C A P A C I T O R S
February 2016
Disc Type Capacitors with Lead
High Voltage Ceramic Capacitors
Commercial Grade
CK45 series
Type:
CK45 [B, E characteristics, Edc: 1kV to 3kV]
(2/11)
C A P A C I T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and product temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications
equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement
equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
Please refer to the guideline of notabilia for fixed ceramic capacitors issued by JEITA(Japan Electronics and Information Technology
Association, EIAJ RCR-2335).
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
20160219 / leaddisc_commercial_ck45_en.fm
(3/11)
C A P A C I T O R S
Product compatible with RoHS directive
Halogen-free
High Voltage Ceramic Capacitors, Commercial Grade
Overview of CK45 Series
FEATURES
These products shall conform to RoHS Directive due to lead(Pb) free of lead wire and internal solder material.
Compatible with halogen-free external resin coating.
APPLICATION
For use in DC ballast
PART NUMBER CONSTRUCTION
CK45 Series
name
B
3AD
102
K
Y
N
A
Temperature
characteristics
Rated
voltage
Nominal
capacitance
Capacitance
tolerance
Class
Lead type
Application
classification
Internal code
B
±10%
E +20, –55%
3AD 1kV
3DD 2kV
3FD 3kV
101 100pF
222 2,200pF
103 10,000pF
K
Z
±10%
+80, –20%
G
N
V
Long lead
Short lead
Taping
N General use
A
Halogen-free
Please refer to P-5~10 about the product dimensions.
OPERATING TEMPERATURE RANGE
Temperature
characteristics
B
E
Temperature range
Operating temperature
(°C)
–25 to +105
–25 to +105
Storage temperature
(°C)
–25 to +105
–25 to +105
The maximum operating temperature of 105°C includes capacitor self-generated heat of up to 20°C.
The storage temperature range applies to after MLCC is mounted on board.
PACKAGE QUANTITY
Package quantity
Type
Taping (pieces / box)
Bulk (pieces / bag)
1000
1000
CK45
500 pieces applies to the following part.
CK45-E3DD103ZYVNA
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm.
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(4/11)
C A P A C I T O R S
RECOMMENDED FLOW PROFILE
Soldering
Preheating
Natural
cooling
T: Temperature
T2
T1
t1
t2
t3
t: Time
Preheating
Temp.
T1
110°C min.
Time
t1
30 to 60s.
Peak
Temp.
T2
260°C
Time
t2
Within 10s.
Natural cooling
Time
t3
Over 60s.
(5/11)
C A P A C I T O R S
CK45 Type
CAPACITANCE AND DIMENSIONS
Temperature Characteristics: B (±10%)
Rated Voltage Edc: 1kV
Capacitance
(pF)
100
150
220
330
470
680
1,000
1,500
2,200
3,300
4,700
Dimensions (mm)
Capacitance
F
tolerance
D max. T max.
(Applied to bulk)
±10%
5.5
5.0
5.0±1.5
±10%
5.5
5.0
5.0±1.5
±10%
5.5
5.0
5.0±1.5
±10%
5.5
5.0
5.0±1.5
±10%
5.5
5.0
5.0±1.5
±10%
5.5
5.0
5.0±1.5
±10%
6.0
5.0
5.0±1.5
±10%
7.0
5.0
5.0±1.5
±10%
8.5
5.0
5.0±1.5
±10%
9.5
5.0
5.0±1.5
±10%
11.0
5.0
5.0±1.5
F
(Applied to taping)
5.0+0.8,–0.2
5.0+0.8,–0.2
5.0+0.8,–0.2
5.0+0.8,–0.2
5.0+0.8,–0.2
5.0+0.8,–0.2
5.0+0.8,–0.2
5.0+0.8,–0.2
5.0+0.8,–0.2
5.0+0.8,–0.2
5.0+0.8,–0.2
d
Taping
Part No.
dimensions
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
V1
V1
V1
V1
V1
V1
V1
V1
V1
V1
V1
CK45-B3AD101KY□NA
CK45-B3AD151KY□NA
CK45-B3AD221KY□NA
CK45-B3AD331KY□NA
CK45-B3AD471KY□NA
CK45-B3AD681KY□NA
CK45-B3AD102KY□NA
CK45-B3AD152KY□NA
CK45-B3AD222KY□NA
CK45-B3AD332KY□NA
CK45-B3AD472KY□NA
* The part numbers are TDK’s standard specification products.
The " □ " of the Part Number contains the lead type, G, N or V. Please refer to the details of each shape is shown below.
Please refer to P-11 about the taping dimemsions.
LIST OF STANDARD LEAD SHAPES
Dimemsions in mm
Symbol V
Taping
T
F
d
5±1
25min.
Vertical kink
F
T
4max.
D
4max.
D
T
4max.
D
Symbol N
Bulk/Short lead
16+1.5
–0.5
Symbol G
Bulk/Long lead
d
F
d
• TDK’s standard product is vertical kink.
• TDK’s recommendation is short lead type with the symbol N for bulk products.
