CGA9N3X7S2A106M230KB
    TDK(东电化)
    10 µF ±20% 100V 陶瓷电容器 X7S 2220(5750 公制)
CGA9N3X7S2A106M230KB 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS May 2023 MULTILAYER CERAMIC CHIP CAPACITORS Automotive grade, mid voltage (100 to 630V)  CGA series CGA2 CGA3 CGA4 CGA5 CGA6 CGA8 CGA9 1005 [0402 inch] 1608 [0603 inch] 2012 [0805 inch] 3216 [1206 inch] 3225 [1210 inch] 4532 [1812 inch] 5750 [2220 inch] * Dimensions code: JIS[EIA] (2/18) MULTILAYER CERAMIC CHIP CAPACITORS REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS 1. The products listed in this specification are intended for use in automotive applications under normal operation and usage conditions. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality requires a more stringent level of safety or reliability, or whose failure, malfunction or defect could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in this specification, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (excepting Pharmaceutical Affairs Law classification Class1,2) (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. In addition, although the products listed in this specification are intended for use in automotive applications as described above, they are not prohibited to use in general electronic equipment, whose performance and/or quality doesn’t require a more stringent level of safety or reliability, or whose failure, malfunction or defect could not cause serious damage to society, person or property. Therefore, the description of this caution will be applied, when the products are used in general electronic equipment under a normal operation and usage conditions. 2. We may modify products or discontinue production of a product listed in this catalog without prior notification. 3. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. 4. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export permission in harmony with this law. 5. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. 6. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. 7. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging specification detail. This new catalog number should be referenced on all catalog orders going forward, and is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will differ from the item description (internal control number) on the product label. Contact your local TDK Sales representative for more information. (Example) Catalog issued date Prior to January 2013 January 2013 and later Catalog number C1608C0G1E103J(080AA) C1608C0G1E103J080AA Item description (on delivery label) C1608C0G1E103JT000N C1608C0G1E103JT000N 20230529 / mlcc_automotive_midvoltage_en.fm (3/18) MULTILAYER CERAMIC CHIP CAPACITORS CGA series Mid voltage (100 to 630V) RoHS REACH Cl Br Pb Halogen Free Lead Free Type: CGA2/1005 [0402 inch], CGA3/1608 [0603 inch], CGA4/2012 [0805 inch], CGA5/3216 [1206 inch], CGA6/3225 [1210 inch], CGA8/4532 [1812 inch], CGA9/5750 [2220 inch] ■ SERIES OVERVIEW Automotive grade medium voltage CGA series is a product that supports circuits to which high voltages with rated voltages of 100 to 630V are applied. The maximum capacitance value is 15µF. ■ FEATURES ■ APPLICATIONS • Four rated voltages: 100V, 250V, 450V, 630V • operating temperature range: –55 to +125°C • C0G temperature characteristic which has excellent stable temperature and DC-bias characteristcs is applicable. • AEC-Q200 compliant. • Wireless Charging units, DC-DC converter, inverter, a charger on board, etc. • High voltage circuit decoupling, smoothing, and snubber, resonant circuit, etc. ■ SHAPE & DIMENSIONS ■ PRODUCT STRUCTURE W L T Sn Ni Cu G B L W T B G The structure