thickness (mm) Capacitance tolerance 1.25+0.25,-0.20 1.25+0.25,-0.20 1.25+0.25,-0.20 1.25+0.25,-0.20 1.25+0.25,-0.20 1.60+0.30,-0.20 ±10% ±10% ±10% ±10% ±10% ±10% Catalog number Rated voltage Edc: 50V Rated voltage Edc: 35V Rated voltage Edc: 25V Rated voltage Edc: 10V CGA4J1X8L1H474K125AE CGA4J1X8L1H105K125AE CGA4J1X8L1V225K125AE CGA4J1X8L1E475K125AE CGA4J1X8L1A106K125AE CGA5L1X8L1E106K160AE Click the part numbers for details. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20241209 / mlcc_automotive_soft_en
CGA6P1X7S0J476MTJY0N 价格&库存
很抱歉,暂时无法提供与“CGA6P1X7S0J476MTJY0N”相匹配的价格&库存,您可以联系我们找货
  • 1+0.78840
  • 10+0.75600
  • 30+0.69120
  • 100+0.64800
库存:1
    • 100+1.25360
    • 500+1.16070
    库存:830
    • 1+1.41900
    • 50+1.08680
    • 1000+1.00100
    库存:313