(6/11)
C A P A C I T O R S
CK45 Type
Rated Voltage Edc: 2kV
Capacitance
(pF)
100
150
220
330
470
680
1,000
1,500
2,200
3,300
4,700
Dimensions (mm)
Capacitance
F
tolerance
D max. T max.
(Applied to bulk)
±10%
5.5
5.0
5.0±1.5
±10%
5.5
5.0
5.0±1.5
±10%
5.5
5.0
5.0±1.5
±10%
5.5
5.0
5.0±1.5
±10%
5.5
5.0
5.0±1.5
±10%
6.5
5.0
5.0±1.5
±10%
7.5
5.0
5.0±1.5
±10%
8.5
5.0
5.0±1.5
±10%
10.0
5.0
5.0±1.5
±10%
11.5
5.0
7.5±1.5
±10%
14.0
5.0
7.5±1.5
F
(Applied to taping)
5.0+0.8, –0.2
5.0+0.8, –0.2
5.0+0.8, –0.2
5.0+0.8, –0.2
5.0+0.8, –0.2
5.0+0.8, –0.2
5.0+0.8, –0.2
5.0+0.8, –0.2
5.0+0.8, –0.2
7.5±0.8
7.5±0.8
d
Taping
Part No.
dimensions
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
V1
V1
V1
V1
V1
V1
V1
V1
V1
V2
V2
CK45-B3DD101KY□NA
CK45-B3DD151KY□NA
CK45-B3DD221KY□NA
CK45-B3DD331KY□NA
CK45-B3DD471KY□NA
CK45-B3DD681KY□NA
CK45-B3DD102KY□NA
CK45-B3DD152KY□NA
CK45-B3DD222KY□NA
CK45-B3DD332KY□NA
CK45-B3DD472KY□NA
Dimemsions in mm
Symbol V
Taping
T
F
d
5±1
25min.
Vertical kink
F
T
4max.
D
4max.
D
T
4max.
D
Symbol N
Bulk/Short lead
16+1.5
–0.5
Symbol G
Bulk/Long lead
d
F
d
(7/11)
C A P A C I T O R S
CK45 Type
Rated Voltage Edc: 3kV
Capacitance
(pF)
100
150
220
330
470
680
1,000
1,500
2,200
Dimensions (mm)
Capacitance
F
tolerance
D max. T max.
(Applied to bulk)
±10%
5.5
6.0
7.5±1.5
±10%
5.5
6.0
7.5±1.5
±10%
5.5
6.0
7.5±1.5
±10%
6.5
6.0
7.5±1.5
±10%
7.0
6.0
7.5±1.5
±10%
8.0
6.0
7.5±1.5
±10%
9.0
6.0
7.5±1.5
±10%
10.5
6.0
7.5±1.5
±10%
12.5
6.0
7.5±1.5
F
(Applied to taping)
7.5±0.8
7.5±0.8
7.5±0.8
7.5±0.8
7.5±0.8
7.5±0.8
7.5±0.8
7.5±0.8
7.5±0.8
d
Taping
Part No.
dimensions
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
V2
V2
V2
V2
V2
V2
V2
V2
V2
CK45-B3FD101KY□NA
CK45-B3FD151KY□NA
CK45-B3FD221KY□NA
CK45-B3FD331KY□NA
CK45-B3FD471KY□NA
CK45-B3FD681KY□NA
CK45-B3FD102KY□NA
CK45-B3FD152KY□NA
CK45-B3FD222KY□NA
Dimemsions in mm
Symbol V
Taping
T
F
d
5±1
25min.
Vertical kink
F
T
4max.
D
4max.
D
T
4max.
D
Symbol N
Bulk/Short lead
16+1.5
–0.5
Symbol G
Bulk/Long lead
d
F
d
(8/11)
C A P A C I T O R S
CK45 Type
Temperature Characteristics: E (+20, –55%)
Capacitance
(pF)
470
1,000
2,200
4,700
10,000
Dimensions (mm)
Capacitance
F
tolerance
D max. T max.
(Applied to bulk)
+80, –20%
5.5
5.0
5.0±1.5
+80, –20%
5.5
5.0
5.0±1.5
+80, –20%
6.5
5.0
5.0±1.5
+80, –20%
8.5
5.0
5.0±1.5
+80, –20%
11.5
5.0
7.5±1.5
F
(Applied to taping)
5.0+0.8, –0.2
5.0+0.8, –0.2
5.0+0.8, –0.2
5.0+0.8, –0.2
7.5±0.8
d
Taping
Part No.
dimensions
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
V1
V1
V1
V1
V2
CK45-E3AD471ZY□NA
CK45-E3AD102ZY□NA
CK45-E3AD222ZY□NA
CK45-E3AD472ZY□NA
CK45-E3AD103ZY□NA
Dimemsions in mm
Symbol V
Taping
T
F
d
5±1
25min.
Vertical kink
F
T
4max.
D
4max.
D
T
4max.
