CGJ5K2X7R2A334K130AA
    TDK(东电化)
    1206(3216公制)
    贴片电容(MLCC) 1206 330nF ±10% 100V X7R
CGJ5K2X7R2A334K130AA 数据手册
April 2016 MULTILAYER CERAMIC CHIP CAPACITORS CGJ Series High Reliability Grade Mid Voltage (100 to 630V) Type: CGJ3 [EIA CC0603] CGJ4 [EIA CC0805] CGJ5 [EIA CC1206] CGJ6 [EIA CC1210] (1/1) MULTILAYER CERAMIC CHIP CAPACITORS REMINDERS Please read before using this product SAFETY REMINDERS REMINDERS 1. If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other damage, you must contact our company’s sales window. 2. We may modify products or discontinue production of a product listed in this catalog without prior notification. 3. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. 4. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item accordingto the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire exportpermission in harmony with this law. 5. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. 6. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. 7. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging specification detail. This new catalog number should be referenced on all catalog orders going forward, and is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will differ from the item description (internal control number) on the product label. Contact your local TDK Sales representative for more information. (Example) Catalog Issued date Prior to January 2013 January 2013 and Later Catalog Number C1608C0G1E103J(080AA) C1608C0G1E103J080AA Item Description (On Delivery Label) C1608C0G1E103JT000N C1608C0G1E103JT000N 20160428 / mlcc_reminders_en.fm (1/8) MULTILAYER CERAMIC CHIP CAPACITORS Pb Lead Free CGJ Series RoHS COMPLIANT Ecological Mid Voltage (100 to 630V) Type: CGJ3 [EIA CC0603], CGJ4 [EIA CC0805], CGJ5 [EIA CC1206], CGJ6 [EIA CC1210] • • • • Highly reliable products with long lifespans. Reliability tests based on AEC-Q200 requirements. Guaranteed TC Bias. UHF (Ultra High Frequency) RFID tag to allow integration with customer RFID programs such as inventory management is availavle by option. • Tamper proof seal to assist in the identification of authentic TDK CGJ products. • CGJ customer priority backed by TDK factory support. Features Catalog Number Construction • • • • • • Applications Shape & Dimensions Smart Meter, Smart Grid, LED Lighting Industrial Application, Telecom Base Station Solar Micro-inverters, Charging station Military Communication Equipment Class 1 & 2 Medical Equipment Applications that require extended life performance L W T B G Body Length Body Width Body Height Terminal Width Terminal Spacing CGJ • 6 • M • 3 • X7S • 2A • 475 • K • 200 • A • A Series Name Dimensions L x W (mm) Code 3 4 5 6 Length Width 1.60 ± 0.10 0.80 ± 0.10 2.00 ± 0.20 1.25 ± 0.20 3.20 ± 0.20 1.60 ± 0.20 3.20 ± 0.40 2.50 ± 0.30 ∗ Standard dimensions Terminal 0.20 min. 0.20 min. 0.20 min. 0.20 min. Thickness T Code (mm) Code C E F H J K L M Voltage Condition for Life Test Thickness 