C A P A C I T O R S
Disc type capacitors with leads
High voltage ceramic capacitors, commercial grade
RoHS
REACH
SVHC-Free
Cl
Br
Pb
Halogen
Free
Lead
Free
CK45 series
FEATURES
Conform to RoHS directive due to lead(Pb) free of lead-wire and internal solder material.
Compatible with halogen-free external resin coating.
APPLICATION
DC ballast
PART NUMBER CONSTRUCTION
CK45
-B
3AD
102
K
Y
N
A
Series
name
Temperature
characteristics
Rated
voltage
Nominal
capacitance
Capacitance
tolerance
Class
Lead-wire type
Application
classification
Internal code
-B
±10%
3AD 1kV DC
-E
+20, –55%
3DD 2kV DC
101 100pF
222 2,200pF
3FD 3kV DC
103 10,000pF
K
±10%
G
Long lead
Z
+80, –20%
N
Short lead
V
Taping
N
A
General
Halogen-free
Please refer to P-3~4 about the product dimensions.
OPERATING TEMPERATURE RANGE
Temperature characteristics
B
E
Storage temperature (°C)
–25 to +105
–25 to +105
Operating temperature (°C)
–25 to +105
–25 to +105
The maximum operating temperature of +105°C includes capacitor self-generated heat of up to 20°C.
After capacitor is mounted on board, the storage temperature range is applied.
STANDARD LEAD-WIRE SHAPES
Dimemsions in mm
Symbol N : Bulk/short leads
T
4max.
5±1
*2
25min.
Vertical kink
D*1
*2
T
4max.
D
Symbol V : Taping
ø0.6±0.05
F
*2
16+1.5
–0.5
*1
4max.
4max.
T
4max.
D*1
5±1
Symbol G : Bulk/long leads
F
F
ø0.6±0.05
ø0.6±0.05
TDK’s standard product is vertical kink. TDK recommends short leads for bulk products.
*1 Body diameter (D) is reference value if D is smaller than maximum dimension of lead to lead distance (F).
*2 Coating on leads shall not extend beyond the bottom of vertical kink.
RoHS Directive Compliant Product: See the following for more details. http://product.tdk.com/en/environment/rohs/
Halogen-free: Indicate that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm.
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/6)
20210108
leaddisc_commercial_ck45_en.fm
C A P A C I T O R S
Overview of CK45 series
RECOMMENDED FLOW PROFILE
Soldering
Preheating
Natural
cooling
T: Temperature
T2
T1
t1
t2
t3
t: Time
Preheating
Temp.
T1
110°C min.
Time
t1
30 to 60s.
Peak
Temp.
T2
260°C
Time
t2
Within 10s.
Natural cooling
Time
t3
Over 60s.
MARKINGS
D dimension: 6.0mm max.
Item
1. Nominal capacitance
Markings
221
Description
220pF
2. Capacitance tolerance
K
±10%
3. Rated voltage
1KV
1kV DC
Marking example
221K
1KV
D dimension: 6.5mm min., temperature characteristic: B
Item
1. Temperature characteristic
Markings
B
Description
B characteristic
2. Nominal capacitance
222
3. Capacitance tolerance
K
2,200pF
4. Rated voltage
2KV
±10%
Marking example
B
222K
2KV
2kV DC
D dimension: 6.5mm min., temperature characteristic: E
Item
Markings
222
Description
2,200pF
Z
+80,-20%
3. Rated voltage
1KV
1kV DC
4. Manufacturer
TDK
TDK
Marking example
222Z
1KV
TDK
(2/6)
20210108
C A P A C I T O R S
CK45 type
RATED VOLTAGE Edc: 1kV
CAPACITANCE AND DIMENSIONS
Dimensions (mm)
