CK45-R3AD271K-NR
CK45-R3AD271K-NR
    TDK(东电化)
    插件
    贴片电容(MLCC) 径向 270pF ±10% 1KV R
CK45-R3AD271K-NR 数据手册
(1/1) Mid-high Voltage Ceramic Capacitors(Disk with Lead) Conformity to RoHS Directive Low Dissipation at High Frequency CK45-RR Series SHAPES AND DIMENSIONS 4max. 4max. 5±1 Part No. 5±1 ø0.6±0.05 RATED VOLTAGE Edc: 2kV T max. øD max. F Dimensions in mm CAPACITANCE TEMPERATURE CHARACTERISTICS AND TOLERANCE Temperature characteristics R(+15, –30%) Temperature range –25 to +125°C Capacitance tolerance K(±10%) CAPACITANCE AND DIMENSIONS RATED VOLTAGE Edc: 1kV Part No. CK45-R3AD101K-NR CK45-R3AD121K-NR CK45-R3AD151K-NR CK45-R3AD181K-NR CK45-R3AD221K-NR CK45-R3AD271K-NR CK45-R3AD331K-NR CK45-R3AD391K-NR CK45-R3AD471K-NR CK45-R3AD561K-NR CK45-R3AD681K-NR CK45-R3AD821K-NR CK45-R3AD102K-NR CK45-R3AD122K-NR CK45-R3AD152K-NR CK45-R3AD182K-NR CK45-R3AD222K-NR CK45-R3AD272K-NR CK45-R3AD332K-NR CK45-R3AD392K-NR CK45-R3AD472K-NR Capacitance (pF) 100∗ 120 150∗ 180 220∗ 270 330∗ 390 470∗ 560 680∗ 820 1,000∗ 1,200 1,500∗ 1,800 2,200∗ 2,700 3,300∗ 3,900 4,700∗ Dimensions (mm) øD max. T max. 6 5 6 5 6 5 6 5 6 5 6 5 6.5 5 6.5 5 7 5 7.5 5 8 5 8.5 5 9 5 9.5 5 10 5 10.5 5 11.5 5 12.5 5 13.5 5 14.5 5 15.5 5 ∗ 1kV and 2kV are E6 series standard products. F 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 10±2 CK45-R3DD101K-NR CK45-R3DD121K-NR CK45-R3DD151K-NR CK45-R3DD181K-NR CK45-R3DD221K-NR CK45-R3DD271K-NR CK45-R3DD331K-NR CK45-R3DD391K-NR CK45-R3DD471K-NR CK45-R3DD561K-NR CK45-R3DD681K-NR CK45-R3DD821K-NR CK45-R3DD102K-NR CK45-R3DD122K-NR CK45-R3DD152K-NR CK45-R3DD182K-NR CK45-R3DD222K-NR CK45-R3DD272K-NR CK45-R3DD332K-NR CK45-R3DD392K-NR CK45-R3DD472K-NR Capacitance (pF) 100∗ 120 150∗ 180 220∗ 270 330∗ 390 470∗ 560 680∗ 820 1,000∗ 1,200 1,500∗ 1,800 2,200∗ 2,700 3,300∗ 3,900 4,700∗ Dimensions (mm) øD max. T max. 6 5 6 5 6 5 6.5 5 7 5 7 5 7.5 5 8 5 8.5 5 9 5 9.5 5 10 5 11 5 11.5 5 12 5 13.5 5 14.5 5 15.5 5 17 5 18 5 19.5 5 F 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 10±2 10±2 10±2 10±2 ∗ 1kV and 2kV are E6 series standard products. RATED VOLTAGE Edc: 3kV Part No. CK45-R3FD101K-NR CK45-R3FD121K-NR CK45-R3FD151K-NR CK45-R3FD181K-NR CK45-R3FD221K-NR CK45-R3FD271K-NR CK45-R3FD331K-NR CK45-R3FD391K-NR CK45-R3FD471K-NR CK45-R3FD561K-NR CK45-R3FD681K-NR CK45-R3FD821K-NR CK45-R3FD102K-NR CK45-R3FD122K-NR CK45-R3FD152K-NR CK45-R3FD182K-NR CK45-R3FD222K-NR CK45-R3FD272K-NR Capacitance (pF) 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 Dimensions (mm) øD max. T max. 6 6 6.5 6 7 6 7 6 7.5 6 8 6 8.5 6 9 6 9.5 6 10 6 10.5 6 11.5 6 12 6 13 6 14.5 6 15.5 6 16.5 6 18 6 F 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 10±2 10±2 10±2 • For more information about the products of other capacitance or data, please contact us. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 004-01 / 20060618 / e4937_rr.fm
CK45-R3AD271K-NR 价格&库存
很抱歉,暂时无法提供与“CK45-R3AD271K-NR”相匹配的价格&库存,您可以联系我们找货