0.60 mm 0.80 mm 0.85 mm 1.15 mm 1.25 mm 1.30 mm 1.60 mm 2.00 mm Symbol 1 2 3 4 Condition 1 × R.V. 2 × R.V. 1.5 × R.V. 1.2 × R.V. Temperature Characteristics Temperature Temperature Coefficient or Characteristics Capacitance Change 0±30 ppm/°C C0G ±15% X7R ±22% X7S X7T +22/-33% Temperature Range -55 to +125°C -55 to +125°C -55 to +125°C -55 to +125°C Rated Voltage (DC) Code 2A 2D 2H Voltage (DC) 100V 200V 500V Nominal Capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. Ex. 0R2 = 0.2pF; 103 = 10,000pF; 105 = 1,000,000pF = 100nF = 1 F Capacitance Tolerance Code Tolerance J K ± 5% ± 10% Nominal Thickness Code 060 080 085 115 Thickness 0.60 mm 0.80 mm 0.85 mm 1.15 mm Code 125 130 160 200 Thickness 1.25 mm 1.30 mm 1.60 mm 2.00 mm Packaging Style Code A Style 178 mm Reel, 4 mm Pitch Special Reserved Code Code A Description TDK Internal Code Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160428 / mlcc_highreliability_midvoltage_en.fm (2/8) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGJ3(1608) [EIA CC0603] Capacitance Range Chart Temperature Characteristics: C0G (0 ±30ppm/℃), X7R (±15%), X7S (±22%) Rated Voltage: 200V (2D), 100V (2A) Capacitance C0G Tolerance (pF) 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 2,200 3,300 4,700 6,800 10,000 33,000 47,000 68,000 100,000 Code 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 222 332 472 682 103 333 473 683 104 X7R X7S 2D 2A 2A 2A (200V) (100V) (100V) (100V) J: ± 5% C0G; J : ± 5% X7R, X7S; K : ± 10% Standard Thickness 0.80 mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160428 / mlcc_highreliability_midvoltage_en.fm (3/8) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGJ4(2012) [EIA CC0805] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/℃), X7R (±15%), X7S (±22%), X7T (+22%/-33%) Rated Voltage: 200V (2D), 100V (2A) Capacitance C0G Tolerance (pF) 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 330,000 470,000 Code 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 682 103 153 223 333 473 683 104 334 474 X7R X7S X7T 2D 2A 2D 2A 2A 2D (200V) (100V) (200V) (100V) (100V) (200V) J : ± 5% K: ± 10% Standard Thickness 0.60 mm 0.85 mm 1.25 mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160428 / mlcc_highreliability_midvoltage_en.fm (4/8) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGJ5(3216) [EIA CC1206] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/℃), X7R (±15%), X7S (±22%), X7T (+22%/-33%) Rated Voltage: 500V (2H), 200V (2D), 100V (2A) Capacitance C0G Tolerance (pF) 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 1,500,000 Code 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 153 223 333 473 683 104 154 224 334 474 155 X7R X7S X7T 2H 2D 2A 2H 2D 2A 2A 2H 2D (500V) (200V) (100V) (500V) (200V) (100V) (100V) (500V) (200V) J: ± 5% C0G; J : ± 5% X7R, X7S, X7T; K : ± 10% Standard Thickness 0.60 mm 0.85 mm 1.15 mm 1.30 mm 1.60 mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160428 / mlcc_highreliability_midvoltage_en.fm (5/8) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CGJ6(3225) [EIA CC1210] Capacitance Range Chart Temperature Characteristics: X7R (±15%), X7S (±22%), X7T (+22%/-33%) Rated Voltage: 500V (2H), 200V (2D), 100V (2A) Capacitance X7R Tolerance (pF) 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 3,300,000 4,700,000 Code 473 683 104 154 224 334 474 684 105 335 475 X7S X7T 2H 2D 2A 2A 2H 2D (500V) (200V) (100V) (100V) (500V) (200V) K: ± 10% Standard Thickness 1.60 mm 2.00 mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160428 / mlcc_highreliability_midvoltage_en.fm (6/8) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: C0G(-55 to +125℃, 0 ± 30 ppm/℃) Capacitance 100 pF 120 pF 150 pF 180 pF 220 pF 270 pF 330 pF 390 pF 470 pF 560 pF 680 pF 820 pF 1 nF Size 1608 2012 3216 1608 2012 3216 1608 2012 3216 1608 2012 3216 1608 2012 3216 1608 2012 3216 1608 2012 3216 1608 2012 3216 1608 2012 3216 1608 2012 3216 1608 2012 3216 1608 2012 3216 1608 2012 3216 1608 1.2 nF 2012 3216 1.5 nF 2012 3216 1.8 nF 2012 3216 2.2 nF 2.7 nF 3.3 nF 2012 3216 2012 3216 2012 3216 Thickness (mm) Capacitance Tolerance 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.60 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.85 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.85 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.85 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.85 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.85 ± 0.15 0.85 ± 0.15 0.80 ± 0.10 0.60 ± 0.15 0.85 ± 0.15 0.85 ± 0.15 0.60 ± 0.15 0.85 ± 0.15 1.15 ± 0.15 0.85 ± 0.15 1.25 ± 0.20 1.15 ± 0.15 0.85 ± 0.15 1.25 ± 0.20 1.15 ± 0.15 1.25 ± 0.20 1.60 ± 0.20 1.25 ± 0.20 0.85 ± 0.15 1.60 ± 0.20 ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% Catalog Number Rated Voltage Edc: 500V Rated Voltage Edc: 200V CGJ3E3C0G2D101J080AA Rated Voltage Edc: 100V CGJ3E2C0G2A101J080AA CGJ4C2C0G2A101J060AA CGJ5C4C0G2H101J060AA CGJ3E3C0G2D121J080AA CGJ3E2C0G2A121J080AA CGJ4C2C0G2A121J060AA CGJ5C4C0G2H121J060AA CGJ3E3C0G2D151J080AA CGJ3E2C0G2A151J080AA CGJ4C2C0G2A151J060AA CGJ5C4C0G2H151J060AA CGJ3E3C0G2D181J080AA CGJ3E2C0G2A181J080AA CGJ4C2C0G2A181J060AA CGJ5C4C0G2H181J060AA CGJ3E3C0G2D221J080AA CGJ3E2C0G2A221J080AA CGJ4C2C0G2A221J060AA CGJ5C4C0G2H221J060AA CGJ3E3C0G2D271J080AA CGJ3E2C0G2A271J080AA CGJ4C2C0G2A271J060AA CGJ5C4C0G2H271J060AA CGJ3E3C0G2D331J080AA CGJ3E2C0G2A331J080AA CGJ4C2C0G2A331J060AA CGJ5C4C0G2H331J060AA CGJ3E3C0G2D391J080AA CGJ3E2C0G2A391J080AA CGJ4C2C0G2A391J060AA CGJ5C4C0G2H391J060AA CGJ3E3C0G2D471J080AA CGJ3E2C0G2A471J080AA CGJ4C2C0G2A471J060AA CGJ5F4C0G2H471J085AA CGJ3E3C0G2D561J080AA CGJ3E2C0G2A561J080AA CGJ4C2C0G2A561J060AA CGJ5F4C0G2H561J085AA CGJ3E3C0G2D681J080AA CGJ3E2C0G2A681J080AA CGJ4C2C0G2A681J060AA CGJ5F4C0G2H681J085AA CGJ3E2C0G2A821J080AA CGJ4C3C0G2D821J060AA CGJ4C2C0G2A821J060AA CGJ5F4C0G2H821J085AA CGJ3E2C0G2A102J080AA CGJ4C2C0G2A102J060AA CGJ4F3C0G2D102J085AA CGJ5F4C0G2H102J085AA CGJ3E2C0G2A122J080AA