Disc Type Capacitors with Lead
High Voltage Ceramic Capacitors
Automotive Grad
Low dissipation at high frequency
CK45-RR series
Issue date:
February 2013
• All specifications are subject to change without notice.
• Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific
bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications.
(1/3)
Automotive Grade
CK45-RR Series
FEATURES
• AEC-Q200 compliant.
• 1,000 cycles guaranteed under heat shock testing at –55°C to
+125°C.
• It can be used as a capacitor for snubber circuits used in
automobiles (EV, HEV).
• High voltage ceramic capacitors series, low dissipation factor
and higher reliability has been achieved through the use of TDK
original dielectric and copper for electrode material due to nice
matching of the ceramic dielectrics material for low dissipation
factor, and copper for electrode.
• Low dissipation factor, and decreased self-heating temperature
in the high frequency, and high voltage application.
• Compatible with halogen-free external resin coating.
PRODUCT IDENTIFICATION
OPERATING TEMPERATURE RANGE: –40 to +125°C
(The maximum operating temperature of 125°C includes capacitor
self-generated heat of up to 20°C.)
TEMPERATURE CHARACTERISTICS AND TOLERANCE
CK 45 -R 3AD 102 K A N R A
(1) (2) (3) (4) (5) (6) (7) (8) (9) (10)
(1) Type
(2) Shape
(3) Temperature characteristics
(4) Rated voltage
(5) Nominal capacitance
(6) Capacitance tolerance
(7) For use in automobiles
(8) Lead type
(9) Low dissipation
(10) Halogen-free compatible product
R (+15, –30%)
Test temperature
range
–25 to +125°C
Capacitance
tolerance
K (±10%)
001-01 / 20130207 / leaddisc_automotive_rr_en.fm
(2/3)
CAPACITANCE AND DIMENSIONS
TEMPERATURE CHARACTERISTICS: R (+15, –30%)
RATED VOLTAGE Edc: 1kV
Part No.
CK45-R3AD101KARA
CK45-R3AD151KARA
CK45-R3AD221KARA
CK45-R3AD331KARA
CK45-R3AD471KARA
CK45-R3AD681KARA
CK45-R3AD102KARA
CK45-R3AD152KARA
CK45-R3AD222KARA
Capacitance
(pF)
100
150
220
330
470
680
1,000
1,500
2,200
Dimensions (mm)
D max.
T max.
6.0
5.0
6.0
5.0
7.0
5.0
7.5
5.0
8.5
5.0
9.5
5.0
11.0
5.0
12.5
5.0
15.0
5.0
F
5.0±1.5
5.0±1.5
5.0±1.5
5.0±1.5
5.0±1.5
5.0±1.5
5.0±1.5
7.5±1.5
7.5±1.5
d
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
Capacitance
(pF)
100
150
220
330
470
680
1,000
Dimensions (mm)
D max.
T max.
6.0
6.0
7.0
6.0
7.5
6.0
8.5
6.0
9.5
6.0
10.5
6.0
12.5
6.0
F
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
d
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
Taping dimensions
V1
V1
V1
V1
V1
V1
V1
V2
V3
: Lead shape symbol
RATED VOLTAGE Edc: 2kV
Part No.
CK45-R3DD101KARA
CK45-R3DD151KARA
CK45-R3DD221KARA
CK45-R3DD331KARA
CK45-R3DD471KARA
CK45-R3DD681KARA
CK45-R3DD102KARA
Taping dimensions
V2
V2
V2
V2
V2
V2
V2
: Lead shape symbol
LIST OF STANDARD LEAD SHAPES
The lead type is indicated by the letter which is the 15th character of the product name.
Example) TDK Product Name: CK45-R3AD102KANRA
N: Lead type (Vertical kink, Short)
Dimensions in mm
T
Taping
Symbol V
D
D
T
4max.
4max.
D
Short lead
Symbol N
F
d
16+1.5
–0.5
F
5±1
25min.
Vertical kink
T
4max.
Long lead
Symbol G
d
• We recommend using a vertical kink type.
• For bulk products, we recommend a short lead type with the symbol N.
(3/3)
TAPING DIMEMSIONS
VERTICAL KINK LEAD TYPE
D
P
T
P2
D
Δh
T
P2
Δh
H0
S
W0
W
L
W1
L
W0
W
P0
D0
P1 F
D0
ød
ød
t
t
P0
C
H0
H1
S
H0
W2
C
A
H0
H1
W1
P1 F
Δh
A
Δh
W2
P
V3
V1, V2
Item
Symbol
Dimensions (mm)
V1
V2
V3
Remarks
Body diameter
D
Depends on the specification of each product.
Body thickness
T
Lead-wire diameter
ød
0.6±0.05
0.6±0.05
0.6±0.05
Pitch of component
P
12.7±1.0
15.0±1.0
30.0±1.0
Including the slant of body
Feed hole pitch
P0
12.7±0.3
15.0±0.3
15.0±0.3
Excepting the tape splicing part
Feed hole center to lead
P1
3.85±0.7
3.75±0.7
3.75±0.7
Feed hole center to component
center
P2
6.35±1.3
7.5±1.3
7.5±1.3
Lead-to lead distance
F
5+0.8, –0.2
7.5±0.8
7.5±0.8
Measuring point is bottom kink
Component alignment
h
0±2.0
0±2.0
0±2.0
Including the slanting body due to bending lead-wire
Tape width
W
18.0+1.0, –0.5 18.0+1.0, –0.5 18.0+1.0, –0.5
Adhesive tape width
W0
10.0min.
10.0min.
10.0min.
Hole position
W1
9.0±0.5
9.0±0.5
9.0±0.5
Adhesive tape position
W2
4.0max.
4.0max.
4.0max.
Bottom of kink from tape center
H0
16.0+1.5, –0.5 16.0+1.5, –0.5 16.0+1.5, –0.5
Height of body from tape center
H1
46.0max.
46.0max.
46.0max.
1.0max.
1.0max.
1.0max.
Lead-wire protrusion
Feed hole diameter
D0
4.0±0.2
4.0±0.2
4.0±0.2
Total tape thickness
t
0.6±0.3
0.6±0.3
0.6±0.3
Length of snipped lead
L
11.0max.
11.0max.
11.0max.
Coating on lead
C
4.0max.
4.0max.
4.0max.
Height of kink
A
4.0max.
4.0max.
4.0max.
Spring action
S
2.0max.
2.0max.
2.0max.
Adhesive tape do not stick out the tape
Including adhesive tape
• For more information about products with other capacitance or other data, please contact us.
很抱歉,暂时无法提供与“CK45-R3DD102KANRA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+10.74528
- 30+10.37475
- 100+9.63370
- 500+8.89264
- 1000+8.52212
