CGJ3E2C0G1H050C080AA
    TDK(东电化)
    0603(1608公制)
    贴片电容(MLCC) 0603 5pF ±0.25pF 50V C0G(NP0)
CGJ3E2C0G1H050C080AA 数据手册
April 2016 MULTILAYER CERAMIC CHIP CAPACITORS CGJ Series High Reliability Grade General (Up to 50V) Type: CGJ2 [EIA CC0402] CGJ3 [EIA CC0603] CGJ4 [EIA CC0805] CGJ5 [EIA CC1206] CGJ6 [EIA CC1210] (1/1) MULTILAYER CERAMIC CHIP CAPACITORS REMINDERS Please read before using this product SAFETY REMINDERS REMINDERS 1. If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other damage, you must contact our company’s sales window. 2. We may modify products or discontinue production of a product listed in this catalog without prior notification. 3. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. 4. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item accordingto the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire exportpermission in harmony with this law. 5. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. 6. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. 7. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging specification detail. This new catalog number should be referenced on all catalog orders going forward, and is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will differ from the item description (internal control number) on the product label. Contact your local TDK Sales representative for more information. (Example) Catalog Issued date Prior to January 2013 January 2013 and Later Catalog Number C1608C0G1E103J(080AA) C1608C0G1E103J080AA Item Description (On Delivery Label) C1608C0G1E103JT000N C1608C0G1E103JT000N 20160428 / mlcc_reminders_en.fm (1/9) MULTILAYER CERAMIC CHIP CAPACITORS Pb Lead Free CGJ Series RoHS Ecological COMPLIANT General (Up to 50V) Type: CGJ2 [EIA CC0402], CGJ3 [EIA CC0603], CGJ4 [EIA CC0805], CGJ5 [EIA CC1206], CGJ6 [EIA CC1210] • • • • Highly reliable products with long lifespans. Reliability tests based on AEC-Q200 requirements. Guaranteed TC Bias. UHF (Ultra High Frequency) RFID tag to allow integration with customer RFID programs such as inventory management is availavle by option. • Tamper proof seal to assist in the identification of authentic TDK CGJ products. • CGJ customer priority backed by TDK factory support. Features Applications • • • • • • Smart Meter, Smart Grid, LED Lighting Industrial Application, Telecom Base Station Solar Micro-inverters, Charging station Military Communication Equipment Class 1 & 2 Medical Equipment Applications that require extended life performance Shape & Dimensions Catalog Number Construction L W T B G Body Length Body Width Body Height Terminal Width Terminal Spacing CGJ • 5 • L • 2 • X7R • 1A • 106 • K • 160 • A • A Series Name Dimensions L x W (mm) Code 2 3 4 5 6 Length Width 1.00 ± 0.05 0.50 ± 0.05 1.60 ± 0.10 0.80 ± 0.10 2.00 ± 0.20 1.25 ± 0.20 3.20 ± 0.20 1.60 ± 0.20 3.20 ± 0.40 2.50 ± 0.30 ∗ Standard dimensions Terminal 0.10 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. Thickness T Code (mm) Code B C E F H J L M N P Voltage Condition for Life Test Thickness 0.50 mm 0.60 mm 0.80 mm 0.85 mm 1.15 mm 1.25 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm Symbol 1 2 3 4 Condition 1 × R.V. 2 × R.V. 1.5 × R.V. 1.2 × R.V. Temperature Characteristics Temperature Characteristics C0G X7R X7S Temperature Coefficient or Capacitance Change 0±30 ppm/°C ±15% ±22% Temperature Range -55 to +125°C - 55 to +125°C -55 to +125°C Rated Voltage (DC) Code 0J 1A 1C 1E 1H Voltage (DC) 6.3V 10V 16V 25V 50V Nominal Capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. Capacitance Tolerance Code C D J K Tolerance ± 0.25 pF ± 0.5 pF ± 5% ± 10% Nominal Thickness Code 050 060 080 085 115 125 160 200 230 250 Thickness 0.50 mm 0.60 mm 0.80 mm 0.85 mm 1.15 mm 1.25 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm Packaging Style Code A B Style 178 mm Reel, 4 mm Pitch 178 mm Reel, 2 mm Pitch Special Reserved Code Code A to C Description TDK Internal Code Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160428 / mlcc_highreliability_general_en.fm (2/9) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGJ2(1005) [EIA CC0402] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/℃), X7R (±15%) Rated Voltage: 50V (1H), 25V (1E), 16V (1C) Capacitance C0G Tolerance (pF) 1 1.5 2 2.2 3 3.3 4 4.7 5 6 6.8 7 8 9 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 Code 010 1R5 020 2R2 030 3R3 040 4R7 050 060 6R8 070 080 090 100 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 152 222 332 472 682 103 153 223 333 473 683 104 Standard Thickness 1H (50V) X7R 1H (50V) 1E (25V) 1C (16V) C : ± 0.25pF D : ± 0.5pF J : ± 5% C0G; J : ± 5% X7R; K : ± 10% 0.50 mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160428 / mlcc_highreliability_general_en.fm (3/9) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGJ3(1608) [EIA CC0603] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/℃), X7R (±15%) Rated Voltage: 50V (1H), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J) Capacitance C0G Tolerance (pF) 1 1.5 2 2.2 3 3.3 4 4.7 5 6 6.8 7 8 9 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 Code 010 1R5 020 2R2 030 3R3 040 4R7 050 060 6R8 070 080 090 100 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 1H (50V) X7R 1H (50V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) C: ± 0.25pF D: ± 0.5pF J : ± 5% C0G; J : ± 5% X7R; K : ± 10% Standard Thickness 0.80 mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160428 / mlcc_highreliability_general_en.fm (4/9) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGJ4(2012) [EIA CC0805] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/℃), X7R (±15%) Rated Voltage: 50V (1H), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J) Capacitance C0G Tolerance (pF) 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 Code 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 335 475 685 106 1H (50V) X7R 1H (50V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) J : ± 5% C0G; J : ± 5% X7R; K : ± 10% Standard Thickness 0.60 mm 0.85 mm 1.25 mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160428 / mlcc_highreliability_general_en.fm (5/9) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGJ5(3216) [EIA CC1206] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/℃), X7R (±15%) Rated Voltage: 50V (1H), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J) Capacitance C0G Tolerance (pF) 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 Code 392 472 562 682 822 103 153 223 333 473 683 104 474 684 105 155 225 335 475 685 106 1H (50V) X7R 1H (50V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) J : ± 5% K: ± 10% Standard Thickness 0.60 mm 0.85 mm 1.15 mm 1.60 mm Capacitance Range Chart CGJ6(3225) [EIA CC1210] Capacitance Range Chart Temperature Characteristics: X7R (±15%), X7S (±22%) Rated Voltage: 50V (1H), 25V (1E), 16V (1C) Capacitance X7R Tolerance (pF) 1,000,000 1,500,000 4,700,000 6,800,000 10,000,000 Code 105 155 475 685 106 K: ± 10% 1H (50V) 1E (25V) X7S 1C (16V) 1H (50V) Standard Thickness 1.60 mm 2.00 mm 2.30 mm 2.50 mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160428 / mlcc_highreliability_general_en.fm (6/9) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: C0G(-55 to +125℃, 0 ± 30 ppm/℃) Capacitance 1 pF 1.5 pF 2 pF 2.2 pF 3 pF 3.3 pF 4 pF 4.7 pF 5 pF 6 pF 6.8 pF 7 pF 8 pF 9 pF 10 pF 12 pF 15 pF 18 pF 22 pF 27 pF 33 pF 39 pF 47 pF 56 pF 68 pF 82 pF 100 pF 120 pF 150 pF Size Thickness (mm) Capacitance Tolerance Catalog Number Rated Voltage Edc: 50V 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 1005 1608 2012 1005 1608 2012 1005 1608 2012 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.25pF ± 0.5pF ± 0.5pF ± 0.5pF ± 0.5pF ± 0.5pF ± 0.5pF ± 0.5pF ± 0.5pF ± 0.5pF ± 0.5pF ± 0.5pF ± 0.5pF ± 5pF ± 5pF ± 5pF ± 5pF ± 5pF ± 5pF ± 5pF ± 5pF ± 5pF ± 5pF ± 5pF ± 5pF ± 5pF ± 5pF ± 5pF ± 5pF ± 5pF ± 5pF ± 5pF ± 5pF ± 5pF ± 5pF ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% CGJ2B2C0G1H010C050BA