which multiple sheets of dielectric and conductive material are layered alternately. The superior mechanical strength and reliability are realized by the monolithic and simple structure. Body length Body width Body height Terminal width Terminal spacing Type L W CGA2 1.00±0.05 0.50±0.05 CGA3 1.60±0.10 0.80±0.10 CGA4 2.00±0.20 1.25±0.20 CGA5 3.20±0.20 1.60±0.20 CGA6 3.20±0.40 2.50±0.30 CGA8 4.50±0.40 3.20±0.40 CGA9 5.70±0.40 5.00±0.40 Dimensional tolerances are typical values. T 0.50±0.05 0.80±0.10 1.25±0.20 1.60±0.20 2.50±0.30 2.50±0.30 2.50±0.30 Dimensions in mm B G 0.10 min. 0.30 min. 0.20 min. 0.30 min. 0.20 min. 0.50 min. 0.20 min. 1.00 min. 0.20 min. — 0.20 min. — 0.20 min. — Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20230529 / mlcc_automotive_midvoltage_en.fm (4/18) MULTILAYER CERAMIC CHIP CAPACITORS ■ CATALOG NUMBER CONSTRUCTION CGA 5 L 1 X7R 2A 475 K 160 A C (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (1) Series (6) Rated voltage (DC) (2) Dimensions L x W (mm) Code 2 3 4 5 6 8 9 EIA CC0402 CC0603 CC0805 CC1206 CC1210 CC1812 CC2220 Length 1.00 1.60 2.00 3.20 3.20 4.50 5.70 Width 0.50 0.80 1.25 1.60 2.50 3.20 5.00 Terminal width 0.10 0.20 0.20 0.20 0.20 0.20 0.20 (3) Thickness code Code B C E F H J K L M N P Q R Thickness 0.50 mm 0.60 mm 0.80 mm 0.85 mm 1.15 mm 1.25 mm 1.30 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm 2.80 mm 3.20 mm Code C D J K M Tolerance ±0.25pF ±0.50pF ±5% ±10% ±20% (9) Thickness Condition 1 × R.V. 2 × R.V. 1.5 × R.V. 1.2 × R.V. Temperature coefficient or capacitance change 0±30 ppm/°C ±15% ±22% +22,–33% (7) Nominal capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. (8) Capacitance tolerance (5) Temperature characteristics Temperature characteristics C0G X7R X7S X7T Voltage (DC) 100V 250V 450V 630V (Example)0R5 = 0.5pF 101 = 100pF 225 = 2,200,000pF = 2.2µF (4) Voltage condition for life test Symbol 1 2 3 4 Code 2A 2E 2W 2J Temperature range –55 to +125°C –55 to +125°C –55 to +125°C –55 to +125°C Code 050 060 080 085 115 125 130 160 200 230 250 280 320 Thickness 0.50 mm 0.60 mm 0.80 mm 0.85 mm 1.15 mm 1.25 mm 1.30 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm 2.80 mm 3.20 mm (10) Packaging style Code A B K Style 178mm reel, 4mm pitch 178mm reel, 2mm pitch 178mm reel, 8mm pitch (11) Special reserved code Code A,B,C,N Description TDK internal code Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20230529 / mlcc_automotive_midvoltage_en.fm (5/18) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,500 2,200 3,300 4,700 6,800 10,000 Code C0G CGA2/1005 [0402 inch] X7S 2A 2A (100V) (100V) 101 121 151 181 221 271 331 391 471 561 681 821 102 152 222 332 472 682 103 Standard thickness   0.50mm Background gray: These products are not recommended for new designs. ■ For details such as the catalog numbers, please refer to the capacitance range table on page 11 and after. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20230529 / mlcc_automotive_midvoltage_en.fm (6/18) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) 1 1.5 2 2.2 3 3.3 4 4.7 5 6 6.8 7 8 9 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 Code C0G CGA3/1608 [0603 inch] X7R X7S 2E 2A 2A 2A (250V) (100V) (100V) (100V) 010 1R5 020 2R2 030 3R3 040 4R7 050 060 6R8 070 080 090 100 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 153 223 333 473 683 104 Standard thickness   0.80mm Background gray: These products are not recommended for new designs. ■ For details such as the catalog numbers, please refer to the capacitance range table on page 11 and after. