CK45-B3DD272KYNN
CK45-B3DD272KYNN
    TDK(东电化)
    Radial
    贴片电容(MLCC) 径向 2.7nF ±10% 2KV B
CK45-B3DD272KYNN 数据手册
(1/2) Mid-high Voltage Ceramic Capacitors(Disk with Lead) General Use CK45 Series SHAPES AND DIMENSIONS øD max. CAPACITANCE TEMPERATURE CHARACTERISTICS AND TOLERANCE 4max. 4max. 5±1 T max. 5±1 ø0.6±0.05 F Temperature characteristics B(±10%) E(+20, –55%) CK45-B3AD101KYNN to CK45-B3AD681KYNN CK45-B3AD821KYNN CK45-B3AD102KYNN CK45-B3AD122KYNN CK45-B3AD152KYNN CK45-B3AD182KYNN CK45-B3AD222KYNN CK45-B3AD272KYNN CK45-B3AD332KYNN CK45-B3AD392KYNN CK45-B3AD472KYNN CK45-B3AD562KYNN CK45-B3AD682KYNN CK45-B3AD822KYNN CK45-B3AD103KYNN Temperature range –25 to +85°C –25 to +85°C Capacitance tolerance K(±10%) Z(+80, –20%) Dimensions in mm CAPACITANCE AND DIMENSIONS TEMPERATURE CHARACTERISTICS: B(±10%) RATED VOLTAGE Edc: 1kV Part No. Conformity to RoHS Directive Capacitance (pF) 100∗ , 120, 150∗ 180, 220∗ , 270 330∗ , 390, 470∗ 560, 680∗ 820 1,000∗ 1,200 1,500∗ 1,800 2,200∗ 2,700 3,300∗ 3,900 4,700∗ 5,600 6,800∗ 8,200 10,000∗ RATED VOLTAGE Edc: 3kV Dimensions (mm) øD max. T max. F 5.5 5 5±1.5 6 6 6.5 7 7.5 8.5 9 9.5 10 11 12 13 14 15 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 Part No. CK45-B3FD101KYNN CK45-B3FD121KYNN CK45-B3FD151KYNN CK45-B3FD181KYNN CK45-B3FD221KYNN CK45-B3FD271KYNN CK45-B3FD331KYNN CK45-B3FD391KYNN CK45-B3FD471KYNN CK45-B3FD561KYNN CK45-B3FD681KYNN CK45-B3FD821KYNN CK45-B3FD102KYNN CK45-B3FD122KYNN CK45-B3FD152KYNN CK45-B3FD182KYNN CK45-B3FD222KYNN CK45-B3FD272KYNN CK45-B3FD332KYNN Capacitance (pF) 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 Dimensions (mm) øD max. T max. F 5.5 6 7.5±1.5 5.5 6 7.5±1.5 5.5 6 7.5±1.5 5.5 6 7.5±1.5 5.5 6 7.5±1.5 6 6 7.5±1.5 6.5 6 7.5±1.5 6.5 6 7.5±1.5 7 6 7.5±1.5 7.5 6 7.5±1.5 8 6 7.5±1.5 8.5 6 7.5±1.5 9 6 7.5±1.5 9.5 6 7.5±1.5 10.5 6 7.5±1.5 11.5 6 7.5±1.5 12.5 6 7.5±1.5 13.5 6 7.5±1.5 14.5 6 7.5±1.5 RATED VOLTAGE Edc: 2kV Part No. CK45-B3DD101KYNN to CK45-B3DD471KYNN CK45-B3DD561KYNN CK45-B3DD681KYNN CK45-B3DD821KYNN CK45-B3DD102KYNN CK45-B3DD122KYNN CK45-B3DD152KYNN CK45-B3DD182KYNN CK45-B3DD222KYNN CK45-B3DD272KYNN CK45-B3DD332KYNN CK45-B3DD392KYNN CK45-B3DD472KYNN ∗ Capacitance (pF) 100∗ , 120, 150∗ 180, 220∗ , 270 330∗ , 470∗ 560 680∗ 820 1,000∗ 1,200 1,500∗ 1,800 2,200∗ 2,700 3,300∗ 3,900 4,700∗ Dimensions (mm) øD max. T max. F 5.5 5 5±1.5 6 6.5 7 7.5 8 8.5 9 10 10.5 11.5 12.5 14 5 5 5 5 5 5 5 5 5 5 5 5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 1kV and 2kV are E6 series standard products in Temperature characteristics B. