CHS-MSS
CHS-MSS
    TDK(东电化)
    Ceramic
    CHS-MSS
CHS-MSS 数据手册
S E N S O R S June 2016 Humidity Sensor CHS series (2/11) S E N S O R S Humidity Sensor Product compatible with RoHS directive Overview of the CHS series APPLICATION Refrigerators (condensation prevention), Air conditioners (indoor humidity control), PPCs, LBPs (image quality control), Industrial electronic humidity sensors, air conditioners for plant factories, etc. PRODUCT LINEUP ASSEMBLY Type CHS-UPS CHS-UPR CHS-UGS CHS-UGR CHS-MSS Driving range Guaranteed measurement accuracy range 5 to 95%RH +25°C 5 to 95%RH 0 to +50°C CHS-CGC5-28 20 to 85%RH +25°C Accuracy Driving voltage Output voltage ±3%RH 0 to 1.0V ±5%RH 50%RH +25°C ±7%RH 5VDC 0 to 2.0V Shapes Size SQUARE TYPE ROUND TYPE SQUARE TYPE ROUND TYPE 27×11.5×6.5 ø20×9 27×11.5×6.5 ø20×9 SQUARE TYPE 20×10×5 PCB ASSY 19×21×12.6 ELEMENT Type Driving range Guaranteed measurement accuracy range Accuracy Driving voltage Output impedance Shapes Size CHS-ESS-CA5 5 to 95%RH 0 to +50°C 50%RH +25°C ±5%RH AC5V max. 1k to 80M : (AC1V/1kHz) SQUARE TYPE 9.0×6.5×3.7 RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160622 / sensor_humidity_chs_en.fm (3/11) S E N S O R S Assembly・Sensor units with built-in circuits CHS-UPS, -UPR, -UGS, -UGR  FEATURES Measures a wide humidity range of 5 to 95% RH. High accuracy. The nominal accuracy for the CHS-UPR and -UPS within ±3% RH. The temperature characteristics are stable over a wide range. Humidity-sensitive characteristics exhibit virtually no hysteresis. Highly cost-effective and compact, requiring extremely little mounting space. Low current consumption. Outputs DC.1V at 100(%)RH; relative humidity can be read directly with a voltmeter. It is of an all-in-one construction that integrates all needed circuitry and operates on a 5V power supply. SHAPE & DIMENSIONS CHS-UPS, -UGS 6.5max. 11.5max. 27max. Sensor face Sensor face CHS - UPS V out G +5 5.7±0.5 ① Vout ② GND ③ Vcc ① ② ③ (3.8) 0.49 2.5 Tolerance:±0.2mm Dimensions in mm 2.5 CHS-UPR, -UGR 20max. Sensor face 5±0.5 9max. Label ① ② 5 5 ① Vout ② GND ③ Vcc ③ Label 5 0.49 Tolerance:±0.2mm Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160622 / sensor_humidity_chs_en.fm (4/11) S E N S O R S Assembly・Sensor units with built-in circuits CHS-UPS, -UPR, -UGS, -UGR  MAXIMUM RATINGS Power supply voltage Edc Operating conditions Storage conditions 7V max. (Ta=25°C) 0 to +50°C, power supply voltage of 5 V, no dew condensation –20 to +60°C, no dew condensation TYPICAL ELECTRICAL CHARACTERISTICS Item Measurement accuracy(%RH) CHS-UPS, -UPR CHS-UGS, -UGR Driving voltage Edc(V) Operating current(mA) Output voltage(mV)/%RH Output impedance(k:) Hysteresis(%)RH Temperature dependency(%RH) Response time(min) Recommended operating temperature(°C) Min. –3 –5 4.75 –5 +5 Standard Max. +3 +5 5 5.25 0.6 10 200 |0 +5 1 +45 Condition Edc=5V, 25°C, 5 to 95%RH Edc=5V, 25°C, 5 to 95%RH Edc=5V, 25°C Edc=5V, 25°C, 5 to 95%RH at DC Stable time: 20min Edc=5V, 25°C standard, +5 to 45°C, 5 to 95%RH 1 Response time to reach 90% of actual humidity from 30 to 85% RH Edc=5V, no dew condensation Reference value EXAMPLE OF SENSOR LINEARITY CHARACTERISTICS CHS-UPS, -UPR CHS-UGS, -UGR at Edc=5V, Ta=25°C, 5% to 95%RH at Edc=5V, Ta=25°C, 5% to 95%RH 1 1 0.9 0.9 0.8 3%RH 0.7 Output voltage( V ) Output voltage( V ) 0.8 0.6 0.5 0.4 3%RH 0.3 0.6 0.5 0.4 0.2 0.1 0.1 0 20 40 60 80 Relative humidity (%RH) 100 5%RH 0.3 0.2 0 5%RH 0.7 0 0 20 40 60 80 Relative humidity (%RH) 100 EXAMPLE OF