CGJ3E2C0G1H010C080AA CGJ2B2C0G1H1R5C050BA CGJ3E2C0G1H1R5C080AA CGJ2B2C0G1H020C050BA CGJ3E2C0G1H020C080AA CGJ2B2C0G1H2R2C050BA CGJ3E2C0G1H2R2C080AA CGJ2B2C0G1H030C050BA CGJ3E2C0G1H030C080AA CGJ2B2C0G1H3R3C050BA CGJ3E2C0G1H3R3C080AA CGJ2B2C0G1H040C050BA CGJ3E2C0G1H040C080AA CGJ2B2C0G1H4R7C050BA CGJ3E2C0G1H4R7C080AA CGJ2B2C0G1H050C050BA CGJ3E2C0G1H050C080AA CGJ2B2C0G1H060D050BA CGJ3E2C0G1H060D080AA CGJ2B2C0G1H6R8D050BA CGJ3E2C0G1H6R8D080AA CGJ2B2C0G1H070D050BA CGJ3E2C0G1H070D080AA CGJ2B2C0G1H080D050BA CGJ3E2C0G1H080D080AA CGJ2B2C0G1H090D050BA CGJ3E2C0G1H090D080AA CGJ2B2C0G1H100D050BA CGJ3E2C0G1H100D080AA CGJ2B2C0G1H120J050BA CGJ3E2C0G1H120J080AA CGJ2B2C0G1H150J050BA CGJ3E2C0G1H150J080AA CGJ2B2C0G1H180J050BA CGJ3E2C0G1H180J080AA CGJ2B2C0G1H220J050BA CGJ3E2C0G1H220J080AA CGJ2B2C0G1H270J050BA CGJ3E2C0G1H270J080AA CGJ2B2C0G1H330J050BA CGJ3E2C0G1H330J080AA CGJ2B2C0G1H390J050BA CGJ3E2C0G1H390J080AA CGJ2B2C0G1H470J050BA CGJ3E2C0G1H470J080AA CGJ2B2C0G1H560J050BA CGJ3E2C0G1H560J080AA CGJ2B2C0G1H680J050BA CGJ3E2C0G1H680J080AA CGJ2B2C0G1H820J050BA CGJ3E2C0G1H820J080AA CGJ2B2C0G1H101J050BA CGJ3E2C0G1H101J080AA CGJ4C2C0G1H101J060AA CGJ2B2C0G1H121J050BA CGJ3E2C0G1H121J080AA CGJ4C2C0G1H121J060AA CGJ2B2C0G1H151J050BA CGJ3E2C0G1H151J080AA CGJ4C2C0G1H151J060AA Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160428 / mlcc_highreliability_general_en.fm (7/9) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: C0G(-55 to +125℃, 0 ± 30 ppm/℃) Capacitance 180 pF 220 pF 270 pF 330 pF 390 pF 470 pF 560 pF 680 pF 820 pF 1 nF 1.2 nF 1.5 nF 1.8 nF 2.2 nF 2.7 nF 3.3 nF 3.9 nF 4.7 nF 5.6 nF 6.8 nF 8.2 nF 10 nF Size Thickness (mm) Capacitance Tolerance Catalog Number Rated Voltage Edc: 50V 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 1608 2012 1608 2012 1608 2012 1608 2012 1608 2012 1608 2012 1608 2012 3216 1608 2012 3216 1608 2012 3216 1608 2012 3216 1608 2012 3216 1608 2012 3216 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.50 ± 0.05 0.80 ± 0.10 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% CGJ2B2C0G1H181J050BA CGJ3E2C0G1H181J080AA CGJ4C2C0G1H181J060AA CGJ2B2C0G1H221J050BA CGJ3E2C0G1H221J080AA CGJ4C2C0G1H221J060AA CGJ2B2C0G1H271J050BA CGJ3E2C0G1H271J080AA CGJ4C2C0G1H271J060AA CGJ2B2C0G1H331J050BA CGJ3E2C0G1H331J080AA CGJ4C2C0G1H331J060AA CGJ2B2C0G1H391J050BA CGJ3E2C0G1H391J080AA CGJ4C2C0G1H391J060AA CGJ2B2C0G1H471J050BA CGJ3E2C0G1H471J080AA CGJ4C2C0G1H471J060AA CGJ2B2C0G1H561J050BA CGJ3E2C0G1H561J080AA CGJ4C2C0G1H561J060AA CGJ2B2C0G1H681J050BA CGJ3E2C0G1H681J080AA CGJ4C2C0G1H681J060AA CGJ2B2C0G1H821J050BA CGJ3E2C0G1H821J080AA CGJ4C2C0G1H821J060AA CGJ2B2C0G1H102J050BA CGJ3E2C0G1H102J080AA