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20230529 / mlcc_automotive_midvoltage_en.fm (7/18) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 330,000 470,000 680,000 1,000,000 2,200,000 Code C0G CGA4/2012 [0805 inch] X7R X7S X7T 2W 2E 2A 2E 2A 2A 2W 2E (450V) (250V) (100V) (250V) (100V) (100V) (450V) (250V) 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 153 223 333 473 683 104 334 474 684 105 225 Standard thickness   0.60 mm  0.85 mm  1.25 mm Background gray: These products are not recommended for new designs. ■ For details such as the catalog numbers, please refer to the capacitance range table on page 11 and after. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20230529 / mlcc_automotive_midvoltage_en.fm (8/18) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 Code CGA5/3216 [1206 inch] C0G X7R X7S X7T 2J 2W 2E 2A 2J 2E 2A 2A 2J 2W 2E (630V) (450V) (250V) (100V) (630V) (250V) (100V) (100V) (630V) (450V) (250V) 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 335 475 Standard thickness   0.60 mm  0.85 mm  1.15 mm  1.30 mm  1.60 mm Background gray: These products are not recommended for new designs. ■ For details such as the catalog numbers, please refer to the capacitance range table on page 11 and after. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20230529 / mlcc_automotive_midvoltage_en.fm (9/18) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 Code CGA6/3225 [1210 inch] C0G X7R X7S X7T 2J 2W 2E 2A 2J 2E 2A 2A 2J 2W 2E (630V) (450V) (250V) (100V) (630V) (250V) (100V) (100V) (630V) (450V) (250V) 392 472 562 682 822 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 335 475 Standard thickness   1.25 mm  1.60 mm  2.00 mm  2.30 mm  2.50 mm Background gray: These products are not recommended for new designs. ■ For details such as the catalog numbers, please refer to the capacitance range table on page 11 and after. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20230529 / mlcc_automotive_midvoltage_en.fm (10/18) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 Code CGA8/4532 [1812 inch] C0G X7R X7S X7T 2J 2W 2E 2A 2J 2E 2A 2A 2J 2W 2E (630V) (450V) (250V) (100V) (630V) (250V) (100V) (100V) (630V) (450V) (250V) 822 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 335 475 Standard thickness   1.60 mm  2.00 mm  2.30 mm  2.50 mm  3.20 mm Background gray: These products are not recommended for new designs. ■ For details such as the catalog numbers, please refer to the capacitance range table on page 11 and after. Capacitance range chart Capacitance (pF) 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 Code CGA9/5750 [2220 inch] C0G X7R X7S X7T 2J 2W 2E 2A 2J 2E 2A 2A 2J 2W 2E (630V) (450V) (250V) (100V) (630V) (250V) (100V) (100V) (630V) (450V) (250V) 683 104 154 224 334 474 684 105 155 225 335 475 685 106 156 Standard thickness   1.60 mm   2.00 mm  2.30 mm  2.50 mm  2.80 mm Background gray: These products are not recommended for new designs. ■ For details such as the catalog numbers, please refer to the capacitance range table on page 11 and after. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20230529 / mlcc_automotive_midvoltage_en.fm (11/18) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions 1pF 1.5pF 2pF 2.2pF 3pF 3.3pF 4pF 4.7pF 5pF 6pF 6.8pF 7pF 8pF 9pF 10pF 12pF 15pF 18pF 22pF 27pF 33pF 39pF 47pF 56pF 68pF 82pF 100pF 120pF 150pF 180pF 220pF 270pF 330pF 390pF 470pF 560pF 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1608 1005 1608 2012 3216 1005 1608 2012 3216 1005 1608 2012 3216 1005 1608 2012 3216 1005 1608 2012 3216 1005 1608 2012 3216 1005 1608 2012 3216 1005 1608 2012 3216 1005 1608 2012 3216 1005 1608 2012 3216 Thickness (mm) Capacitance tolerance 0.80±0.10 ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.50pF ±0.50pF ±0.50pF ±0.50pF ±0.50pF ±0.50pF ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.80±0.10 0.50±0.05 0.80±0.10 0.60±0.15 0.60±0.15 0.50±0.05 0.80±0.10 0.60±0.15 0.60±0.15 0.50±0.05 0.80±0.10 0.60±0.15 0.60±0.15 0.50±0.05 0.80±0.10 0.60±0.15 0.60±0.15 0.50±0.05 0.80±0.10 0.60±0.15 0.60±0.15 0.50±0.05 0.80±0.10 0.60±0.15 0.60±0.15 0.50±0.05 0.80±0.10 0.60±0.15 0.60±0.15 0.50±0.05 0.80±0.10 0.60±0.15 0.60±0.15 0.50±0.10 0.80±0.10 0.60±0.15 0.85±0.15 0.50±0.05 0.80±0.10 0.60±0.15 0.85±0.15 Temperature characteristics: C0G (–55 to +125°C, 0±30ppm/°C) Catalog number Rated voltage Edc: 630V Rated voltage Edc: 450V Rated voltage Edc: 250V Rated voltage Edc: 100V CGA3E2C0G2A010C080AA CGA3E2C0G2A1R5C080AA CGA3E2C0G2A020C080AA CGA3E2C0G2A2R2C080AA CGA3E2C0G2A030C080AA CGA3E2C0G2A3R3C080AA CGA3E2C0G2A040C080AA CGA3E2C0G2A4R7C080AA CGA3E2C0G2A050C080AA CGA3E2C0G2A060D080AA CGA3E2C0G2A6R8D080AA CGA3E2C0G2A070D080AA CGA3E2C0G2A080D080AA CGA3E2C0G2A090D080AA CGA3E2C0G2A100D080AA CGA3E2C0G2A120J080AA CGA3E2C0G2A150J080AA CGA3E2C0G2A180J080AA CGA3E2C0G2A220J080AA CGA3E2C0G2A270J080AA CGA3E2C0G2A330J080AA CGA3E2C0G2A390J080AA CGA3E2C0G2A470J080AA CGA3E2C0G2A560J080AA CGA3E2C0G2A680J080AA CGA3E2C0G2A820J080AA CGA2B2C0G2A101J050BA CGA3E3C0G2E101J080AA CGA4C4C0G2W101J060AA CGA3E2C0G2A101J080AA CGA4C2C0G2A101J060AA CGA5C4C0G2J101J060AA CGA2B2C0G2A121J050BA CGA3E3C0G2E121J080AA CGA3E2C0G2A121J080AA CGA3E3C0G2E151J080AA CGA3E2C0G2A151J080AA CGA3E3C0G2E181J080AA CGA3E2C0G2A181J080AA CGA3E3C0G2E221J080AA CGA3E2C0G2A221J080AA CGA4C4C0G2W121J060AA CGA5C4C0G2J121J060AA CGA2B2C0G2A151J050BA CGA4C4C0G2W151J060AA CGA5C4C0G2J151J060AA CGA2B2C0G2A181J050BA CGA4C4C0G2W181J060AA CGA5C4C0G2J181J060AA CGA2B2C0G2A221J050BA CGA4C4C0G2W221J060AA CGA4C2C0G2A221J060AA CGA5C4C0G2J221J060AA CGA2B2C0G2A271J050BA CGA3E3C0G2E271J080AA CGA3E2C0G2A271J080AA CGA3E3C0G2E331J080AA CGA3E2C0G2A331J080AA CGA3E3C0G2E391J080AA CGA3E2C0G2A391J080AA CGA3E3C0G2E471J080AA CGA3E2C0G2A471J080AA CGA4C4C0G2W271J060AA CGA5C4C0G2J271J060AA CGA2B2C0G2A331J050BA CGA4C4C0G2W331J060AA CGA5C4C0G2J331J060AA CGA2B2C0G2A391J050BA CGA4C4C0G2W391J060AA CGA5C4C0G2J391J060AA CGA2B2C0G2A471J050BA CGA4C4C0G2W471J060AA CGA4C2C0G2A471J060AA CGA5F4C0G2J471J085AA CGA2B1C0G2A561J050BC CGA3E3C0G2E561J080AA CGA3E2C0G2A561J080AA CGA4C4C0G2W561J060AA CGA5F4C0G2J561J085AA ■ Gray items: These products are not recommended for new designs. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20230529 / mlcc_automotive_midvoltage_en.fm (12/18) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions 680pF 820pF 1nF 1005 1608 2012 3216 1005 1608 2012 3216 1005 1608 2012 3216 1608 1.2nF 2012 3216 1608 1.5nF 2012 3216 1608 1.8nF 2012 3216 1608 2.2nF 2.7nF 3.3nF 2012 3216 1608 2012 3216 1608 2012 3216 1608 2012 3.9nF Thickness (mm) Capacitance tolerance 0.50±0.05 ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% 0.80±0.10 0.60±0.15 0.85±0.15 0.50±0.05 0.80±0.10 0.60±0.15 0.85±0.15 0.50±0.05 0.80±0.10 0.60±0.15 0.85±0.15 0.85±0.15 0.80±0.10 0.60±0.15 0.85±0.15 0.85±0.15 0.80±0.10 0.60±0.15 0.85±0.15 1.15±0.15 0.80±0.10 0.85±0.15 1.25±0.20 1.15±0.15 0.80±0.10 0.80±0.20 0.85±0.15 1.25±0.20 1.15±0.15 0.80±0.20 1.25±0.20 1.60±0.20 0.80±0.20 0.85±0.15 1.25±0.20 0.85±0.15 1.60±0.20 0.80±0.10 1.25±0.20 0.60±0.15 3216 0.85±0.15 1.15±0.15 3225 1608 2012 4.7nF 3216 3225 1608 2012 5.6nF 3216 3225 1608 2012 6.8nF 3216 3225 1608 2012 8.2nF 3216 3225 4532 1.25±0.20 0.80±0.10 1.25±0.20 0.85±0.15 1.15±0.15 1.60±0.20 0.80±0.10 1.25±0.20 0.85±0.15 1.15±0.15 1.60±0.20 0.80±0.10 1.25±0.20 1.15±0.15 1.60±0.20 2.00±0.20 0.80±0.10 1.25±0.20 1.15±0.15 1.60±0.20 