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 003-01 / 20060618 / e413_ck45.fm (2/2) CAPACITANCE AND DIMENSIONS TEMPERATURE CHARACTERISTICS: E(+20, –55%) RATED VOLTAGE Edc: 1kV Part No. CK45-E3AD471ZYNN CK45-E3AD681ZYNN CK45-E3AD102ZYNN CK45-E3AD152ZYNN CK45-E3AD222ZYNN CK45-E3AD332ZYNN CK45-E3AD472ZYNN CK45-E3AD682ZYNN CK45-E3AD103ZYNN Capacitance (pF) 470∗ 680 1,000∗ 1,500 2,200∗ 3,300 4,700∗ 6,800 10,000∗ Dimensions (mm) øD max. T max. F 5.5 5 5±1.5 5.5 5 5±1.5 5.5 5 5±1.5 5.5 5 5±1.5 6.5 5 5±1.5 7.5 5 5±1.5 8.5 5 5±1.5 10 5 5±1.5 11.5 5 7.5±1.5 RATED VOLTAGE Edc: 2kV Part No. CK45-E3DD471ZYNN CK45-E3DD681ZYNN CK45-E3DD102ZYNN CK45-E3DD152ZYNN CK45-E3DD222ZYNN CK45-E3DD332ZYNN CK45-E3DD472ZYNN CK45-E3DD682ZYNN CK45-E3DD103ZYNN ∗ Capacitance (pF) 470∗ 680 1,000∗ 1,500 2,200∗ 3,300 4,700∗ 6,800 10,000∗ Dimensions (mm) øD max. T max. F 5.5 5 5±1.5 5.5 5 5±1.5 6 5 5±1.5 7 5 5±1.5 8 5 5±1.5 9 5 5±1.5 10.5 5 5±1.5 12.5 5 7.5±1.5 14.5 5 7.5±1.5 1kV and 2kV are E3 series standard products in Temperature characteristics E. RATED VOLTAGE Edc: 3kV Part No. CK45-E3FD471ZYNN CK45-E3FD681ZYNN CK45-E3FD102ZYNN CK45-E3FD152ZYNN CK45-E3FD222ZYNN CK45-E3FD332ZYNN CK45-E3FD472ZYNN CK45-E3FD682ZYNN CK45-E3FD103ZYNN Capacitance (pF) 470 680 1,000 1,500 2,200 3,300 4,700 6,800 10,000 Dimensions (mm) øD max. T max. F 6 6 7.5±1.5 6.5 6 7.5±1.5 7.5 6 7.5±1.5 8.5 6 7.5±1.5 9.5 6 7.5±1.5 11.5 6 7.5±1.5 12.5 6 7.5±1.5 15 6 7.5±1.5 17.5 6 10±2 • For more information about products with other capacitance or other data, please contact us. • All specifications are subject to change without notice. 003-01 / 20060618 / e413_ck45.fm
CK45-B3DD272KYNN
物料型号:CK45系列
器件简介:该系列是符合RoHS指令的中高压陶瓷电容器,具有不同的电容值和尺寸。
引脚分配:文档中未提供引脚分配信息。
参数特性: - 电容温度特性和容差:包括B(±10%)、E(+20%,-55%)和Z(+80%,-20%)等级。 - 额定直流电压(Edc):提供1kV、2kV和3kV的选项。
功能详解:文档中未提供详细的功能解释,但通常这类电容器用于电源滤波、能量存储等。
应用信息:适用于一般用途,特别是需要符合RoHS指令的应用。
封装信息:提供了详细的尺寸信息,包括最大外径(øD max.)、最大高度(T max.)和引脚长度(F)。
CK45-B3DD272KYNN 价格&库存
很抱歉,暂时无法提供与“CK45-B3DD272KYNN”相匹配的价格&库存,您可以联系我们找货