CGJ4C2C0G1H102J060AA CGJ3E2C0G1H122J080AA CGJ4C2C0G1H122J060AA CGJ3E2C0G1H152J080AA CGJ4C2C0G1H152J060AA CGJ3E2C0G1H182J080AA CGJ4C2C0G1H182J060AA CGJ3E2C0G1H222J080AA CGJ4C2C0G1H222J060AA CGJ3E2C0G1H272J080AA CGJ4C2C0G1H272J060AA CGJ3E2C0G1H332J080AA CGJ4C2C0G1H332J060AA CGJ3E2C0G1H392J080AA CGJ4C2C0G1H392J060AA CGJ5C2C0G1H392J060AA CGJ3E2C0G1H472J080AA CGJ4C2C0G1H472J060AA CGJ5C2C0G1H472J060AA CGJ3E2C0G1H562J080AA CGJ4C2C0G1H562J060AA CGJ5C2C0G1H562J060AA CGJ3E2C0G1H682J080AA CGJ4C2C0G1H682J060AA CGJ5C2C0G1H682J060AA CGJ3E2C0G1H822J080AA CGJ4C2C0G1H822J060AA CGJ5C2C0G1H822J060AA CGJ3E2C0G1H103J080AA CGJ4C2C0G1H103J060AA CGJ5C2C0G1H103J060AA Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160428 / mlcc_highreliability_general_en.fm (8/9) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: C0G(-55 to +125℃, 0 ± 30 ppm/℃) Capacitance 15 nF 22 nF 33 nF 47 nF 68 nF 100 nF Size Thickness (mm) Capacitance Tolerance 2012 3216 2012 3216 2012 3216 3216 3216 3216 0.85 ± 0.15 0.60 ± 0.15 1.25 ± 0.20 0.60 ± 0.15 1.25 ± 0.20 0.85 ± 0.15 1.15 ± 0.15 1.60 ± 0.20 1.60 ± 0.20 ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% Catalog Number Rated Voltage Edc: 50V CGJ4F2C0G1H153J085AA CGJ5C2C0G1H153J060AA CGJ4J2C0G1H223J125AA CGJ5C2C0G1H223J060AA CGJ4J2C0G1H333J125AA CGJ5F2C0G1H333J085AA CGJ5H2C0G1H473J115AA CGJ5L2C0G1H683J160AA CGJ5L2C0G1H104J160AA Class 2 (Temperature Stable) Temperature Characteristics: X7R(-55 to +125℃, ±15%) Capacitance Size 1 nF 1.5 nF 2.2 nF 3.3 nF 4.7 nF 6.8 nF 1005 1005 1005 1005 1005 1005 1005 1608 1005 1608 1005 1608 1005 1608 2012 1005 1608 2012 1005 1608 2012 1005 1608 2012 1608 2012 1608 2012 1608 2012 1608 2012 3216 1608 2012 3216 1608 2012 3216 3225 2012 3216 10 nF 15 nF 22 nF 33 nF 47 nF 68 nF 100 nF 150 nF 220 nF 330 nF 470 nF 680 nF 1 μF 1.5 μF 3225 Thickness (mm) Capacitance Tolerance Catalog Number Rated Voltage Edc: 50V Rated Voltage Edc: 25V Rated Voltage Edc: 16V 0.50 ± 0.05 0.50 ± 0.05 0.50 ± 0.05 0.50 ± 0.05 0.50 ± 0.05 0.50 ± 0.05 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 0.50 ± 0.05 0.80 ± 0.10 1.25 ± 0.20 0.50 ± 0.05 0.80 ± 0.10 1.25 ± 0.20 0.50 ± 0.05 0.80 ± 0.10 1.25 ± 0.20 0.50 ± 0.05 0.80 ± 0.10 1.25 ± 0.20 0.80 ± 0.10 1.25 ± 0.20 0.80 ± 0.10 1.25 ± 0.20 0.80 ± 0.10 1.25 ± 0.20 0.80 ± 0.10 1.25 ± 0.20 1.60 +0.30/-0.10 0.80 ± 0.10 1.25 ± 0.20 1.60 +0.30/-0.10 0.80 ± 0.10 1.25 ± 0.20 1.60 +0.30/-0.10 1.60 ± 0.20 1.25 ± 0.20 1.60 +0.30/-0.10 1.60 ± 0.20 2.00 ± 0.20 ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% CGJ2B2X7R1H102K050BA CGJ2B2X7R1E102K050BA CGJ2B2X7R1C102K050BA CGJ2B2X7R1H152K050BA CGJ2B2X7R1E152K050BA CGJ2B2X7R1C152K050BA