CGJ4C2C0G2A122J060AA CGJ4F3C0G2D122J085AA CGJ5F4C0G2H122J085AA CGJ4C2C0G2A152J060AA CGJ4F3C0G2D152J085AA CGJ5H4C0G2H152J115AA CGJ4F2C0G2A182J085AA CGJ4J3C0G2D182J125AA CGJ5H4C0G2H182J115AA CGJ4F2C0G2A222J085AA CGJ4J3C0G2D222J125AA CGJ5H4C0G2H222J115AA CGJ4J3C0G2D272J125AA CGJ4J2C0G2A272J125AA CGJ5L4C0G2H272J160AA CGJ4J2C0G2A332J125AA CGJ5F3C0G2D332J085AA CGJ5L4C0G2H332J160AA Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160428 / mlcc_highreliability_midvoltage_en.fm (7/8) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: C0G(-55 to +125℃, 0 ± 30 ppm/℃) Capacitance Size 2012 3.9 nF 3216 2012 4.7 nF 3216 5.6 nF 3216 6.8 nF 3216 8.2 nF 3216 10 nF 3216 Thickness (mm) Capacitance Tolerance 1.25 ± 0.20 0.60 ± 0.15 0.85 ± 0.15 1.15 ± 0.15 1.25 ± 0.20 0.85 ± 0.15 1.15 ± 0.15 0.85 ± 0.15 1.15 ± 0.15 1.15 ± 0.15 1.60 ± 0.20 1.15 ± 0.15 1.60 ± 0.20 1.15 ± 0.15 1.60 ± 0.20 ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% Catalog Number Rated Voltage Edc: 500V Rated Voltage Edc: 200V Rated Voltage Edc: 100V CGJ4J2C0G2A392J125AA CGJ5C2C0G2A392J060AA CGJ5F4C0G2H392J085AA CGJ5H3C0G2D392J115AA CGJ4J2C0G2A472J125AA CGJ5F4C0G2H472J085AA CGJ5F2C0G2A472J085AA CGJ5H3C0G2D472J115AA CGJ5F2C0G2A562J085AA CGJ5H4C0G2H562J115AA CGJ5H3C0G2D562J115AA CGJ5H4C0G2H682J115AA CGJ5H2C0G2A682J115AA CGJ5L3C0G2D682J160AA CGJ5H2C0G2A822J115AA CGJ5L4C0G2H822J160AA CGJ5L3C0G2D822J160AA CGJ5H2C0G2A103J115AA CGJ5L4C0G2H103J160AA Class 2 (Temperature Stable) Temperature Characteristics: X7R(-55 to +125℃, ±15%) Capacitance 1 nF 1.5 nF 2.2 nF 3.3 nF 4.7 nF 6.8 nF 10 nF 15 nF Size 1608 3216 1608 3216 1608 3216 1608 3216 1608 3216 1608 2012 3216 1608 2012 3216 2012 3216 2012 22 nF 3216 2012 33 nF 3216 2012 47 nF 68 nF 100 nF 150 nF 220 nF 330 nF 3216 3225 3216 3225 3216 3225 3216 3225 3216 3225 3216 3225 Thickness (mm) Capacitance Tolerance 0.80 ± 0.10 1.15 ± 0.15 0.80 ± 0.10 1.15 ± 0.15 0.80 ± 0.10 1.15 ± 0.15 0.80 ± 0.10 1.15 ± 0.15 0.80 ± 0.10 1.15 ± 0.15 0.80 ± 0.10 1.25 ± 0.20 1.15 ± 0.15 0.80 ± 0.10 1.25 ± 0.20 1.15 ± 0.15 1.25 ± 0.20 1.15 ± 0.15 1.30 ± 0.20 1.25 ± 0.20 1.15 ± 0.15 1.30 ± 0.20 1.25 ± 0.20 1.15 ± 0.15 1.60 ± 0.20 1.25 ± 0.20 1.15 ± 0.15 1.60 ± 0.20 2.00 ± 0.20 1.60 ± 0.20 2.00 ± 0.20 1.60 ± 0.20 2.00 ± 0.20 1.60 ± 0.20 2.00 ± 0.20 1.15 ± 0.15 2.00 ± 0.20 1.30 ± 0.20 2.00 ± 0.20 ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% Catalog Number Rated Voltage Edc: 500V Rated Voltage Edc: 200V Rated Voltage Edc: 100V CGJ3E2X7R2A102K080AA CGJ5H4X7R2H102K115AA CGJ3E2X7R2A152K080AA CGJ5H4X7R2H152K115AA CGJ3E2X7R2A222K080AA CGJ5H4X7R2H222K115AA CGJ3E2X7R2A332K080AA CGJ5H4X7R2H332K115AA CGJ3E2X7R2A472K080AA CGJ5H4X7R2H472K115AA CGJ3E2X7R2A682K080AA CGJ4J3X7R2D682K125AA CGJ5H4X7R2H682K115AA CGJ3E2X7R2A103K080AA CGJ4J3X7R2D103K125AA CGJ5H4X7R2H103K115AA CGJ4J3X7R2D153K125AA CGJ4J2X7R2A153K125AA CGJ5H3X7R2D153K115AA CGJ5K4X7R2H153K130AA CGJ4J3X7R2D223K125AA CGJ4J2X7R2A223K125AA CGJ5H3X7R2D223K115AA CGJ5K4X7R2H223K130AA