D
Symbol N
Bulk/Short lead
16+1.5
–0.5
Symbol G
Bulk/Long lead
d
F
d
(9/11)
C A P A C I T O R S
CK45 Type
Capacitance
(pF)
470
1,000
2,200
4,700
10,000
Dimensions (mm)
Capacitance
F
tolerance
D max. T max.
(Applied to bulk)
+80, –20%
5.5
5.0
5.0±1.5
+80, –20%
6.0
5.0
5.0±1.5
+80, –20%
8.0
5.0
5.0±1.5
+80, –20%
10.5
5.0
5.0±1.5
+80, –20%
14.5
5.0
7.5±1.5
F
(Applied to taping)
5.0+0.8, –0.2
5.0+0.8, –0.2
5.0+0.8, –0.2
5.0+0.8, –0.2
7.5±0.8
d
Taping
Part No.
dimensions
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
V1
V1
V1
V1
V3
CK45-E3DD471ZY□NA
CK45-E3DD102ZY□NA
CK45-E3DD222ZY□NA
CK45-E3DD472ZY□NA
CK45-E3DD103ZY□NA
Dimemsions in mm
Symbol V
Taping
T
F
d
5±1
25min.
Vertical kink
F
T
4max.
D
4max.
D
T
4max.
D
Symbol N
Bulk/Short lead
16+1.5
–0.5
Symbol G
Bulk/Long lead
d
F
d
(10/11)
C A P A C I T O R S
CK45 Type
Capacitance
(pF)
470
1,000
2,200
4,700
Dimensions (mm)
Capacitance
F
tolerance
D max. T max.
(Applied to bulk)
+80, –20%
6.0
6.0
7.5±1.5
+80, –20%
7.5
6.0
7.5±1.5
+80, –20%
9.5
6.0
7.5±1.5
+80, –20%
12.5
6.0
7.5±1.5
F
(Applied to taping)
7.5±0.8
7.5±0.8
7.5±0.8
7.5±0.8
d
Taping
Part No.
dimensions
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
V2
V2
V2
V2
CK45-E3FD471ZY□NA
CK45-E3FD102ZY□NA
CK45-E3FD222ZY□NA
CK45-E3FD472ZY□NA
Dimemsions in mm
Symbol V
Taping
T
F
d
5±1
25min.
Vertical kink
F
T
4max.
D
4max.
D
T
4max.
D
Symbol N
Bulk/Short lead
16+1.5
–0.5
Symbol G
Bulk/Long lead
d
F
d
(11/11)
C A P A C I T O R S
CK45 Type
TAPING DIMEMSIONS
D
T
P2
P
D
Δh
T
P2
C
H0
S
W0
W
W0
W
D0
P0
ød
P1 F
D0
ød
t
t
P0
Δh
L
L
W1
H0
H1
S
H0
C
W2
H0
H1
W1
P1 F
Δh
A
A
Δh
W2
P
V1, V2
Item
V3
Symbol
Dimensions(mm)
V1
V2
V3
Remarks
Body diameter
D
Depends on the specification of each product.
Body thickness
T
Lead-wire diameter
ød
0.6±0.05
0.6±0.05
Pitch of component
P
12.7±1.0
15.0±1.0
30.0±1.0
Including the slant of body
Feed hole pitch
P0
12.7±0.3
15.0±0.3
15.0±0.3
Excepting the tape splicing part
Feed hole center to lead
P1
3.85±0.7
3.75±0.7
3.75±0.7
Feed hole center to component center
P2
6.35±1.3
7.5±1.3
7.5±1.3
Lead-to lead distance
F
5+0.8, –0.2
7.5±0.8
7.5±0.8
Measuring point is bottom kink
Component alignment
'h
0±2.0
0±2.0
0±2.0
Including the slanting body due to bending lead-wire
Tape width
W
18.0+1.0, –0.5 18.0+1.0, –0.5 18.0+1.0, –0.5
Adhesive tape width
W0
10.0min.
10.0min.
10.0min.
Hole position
W1
9.0±0.5
9.0±0.5
9.0±0.5
Adhesive tape position
W2
4.0max.
4.0max.
4.0max.
Bottom of kink from tape center
H0
16.0+1.5, –0.5 16.0+1.5, –0.5 16.0+1.5, –0.5
Height of body from tape center
H1
46.0max.
46.0max.
46.0max.
1.0max.
1.0max.
1.0max.
Lead-wire protrusion
0.6±0.05
Feed hole diameter
D0
4.0±0.2
4.0±0.2
4.0±0.2
Total tape thickness
t
0.6±0.3
0.6±0.3
0.6±0.3
Length of snipped lead
L
11.0max.
11.0max.
11.0max.
Coating on lead
C
4.0max.
4.0max.
4.0max.
Height of kink
A
4.0max.
4.0max.
4.0max.
Spring action
S
2.0max.
2.0max.
2.0max.
Adhesive tape do not stick out the tape
Including adhesive tape
320max.
AMMO PACK INNER BOX SIZE
x.
ma
340max.
60
Dimensions in mm
• For more information about products with other capacitance or other data, please contact us.