CGJ2B2X7R1H222K050BA CGJ2B2X7R1E222K050BA CGJ2B2X7R1C222K050BA CGJ2B2X7R1H332K050BA CGJ2B2X7R1E332K050BA CGJ2B2X7R1C332K050BA CGJ2B2X7R1H472K050BA CGJ2B2X7R1E472K050BA CGJ2B2X7R1C472K050BA CGJ2B2X7R1H682K050BA CGJ2B2X7R1E682K050BA CGJ2B2X7R1C682K050BA CGJ2B3X7R1H103K050BB CGJ2B2X7R1E103K050BA CGJ2B2X7R1C103K050BA CGJ3E2X7R1H103K080AA CGJ3E2X7R1E103K080AA CGJ3E2X7R1C103K080AA CGJ2B3X7R1H153K050BB CGJ2B2X7R1E153K050BA CGJ2B2X7R1C153K050BA CGJ3E2X7R1H153K080AA CGJ3E2X7R1E153K080AA CGJ3E2X7R1C153K080AA CGJ2B3X7R1H223K050BB CGJ2B2X7R1E223K050BA CGJ2B2X7R1C223K050BA CGJ3E2X7R1H223K080AA CGJ3E2X7R1E223K080AA CGJ3E2X7R1C223K080AA CGJ2B3X7R1H333K050BB CGJ2B2X7R1E333K050BA CGJ2B2X7R1C333K050BA CGJ3E2X7R1H333K080AA CGJ3E2X7R1E333K080AA CGJ3E2X7R1C333K080AA CGJ4J2X7R1H333K125AA CGJ4J2X7R1E333K125AA CGJ4J2X7R1C333K125AA CGJ2B3X7R1H473K050BB CGJ2B2X7R1E473K050BA CGJ2B2X7R1C473K050BA CGJ3E2X7R1H473K080AA CGJ3E2X7R1E473K080AA CGJ3E2X7R1C473K080AA CGJ4J2X7R1H473K125AA CGJ4J2X7R1E473K125AA CGJ4J2X7R1C473K125AA CGJ2B3X7R1E683K050BB CGJ2B2X7R1C683K050BA CGJ3E2X7R1H683K080AA CGJ3E2X7R1E683K080AA CGJ3E2X7R1C683K080AA CGJ4J2X7R1H683K125AA CGJ4J2X7R1E683K125AA CGJ4J2X7R1C683K125AA CGJ2B3X7R1E104K050BB CGJ2B2X7R1C104K050BA CGJ3E2X7R1H104K080AA CGJ3E2X7R1E104K080AA CGJ3E2X7R1C104K080AA CGJ4J2X7R1H104K125AA CGJ4J2X7R1E104K125AA CGJ4J2X7R1C104K125AA CGJ3E3X7R1H154K080AB CGJ3E2X7R1E154K080AA CGJ3E2X7R1C154K080AA CGJ4J2X7R1H154K125AA CGJ4J2X7R1E154K125AA CGJ4J2X7R1C154K125AA CGJ3E3X7R1H224K080AB CGJ3E2X7R1E224K080AA CGJ3E2X7R1C224K080AA CGJ4J2X7R1H224K125AA CGJ4J2X7R1H334K125AA CGJ4J3X7R1H474K125AB Rated Voltage Edc: 10V CGJ4J2X7R1E224K125AA CGJ4J2X7R1C224K125AA CGJ4J2X7R1A224K125AA CGJ3E3X7R1E334K080AB CGJ3E2X7R1C334K080AA CGJ3E2X7R1A334K080AA CGJ4J2X7R1E334K125AA CGJ4J2X7R1C334K125AA CGJ4J2X7R1A334K125AA CGJ3E3X7R1E474K080AB CGJ3E2X7R1C474K080AA CGJ3E2X7R1A474K080AA CGJ4J2X7R1E474K125AA CGJ4J2X7R1C474K125AA CGJ4J2X7R1A474K125AA CGJ3E1X7R1E684K080AC CGJ3E3X7R1C684K080AB CGJ3E2X7R1A684K080AA CGJ4J2X7R1E684K125AA CGJ4J2X7R1C684K125AA CGJ4J2X7R1A684K125AA CGJ3E1X7R1E105K080AC CGJ3E3X7R1C105K080AB CGJ3E2X7R1A105K080AA CGJ4J2X7R1E105K125AA CGJ4J2X7R1C105K125AA CGJ4J2X7R1A105K125AA CGJ5L2X7R1H474K160AA CGJ4J3X7R1H684K125AB CGJ5L2X7R1H684K160AA CGJ4J3X7R1H105K125AB CGJ5L2X7R1E105K160AA CGJ6L2X7R1H105K160AA CGJ5L3X7R1H155K160AB CGJ6L2X7R1E105K160AA CGJ6L2X7R1C105K160AA CGJ4J3X7R1E155K125AB CGJ4J2X7R1C155K125AA CGJ4J2X7R1A155K125AA CGJ5L2X7R1E155K160AA CGJ5L2X7R1C155K160AA CGJ5L2X7R1A155K160AA CGJ6L2X7R1E155K160AA CGJ6L2X7R1C155K160AA CGJ6M2X7R1H155K200AA Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160428 / mlcc_highreliability_general_en.fm (9/9) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X7R(-55 to +125℃, ±15%) Capacitance 2.2 μF 3.3 μF 4.7 μF 6.8 μF 10 μF Size Thickness (mm) Capacitance Tolerance 2012 3216 2012 3216 2012 3216 3216 3216 1.25 ± 0.20 1.60 +0.30/-0.10 1.25 ± 0.20 1.60 +0.30/-0.10 1.25 ± 0.20 1.60 +0.30/-0.10 1.60 +0.30/-0.10 1.60 +0.30/-0.10 ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% Catalog Number Rated Voltage Edc: 50V CGJ5L3X7R1H225K160AB Rated Voltage Edc: 25V Rated Voltage Edc: 16V CGJ4J3X7R1E225K125AB CGJ4J2X7R1C225K125AA Rated Voltage Edc: 10V CGJ4J2X7R1A225K125AA CGJ5L2X7R1E225K160AA CGJ5L2X7R1C225K160AA CGJ5L2X7R1A225K160AA CGJ4J1X7R1E335K125AC CGJ4J3X7R1C335K125AB CGJ4J2X7R1A335K125AA CGJ5L3X7R1E335K160AB CGJ5L2X7R1C335K160AA CGJ5L2X7R1A335K160AA CGJ4J1X7R1E475K125AC CGJ4J3X7R1C475K125AB CGJ4J2X7R1A475K125AA CGJ5L3X7R1E475K160AB CGJ5L2X7R1C475K160AA CGJ5L2X7R1A475K160AA CGJ5L2X7R1A685K160AA CGJ5L2X7R1A106K160AA Class 2 (Temperature Stable) Temperature Characteristics: X7R(-55 to +125℃, ±15%) Capacitance Size Thickness (mm) Capacitance Tolerance 220 nF 2012 1608 2012 1608 2012 1608 2012 1608 2012 1608 2012 3216 1608 2012 3216 2012 3216 2012 3216 2012 3216 2012 3216 1.25 ± 0.20 0.80 ± 0.10 1.25 ± 0.20 0.80 ± 0.10 1.25 ± 0.20 0.80 ± 0.10 1.25 ± 0.20 0.80 ± 0.10 1.25 ± 0.20 0.80 ± 0.10 1.25 ± 0.20 1.60 +0.30/-0.10 0.80 ± 0.10 1.25 ± 0.20 1.60 +0.30/-0.10 1.25 ± 0.20 1.60 +0.30/-0.10 1.25 ± 0.20 1.60 +0.30/-0.10 1.25 ± 0.20 1.60 +0.30/-0.10 1.25 ± 0.20 1.60 +0.30/-0.10 ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% 330 nF 470 nF 680 nF 1 μF 1.5 μF 2.2 μF 3.3 μF 4.7 μF 6.8 μF 10 μF Catalog Number Rated Voltage Edc: 6.3V CGJ4J2X7R0J224K125AA CGJ3E2X7R0J334K080AA CGJ4J2X7R0J334K125AA CGJ3E2X7R0J474K080AA CGJ4J2X7R0J474K125AA CGJ3E2X7R0J684K080AA CGJ4J2X7R0J684K125AA CGJ3E2X7R0J105K080AA CGJ4J2X7R0J105K125AA CGJ3E1X7R0J155K080AC CGJ4J2X7R0J155K125AA CGJ5L2X7R0J155K160AA CGJ3E1X7R0J225K080AC CGJ4J2X7R0J225K125AA CGJ5L2X7R0J225K160AA CGJ4J2X7R0J335K125AA CGJ5L2X7R0J335K160AA CGJ4J2X7R0J475K125AA CGJ5L2X7R0J475K160AA CGJ4J1X7R0J685K125AC CGJ5L2X7R0J685K160AA CGJ4J1X7R0J106K125AC CGJ5L2X7R0J106K160AA Class 2 (Temperature Stable) Temperature Characteristics: X7S(-55 to +125℃, ±22%) Capacitance Size Thickness (mm) Capacitance Tolerance Catalog Number Rated Voltage Edc: 50V 4.7 μF 6.8 μF 10 μF 3225 3225 3225 2.30 ± 0.20 2.50 ± 0.30 2.50 ± 0.30 ± 10% ± 10% ± 10% CGJ6N3X7S1H475K230AB CGJ6P3X7S1H685K250AB CGJ6P3X7S1H106K250AB Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160428 / mlcc_highreliability_general_en.fm
CGJ3E2C0G1H050C080AA 价格&库存
很抱歉,暂时无法提供与“CGJ3E2C0G1H050C080AA”相匹配的价格&库存,您可以联系我们找货