CGJ4J2X7R2A333K125AA CGJ5H2X7R2A333K115AA CGJ5L4X7R2H333K160AA CGJ5L3X7R2D333K160AA CGJ4J2X7R2A473K125AA CGJ5H2X7R2A473K115AA CGJ5L3X7R2D473K160AA CGJ6M4X7R2H473K200AA CGJ5L3X7R2D683K160AA CGJ5L2X7R2A683K160AA CGJ5L3X7R2D104K160AA CGJ5L2X7R2A104K160AA CGJ6M4X7R2H683K200AA CGJ6M3X7R2D104K200AA CGJ5L2X7R2A154K160AA CGJ6M3X7R2D154K200AA CGJ5H2X7R2A224K115AA CGJ6M3X7R2D224K200AA CGJ5K2X7R2A334K130AA CGJ6M2X7R2A334K200AA Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160428 / mlcc_highreliability_midvoltage_en.fm (8/8) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X7R(-55 to +125℃, ±15%) Capacitance 470 nF 680 nF 1 μF Size Thickness (mm) Capacitance Tolerance 3216 3225 3225 3225 1.60 ± 0.20 2.00 ± 0.20 1.60 ± 0.20 2.00 ± 0.20 ± 10% ± 10% ± 10% ± 10% Catalog Number Rated Voltage Edc: 500V Rated Voltage Edc: 100V CGJ5L2X7R2A474K160AA CGJ6M2X7R2A474K200AA CGJ6L2X7R2H684K160AA CGJ6M2X7R2A105K200AA Class 2 (Temperature Stable) Temperature Characteristics: X7S(-55 to +125℃, ±22%) Capacitance Size Thickness (mm) Capacitance Tolerance Catalog Number Rated Voltage Edc: 100V 33 nF 47 nF 68 nF 100 nF 330 nF 470 nF 1.5 μF 3.3 μF 4.7 μF 1608 1608 1608 1608 2012 2012 3216 3225 3225 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 0.80 ± 0.10 1.25 ± 0.20 1.25 ± 0.20 1.60 ± 0.20 2.00 ± 0.20 2.00 ± 0.20 ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% CGJ3E3X7S2A333K080AA CGJ3E3X7S2A473K080AA CGJ3E3X7S2A683K080AA CGJ3E3X7S2A104K080AA CGJ4J3X7S2A334K125AA CGJ4J3X7S2A474K125AA CGJ5L3X7S2A155K160AA CGJ6M3X7S2A335K200AA CGJ6M3X7S2A475K200AA Class 2 (Temperature Stable) Temperature Characteristics: X7T(-55 to +125℃, +22/-33%) Capacitance Size Thickness (mm) Capacitance Tolerance Catalog Number Rated Voltage Edc: 500V 22 nF 3216 2012 3216 2012 3216 2012 2012 3225 3216 3225 3216 3225 1.15 ± 0.15 1.25 ± 0.20 1.15 ± 0.15 1.25 ± 0.20 1.60 ± 0.20 1.25 ± 0.20 1.25 ± 0.20 1.60 ± 0.20 1.30 ± 0.20 2.00 ± 0.20 1.60 ± 0.20 2.00 ± 0.20 ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% CGJ5H4X7T2H223K115AA 33 nF 47 nF 68 nF 100 nF 150 nF 220 nF 330 nF Rated Voltage Edc: 200V CGJ4J3X7T2D333K125AA CGJ5H4X7T2H333K115AA CGJ4J3X7T2D473K125AA CGJ5L4X7T2H473K160AA CGJ4J3X7T2D683K125AA CGJ4J3X7T2D104K125AA CGJ6L4X7T2H104K160AA CGJ5K3X7T2D154K130AA CGJ6M4X7T2H154K200AA CGJ5L3X7T2D224K160AA CGJ6M3X7T2D334K200AA Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160428 / mlcc_highreliability_midvoltage_en.fm
物料型号:CGJ系列,包括CGJ3 [EIA CC0603]、CGJ4 [EIA CC0805]、CGJ5 [EIA CC1206] 和 CGJ6 [EIA CC1210]。
器件简介:这些电容器是无铅且符合RoHS标准的环保产品,具有高可靠性和长寿命,适用于智能电表、智能电网、LED照明、工业应用、电信基站、太阳能微型逆变器、充电站、军事通信设备、1类和2类医疗设备等。
引脚分配:文档中未明确提供引脚分配信息,但根据EIA标准,可以推断出不同型号的尺寸和引脚间距。
参数特性:电容器的额定电压范围从100V到630V,容量范围从100pF到10μF,具有不同的温度特性和电容公差,例如C0G、X7R、X7S和X7T。
功能详解:文档提供了详细的产品特点,包括基于AEC-Q200要求的可靠性测试、保证的TC偏差、UHF RFID标签选项、防篡改密封以及TDK工厂支持的客户优先权。
应用信息:适用于需要延长使用寿命性能的应用,如智能电网、LED照明、工业应用等。
封装信息:提供了详细的封装尺寸和厚度信息,以及对应的目录编号构建方法。
CGJ5K2X7R2A334K130AA 价格&库存
很抱歉,暂时无法提供与“CGJ5K2X7R2A334K130AA”相匹配的价格&库存,您可以联系我们找货
