CHS-GSS
CHS-GSS
    TDK(东电化)
    Ceramic
CHS-GSS 数据手册
納入仕様書     仕様書番号 SPEC. No. C129NAA*****       発 行 日 DATE: SPECIFICATION MESSRS.      御中     貴社品名 CUSTOMER’S PRODUCT NAME 弊社品名 TDK PRODUCT NAME                        HUMIDITY SENSOR UNIT CHS-GSS 受領印欄 THIS SPECIFICATION IS RECEIVED   受領日      年   DATE: YEAR 営業部門     TDK 株式会社             〒103 東京都中央区日本橋 1-13-1     TDK Corporation 1-13-1,Nihonbashi,Chuo-ku, Tokyo SALES     責任者  担当者 MANAGER SALES     月   MONTH   日 DAY 技術部門 ENGINEERING   責任者  確認者  担当者 APPROVED BY 103,Japan 担当営業所    Sales Office 検索用製品分類コード   営業担当者電話              PRODUCT CLASSIFICATION CODE      Sales Tel. CHECKED BY ISSUED BY                             P1 Product Information, Precautions and Warnings - IMPORTANT Before use, please read the following carefully as the product use in improper conditions may shorten product life. Please confirm the functional life in your usage conditions ahead of actualinstallations. Although TDK makes its utmost effort to constantly improve reliability of its product quality, your misuse may cause the product malfunctioning and property damage and/or human injury. For this reason, TDK requests that customers use the products with sufficient handling care and add a safeguard design upon your application so as to prevent malfunctioning of your systems, serious damages, personal accidents, fires and other possible damages, which may result from using these products of ours. Precaution: The product's operating life is limited because the products are constantly exposed to various environments when used. For this reason, this "operating life" must be taken into consideration before use. (1)Storage ・Store the products within the "absolute maximum ratings" specified. ・Do not store the products in dusty places or in places where corrosive gases are generated. ・When storing CHS series humidity sensors for long(over 1 year) or storing in places with high temperature and high humidity or where sudden temperature change may occur, the humidity-sensitive film on the sensor elements as well as the solderability of the terminals of the sensor unit may deteriorate to cause output changes in excess of the guaranteed ranges. (2)Operating Environment and Conditions ・Use CHS series within the "absolute maximum ratings" of the operating environmental conditions specified. ・Electrically, such as input voltages, please stay within our electrical specifications. ・Avoid usage in locations subject to corrosive gases or excessive dust as these may cause the element's deterioration, resulting in output changes in excess of guaranteed ranges. Please consider measures to keep the corrosive gases from entering the sensor unit, for example, by a special jig to seal it, particularly during a solder flow process where flux-decomposed gases generate. ・Avoid usage in locations subject to excessive dewing or to water or salt water, as it may deteriorate the element to cause output changes in excess of guaranteed ranges. (3)Handling ・Applying excessive physical impacts to the sensor, such as by dropping, should be strictly avoided. ・Avoid applying excessive mechanical stress onto the product, for instance, when forming the terminals, for it may cause damages to the component. 変更履歴 Revision Records 版 Rev. 年月日 Date 担 当 Revised By 事業部(部) Div. Sensor Actuator Business Group 変 更 内 容 Revision 作成日 Date 仕様書番号 Spec. No. C129NAA*****                                            P2 基本目次 Basic contents 1.適用範囲 Scope of Application 本仕様書は 殿へ納入する湿度センサユニットに適用する。 