1.25±0.20 1.60±0.20 Temperature characteristics: C0G (–55 to +125°C, 0±30ppm/°C) Catalog number Rated voltage Edc: 630V Rated voltage Edc: 450V Rated voltage Edc: 250V Rated voltage Edc: 100V CGA2B1C0G2A681J050BC CGA3E3C0G2E681J080AA CGA3E2C0G2A681J080AA CGA4C4C0G2W681J060AA CGA5F4C0G2J681J085AA CGA2B1C0G2A821J050BC CGA3E3C0G2E821J080AA CGA4C4C0G2W821J060AA CGA3E2C0G2A821J080AA CGA4C3C0G2E821J060AA CGA5F4C0G2J821J085AA CGA2B1C0G2A102J050BC CGA3E3C0G2E102J080AA CGA4C4C0G2W102J060AA CGA3E2C0G2A102J080AA CGA4C2C0G2A102J060AA CGA4F3C0G2E102J085AA CGA5F4C0G2J102J085AA CGA3E3C0G2E122J080AA CGA4C4C0G2W122J060AA CGA3E2C0G2A122J080AA CGA4C2C0G2A122J060AA CGA4F3C0G2E122J085AA CGA5F4C0G2J122J085AA CGA3E3C0G2E152J080AA CGA3E2C0G2A152J080AA CGA4C2C0G2A152J060AA CGA4F4C0G2W152J085AA CGA4F3C0G2E152J085AA CGA5H4C0G2J152J115AA CGA3E3C0G2E182J080AA CGA4F4C0G2W182J085AA CGA3E2C0G2A182J080AA CGA4F2C0G2A182J085AA CGA4J3C0G2E182J125AA CGA5H4C0G2J182J115AA CGA3E2C0G2A222J080AA CGA3E3C0G2E222J080AA CGA4F4C0G2W222J085AA CGA4F2C0G2A222J085AA CGA4J3C0G2E222J125AA CGA5H4C0G2J222J115AA CGA3E2C0G2A272J080AA CGA4J4C0G2W272J125AA CGA4J3C0G2E272J125AA CGA4J2C0G2A272J125AA CGA5L4C0G2J272J160AA CGA3E2C0G2A332J080AA CGA4F3C0G2E332J085AA CGA4J4C0G2W332J125AA CGA4J2C0G2A332J125AA CGA5F3C0G2E332J085AA CGA5L4C0G2J332J160AA CGA3E1C0G2A392J080AC CGA4J4C0G2W392J125AA CGA4J3C0G2E392J125AA CGA4J2C0G2A392J125AA CGA5C2C0G2A392J060AA CGA5F4C0G2J392J085AA CGA5H3C0G2E392J115AA CGA6J4C0G2J392J125AA CGA3E1C0G2A472J080AC CGA4J4C0G2W472J125AA CGA4J3C0G2E472J125AA CGA5F4C0G2J472J085AA CGA4J2C0G2A472J125AA CGA5F2C0G2A472J085AA CGA5H3C0G2E472J115AA CGA6L4C0G2J472J160AA CGA3E1C0G2A562J080AC CGA4J4C0G2W562J125AA CGA4J3C0G2E562J125AA CGA4J2C0G2A562J125AA CGA5F2C0G2A562J085AA CGA5H4C0G2J562J115AA CGA5H3C0G2E562J115AA CGA6L4C0G2J562J160AA CGA3E1C0G2A682J080AC CGA4J3C0G2E682J125AA CGA5H4C0G2J682J115AA CGA5H4C0G2W682J115AA CGA4J2C0G2A682J125AA CGA5H2C0G2A682J115AA CGA5L3C0G2E682J160AA CGA6M4C0G2J682J200AA CGA3E1C0G2A822J080AC CGA4J3C0G2E822J125AA CGA5H4C0G2W822J115AA CGA5L4C0G2J822J160AA CGA4J2C0G2A822J125AA CGA5H2C0G2A822J115AA CGA5L3C0G2E822J160AA CGA6J4C0G2J822J125AA CGA8L4C0G2J822J160KA ■ Gray items: These products are not recommended for new designs. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20230529 / mlcc_automotive_midvoltage_en.fm (13/18) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions 1608 2012 10nF 3216 3225 4532 2012 Thickness (mm) Capacitance tolerance 0.80±0.10 ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% 1.25±0.20 1.15±0.15 1.60±0.20 1.25±0.20 1.60±0.20 1.60±0.20 0.85±0.15 1.15±0.15 3216 1.60+0.30,-0.10 1.60±0.20 15nF 1.25±0.20 3225 1.60±0.20 4532 2012 2.50±0.30 2.00±0.20 3216 22nF 3225 4532 33nF 1.25±0.20 1.60+0.30,-0.10 1.60±0.20 1.60±0.20 2.30±0.20 1.60±0.20 3.20±0.30 2012 3216 1.60+0.30,-0.10 3225 2.30±0.20 4532 3216 2.00±0.20 1.25±0.20 2.00±0.20 2.50±0.30 3225 47nF 1.15±0.15 2.30±0.20 2.50±0.30 2.00±0.20 4532 2.30±0.20 3.20±0.30 68nF 3216 3225 1.60±0.20 4532 2.50±0.30 2.30±0.20 2.30±0.20 3.20±0.30 100nF 150nF 5750 3216 4532 5750 5750 2.30±0.20 1.60±0.20 3.20±0.30 2.80±0.30 2.30±0.20 Temperature characteristics: C0G (–55 to +125°C, 0±30ppm/°C) Catalog number Rated voltage Edc: 630V Rated voltage Edc: 450V Rated voltage Edc: 250V Rated voltage Edc: 100V CGA3E1C0G2A103J080AC CGA5L4C0G2J103J160AA CGA4J3C0G2E103J125AA CGA4J2C0G2A103J125AA CGA5H3C0G2E103J115AA CGA5H2C0G2A103J115AA CGA5L4C0G2W103J160AA CGA6J4C0G2J103J125AA CGA6L3C0G2E103J160AA CGA8L4C0G2J103J160KA CGA4F1C0G2A153J085AC CGA5H2C0G2A153J115AA CGA5L4C0G2W153J160AA CGA5L3C0G2E153J160AA CGA6J2C0G2A153J125AA CGA6L4C0G2J153J160AA CGA6M3C0G2E153J200AA