Temperature
Capacitance
F
Capacitance
characteristics
tolerance
Dmax. * Tmax. (applied
to bulk)
F
(applied
to taping)
Part numbers
B
100pF
±10%
(5.5)
5.0
5.0±1.5
5.0+0.8,–0.2 V1
B
150pF
±10%
(5.5)
5.0
5.0±1.5
5.0+0.8,–0.2 V1
B
220pF
±10%
(5.5)
5.0
5.0±1.5
B
330pF
±10%
(5.5)
5.0
B
470pF
±10%
(5.5)
5.0
B
680pF
±10%
(5.5)
B
1,000pF
±10%
6.0
B
1,500pF
±10%
B
2,200pF
B
Taping
Bulk/long leads
dimensions (Symbol: G)
Bulk/short leads
(Symbol: N)
Taping
(Symbol: V)
CK45-B3AD101KYGNA
CK45-B3AD101KYNNA
CK45-B3AD101KYVNA
CK45-B3AD151KYGNA
CK45-B3AD151KYNNA
CK45-B3AD151KYVNA
5.0+0.8,–0.2 V1
CK45-B3AD221KYGNA
CK45-B3AD221KYNNA
CK45-B3AD221KYVNA
5.0±1.5
5.0+0.8,–0.2 V1
CK45-B3AD331KYGNA
CK45-B3AD331KYNNA
CK45-B3AD331KYVNA
5.0±1.5
5.0+0.8,–0.2 V1
CK45-B3AD471KYGNA
CK45-B3AD471KYNNA
CK45-B3AD471KYVNA
5.0
5.0±1.5
5.0+0.8,–0.2 V1
CK45-B3AD681KYGNA
CK45-B3AD681KYNNA
CK45-B3AD681KYVNA
5.0
5.0±1.5
5.0+0.8,–0.2 V1
CK45-B3AD102KYGNA
CK45-B3AD102KYNNA
CK45-B3AD102KYVNA
7.0
5.0
5.0±1.5
5.0+0.8,–0.2 V1
CK45-B3AD152KYGNA
CK45-B3AD152KYNNA
CK45-B3AD152KYVNA
±10%
8.5
5.0
5.0±1.5
5.0+0.8,–0.2 V1
CK45-B3AD222KYGNA
CK45-B3AD222KYNNA
CK45-B3AD222KYVNA
3,300pF
±10%
9.5
5.0
5.0±1.5
5.0+0.8,–0.2 V1
CK45-B3AD332KYGNA
CK45-B3AD332KYNNA
CK45-B3AD332KYVNA
B
4,700pF
±10%
11.0
5.0
5.0±1.5
5.0+0.8,–0.2 V1
CK45-B3AD472KYGNA
CK45-B3AD472KYNNA
CK45-B3AD472KYVNA
E
470pF
+80, –20%
(5.5)
5.0
5.0±1.5
5.0+0.8, –0.2 V1
CK45-E3AD471ZYGNA
CK45-E3AD471ZYNNA
CK45-E3AD471ZYVNA
E
1,000pF
+80, –20%
(5.5)
5.0
5.0±1.5
5.0+0.8, –0.2 V1
CK45-E3AD102ZYGNA
CK45-E3AD102ZYNNA
CK45-E3AD102ZYVNA
E
2,200pF
+80, –20%
6.5
5.0
5.0±1.5
5.0+0.8, –0.2 V1
CK45-E3AD222ZYGNA
CK45-E3AD222ZYNNA
CK45-E3AD222ZYVNA
E
4,700pF
+80, –20%
8.5
5.0
5.0±1.5
5.0+0.8, –0.2 V1
CK45-E3AD472ZYGNA
CK45-E3AD472ZYNNA
CK45-E3AD472ZYVNA
E
10,000pF
+80, –20%
11.0
5.0
7.5±1.5
7.5±0.8
V2
CK45-E3AD103ZYGNA
CK45-E3AD103ZYNNA
CK45-E3AD103ZYVNA
Dimensions (mm)
Temperature
Capacitance
F
Capacitance
characteristics
tolerance
to bulk)
F
(applied
to taping)
Taping
Bulk/long leads
Bulk/short leads
(Symbol: N)
Taping
(Symbol: V)
B
100pF
±10%
(5.5)
5.0
5.0±1.5
5.0+0.8, –0.2 V1
CK45-B3DD101KYGNA
CK45-B3DD101KYNNA
CK45-B3DD101KYVNA
B
150pF
±10%
(5.5)
5.0
5.0±1.5
5.0+0.8, –0.2 V1
CK45-B3DD151KYGNA
CK45-B3DD151KYNNA
CK45-B3DD151KYVNA
B
220pF
±10%
(5.5)
5.0
5.0±1.5
5.0+0.8, –0.2 V1
CK45-B3DD221KYGNA
CK45-B3DD221KYNNA
CK45-B3DD221KYVNA
B
330pF
±10%
(5.5)
5.0
5.0±1.5
5.0+0.8, –0.2 V1
CK45-B3DD331KYGNA
CK45-B3DD331KYNNA
CK45-B3DD331KYVNA
B
470pF
±10%
(5.5)
5.0
5.0±1.5
5.0+0.8, –0.2 V1
CK45-B3DD471KYGNA
CK45-B3DD471KYNNA
CK45-B3DD471KYVNA
B
680pF
±10%
6.5
5.0
5.0±1.5
5.0+0.8, –0.2 V1
CK45-B3DD681KYGNA
CK45-B3DD681KYNNA
CK45-B3DD681KYVNA
B
1,000pF
±10%
7.5
5.0
5.0±1.5
5.0+0.8, –0.2 V1
CK45-B3DD102KYGNA
CK45-B3DD102KYNNA
CK45-B3DD102KYVNA
B
1,500pF
±10%
8.5
5.0
5.0±1.5
5.0+0.8, –0.2 V1
CK45-B3DD152KYGNA
CK45-B3DD152KYNNA
CK45-B3DD152KYVNA
The values in parentheses "( )" are reference values.