THERMAL CHARACTERISTICS (TEMPERATURE DEPENDENCY) at Edc=5V, +5 to +45°C, 5% to 95%RH 1 95%RH 90%RH 0.9 80%RH Output voltage( V ) 0.8 0.7 70%RH 0.6 60%RH 0.5 50%RH 0.4 40%RH 0.3 30%RH 0.2 20%RH 0.1 10%RH 5%RH 0 5 10 15 20 25 30 35 Temperature ( °C) 40 45 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160622 / sensor_humidity_chs_en.fm (5/11) S E N S O R S Assembly・Sensor units with built-in circuits CHS-MSS FEATURES A compact type that is the smallest and lightest in the series. Guarantees a measurement accuracy of ±5% RH in the humidity range of 20 to 85% RH. Feature low current consumption (0.6 mA with a driving voltage of 5 V at 25°C). Humidity-sensitive characteristics exhibit virtually no hysteresis. SHAPE & DIMENSIONS 10max. 5max. Sensor face Sensor face 20max. CHS - MSS (7) Vout G +5 1 2 0.5 3 1 2.5 2 Vout GND Vcc 0.25 3 2.5 Tolerance:±0.2mm Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160622 / sensor_humidity_chs_en.fm (6/11) S E N S O R S Assembly・Sensor units with built-in circuits CHS-MSS MAXIMUM RATINGS Power supply voltage Edc Operating conditions Storage conditions 7V max. (Ta=25°C) 0 to +50°C, power supply voltage of 5 V, no dew condensation –20 to +60°C, no dew condensation TYPICAL ELECTRICAL CHARACTERISTICS Item Driving voltage Edc(V) Operating current(mA) Output voltage(mV)/%RH Output impedance(k:) Measurement accuracy(%RH) Hysteresis(%)RH Temperature dependency(%RH) Response time(min) Recommended operating temperature(°C) Min. 4.75 –5 –5 +15 Standard Max. 5 5.25 0.6 10 200 +5 1 +5 1 +35 Condition Edc=5V, 25°C Edc=5V, 25°C, 20 to 85%RH at DC Edc=5V, 25°C, 20 to 85%RH Stable time: 20min Edc=5V, 25°C standard, +15 to 35°C, 20 to 85%RH 1 Response time to reach 90% of actual humidity from 30 to 85% RH Edc=5V, no dew condensation Reference value EXAMPLE OF THERMAL CHARACTERISTICS (TEMPERATURE DEPENDENCY) at Edc=5V, Ta=25°C, 20% to 85%RH at Edc=5V, +15 to +35°C, 20% to 85%RH 1 1 0.9 0.9 0.8 0.8 5%RH Output voltage( V ) Output voltage( V ) EXAMPLE OF SENSOR LINEARITY CHARACTERISTICS 0.7 0.6 0.5 0.4 5%RH 95%RH 90%RH 80%RH 70%RH 60%RH 0.7 0.6 50%RH 0.5 40%RH 0.4 0.3 30%RH 0.2 0.2 20%RH 0.1 0.1 0 0 0.3 0 20 40 60 80 Relative humidity (%RH) 100 10%RH 5%RH 5 10 15 20 25 30 35 Temperature ( °C) 40 45 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160622 / sensor_humidity_chs_en.fm (7/11) S E N S O R S Assembly・Sensor units with built-in circuits CHS-CGC5-28 FEATURES A small sensor element and connector are mounted on a PCB on which circuits are constituted. Guarantees a measurement accuracy of ±7% RH at 50% RH in humidity. Allows output voltage suitable for the measured humidity to be obtained when connected to a 5V power supply. The hysteresis of the humidity-sensitive characteristics is about 1% RH. Equipped with a thermistor for humidity detection. SHAPE & DIMENSIONS 21 4.75 19 8.2 ø3.5±0.1 3.45 9.5 4 4 3 3 2 2 1 1 Thermistor GND Vout Vcc 7max. 4 max. 1.6 Connector: 292250-4(AMP) Sensor element Area without parts and the pattern (Installation area) Tolerance:±0.5mm Dimensions in mm BUILT-IN SENSOR (THERMISTOR) CONNECTION EXAMPLE Edc R Sensor element 4 3 2 Vout Detection temperature output 1 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160622 / sensor_humidity_chs_en.fm (8/11) S E N S O R S Assembly・Sensor units with built-in circuits CHS-CGC5-28 MAXIMUM RATINGS Power supply voltage Edc Operating conditions Storage conditions 7V max. (Ta=25°C) 0 to +50°C, power supply voltage of 5 V, no dew condensation –20 to +60°C, no dew condensation TYPICAL ELECTRICAL CHARACTERISTICS Item Driving voltage Edc(V) Operating current(mA) Output impedance(k:) Min. 4.75 Standard Max. 5 5.25 2 100 –7 +7 0.724V 0.89V 1.096V 1 1 Measurement accuracy(%RH) Hysteresis(%)RH Response time(min) Condition Edc=5V, 25°C at DC Edc=5V, 25°C, at 50%RH Stable time: 20min 1 Response time to reach 90% of actual humidity from 30 to 85% RH Reference value EXAMPLE OF THERMAL CHARACTERISTICS (TEMPERATURE DEPENDENCY) at Edc=5V, Ta=25°C, 50%RH at Edc=5V, 25°C, 50%RH 2.2 2.2 2.0 2.0 1.8 1.8 90%RH 80%RH 70%RH 1.6 1.6 60%RH 1.4 1.2 1.0 0.8 7%RH 7%RH 0.6 Output voltage( V ) Output voltage( V ) EXAMPLE OF SENSOR LINEARITY CHARACTERISTICS 1.4 50%RH 1.2 1.0 40%RH 0.8 30%RH 0.6 0.4 0.4 20%RH 0.2 0.2 10%RH 0 0 10 20 30 40 50 60 70 80 90 100 Relative humidity (%RH) 0 5 10 15 20 25 30 35 Temperature ( °C) 40 45 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160622 / sensor_humidity_chs_en.fm (9/11) S E N S O R S Element CHS-ESS-CA5 FEATURES A resistance change-type humidity sensor with superior water and gas resistance in a small package. Features a large impedance change in response to humidity changes and exhibits excellent responsiveness and sensitivity. Guarantees a measurement accuracy of ±5% RH at 50% RH in humidity. The hysteresis of the humidity-sensitive characteristics is suppressed at about 1% RH. SHAPE & DIMENSIONS 6.5±0.5 3.7±0.5 Sensor face 3.4±1 9.0±0.5 Sensor face (0.5) 2.54 (0.25) Tolerance:±0.2mm Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160622 / sensor_humidity_chs_en.fm (10/11) S E N S O R S Element CHS-ESS-CA5 MAXIMUM RATINGS Power supply voltage Eac Operating conditions Storage conditions 7V max. (Ta=25°C) 0 to +60°C, 10 to 90%RH, no dew condensation –20 to +85°C, 5 to 95%RH, no dew condensation TYPICAL ELECTRICAL CHARACTERISTICS Item Driving voltage Eac(V) Operating current(mA) Output impedance(k:) Measurement accuracy(%RH) Min. 26 –5 62k: Hysteresis(%)RH Response time(min) Standard Max. 5 0.5 40 62 +5 40k: 26k: 1 1 Condition 25°C, at 50%RH Eac=1V, 25°C, at 50%RH 1 Response time to reach 90% of actual humidity from 30 to 85% RH IMPEDANCE-HUMIDITY CHARACTERISTICS (BY TEMPERATURE) IMPEDANCE-HUMIDITY CHARACTERISTICS (BY FREQUENCY) at Eac=1V, 1kHz at Eac=1V, 25°C 10000 10000 Impedance(k Ω ) 100000 Impedance(k Ω ) 100000 1000 100 5 ˚C 15 ˚C 25 ˚C 35 ˚C 45 ˚C 10 1 0 10 20 30 40 50 60 70 Relative humidity (%RH) 80 90 1000 100 100Hz 10 1 1kHz 10kHz 100kHz 0 10 20 30 40 50 60 70 Relative humidity (%RH) 80 90 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160622 / sensor_humidity_chs_en.fm (11/11) S E N S O R S CHS series Handling Precautions For CHS series products of all types Please request a delivery specification form containing more detailed information on characteristics and specifications so as to ensure correct and safe use of the products. Operating life of the products becomes shorter depending on the environmental conditions. If you are concerned with the stable operation period, please confirm the operating life in the actual environment in advance. [Storage Environment] Check the standards concerning the storage conditions described in the delivery specifications of the products, and store them in accordance with the standards. It is recommended that the products be stored in an airtight container with silica gel. Do not store this product in an environment in which corrosive gases are generated, entered, or stagnated, or in dusty