CGA8P4C0G2J153J250KA CGA4J1C0G2A223J125AC CGA5L3C0G2E223J160AA CGA5L2C0G2A223J160AA CGA6L3C0G2E223J160AA CGA6N4C0G2J223J230AA CGA6L2C0G2A223J160AA CGA6N4C0G2W223J230AA CGA8L3C0G2E223J160KA CGA8R4C0G2J223J320KA CGA4J1C0G2A333J125AC CGA5L2C0G2A333J160AA CGA6M2C0G2A333J200AA CGA6N3C0G2E333J230AA CGA6P4C0G2J333J250AA CGA6P4C0G2W333J250AA CGA8M4C0G2J333J200KA CGA8M3C0G2E333J200KA CGA5H1C0G2A473J115AC CGA6N2C0G2A473J230AA CGA6P3C0G2E473J250AA CGA8M2C0G2A473J200KA CGA8N4C0G2W473J230KA CGA8R4C0G2J473J320KA CGA8R3C0G2E473J320KA CGA5L1C0G2A683J160AC CGA6N2C0G2A683J230AA CGA8N4C0G2E683J230KN CGA8P2C0G2A683J250KA CGA8R4C0G2W683J320KA CGA9N1C0G2J683J230KC CGA5L1C0G2A104J160AC CGA9Q1C0G2J104J280KC CGA8R4C0G2E104J320KN CGA8R2C0G2A104J320KA CGA9N4C0G2E154J230KN CGA9N2C0G2A154J230KA CGA9Q4C0G2W104J280KA Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20230529 / mlcc_automotive_midvoltage_en.fm (14/18) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions Thickness (mm) 1608 0.80±0.10 3216 1.15±0.15 1608 0.80±0.10 3216 1.15±0.15 1608 0.80±0.10 3216 1.15±0.15 1608 0.80±0.10 3216 1.15±0.15 1608 0.80±0.10 3216 1.15±0.15 1608 0.80±0.10 2012 1.25±0.20 3216 1.15±0.15 1608 0.80±0.10 2012 1.25±0.20 3216 1.15±0.15 1608 0.80±0.10 2012 1.25±0.20 1nF 1.5nF 2.2nF 3.3nF 4.7nF 6.8nF 10nF 15nF 1.15±0.15 3216 1.30±0.20 1608 0.80±0.10 2012 1.25±0.20 22nF 1.15±0.15 3216 1.30±0.20 2012 33nF 1.25±0.20 1.15±0.15 3216 1.60±0.20 2012 1.25±0.20 1.15±0.15 47nF 3216 1.60±0.20 68nF 3225 2.00±0.20 3216 1.60±0.20 3225 2.00±0.20 4532 1.60±0.20 Capacitance tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Temperature characteristics: X7R (–55 to +125°C, ±15%) Catalog number Rated voltage Edc: 630V Rated voltage Edc: 250V Rated voltage Edc: 100V CGA3E2X7R2A102K080AA CGA3E2X7R2A102M080AA CGA5H4X7R2J102K115AA CGA5H4X7R2J102M115AA CGA3E2X7R2A152K080AA CGA3E2X7R2A152M080AA CGA5H4X7R2J152K115AA CGA5H4X7R2J152M115AA CGA3E2X7R2A222K080AA CGA3E2X7R2A222M080AA CGA5H4X7R2J222K115AA CGA5H4X7R2J222M115AA CGA3E2X7R2A332K080AA CGA3E2X7R2A332M080AA CGA5H4X7R2J332K115AA CGA5H4X7R2J332M115AA CGA3E2X7R2A472K080AA CGA3E2X7R2A472M080AA CGA5H4X7R2J472K115AA CGA5H4X7R2J472M115AA CGA3E2X7R2A682K080AA CGA3E2X7R2A682M080AA CGA4J3X7R2E682K125AA CGA4J3X7R2E682M125AA CGA5H4X7R2J682K115AA CGA5H4X7R2J682M115AA CGA3E2X7R2A103K080AA CGA3E2X7R2A103M080AA CGA4J3X7R2E103K125AA CGA4J3X7R2E103M125AA CGA5H4X7R2J103K115AA CGA5H4X7R2J103M115AA CGA4J3X7R2E153K125AA CGA4J3X7R2E153M125AA CGA5H3X7R2E153K115AA CGA5H3X7R2E153M115AA CGA3E2X7R2A153K080AA CGA3E2X7R2A153M080AA CGA4J2X7R2A153K125AA CGA4J2X7R2A153M125AA CGA5K4X7R2J153K130AA CGA5K4X7R2J153M130AA CGA4J3X7R2E223K125AA CGA4J3X7R2E223M125AA CGA5H3X7R2E223K115AA CGA5H3X7R2E223M115AA CGA3E2X7R2A223K080AA CGA3E2X7R2A223M080AA CGA4J2X7R2A223K125AA CGA4J2X7R2A223M125AA CGA5K4X7R2J223K130AA CGA5K4X7R2J223M130AA CGA4J2X7R2A333K125AA CGA4J2X7R2A333M125AA CGA5H2X7R2A333K115AA CGA5H2X7R2A333M115AA CGA5L4X7R2J333K160AA CGA5L4X7R2J333M160AA CGA5L3X7R2E333K160AA CGA5L3X7R2E333M160AA CGA4J2X7R2A473K125AA CGA4J2X7R2A473M125AA CGA5H2X7R2A473K115AA CGA5H2X7R2A473M115AA CGA5L3X7R2E473K160AA CGA5L3X7R2E473M160AA CGA6M4X7R2J473K200AA CGA6M4X7R2J473M200AA CGA5L3X7R2E683K160AA CGA5L3X7R2E683M160AA CGA5L2X7R2A683K160AA CGA5L2X7R2A683M160AA CGA6M4X7R2J683K200AA CGA6M4X7R2J683M200AA CGA8L4X7R2J683K160KA CGA8L4X7R2J683M160KA ■ Gray items: These products are not recommended for new designs. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20230529 / mlcc_automotive_midvoltage_en.fm (15/18) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions Thickness (mm) 2012 1.25±0.20 3216 1.60±0.20 3225 2.00±0.20 4532 2.30±0.20 3216 1.60±0.20 3225 2.00±0.20 4532 1.60±0.20 5750 1.60±0.20 3216 1.15±0.15 3225 2.00±0.20 4532 2.30±0.20 5750 2.30±0.20 3216 1.30±0.20 3225 2.00±0.20 4532 2.30±0.20 5750 1.60±0.20 3216 1.60±0.20 3225 2.00±0.20 4532 2.30±0.20 5750 2.30±0.20 3216 1.60±0.20 3225 1.60±0.20 4532 2.30±0.20 100nF 150nF 220nF 330nF 470nF 680nF 1.60±0.20 5750 2.30±0.20 3216 1.60±0.20 3225 2.00±0.20 4532 2.30±0.20 5750 2.30±0.20 3225 2.00±0.20 4532 2.30±0.20 5750 2.30±0.20 1µF 1.5µF Capacitance tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Temperature characteristics: X7R (–55 to +125°C, ±15%) Catalog number Rated voltage Edc: 630V Rated voltage Edc: 250V CGA5L3X7R2E104K160AA CGA5L3X7R2E104M160AA CGA6M3X7R2E104K200AA CGA6M3X7R2E104M200AA Rated voltage Edc: 100V CGA4J2X7R2A104K125AA CGA4J2X7R2A104M125AA CGA5L2X7R2A104K160AA CGA5L2X7R2A104M160AA CGA8N4X7R2J104K230KA CGA8N4X7R2J104M230KA CGA5L2X7R2A154K160AA CGA5L2X7R2A154M160AA CGA6M3X7R2E154K200AA CGA6M3X7R2E154M200AA CGA8L3X7R2E154K160KA CGA8L3X7R2E154M160KA CGA9L4X7R2J154K160KA CGA9L4X7R2J154M160KA CGA5H2X7R2A224K115AA CGA5H2X7R2A224M115AA CGA6M3X7R2E224K200AA CGA6M3X7R2E224M200AA CGA8N3X7R2E224K230KA CGA8N3X7R2E224M230KA CGA9N4X7R2J224K230KA CGA9N4X7R2J224M230KA CGA5K2X7R2A334K130AA CGA5K2X7R2A334M130AA CGA6M2X7R2A334K200AA CGA6M2X7R2A334M200AA CGA8N3X7R2E334K230KA CGA8N3X7R2E334M230KA CGA9L3X7R2E334K160KA CGA9L3X7R2E334M160KA CGA5L2X7R2A474K160AA CGA5L2X7R2A474M160AA CGA6M2X7R2A474K200AA CGA6M2X7R2A474M200AA CGA8N3X7R2E474K230KA CGA8N3X7R2E474M230KA CGA9N3X7R2E474K230KA CGA9N3X7R2E474M230KA CGA5L2X7R2A684K160AA CGA5L2X7R2A684M160AA CGA6L2X7R2A684K160AA CGA6L2X7R2A684M160AA CGA8N2X7R2A684K230KA CGA8N2X7R2A684M230KA CGA9L2X7R2A684K160KA CGA9L2X7R2A684M160KA CGA9N3X7R2E684K230KA CGA9N3X7R2E684M230KA CGA9N3X7R2E105K230KA CGA9N3X7R2E105M230KA CGA5L2X7R2A105K160AA CGA5L2X7R2A105M160AA CGA6M2X7R2A105K200AA CGA6M2X7R2A105M200AA CGA8N2X7R2A105K230KA CGA8N2X7R2A105M230KA CGA9N2X7R2A105K230KA CGA9N2X7R2A105M230KA CGA6M3X7R2A155K200AB CGA6M3X7R2A155M200AB CGA8N2X7R2A155K230KA CGA8N2X7R2A155M230KA CGA9N2X7R2A155K230KA CGA9N2X7R2A155M230KA ■ Gray items: These products are not recommended for new designs. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20230529 / mlcc_automotive_midvoltage_en.fm (16/18) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Thickness (mm) Capacitance tolerance Catalog number Rated voltage Edc: 100V 2012 1.25+0.25,-0.15 3225 2.30±0.20 4532 2.30±0.20 5750 2.30±0.20 ±10% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±10% ±20% CGA4J1X7R2A225K125AC CGA6N3X7R2A225K230AB CGA6N3X7R2A225M230AB CGA8N2X7R2A225K230KA CGA8N2X7R2A225M230KA CGA9N2X7R2A225K230KA CGA9N2X7R2A225M230KA CGA9N2X7R2A335K230KA CGA9N2X7R2A335M230KA CGA5L1X7R2A475K160AC CGA9N2X7R2A475K230KA CGA9N2X7R2A475M230KA Capacitance Dimensions 2.2µF 3.3µF 4.7µF Temperature characteristics: X7R (–55 to +125°C, ±15%) 5750 2.30±0.20 3216 1.6+0.30,-0.10 5750 2.30±0.20 ■ Gray items: These products are not recommended for new designs. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20230529 / mlcc_automotive_midvoltage_en.fm (17/18) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions Thickness (mm) 1nF 1005 0.50±0.05 1.5nF 1005 0.50±0.05 2.2nF 1005 0.50±0.05 3.3nF 1005 0.50±0.05 4.7nF 1005 0.50±0.05 6.8nF 1005 0.50±0.05 10nF 1005 0.50±0.05 33nF 1608 0.80±0.10 47nF 1608 0.80±0.10 68nF 1608 0.80±0.10 100nF 1608 0.80±0.10 330nF 2012 1.25±0.20 470nF 2012 1.25±0.20 680nF 2012 1.25±0.20 1µF 2012 1.25±0.20 1.5µF 3216 1.60±0.20 2.2µF 3216 1.60±0.20 3216 1.60+0.30,-0.10 3225 2.00±0.20 4532 2.00±0.20 3225 2.00±0.20 4532 2.30±0.20 6.8µF 5750 2.00±0.20 10µF 5750 2.30±0.20 15µF 5750 2.50±0.30 3.3µF 4.7µF