Mid-high Voltage Ceramic Capacitors
Disk type with lead
Low dissipation at high frequency
General use
CK45-RB series
Issue date:
July 2011
• All specifications are subject to change without notice.
• Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific
bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications.
(1/3)
Mid-high Voltage Ceramic Capacitors(Disk with Lead) Conformity to RoHS Directive
Low Dissipation at High Frequency CK45-RB Series
FEATURES
• High voltage ceramic capacitors series, low dissipation factor
and higher reliability has been achieved through the use of TDK
original dielectric and copper for electrode material due to nice
matching of the ceramic dielectrics material for low dissipation
factor, and copper for electrode.
• These capacitors have lower dissipation, and have a lower selfheating temperature than the Type 2 mid-high voltage ceramic
capacitors. This makes it perfect for high-frequency, high-voltage
circuits such as color TV horizontal circuits.
• Low dissipation factor, and decreased self-heating temperature
in the high frequency, and high voltage application.
• These products shall conform to RoHS Directive due to lead(Pb)
free of lead wire and internal solder material.
• This product is compatible with halogen-free external resin
coating (we recommend halogen-free products as standard).
OPERATING TEMPERATURE RANGE: –25 to +105°C
(The maximum operating temperature of 105°C includes capacitor
self-generated heat of up to 20°C.)
PRODUCT IDENTIFICATION
CK 45 -B 3AD 102 K Y N R A
(1) (2) (3) (4) (5) (6) (7) (8) (9) (10)
(1) Type
(2) Shape
(3) Capacitance temperature
characteristics
(4) Rated voltage
(5) Nominal capacitance
(6) Capacitance tolerance
(7) Class
(8) Lead type
(9) Low dissipation
(10) Halogen-free compatible product
CAPACITANCE TEMPERATURE CHARACTERISTICS
AND TOLERANCE
Temperature characteristics
B(±10%)
Test temperature
range
–25 to +85°C
Capacitance
tolerance
K(±10%)
CAPACITANCE AND DIMENSIONS
TEMPERATURE CHARACTERISTICS: B(±10%)
RATED VOLTAGE Edc: 1kV
Part No.
Halogen-free product
CK45-B3AD101KY∗RA
CK45-B3AD151KYRA
CK45-B3AD221KYRA
CK45-B3AD331KYRA
CK45-B3AD471KYRA
CK45-B3AD681KYRA
CK45-B3AD102KYRA
CK45-B3AD152KYRA
CK45-B3AD222KYRA
Current product
CK45-B3AD101KY∗R
CK45-B3AD151KYR
CK45-B3AD221KYR
CK45-B3AD331KYR
CK45-B3AD471KYR
CK45-B3AD681KYR
CK45-B3AD102KYR
CK45-B3AD152KYR
CK45-B3AD222KYR
Capacitance
(pF)
100
150
220
330
470
680
1,000
1,500
2,200
Dimensions(mm)
D max.
T max.
7.5
5.0
7.5
5.0
7.5
5.0
7.5
5.0
7.5
5.0
8.0
5.0
9.0
5.0
10.0
5.0
11.5
5.0
F
5±1.5
5±1.5
5±1.5
5±1.5
5±1.5
5±1.5
5±1.5
5±1.5
7.5±1.5
d
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
Taping
dimensions
V1
V1
V1
V1
V1
V1
V1
V1
V2
Capacitance
(pF)
100
150
220
330
470
680
1,000
1,500
2,200
Dimensions(mm)
D max.
T max.
7.5
5.0
7.5
5.0
7.5
5.0
8.0
5.0
8.5
5.0
10.0
5.0
11.0
5.0
12.5
5.0
14.5
5.0
F
5±1.5
5±1.5
5±1.5
5±1.5
5±1.5
5±1.5
5±1.5
7.5±1.5
7.5±1.5
d
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
Taping
dimensions
V1
V1
V1
V1
V1
V1
V1
V2
V3
: Lead shape symbol
• 1kV and 2kV are E6 series standard products.
RATED VOLTAGE Edc: 2kV
Part No.
CK45-B3DD101KY∗RA
CK45-B3DD151KYRA
CK45-B3DD221KYRA
CK45-B3DD331KYRA
CK45-B3DD471KYRA
CK45-B3DD681KYRA
CK45-B3DD102KYRA
CK45-B3DD152KYRA
CK45-B3DD222KYRA
Current product
CK45-B3DD101KY∗R
CK45-B3DD151KYR
CK45-B3DD221KYR
CK45-B3DD331KYR
CK45-B3DD471KYR
CK45-B3DD681KYR
CK45-B3DD102KYR
CK45-B3DD152KYR
CK45-B3DD222KYR
: Lead shape symbol
• We recommend using a Halogen-free product.
