CGA8L1C0G3F151K160KA
    TDK(东电化)
    150PF ±10% 3KV
CGA8L1C0G3F151K160KA 数据手册
CGA8L1C0G3F151K160KA TDK Item Description : CGA8L1C0G3F151KT**** Equivalent C4532C0G3F151K for Automotive Application & Main Feature Automotive Grade ( High Voltage (1000V and over) ) Series CGA8(4532) [EIA CC1812] 4.50mm 3.20mm 1.60mm 0.20mm +/-0.4mm +/-0.4mm +/-0.2mm Min. Temperature Characteristic Rated Voltage 3 10 1 0.1 0.01 Capacitance 0 -1 -2 -3 10 100 1000 10000 0 200 400 |Z| K (+/-10%) 800 1000 1200 ESR Cap. vs. Freq. Characteristic 10000 600 DC Bias/V Frequency/MHz Capacitance Tolerance Temperature Characteristics 0.5 0.4 0.3 Q Factor 0.2 Cap. Change/% 1000 Min. AEC-Q200 1 -5 1 150pF 10Gohm Min. 2 -4 3F (3000Vdc) Insulation Resistance DC Bias Characteristic 5 4 1000 Cap./pF Characterization Sheet ( Multilayer Ceramic Chip Capacitors ) C0G (-55 to 125 degC 0+/-30ppm/degC) |Z|, ESR vs. Freq. Characteristics 100 Cap. Change/% L W T B G |Z|, ESR/ohm Dimensions 0.1 100 0 -0.1 -0.2 -0.3 10 Yes -0.4 1 -0.5 1 10 100 Frequency/MHz All specifications are subject to change without notice. 1000 10000 -60 -40 -20 0 20 40 60 80 100 120 140 160 Temperature/degC Temp.Chara. TCBias(1/2Rated) March 23, 2018
CGA8L1C0G3F151K160KA 价格&库存
很抱歉,暂时无法提供与“CGA8L1C0G3F151K160KA”相匹配的价格&库存,您可以联系我们找货
  • 1000+2.28540
  • 2000+2.13807
  • 3000+2.06381
  • 4000+2.00871
  • 5000+1.97158
  • 6000+1.94403
  • 10000+1.92486
  • 1+8.110751+1.05131
  • 10+5.1382310+0.66602
  • 50+3.9626550+0.51364
  • 100+3.60220100+0.46692
  • 500+2.99296500+0.38795
库存:1488
  • 1000+2.648711000+0.34333
  • 2000+2.502312000+0.32435
  • 3000+2.428993000+0.31485
  • 5000+2.347725000+0.30431
  • 7000+2.300227000+0.29816
  • 10000+2.2545010000+0.29223
库存:1488
