CK45-B3DD121KYNR
CK45-B3DD121KYNR
    TDK(东电化)
    插件
    120 pF ±10% 2000V(2kV) 陶瓷电容器 B 径向,圆片式
CK45-B3DD121KYNR 数据手册
Mid-high Voltage Ceramic Capacitors Disk type with lead Low dissipation at high frequency General use CK45-RB series Issue date: July 2011 • All specifications are subject to change without notice. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. (1/3) Mid-high Voltage Ceramic Capacitors(Disk with Lead) Conformity to RoHS Directive Low Dissipation at High Frequency CK45-RB Series FEATURES • High voltage ceramic capacitors series, low dissipation factor and higher reliability has been achieved through the use of TDK original dielectric and copper for electrode material due to nice matching of the ceramic dielectrics material for low dissipation factor, and copper for electrode. • These capacitors have lower dissipation, and have a lower selfheating temperature than the Type 2 mid-high voltage ceramic capacitors. This makes it perfect for high-frequency, high-voltage circuits such as color TV horizontal circuits. • Low dissipation factor, and decreased self-heating temperature in the high frequency, and high voltage application. • These products shall conform to RoHS Directive due to lead(Pb) free of lead wire and internal solder material. • This product is compatible with halogen-free external resin coating (we recommend halogen-free products as standard). OPERATING TEMPERATURE RANGE: –25 to +105°C (The maximum operating temperature of 105°C includes capacitor self-generated heat of up to 20°C.) PRODUCT IDENTIFICATION CK 45 -B 3AD 102 K Y N R A (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (1) Type (2) Shape (3) Capacitance temperature characteristics (4) Rated voltage (5) Nominal capacitance (6) Capacitance tolerance (7) Class (8) Lead type (9) Low dissipation (10) Halogen-free compatible product CAPACITANCE TEMPERATURE CHARACTERISTICS AND TOLERANCE Temperature characteristics B(±10%) Test temperature range –25 to +85°C Capacitance tolerance K(±10%) CAPACITANCE AND DIMENSIONS TEMPERATURE CHARACTERISTICS: B(±10%) RATED VOLTAGE Edc: 1kV Part No. Halogen-free product CK45-B3AD101KY†∗RA CK45-B3AD151KY†RA CK45-B3AD221KY†RA CK45-B3AD331KY†RA CK45-B3AD471KY†RA CK45-B3AD681KY†RA CK45-B3AD102KY†RA CK45-B3AD152KY†RA CK45-B3AD222KY†RA Current product CK45-B3AD101KY†∗R CK45-B3AD151KY†R CK45-B3AD221KY†R CK45-B3AD331KY†R CK45-B3AD471KY†R CK45-B3AD681KY†R CK45-B3AD102KY†R CK45-B3AD152KY†R CK45-B3AD222KY†R Capacitance (pF) 100 150 220 330 470 680 1,000 1,500 2,200 Dimensions(mm) D max. T max. 7.5 5.0 7.5 5.0 7.5 5.0 7.5 5.0 7.5 5.0 8.0 5.0 9.0 5.0 10.0 5.0 11.5 5.0 F 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 7.5±1.5 d 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 Taping dimensions V1 V1 V1 V1 V1 V1 V1 V1 V2 Capacitance (pF) 100 150 220 330 470 680 1,000 1,500 2,200 Dimensions(mm) D max. T max. 7.5 5.0 7.5 5.0 7.5 5.0 8.0 5.0 8.5 5.0 10.0 5.0 11.0 5.0 12.5 5.0 14.5 5.0 F 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 7.5±1.5 7.5±1.5 d 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 Taping dimensions V1 V1 V1 V1 V1 V1 V1 V2 V3 ∗ † : Lead shape symbol • 1kV and 2kV are E6 series standard products. RATED VOLTAGE Edc: 2kV Part No. Halogen-free product CK45-B3DD101KY†∗RA CK45-B3DD151KY†RA CK45-B3DD221KY†RA CK45-B3DD331KY†RA CK45-B3DD471KY†RA CK45-B3DD681KY†RA CK45-B3DD102KY†RA CK45-B3DD152KY†RA CK45-B3DD222KY†RA Current product CK45-B3DD101KY†∗R CK45-B3DD151KY†R CK45-B3DD221KY†R CK45-B3DD331KY†R CK45-B3DD471KY†R CK45-B3DD681KY†R CK45-B3DD102KY†R CK45-B3DD152KY†R CK45-B3DD222KY†R ∗ † : Lead shape symbol • We recommend using a Halogen-free product. • 1kV and 2kV are E6 series standard products. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 003-02 / 20110711 / e4a3_rb.fm (2/3) CAPACITANCE AND DIMENSIONS TEMPERATURE CHARACTERISTICS: B(±10%) RATED VOLTAGE Edc: 3kV Part No. Halogen-free product CK45-B3FD101KY†∗RA CK45-B3FD151KY†RA CK45-B3FD221KY†RA CK45-B3FD331KY†RA CK45-B3FD471KY†RA CK45-B3FD681KY†RA CK45-B3FD102KY†RA CK45-B3FD152KY†RA ∗ Capacitance (pF) 100 150 220 330 470 680 1,000 1,500 Current product CK45-B3FD101KY†∗R CK45-B3FD151KY†R CK45-B3FD221KY†R CK45-B3FD331KY†R CK45-B3FD471KY†R CK45-B3FD681KY†R CK45-B3FD102KY†R CK45-B3FD152KY†R Dimensions(mm) D max. T max. 7.5 6.0 7.5 6.0 7.5 6.0 8.0 6.0 10.0 6.0 11.0 6.0 12.5 6.0 14.5 6.0 F 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 Taping dimensions V2 V2 V2 V2 V2 V2 V2 V3 d 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 † : Lead shape symbol LIST OF STANDARD LEAD SHAPES The lead type is indicated by the letter which is the 15th character of the product name. Example) TDK Product Name: CK45-B3AD102KYNRA N: Lead type (Vertical kink, Short) Dimensions in mm T Taping Symbol V D T 4max. D 4max. D Short lead Symbol N F d 16+1.5 –0.5 F 5±1 25min. Vertical kink T 4max. Long lead Symbol G d • We recommend using a vertical kink type. • For bulk products, we recommend a short lead type with the symbol N. • All specifications are subject to change without notice. 003-02 / 20110711 / e4a3_rb.fm (3/3) TAPING DIMEMSIONS VERTICAL KINK LEAD TYPE D P T P2 D ∆h T P2 ∆h H0 S W0 W L W1 L W0 W P0 D0 ød P1 F D0 ød t t P0 C H0 H1 S H0 W2 C A H0 H1 W1 P1 F ∆h A ∆h W2 P V3 V1, V2 Item Symbol Dimensions(mm) V1 V2 V3 Remarks Body diameter D Depends on the specification of each product. Body thickness T Depends on the specification of each product. Lead-wire diameter ød 0.6±0.05 0.6±0.05 0.6±0.05 Pitch of component P 12.7±1.0 15.0±1.0 30.0±1.0 Including the slant of body Feed hole pitch P0 12.7±0.3 15.0±0.3 15.0±0.3 Excepting the tape splicing part Feed hole center to lead P1 3.85±0.7 3.75±0.7 3.75±0.7 Feed hole center to component center P2 6.35±1.3 7.5±1.3 7.5±1.3 Lead-to lead distance F 5+0.8, –0.2 7.5±0.8 7.5±0.8 Measuring point is bottom kink Component alignment ∆h 0±2.0 0±2.0 0±2.0 Including the slanting body due to bending lead-wire Tape width W 18.0+1.0, –0.5 18.0+1.0, –0.5 18.0+1.0, –0.5 Adhesive tape width W0 11.5min. 11.5min. 11.5min. Hole position W1 9.0±0.5 9.0±0.5 9.0±0.5 Adhesive tape position W2 3.0max. 3.0max. 3.0max. Bottom of kink from tape center H0 16.0+1.5, –0.5 16.0+1.5, –0.5 16.0+1.5, –0.5 Height of body from tape center H1 46.0max. 46.0max. 46.0max. 1.0max. 1.0max. 1.0max. Lead-wire protrusion Feed hole diameter D0 4.0±0.2 4.0±0.2 4.0±0.2 Total tape thickness t 0.6±0.3 0.6±0.3 0.6±0.3 Length of snipped lead L 11.0max. 11.0max. 11.0max. Coating on lead C 4.0max. 4.0max. 4.0max. Height of kink A 4.0max. 4.0max. 4.0max. Spring action S 2.0max. 2.0max. 2.0max. Adhesive tape do not stick out the tape Do not including adhesive tape Measuring point is bottom kink • For more information about products with other capacitance or other data, please contact us. • All specifications are subject to change without notice. 003-02 / 20110711 / e4a3_rb.fm
CK45-B3DD121KYNR 价格&库存
很抱歉,暂时无法提供与“CK45-B3DD121KYNR”相匹配的价格&库存,您可以联系我们找货