Click the part number for details.
Reference values are applied to bulk products.
Please refer to p-5 about the taping dimemsions.
RATED VOLTAGE Edc: 2kV
Part numbers
B
2,200pF
±10%
10.0
5.0
5.0±1.5
5.0+0.8, –0.2 V1
CK45-B3DD222KYGNA
CK45-B3DD222KYNNA
CK45-B3DD222KYVNA
B
3,300pF
±10%
11.5
5.0
7.5±1.5
7.5±0.8
V2
CK45-B3DD332KYGNA
CK45-B3DD332KYNNA
CK45-B3DD332KYVNA
B
4,700pF
±10%
14.0
5.0
7.5±1.5
7.5±0.8
V2
CK45-B3DD472KYGNA
CK45-B3DD472KYNNA
CK45-B3DD472KYVNA
E
470pF
+80, –20%
(5.5)
5.0
5.0±1.5
5.0+0.8, –0.2 V1
CK45-E3DD471ZYGNA
CK45-E3DD471ZYNNA
CK45-E3DD471ZYVNA
E
1,000pF
+80, –20%
(6.0)
5.0
5.0±1.5
5.0+0.8, –0.2 V1
CK45-E3DD102ZYGNA
CK45-E3DD102ZYNNA
CK45-E3DD102ZYVNA
E
2,200pF
+80, –20%
8.0
5.0
5.0±1.5
5.0+0.8, –0.2 V1
CK45-E3DD222ZYGNA
CK45-E3DD222ZYNNA
CK45-E3DD222ZYVNA
E
4,700pF
+80, –20%
10.5
5.0
5.0±1.5
5.0+0.8, –0.2 V1
CK45-E3DD472ZYGNA
CK45-E3DD472ZYNNA
CK45-E3DD472ZYVNA
E
10,000pF
+80, –20%
14.5
5.0
7.5±1.5
7.5±0.8
CK45-E3DD103ZYGNA
CK45-E3DD103ZYNNA
CK45-E3DD103ZYVNA
V3
• For more information about products with other capacitance or other data, please contact us.
(3/6)
20210108
C A P A C I T O R S
CK45 type
RATED VOLTAGE Edc: 3kV
Dimensions (mm)
Temperature
Capacitance
F
Capacitance
characteristics
tolerance
to bulk)
F
(applied
to taping)
Taping
Bulk/long leads
Part numbers
Bulk/short leads
(Symbol: N)
Taping
(Symbol: V)
B
100pF
±10%
(5.5)
6.0
7.5±1.5
7.5±0.8
V2
CK45-B3FD101KYGNA
CK45-B3FD101KYNNA
CK45-B3FD101KYVNA
B
150pF
±10%
(5.5)
6.0
7.5±1.5
7.5±0.8
V2
CK45-B3FD151KYGNA
CK45-B3FD151KYNNA
CK45-B3FD151KYVNA
B
220pF
±10%
(5.5)
6.0
7.5±1.5
7.5±0.8
V2
CK45-B3FD221KYGNA
CK45-B3FD221KYNNA
CK45-B3FD221KYVNA
B
330pF
±10%
(6.5)
6.0
7.5±1.5
7.5±0.8
V2
CK45-B3FD331KYGNA
CK45-B3FD331KYNNA
CK45-B3FD331KYVNA
B
470pF
±10%
(7.0)
6.0
7.5±1.5
7.5±0.8
V2
CK45-B3FD471KYGNA
CK45-B3FD471KYNNA
CK45-B3FD471KYVNA
B
680pF
±10%
(8.0)
6.0
7.5±1.5
7.5±0.8
V2
CK45-B3FD681KYGNA
CK45-B3FD681KYNNA
CK45-B3FD681KYVNA
B
1,000pF
±10%
9.0
6.0
7.5±1.5
7.5±0.8
V2
CK45-B3FD102KYGNA
CK45-B3FD102KYNNA
CK45-B3FD102KYVNA
B
1,500pF
±10%
10.5
6.0
7.5±1.5
7.5±0.8
V2
CK45-B3FD152KYGNA
CK45-B3FD152KYNNA
CK45-B3FD152KYVNA
B
2,200pF
±10%
12.5
6.0
7.5±1.5
7.5±0.8
V2
CK45-B3FD222KYGNA
CK45-B3FD222KYNNA
CK45-B3FD222KYVNA
E
470pF
+80, –20%
(6.0)
6.0
7.5±1.5
7.5±0.8
V2
CK45-E3FD471ZYGNA
CK45-E3FD471ZYNNA
CK45-E3FD471ZYVNA
E
1,000pF
+80, –20%
(7.5)
6.0
7.5±1.5
7.5±0.8
V2
CK45-E3FD102ZYGNA
CK45-E3FD102ZYNNA
CK45-E3FD102ZYVNA
E
2,200pF
+80, –20%
9.5
6.0
7.5±1.5
7.5±0.8
V2