environments. Storage in high temperature and high-humidity environments, environments where condensation occurs, or environments where sudden temperature changes occur may cause deterioration of the moisture sensitive film, resulting in fluctuations of output exceeding the guaranteed range. If the products have been stored in such environments, check their characteristics before use. Storage in environments where products may come into contact with water or saltwater may cause deterioration of the moisture sensitive film, resulting in fluctuations of output exceeding the guaranteed range. If the products have been stored in such environments, check their characteristics before use. Storage for an extended period of time may cause deterioration of the moisture sensitive film, resulting in fluctuations of output exceeding the guaranteed range. If the products have been stored for an extended period of time, check their characteristics before use. [Usage Environment/Operating Conditions] As for usage environment conditions and operating conditions of the products, check the standards concerning the usage environment conditions and operating conditions described in the delivery specifications, and use the products in accordance with the standards. The generation, influx, or stagnation of corrosive gases or a large amount of dust may become a cause of deterioration of the moisture sensitive film, resulting in fluctuations of output exceeding the guaranteed range. High temperature and high humidity, condensation, or sudden temperature changes may become a cause of deterioration of the moisture sensitive film, resulting in fluctuations of output exceeding the guaranteed range. Environments where the products come into contact with water or saltwater may become a cause of deterioration of the moisture sensitive film, resulting in fluctuations of output exceeding the guaranteed range. [Handling] Do not apply excessive mechanical shock such as dropping to the products. Do not cover the sensing surface of the products when mounting. Be careful not to apply excessive stress on the main unit when forming terminals. In a process such as flow soldering where flux decomposition gas is generated, take measures such as temporarily sealing the opening of the main unit to keep corrosive gas from entering (corrosive gas may become a cause of deterioration of the moisture sensitive film, resulting in fluctuations of output exceeding the guaranteed range). Element type [Usage Environment/Operating Conditions] The rated voltage of this product is "AC (Eac) 5Vmax". Please be reminded that serious damage such as electrolysis or peeling of the moisture sensitive material may occur if a direct current is applied to the products. In addition, please keep in mind that there may be effects similar to direct current application even when applying an alternating current, due to (1) residual direct current or (2) asymmetrical waveforms. Other Requests/Notices We do not assume any responsibility for any damage caused by the use of our products exceeding the scope or conditions defined in the delivery specifications. Specifications of the products in this catalog are subject to change without notice due to improvements or other reasons. In addition, supply of the products may be cancelled without notice. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160622 / sensor_humidity_chs_en.fm
CHS-MSS 价格&库存
很抱歉,暂时无法提供与“CHS-MSS”相匹配的价格&库存,您可以联系我们找货
CHS-MSS
    • 1+182.665151+23.63053