Capacitance tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% Temperature characteristics: X7S (–55 to +125°C, ±22%) Catalog number Rated voltage Edc: 100V CGA2B3X7S2A102K050BB CGA2B3X7S2A102M050BB CGA2B3X7S2A152K050BB CGA2B3X7S2A152M050BB CGA2B3X7S2A222K050BB CGA2B3X7S2A222M050BB CGA2B3X7S2A332K050BB CGA2B3X7S2A332M050BB CGA2B3X7S2A472K050BB CGA2B3X7S2A472M050BB CGA2B3X7S2A682K050BB CGA2B3X7S2A682M050BB CGA2B3X7S2A103K050BB CGA2B3X7S2A103M050BB CGA3E3X7S2A333K080AB CGA3E3X7S2A333M080AB CGA3E3X7S2A473K080AB CGA3E3X7S2A473M080AB CGA3E3X7S2A683K080AB CGA3E3X7S2A683M080AB CGA3E3X7S2A104K080AB CGA3E3X7S2A104M080AB CGA4J3X7S2A334K125AB CGA4J3X7S2A334M125AB CGA4J3X7S2A474K125AB CGA4J3X7S2A474M125AB CGA4J3X7S2A684K125AB CGA4J3X7S2A684M125AB CGA4J3X7S2A105K125AB CGA4J3X7S2A105M125AB CGA5L3X7S2A155K160AB CGA5L3X7S2A155M160AB CGA5L3X7S2A225K160AB CGA5L3X7S2A225M160AB CGA5L3X7S2A335K160AB CGA5L3X7S2A335M160AB CGA6M3X7S2A335K200AB CGA6M3X7S2A335M200AB CGA8M3X7S2A335K200KB CGA8M3X7S2A335M200KB CGA6M3X7S2A475K200AB CGA6M3X7S2A475M200AB CGA8N3X7S2A475K230KB CGA8N3X7S2A475M230KB CGA9M3X7S2A685K200KB CGA9M3X7S2A685M200KB CGA9N3X7S2A106K230KB CGA9N3X7S2A106M230KB CGA9P3X7S2A156M250KB ■ Gray items: These products are not recommended for new designs. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20230529 / mlcc_automotive_midvoltage_en.fm (18/18) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance Dimensions Thickness (mm) 2012 1.25±0.20 3216 1.15±0.15 2012 1.25±0.20 3216 1.15±0.15 2012 1.25±0.20 3216 1.60±0.20 2012 1.25±0.20 3216 1.30±0.20 2012 1.25±0.20 3216 1.60±0.20 3225 1.60±0.20 3216 1.30±0.20 3225 2.00±0.20 4532 1.60±0.20 3216 1.60±0.20 3225 2.00±0.20 4532 2.00±0.20 3225 2.00±0.20 4532 1.60±0.20 5750 2.00±0.20 4532 2.30±0.20 5750 2.50±0.30 4532 1.60±0.20 5750 2.00±0.20 4532 2.50±0.30 5750 2.50±0.30 1.5µF 5750 2.00±0.20 2.2µF 5750 2.50±0.30 22nF 33nF 47nF 68nF 100nF 150nF 220nF 330nF 470nF 680nF 1µF Capacitance tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Temperature characteristics: X7T (–55 to +125°C, +22, –33%) Catalog number Rated voltage Edc: 630V Rated voltage Edc: 450V Rated voltage Edc: 250V CGA4J4X7T2W223K125AA CGA4J4X7T2W223M125AA CGA5H1X7T2J223K115AC CGA5H1X7T2J223M115AC CGA4J4X7T2W333K125AA CGA4J4X7T2W333M125AA CGA4J3X7T2E333K125AA CGA4J3X7T2E333M125AA CGA4J4X7T2W473K125AA CGA4J4X7T2W473M125AA CGA4J3X7T2E473K125AA CGA4J3X7T2E473M125AA CGA5H1X7T2J333K115AC CGA5H1X7T2J333M115AC CGA5L1X7T2J473K160AC CGA5L1X7T2J473M160AC CGA4J3X7T2E683K125AA CGA4J3X7T2E683M125AA CGA5K4X7T2W683K130AA CGA5K4X7T2W683M130AA CGA4J3X7T2E104K125AA CGA4J3X7T2E104M125AA CGA5L4X7T2W104K160AA CGA5L4X7T2W104M160AA CGA6L1X7T2J104K160AC CGA6L1X7T2J104M160AC CGA5K3X7T2E154K130AA CGA5K3X7T2E154M130AA CGA6M1X7T2J154K200AC CGA6M1X7T2J154M200AC CGA8L1X7T2J154K160KC CGA8L1X7T2J154M160KC CGA5L3X7T2E224K160AA CGA5L3X7T2E224M160AA CGA6M4X7T2W224K200AA CGA6M4X7T2W224M200AA CGA8M1X7T2J224K200KC CGA8M1X7T2J224M200KC CGA6M3X7T2E334K200AA CGA6M3X7T2E334M200AA CGA8L4X7T2W334K160KA CGA8L4X7T2W334M160KA CGA9M1X7T2J334K200KC CGA9M1X7T2J334M200KC CGA8N4X7T2W474K230KA CGA8N4X7T2W474M230KA CGA9P1X7T2J474K250KC CGA9P1X7T2J474M250KC CGA8L3X7T2E684K160KA CGA8L3X7T2E684M160KA CGA9M4X7T2W684K200KA CGA9M4X7T2W684M200KA CGA8P3X7T2E105K250KA CGA8P3X7T2E105M250KA CGA9P4X7T2W105K250KA CGA9P4X7T2W105M250KA CGA9M3X7T2E155K200KA CGA9M3X7T2E155M200KA CGA9P3X7T2E225K250KA CGA9P3X7T2E225M250KA ■ Gray items: These products are not recommended for new designs.   Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20230529 / mlcc_automotive_midvoltage_en.fm
CGA9N3X7S2A106M230KB 价格&库存
很抱歉,暂时无法提供与“CGA9N3X7S2A106M230KB”相匹配的价格&库存,您可以联系我们找货