CK45-E3FD222ZYGNA
CK45-E3FD222ZYNNA
CK45-E3FD222ZYVNA
E
4,700pF
+80, –20%
12.5
6.0
7.5±1.5
7.5±0.8
V2
CK45-E3FD472ZYGNA
CK45-E3FD472ZYNNA
CK45-E3FD472ZYVNA
(4/6)
20210108
C A P A C I T O R S
CK45 type
TAPING DIMENSIONS
P
P
P2
T
D*1
P2
h
T
D*1
h
h
S
H0
H0
L
W0
W
W0
W
ød
D0
ød
t
P0
V1, V2
V3
Item
Symbols
Dimensions (mm)
V1
V2
Body diameter
D
Refer to P-3~4
Body thickness
Lead-wire diameter
Pitch of component
Feed hole pitch
Feed hole center to lead-wire
Feed hole center to component center
Lead-to lead distance
Component alignment
Carrier tape width
Adhesive tape width
Hole position
Adhesive tape position
Bottom of kink from tape center
Lead-wire protrusion
Feed hole diameter
Carrier tape thickness
(Including adhesive tape)
Length of snipped lead-wire
T
ød
P
P0
P1
P2
F
h
W
W0
W1
W2
H0
D0
Refer to P-3~4
0.6±0.05
12.7±1.0
12.7±0.3
3.85±0.7
6.35±1.3
5+0.8, –0.2
0±2.0
18.0+1.0,–0.5
10.0 Min.
9.0±0.5
4.0 Max.
16.0+1.5,–0.5
1.0 Max.
4.0±0.2
0.6±0.05
15.0±1.0
15.0±0.3
3.75±0.7
7.5±1.3
7.5±0.8
0±2.0
18.0+1.0,–0.5
10.0 Min.
9.0±0.5
4.0 Max.
16.0+1.5,–0.5
1.0 Max.
4.0±0.2
0.6±0.05
30.0±1.0
15.0±0.3
3.75±0.7
7.5±1.3
7.5±0.8
0±2.0
18.0+1.0,–0.5
10.0 Min.
9.0±0.5
4.0 Max.
16.0+1.5,–0.5
1.0 Max.
4.0±0.2
t
0.6±0.3
0.6±0.3
0.6±0.3
L
11.0 Max.
11.0 Max.
11.0 Max.
Coating on lead-wire
C
4.0 Max.
4.0 Max.
4.0 Max.
Height of kink
Spring action
A
S
4.0 Max.
2.0 Max.
4.0 Max.
2.0 Max.
4.0 Max.
2.0 Max.
AMMO PACK INNER BOX SIZE
V3
t
D0
F
W1
L
W1
P0
P1
C*2
A
C*2
S
W2
F
H0
P1
W2
H0
A
h
Remarks
distance (F).
Including the slant of body
Excepting the tape splicing part
Including the slanting body due to bending lead-wire
Measuring point is bottom kink
Adhesive tape do not stick out the tape
PACKAGE QUANTITY
Package quantity
Type
Bulk (pieces / bag)
Taping (pieces / box)
1000
1000
CK45
320max.
500 pieces applies to the following part.
x.
ma
340max.
60
CK45-E3DD103ZYVNA
Dimensions in mm
(5/6)
20210108
C A P A C I T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and product temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
Please refer to the guideline of notabilia for fixed ceramic capacitors issued by JEITA(Japan Electronics and Information Technology
Association, EIAJ RCR-2335).
This guideline describes general precautions* for using fixed ceramic capacitors. Please carefully confirm it and use capacitors safely.
* Items for check, explanation/reason/concrete example and failure examples, etc.
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(6/6)
20210108