003-02 / 20110711 / e4a3_rb.fm
(2/3)
RATED VOLTAGE Edc: 3kV
Part No.
CK45-B3FD101KY∗RA
CK45-B3FD151KYRA
CK45-B3FD221KYRA
CK45-B3FD331KYRA
CK45-B3FD471KYRA
CK45-B3FD681KYRA
CK45-B3FD102KYRA
CK45-B3FD152KYRA
Capacitance
(pF)
100
150
220
330
470
680
1,000
1,500
Current product
CK45-B3FD101KY∗R
CK45-B3FD151KYR
CK45-B3FD221KYR
CK45-B3FD331KYR
CK45-B3FD471KYR
CK45-B3FD681KYR
CK45-B3FD102KYR
CK45-B3FD152KYR
Dimensions(mm)
D max.
T max.
7.5
6.0
7.5
6.0
7.5
6.0
8.0
6.0
10.0
6.0
11.0
6.0
12.5
6.0
14.5
6.0
F
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
Taping
dimensions
V2
V2
V2
V2
V2
V2
V2
V3
d
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
: Lead shape symbol
LIST OF STANDARD LEAD SHAPES
The lead type is indicated by the letter which is the 15th character of the product name.
Example) TDK Product Name: CK45-B3AD102KYNRA
N: Lead type (Vertical kink, Short)
Dimensions in mm
T
Taping
Symbol V
D
T
4max.
D
4max.
D
Short lead
Symbol N
F
d
16+1.5
–0.5
F
5±1
25min.
Vertical kink
T
4max.
Long lead
Symbol G
d
• We recommend using a vertical kink type.
• For bulk products, we recommend a short lead type with the symbol N.
(3/3)
TAPING DIMEMSIONS
VERTICAL KINK LEAD TYPE
D
P
T
P2
D
∆h
T
P2
∆h
H0
S
W0
W
L
W1
L
W0
W
P0
D0
ød
P1 F
D0
ød
t
t
P0
C
H0
H1
S
H0
W2
C
A
H0
H1
W1
P1 F
∆h
A
∆h
W2
P
V3
V1, V2
Item
Symbol
Dimensions(mm)
V1
V2
V3
Remarks
Body diameter
D
Depends on the specification of each product.
Body thickness
T
Lead-wire diameter
ød
0.6±0.05
0.6±0.05
0.6±0.05
Pitch of component
P
12.7±1.0
15.0±1.0
30.0±1.0
Including the slant of body
Feed hole pitch
P0
12.7±0.3
15.0±0.3
15.0±0.3
Excepting the tape splicing part
Feed hole center to lead
P1
3.85±0.7
3.75±0.7
3.75±0.7
Feed hole center to component
center
P2
6.35±1.3
7.5±1.3
7.5±1.3
Lead-to lead distance
F
5+0.8, –0.2
7.5±0.8
7.5±0.8
Measuring point is bottom kink
Component alignment
∆h
0±2.0
0±2.0
0±2.0
Including the slanting body due to bending lead-wire
Tape width
W
18.0+1.0, –0.5 18.0+1.0, –0.5 18.0+1.0, –0.5
Adhesive tape width
W0
11.5min.
11.5min.
11.5min.
Hole position
W1
9.0±0.5
9.0±0.5
9.0±0.5
Adhesive tape position
W2
3.0max.
3.0max.
3.0max.
Bottom of kink from tape center
H0
16.0+1.5, –0.5 16.0+1.5, –0.5 16.0+1.5, –0.5
Height of body from tape center
H1
46.0max.
46.0max.
46.0max.
1.0max.
1.0max.
1.0max.
Lead-wire protrusion
Feed hole diameter
D0
4.0±0.2
4.0±0.2
4.0±0.2
Total tape thickness
t
0.6±0.3
0.6±0.3
0.6±0.3
Length of snipped lead
L
11.0max.
11.0max.
11.0max.
Coating on lead
C
4.0max.
4.0max.
4.0max.
Height of kink
A
4.0max.
4.0max.
4.0max.
Spring action
S
2.0max.
2.0max.
2.0max.
Adhesive tape do not stick out the tape
Do not including adhesive tape
• For more information about products with other capacitance or other data, please contact us.
很抱歉,暂时无法提供与“CK45-B3DD222KYNR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+2.454401000+0.31752