This specification shall be applied to the product HUMIDITY SENSOR UNIT to be delivered to Messrs. . 2.製品の名称 Name of Product 本仕様書に定める製品の名称は CHS-GSS とする。 The name of the product to be defined in this specification shall be defined as CHS-GSS. 3.関連規格 Related Spec. 4.記載項目 Description Items Attached drawing and tables Page HANDLING AND PRECAUTIONS 1/6 1.Maximum Ratings 3/6 2.Ratings 3/6 3.Characteristics 4/6 4.Appearance Structure and Dimensions 5/6 5. Marking 5/6 6. Mechanical Performance Characteristics 6/6 変更履歴 Revision Records 版 Rev. 年月日 Date 担 当 Revised By 事業部(部) Div. Sensor Actuator Business Group 変 更 内 容 Revision 作成日 Date 仕様書番号 Spec. No. C129NAA***** 1. MAXIMUM RATINGS Power voltage Ambient conditions +7V D.C. (at 25deg) During operating : 0 to +50 deg, 5Vdc power voltage, without dewing During storage : -20 to +60 deg, without dewing 2. RATINGS Item Operating voltage(Vo) Min. 4.75 Ratings Typ. Max. 5 Operating current 5.25 0.6 Output voltage 10 Output impedance Unit V Vo=5.0V 25 deg Vo=5.0V mV/%RH 25 deg 5%RH to 95%RH (200) mA kΩ Accuracy -5 +5 %RH Temperature dependency -5 +5 %RH Hysteresis Response time Recommended operating temperature TDK CORPORATION 5 Conditions ≒0 %RH 1 min. 45 ℃ at DC Vo=5.0V 25 deg 5%RH to 90%RH (See characteristics chart.) Vo=5.0V 5 to 45 deg (25 deg standard) (See characteristics chart.) Allow 20 minutes for stabilization response 90% humidity change between 30%RH and 85%RH Vo=5.0V without dewing 図面名:NAME OF DRAWING 図番:DRAWING No. 頁:PAGE SPECIFICATION C129NAA***** 3 / 6 TSB-08-01-05(00) 様式-2(A4) 3. CHARACTERISTICS (Representative example) 3-1. LINEARITY CHARACTERISTICS 1.0 Sensor Output(V) 0.8 Centerline Allowance Typical value +5%RH 0.6 0.4 -5%RH 0.2 0.0 0 20 40 60 80 100 Relative humidity ( % R H ) 3-2.TEMPERATURE CHARACTERISTICS Sensor Output(V) 1.0 0.8 95%RH 90%RH 80%RH 70%RH 0.6 60%RH 50%RH 40%RH 0.4 Typical value (+/-5%RH specification temperature zone, 25deg standard) 30%RH 0.2 20%RH 0.0 10%RH 5%RH 0 10 20 30 40 Not pecification temperature zone 50 Temperature(℃) TDK CORPORATION 図面名:NAME OF DRAWING 図番:DRAWING No. 頁:PAGE SPECIFICATION C129NAA***** 4 / 6 TSB-08-01-05(00) 様式-2(A4) 4. APPEARANCE STRUCTURE AND DIMENSIONS (20) (10) (5) CHS-GSS MARKING Pin No.1 Sensor output Pin No.2 GND Pin No.3 Vcc Unit : mm Tolerance : +/-0.2 Weight : 1.05g typ. 5. MARKING CHS-GSS XA1 X A 1 Secret number Vout G TDK CORPORATION +5 * Symbols, color dots, and the like may be added as necessary 図面名:NAME OF DRAWING 図番:DRAWING No. 頁:PAGE SPECIFICATION C129NAA***** 5 / 6 TSB-08-01-05(00) 様式-2(A4) 6. MECHANICAL PERFORMANCE CHARACTERISTICS ITEM TEST CONDITION VIBRATION RESISTANCE at frequencies of 5 to 55Hz, at amplitude of 2.0mm into the X, Y and Z directions, each for two hours. SHOCK RESISTANCE at 100G,for 6msec, three times in each of the X, Y and Z directions. SPECIFICATIONS Deviation from initial value +/-5%RH or less NATURAL FALL from a height of 30cm onto concrete floor. HIGHTEMPERATURE STORAGE TEST LOWTEMPERATURE STORAGE TEST THERMAL SHOCK TEST +60 deg 240h Deviation from initial value +/-5%RH or less -40 deg 240h -40 to +60 deg each lasting 30 min. 10cyc TEMPERATURE -40 to +60 deg CYCLE Stable time 1h, rise and fall time 1h. 10cyc TDK CORPORATION 図面名:NAME OF DRAWING 図番:DRAWING No. 頁:PAGE SPECIFICATION C129NAA***** 6 / 6 TSB-08-01-05(00) 様式-2(A4)
CHS-GSS 价格&库存
很抱歉,暂时无法提供与“CHS-GSS”相匹配的价格&库存,您可以联系我们找货
CHS-GSS
  • 5+231.22833
  • 19+221.64017
  • 38+212.76537
  • 188+204.25331
  • 564+195.65660
库存:32
